We don't have proper reference counting for this yet, so we run into
cases where the device is pulled and we OOPS on flushing the fs data.
This happens even though the dirty inodes have already been
migrated to the default_backing_dev_info.
Bug 863000
(cherry picked from commit 95f28604a65b1c40b6c6cd95e58439cd7ded3add
of kernel.org, linux-2.6 tree)
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Change-Id: I01b2e2689e065bbe7667b18f2785c6b21beaf432
Reviewed-on: http://git-master/r/48468
Reviewed-by: Ramalingam C <ramalingamc@nvidia.com>
Tested-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
arch/arm/mm/cache-v6.S
Change-Id: I1a2063218dd705a762a40f4a9dfe504ce1a1d491
commit ebb76ce16daf6908dc030dec1c00827d37129fe5 upstream.
At __mem_cgroup_try_charge(), VM_BUG_ON(!mm->owner) is checked.
But as commented in mem_cgroup_from_task(), mm->owner can be NULL
in some racy case. This check of VM_BUG_ON() is bad.
A possible story to hit this is at swapoff()->try_to_unuse(). It passes
mm_struct to mem_cgroup_try_charge_swapin() while mm->owner is NULL. If we
can't get proper mem_cgroup from swap_cgroup information, mm->owner is used
as charge target and we see NULL.
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Reported-by: Hugh Dickins <hughd@google.com>
Reported-by: Thomas Meyer <thomas@m3y3r.de>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com>
commit 462e635e5b73ba9a4c03913b77138cd57ce4b050 upstream.
The install_special_mapping routine (used, for example, to setup the
vdso) skips the security check before insert_vm_struct, allowing a local
attacker to bypass the mmap_min_addr security restriction by limiting
the available pages for special mappings.
bprm_mm_init() also skips the check, and although I don't think this can
be used to bypass any restrictions, I don't see any reason not to have
the security check.
$ uname -m
x86_64
$ cat /proc/sys/vm/mmap_min_addr
65536
$ cat install_special_mapping.s
section .bss
resb BSS_SIZE
section .text
global _start
_start:
mov eax, __NR_pause
int 0x80
$ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s
$ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o
$ ./install_special_mapping &
[1] 14303
$ cat /proc/14303/maps
0000f000-00010000 r-xp 00000000 00:00 0 [vdso]
00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping
00011000-ffffe000 rwxp 00000000 00:00 0 [stack]
It's worth noting that Red Hat are shipping with mmap_min_addr set to
4096.
Signed-off-by: Tavis Ormandy <taviso@google.com>
Acked-by: Kees Cook <kees@ubuntu.com>
Acked-by: Robert Swiecki <swiecki@google.com>
[ Changed to not drop the error code - akpm ]
Reviewed-by: James Morris <jmorris@namei.org>
drivers/usb/gadget/composite.c
Change-Id: I1a332ec21da62aea98912df9a01cf0282ed50ee1
commit c9e664f1fdf34aa8cede047b206deaa8f1945af0 upstream.
There is a problem that swap pages allocated before the creation of
a hibernation image can be released and used for storing the contents
of different memory pages while the image is being saved. Since the
kernel stored in the image doesn't know of that, it causes memory
corruption to occur after resume from hibernation, especially on
systems with relatively small RAM that need to swap often.
This issue can be addressed by keeping the GFP_IOFS bits clear
in gfp_allowed_mask during the entire hibernation, including the
saving of the image, until the system is finally turned off or
the hibernation is aborted. Unfortunately, for this purpose
it's necessary to rework the way in which the hibernate and
suspend code manipulates gfp_allowed_mask.
This change is based on an earlier patch from Hugh Dickins.
Reported-by: Ondrej Zary <linux@rainbow-software.org>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit b1dd693e5b9348bd68a80e679e03cf9c0973b01b upstream.
__mem_cgroup_try_charge() can be called under down_write(&mmap_sem)(e.g.
mlock does it). This means it can cause deadlock if it races with move charge:
Ex.1)
move charge | try charge
mem_cgroup_can_attach() | down_write(&mmap_sem)
mc.moving_task = current | ..
mem_cgroup_precharge_mc() | __mem_cgroup_try_charge()
mem_cgroup_count_precharge() | prepare_to_wait()
down_read(&mmap_sem) | if (mc.moving_task)
-> cannot aquire the lock | -> true
| schedule()
Ex.2)
up_read(&mmap_sem) |
mem_cgroup_move_task() | ..
mem_cgroup_move_charge() | __mem_cgroup_try_charge()
down_read(&mmap_sem) | prepare_to_wait()
-> cannot aquire the lock | if (mc.moving_task)
| -> true
| schedule()
To avoid this deadlock, we do all the move charge works (both can_attach() and
attach()) under one mmap_sem section.
And after this patch, we set/clear mc.moving_task outside mc.lock, because we
use the lock only to check mc.from/to.
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 63bfd7384b119409685a17d5c58f0b56e5dc03da upstream.
As pointed out by Linus, commit dab5855 ("perf_counter: Add mmap event hooks to
mprotect()") is fundamentally wrong as mprotect_fixup() can free 'vma' due to
merging. Fix the problem by moving perf_event_mmap() hook to
mprotect_fixup().
Note: there's another successful return path from mprotect_fixup() if old
flags equal to new flags. We don't, however, need to call
perf_event_mmap() there because 'perf' already knows the VMA is
executable.
Reported-by: Dave Jones <davej@redhat.com>
Analyzed-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
commit 04c3496152394d17e3bc2316f9731ee3e8a026bc upstream.
Depending on processor speed, page size, and the amount of memory a
process is allowed to amass, cleanup of a large VM may freeze the system
for many seconds. This can result in a watchdog timeout.
Make sure other tasks receive some service when cleaning up large VMs.
Signed-off-by: Steven J. Magnani <steve@digidescorp.com>
Cc: Greg Ungerer <gerg@snapgear.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 1f64d69c7ad2e48e697493e45590679f7a69b7b2 upstream.
Have hugetlb_fault() call unlock_page(page) only if it had previously
called lock_page(page).
Setting CONFIG_DEBUG_VM=y and then running the libhugetlbfs test suite,
resulted in the tripping of VM_BUG_ON(!PageLocked(page)) in
unlock_page() having been called by hugetlb_fault() when page ==
pagecache_page. This patch remedied the problem.
Signed-off-by: Dean Nelson <dnelson@redhat.com>
commit 8d056cb965b8fb7c53c564abf28b1962d1061cd3 upstream.
70 hours into some stress tests of a 2.6.32-based enterprise kernel, we
ran into a NULL dereference in here:
int block_is_partially_uptodate(struct page *page, read_descriptor_t *desc,
unsigned long from)
----> struct inode *inode = page->mapping->host;
It looks like page->mapping was the culprit. (xmon trace is below).
After closer examination, I realized that do_generic_file_read() does a
find_get_page(), and eventually locks the page before calling
block_is_partially_uptodate(). However, it doesn't revalidate the
page->mapping after the page is locked. So, there's a small window
between the find_get_page() and ->is_partially_uptodate() where the page
could get truncated and page->mapping cleared.
We _have_ a reference, so it can't get reclaimed, but it certainly
can be truncated.
I think the correct thing is to check page->mapping after the
trylock_page(), and jump out if it got truncated. This patch has been
running in the test environment for a month or so now, and we have not
seen this bug pop up again.
xmon info:
1f:mon> e
cpu 0x1f: Vector: 300 (Data Access) at [c0000002ae36f770]
pc: c0000000001e7a6c: .block_is_partially_uptodate+0xc/0x100
lr: c000000000142944: .generic_file_aio_read+0x1e4/0x770
sp: c0000002ae36f9f0
msr: 8000000000009032
dar: 0
dsisr: 40000000
current = 0xc000000378f99e30
paca = 0xc000000000f66300
pid = 21946, comm = bash
1f:mon> r
R00 = 0025c0500000006d R16 = 0000000000000000
R01 = c0000002ae36f9f0 R17 = c000000362cd3af0
R02 = c000000000e8cd80 R18 = ffffffffffffffff
R03 = c0000000031d0f88 R19 = 0000000000000001
R04 = c0000002ae36fa68 R20 = c0000003bb97b8a0
R05 = 0000000000000000 R21 = c0000002ae36fa68
R06 = 0000000000000000 R22 = 0000000000000000
R07 = 0000000000000001 R23 = c0000002ae36fbb0
R08 = 0000000000000002 R24 = 0000000000000000
R09 = 0000000000000000 R25 = c000000362cd3a80
R10 = 0000000000000000 R26 = 0000000000000002
R11 = c0000000001e7b60 R27 = 0000000000000000
R12 = 0000000042000484 R28 = 0000000000000001
R13 = c000000000f66300 R29 = c0000003bb97b9b8
R14 = 0000000000000001 R30 = c000000000e28a08
R15 = 000000000000ffff R31 = c0000000031d0f88
pc = c0000000001e7a6c .block_is_partially_uptodate+0xc/0x100
lr = c000000000142944 .generic_file_aio_read+0x1e4/0x770
msr = 8000000000009032 cr = 22000488
ctr = c0000000001e7a60 xer = 0000000020000000 trap = 300
dar = 0000000000000000 dsisr = 40000000
1f:mon> t
[link register ] c000000000142944 .generic_file_aio_read+0x1e4/0x770
[c0000002ae36f9f0] c000000000142a14 .generic_file_aio_read+0x2b4/0x770 (unreliable)
[c0000002ae36fb40] c0000000001b03e4 .do_sync_read+0xd4/0x160
[c0000002ae36fce0] c0000000001b153c .vfs_read+0xec/0x1f0
[c0000002ae36fd80] c0000000001b1768 .SyS_read+0x58/0xb0
[c0000002ae36fe30] c00000000000852c syscall_exit+0x0/0x40
--- Exception: c00 (System Call) at 00000080a840bc54
SP (fffca15df30) is in userspace
1f:mon> di c0000000001e7a6c
c0000000001e7a6c e9290000 ld r9,0(r9)
c0000000001e7a70 418200c0 beq c0000000001e7b30 # .block_is_partially_uptodate+0xd0/0x100
c0000000001e7a74 e9440008 ld r10,8(r4)
c0000000001e7a78 78a80020 clrldi r8,r5,32
c0000000001e7a7c 3c000001 lis r0,1
c0000000001e7a80 812900a8 lwz r9,168(r9)
c0000000001e7a84 39600001 li r11,1
c0000000001e7a88 7c080050 subf r0,r8,r0
c0000000001e7a8c 7f805040 cmplw cr7,r0,r10
c0000000001e7a90 7d6b4830 slw r11,r11,r9
c0000000001e7a94 796b0020 clrldi r11,r11,32
c0000000001e7a98 419d00a8 bgt cr7,c0000000001e7b40 # .block_is_partially_uptodate+0xe0/0x100
c0000000001e7a9c 7fa55840 cmpld cr7,r5,r11
c0000000001e7aa0 7d004214 add r8,r0,r8
c0000000001e7aa4 79080020 clrldi r8,r8,32
c0000000001e7aa8 419c0078 blt cr7,c0000000001e7b20 # .block_is_partially_uptodate+0xc0/0x100
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: <arunabal@in.ibm.com>
Cc: <sbest@us.ibm.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
commit 27d20fddc8af539464fc3ba499d6a830054c3bd6 upstream.
Salman Qazi describes the following radix-tree bug:
In the following case, we get can get a deadlock:
0. The radix tree contains two items, one has the index 0.
1. The reader (in this case find_get_pages) takes the rcu_read_lock.
2. The reader acquires slot(s) for item(s) including the index 0 item.
3. The non-zero index item is deleted, and as a consequence the other item is
moved to the root of the tree. The place where it used to be is queued for
deletion after the readers finish.
3b. The zero item is deleted, removing it from the direct slot, it remains in
the rcu-delayed indirect node.
4. The reader looks at the index 0 slot, and finds that the page has 0 ref
count
5. The reader looks at it again, hoping that the item will either be freed or
the ref count will increase. This never happens, as the slot it is looking
at will never be updated. Also, this slot can never be reclaimed because
the reader is holding rcu_read_lock and is in an infinite loop.
The fix is to re-use the same "indirect" pointer case that requires a slot
lookup retry into a general "retry the lookup" bit.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Reported-by: Salman Qazi <sqazi@google.com>
commit 44e2aa937e698ea95dd86b2a4fabd734ef2c76db upstream.
Add missing spin_lock() of the page_table_lock before an error return in
hugetlb_cow(). Callers of hugtelb_cow() expect it to be held upon return.
commit 572438f9b52236bd8938b1647cc15e027d27ef55 upstream.
page_order() is called by memory hotplug's user interface to check the
section is removable or not. (is_mem_section_removable())
It calls page_order() withoug holding zone->lock.
So, even if the caller does
if (PageBuddy(page))
ret = page_order(page) ...
The caller may hit BUG_ON().
For fixing this, there are 2 choices.
1. add zone->lock.
2. remove BUG_ON().
is_mem_section_removable() is used for some "advice" and doesn't need to
be 100% accurate. This is_removable() can be called via user program..
We don't want to take this important lock for long by user's request. So,
this patch removes BUG_ON().
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Mel Gorman <mel@csn.ul.ie>
commit b7f50cfa3630b6e079929ffccfd442d65064ee1f upstream.
There is a bug in commit 6dda9d55 ("page allocator: reduce fragmentation
in buddy allocator by adding buddies that are merging to the tail of the
free lists") that means a buddy at order MAX_ORDER is checked for merging.
A page of this order never exists so at times, an effectively random
piece of memory is being checked.
Alan Curry has reported that this is causing memory corruption in
userspace data on a PPC32 platform (http://lkml.org/lkml/2010/10/9/32).
It is not clear why this is happening. It could be a cache coherency
problem where pages mapped in both user and kernel space are getting
different cache lines due to the bad read from kernel space
(http://lkml.org/lkml/2010/10/13/179). It could also be that there are
some special registers being io-remapped at the end of the memmap array
and that a read has special meaning on them. Compiler bugs have been
ruled out because the assembly before and after the patch looks relatively
harmless.
This patch fixes the problem by ensuring we are not reading a possibly
invalid location of memory. It's not clear why the read causes corruption
but one way or the other it is a buggy read.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Corrado Zoccolo <czoccolo@gmail.com>
Reported-by: Alan Curry <pacman@kosh.dhis.org>
commit f8f72ad5396987e05a42cf7eff826fb2a15ff148 upstream.
scan_lru_pages returns pfn. So, it's type should be "unsigned long"
not "int".
Note: I guess this has been work until now because memory hotplug tester's
machine has not very big memory....
physical address < 32bit << PAGE_SHIFT.
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 800416f799e0723635ac2d720ad4449917a1481c upstream.
When a node contains only HighMem memory, slab_node(MPOL_BIND)
dereferences a NULL pointer.
[ This code seems to go back all the way to commit 19770b32609b: "mm:
filter based on a nodemask as well as a gfp_mask". Which was back in
April 2008, and it got merged into 2.6.26. - Linus ]
Cc: Christoph Lameter <cl@linux.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
commit 3ee48b6af49cf534ca2f481ecc484b156a41451d upstream.
During the reading of /proc/vmcore the kernel is doing
ioremap()/iounmap() repeatedly. And the buildup of un-flushed
vm_area_struct's is causing a great deal of overhead. (rb_next()
is chewing up most of that time).
This solution is to provide function set_iounmap_nonlazy(). It
causes a subsequent call to iounmap() to immediately purge the
vma area (with try_purge_vmap_area_lazy()).
With this patch we have seen the time for writing a 250MB
compressed dump drop from 71 seconds to 44 seconds.
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Cc: kexec@lists.infradead.org
LKML-Reference: <E1OwHZ4-0005WK-Tw@eag09.americas.sgi.com>
arch/arm/mach-tegra/tegra_i2s_audio.c
Change-Id: I3e05a70e3fb8fdaa8ca4c5ed78ca020c75ed0caa
Based on patch by rmk on lkml at http://lkml.org/lkml/2010/10/11/179
Reverts changes to find_limits to fix crash when using memblock_remove
on the end of memory.
Original-author: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Colin Cross <ccross@android.com>
Change-Id: I6137a7939329381e4ed34bfcdc8b713dc50ebcc8
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6:
HWPOISON: Stop shrinking at right page count
HWPOISON: Report correct address granuality for AO huge page errors
HWPOISON: Copy si_addr_lsb to user
page-types.c: fix name of unpoison interface
We need to check parent's thresholds if parent has use_hierarchy == 1 to
be sure that parent's threshold events will be triggered even if parent
itself is not active (no MEM_CGROUP_EVENTS).
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
During boot of a 16TB system, the following is printed:
Dentry cache hash table entries: -2147483648 (order: 22, 17179869184 bytes)
Signed-off-by: Robin Holt <holt@sgi.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
When we call the slab shrinker to free a page we need to stop at
page count one because the caller always holds a single reference, not zero.
This avoids useless looping over slab shrinkers and freeing too much
memory.
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
The SIGBUS user space signalling is supposed to report the
address granuality of a corruption. Pass this information correctly
for huge pages by querying the hpage order.
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Building under memory pressure, with KSM on 2.6.36-rc5, collapsed with
an internal compiler error: typically indicating an error in swapping.
Perhaps there's a timing issue which makes it now more likely, perhaps
it's just a long time since I tried for so long: this bug goes back to
KSM swapping in 2.6.33.
Notice how reuse_swap_page() allows an exclusive page to be reused, but
only does SetPageDirty if it can delete it from swap cache right then -
if it's currently under Writeback, it has to be left in cache and we
don't SetPageDirty, but the page can be reused. Fine, the dirty bit
will get set in the pte; but notice how zap_pte_range() does not bother
to transfer pte_dirty to page_dirty when unmapping a PageAnon.
If KSM chooses to share such a page, it will look like a clean copy of
swapcache, and not be written out to swap when its memory is needed;
then stale data read back from swap when it's needed again.
We could fix this in reuse_swap_page() (or even refuse to reuse a
page under writeback), but it's more honest to fix my oversight in
KSM's write_protect_page(). Several days of testing on three machines
confirms that this fixes the issue they showed.
Cc: stable@kernel.org
2.6.36-rc1 commit 21d0d443cdc1658a8c1484fdcece4803f0f96d0e "rmap:
resurrect page_address_in_vma anon_vma check" was right to resurrect
that check; but now that it's comparing anon_vma->roots instead of
just anon_vmas, there's a danger of oopsing on a NULL anon_vma.
In most cases no NULL anon_vma ever gets here; but it turns out that
occasionally KSM, when enabled on a forked or forking process, will
itself call page_address_in_vma() on a "half-KSM" page left over from
an earlier failed attempt to merge - whose page_anon_vma() is NULL.
It's my bug that those should be getting here at all: I thought they
were already dealt with, this oops proves me wrong, I'll fix it in
the next release - such pages are effectively pinned until their
process exits, since rmap cannot find their ptes (though swapoff can).
For now just work around it by making page_address_in_vma() safe (and
add a comment on why that check is wanted anyway). A similar check
in __page_check_anon_rmap() is safe because do_page_add_anon_rmap()
already excluded KSM pages.
Signed-off-by: Bjorn Bringert <bringert@android.com>
Change-Id: I509d18b21832e229737ea7ebaa231fb107eb61d7
Change-Id: Ie527d18f3352ede06d565826c8d35ded1638203a
Signed-off-by: Colin Cross <ccross@google.com>
Change-Id: I1412cc9560de8c4feb1162fc30922f0e3362a476
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Bug: 2595601
Change-Id: I47c0016f594f9354fb8658ccb26e3d395bcb137b
Forward port of ashmem to 2.6.27.
Signed-off-by: Robert Love <rlove@google.com>
ashmem: Don't install fault handler for private mmaps.
Ashmem is used to create named private heaps. If this heap is backed
by a tmpfs file it will allocate two pages for every page touched.
In 2.6.27, the extra page would later be freed, but 2.6.29 does not
scan anonymous pages when running without swap so the memory is not
freed while the file is referenced. This change changes the behavior
of private ashmem mmaps to match /dev/zero instead tmpfs.
ashmem: Add common prefix to name reported in /proc/pid/maps
ashmem: don't require a page aligned size
This makes ashmem more similar to shmem and mmap, by
not requiring the specified size to be page aligned,
instead rounding it internally as needed.
Signed-off-by: Marco Nelissen <marcone@android.com>
MIGRATE_RESERVE
This fixes a problem where the first pageblock got marked MIGRATE_RESERVE even
though it only had a few free pages. This in turn caused no contiguous memory
to be reserved and frequent kswapd wakeups that emptied the caches to get more
contiguous memory.
By default the kernel tries to keep half as much memory free at each
order as it does for one order below. This can be too agressive when
running without swap.
Change-Id: I5efc1a0b50f41ff3ac71e92d2efd175dedd54ead
Thomas Pollet noticed that the remap_file_pages() system call in
fremap.c has a potential overflow in the first part of the if statement
below, which could cause it to process bogus input parameters.
Specifically the pgoff + size parameters could be wrap thereby
preventing the system call from failing when it should.
Reported-by: Thomas Pollet <thomas.pollet@gmail.com>
Signed-off-by: Larry Woodman <lwoodman@redhat.com>
Thomas Pollet points out that the 'end' variable is broken. It was
computed based on start/size before they were page-aligned, and as such
doesn't actually match any of the other actions we take. The overflow
test on end was also redundant, since we had already tested it with the
properly aligned version.
So just get rid of it entirely. The one remaining use for that broken
variable can just use 'start+size' like all the other cases already did.
Confirming page lock is held in hugetlb_add_anon_rmap() may be useful
to detect possible future problems.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
The "if (!trylock_page)" block in the avoidcopy path of hugetlb_cow()
looks confusing and is buggy. Originally this trylock_page() was
intended to make sure that old_page is locked even when old_page !=
pagecache_page, because then only pagecache_page is locked.
This patch fixes it by moving page locking into hugetlb_fault().
Obviously, setting anon_vma for COWed hugepage should be done
by hugepage_add_new_anon_rmap() to scan vmas faster.
This patch fixes it.
This patch applies Andrea's fix given by the following patch into hugepage
rmapping code:
commit 288468c334e98aacbb7e2fb8bde6bc1adcd55e05
Author: Andrea Arcangeli <aarcange@redhat.com>
Date: Mon Aug 9 17:19:09 2010 -0700
This patch uses anon_vma->root and avoids unnecessary overwriting when
anon_vma is already set up.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: fix pcpu_last_unit_cpu
If __split_vma fails because of an out of memory condition the
anon_vma_chain isn't teardown and freed potentially leading to rmap walks
accessing freed vma information plus there's a memleak.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Johannes Weiner <jweiner@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: <stable@kernel.org>
/proc/sys/vm/oom_dump_tasks is enabled by default, so it's necessary to
limit as much information as possible that it should emit.
The tasklist dump should be filtered to only those tasks that are eligible
for oom kill. This is already done for memcg ooms, but this patch extends
it to both cpuset and mempolicy ooms as well as init.
In addition to suppressing irrelevant information, this also reduces
confusion since users currently don't know which tasks in the tasklist
aren't eligible for kill (such as those attached to cpusets or bound to
mempolicies with a disjoint set of mems or nodes, respectively) since that
information is not shown.
Signed-off-by: David Rientjes <rientjes@google.com>
M. Vefa Bicakci reported 2.6.35 kernel hang up when hibernation on his
32bit 3GB mem machine.
(https://bugzilla.kernel.org/show_bug.cgi?id=16771). Also he bisected
the regression to
commit bb21c7ce18eff8e6e7877ca1d06c6db719376e3c
Author: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Date: Fri Jun 4 14:15:05 2010 -0700
vmscan: fix do_try_to_free_pages() return value when priority==0 reclaim failure
At first impression, this seemed very strange because the above commit
only chenged function return value and hibernate_preallocate_memory()
ignore return value of shrink_all_memory(). But it's related.
Now, page allocation from hibernation code may enter infinite loop if the
system has highmem. The reasons are that vmscan don't care enough OOM
case when oom_killer_disabled.
The problem sequence is following as.
1. hibernation
2. oom_disable
3. alloc_pages
4. do_try_to_free_pages
if (scanning_global_lru(sc) && !all_unreclaimable)
return 1;
If kswapd is not freozen, it would set zone->all_unreclaimable to 1 and
then shrink_zones maybe return true(ie, all_unreclaimable is true). So at
last, alloc_pages could go to _nopage_. If it is, it should have no
problem.
This patch adds all_unreclaimable check to protect in direct reclaim path,
too. It can care of hibernation OOM case and help bailout
all_unreclaimable case slightly.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reported-by: M. Vefa Bicakci <bicave@superonline.com>
Reported-by: <caiqian@redhat.com>
Tested-by: <caiqian@redhat.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Balbir Singh <balbir@in.ibm.com>
A task's badness score is roughly a proportion of its rss and swap
compared to the system's capacity. The scale ranges from 0 to 1000 with
the highest score chosen for kill. Thus, this scale operates on a
resolution of 0.1% of RAM + swap. Admin tasks are also given a 3% bonus,
so the badness score of an admin task using 3% of memory, for example,
would still be 0.
It's possible that an exceptionally large number of tasks will combine to
exhaust all resources but never have a single task that uses more than
0.1% of RAM and swap (or 3.0% for admin tasks).
This patch ensures that the badness score of any eligible task is never 0
so the machine doesn't unnecessarily panic because it cannot find a task
to kill.
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
bdi: Fix warnings in __mark_inode_dirty for /dev/zero and friends
char: Mark /dev/zero and /dev/kmem as not capable of writeback
bdi: Initialize noop_backing_dev_info properly
cfq-iosched: fix a kernel OOPs when usb key is inserted
block: fix blk_rq_map_kern bio direction flag
cciss: freeing uninitialized data on error path
Properly initialize this backing dev info so that writeback code does not
barf when getting to it e.g. via sb->s_bdi.
