The zonelist patches caused the loop that checks for available
objects in permitted zones to not terminate immediately. One object
per zone per allocation may be allocated and then abandoned.
Break the loop when we have successfully allocated one object.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
This patch changes the function reserve_bootmem_node() from void to int,
returning -ENOMEM if the allocation fails.
This fixes a build problem on x86 with CONFIG_KEXEC=y and
CONFIG_NEED_MULTIPLE_NODES=y
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Reported-by: Adrian Bunk <bunk@kernel.org>
KAMEZAWA Hiroyuki and Oleg Nesterov point out that since the commit
557ed1fa2620dc119adb86b34c614e152a629a80 ("remove ZERO_PAGE") removed
the ZERO_PAGE from the VM mappings, any users of get_user_pages() will
generally now populate the VM with real empty pages needlessly.
We used to get the ZERO_PAGE when we did the "handle_mm_fault()", but
since fault handling no longer uses ZERO_PAGE for new anonymous pages,
we now need to handle that special case in follow_page() instead.
In particular, the removal of ZERO_PAGE effectively removed the core
file writing optimization where we would skip writing pages that had not
been populated at all, and increased memory pressure a lot by allocating
all those useless newly zeroed pages.
This reinstates the optimization by making the unmapped PTE case the
same as for a non-existent page table, which already did this correctly.
While at it, this also fixes the XIP case for follow_page(), where the
caller could not differentiate between the case of a page that simply
could not be used (because it had no "struct page" associated with it)
and a page that just wasn't mapped.
We do that by simply returning an error pointer for pages that could not
be turned into a "struct page *". The error is arbitrarily picked to be
EFAULT, since that was what get_user_pages() already used for the
equivalent IO-mapped page case.
[ Also removed an impossible test for pte_offset_map_lock() failing:
that's not how that function works ]
Acked-by: Oleg Nesterov <oleg@tv-sign.ru>
Acked-by: Nick Piggin <npiggin@suse.de>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Roland McGrath <roland@redhat.com>
We need this at least for huge page detection for now, because powerpc
needs the vm_area_struct to be able to determine whether a virtual address
is referring to a huge page (its pmd_huge() doesn't work).
It might also come in handy for some of the other users.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Acked-by: Matt Mackall <mpm@selenic.com>
"Smarter retry of costly-order allocations" patch series change behaver of
do_try_to_free_pages(). But unfortunately ret variable type was
unchanged.
Thus an overflow is possible.
Acked-by: Nishanth Aravamudan <nacc@us.ibm.com>
This implements a few changes on top of the recent kobjsize() refactoring
introduced by commit 6cfd53fc03670c7a544a56d441eb1a6cc800d72b.
As Christoph points out:
virt_to_head_page cannot return NULL. virt_to_page also
does not return NULL. pfn_valid() needs to be used to
figure out if a page is valid. Otherwise the page struct
reference that was returned may have PageReserved() set
to indicate that it is not a valid page.
As discussed further in the thread, virt_addr_valid() is the preferable
way to validate the object pointer in this case. In addition to fixing
up the reserved page case, it also has the benefit of encapsulating the
hack introduced by commit 4016a1390d07f15b267eecb20e76a48fd5c524ef on
the impacted platforms, allowing us to get rid of the extra checking in
kobjsize() for the platforms that don't perform this type of bizarre
memory_end abuse (every nommu platform that isn't blackfin). If blackfin
decides to get in line with every other platform and use PageReserved
for the DMA pages in question, kobjsize() will also continue to work
fine.
It also turns out that compound_order() will give us back 0-order for
non-head pages, so we can get rid of the PageCompound check and just
use compound_order() directly. Clean that up while we're at it.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Reviewed-by: Christoph Lameter <clameter@sgi.com>
Minor source code cleanup of page flags in mm/page_alloc.c.
Move the definition of the groups of bits to page-flags.h.
The purpose of this clean up is that the next patch will
conditionally add a page flag to the groups. Doing that
in a header file is cleaner than adding #ifdefs to the
C code.
Signed-off-by: Russ Anderson <rja@sgi.com>
kobjsize() has been abusing page->index as a method for sorting out
compound order, which blows up both for page cache pages, and SLOB's
reuse of the index in struct slob_page.
Presently we are not able to accurately size arbitrary pointers that
don't come from kmalloc(), so the best we can do is sort out the
compound order from the head page if it's a compound page, or default
to 0-order if it's impossible to ksize() the object.
Obviously this leaves quite a bit to be desired in terms of object
sizing accuracy, but the behaviour is unchanged over the existing
implementation, while fixing the page->index oopses originally reported
here:
http://marc.info/?l=linux-mm&m=121127773325245&w=2
Accuracy could also be improved by having SLUB and SLOB both set PG_slab
on ksizeable pages, rather than just handling the __GFP_COMP cases
irregardless of the PG_slab setting, as made possibly with Pekka's
patches:
http://marc.info/?l=linux-kernel&m=121139439900534&w=2
http://marc.info/?l=linux-kernel&m=121139440000537&w=2
http://marc.info/?l=linux-kernel&m=121139440000540&w=2
This is primarily a bugfix for nommu systems for 2.6.26, with the aim
being to gradually kill off kobjsize() and its particular brand of
object abuse entirely.
Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi>
Fix a regression introduced by
commit 4cc6028d4040f95cdb590a87db478b42b8be0508
Author: Jiri Kosina <jkosina@suse.cz>
Date: Wed Feb 6 22:39:44 2008 +0100
brk: check the lower bound properly
The check in sys_brk() on minimum value the brk might have must take
CONFIG_COMPAT_BRK setting into account. When this option is turned on
(i.e. we support ancient legacy binaries, e.g. libc5-linked stuff), the
lower bound on brk value is mm->end_code, otherwise the brk start is
allowed to be arbitrarily shifted.
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: <stable@kernel.org>
[ INFO: possible recursive locking detected ]
2.6.26-rc4 #30
heap-overflow/2250 is trying to acquire lock:
(&mm->page_table_lock){--..}, at: [<c0000000000cf2e8>] .copy_hugetlb_page_range+0x108/0x280
but task is already holding lock:
(&mm->page_table_lock){--..}, at: [<c0000000000cf2dc>] .copy_hugetlb_page_range+0xfc/0x280
3 locks held by heap-overflow/2250:
#0: (&mm->mmap_sem){----}, at: [<c000000000050e44>] .dup_mm+0x134/0x410
#1: (&mm->mmap_sem/1){--..}, at: [<c000000000050e54>] .dup_mm+0x144/0x410
#2: (&mm->page_table_lock){--..}, at: [<c0000000000cf2dc>] .copy_hugetlb_page_range+0xfc/0x280
stack backtrace:
Call Trace:
[c00000003b2774e0] [c000000000010ce4] .show_stack+0x74/0x1f0 (unreliable)
[c00000003b2775a0] [c0000000003f10e0] .dump_stack+0x20/0x34
[c00000003b277620] [c0000000000889bc] .__lock_acquire+0xaac/0x1080
[c00000003b277740] [c000000000089000] .lock_acquire+0x70/0xb0
[c00000003b2777d0] [c0000000003ee15c] ._spin_lock+0x4c/0x80
[c00000003b277870] [c0000000000cf2e8] .copy_hugetlb_page_range+0x108/0x280
[c00000003b277950] [c0000000000bcaa8] .copy_page_range+0x558/0x790
[c00000003b277ac0] [c000000000050fe0] .dup_mm+0x2d0/0x410
[c00000003b277ba0] [c000000000051d24] .copy_process+0xb94/0x1020
[c00000003b277ca0] [c000000000052244] .do_fork+0x94/0x310
[c00000003b277db0] [c000000000011240] .sys_clone+0x60/0x80
[c00000003b277e30] [c0000000000078c4] .ppc_clone+0x8/0xc
Fix is the same way that mm/memory.c copy_page_range does the
lockdep annotation.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: Adam Litke <agl@us.ibm.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
slub: ksize() abuse checks
slob: Fix to return wrong pointer
Trying to add memory via add_memory() from within an initcall function
results in
bootmem alloc of 163840 bytes failed!
Kernel panic - not syncing: Out of memory
This is caused by zone_wait_table_init() which uses system_state to decide
if it should use the bootmem allocator or not.
When initcalls are handled the system_state is still SYSTEM_BOOTING but
the bootmem allocator doesn't work anymore. So the allocation will fail.
To fix this use slab_is_available() instead as indicator like we do it
everywhere else.
[akpm@linux-foundation.org: coding-style fix]
Reviewed-by: Andy Whitcroft <apw@shadowen.org>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com>
When booting 2.6.26-rc3 on a multi-node x86_32 numa system we are seeing
panics when trying node local allocations:
BUG: unable to handle kernel NULL pointer dereference at 0000034c
IP: [<c1042507>] get_page_from_freelist+0x4a/0x18e
*pdpt = 00000000013a7001 *pde = 0000000000000000
Oops: 0000 [#1] SMP
Modules linked in:
Pid: 0, comm: swapper Not tainted (2.6.26-rc3-00003-g5abc28d #82)
EIP: 0060:[<c1042507>] EFLAGS: 00010282 CPU: 0
EIP is at get_page_from_freelist+0x4a/0x18e
EAX: c1371ed8 EBX: 00000000 ECX: 00000000 EDX: 00000000
ESI: f7801180 EDI: 00000000 EBP: 00000000 ESP: c1371ec0
DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
Process swapper (pid: 0, ti=c1370000 task=c12f5b40 task.ti=c1370000)
Stack: 00000000 00000000 00000000 00000000 000612d0 000412d0 00000000 000412d0
f7801180 f7c0101c f7c01018 c10426e4 f7c01018 00000001 00000044 00000000
00000001 c12f5b40 00000001 00000010 00000000 000412d0 00000286 000412d0
Call Trace:
[<c10426e4>] __alloc_pages_internal+0x99/0x378
[<c10429ca>] __alloc_pages+0x7/0x9
[<c105e0e8>] kmem_getpages+0x66/0xef
[<c105ec55>] cache_grow+0x8f/0x123
[<c105f117>] ____cache_alloc_node+0xb9/0xe4
[<c105f427>] kmem_cache_alloc_node+0x92/0xd2
[<c122118c>] setup_cpu_cache+0xaf/0x177
[<c105e6ca>] kmem_cache_create+0x2c8/0x353
[<c13853af>] kmem_cache_init+0x1ce/0x3ad
[<c13755c5>] start_kernel+0x178/0x1ee
This occurs when we are scanning the zonelists looking for a ZONE_NORMAL
page. In this system there is only ZONE_DMA and ZONE_NORMAL memory on
node 0, all other nodes are mapped above 4GB physical. Here is a dump
of the zonelists from this system:
zonelists pgdat=c1400000
0: c14006c0:2 f7c006c0:2 f7e006c0:2 c1400360:1 c1400000:0
1: c14006c0:2 c1400360:1 c1400000:0
zonelists pgdat=f7c00000
0: f7c006c0:2 f7e006c0:2 c14006c0:2 c1400360:1 c1400000:0
1: f7c006c0:2
zonelists pgdat=f7e00000
0: f7e006c0:2 c14006c0:2 f7c006c0:2 c1400360:1 c1400000:0
1: f7e006c0:2
When performing a node local allocation we call get_page_from_freelist()
looking for a page. It in turn calls first_zones_zonelist() which returns
a preferred_zone. Where there are no applicable zones this will be NULL.
However we use this unconditionally, leading to this panic.
Where there are no applicable zones there is no possibility of a successful
allocation, so simply fail the allocation.
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Acked-by: Mel Gorman <mel@csn.ul.ie>
The atomic_t type is 32bit but a 64bit system can have more than 2^32
pages of virtual address space available. Without this we overflow on
ludicrously large mappings
Signed-off-by: Alan Cox <alan@redhat.com>
In a zone's present pages number, account for all pages occupied by the
memory map, including a partial.
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
Take out an assertion to allow ->fault handlers to service PFNMAP regions.
This is required to reimplement .nopfn handlers with .fault handlers and
subsequently remove nopfn.
Acked-by: Jes Sorensen <jes@sgi.com>
Currently there is no protection from the root user to use up all of
memory for trace buffers. If the root user allocates too many entries,
the OOM killer might start kill off all tasks.
This patch adds an algorith to check the following condition:
pages_requested > (freeable_memory + current_trace_buffer_pages) / 4
If the above is met then the allocation fails. The above prevents more
than 1/4th of freeable memory from being used by trace buffers.
To determine the freeable_memory, I made determine_dirtyable_memory in
mm/page-writeback.c global.
Special thanks goes to Peter Zijlstra for suggesting the above calculation.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Add a WARN_ON for pages that don't have PageSlab nor PageCompound set to catch
the worst abusers of ksize() in the kernel.
Acked-by: Christoph Lameter <clameter@sgi.com>
Cc: Matt Mackall <mpm@selenic.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
There is a race from when a device is created with device_create() and
then the drvdata is set with a call to dev_set_drvdata() in which a
sysfs file could be open, yet the drvdata will be NULL, causing all
sorts of bad things to happen.
This patch fixes the problem by using the new function,
device_create_vargs().
Many thanks to Arthur Jones <ajones@riverbed.com> for reporting the bug,
and testing patches out.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Arthur Jones <ajones@riverbed.com>
Cc: Miklos Szeredi <mszeredi@suse.cz>
Although slob_alloc return NULL, __kmalloc_node returns NULL + align.
Because align always can be changed, it is very hard for debugging
problem of no page if it don't return NULL.
We have to return NULL in case of no page.
[penberg@cs.helsinki.fi: fix formatting as suggested by Matt.]
Signed-off-by: MinChan Kim <minchan.kim@gmail.com>
Trying to online a new memory section that was added via memory hotplug
sometimes results in crashes when the new pages are added via __free_page.
Reason for that is that the pageblock bitmap isn't initialized and hence
contains random stuff. That means that get_pageblock_migratetype()
returns also random stuff and therefore
list_add(&page->lru,
&zone->free_area[order].free_list[migratetype]);
in __free_one_page() tries to do a list_add to something that isn't even
necessarily a list.
This happens since 86051ca5eaf5e560113ec7673462804c54284456 ("mm: fix
usemap initialization") which makes sure that the pageblock bitmap gets
only initialized for pages present in a zone. Unfortunately for hot-added
memory the zones "grow" after the memmap and the pageblock memmap have
been initialized. Which means that the new pages have an unitialized
bitmap. To solve this the calls to grow_zone_span() and grow_pgdat_span()
are moved to __add_zone() just before the initialization happens.
The patch also moves the two functions since __add_zone() is the only
caller and I didn't want to add a forward declaration.
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
There is a defect in mprotect, which lets the user change the page cache
type bits by-passing the kernel reserve_memtype and free_memtype
wrappers. Fix the problem by not letting mprotect change the PAT bits.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Add a check to online_pages() to test for failure of
walk_memory_resource(). This fixes a condition where a failure
of walk_memory_resource() can lead to online_pages() returning
success without the requested pages being onlined.
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Cc: Keith Mannthey <kmannth@us.ibm.com>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Paul Jackson <pj@sgi.com>
__add_zone calls memmap_init_zone twice if memory gets attached to an empty
zone. Once via init_currently_empty_zone and once explictly right after that
call.
Looks like this is currently not a bug, however the call is superfluous and
might lead to subtle bugs if memmap_init_zone gets changed. So make sure it
is called only once.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
filemap_fault will go into an infinite loop if ->readpage() fails
asynchronously.
AFAICS the bug was introduced by this commit, which removed the wait after the
final readpage:
commit d00806b183152af6d24f46f0c33f14162ca1262a
Author: Nick Piggin <npiggin@suse.de>
Date: Thu Jul 19 01:46:57 2007 -0700
mm: fix fault vs invalidate race for linear mappings
Fix by reintroducing the wait_on_page_locked() after ->readpage() to make sure
the page is up-to-date before jumping back to the beginning of the function.
I've noticed this while testing nfs exporting on fuse. The patch
fixes it.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: Nick Piggin <npiggin@suse.de>
There is a possible data race in the page table walking code. After the split
ptlock patches, it actually seems to have been introduced to the core code, but
even before that I think it would have impacted some architectures (powerpc
and sparc64, at least, walk the page tables without taking locks eg. see
find_linux_pte()).
The race is as follows:
The pte page is allocated, zeroed, and its struct page gets its spinlock
initialized. The mm-wide ptl is then taken, and then the pte page is inserted
into the pagetables.
At this point, the spinlock is not guaranteed to have ordered the previous
stores to initialize the pte page with the subsequent store to put it in the
page tables. So another Linux page table walker might be walking down (without
any locks, because we have split-leaf-ptls), and find that new pte we've
inserted. It might try to take the spinlock before the store from the other
CPU initializes it. And subsequently it might read a pte_t out before stores
from the other CPU have cleared the memory.
There are also similar races in higher levels of the page tables. They
obviously don't involve the spinlock, but could see uninitialized memory.
Arch code and hardware pagetable walkers that walk the pagetables without
locks could see similar uninitialized memory problems, regardless of whether
split ptes are enabled or not.
I prefer to put the barriers in core code, because that's where the higher
level logic happens, but the page table accessors are per-arch, and open-coding
them everywhere I don't think is an option. I'll put the read-side barriers
in alpha arch code for now (other architectures perform data-dependent loads
in order).
Signed-off-by: Denis Cheng <crquan@gmail.com>
When accessing cpu_online_map, we should prevent dynamic changing
of cpu_online_map by get_online_cpus().
Unfortunately, all_vm_events() doesn't do that.
Cc: Gautham R Shenoy <ego@in.ibm.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
Revert "relay: fix splice problem"
docbook: fix bio missing parameter
block: use unitialized_var() in bio_alloc_bioset()
block: avoid duplicate calls to get_part() in disk stat code
cfq-iosched: make io priorities inherit CPU scheduling class as well as nice
block: optimize generic_unplug_device()
block: get rid of likely/unlikely predictions in merge logic
vfs: splice remove_suid() cleanup
cfq-iosched: fix RCU race in the cfq io_context destructor handling
block: adjust tagging function queue bit locking
block: sysfs store function needs to grab queue_lock and use queue_flag_*()
any_slab_objects() does an atomic_read on an atomic_long_t, this
fixes it to use atomic_long_read instead.
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
generic_file_splice_write() duplicates remove_suid() just because it
doesn't hold i_mutex. But it grabs i_mutex inside splice_from_pipe()
anyway, so this is rather pointless.
Move locking to generic_file_splice_write() and call remove_suid() and
__splice_from_pipe() instead.
Fix warning from pmd_bad() at bootup on a HIGHMEM64G HIGHPTE x86_32.
That came from 9fc34113f6880b215cbea4e7017fc818700384c2 x86: debug pmd_bad();
but we understand now that the typecasting was wrong for PAE in the previous
version: pagetable pages above 4GB looked bad and stopped Arjan from booting.
And revert that cded932b75ab0a5f9181ee3da34a0a488d1a14fd x86: fix pmd_bad
and pud_bad to support huge pages. It was the wrong way round: we shouldn't
weaken every pmd_bad and pud_bad check to let huge pages slip through - in
part they check that we _don't_ have a huge page where it's not expected.
Put the x86 pmd_bad() and pud_bad() definitions back to what they have long
been: they can be improved (x86_32 should use PTE_MASK, to stop PAE thinking
junk in the upper word is good; and x86_64 should follow x86_32's stricter
comparison, to stop thinking any subset of required bits is good); but that
should be a later patch.
Fix Hans' good observation that follow_page() will never find pmd_huge()
because that would have already failed the pmd_bad test: test pmd_huge in
between the pmd_none and pmd_bad tests. Tighten x86's pmd_huge() check?
No, once it's a hugepage entry, it can get quite far from a good pmd: for
example, PROT_NONE leaves it with only ACCESSED of the KERN_PGTABLE bits.
However... though follow_page() contains this and another test for huge
pages, so it's nice to keep it working on them, where does it actually get
called on a huge page? get_user_pages() checks is_vm_hugetlb_page(vma) to
to call alternative hugetlb processing, as does unmap_vmas() and others.
Earlier-version-tested-by: Ingo Molnar <mingo@elte.hu>
Cc: Jeff Chua <jeff.chua.linux@gmail.com>
Cc: Hans Rosenfeld <hans.rosenfeld@amd.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
If we make SLUB_DEBUG depend on SYSFS then we can simplify some
#ifdefs and avoid others.
Fix some issues with wrapping and use strict_strtoul to make parameter
passing from sysfs safer.
Implement trivial statistics for the memory resource controller.
Signed-off-by: Balaji Rao <balajirrao@gmail.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Fix vmalloc kernel-doc warning:
Warning(linux-2.6.25-git14//mm/vmalloc.c:555): No description found for parameter 'caller'
x86 is the only arch right now, which provides an optimized for
div_long_long_rem and it has the downside that one has to be very careful that
the divide doesn't overflow.
The API is a little akward, as the arguments for the unsigned divide are
signed. The signed version also doesn't handle a negative divisor and
produces worse code on 64bit archs.
There is little incentive to keep this API alive, so this converts the few
users to the new API.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Cc: john stultz <johnstul@us.ibm.com>
This:
commit 86f6dae1377523689bd8468fed2f2dd180fc0560
Author: Yasunori Goto <y-goto@jp.fujitsu.com>
Date: Mon Apr 28 02:13:33 2008 -0700
memory hotplug: allocate usemap on the section with pgdat
Usemaps are allocated on the section which has pgdat by this.
Because usemap size is very small, many other sections usemaps are allocated
on only one page. If a section has usemap, it can't be removed until removing
other sections. This dependency is not desirable for memory removing.
Pgdat has similar feature. When a section has pgdat area, it must be the last
section for removing on the node. So, if section A has pgdat and section B
has usemap for section A, Both sections can't be removed due to dependency
each other.
To solve this issue, this patch collects usemap on same section with pgdat.
If other sections doesn't have any dependency, this section will be able to be
removed finally.
Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
broke davem's sparc64 bootup. Revert it while we work out what went wrong.
KAMEZAWA Hiroyuki found a warning message in the buffer dirtying code that
is coming from page migration caller.
WARNING: at fs/buffer.c:720 __set_page_dirty+0x330/0x360()
Call Trace:
[<a000000100015220>] show_stack+0x80/0xa0
[<a000000100015270>] dump_stack+0x30/0x60
[<a000000100089ed0>] warn_on_slowpath+0x90/0xe0
[<a0000001001f8b10>] __set_page_dirty+0x330/0x360
[<a0000001001ffb90>] __set_page_dirty_buffers+0xd0/0x280
[<a00000010012fec0>] set_page_dirty+0xc0/0x260
[<a000000100195670>] migrate_page_copy+0x5d0/0x5e0
[<a000000100197840>] buffer_migrate_page+0x2e0/0x3c0
[<a000000100195eb0>] migrate_pages+0x770/0xe00
What was happening is that migrate_page_copy wants to transfer the PG_dirty
bit from old page to new page, so what it would do is set_page_dirty(newpage).
However set_page_dirty() is used to set the entire page dirty, wheras in
this case, only part of the page was dirty, and it also was not uptodate.
Marking the whole page dirty with set_page_dirty would lead to corruption or
unresolvable conditions -- a dirty && !uptodate page and dirty && !uptodate
buffers.
Possibly we could just ClearPageDirty(oldpage); SetPageDirty(newpage);
however in the interests of keeping the change minimal...
Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
We can see an ever repeating problem pattern with objects of any kind in the
kernel:
1) freeing of active objects
2) reinitialization of active objects
Both problems can be hard to debug because the crash happens at a point where
we have no chance to decode the root cause anymore. One problem spot are
kernel timers, where the detection of the problem often happens in interrupt
context and usually causes the machine to panic.
While working on a timer related bug report I had to hack specialized code
into the timer subsystem to get a reasonable hint for the root cause. This
debug hack was fine for temporary use, but far from a mergeable solution due
to the intrusiveness into the timer code.
The code further lacked the ability to detect and report the root cause
instantly and keep the system operational.
Keeping the system operational is important to get hold of the debug
information without special debugging aids like serial consoles and special
knowledge of the bug reporter.
The problems described above are not restricted to timers, but timers tend to
expose it usually in a full system crash. Other objects are less explosive,
but the symptoms caused by such mistakes can be even harder to debug.
Instead of creating specialized debugging code for the timer subsystem a
generic infrastructure is created which allows developers to verify their code
and provides an easy to enable debug facility for users in case of trouble.
The debugobjects core code keeps track of operations on static and dynamic
objects by inserting them into a hashed list and sanity checking them on
object operations and provides additional checks whenever kernel memory is
freed.
The tracked object operations are:
- initializing an object
- adding an object to a subsystem list
- deleting an object from a subsystem list
Each operation is sanity checked before the operation is executed and the
subsystem specific code can provide a fixup function which allows to prevent
the damage of the operation. When the sanity check triggers a warning message
and a stack trace is printed.
The list of operations can be extended if the need arises. For now it's
limited to the requirements of the first user (timers).
The core code enqueues the objects into hash buckets. The hash index is
generated from the address of the object to simplify the lookup for the check
on kfree/vfree. Each bucket has it's own spinlock to avoid contention on a
global lock.
The debug code can be compiled in without being active. The runtime overhead
is minimal and could be optimized by asm alternatives. A kernel command line
option enables the debugging code.
Thanks to Ingo Molnar for review, suggestions and cleanup patches.
Cc: Greg KH <greg@kroah.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Fuse will use temporary buffers to write back dirty data from memory mappings
(normal writes are done synchronously). This is needed, because there cannot
be any guarantee about the time in which a write will complete.
By using temporary buffers, from the MM's point if view the page is written
back immediately. If the writeout was due to memory pressure, this
effectively migrates data from a full zone to a less full zone.
This patch adds a new counter (NR_WRITEBACK_TEMP) for the number of pages used
as temporary buffers.
[Lee.Schermerhorn@hp.com: add vmstat_text for NR_WRITEBACK_TEMP]
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Fuse needs this for writable mmap support.
Add a new BDI capability flag: BDI_CAP_NO_ACCT_WB. If this flag is
set, then don't update the per-bdi writeback stats from
test_set_page_writeback() and test_clear_page_writeback().
Misc cleanups:
- convert bdi_cap_writeback_dirty() and friends to static inline functions
- create a flag that includes all three dirty/writeback related flags,
since almst all users will want to have them toghether
Move BDI statistics to debugfs:
/sys/kernel/debug/bdi/<bdi>/stats
Use postcore_initcall() to initialize the sysfs class and debugfs,
because debugfs is initialized in core_initcall().
Update descriptions in ABI documentation.
Add "max_ratio" to /sys/class/bdi. This indicates the maximum percentage of
the global dirty threshold allocated to this bdi.
[mszeredi@suse.cz]
- fix parsing in max_ratio_store().
- export bdi_set_max_ratio() to modules
- limit bdi_dirty with bdi->max_ratio
- document new sysfs attribute
Under normal circumstances each device is given a part of the total write-back
cache that relates to its current avg writeout speed in relation to the other
devices.
min_ratio - allows one to assign a minimum portion of the write-back cache to
a particular device. This is useful in situations where you might want to
provide a minimum QoS. (One request for this feature came from flash based
storage people who wanted to avoid writing out at all costs - they of course
needed some pdflush hacks as well)
max_ratio - allows one to assign a maximum portion of the dirty limit to a
particular device. This is useful in situations where you want to avoid one
device taking all or most of the write-back cache. Eg. an NFS mount that is
prone to get stuck, or a FUSE mount which you don't trust to play fair.
Add "min_ratio" to /sys/class/bdi. This indicates the minimum percentage of
[mszeredi@suse.cz]
- fix parsing in min_ratio_store()
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object.
This allows us to see and set the various BDI specific variables.
In particular this properly exposes the read-ahead window for all relevant
users and /sys/block/<block>/queue/read_ahead_kb should be deprecated.
With patient help from Kay Sievers and Greg KH
[mszeredi@suse.cz]
- split off NFS and FUSE changes into separate patches
- document new sysfs attributes under Documentation/ABI
- do bdi_class_init as a core_initcall, otherwise the "default" BDI
won't be initialized
- remove bdi_init_fmt macro, it's not used very much
[akpm@linux-foundation.org: fix ia64 warning]
Acked-by: Greg KH <greg@kroah.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
