commit c9e664f1fdf34aa8cede047b206deaa8f1945af0 upstream.
There is a problem that swap pages allocated before the creation of
a hibernation image can be released and used for storing the contents
of different memory pages while the image is being saved. Since the
kernel stored in the image doesn't know of that, it causes memory
corruption to occur after resume from hibernation, especially on
systems with relatively small RAM that need to swap often.
This issue can be addressed by keeping the GFP_IOFS bits clear
in gfp_allowed_mask during the entire hibernation, including the
saving of the image, until the system is finally turned off or
the hibernation is aborted. Unfortunately, for this purpose
it's necessary to rework the way in which the hibernate and
suspend code manipulates gfp_allowed_mask.
This change is based on an earlier patch from Hugh Dickins.
Reported-by: Ondrej Zary <linux@rainbow-software.org>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit b1dd693e5b9348bd68a80e679e03cf9c0973b01b upstream.
__mem_cgroup_try_charge() can be called under down_write(&mmap_sem)(e.g.
mlock does it). This means it can cause deadlock if it races with move charge:
Ex.1)
move charge | try charge
mem_cgroup_can_attach() | down_write(&mmap_sem)
mc.moving_task = current | ..
mem_cgroup_precharge_mc() | __mem_cgroup_try_charge()
mem_cgroup_count_precharge() | prepare_to_wait()
down_read(&mmap_sem) | if (mc.moving_task)
-> cannot aquire the lock | -> true
| schedule()
Ex.2)
up_read(&mmap_sem) |
mem_cgroup_move_task() | ..
mem_cgroup_move_charge() | __mem_cgroup_try_charge()
down_read(&mmap_sem) | prepare_to_wait()
-> cannot aquire the lock | if (mc.moving_task)
| -> true
| schedule()
To avoid this deadlock, we do all the move charge works (both can_attach() and
attach()) under one mmap_sem section.
And after this patch, we set/clear mc.moving_task outside mc.lock, because we
use the lock only to check mc.from/to.
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 63bfd7384b119409685a17d5c58f0b56e5dc03da upstream.
As pointed out by Linus, commit dab5855 ("perf_counter: Add mmap event hooks to
mprotect()") is fundamentally wrong as mprotect_fixup() can free 'vma' due to
merging. Fix the problem by moving perf_event_mmap() hook to
mprotect_fixup().
Note: there's another successful return path from mprotect_fixup() if old
flags equal to new flags. We don't, however, need to call
perf_event_mmap() there because 'perf' already knows the VMA is
executable.
Reported-by: Dave Jones <davej@redhat.com>
Analyzed-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
commit 04c3496152394d17e3bc2316f9731ee3e8a026bc upstream.
Depending on processor speed, page size, and the amount of memory a
process is allowed to amass, cleanup of a large VM may freeze the system
for many seconds. This can result in a watchdog timeout.
Make sure other tasks receive some service when cleaning up large VMs.
Signed-off-by: Steven J. Magnani <steve@digidescorp.com>
Cc: Greg Ungerer <gerg@snapgear.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 1f64d69c7ad2e48e697493e45590679f7a69b7b2 upstream.
Have hugetlb_fault() call unlock_page(page) only if it had previously
called lock_page(page).
Setting CONFIG_DEBUG_VM=y and then running the libhugetlbfs test suite,
resulted in the tripping of VM_BUG_ON(!PageLocked(page)) in
unlock_page() having been called by hugetlb_fault() when page ==
pagecache_page. This patch remedied the problem.
Signed-off-by: Dean Nelson <dnelson@redhat.com>
commit 8d056cb965b8fb7c53c564abf28b1962d1061cd3 upstream.
70 hours into some stress tests of a 2.6.32-based enterprise kernel, we
ran into a NULL dereference in here:
int block_is_partially_uptodate(struct page *page, read_descriptor_t *desc,
unsigned long from)
----> struct inode *inode = page->mapping->host;
It looks like page->mapping was the culprit. (xmon trace is below).
After closer examination, I realized that do_generic_file_read() does a
find_get_page(), and eventually locks the page before calling
block_is_partially_uptodate(). However, it doesn't revalidate the
page->mapping after the page is locked. So, there's a small window
between the find_get_page() and ->is_partially_uptodate() where the page
could get truncated and page->mapping cleared.
We _have_ a reference, so it can't get reclaimed, but it certainly
can be truncated.
I think the correct thing is to check page->mapping after the
trylock_page(), and jump out if it got truncated. This patch has been
running in the test environment for a month or so now, and we have not
seen this bug pop up again.
xmon info:
1f:mon> e
cpu 0x1f: Vector: 300 (Data Access) at [c0000002ae36f770]
pc: c0000000001e7a6c: .block_is_partially_uptodate+0xc/0x100
lr: c000000000142944: .generic_file_aio_read+0x1e4/0x770
sp: c0000002ae36f9f0
msr: 8000000000009032
dar: 0
dsisr: 40000000
current = 0xc000000378f99e30
paca = 0xc000000000f66300
pid = 21946, comm = bash
1f:mon> r
R00 = 0025c0500000006d R16 = 0000000000000000
R01 = c0000002ae36f9f0 R17 = c000000362cd3af0
R02 = c000000000e8cd80 R18 = ffffffffffffffff
R03 = c0000000031d0f88 R19 = 0000000000000001
R04 = c0000002ae36fa68 R20 = c0000003bb97b8a0
R05 = 0000000000000000 R21 = c0000002ae36fa68
R06 = 0000000000000000 R22 = 0000000000000000
R07 = 0000000000000001 R23 = c0000002ae36fbb0
R08 = 0000000000000002 R24 = 0000000000000000
R09 = 0000000000000000 R25 = c000000362cd3a80
R10 = 0000000000000000 R26 = 0000000000000002
R11 = c0000000001e7b60 R27 = 0000000000000000
R12 = 0000000042000484 R28 = 0000000000000001
R13 = c000000000f66300 R29 = c0000003bb97b9b8
R14 = 0000000000000001 R30 = c000000000e28a08
R15 = 000000000000ffff R31 = c0000000031d0f88
pc = c0000000001e7a6c .block_is_partially_uptodate+0xc/0x100
lr = c000000000142944 .generic_file_aio_read+0x1e4/0x770
msr = 8000000000009032 cr = 22000488
ctr = c0000000001e7a60 xer = 0000000020000000 trap = 300
dar = 0000000000000000 dsisr = 40000000
1f:mon> t
[link register ] c000000000142944 .generic_file_aio_read+0x1e4/0x770
[c0000002ae36f9f0] c000000000142a14 .generic_file_aio_read+0x2b4/0x770 (unreliable)
[c0000002ae36fb40] c0000000001b03e4 .do_sync_read+0xd4/0x160
[c0000002ae36fce0] c0000000001b153c .vfs_read+0xec/0x1f0
[c0000002ae36fd80] c0000000001b1768 .SyS_read+0x58/0xb0
[c0000002ae36fe30] c00000000000852c syscall_exit+0x0/0x40
--- Exception: c00 (System Call) at 00000080a840bc54
SP (fffca15df30) is in userspace
1f:mon> di c0000000001e7a6c
c0000000001e7a6c e9290000 ld r9,0(r9)
c0000000001e7a70 418200c0 beq c0000000001e7b30 # .block_is_partially_uptodate+0xd0/0x100
c0000000001e7a74 e9440008 ld r10,8(r4)
c0000000001e7a78 78a80020 clrldi r8,r5,32
c0000000001e7a7c 3c000001 lis r0,1
c0000000001e7a80 812900a8 lwz r9,168(r9)
c0000000001e7a84 39600001 li r11,1
c0000000001e7a88 7c080050 subf r0,r8,r0
c0000000001e7a8c 7f805040 cmplw cr7,r0,r10
c0000000001e7a90 7d6b4830 slw r11,r11,r9
c0000000001e7a94 796b0020 clrldi r11,r11,32
c0000000001e7a98 419d00a8 bgt cr7,c0000000001e7b40 # .block_is_partially_uptodate+0xe0/0x100
c0000000001e7a9c 7fa55840 cmpld cr7,r5,r11
c0000000001e7aa0 7d004214 add r8,r0,r8
c0000000001e7aa4 79080020 clrldi r8,r8,32
c0000000001e7aa8 419c0078 blt cr7,c0000000001e7b20 # .block_is_partially_uptodate+0xc0/0x100
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: <arunabal@in.ibm.com>
Cc: <sbest@us.ibm.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
commit 27d20fddc8af539464fc3ba499d6a830054c3bd6 upstream.
Salman Qazi describes the following radix-tree bug:
In the following case, we get can get a deadlock:
0. The radix tree contains two items, one has the index 0.
1. The reader (in this case find_get_pages) takes the rcu_read_lock.
2. The reader acquires slot(s) for item(s) including the index 0 item.
3. The non-zero index item is deleted, and as a consequence the other item is
moved to the root of the tree. The place where it used to be is queued for
deletion after the readers finish.
3b. The zero item is deleted, removing it from the direct slot, it remains in
the rcu-delayed indirect node.
4. The reader looks at the index 0 slot, and finds that the page has 0 ref
count
5. The reader looks at it again, hoping that the item will either be freed or
the ref count will increase. This never happens, as the slot it is looking
at will never be updated. Also, this slot can never be reclaimed because
the reader is holding rcu_read_lock and is in an infinite loop.
The fix is to re-use the same "indirect" pointer case that requires a slot
lookup retry into a general "retry the lookup" bit.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Reported-by: Salman Qazi <sqazi@google.com>
commit 44e2aa937e698ea95dd86b2a4fabd734ef2c76db upstream.
Add missing spin_lock() of the page_table_lock before an error return in
hugetlb_cow(). Callers of hugtelb_cow() expect it to be held upon return.
commit 572438f9b52236bd8938b1647cc15e027d27ef55 upstream.
page_order() is called by memory hotplug's user interface to check the
section is removable or not. (is_mem_section_removable())
It calls page_order() withoug holding zone->lock.
So, even if the caller does
if (PageBuddy(page))
ret = page_order(page) ...
The caller may hit BUG_ON().
For fixing this, there are 2 choices.
1. add zone->lock.
2. remove BUG_ON().
is_mem_section_removable() is used for some "advice" and doesn't need to
be 100% accurate. This is_removable() can be called via user program..
We don't want to take this important lock for long by user's request. So,
this patch removes BUG_ON().
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Mel Gorman <mel@csn.ul.ie>
commit b7f50cfa3630b6e079929ffccfd442d65064ee1f upstream.
There is a bug in commit 6dda9d55 ("page allocator: reduce fragmentation
in buddy allocator by adding buddies that are merging to the tail of the
free lists") that means a buddy at order MAX_ORDER is checked for merging.
A page of this order never exists so at times, an effectively random
piece of memory is being checked.
Alan Curry has reported that this is causing memory corruption in
userspace data on a PPC32 platform (http://lkml.org/lkml/2010/10/9/32).
It is not clear why this is happening. It could be a cache coherency
problem where pages mapped in both user and kernel space are getting
different cache lines due to the bad read from kernel space
(http://lkml.org/lkml/2010/10/13/179). It could also be that there are
some special registers being io-remapped at the end of the memmap array
and that a read has special meaning on them. Compiler bugs have been
ruled out because the assembly before and after the patch looks relatively
harmless.
This patch fixes the problem by ensuring we are not reading a possibly
invalid location of memory. It's not clear why the read causes corruption
but one way or the other it is a buggy read.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Corrado Zoccolo <czoccolo@gmail.com>
Reported-by: Alan Curry <pacman@kosh.dhis.org>
commit f8f72ad5396987e05a42cf7eff826fb2a15ff148 upstream.
scan_lru_pages returns pfn. So, it's type should be "unsigned long"
not "int".
Note: I guess this has been work until now because memory hotplug tester's
machine has not very big memory....
physical address < 32bit << PAGE_SHIFT.
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 800416f799e0723635ac2d720ad4449917a1481c upstream.
When a node contains only HighMem memory, slab_node(MPOL_BIND)
dereferences a NULL pointer.
[ This code seems to go back all the way to commit 19770b32609b: "mm:
filter based on a nodemask as well as a gfp_mask". Which was back in
April 2008, and it got merged into 2.6.26. - Linus ]
Cc: Christoph Lameter <cl@linux.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
commit 3ee48b6af49cf534ca2f481ecc484b156a41451d upstream.
During the reading of /proc/vmcore the kernel is doing
ioremap()/iounmap() repeatedly. And the buildup of un-flushed
vm_area_struct's is causing a great deal of overhead. (rb_next()
is chewing up most of that time).
This solution is to provide function set_iounmap_nonlazy(). It
causes a subsequent call to iounmap() to immediately purge the
vma area (with try_purge_vmap_area_lazy()).
With this patch we have seen the time for writing a 250MB
compressed dump drop from 71 seconds to 44 seconds.
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Cc: kexec@lists.infradead.org
LKML-Reference: <E1OwHZ4-0005WK-Tw@eag09.americas.sgi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6:
HWPOISON: Stop shrinking at right page count
HWPOISON: Report correct address granuality for AO huge page errors
HWPOISON: Copy si_addr_lsb to user
page-types.c: fix name of unpoison interface
We need to check parent's thresholds if parent has use_hierarchy == 1 to
be sure that parent's threshold events will be triggered even if parent
itself is not active (no MEM_CGROUP_EVENTS).
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
During boot of a 16TB system, the following is printed:
Dentry cache hash table entries: -2147483648 (order: 22, 17179869184 bytes)
Signed-off-by: Robin Holt <holt@sgi.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
When we call the slab shrinker to free a page we need to stop at
page count one because the caller always holds a single reference, not zero.
This avoids useless looping over slab shrinkers and freeing too much
memory.
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
The SIGBUS user space signalling is supposed to report the
address granuality of a corruption. Pass this information correctly
for huge pages by querying the hpage order.
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Building under memory pressure, with KSM on 2.6.36-rc5, collapsed with
an internal compiler error: typically indicating an error in swapping.
Perhaps there's a timing issue which makes it now more likely, perhaps
it's just a long time since I tried for so long: this bug goes back to
KSM swapping in 2.6.33.
Notice how reuse_swap_page() allows an exclusive page to be reused, but
only does SetPageDirty if it can delete it from swap cache right then -
if it's currently under Writeback, it has to be left in cache and we
don't SetPageDirty, but the page can be reused. Fine, the dirty bit
will get set in the pte; but notice how zap_pte_range() does not bother
to transfer pte_dirty to page_dirty when unmapping a PageAnon.
If KSM chooses to share such a page, it will look like a clean copy of
swapcache, and not be written out to swap when its memory is needed;
then stale data read back from swap when it's needed again.
We could fix this in reuse_swap_page() (or even refuse to reuse a
page under writeback), but it's more honest to fix my oversight in
KSM's write_protect_page(). Several days of testing on three machines
confirms that this fixes the issue they showed.
Cc: stable@kernel.org
2.6.36-rc1 commit 21d0d443cdc1658a8c1484fdcece4803f0f96d0e "rmap:
resurrect page_address_in_vma anon_vma check" was right to resurrect
that check; but now that it's comparing anon_vma->roots instead of
just anon_vmas, there's a danger of oopsing on a NULL anon_vma.
In most cases no NULL anon_vma ever gets here; but it turns out that
occasionally KSM, when enabled on a forked or forking process, will
itself call page_address_in_vma() on a "half-KSM" page left over from
an earlier failed attempt to merge - whose page_anon_vma() is NULL.
It's my bug that those should be getting here at all: I thought they
were already dealt with, this oops proves me wrong, I'll fix it in
the next release - such pages are effectively pinned until their
process exits, since rmap cannot find their ptes (though swapoff can).
For now just work around it by making page_address_in_vma() safe (and
add a comment on why that check is wanted anyway). A similar check
in __page_check_anon_rmap() is safe because do_page_add_anon_rmap()
already excluded KSM pages.
Thomas Pollet noticed that the remap_file_pages() system call in
fremap.c has a potential overflow in the first part of the if statement
below, which could cause it to process bogus input parameters.
Specifically the pgoff + size parameters could be wrap thereby
preventing the system call from failing when it should.
Reported-by: Thomas Pollet <thomas.pollet@gmail.com>
Signed-off-by: Larry Woodman <lwoodman@redhat.com>
Thomas Pollet points out that the 'end' variable is broken. It was
computed based on start/size before they were page-aligned, and as such
doesn't actually match any of the other actions we take. The overflow
test on end was also redundant, since we had already tested it with the
properly aligned version.
So just get rid of it entirely. The one remaining use for that broken
variable can just use 'start+size' like all the other cases already did.
Confirming page lock is held in hugetlb_add_anon_rmap() may be useful
to detect possible future problems.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
The "if (!trylock_page)" block in the avoidcopy path of hugetlb_cow()
looks confusing and is buggy. Originally this trylock_page() was
intended to make sure that old_page is locked even when old_page !=
pagecache_page, because then only pagecache_page is locked.
This patch fixes it by moving page locking into hugetlb_fault().
Obviously, setting anon_vma for COWed hugepage should be done
by hugepage_add_new_anon_rmap() to scan vmas faster.
This patch fixes it.
This patch applies Andrea's fix given by the following patch into hugepage
rmapping code:
commit 288468c334e98aacbb7e2fb8bde6bc1adcd55e05
Author: Andrea Arcangeli <aarcange@redhat.com>
Date: Mon Aug 9 17:19:09 2010 -0700
This patch uses anon_vma->root and avoids unnecessary overwriting when
anon_vma is already set up.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: fix pcpu_last_unit_cpu
If __split_vma fails because of an out of memory condition the
anon_vma_chain isn't teardown and freed potentially leading to rmap walks
accessing freed vma information plus there's a memleak.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Johannes Weiner <jweiner@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: <stable@kernel.org>
/proc/sys/vm/oom_dump_tasks is enabled by default, so it's necessary to
limit as much information as possible that it should emit.
The tasklist dump should be filtered to only those tasks that are eligible
for oom kill. This is already done for memcg ooms, but this patch extends
it to both cpuset and mempolicy ooms as well as init.
In addition to suppressing irrelevant information, this also reduces
confusion since users currently don't know which tasks in the tasklist
aren't eligible for kill (such as those attached to cpusets or bound to
mempolicies with a disjoint set of mems or nodes, respectively) since that
information is not shown.
Signed-off-by: David Rientjes <rientjes@google.com>
M. Vefa Bicakci reported 2.6.35 kernel hang up when hibernation on his
32bit 3GB mem machine.
(https://bugzilla.kernel.org/show_bug.cgi?id=16771). Also he bisected
the regression to
commit bb21c7ce18eff8e6e7877ca1d06c6db719376e3c
Author: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Date: Fri Jun 4 14:15:05 2010 -0700
vmscan: fix do_try_to_free_pages() return value when priority==0 reclaim failure
At first impression, this seemed very strange because the above commit
only chenged function return value and hibernate_preallocate_memory()
ignore return value of shrink_all_memory(). But it's related.
Now, page allocation from hibernation code may enter infinite loop if the
system has highmem. The reasons are that vmscan don't care enough OOM
case when oom_killer_disabled.
The problem sequence is following as.
1. hibernation
2. oom_disable
3. alloc_pages
4. do_try_to_free_pages
if (scanning_global_lru(sc) && !all_unreclaimable)
return 1;
If kswapd is not freozen, it would set zone->all_unreclaimable to 1 and
then shrink_zones maybe return true(ie, all_unreclaimable is true). So at
last, alloc_pages could go to _nopage_. If it is, it should have no
problem.
This patch adds all_unreclaimable check to protect in direct reclaim path,
too. It can care of hibernation OOM case and help bailout
all_unreclaimable case slightly.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reported-by: M. Vefa Bicakci <bicave@superonline.com>
Reported-by: <caiqian@redhat.com>
Tested-by: <caiqian@redhat.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Balbir Singh <balbir@in.ibm.com>
A task's badness score is roughly a proportion of its rss and swap
compared to the system's capacity. The scale ranges from 0 to 1000 with
the highest score chosen for kill. Thus, this scale operates on a
resolution of 0.1% of RAM + swap. Admin tasks are also given a 3% bonus,
so the badness score of an admin task using 3% of memory, for example,
would still be 0.
It's possible that an exceptionally large number of tasks will combine to
exhaust all resources but never have a single task that uses more than
0.1% of RAM and swap (or 3.0% for admin tasks).
This patch ensures that the badness score of any eligible task is never 0
so the machine doesn't unnecessarily panic because it cannot find a task
to kill.
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
bdi: Fix warnings in __mark_inode_dirty for /dev/zero and friends
char: Mark /dev/zero and /dev/kmem as not capable of writeback
bdi: Initialize noop_backing_dev_info properly
cfq-iosched: fix a kernel OOPs when usb key is inserted
block: fix blk_rq_map_kern bio direction flag
cciss: freeing uninitialized data on error path
Properly initialize this backing dev info so that writeback code does not
barf when getting to it e.g. via sb->s_bdi.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
pcpu_first/last_unit_cpu are used to track which cpu has the first and
last units assigned. This in turn is used to determine the span of a
chunk for man/unmap cache flushes and whether an address belongs to
the first chunk or not in per_cpu_ptr_to_phys().
When the number of possible CPUs isn't power of two, a chunk may
contain unassigned units towards the end of a chunk. The logic to
determine pcpu_last_unit_cpu was incorrect when there was an unused
unit at the end of a chunk. It failed to ignore the unused unit and
assigned the unused marker NR_CPUS to pcpu_last_unit_cpu.
This was discovered through kdump failure which was caused by
malfunctioning per_cpu_ptr_to_phys() on a kvm setup with 50 possible
CPUs by CAI Qian.
Reported-by: CAI Qian <caiqian@redhat.com>
Commit 4969c1192d15 ("mm: fix swapin race condition") is now agreed to
be incomplete. There's a race, not very much less likely than the
original race envisaged, in which it is further necessary to check that
the swapcache page's swap has not changed.
Here's the reasoning: cast in terms of reuse_swap_page(), but probably
could be reformulated to rely on try_to_free_swap() instead, or on
swapoff+swapon.
A, faults into do_swap_page(): does page1 = lookup_swap_cache(swap1) and
comes through the lock_page(page1).
B, a racing thread of the same process, faults on the same address: does
page1 = lookup_swap_cache(swap1) and now waits in lock_page(page1), but
for whatever reason is unlucky not to get the lock any time soon.
A carries on through do_swap_page(), a write fault, but cannot reuse the
swap page1 (another reference to swap1). Unlocks the page1 (but B
doesn't get it yet), does COW in do_wp_page(), page2 now in that pte.
C, perhaps the parent of A+B, comes in and write faults the same swap
page1 into its mm, reuse_swap_page() succeeds this time, swap1 is freed.
kswapd comes in after some time (B still unlucky) and swaps out some
pages from A+B and C: it allocates the original swap1 to page2 in A+B,
and some other swap2 to the original page1 now in C. But does not
immediately free page1 (actually it couldn't: B holds a reference),
leaving it in swap cache for now.
B at last gets the lock on page1, hooray! Is PageSwapCache(page1)? Yes.
Is pte_same(*page_table, orig_pte)? Yes, because page2 has now been
given the swap1 which page1 used to have. So B proceeds to insert page1
into A+B's page_table, though its content now belongs to C, quite
different from what A wrote there.
B ought to have checked that page1's swap was still swap1.
block: Range check cpu in blk_cpu_to_group
scatterlist: prevent invalid free when alloc fails
writeback: Fix lost wake-up shutting down writeback thread
writeback: do not lose wakeup events when forking bdi threads
cciss: fix reporting of max queue depth since init
block: switch s390 tape_block and mg_disk to elevator_change()
block: add function call to switch the IO scheduler from a driver
fs/bio-integrity.c: return -ENOMEM on kmalloc failure
bio-integrity.c: remove dependency on __GFP_NOFAIL
BLOCK: fix bio.bi_rw handling
block: put dev->kobj in blk_register_queue fail path
cciss: handle allocation failure
cfq-iosched: Documentation help for new tunables
cfq-iosched: blktrace print per slice sector stats
cfq-iosched: Implement tunable group_idle
cfq-iosched: Do group share accounting in IOPS when slice_idle=0
cfq-iosched: Do not idle if slice_idle=0
cciss: disable doorbell reset on reset_devices
blkio: Fix return code for mkdir calls
When under significant memory pressure, a process enters direct reclaim
and immediately afterwards tries to allocate a page. If it fails and no
further progress is made, it's possible the system will go OOM. However,
on systems with large amounts of memory, it's possible that a significant
number of pages are on per-cpu lists and inaccessible to the calling
process. This leads to a process entering direct reclaim more often than
it should increasing the pressure on the system and compounding the
problem.
This patch notes that if direct reclaim is making progress but allocations
are still failing that the system is already under heavy pressure. In
this case, it drains the per-cpu lists and tries the allocation a second
time before continuing.
Reviewed-by: Christoph Lameter <cl@linux.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
is low and kswapd is awake
Ordinarily watermark checks are based on the vmstat NR_FREE_PAGES as it is
cheaper than scanning a number of lists. To avoid synchronization
overhead, counter deltas are maintained on a per-cpu basis and drained
both periodically and when the delta is above a threshold. On large CPU
systems, the difference between the estimated and real value of
NR_FREE_PAGES can be very high. If NR_FREE_PAGES is much higher than
number of real free page in buddy, the VM can allocate pages below min
watermark, at worst reducing the real number of pages to zero. Even if
the OOM killer kills some victim for freeing memory, it may not free
memory if the exit path requires a new page resulting in livelock.
This patch introduces a zone_page_state_snapshot() function (courtesy of
Christoph) that takes a slightly more accurate view of an arbitrary vmstat
counter. It is used to read NR_FREE_PAGES while kswapd is awake to avoid
the watermark being accidentally broken. The estimate is not perfect and
may result in cache line bounces but is expected to be lighter than the
IPI calls necessary to continually drain the per-cpu counters while kswapd
is awake.
Signed-off-by: Christoph Lameter <cl@linux.com>
free list
When allocating a page, the system uses NR_FREE_PAGES counters to
determine if watermarks would remain intact after the allocation was made.
This check is made without interrupts disabled or the zone lock held and
so is race-prone by nature. Unfortunately, when pages are being freed in
batch, the counters are updated before the pages are added on the list.
During this window, the counters are misleading as the pages do not exist
yet. When under significant pressure on systems with large numbers of
CPUs, it's possible for processes to make progress even though they should
have been stalled. This is particularly problematic if a number of the
processes are using GFP_ATOMIC as the min watermark can be accidentally
breached and in extreme cases, the system can livelock.
This patch updates the counters after the pages have been added to the
list. This makes the allocator more cautious with respect to preserving
the watermarks and mitigates livelock possibilities.
[akpm@linux-foundation.org: avoid modifying incoming args]
refresh_zone_stat_thresholds() calculates parameter based on the number of
online cpus. It's called at cpu offlining but needs to be called at
onlining, too.
Tests with recent firmware on Intel X25-M 80GB and OCZ Vertex 60GB SSDs
show a shift since I last tested in December: in part because of firmware
updates, in part because of the necessary move from barriers to awaiting
completion at the block layer. While discard at swapon still shows as
slightly beneficial on both, discarding 1MB swap cluster when allocating
is now disadvanteous: adds 25% overhead on Intel, adds 230% on OCZ (YMMV).
Surrender: discard as presently implemented is more hindrance than help
for swap; but might prove useful on other devices, or with improvements.
So continue to do the discard at swapon, but make discard while swapping
conditional on a SWAP_FLAG_DISCARD to sys_swapon() (which has been using
only the lower 16 bits of int flags).
We can add a --discard or -d to swapon(8), and a "discard" to swap in
/etc/fstab: matching the mount option for btrfs, ext4, fat, gfs2, nilfs2.
Cc: Nigel Cunningham <nigel@tuxonice.net>
Cc: Tejun Heo <tj@kernel.org>
Cc: Jens Axboe <jaxboe@fusionio.com>
Cc: James Bottomley <James.Bottomley@hansenpartnership.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
The swap code already uses synchronous discards, no need to add I/O
barriers.
This fixes the worst of the terrible slowdown in swap allocation for
hibernation, reported on 2.6.35 by Nigel Cunningham; but does not entirely
eliminate that regression.
[tj@kernel.org: superflous newlines removed]
Tested-by: Nigel Cunningham <nigel@tuxonice.net>
Move the hibernation check from scan_swap_map() into try_to_free_swap():
to catch not only the common case when hibernation's allocation itself
triggers swap reuse, but also the less likely case when concurrent page
reclaim (shrink_page_list) might happen to try_to_free_swap from a page.
Hibernation already clears __GFP_IO from the gfp_allowed_mask, to stop
reclaim from going to swap: check that to prevent swap reuse too.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Ondrej Zary <linux@rainbow-software.org>
Cc: Andrea Gelmini <andrea.gelmini@gmail.com>
Please revert 2.6.36-rc commit d2997b1042ec150616c1963b5e5e919ffd0b0ebf
"hibernation: freeze swap at hibernation". It complicated matters by
adding a second swap allocation path, just for hibernation; without in any
way fixing the issue that it was intended to address - page reclaim after
fixing the hibernation image might free swap from a page already imaged as
swapcache, letting its swap be reallocated to store a different page of
the image: resulting in data corruption if the imaged page were freed as
clean then swapped back in. Pages freed to si->swap_map were still in
danger of being reallocated by the alternative allocation path.
I guess it inadvertently fixed slow SSD swap allocation for hibernation,
as reported by Nigel Cunningham: by missing out the discards that occur on
the usual swap allocation path; but that was unintentional, and needs a
separate fix.
I have been seeing problems on Tegra 2 (ARMv7 SMP) systems with HIGHMEM
enabled on 2.6.35 (plus some patches targetted at 2.6.36 to perform cache
maintenance lazily), and the root cause appears to be that the mm bouncing
code is calling flush_dcache_page before it copies the bounce buffer into
the bio.
The bounced page needs to be flushed after data is copied into it, to
ensure that architecture implementations can synchronize instruction and
data caches if necessary.
Signed-off-by: Gary King <gking@nvidia.com>
Acked-by: Jens Axboe <axboe@kernel.dk>
next_active_pageblock() is for finding next _used_ freeblock. It skips
several blocks when it finds there are a chunk of free pages lager than
pageblock. But it has 2 bugs.
1. We have no lock. page_order(page) - pageblock_order can be minus.
2. pageblocks_stride += is wrong. it should skip page_order(p) of pages.
Iram reported that compaction's too_many_isolated() loops forever.
(http://www.spinics.net/lists/linux-mm/msg08123.html)
The meminfo when the situation happened was inactive anon is zero. That's
because the system has no memory pressure until then. While all anon
pages were in the active lru, compaction could select active lru as well
as inactive lru. That's a different thing from vmscan's isolated. So we
has been two too_many_isolated.
While compaction can isolate pages in both active and inactive, current
implementation of too_many_isolated only considers inactive. It made
Iram's problem.
This patch handles active and inactive fairly. That's because we can't
expect where from and how many compaction would isolated pages.
This patch changes (nr_isolated > nr_inactive) with
nr_isolated > (nr_active + nr_inactive) / 2.
Reported-by: Iram Shahzad <iram.shahzad@jp.fujitsu.com>
COMPACTION enables MIGRATION, but MIGRATION spawns a warning if numa or
memhotplug aren't selected. However MIGRATION doesn't depend on them. I
guess it's just trying to be strict doing a double check on who's enabling
it, but it doesn't know that compaction also enables MIGRATION.
The pte_same check is reliable only if the swap entry remains pinned (by
the page lock on swapcache). We've also to ensure the swapcache isn't
removed before we take the lock as try_to_free_swap won't care about the
page pin.
One of the possible impacts of this patch is that a KSM-shared page can
point to the anon_vma of another process, which could exit before the page
is freed.
This can leave a page with a pointer to a recycled anon_vma object, or
worse, a pointer to something that is no longer an anon_vma.
[riel@redhat.com: changelog help]
So it can be used by all that need to check for that.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
