path: root/mm
2007-01-10[PATCH] Fix up page_mkclean_one(): virtual caches, s390Peter Zijlstra
- add flush_cache_page() for all those virtual indexed cache architectures. - handle s390. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@osdl.org> [chrisw: fold in d6e88e671ac1] Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-01-10[PATCH] Fix incorrect user space access locking in mincore() (CVE-2006-4814)Linus Torvalds
Doug Chapman noticed that mincore() will doa "copy_to_user()" of the result while holding the mmap semaphore for reading, which is a big no-no. While a recursive read-lock on a semaphore in the case of a page fault happens to work, we don't actually allow them due to deadlock schenarios with writers due to fairness issues. Doug and Marcel sent in a patch to fix it, but I decided to just rewrite the mess instead - not just fixing the locking problem, but making the code smaller and (imho) much easier to understand. Cc: Doug Chapman <dchapman@redhat.com> Cc: Marcel Holtmann <holtmann@redhat.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Andrew Morton <akpm@osdl.org> [chrisw: fold in subsequent fix: 4fb23e439ce0] Acked-by: Hugh Dickins <hugh@veritas.com> [chrisw: fold in subsequent fix: 825020c3866e] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-01-10[PATCH] fix OOM killing of swapoffHugh Dickins
These days, if you swapoff when there isn't enough memory, OOM killer gives "BUG: scheduling while atomic" and the machine hangs: badness() needs to do its PF_SWAPOFF return after the task_unlock (tasklist_lock is also held here, so p isn't going to be freed: PF_SWAPOFF might get turned off at any moment, but that doesn't really matter). Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-01-10[PATCH] VM: Fix nasty and subtle race in shared mmap'ed page writebackLinus Torvalds
The VM layer (on the face of it, fairly reasonably) expected that when it does a ->writepage() call to the filesystem, it would write out the full page at that point in time. Especially since it had earlier marked the whole page dirty with "set_page_dirty()". But that isn't actually the case: ->writepage() does not actually write a page, it writes the parts of the page that have been explicitly marked dirty before, *and* that had not got written out for other reasons since the last time we told it they were dirty. That last caveat is the important one. Which _most_ of the time ends up being the whole page (since we had called "set_page_dirty()" on the page earlier), but if the filesystem had done any dirty flushing of its own (for example, to honor some internal write ordering guarantees), it might end up doing only a partial page IO (or none at all) when ->writepage() is actually called. That is the correct thing in general (since we actually often _want_ only the known-dirty parts of the page to be written out), but the shared dirty page handling had implicitly forgotten about these details, and had a number of cases where it was doing just the "->writepage()" part, without telling the low-level filesystem that the whole page might have been re-dirtied as part of being mapped writably into user space. Since most of the time the FS did actually write out the full page, we didn't notice this for a loong time, and this needed some really odd patterns to trigger. But it caused occasional corruption with rtorrent and with the Debian "apt" database, because both use shared mmaps to update the end result. This fixes it. Finally. After way too much hair-pulling. Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Martin J. Bligh <mbligh@google.com> Acked-by: Martin Michlmayr <tbm@cyrius.com> Acked-by: Martin Johansson <martin@fatbob.nu> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Andrei Popa <andrei.popa@i-neo.ro> Cc: High Dickins <hugh@veritas.com> Cc: Andrew Morton <akpm@osdl.org>, Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Segher Boessenkool <segher@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Gordon Farquharson <gordonfarquharson@gmail.com> Cc: Guillaume Chazarain <guichaz@yahoo.fr> Cc: Theodore Tso <tytso@mit.edu> Cc: Kenneth Cheng <kenneth.w.chen@intel.com> Cc: Tobias Diedrich <ranma@tdiedrich.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org> [chrisw: backport to 2.6.19.1] Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-01-10[PATCH] Buglet in vmscan.cShantanu Goel
Fix a rather obvious buglet. Noticed while instrumenting the VM using /proc/vmstat. Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-01-10[PATCH] Fix for shmem_truncate_range() BUG_ON()Badari Pulavarty
Ran into BUG() while doing madvise(REMOVE) testing. If we are punching a hole into shared memory segment using madvise(REMOVE) and the entire hole is below the indirect blocks, we hit following assert. BUG_ON(limit <= SHMEM_NR_DIRECT); Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-01-10[PATCH] read_zero_pagealigned() locking fixHugh Dickins
Ramiro Voicu hits the BUG_ON(!pte_none(*pte)) in zeromap_pte_range: kernel bugzilla 7645. Right: read_zero_pagealigned uses down_read of mmap_sem, but another thread's racing read of /dev/zero, or a normal fault, can easily set that pte again, in between zap_page_range and zeromap_page_range getting there. It's been wrong ever since 2.4.3. The simple fix is to use down_write instead, but that would serialize reads of /dev/zero more than at present: perhaps some app would be badly affected. So instead let zeromap_page_range return the error instead of BUG_ON, and read_zero_pagealigned break to the slower clear_user loop in that case - there's no need to optimize for it. Use -EEXIST for when a pte is found: BUG_ON in mmap_zero (the other user of zeromap_page_range), though it really isn't interesting there. And since mmap_zero wants -EAGAIN for out-of-memory, the zeromaps better return that than -ENOMEM. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Ramiro Voicu: <Ramiro.Voicu@cern.ch> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-11-23[PATCH] x86_64: fix bad page state in process 'swapper'Mel Gorman
find_min_pfn_for_node() and find_min_pfn_with_active_regions() both depend on a sorted early_node_map[]. However, sort_node_map() is being called after fin_min_pfn_with_active_regions() in free_area_init_nodes(). In most cases, this is ok, but on at least one x86_64, the SRAT table caused the E820 ranges to be registered out of order. This gave the wrong values for the min PFN range resulting in some pages not being initialised. This patch sorts the early_node_map in find_min_pfn_for_node(). It has been boot tested on x86, x86_64, ppc64 and ia64. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andre Noll <maan@systemlinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-16[PATCH] Fix strange size check in __get_vm_area_node()OGAWA Hirofumi
Recently, __get_vm_area_node() was changed like following if (unlikely(!area)) return NULL; - if (unlikely(!size)) { - kfree (area); + if (unlikely(!size)) return NULL; - } It is leaking `area', also original code seems strange already. Probably, we wanted to do this patch. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-14[PATCH] hugetlb: fix error return for brk() entering a hugepage regionHugh Dickins
Commit cb07c9a1864a8eac9f3123e428100d5b2a16e65a causes the wrong return value. is_hugepage_only_range() is a boolean, so we should return -EINVAL rather than 1. Also - we can use "mm" instead of looking up "current->mm" again. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-14[PATCH] hugetlb: check for brk() entering a hugepage regionDavid Gibson
Unlike mmap(), the codepath for brk() creates a vma without first checking that it doesn't touch a region exclusively reserved for hugepages. On powerpc, this can allow it to create a normal page vma in a hugepage region, causing oopses and other badness. Add a test to prevent this. With this patch, brk() will simply fail if it attempts to move the break into a hugepage reserved region. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: Adam Litke <agl@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-14[PATCH] hugetlb: prepare_hugepage_range check offset tooHugh Dickins
(David:) If hugetlbfs_file_mmap() returns a failure to do_mmap_pgoff() - for example, because the given file offset is not hugepage aligned - then do_mmap_pgoff will go to the unmap_and_free_vma backout path. But at this stage the vma hasn't been marked as hugepage, and the backout path will call unmap_region() on it. That will eventually call down to the non-hugepage version of unmap_page_range(). On ppc64, at least, that will cause serious problems if there are any existing hugepage pagetable entries in the vicinity - for example if there are any other hugepage mappings under the same PUD. unmap_page_range() will trigger a bad_pud() on the hugepage pud entries. I suspect this will also cause bad problems on ia64, though I don't have a machine to test it on. (Hugh:) prepare_hugepage_range() should check file offset alignment when it checks virtual address and length, to stop MAP_FIXED with a bad huge offset from unmapping before it fails further down. PowerPC should apply the same prepare_hugepage_range alignment checks as ia64 and all the others do. Then none of the alignment checks in hugetlbfs_file_mmap are required (nor is the check for too small a mapping); but even so, move up setting of VM_HUGETLB and add a comment to warn of what David Gibson discovered - if hugetlbfs_file_mmap fails before setting it, do_mmap_pgoff's unmap_region when unwinding from error will go the non-huge way, which may cause bad behaviour on architectures (powerpc and ia64) which segregate their huge mappings into a separate region of the address space. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] vmalloc: optimization, cleanup, bugfixesEric Dumazet
- reorder 'struct vm_struct' to speedup lookups on CPUS with small cache lines. The fields 'next,addr,size' should be now in the same cache line, to speedup lookups. - One minor cleanup in __get_vm_area_node() - Bugfixes in vmalloc_user() and vmalloc_32_user() NULL returns from __vmalloc() and __find_vm_area() were not tested. [akpm@osdl.org: remove redundant BUG_ONs] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] Fix sys_move_pages when a NULL node list is passedStephen Rothwell
sys_move_pages() uses vmalloc() to allocate an array of structures that is fills with information passed from user mode and then passes to do_stat_pages() (in the case the node list is NULL). do_stat_pages() depends on a marker in the node field of the structure to decide how large the array is and this marker is correctly inserted into the last element of the array. However, vmalloc() doesn't zero the memory it allocates and if the user passes NULL for the node list, then the node fields are not filled in (except for the end marker). If the memory the vmalloc() returned happend to have a word with the marker value in it in just the right place, do_pages_stat will fail to fill the status field of part of the array and we will return (random) kernel data to user mode. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] init_reap_node() initialization fixDaniel Yeisley
It looks like there is a bug in init_reap_node() in slab.c that can cause multiple oops's on certain ES7000 configurations. The variable reap_node is defined per cpu, but only initialized on a single CPU. This causes an oops in next_reap_node() when __get_cpu_var(reap_node) returns the wrong value. Fix is below. Signed-off-by: Dan Yeisley <dan.yeisley@unisys.com> Cc: Andi Kleen <ak@suse.de> Acked-by: Christoph Lameter <clameter@engr.sgi.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] Cleanup read_pages()OGAWA Hirofumi
Current read_pages() assume ->readpages() frees the passed pages. This patch free the pages in ->read_pages(), if those were remaining in the pages_list. So, readpages() just can ignore the remaining pages in pages_list. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Steven French <sfrench@us.ibm.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] mm: un-needed add-store operation wastes a few bytesnkalmala
Un-needed add-store operation wastes a few bytes. 8 bytes wasted with -O2, on a ppc. Signed-off-by: nkalmala <nkalmala@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29[PATCH] Fix GFP_HIGHMEM slab panicGiridhar Pemmasani
As reported by Martin J. Bligh <mbligh@google.com>, we let through some non-slab bits to slab allocation through __get_vm_area_node when doing a vmalloc. I haven't been able to reproduce this, although I understand why it happens: vmalloc allocates memory with GFP_KERNEL | __GFP_HIGHMEM and commit 52fd24ca1db3a741f144bbc229beefe044202cac resulted in the same flags are passed down to cache_alloc_refill, causing the BUG. The following patch fixes it. Note that when calling kmalloc_node, I am masking off __GFP_HIGHMEM with GFP_LEVEL_MASK, whereas __vmalloc_area_node does the same with ~(__GFP_HIGHMEM | __GFP_ZERO). IMHO, using GFP_LEVEL_MASK is preferable, but either should fix this problem. Signed-off-by: Giridhar Pemmasani (pgiri@yahoo.com) Cc: Martin J. Bligh <mbligh@google.com> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] Calculation fix for memory holes beyong the end of physical memoryMel Gorman
absent_pages_in_range() made the assumption that users of the arch-independent zone-sizing API would not care about holes beyound the end of physical memory. This was not the case and was "fixed" in a patch called "Account for holes that are outside the range of physical memory". However, when given a range that started before a hole in "real" memory and ended beyond the end of memory, it would get the result wrong. The bug is in mainline but a patch is below. It has been tested successfully on a number of machines and architectures. Additional credit to Keith Mannthey for discovering the problem, helping identify the correct fix and confirming it Worked For Him. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: keith mannthey <kmannth@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] hugetlb: fix absurd HugePages_RsvdHugh Dickins
If you truncated an mmap'ed hugetlbfs file, then faulted on the truncated area, /proc/meminfo's HugePages_Rsvd wrapped hugely "negative". Reinstate my preliminary i_size check before attempting to allocate the page (though this only fixes the most obvious case: more work will be needed here). Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: "Chen, Kenneth W" <kenneth.w.chen@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] __vmalloc with GFP_ATOMIC causes 'sleeping from invalid context'Giridhar Pemmasani
If __vmalloc is called to allocate memory with GFP_ATOMIC in atomic context, the chain of calls results in __get_vm_area_node allocating memory for vm_struct with GFP_KERNEL, causing the 'sleeping from invalid context' warning. This patch fixes it by passing the gfp flags along so __get_vm_area_node allocates memory for vm_struct with the same flags. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] memory hotplug: __GFP_NOWARN is better for __kmalloc_section_memmap()Yasunori Goto
Add __GFP_NOWARN flag to calling of __alloc_pages() in __kmalloc_section_memmap(). It can reduce noisy failure message. In ia64, section size is 1 GB, this means that order 8 pages are necessary for each section's memmap. It is often very hard requirement under heavy memory pressure as you know. So, __alloc_pages() gives up allocation and shows many noisy stack traces which means no page for each sections. (Current my environment shows 32 times of stack trace....) But, __kmalloc_section_memmap() calls vmalloc() after failure of it, and it can succeed allocation of memmap. So, its stack trace warning becomes just noisy. I suppose it shouldn't be shown. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] Use min of two prio settings in calculating distress for reclaimMartin Bligh
If try_to_free_pages / balance_pgdat are called with a gfp_mask specifying GFP_IO and/or GFP_FS, they will reclaim the requisite number of pages, and the reset prev_priority to DEF_PRIORITY (or to some other high (ie: unurgent) value). However, another reclaimer without those gfp_mask flags set (say, GFP_NOIO) may still be struggling to reclaim pages. The concurrent overwrite of zone->prev_priority will cause this GFP_NOIO thread to unexpectedly cease deactivating mapped pages, thus causing reclaim difficulties. Fix this is to key the distress calculation not off zone->prev_priority, but also take into account the local caller's priority by using min(zone->prev_priority, sc->priority) Signed-off-by: Martin J. Bligh <mbligh@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] vmscan: Fix temp_priority raceMartin Bligh
The temp_priority field in zone is racy, as we can walk through a reclaim path, and just before we copy it into prev_priority, it can be overwritten (say with DEF_PRIORITY) by another reclaimer. The same bug is contained in both try_to_free_pages and balance_pgdat, but it is fixed slightly differently. In balance_pgdat, we keep a separate priority record per zone in a local array. In try_to_free_pages there is no need to do this, as the priority level is the same for all zones that we reclaim from. Impact of this bug is that temp_priority is copied into prev_priority, and setting this artificially high causes reclaimers to set distress artificially low. They then fail to reclaim mapped pages, when they are, in fact, under severe memory pressure (their priority may be as low as 0). This causes the OOM killer to fire incorrectly. From: Andrew Morton <akpm@osdl.org> __zone_reclaim() isn't modifying zone->prev_priority. But zone->prev_priority is used in the decision whether or not to bring mapped pages onto the inactive list. Hence there's a risk here that __zone_reclaim() will fail because zone->prev_priority ir large (ie: low urgency) and lots of mapped pages end up stuck on the active list. Fix that up by decreasing (ie making more urgent) zone->prev_priority as __zone_reclaim() scans the zone's pages. This bug perhaps explains why ZONE_RECLAIM_PRIORITY was created. It should be possible to remove that now, and to just start out at DEF_PRIORITY? Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] mm: clean up pagecache allocationNick Piggin
- Consolidate page_cache_alloc - Fix splice: only the pagecache pages and filesystem data need to use mapping_gfp_mask. - Fix grab_cache_page_nowait: same as splice, also honour NUMA placement. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-21[PATCH] Slab: Do not fallback to nodes that have not been bootstrapped yetChristoph Lameter
The zonelist may contain zones of nodes that have not been bootstrapped and we will oops if we try to allocate from those zones. So check if the node information for the slab and the node have been setup before attempting an allocation. If it has not been setup then skip that zone. Usually we will not encounter this situation since the slab bootstrap code avoids falling back before we have setup the respective nodes but we seem to have a special needs for pppc. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Kravetz <kravetz@us.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Will Schmidt <will_schmidt@vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-21[PATCH] Reintroduce NODES_SPAN_OTHER_NODES for powerpcAndy Whitcroft
Reintroduce NODES_SPAN_OTHER_NODES for powerpc Revert "[PATCH] Remove SPAN_OTHER_NODES config definition" This reverts commit f62859bb6871c5e4a8e591c60befc8caaf54db8c. Revert "[PATCH] mm: remove arch independent NODES_SPAN_OTHER_NODES" This reverts commit a94b3ab7eab4edcc9b2cb474b188f774c331adf7. Also update the comments to indicate that this is still required and where its used. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Kravetz <kravetz@us.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-21Merge branch 'splice' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'splice' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] Remove SUID when splicing into an inode [PATCH] Add lockless helpers for remove_suid() [PATCH] Introduce generic_file_splice_write_nolock() [PATCH] Take i_mutex in splice_from_pipe()
2006-10-20[PATCH] mm: more commenting on lock orderingNick Piggin
Clarify lockorder comments now that sys_msync dropps mmap_sem before calling do_fsync. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] mm: D-cache aliasing issue in cow_user_pageDmitriy Monakhov
--=-=-= from mm/memory.c: 1434 static inline void cow_user_page(struct page *dst, struct page *src, unsigned long va) 1435 { 1436 /* 1437 * If the source page was a PFN mapping, we don't have 1438 * a "struct page" for it. We do a best-effort copy by 1439 * just copying from the original user address. If that 1440 * fails, we just zero-fill it. Live with it. 1441 */ 1442 if (unlikely(!src)) { 1443 void *kaddr = kmap_atomic(dst, KM_USER0); 1444 void __user *uaddr = (void __user *)(va & PAGE_MASK); 1445 1446 /* 1447 * This really shouldn't fail, because the page is there 1448 * in the page tables. But it might just be unreadable, 1449 * in which case we just give up and fill the result with 1450 * zeroes. 1451 */ 1452 if (__copy_from_user_inatomic(kaddr, uaddr, PAGE_SIZE)) 1453 memset(kaddr, 0, PAGE_SIZE); 1454 kunmap_atomic(kaddr, KM_USER0); #### D-cache have to be flushed here. #### It seems it is just forgotten. 1455 return; 1456 1457 } 1458 copy_user_highpage(dst, src, va); #### Ok here. flush_dcache_page() called from this func if arch need it 1459 } Following is the patch fix this issue: Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] highest_possible_node_id() linkage fixAndrew Morton
Qooting Adrian: - net/sunrpc/svc.c uses highest_possible_node_id() - include/linux/nodemask.h says highest_possible_node_id() is out-of-line #if MAX_NUMNODES > 1 - the out-of-line highest_possible_node_id() is in lib/cpumask.c - lib/Makefile: lib-$(CONFIG_SMP) += cpumask.o CONFIG_ARCH_DISCONTIGMEM_ENABLE=y, CONFIG_SMP=n, CONFIG_SUNRPC=y -> highest_possible_node_id() is used in net/sunrpc/svc.c CONFIG_NODES_SHIFT defined and > 0 -> include/linux/numa.h: MAX_NUMNODES > 1 -> compile error The bug is not present on architectures where ARCH_DISCONTIGMEM_ENABLE depends on NUMA (but m32r isn't the only affected architecture). So move the function into page_alloc.c Cc: Adrian Bunk <bunk@stusta.de> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] OOM killer meets userspace headersAlexey Dobriyan
Despite mm.h is not being exported header, it does contain one thing which is part of userspace ABI -- value disabling OOM killer for given process. So, a) create and export include/linux/oom.h b) move OOM_DISABLE define there. c) turn bounding values of /proc/$PID/oom_adj into defines and export them too. Note: mass __KERNEL__ removal will be done later. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] separate bdi congestion functions from queue congestion functionsAndrew Morton
Separate out the concept of "queue congestion" from "backing-dev congestion". Congestion is a backing-dev concept, not a queue concept. The blk_* congestion functions are retained, as wrappers around the core backing-dev congestion functions. This proper layering is needed so that NFS can cleanly use the congestion functions, and so that CONFIG_BLOCK=n actually links. Cc: "Thomas Maier" <balagi@justmail.de> Cc: "Jens Axboe" <jens.axboe@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: David Howells <dhowells@redhat.com> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] direct-io: sync and invalidate file region when falling back to ↵Jeff Moyer
buffered write When direct-io falls back to buffered write, it will just leave the dirty data floating about in pagecache, pending regular writeback. But normal direct-io semantics are that IO is synchronous, and that it leaves no pagecache behind. So change the fallback-to-buffered-write code to sync the file region and to then strip away the pagecache, just as a regular direct-io write would do. Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-19[PATCH] Add lockless helpers for remove_suid()Jens Axboe
Right now users have to grab i_mutex before calling remove_suid(), in the unlikely event that a call to ->setattr() may be needed. Split up the function in two parts: - One to check if we need to remove suid - One to actually remove it The first we can call lockless. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-17[PATCH] vmalloc(): don't pass __GFP_ZERO to slabAndrew Morton
A recent change to the vmalloc() code accidentally resulted in us passing __GFP_ZERO into the slab allocator. But we only wanted __GFP_ZERO for the actual pages whcih are being vmalloc()ed, and passing __GFP_ZERO into slab is not a rational thing to ask for. Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] knfsd: add nfs-export support to tmpfsDavid M. Grimes
We need to encode a decode the 'file' part of a handle. We simply use the inode number and generation number to construct the filehandle. The generation number is the time when the file was created. As inode numbers cycle through the full 32 bits before being reused, there is no real chance of the same inum being allocated to different files in the same second so this is suitably unique. Using time-of-day rather than e.g. jiffies makes it less likely that the same filehandle can be created after a reboot. In order to be able to decode a filehandle we need to be able to lookup by inum, which means that the inode needs to be added to the inode hash table (tmpfs doesn't currently hash inodes as there is never a need to lookup by inum). To avoid overhead when not exporting, we only hash an inode when it is first exported. This requires a lock to ensure it isn't hashed twice. This code is separate from the patch posted in June06 from Atal Shargorodsky which provided the same functionality, but does borrow slightly from it. Locking comment: Most filesystems that hash their inodes do so at the point where the 'struct inode' is initialised, and that has suitable locking (I_NEW). Here in shmem, we are hashing the inode later, the first time we need an NFS file handle for it. We no longer have I_NEW to ensure only one thread tries to add it to the hash table. Cc: Atal Shargorodsky <atal@codefidence.com> Cc: Gilad Ben-Yossef <gilad@codefidence.com> Signed-off-by: David M. Grimes <dgrimes@navisite.com> Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] invalidate: remove_mapping() fixAndrew Morton
If remove_mapping() failed to remove the page from its mapping, don't go and mark it not uptodate! Makes kernel go dead. (Actually, I don't think the ClearPageUptodate is needed there at all). Says Nick Piggin: "Right, it isn't needed because at this point the page is guaranteed by remove_mapping to have no references (except us) and cannot pick up any new ones because it is removed from pagecache. We can delete it." Signed-off-by: Andrew Morton <akpm@osdl.org> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-15Fix VM_MAYEXEC calculationLinus Torvalds
.. and clean up the file mapping code while at it. No point in having a "if (file)" repeated twice, and generally doing similar checks in two different sections of the same code Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Fix typos in mm/shmem_acl.cAneesh Kumar
2006-10-11[PATCH] VM: Fix the gfp_mask in invalidate_complete_page2Trond Myklebust
If try_to_release_page() is called with a zero gfp mask, then the filesystem is effectively denied the possibility of sleeping while attempting to release the page. There doesn't appear to be any valid reason why this should be banned, given that we're not calling this from a memory allocation context. For this reason, change the gfp_mask argument of the call to GFP_KERNEL. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Steve Dickson <SteveD@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] invalidate_inode_pages2_range() debugAndrew Morton
A failure in invalidate_inode_pages2_range() can result in unpleasant things happening in NFS (at least). Stick a WARN_ON_ONCE() in there so we can find out if it happens, and maybe why. (akpm: might be a -mm-only patch, we'll see..) Cc: Chuck Lever <chuck.lever@oracle.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Steve Dickson <SteveD@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] mm: locks_freed fixNick Piggin
Move the lock debug checks below the page reserved checks. Also, having debug_check_no_locks_freed in kernel_map_pages is wrong. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] mm: arch_free_page fixNick Piggin
After the PG_reserved check was added, arch_free_page was being called in the wrong place (it could be called for a page we don't actually want to free). Fix that. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Fix do_mbind warning with CONFIG_MIGRATION=nKeith Owens
With CONFIG_MIGRATION=n mm/mempolicy.c: In function 'do_mbind': mm/mempolicy.c:796: warning: passing argument 2 of 'migrate_pages' from incompatible pointer type Signed-off-by: Keith Owens <kaos@ocs.com.au> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] move rmap BUG_ON outside DEBUG_VMDave Jones
We have a persistent dribble of reports of this BUG triggering. Its extended diagnostics were recently made conditional on CONFIG_DEBUG_VM, which was a bad idea - we want to know about it. Signed-off-by: Dave Jones <davej@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] hugetlb: fix linked list corruption in unmap_hugepage_range()Chen, Kenneth W
commit fe1668ae5bf0145014c71797febd9ad5670d5d05 causes kernel to oops with libhugetlbfs test suite. The problem is that hugetlb pages can be shared by multiple mappings. Multiple threads can fight over page->lru in the unmap path and bad things happen. We now serialize __unmap_hugepage_range to void concurrent linked list manipulation. Such serialization is also needed for shared page table page on hugetlb area. This patch will fixed the bug and also serve as a prepatch for shared page table. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] mm: remove memmap_zone_idx()Mel Gorman
memmap_zone_idx() is not used anymore. It was required by an earlier version of account-for-memmap-and-optionally-the-kernel-image-as-holes.patch but not any more. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-07[PATCH] slab: remove wrongly placed BUG_ONChristoph Lameter
Init list is called with a list parameter that is not equal to the cachep->nodelists entry under NUMA if more than one node exists. This is fully legitimatei. One may want to populate the list fields before switching nodelist pointers. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06[PATCH] page fault retry with NOPAGE_REFAULTBenjamin Herrenschmidt
Add a way for a no_page() handler to request a retry of the faulting instruction. It goes back to userland on page faults and just tries again in get_user_pages(). I added a cond_resched() in the loop in that later case. The problem I have with signal and spufs is an actual bug affecting apps and I don't see other ways of fixing it. In addition, we are having issues with infiniband and 64k pages (related to the way the hypervisor deals with some HV cards) that will require us to muck around with the MMU from within the IB driver's no_page() (it's a pSeries specific driver) and return to the caller the same way using NOPAGE_REFAULT. And to add to this, the graphics folks have been following a new approach of memory management that involves transparently swapping objects between video ram and main meory. To do that, they need installing PTEs from a no_page() handler as well and that also requires returning with NOPAGE_REFAULT. (For the later, they are currently using io_remap_pfn_range to install one PTE from no_page() which is a bit racy, we need to add a check for the PTE having already been installed afer taking the lock, but that's ok, they are only at the proof-of-concept stage. I'll send a patch adding a "clean" function to do that, we can use that from spufs too and get rid of the sparsemem hacks we do to create struct page for SPEs. Basically, that provides a generic solution for being able to have no_page() map hardware devices, which is something that I think sound driver folks have been asking for some time too). All of these things depend on having the NOPAGE_REFAULT exit path from no_page() handlers. Signed-off-by: Benjamin Herrenchmidt <benh@kernel.crashing.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
