path: root/mm
2011-01-07install_special_mapping skips security_file_mmap check.Tavis Ormandy
commit 462e635e5b73ba9a4c03913b77138cd57ce4b050 upstream. The install_special_mapping routine (used, for example, to setup the vdso) skips the security check before insert_vm_struct, allowing a local attacker to bypass the mmap_min_addr security restriction by limiting the available pages for special mappings. bprm_mm_init() also skips the check, and although I don't think this can be used to bypass any restrictions, I don't see any reason not to have the security check. $ uname -m x86_64 $ cat /proc/sys/vm/mmap_min_addr 65536 $ cat install_special_mapping.s section .bss resb BSS_SIZE section .text global _start _start: mov eax, __NR_pause int 0x80 $ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s $ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o $ ./install_special_mapping & [1] 14303 $ cat /proc/14303/maps 0000f000-00010000 r-xp 00000000 00:00 0 [vdso] 00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping 00011000-ffffe000 rwxp 00000000 00:00 0 [stack] It's worth noting that Red Hat are shipping with mmap_min_addr set to 4096. Signed-off-by: Tavis Ormandy <taviso@google.com> Acked-by: Kees Cook <kees@ubuntu.com> Acked-by: Robert Swiecki <swiecki@google.com> [ Changed to not drop the error code - akpm ] Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09perf_events: Fix perf_counter_mmap() hook in mprotect()Pekka Enberg
commit 63bfd7384b119409685a17d5c58f0b56e5dc03da upstream. As pointed out by Linus, commit dab5855 ("perf_counter: Add mmap event hooks to mprotect()") is fundamentally wrong as mprotect_fixup() can free 'vma' due to merging. Fix the problem by moving perf_event_mmap() hook to mprotect_fixup(). Note: there's another successful return path from mprotect_fixup() if old flags equal to new flags. We don't, however, need to call perf_event_mmap() there because 'perf' already knows the VMA is executable. Reported-by: Dave Jones <davej@redhat.com> Analyzed-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09nommu: yield CPU while disposing VMSteven J. Magnani
commit 04c3496152394d17e3bc2316f9731ee3e8a026bc upstream. Depending on processor speed, page size, and the amount of memory a process is allowed to amass, cleanup of a large VM may freeze the system for many seconds. This can result in a watchdog timeout. Make sure other tasks receive some service when cleaning up large VMs. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Cc: Greg Ungerer <gerg@snapgear.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09mm/vfs: revalidate page->mapping in do_generic_file_read()Dave Hansen
commit 8d056cb965b8fb7c53c564abf28b1962d1061cd3 upstream. 70 hours into some stress tests of a 2.6.32-based enterprise kernel, we ran into a NULL dereference in here: int block_is_partially_uptodate(struct page *page, read_descriptor_t *desc, unsigned long from) { ----> struct inode *inode = page->mapping->host; It looks like page->mapping was the culprit. (xmon trace is below). After closer examination, I realized that do_generic_file_read() does a find_get_page(), and eventually locks the page before calling block_is_partially_uptodate(). However, it doesn't revalidate the page->mapping after the page is locked. So, there's a small window between the find_get_page() and ->is_partially_uptodate() where the page could get truncated and page->mapping cleared. We _have_ a reference, so it can't get reclaimed, but it certainly can be truncated. I think the correct thing is to check page->mapping after the trylock_page(), and jump out if it got truncated. This patch has been running in the test environment for a month or so now, and we have not seen this bug pop up again. xmon info: 1f:mon> e cpu 0x1f: Vector: 300 (Data Access) at [c0000002ae36f770] pc: c0000000001e7a6c: .block_is_partially_uptodate+0xc/0x100 lr: c000000000142944: .generic_file_aio_read+0x1e4/0x770 sp: c0000002ae36f9f0 msr: 8000000000009032 dar: 0 dsisr: 40000000 current = 0xc000000378f99e30 paca = 0xc000000000f66300 pid = 21946, comm = bash 1f:mon> r R00 = 0025c0500000006d R16 = 0000000000000000 R01 = c0000002ae36f9f0 R17 = c000000362cd3af0 R02 = c000000000e8cd80 R18 = ffffffffffffffff R03 = c0000000031d0f88 R19 = 0000000000000001 R04 = c0000002ae36fa68 R20 = c0000003bb97b8a0 R05 = 0000000000000000 R21 = c0000002ae36fa68 R06 = 0000000000000000 R22 = 0000000000000000 R07 = 0000000000000001 R23 = c0000002ae36fbb0 R08 = 0000000000000002 R24 = 0000000000000000 R09 = 0000000000000000 R25 = c000000362cd3a80 R10 = 0000000000000000 R26 = 0000000000000002 R11 = c0000000001e7b60 R27 = 0000000000000000 R12 = 0000000042000484 R28 = 0000000000000001 R13 = c000000000f66300 R29 = c0000003bb97b9b8 R14 = 0000000000000001 R30 = c000000000e28a08 R15 = 000000000000ffff R31 = c0000000031d0f88 pc = c0000000001e7a6c .block_is_partially_uptodate+0xc/0x100 lr = c000000000142944 .generic_file_aio_read+0x1e4/0x770 msr = 8000000000009032 cr = 22000488 ctr = c0000000001e7a60 xer = 0000000020000000 trap = 300 dar = 0000000000000000 dsisr = 40000000 1f:mon> t [link register ] c000000000142944 .generic_file_aio_read+0x1e4/0x770 [c0000002ae36f9f0] c000000000142a14 .generic_file_aio_read+0x2b4/0x770 (unreliable) [c0000002ae36fb40] c0000000001b03e4 .do_sync_read+0xd4/0x160 [c0000002ae36fce0] c0000000001b153c .vfs_read+0xec/0x1f0 [c0000002ae36fd80] c0000000001b1768 .SyS_read+0x58/0xb0 [c0000002ae36fe30] c00000000000852c syscall_exit+0x0/0x40 --- Exception: c00 (System Call) at 00000080a840bc54 SP (fffca15df30) is in userspace 1f:mon> di c0000000001e7a6c c0000000001e7a6c e9290000 ld r9,0(r9) c0000000001e7a70 418200c0 beq c0000000001e7b30 # .block_is_partially_uptodate+0xd0/0x100 c0000000001e7a74 e9440008 ld r10,8(r4) c0000000001e7a78 78a80020 clrldi r8,r5,32 c0000000001e7a7c 3c000001 lis r0,1 c0000000001e7a80 812900a8 lwz r9,168(r9) c0000000001e7a84 39600001 li r11,1 c0000000001e7a88 7c080050 subf r0,r8,r0 c0000000001e7a8c 7f805040 cmplw cr7,r0,r10 c0000000001e7a90 7d6b4830 slw r11,r11,r9 c0000000001e7a94 796b0020 clrldi r11,r11,32 c0000000001e7a98 419d00a8 bgt cr7,c0000000001e7b40 # .block_is_partially_uptodate+0xe0/0x100 c0000000001e7a9c 7fa55840 cmpld cr7,r5,r11 c0000000001e7aa0 7d004214 add r8,r0,r8 c0000000001e7aa4 79080020 clrldi r8,r8,32 c0000000001e7aa8 419c0078 blt cr7,c0000000001e7b20 # .block_is_partially_uptodate+0xc0/0x100 Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: <arunabal@in.ibm.com> Cc: <sbest@us.ibm.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09mm: fix is_mem_section_removable() page_order BUG_ON checkKAMEZAWA Hiroyuki
commit 572438f9b52236bd8938b1647cc15e027d27ef55 upstream. page_order() is called by memory hotplug's user interface to check the section is removable or not. (is_mem_section_removable()) It calls page_order() withoug holding zone->lock. So, even if the caller does if (PageBuddy(page)) ret = page_order(page) ... The caller may hit BUG_ON(). For fixing this, there are 2 choices. 1. add zone->lock. 2. remove BUG_ON(). is_mem_section_removable() is used for some "advice" and doesn't need to be 100% accurate. This is_removable() can be called via user program.. We don't want to take this important lock for long by user's request. So, this patch removes BUG_ON(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09mm: fix return value of scan_lru_pages in memory unplugKAMEZAWA Hiroyuki
commit f8f72ad5396987e05a42cf7eff826fb2a15ff148 upstream. scan_lru_pages returns pfn. So, it's type should be "unsigned long" not "int". Note: I guess this has been work until now because memory hotplug tester's machine has not very big memory.... physical address < 32bit << PAGE_SHIFT. Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09numa: fix slab_node(MPOL_BIND)Eric Dumazet
commit 800416f799e0723635ac2d720ad4449917a1481c upstream. When a node contains only HighMem memory, slab_node(MPOL_BIND) dereferences a NULL pointer. [ This code seems to go back all the way to commit 19770b32609b: "mm: filter based on a nodemask as well as a gfp_mask". Which was back in April 2008, and it got merged into 2.6.26. - Linus ] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22mm, x86: Saving vmcore with non-lazy freeing of vmasCliff Wickman
commit 3ee48b6af49cf534ca2f481ecc484b156a41451d upstream. During the reading of /proc/vmcore the kernel is doing ioremap()/iounmap() repeatedly. And the buildup of un-flushed vm_area_struct's is causing a great deal of overhead. (rb_next() is chewing up most of that time). This solution is to provide function set_iounmap_nonlazy(). It causes a subsequent call to iounmap() to immediately purge the vma area (with try_purge_vmap_area_lazy()). With this patch we have seen the time for writing a 250MB compressed dump drop from 71 seconds to 44 seconds. Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: kexec@lists.infradead.org LKML-Reference: <E1OwHZ4-0005WK-Tw@eag09.americas.sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28mm: Move vma_stack_continue into mm.hStefan Bader
commit 39aa3cb3e8250db9188a6f1e3fb62ffa1a717678 upstream. So it can be used by all that need to check for that. Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26guard page for stacks that grow upwardsLuck, Tony
commit 8ca3eb08097f6839b2206e2242db4179aee3cfb3 upstream. pa-risc and ia64 have stacks that grow upwards. Check that they do not run into other mappings. By making VM_GROWSUP 0x0 on architectures that do not ever use it, we can avoid some unpleasant #ifdefs in check_stack_guard_page(). Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: dann frazier <dannf@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26mm: page allocator: update free page counters after pages are placed on the ↵Mel Gorman
free list commit 72853e2991a2702ae93aaf889ac7db743a415dd3 upstream. When allocating a page, the system uses NR_FREE_PAGES counters to determine if watermarks would remain intact after the allocation was made. This check is made without interrupts disabled or the zone lock held and so is race-prone by nature. Unfortunately, when pages are being freed in batch, the counters are updated before the pages are added on the list. During this window, the counters are misleading as the pages do not exist yet. When under significant pressure on systems with large numbers of CPUs, it's possible for processes to make progress even though they should have been stalled. This is particularly problematic if a number of the processes are using GFP_ATOMIC as the min watermark can be accidentally breached and in extreme cases, the system can livelock. This patch updates the counters after the pages have been added to the list. This makes the allocator more cautious with respect to preserving the watermarks and mitigates livelock possibilities. [akpm@linux-foundation.org: avoid modifying incoming args] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26mm: page allocator: calculate a better estimate of NR_FREE_PAGES when memory ↵Christoph Lameter
is low and kswapd is awake commit aa45484031ddee09b06350ab8528bfe5b2c76d1c upstream. Ordinarily watermark checks are based on the vmstat NR_FREE_PAGES as it is cheaper than scanning a number of lists. To avoid synchronization overhead, counter deltas are maintained on a per-cpu basis and drained both periodically and when the delta is above a threshold. On large CPU systems, the difference between the estimated and real value of NR_FREE_PAGES can be very high. If NR_FREE_PAGES is much higher than number of real free page in buddy, the VM can allocate pages below min watermark, at worst reducing the real number of pages to zero. Even if the OOM killer kills some victim for freeing memory, it may not free memory if the exit path requires a new page resulting in livelock. This patch introduces a zone_page_state_snapshot() function (courtesy of Christoph) that takes a slightly more accurate view of an arbitrary vmstat counter. It is used to read NR_FREE_PAGES while kswapd is awake to avoid the watermark being accidentally broken. The estimate is not perfect and may result in cache line bounces but is expected to be lighter than the IPI calls necessary to continually drain the per-cpu counters while kswapd is awake. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26mm: page allocator: drain per-cpu lists after direct reclaim allocation failsMel Gorman
commit 9ee493ce0a60bf42c0f8fd0b0fe91df5704a1cbf upstream. When under significant memory pressure, a process enters direct reclaim and immediately afterwards tries to allocate a page. If it fails and no further progress is made, it's possible the system will go OOM. However, on systems with large amounts of memory, it's possible that a significant number of pages are on per-cpu lists and inaccessible to the calling process. This leads to a process entering direct reclaim more often than it should increasing the pressure on the system and compounding the problem. This patch notes that if direct reclaim is making progress but allocations are still failing that the system is already under heavy pressure. In this case, it drains the per-cpu lists and tries the allocation a second time before continuing. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26percpu: fix pcpu_last_unit_cpuTejun Heo
commit 46b30ea9bc3698bc1d1e6fd726c9601d46fa0a91 upstream. pcpu_first/last_unit_cpu are used to track which cpu has the first and last units assigned. This in turn is used to determine the span of a chunk for man/unmap cache flushes and whether an address belongs to the first chunk or not in per_cpu_ptr_to_phys(). When the number of possible CPUs isn't power of two, a chunk may contain unassigned units towards the end of a chunk. The logic to determine pcpu_last_unit_cpu was incorrect when there was an unused unit at the end of a chunk. It failed to ignore the unused unit and assigned the unused marker NR_CPUS to pcpu_last_unit_cpu. This was discovered through kdump failure which was caused by malfunctioning per_cpu_ptr_to_phys() on a kvm setup with 50 possible CPUs by CAI Qian. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20memory hotplug: fix next block calculation in is_removableKAMEZAWA Hiroyuki
commit 0dcc48c15f63ee86c2fcd33968b08d651f0360a5 upstream. next_active_pageblock() is for finding next _used_ freeblock. It skips several blocks when it finds there are a chunk of free pages lager than pageblock. But it has 2 bugs. 1. We have no lock. page_order(page) - pageblock_order can be minus. 2. pageblocks_stride += is wrong. it should skip page_order(p) of pages. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20bounce: call flush_dcache_page() after bounce_copy_vec()Gary King
commit ac8456d6f9a3011c824176bd6084d39e5f70a382 upstream. I have been seeing problems on Tegra 2 (ARMv7 SMP) systems with HIGHMEM enabled on 2.6.35 (plus some patches targetted at 2.6.36 to perform cache maintenance lazily), and the root cause appears to be that the mm bouncing code is calling flush_dcache_page before it copies the bounce buffer into the bio. The bounced page needs to be flushed after data is copied into it, to ensure that architecture implementations can synchronize instruction and data caches if necessary. Signed-off-by: Gary King <gking@nvidia.com> Cc: Tejun Heo <tj@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26vmscan: raise the bar to PAGEOUT_IO_SYNC stallsWu Fengguang
commit e31f3698cd3499e676f6b0ea12e3528f569c4fa3 upstream. Fix "system goes unresponsive under memory pressure and lots of dirty/writeback pages" bug. http://lkml.org/lkml/2010/4/4/86 In the above thread, Andreas Mohr described that Invoking any command locked up for minutes (note that I'm talking about attempted additional I/O to the _other_, _unaffected_ main system HDD - such as loading some shell binaries -, NOT the external SSD18M!!). This happens when the two conditions are both meet: - under memory pressure - writing heavily to a slow device OOM also happens in Andreas' system. The OOM trace shows that 3 processes are stuck in wait_on_page_writeback() in the direct reclaim path. One in do_fork() and the other two in unix_stream_sendmsg(). They are blocked on this condition: (sc->order && priority < DEF_PRIORITY - 2) which was introduced in commit 78dc583d (vmscan: low order lumpy reclaim also should use PAGEOUT_IO_SYNC) one year ago. That condition may be too permissive. In Andreas' case, 512MB/1024 = 512KB. If the direct reclaim for the order-1 fork() allocation runs into a range of 512KB hard-to-reclaim LRU pages, it will be stalled. It's a severe problem in three ways. Firstly, it can easily happen in daily desktop usage. vmscan priority can easily go below (DEF_PRIORITY - 2) on _local_ memory pressure. Even if the system has 50% globally reclaimable pages, it still has good opportunity to have 0.1% sized hard-to-reclaim ranges. For example, a simple dd can easily create a big range (up to 20%) of dirty pages in the LRU lists. And order-1 to order-3 allocations are more than common with SLUB. Try "grep -v '1 :' /proc/slabinfo" to get the list of high order slab caches. For example, the order-1 radix_tree_node slab cache may stall applications at swap-in time; the order-3 inode cache on most filesystems may stall applications when trying to read some file; the order-2 proc_inode_cache may stall applications when trying to open a /proc file. Secondly, once triggered, it will stall unrelated processes (not doing IO at all) in the system. This "one slow USB device stalls the whole system" avalanching effect is very bad. Thirdly, once stalled, the stall time could be intolerable long for the users. When there are 20MB queued writeback pages and USB 1.1 is writing them in 1MB/s, wait_on_page_writeback() will stuck for up to 20 seconds. Not to mention it may be called multiple times. So raise the bar to only enable PAGEOUT_IO_SYNC when priority goes below DEF_PRIORITY/3, or 6.25% LRU size. As the default dirty throttle ratio is 20%, it will hardly be triggered by pure dirty pages. We'd better treat PAGEOUT_IO_SYNC as some last resort workaround -- its stall time is so uncomfortably long (easily goes beyond 1s). The bar is only raised for (order < PAGE_ALLOC_COSTLY_ORDER) allocations, which are easy to satisfy in 1TB memory boxes. So, although 6.25% of memory could be an awful lot of pages to scan on a system with 1TB of memory, it won't really have to busy scan that much. Andreas tested an older version of this patch and reported that it mostly fixed his problem. Mel Gorman helped improve it and KOSAKI Motohiro will fix it further in the next patch. Reported-by: Andreas Mohr <andi@lisas.de> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26slab: fix object alignmentCarsten Otte
commit 1ab335d8f85792e3b107ff8237d53cf64db714df upstream. This patch fixes alignment of slab objects in case CONFIG_DEBUG_PAGEALLOC is active. Before this spot in kmem_cache_create, we have this situation: - align contains the required alignment of the object - cachep->obj_offset is 0 or equals align in case of CONFIG_DEBUG_SLAB - size equals the size of the object, or object plus trailing redzone in case of CONFIG_DEBUG_SLAB This spot tries to fill one page per object if the object is in certain size limits, however setting obj_offset to PAGE_SIZE - size does break the object alignment since size may not be aligned with the required alignment. This patch simply adds an ALIGN(size, align) to the equation and fixes the object size detection accordingly. This code in drivers/s390/cio/qdio_setup_init has lead to incorrectly aligned slab objects (sizeof(struct qdio_q) equals 1792): qdio_q_cache = kmem_cache_create("qdio_q", sizeof(struct qdio_q), 256, 0, NULL); Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26mm: make stack guard page logic use vm_prev pointerLinus Torvalds
commit 0e8e50e20c837eeec8323bba7dcd25fe5479194c upstream. Like the mlock() change previously, this makes the stack guard check code use vma->vm_prev to see what the mapping below the current stack is, rather than have to look it up with find_vma(). Also, accept an abutting stack segment, since that happens naturally if you split the stack with mlock or mprotect. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26mm: make the mlock() stack guard page checks stricterLinus Torvalds
commit 7798330ac8114c731cfab83e634c6ecedaa233d7 upstream. If we've split the stack vma, only the lowest one has the guard page. Now that we have a doubly linked list of vma's, checking this is trivial. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26mm: make the vma list be doubly linkedLinus Torvalds
commit 297c5eee372478fc32fec5fe8eed711eedb13f3d upstream. It's a really simple list, and several of the users want to go backwards in it to find the previous vma. So rather than have to look up the previous entry with 'find_vma_prev()' or something similar, just make it doubly linked instead. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-20mm: fix up some user-visible effects of the stack guard pageLinus Torvalds
commit d7824370e26325c881b665350ce64fb0a4fde24a upstream. This commit makes the stack guard page somewhat less visible to user space. It does this by: - not showing the guard page in /proc/<pid>/maps It looks like lvm-tools will actually read /proc/self/maps to figure out where all its mappings are, and effectively do a specialized "mlockall()" in user space. By not showing the guard page as part of the mapping (by just adding PAGE_SIZE to the start for grows-up pages), lvm-tools ends up not being aware of it. - by also teaching the _real_ mlock() functionality not to try to lock the guard page. That would just expand the mapping down to create a new guard page, so there really is no point in trying to lock it in place. It would perhaps be nice to show the guard page specially in /proc/<pid>/maps (or at least mark grow-down segments some way), but let's not open ourselves up to more breakage by user space from programs that depends on the exact deails of the 'maps' file. Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools source code to see what was going on with the whole new warning. Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-20mm: fix page table unmap for stack guard page properlyLinus Torvalds
commit 11ac552477e32835cb6970bf0a70c210807f5673 upstream. We do in fact need to unmap the page table _before_ doing the whole stack guard page logic, because if it is needed (mainly 32-bit x86 with PAE and CONFIG_HIGHPTE, but other architectures may use it too) then it will do a kmap_atomic/kunmap_atomic. And those kmaps will create an atomic region that we cannot do allocations in. However, the whole stack expand code will need to do anon_vma_prepare() and vma_lock_anon_vma() and they cannot do that in an atomic region. Now, a better model might actually be to do the anon_vma_prepare() when _creating_ a VM_GROWSDOWN segment, and not have to worry about any of this at page fault time. But in the meantime, this is the straightforward fix for the issue. See https://bugzilla.kernel.org/show_bug.cgi?id=16588 for details. Reported-by: Wylda <wylda@volny.cz> Reported-by: Sedat Dilek <sedat.dilek@gmail.com> Reported-by: Mike Pagano <mpagano@gentoo.org> Reported-by: François Valenduc <francois.valenduc@tvcablenet.be> Tested-by: Ed Tomlinson <edt@aei.ca> Cc: Pekka Enberg <penberg@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13mm: fix missing page table unmap for stack guard page failure caseLinus Torvalds
commit 5528f9132cf65d4d892bcbc5684c61e7822b21e9 upstream. .. which didn't show up in my tests because it's a no-op on x86-64 and most other architectures. But we enter the function with the last-level page table mapped, and should unmap it at exit. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13mm: keep a guard page below a grow-down stack segmentLinus Torvalds
commit 320b2b8de12698082609ebbc1a17165727f4c893 upstream. This is a rather minimally invasive patch to solve the problem of the user stack growing into a memory mapped area below it. Whenever we fill the first page of the stack segment, expand the segment down by one page. Now, admittedly some odd application might _want_ the stack to grow down into the preceding memory mapping, and so we may at some point need to make this a process tunable (some people might also want to have more than a single page of guarding), but let's try the minimal approach first. Tested with trivial application that maps a single page just below the stack, and then starts recursing. Without this, we will get a SIGSEGV _after_ the stack has smashed the mapping. With this patch, we'll get a nice SIGBUS just as the stack touches the page just above the mapping. Requested-by: Keith Packard <keithp@keithp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13mm: fix corruption of hibernation caused by reusing swap during image savingKAMEZAWA Hiroyuki
commit 966cca029f739716fbcc8068b8c6dfe381f86fc3 upstream. Since 2.6.31, swap_map[]'s refcounting was changed to show that a used swap entry is just for swap-cache, can be reused. Then, while scanning free entry in swap_map[], a swap entry may be able to be reclaimed and reused. It was caused by commit c9e444103b5e7a5 ("mm: reuse unused swap entry if necessary"). But this caused deta corruption at resume. The scenario is - Assume a clean-swap cache, but mapped. - at hibernation_snapshot[], clean-swap-cache is saved as clean-swap-cache and swap_map[] is marked as SWAP_HAS_CACHE. - then, save_image() is called. And reuse SWAP_HAS_CACHE entry to save image, and break the contents. After resume: - the memory reclaim runs and finds clean-not-referenced-swap-cache and discards it because it's marked as clean. But here, the contents on disk and swap-cache is inconsistent. Hance memory is corrupted. This patch avoids the bug by not reclaiming swap-entry during hibernation. This is a quick fix for backporting. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Ondreg Zary <linux@rainbow-software.org> Tested-by: Ondreg Zary <linux@rainbow-software.org> Tested-by: Andrea Gelmini <andrea.gelmini@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13HWPOISON: abort on failed unmapWu Fengguang
commit 1668bfd5be9d8a52536c4865000fbbe065a3613b upstream. Don't try to isolate a still mapped page. Otherwise we will hit the BUG_ON(page_mapped(page)) in __remove_from_page_cache(). Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13HWPOISON: remove the anonymous entryWu Fengguang
commit 9b9a29ecd75e310f75a9243e1c3538ad34598fcb upstream. (PG_swapbacked && !PG_lru) pages should not happen. Better to treat them as unknown pages. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10mm: fix ia64 crash when gcore reads gate areaHugh Dickins
commit de51257aa301652876ab6e8f13ea4eadbe4a3846 upstream. Debian's ia64 autobuilders have been seeing kernel freeze or reboot when running the gdb testsuite (Debian bug 588574): dannf bisected to 2.6.32 62eede62dafb4a6633eae7ffbeb34c60dba5e7b1 "mm: ZERO_PAGE without PTE_SPECIAL"; and reproduced it with gdb's gcore on a simple target. I'd missed updating the gate_vma handling in __get_user_pages(): that happens to use vm_normal_page() (nowadays failing on the zero page), yet reported success even when it failed to get a page - boom when access_process_vm() tried to copy that to its intermediate buffer. Fix this, resisting cleanups: in particular, leave it for now reporting success when not asked to get any pages - very probably safe to change, but let's not risk it without testing exposure. Why did ia64 crash with 16kB pages, but succeed with 64kB pages? Because setup_gate() pads each 64kB of its gate area with zero pages. Reported-by: Andreas Barth <aba@not.so.argh.org> Bisected-by: dann frazier <dannf@debian.org> Signed-off-by: Hugh Dickins <hughd@google.com> Tested-by: dann frazier <dannf@dannf.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05do_generic_file_read: clear page errors when issuing a fresh read of the pageJeff Moyer
commit 91803b499cca2fe558abad709ce83dc896b80950 upstream. I/O errors can happen due to temporary failures, like multipath errors or losing network contact with the iSCSI server. Because of that, the VM will retry readpage on the page. However, do_generic_file_read does not clear PG_error. This causes the system to be unable to actually use the data in the page cache page, even if the subsequent readpage completes successfully! The function filemap_fault has had a ClearPageError before readpage forever. This patch simply adds the same to do_generic_file_read. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05tmpfs: insert tmpfs cache pages to inactive list at firstKOSAKI Motohiro
commit e9d6c157385e4efa61cb8293e425c9d8beba70d3 upstream. Shaohua Li reported parallel file copy on tmpfs can lead to OOM killer. This is regression of caused by commit 9ff473b9a7 ("vmscan: evict streaming IO first"). Wow, It is 2 years old patch! Currently, tmpfs file cache is inserted active list at first. This means that the insertion doesn't only increase numbers of pages in anon LRU, but it also reduces anon scanning ratio. Therefore, vmscan will get totally confused. It scans almost only file LRU even though the system has plenty unused tmpfs pages. Historically, lru_cache_add_active_anon() was used for two reasons. 1) Intend to priotize shmem page rather than regular file cache. 2) Intend to avoid reclaim priority inversion of used once pages. But we've lost both motivation because (1) Now we have separate anon and file LRU list. then, to insert active list doesn't help such priotize. (2) In past, one pte access bit will cause page activation. then to insert inactive list with pte access bit mean higher priority than to insert active list. Its priority inversion may lead to uninteded lru chun. but it was already solved by commit 645747462 (vmscan: detect mapped file pages used only once). (Thanks Hannes, you are great!) Thus, now we can use lru_cache_add_anon() instead. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05mm: hugetlb: fix clear_huge_page()Andrea Arcangeli
commit 74dbdd239bb1348ad86d28b18574d9c1f28b62ca upstream. sz is in bytes, MAX_ORDER_NR_PAGES is in pages. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: David Gibson <dwg@au1.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26hugetlbfs: kill applications that use MAP_NORESERVE with SIGBUS instead of ↵Mel Gorman
OOM-killer commit 4a6018f7f4f1075c1a5403b5ec0ee7262187b86c upstream. Ordinarily, application using hugetlbfs will create mappings with reserves. For shared mappings, these pages are reserved before mmap() returns success and for private mappings, the caller process is guaranteed and a child process that cannot get the pages gets killed with sigbus. An application that uses MAP_NORESERVE gets no reservations and mmap() will always succeed at the risk the page will not be available at fault time. This might be used for example on very large sparse mappings where the developer is confident the necessary huge pages exist to satisfy all faults even though the whole mapping cannot be backed by huge pages. Unfortunately, if an allocation does fail, VM_FAULT_OOM is returned to the fault handler which proceeds to trigger the OOM-killer. This is unhelpful. Even without hugetlbfs mounted, a user using mmap() can trivially trigger the OOM-killer because VM_FAULT_OOM is returned (will provide example program if desired - it's a whopping 24 lines long). It could be considered a DOS available to an unprivileged user. This patch alters hugetlbfs to kill a process that uses MAP_NORESERVE where huge pages were not available with SIGBUS instead of triggering the OOM killer. This change affects hugetlb_cow() as well. I feel there is a failure case in there, but I didn't create one. It would need a fairly specific target in terms of the faulting application and the hugepage pool size. The hugetlb_no_page() path is much easier to hit but both might as well be closed. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12hugetlb: fix infinite loop in get_futex_key() when backed by huge pagesMel Gorman
commit 23be7468e8802a2ac1de6ee3eecb3ec7f14dc703 upstream. If a futex key happens to be located within a huge page mapped MAP_PRIVATE, get_futex_key() can go into an infinite loop waiting for a page->mapping that will never exist. See https://bugzilla.redhat.com/show_bug.cgi?id=552257 for more details about the problem. This patch makes page->mapping a poisoned value that includes PAGE_MAPPING_ANON mapped MAP_PRIVATE. This is enough for futex to continue but because of PAGE_MAPPING_ANON, the poisoned value is not dereferenced or used by futex. No other part of the VM should be dereferencing the page->mapping of a hugetlbfs page as its page cache is not on the LRU. This patch fixes the problem with the test case described in the bugzilla. [akpm@linux-foundation.org: mel cant spel] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Darren Hart <darren@dvhart.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12memcg: fix prepare migrationAndrea Arcangeli
commit 93d5c9be1ddd57d4063ce463c9ac2be1e5ee14f1 upstream. If a signal is pending (task being killed by sigkill) __mem_cgroup_try_charge will write NULL into &mem, and css_put will oops on null pointer dereference. BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 IP: [<ffffffff810fc6cc>] mem_cgroup_prepare_migration+0x7c/0xc0 PGD a5d89067 PUD a5d8a067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/platform/microcode/firmware/microcode/loading CPU 0 Modules linked in: nfs lockd nfs_acl auth_rpcgss sunrpc acpi_cpufreq pcspkr sg [last unloaded: microcode] Pid: 5299, comm: largepages Tainted: G W 2.6.34-rc3 #3 Penryn1600SLI-110dB/To Be Filled By O.E.M. RIP: 0010:[<ffffffff810fc6cc>] [<ffffffff810fc6cc>] mem_cgroup_prepare_migration+0x7c/0xc0 [nishimura@mxp.nes.nec.co.jp: fix merge issues] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26readahead: fix NULL filp dereferenceWu Fengguang
commit 70655c06bd3f25111312d63985888112aed15ac5 upstream. btrfs relocate_file_extent_cluster() calls us with NULL filp: [ 4005.426805] BUG: unable to handle kernel NULL pointer dereference at 00000021 [ 4005.426818] IP: [<c109a130>] page_cache_sync_readahead+0x18/0x3e Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Yan Zheng <yanzheng@21cn.com> Reported-by: Kirill A. Shutemov <kirill@shutemov.name> Tested-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tmpfs: cleanup mpol_parse_str()KOSAKI Motohiro
commit 926f2ae04f183098cf9a30521776fb2759c8afeb upstream. mpol_parse_str() made lots 'err' variable related bug. Because it is ugly and reviewing unfriendly. This patch simplifies it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tmpfs: handle MPOL_LOCAL mount option properlyKOSAKI Motohiro
commit 12821f5fb942e795f8009ece14bde868893bd811 upstream. commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in shmem_sb_info) added mpol=local mount option. but its feature is broken since it was born. because such code always return 1 (i.e. mount failure). This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tmpfs: mpol=bind:0 don't cause mount error.KOSAKI Motohiro
commit d69b2e63e9172afb4d07c305601b79a55509ac4c upstream. Currently, following mount operation cause mount error. % mount -t tmpfs -ompol=bind:0 none /tmp Because commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in shmem_sb_info) corrupted MPOL_BIND parse code. This patch restore the needed one. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tmpfs: fix oops on mounts with mpol=defaultRavikiran G Thirumalai
commit 413b43deab8377819aba1dbad2abf0c15d59b491 upstream. Fix an 'oops' when a tmpfs mount point is mounted with the mpol=default mempolicy. Upon remounting a tmpfs mount point with 'mpol=default' option, the mount code crashed with a null pointer dereference. The initial problem report was on 2.6.27, but the problem exists in mainline 2.6.34-rc as well. On examining the code, we see that mpol_new returns NULL if default mempolicy was requested. This 'NULL' mempolicy is accessed to store the node mask resulting in oops. The following patch fixes it. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01readahead: add blk_run_backing_devHisashi Hifumi
commit 65a80b4c61f5b5f6eb0f5669c8fb120893bfb388 upstream. I added blk_run_backing_dev on page_cache_async_readahead so readahead I/O is unpluged to improve throughput on especially RAID environment. The normal case is, if page N become uptodate at time T(N), then T(N) <= T(N+1) holds. With RAID (and NFS to some degree), there is no strict ordering, the data arrival time depends on runtime status of individual disks, which breaks that formula. So in do_generic_file_read(), just after submitting the async readahead IO request, the current page may well be uptodate, so the page won't be locked, and the block device won't be implicitly unplugged: if (PageReadahead(page)) page_cache_async_readahead() if (!PageUptodate(page)) goto page_not_up_to_date; //... page_not_up_to_date: lock_page_killable(page); Therefore explicit unplugging can help. Following is the test result with dd. #dd if=testdir/testfile of=/dev/null bs=16384 -2.6.30-rc6 1048576+0 records in 1048576+0 records out 17179869184 bytes (17 GB) copied, 224.182 seconds, 76.6 MB/s -2.6.30-rc6-patched 1048576+0 records in 1048576+0 records out 17179869184 bytes (17 GB) copied, 206.465 seconds, 83.2 MB/s (7Disks RAID-0 Array) -2.6.30-rc6 1054976+0 records in 1054976+0 records out 17284726784 bytes (17 GB) copied, 212.233 seconds, 81.4 MB/s -2.6.30-rc6-patched 1054976+0 records out 17284726784 bytes (17 GB) copied, 198.878 seconds, 86.9 MB/s (7Disks RAID-5 Array) The patch was found to improve performance with the SCST scsi target driver. See http://sourceforge.net/mailarchive/forum.php?thread_name=a0272b440906030714g67eabc5k8f847fb1e538cc62%40mail.gmail.com&forum_name=scst-devel [akpm@linux-foundation.org: unbust comment layout] [akpm@linux-foundation.org: "fix" CONFIG_BLOCK=n] Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Tested-by: Ronald <intercommit@gmail.com> Cc: Bart Van Assche <bart.vanassche@gmail.com> Cc: Vladislav Bolkhovitin <vst@vlnb.net> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15readahead: introduce FMODE_RANDOM for POSIX_FADV_RANDOMWu Fengguang
commit 0141450f66c3c12a3aaa869748caa64241885cdf upstream. This fixes inefficient page-by-page reads on POSIX_FADV_RANDOM. POSIX_FADV_RANDOM used to set ra_pages=0, which leads to poor performance: a 16K read will be carried out in 4 _sync_ 1-page reads. In other places, ra_pages==0 means - it's ramfs/tmpfs/hugetlbfs/sysfs/configfs - some IO error happened where multi-page read IO won't help or should be avoided. POSIX_FADV_RANDOM actually want a different semantics: to disable the *heuristic* readahead algorithm, and to use a dumb one which faithfully submit read IO for whatever application requests. So introduce a flag FMODE_RANDOM for POSIX_FADV_RANDOM. Note that the random hint is not likely to help random reads performance noticeably. And it may be too permissive on huge request size (its IO size is not limited by read_ahead_kb). In Quentin's report (http://lkml.org/lkml/2009/12/24/145), the overall (NFS read) performance of the application increased by 313%! Tested-by: Quentin Barnes <qbarnes+nfs@yahoo-inc.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: <qbarnes+nfs@yahoo-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15slab: initialize unused alien cache entry as NULL at alloc_alien_cache().Haicheng Li
commit f3186a9c51eabe75b2780153ed7f07778d78b16e upstream. Comparing with existing code, it's a simpler way to use kzalloc_node() to ensure that each unused alien cache entry is NULL. CC: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15memcg: fix oom killing a child process in an other cgroupKAMEZAWA Hiroyuki
commit 5a2d41961dd6815b874b5c0afec0ac96cd90eea4 upstream. Presently the oom-killer is memcg aware and it finds the worst process from processes under memcg(s) in oom. Then, it kills victim's child first. It may kill a child in another cgroup and may not be any help for recovery. And it will break the assumption users have. This patch fixes it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-23Fix potential crash with sys_move_pagesLinus Torvalds
commit 6f5a55f1a6c5abee15a0e878e5c74d9f1569b8b0 upstream. We incorrectly depended on the 'node_state/node_isset()' functions testing the node range, rather than checking it explicitly. That's not reliable, even if it might often happen to work. So do the proper explicit test. Reported-by: Marcus Meissner <meissner@suse.de> Acked-and-tested-by: Brice Goglin <Brice.Goglin@inria.fr> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-09mm: flush dcache before writing into page to avoid aliasanfei zhou
commit 931e80e4b3263db75c8e34f078d22f11bbabd3a3 upstream. The cache alias problem will happen if the changes of user shared mapping is not flushed before copying, then user and kernel mapping may be mapped into two different cache line, it is impossible to guarantee the coherence after iov_iter_copy_from_user_atomic. So the right steps should be: flush_dcache_page(page); kmap_atomic(page); write to page; kunmap_atomic(page); flush_dcache_page(page); More precisely, we might create two new APIs flush_dcache_user_page and flush_dcache_kern_page to replace the two flush_dcache_page accordingly. Here is a snippet tested on omap2430 with VIPT cache, and I think it is not ARM-specific: int val = 0x11111111; fd = open("abc", O_RDWR); addr = mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); *(addr+0) = 0x44444444; tmp = *(addr+0); *(addr+1) = 0x77777777; write(fd, &val, sizeof(int)); close(fd); The results are not always 0x11111111 0x77777777 at the beginning as expected. Sometimes we see 0x44444444 0x77777777. Signed-off-by: Anfei <anfei.zhou@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-09mm: purge fragmented percpu vmap blocksNick Piggin
commit 02b709df817c0db174f249cc59e5f7fd01b64d92 upstream. Improve handling of fragmented per-CPU vmaps. We previously don't free up per-CPU maps until all its addresses have been used and freed. So fragmented blocks could fill up vmalloc space even if they actually had no active vmap regions within them. Add some logic to allow all CPUs to have these blocks purged in the case of failure to allocate a new vm area, and also put some logic to trim such blocks of a current CPU if we hit them in the allocation path (so as to avoid a large build up of them). Christoph reported some vmap allocation failures when using the per CPU vmap APIs in XFS, which cannot be reproduced after this patch and the previous bug fix. Cc: linux-mm@kvack.org Tested-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-09mm: percpu-vmap fix RCU list walkingNick Piggin
commit de5604231ce4bc8db1bc1dcd27d8540cbedf1518 upstream. RCU list walking of the per-cpu vmap cache was broken. It did not use RCU primitives, and also the union of free_list and rcu_head is obviously wrong (because free_list is indeed the list we are RCU walking). While we are there, remove a couple of unused fields from an earlier iteration. These APIs aren't actually used anywhere, because of problems with the XFS conversion. Christoph has now verified that the problems are solved with these patches. Also it is an exported interface, so I think it will be good to be merged now (and Christoph wants to get the XFS changes into their local tree). Cc: linux-mm@kvack.org Tested-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-09mm: fix migratetype bug which slowed swappingHugh Dickins
commit a7016235a61d520e6806f38129001d935c4b6661 upstream. After memory pressure has forced it to dip into the reserves, 2.6.32's 5f8dcc21211a3d4e3a7a5ca366b469fb88117f61 "page-allocator: split per-cpu list into one-list-per-migrate-type" has been returning MIGRATE_RESERVE pages to the MIGRATE_MOVABLE free_list: in some sense depleting reserves. Fix that in the most straightforward way (which, considering the overheads of alternative approaches, is Mel's preference): the right migratetype is already in page_private(page), but free_pcppages_bulk() wasn't using it. How did this bug show up? As a 20% slowdown in my tmpfs loop kbuild swapping tests, on PowerMac G5 with SLUB allocator. Bisecting to that commit was easy, but explaining the magnitude of the slowdown not easy. The same effect appears, but much less markedly, with SLAB, and even less markedly on other machines (the PowerMac divides into fewer zones than x86, I think that may be a factor). We guess that lumpy reclaim of short-lived high-order pages is implicated in some way, and probably this bug has been tickling a poor decision somewhere in page reclaim. But instrumentation hasn't told me much, I've run out of time and imagination to determine exactly what's going on, and shouldn't hold up the fix any longer: it's valid, and might even fix other misbehaviours. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-09mm: add new 'read_cache_page_gfp()' helper functionLinus Torvalds
commit 0531b2aac59c2296570ac52bfc032ef2ace7d5e1 upstream. It's a simplified 'read_cache_page()' which takes a page allocation flag, so that different paths can control how aggressive the memory allocations are that populate a address space. In particular, the intel GPU object mapping code wants to be able to do a certain amount of own internal memory management by automatically shrinking the address space when memory starts getting tight. This allows it to dynamically use different memory allocation policies on a per-allocation basis, rather than depend on the (static) address space gfp policy. The actual new function is a one-liner, but re-organizing the helper functions to the point where you can do this with a single line of code is what most of the patch is all about. Tested-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
