path: root/mm
2012-06-20mm, mempolicy: fix mbind() to do synchronous migrationDavid Rientjes
If the range passed to mbind() is not allocated on nodes set in the nodemask, it migrates the pages to respect the constraint. The final formal of migrate_pages() is a mode of type enum migrate_mode, not a boolean. do_mbind() is currently passing "true" which is the equivalent of MIGRATE_SYNC_LIGHT. This should instead be MIGRATE_SYNC for synchronous page migration. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-20mm/memblock: fix overlapping allocation when doubling reserved arrayGreg Pearson
__alloc_memory_core_early() asks memblock for a range of memory then try to reserve it. If the reserved region array lacks space for the new range, memblock_double_array() is called to allocate more space for the array. If memblock is used to allocate memory for the new array it can end up using a range that overlaps with the range originally allocated in __alloc_memory_core_early(), leading to possible data corruption. With this patch memblock_double_array() now calls memblock_find_in_range() with a narrowed candidate range (in cases where the reserved.regions array is being doubled) so any memory allocated will not overlap with the original range that was being reserved. The range is narrowed by passing in the starting address and size of the previously allocated range. Then the range above the ending address is searched and if a candidate is not found, the range below the starting address is searched. Signed-off-by: Greg Pearson <greg.pearson@hp.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Tejun Heo <tj@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-20mm/memory.c: fix kernel-doc warningsRandy Dunlap
Fix kernel-doc warnings in mm/memory.c: Warning(mm/memory.c:1377): No description found for parameter 'start' Warning(mm/memory.c:1377): Excess function parameter 'address' description in 'zap_page_range' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-20mm: fix kernel-doc warningsWanpeng Li
Fix kernel-doc warnings such as Warning(../mm/page_cgroup.c:432): No description found for parameter 'id' Warning(../mm/page_cgroup.c:432): Excess function parameter 'mem' description in 'swap_cgroup_record' Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-20mm, thp: print useful information when mmap_sem is unlocked in zap_pmd_rangeDavid Rientjes
Andrea asked for addr, end, vma->vm_start, and vma->vm_end to be emitted when !rwsem_is_locked(&tlb->mm->mmap_sem). Otherwise, debugging the underlying issue is more difficult. Suggested-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-20memcg: fix use_hierarchy css_is_ancestor oops regressionHugh Dickins
If use_hierarchy is set, reclaim testing soon oopses in css_is_ancestor() called from __mem_cgroup_same_or_subtree() called from page_referenced(): when processes are exiting, it's easy for mm_match_cgroup() to pass along a NULL memcg coming from a NULL mm->owner. Check for that in __mem_cgroup_same_or_subtree(). Return true or false? False because we cannot know if it was in the hierarchy, but also false because it's better not to count a reference from an exiting process. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-20mm, oom: fix and cleanup oom score calculationsDavid Rientjes
The divide in p->signal->oom_score_adj * totalpages / 1000 within oom_badness() was causing an overflow of the signed long data type. This adds both the root bias and p->signal->oom_score_adj before doing the normalization which fixes the issue and also cleans up the calculation. Tested-by: Dave Jones <davej@redhat.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-15swap: fix shmem swapping when more than 8 areasHugh Dickins
Minchan Kim reports that when a system has many swap areas, and tmpfs swaps out to the ninth or more, shmem_getpage_gfp()'s attempts to read back the page cannot locate it, and the read fails with -ENOMEM. Whoops. Yes, I blindly followed read_swap_header()'s pte_to_swp_entry( swp_entry_to_pte()) technique for determining maximum usable swap offset, without stopping to realize that that actually depends upon the pte swap encoding shifting swap offset to the higher bits and truncating it there. Whereas our radix_tree swap encoding leaves offset in the lower bits: it's swap "type" (that is, index of swap area) that was truncated. Fix it by reducing the SWP_TYPE_SHIFT() in swapops.h, and removing the broken radix_to_swp_entry(swp_to_radix_entry()) from read_swap_header(). This does not reduce the usable size of a swap area any further, it leaves it as claimed when making the original commit: no change from 3.0 on x86_64, nor on i386 without PAE; but 3.0's 512GB is reduced to 128GB per swapfile on i386 with PAE. It's not a change I would have risked five years ago, but with x86_64 supported for ten years, I believe it's appropriate now. Hmm, and what if some architecture implements its swap pte with offset encoded below type? That would equally break the maximum usable swap offset check. Happily, they all follow the same tradition of encoding offset above type, but I'll prepare a check on that for next. Reported-and-Reviewed-and-Tested-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@vger.kernel.org [3.1, 3.2, 3.3, 3.4] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-15Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core updates (RCU and locking) from Ingo Molnar: "Most of the diffstat comes from the RCU slow boot regression fixes, but there's also a debuggability improvements/fixes." * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: memblock: Document memblock_is_region_{memory,reserved}() rcu: Precompute RCU_FAST_NO_HZ timer offsets rcu: Move RCU_FAST_NO_HZ per-CPU variables to rcu_dynticks structure rcu: Update RCU_FAST_NO_HZ tracing for lazy callbacks rcu: RCU_FAST_NO_HZ detection of callback adoption spinlock: Indicate that a lockup is only suspected kdump: Execute kmsg_dump(KMSG_DUMP_PANIC) after smp_send_stop() panic: Make panic_on_oops configurable
2012-06-08mm, oom: fix badness score underflowDavid Rientjes
If the privileges given to root threads (3% of allowable memory) or a negative value of /proc/pid/oom_score_adj happen to exceed the amount of rss of a thread, its badness score overflows as a result of commit a7f638f999ff ("mm, oom: normalize oom scores to oom_score_adj scale only for userspace"). Fix this by making the type signed and return 1, meaning the thread is still eligible for kill, if the value is negative. Reported-by: Dave Jones <davej@redhat.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-08memblock: Document memblock_is_region_{memory,reserved}()Stephen Boyd
At first glance one would think that memblock_is_region_memory() and memblock_is_region_reserved() would be implemented in the same way. Unfortunately they aren't and the former returns whether the region specified is a subset of a memory bank while the latter returns whether the region specified intersects with reserved memory. Document the two functions so that users aren't tempted to make the implementation the same between them and to clarify the purpose of the functions. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/1337845521-32755-1-git-send-email-sboyd@codeaurora.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-06-07shmem: replace_page must flush_dcache and othersHugh Dickins
Commit bde05d1ccd51 ("shmem: replace page if mapping excludes its zone") is not at all likely to break for anyone, but it was an earlier version from before review feedback was incorporated. Fix that up now. * shmem_replace_page must flush_dcache_page after copy_highpage [akpm] * Expand comment on why shmem_unuse_inode needs page_swapcount [akpm] * Remove excess of VM_BUG_ONs from shmem_replace_page [wangcong] * Check page_private matches swap before calling shmem_replace_page [hughd] * shmem_replace_page allow for unexpected race in radix_tree lookup [hughd] Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Stephane Marchesin <marcheu@chromium.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Dave Airlie <airlied@gmail.com> Cc: Daniel Vetter <daniel@ffwll.ch> Cc: Rob Clark <rob.clark@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-04Pull 'for-linus' branches of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/{signal,vfs} Pull signal and vfs compile breakage fixes from Al Viro. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: fixups for signal breakage * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nommu: fix compilation of nommu.c
2012-06-04nommu: fix compilation of nommu.cGreg Ungerer
Compiling 3.5-rc1 for nommu targets gives: CC mm/nommu.o mm/nommu.c: In function ‘sys_mmap_pgoff’: mm/nommu.c:1489:2: error: ‘ret’ undeclared (first use in this function) mm/nommu.c:1489:2: note: each undeclared identifier is reported only once for each function it appears in It is trivially fixed by replacing 'ret' with the local variable that is already defined for the return value 'retval'. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-04Merge tag 'stable/frontswap.v16-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull frontswap feature from Konrad Rzeszutek Wilk: "Frontswap provides a "transcendent memory" interface for swap pages. In some environments, dramatic performance savings may be obtained because swapped pages are saved in RAM (or a RAM-like device) instead of a swap disk. This tag provides the basic infrastructure along with some changes to the existing backends." Fix up trivial conflict in mm/Makefile due to removal of swap token code changing a line next to the new frontswap entry. This pull request came in before the merge window even opened, it got delayed to after the merge window by me just wanting to make sure it had actual users. Apparently IBM is using this on their embedded side, and Jan Beulich says that it's already made available for SLES and OpenSUSE users. Also acked by Rik van Riel, and Konrad points to other people liking it too. So in it goes. By Dan Magenheimer (4) and Konrad Rzeszutek Wilk (2) via Konrad Rzeszutek Wilk * tag 'stable/frontswap.v16-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: frontswap: s/put_page/store/g s/get_page/load MAINTAINER: Add myself for the frontswap API mm: frontswap: config and doc files mm: frontswap: core frontswap functionality mm: frontswap: core swap subsystem hooks and headers mm: frontswap: add frontswap header file
2012-06-03Revert "mm: compaction: handle incorrect MIGRATE_UNMOVABLE type pageblocks"Linus Torvalds
This reverts commit 5ceb9ce6fe9462a298bb2cd5c9f1ca6cb80a0199. That commit seems to be the cause of the mm compation list corruption issues that Dave Jones reported. The locking (or rather, absense there-of) is dubious, as is the use of the 'page' variable once it has been found to be outside the pageblock range. So revert it for now, we can re-visit this for 3.6. If we even need to: as Minchan Kim says, "The patch wasn't a bug fix and even test workload was very theoretical". Reported-and-tested-by: Dave Jones <davej@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-03mm: fix warning in __set_page_dirty_nobuffersHugh Dickins
New tmpfs use of !PageUptodate pages for fallocate() is triggering the WARNING: at mm/page-writeback.c:1990 when __set_page_dirty_nobuffers() is called from migrate_page_copy() for compaction. It is anomalous that migration should use __set_page_dirty_nobuffers() on an address_space that does not participate in dirty and writeback accounting; and this has also been observed to insert surprising dirty tags into a tmpfs radix_tree, despite tmpfs not using tags at all. We should probably give migrate_page_copy() a better way to preserve the tag and migrate accounting info, when mapping_cap_account_dirty(). But that needs some more work: so in the interim, avoid the warning by using a simple SetPageDirty on PageSwapBacked pages. Reported-and-tested-by: Dave Jones <davej@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-01Merge branch 'slab/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull slab updates from Pekka Enberg: "Mainly a bunch of SLUB fixes from Joonsoo Kim" * 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: slub: use __SetPageSlab function to set PG_slab flag slub: fix a memory leak in get_partial_node() slub: remove unused argument of init_kmem_cache_node() slub: fix a possible memory leak Documentations: Fix slabinfo.c directory in vm/slub.txt slub: fix incorrect return type of get_any_partial()
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-06-01fs: introduce inode operation ->update_timeJosef Bacik
Btrfs has to make sure we have space to allocate new blocks in order to modify the inode, so updating time can fail. We've gotten around this by having our own file_update_time but this is kind of a pain, and Christoph has indicated he would like to make xfs do something different with atime updates. So introduce ->update_time, where we will deal with i_version an a/m/c time updates and indicate which changes need to be made. The normal version just does what it has always done, updates the time and marks the inode dirty, and then filesystems can choose to do something different. I've gone through all of the users of file_update_time and made them check for errors with the exception of the fault code since it's complicated and I wasn't quite sure what to do there, also Jan is going to be pushing the file time updates into page_mkwrite for those who have it so that should satisfy btrfs and make it not a big deal to check the file_update_time() return code in the generic fault path. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2012-06-01unexport do_munmap()Al Viro
2012-06-01new helper: vm_mmap_pgoff()Al Viro
take it to mm/util.c, convert vm_mmap() to use of that one and take it to mm/util.c as well, convert both sys_mmap_pgoff() to use of vm_mmap_pgoff() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01kill do_mmap() completelyAl Viro
just pull into vm_mmap() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01switch aio and shm to do_mmap_pgoff(), make do_mmap() staticAl Viro
after all, 0 bytes and 0 pages is the same thing... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01move security_mmap_addr() to saner placeAl Viro
it really should be done by get_unmapped_area(); that cuts down on the amount of callers considerably and it's the right place for that stuff anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01take security_mmap_file() outside of ->mmap_semAl Viro
2012-05-31Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge misc patches from Andrew Morton: - the "misc" tree - stuff from all over the map - checkpatch updates - fatfs - kmod changes - procfs - cpumask - UML - kexec - mqueue - rapidio - pidns - some checkpoint-restore feature work. Reluctantly. Most of it delayed a release. I'm still rather worried that we don't have a clear roadmap to completion for this work. * emailed from Andrew Morton <akpm@linux-foundation.org>: (78 patches) kconfig: update compression algorithm info c/r: prctl: add ability to set new mm_struct::exe_file c/r: prctl: extend PR_SET_MM to set up more mm_struct entries c/r: procfs: add arg_start/end, env_start/end and exit_code members to /proc/$pid/stat syscalls, x86: add __NR_kcmp syscall fs, proc: introduce /proc/<pid>/task/<tid>/children entry sysctl: make kernel.ns_last_pid control dependent on CHECKPOINT_RESTORE aio/vfs: cleanup of rw_copy_check_uvector() and compat_rw_copy_check_uvector() eventfd: change int to __u64 in eventfd_signal() fs/nls: add Apple NLS pidns: make killed children autoreap pidns: use task_active_pid_ns in do_notify_parent rapidio/tsi721: add DMA engine support rapidio: add DMA engine support for RIO data transfers ipc/mqueue: add rbtree node caching support tools/selftests: add mq_perf_tests ipc/mqueue: strengthen checks on mqueue creation ipc/mqueue: correct mq_attr_ok test ipc/mqueue: improve performance of send/recv selftests: add mq_open_tests ...
2012-05-31aio/vfs: cleanup of rw_copy_check_uvector() and compat_rw_copy_check_uvector()Christopher Yeoh
A cleanup of rw_copy_check_uvector and compat_rw_copy_check_uvector after changes made to support CMA in an earlier patch. Rather than having an additional check_access parameter to these functions, the first paramater type is overloaded to allow the caller to specify CHECK_IOVEC_ONLY which means check that the contents of the iovec are valid, but do not check the memory that they point to. This is used by process_vm_readv/writev where we need to validate that a iovec passed to the syscall is valid but do not want to check the memory that it points to at this point because it refers to an address space in another process. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31split ->file_mmap() into ->mmap_addr()/->mmap_file()Al Viro
... i.e. file-dependent and address-dependent checks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-30unexport do_mmap()Al Viro
2012-05-30merge do_mremap() into sys_mremap()Al Viro
2012-05-30fs: move file_remove_suid() to fs/inode.cCong Wang
file_remove_suid() is a generic function operates on struct file, it almost has no relations with file mapping, so move it to fs/inode.c. Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-30mm: fix vma_resv_map() NULL pointerDave Hansen
hugetlb_reserve_pages() can be used for either normal file-backed hugetlbfs mappings, or MAP_HUGETLB. In the MAP_HUGETLB, semi-anonymous mode, there is not a VMA around. The new call to resv_map_put() assumed that there was, and resulted in a NULL pointer dereference: BUG: unable to handle kernel NULL pointer dereference at 0000000000000030 IP: vma_resv_map+0x9/0x30 PGD 141453067 PUD 1421e1067 PMD 0 Oops: 0000 [#1] PREEMPT SMP ... Pid: 14006, comm: trinity-child6 Not tainted 3.4.0+ #36 RIP: vma_resv_map+0x9/0x30 ... Process trinity-child6 (pid: 14006, threadinfo ffff8801414e0000, task ffff8801414f26b0) Call Trace: resv_map_put+0xe/0x40 hugetlb_reserve_pages+0xa6/0x1d0 hugetlb_file_setup+0x102/0x2c0 newseg+0x115/0x360 ipcget+0x1ce/0x310 sys_shmget+0x5a/0x60 system_call_fastpath+0x16/0x1b This was reported by Dave Jones, but was reproducible with the libhugetlbfs test cases, so shame on me for not running them in the first place. With this, the oops is gone, and the output of libhugetlbfs's run_tests.py is identical to plain 3.4 again. [ Marked for stable, since this was introduced by commit c50ac050811d ("hugetlb: fix resv_map leak in error path") which was also marked for stable ] Reported-by: Dave Jones <davej@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: <stable@vger.kernel.org> [2.6.32+] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29->encode_fh() API changeAl Viro
pass inode + parent's inode or NULL instead of dentry + bool saying whether we want the parent or not. NOTE: that needs ceph fix folded in. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-29memcg: decrement static keys at real destroy timeGlauber Costa
We call the destroy function when a cgroup starts to be removed, such as by a rmdir event. However, because of our reference counters, some objects are still inflight. Right now, we are decrementing the static_keys at destroy() time, meaning that if we get rid of the last static_key reference, some objects will still have charges, but the code to properly uncharge them won't be run. This becomes a problem specially if it is ever enabled again, because now new charges will be added to the staled charges making keeping it pretty much impossible. We just need to be careful with the static branch activation: since there is no particular preferred order of their activation, we need to make sure that we only start using it after all call sites are active. This is achieved by having a per-memcg flag that is only updated after static_key_slow_inc() returns. At this time, we are sure all sites are active. This is made per-memcg, not global, for a reason: it also has the effect of making socket accounting more consistent. The first memcg to be limited will trigger static_key() activation, therefore, accounting. But all the others will then be accounted no matter what. After this patch, only limited memcgs will have its sockets accounted. [akpm@linux-foundation.org: move enum sock_flag_bits into sock.h, document enum sock_flag_bits, convert memcg_proto_active() and memcg_proto_activated() to test_bit(), redo tcp_update_limit() comment to 80 cols] Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29memcg: always free struct memcg through schedule_work()Glauber Costa
Right now we free struct memcg with kfree right after a rcu grace period, but defer it if we need to use vfree() to get rid of that memory area. We do that by need, because we need vfree to be called in a process context. This patch unifies this behavior, by ensuring that even kfree will happen in a separate thread. The goal is to have a stable place to call the upcoming jump label destruction function outside the realm of the complicated and quite far-reaching cgroup lock (that can't be held when holding either the cpu_hotplug.lock or jump_label_mutex) [akpm@linux-foundation.org: tweak comment] Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/memcg: apply add/del_page to lruvecHugh Dickins
Take lruvec further: pass it instead of zone to add_page_to_lru_list() and del_page_from_lru_list(); and pagevec_lru_move_fn() pass lruvec down to its target functions. This cleanup eliminates a swathe of cruft in memcontrol.c, including mem_cgroup_lru_add_list(), mem_cgroup_lru_del_list() and mem_cgroup_lru_move_lists() - which never actually touched the lists. In their place, mem_cgroup_page_lruvec() to decide the lruvec, previously a side-effect of add, and mem_cgroup_update_lru_size() to maintain the lru_size stats. Whilst these are simplifications in their own right, the goal is to bring the evaluation of lruvec next to the spin_locking of the lrus, in preparation for a future patch. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: trivial cleanups in vmscan.cHugh Dickins
Utter trivia in mm/vmscan.c, mostly just reducing the linecount slightly; most exciting change being get_scan_count() calling vmscan_swappiness() once instead of twice. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/memcg: get_lru_size not get_lruvec_sizeHugh Dickins
Konstantin just introduced mem_cgroup_get_lruvec_size() and get_lruvec_size(), I'm about to add mem_cgroup_update_lru_size(): but we're dealing with the same thing, lru_size[lru]. We ought to agree on the naming, and I do think lru_size is the more correct: so rename his ones to get_lru_size(). Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: memcg: print statistics from live countersJohannes Weiner
Directly print statistics and event counters instead of going through an intermediate accumulation stage into a separate array, which used to require defining statistic items in more than one place. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: memcg: group swapped-out statistics counter logicallyJohannes Weiner
The counter of currently swapped out pages in a memcg (hierarchy) is sitting amidst ever-increasing event counters. Move this item to the other counters that reflect current state rather than history. This technically breaks the kernel ABI, but hopefully nobody relies on the order of items in memory.stat. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: memcg: keep ratelimit counter separate from event countersJohannes Weiner
All events except the ratelimit counter are statistics exported to userspace. Keep this internal value out of the event count array. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: memcg: print statistics directly to seq_fileJohannes Weiner
Being able to use seq_printf() allows being smarter about statistics name strings, which are currently listed twice, with the only difference being a "total_" prefix on the hierarchical version. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: memcg: convert numa stat to read_seq_string interfaceJohannes Weiner
Instead of using the raw seq_file file interface, switch over to the read_seq_string cftype callback and let cgroup core code set up the seq_file. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: memcg: remove obsolete statistics array boundary enum itemJohannes Weiner
MEM_CGROUP_STAT_DATA is a leftover from when item counters were living in the same array as ever-increasing event counters. It's no longer needed, use MEM_CGROUP_STAT_NSTATS to iterate over the stat array. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29memcg: don't uncharge in mem_cgroup_move_account()KAMEZAWA Hiroyuki
Now, all callers pass 'false' for 'bool uncharge' so remove this argument. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ying Han <yinghan@google.com> Cc: Glauber Costa <glommer@parallels.com> Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29memcg: move charges to root cgroup if use_hierarchy=0KAMEZAWA Hiroyuki
Presently, at removal of cgroup, ->pre_destroy() is called and moves charges to the parent cgroup. A major reason for returning -EBUSY from ->pre_destroy() is that the 'moving' hits the parent's resource limitation. It happens only when use_hierarchy=0. Considering use_hierarchy=0, all cgroups should be flat. So, no one cannot justify moving charges to parent...parent and children are in flat configuration, not hierarchical. This patch modifes the code to move charges to the root cgroup at rmdir/force_empty if use_hierarchy==0. This will much simplify rmdir() and reduce error in ->pre_destroy. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ying Han <yinghan@google.com> Cc: Glauber Costa <glommer@parallels.com> Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29memcg: use res_counter_uncharge_until() in move_parent()KAMEZAWA Hiroyuki
By using res_counter_uncharge_until(), we can avoid race and unnecessary charging. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ying Han <yinghan@google.com> Cc: Glauber Costa <glommer@parallels.com> Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/vmscan: kill struct mem_cgroup_zoneKonstantin Khlebnikov
Kill struct mem_cgroup_zone and rename shrink_mem_cgroup_zone() to shrink_lruvec(), it always shrinks one lruvec which it takes as an argument. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/vmscan: push lruvec pointer into should_continue_reclaim()Konstantin Khlebnikov
