path: root/mm
2005-06-29[PATCH] fix remap_pte_range BUGHugh Dickins
Out-of-tree user of remap_pfn_range hit kernel BUG at mm/memory.c:1112! It passes an unrounded size to remap_pfn_range, which was okay before 2.6.12, but misses remap_pte_range's new end condition. An audit of all the other ptwalks confirms that this is the only one so exposed. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Chris Wright <chrisw@osdl.org>
2005-06-06[PATCH] broken fault_in_pages_readable call in generic_file_buffered_write()Martin Schwidefsky
fault_in_pages_readable() is being passed an incorrect `end' address, which can result in writes accidentally faulting in pages which will not be affected by the write() call. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-24[PATCH] try_to_unmap_cluster() passes out-of-bounds pte to pte_unmap()William Lee Irwin III
try_to_unmap_cluster() does: for (pte = pte_offset_map(pmd, address); address < end; pte++, address += PAGE_SIZE) { ... } pte_unmap(pte); It may take a little staring to notice, but pte can actually fall off the end of the pte page in this iteration, which makes life difficult for kmap_atomic() and the users not expecting it to BUG(). Of course, we're somewhat lucky in that arithmetic elsewhere in the function guarantees that at least one iteration is made, lest this force larger rearrangements to be made. This issue and patch also apply to non-mm mainline and with trivial adjustments, at least two related kernels. Discovered during internal testing at Oracle. Signed-off-by: William Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-21[PATCH] fix for __generic_file_aio_read() to return 0 on EOFSuparna Bhattacharya
I came across the following problem while running ltp-aiodio testcases from ltp-full-20050405 on linux-2.6.12-rc3-mm3. I tried running the tests with EXT3 as well as JFS filesystems. One or two fsx-linux testcases were hung after some time. These testcases were hanging at wait_for_all_aios(). Debugging shows that there were some iocbs which were not getting completed eventhough the last retry for those returned -EIOCBQUEUED. Also all such pending iocbs represented READ operation. Further debugging revealed that all such iocbs hit EOF in the DIO layer. To be more precise, the "pos" from which they were trying to read was greater than the "size" of the file. So the generic_file_direct_IO returned 0. This happens rarely as there is already a check in __generic_file_aio_read(), for whether "pos" < "size" before calling direct IO routine. >size = i_size_read(inode); >if (pos < size) { > retval = generic_file_direct_IO(READ, iocb, > iov, pos, nr_segs); But for READ, we are taking the inode->i_sem only in the DIO layer. So it is possible that some other process can change the size of the file before we take the i_sem. In such a case ( when "pos" > "size"), the __generic_file_aio_read() would return -EIOCBQUEUED even though there were no I/O requests submitted by the DIO layer. This would cause the AIO layer to expect aio_complete() for THE iocb, which doesnot happen. And thus the test hangs forever, waiting for an I/O completion, where there are no requests submitted at all. The following patch makes __generic_file_aio_read() return 0 (instead of returning -EIOCBQUEUED), on getting 0 from generic_file_direct_IO(), so that the AIO layer does the aio_complete(). Testing: I have tested the patch on a SMP machine(with 2 Pentium 4 (HT)) running linux-2.6.12-rc3-mm3. I ran the ltp-aiodio testcases and none of the fsx-linux tests hung. Also the aio-stress tests ran without any problem. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Suparna Bhattacharya <suparna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] x86_64: Fixed guard page handling again in iounmapAndi Kleen
Caused oopses again. Also fix potential mismatch in checking if change_page_attr was needed. To do it without races I needed to change mm/vmalloc.c to export a __remove_vm_area that does not take vmlist lock. Noticed by Terence Ripperda and based on a patch of his. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-19Fix get_unmapped_area sanity testsLinus Torvalds
As noted by Chris Wright, we need to do the full range of tests regardless of whether MAP_FIXED is set or not, so re-organize get_unmapped_area() slightly to do the sanity checks unconditionally.
2005-05-19[PATCH] prevent NULL mmap in topdown modelLinus Torvalds
Prevent the topdown allocator from allocating mmap areas all the way down to address zero. We still allow a MAP_FIXED mapping of page 0 (needed for various things, ranging from Wine and DOSEMU to people who want to allow speculative loads off a NULL pointer). Tested by Chris Wright. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] do_swap_page() can map random data if swap read failsKirill Korotaev
There is a bug in do_swap_page(): when swap page happens to be unreadable, page filled with random data is mapped into user address space. The fix is to check for PageUptodate and send SIGBUS in case of error. Signed-Off-By: Kirill Korotaev <dev@sw.ru> Signed-Off-By: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] swapout oops fixMcMullan, Jason
Fix OOPS when swapping on a device that doesn't have an unplug_io_fn defined (eg, ATA Over Ethernet) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] mm/nommu.c: try to fix __vmallocAdrian Bunk
Linus changed the second argument of __vmalloc from int to unsigned int breaking the compilation for CONFIG_MMU=n configurations (since he only changed vmalloc.c but not nommu.c). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] mm acct accounting fixKirill Korotaev
This patch fixes mm->total_vm and mm->locked_vm acctounting in case when move_page_tables() fails inside move_vma(). Signed-Off-By: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] mm: fix rss counter being incremented when unmappingBjorn Steinbrink
This patch fixes a bug introduced by the "mm counter operations through macros" patch, which replaced a decrement operation in with an increment macro in try_to_unmap_one(). Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] remove outdated comments from filemap.cChristoph Hellwig
2005-05-03[IA64] Export node_online_map and node_possible_mapDean Nelson
Export node_online_map and node_possible_map so that kernel modules can use the nodemask macros, like, for_each_node() and for_each_online_node(). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-05-01[PATCH] DocBook: fix some descriptionsMartin Waitz
Some KernelDoc descriptions are updated to match the current code. No code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: changes and extensions to the kernel documentationPavel Pisa
I have recompiled Linux kernel 2.6.11.5 documentation for me and our university students again. The documentation could be extended for more sources which are equipped by structured comments for recent 2.6 kernels. I have tried to proceed with that task. I have done that more times from 2.6.0 time and it gets boring to do same changes again and again. Linux kernel compiles after changes for i386 and ARM targets. I have added references to some more files into kernel-api book, I have added some section names as well. So please, check that changes do not break something and that categories are not too much skewed. I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved by kernel convention. Most of the other changes are modifications in the comments to make kernel-doc happy, accept some parameters description and do not bail out on errors. Changed <pid> to @pid in the description, moved some #ifdef before comments to correct function to comments bindings, etc. You can see result of the modified documentation build at http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz Some more sources are ready to be included into kernel-doc generated documentation. Sources has been added into kernel-api for now. Some more section names added and probably some more chaos introduced as result of quick cleanup work. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Change synchronize_kernel to _rcu and _schedPaul E. McKenney
This patch changes calls to synchronize_kernel(), deprecated in the earlier "Deprecate synchronize_kernel, GPL replacement" patch to instead call the new synchronize_rcu() and synchronize_sched() APIs. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Exterminate PAGE_BUGMatt Mackall
Remove PAGE_BUG - repalce it with BUG and BUG_ON. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] add kmalloc_node, inline cleanupManfred Spraul
The patch makes the following function calls available to allocate memory on a specific node without changing the basic operation of the slab allocator: kmem_cache_alloc_node(kmem_cache_t *cachep, unsigned int flags, int node); kmalloc_node(size_t size, unsigned int flags, int node); in a similar way to the existing node-blind functions: kmem_cache_alloc(kmem_cache_t *cachep, unsigned int flags); kmalloc(size, flags); kmem_cache_alloc_node was changed to pass flags and the node information through the existing layers of the slab allocator (which lead to some minor rearrangements). The functions at the lowest layer (kmem_getpages, cache_grow) are already node aware. Also __alloc_percpu can call kmalloc_node now. Performance measurements (using the pageset localization patch) yields: w/o patches: Tasks jobs/min jti jobs/min/task real cpu 1 484.27 100 484.2736 12.02 1.97 Wed Mar 30 20:50:43 2005 100 25170.83 91 251.7083 23.12 150.10 Wed Mar 30 20:51:06 2005 200 34601.66 84 173.0083 33.64 294.14 Wed Mar 30 20:51:40 2005 300 37154.47 86 123.8482 46.99 436.56 Wed Mar 30 20:52:28 2005 400 39839.82 80 99.5995 58.43 580.46 Wed Mar 30 20:53:27 2005 500 40036.32 79 80.0726 72.68 728.60 Wed Mar 30 20:54:40 2005 600 44074.21 79 73.4570 79.23 872.10 Wed Mar 30 20:55:59 2005 700 44016.60 78 62.8809 92.56 1015.84 Wed Mar 30 20:57:32 2005 800 40411.05 80 50.5138 115.22 1161.13 Wed Mar 30 20:59:28 2005 900 42298.56 79 46.9984 123.83 1303.42 Wed Mar 30 21:01:33 2005 1000 40955.05 80 40.9551 142.11 1441.92 Wed Mar 30 21:03:55 2005 with pageset localization and slab API patches: Tasks jobs/min jti jobs/min/task real cpu 1 484.19 100 484.1930 12.02 1.98 Wed Mar 30 21:10:18 2005 100 27428.25 92 274.2825 21.22 149.79 Wed Mar 30 21:10:40 2005 200 37228.94 86 186.1447 31.27 293.49 Wed Mar 30 21:11:12 2005 300 41725.42 85 139.0847 41.84 434.10 Wed Mar 30 21:11:54 2005 400 43032.22 82 107.5805 54.10 582.06 Wed Mar 30 21:12:48 2005 500 42211.23 83 84.4225 68.94 722.61 Wed Mar 30 21:13:58 2005 600 40084.49 82 66.8075 87.12 873.11 Wed Mar 30 21:15:25 2005 700 44169.30 79 63.0990 92.24 1008.77 Wed Mar 30 21:16:58 2005 800 43097.94 79 53.8724 108.03 1155.88 Wed Mar 30 21:18:47 2005 900 41846.75 79 46.4964 125.17 1303.38 Wed Mar 30 21:20:52 2005 1000 40247.85 79 40.2478 144.60 1442.21 Wed Mar 30 21:23:17 2005 Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] sync_page() smp_mb() commentWilliam Lee Irwin III
The smp_mb() is becaus sync_page() doesn't have PG_locked while it accesses page_mapping(page). The comments in the patch (the entire patch is the addition of this comment) try to explain further how and why smp_mb() is used. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] RLIMIT_MEMLOCK checking fixChris Wright
Always use page counts when doing RLIMIT_MEMLOCK checking to avoid possible overflow. Signed-off-by: Chris Wright <chrisw@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] count bounce buffer pages in vmstatKAMEZAWA Hiroyuki
This is a patch for counting the number of pages for bounce buffers. It's shown in /proc/vmstat. Currently, the number of bounce pages are not counted anywhere. So, if there are many bounce pages, it seems that there are leaked pages. And it's difficult for a user to imagine the usage of bounce pages. So, it's meaningful to show # of bouce pages. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] mm: use __GFP_NOMEMALLOCNick Piggin
Use the new __GFP_NOMEMALLOC to simplify the previous handling of PF_MEMALLOC. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] mempool: simplify allocNick Piggin
Mempool is pretty clever. Looks too clever for its own good :) It shouldn't really know so much about page reclaim internals. - don't guess about what effective page reclaim might involve. - don't randomly flush out all dirty data if some unlikely thing happens (alloc returns NULL). page reclaim can (sort of :P) handle it. I think the main motivation is trying to avoid pool->lock at all costs. However the first allocation is attempted with __GFP_WAIT cleared, so it will be 'can_try_harder' if it hits the page allocator. So if allocation still fails, then we can probably afford to hit the pool->lock - and what's the alternative? Try page reclaim and hit zone->lru_lock? A nice upshot is that we don't need to do any fancy memory barriers or do (intentionally) racy access to pool-> fields outside the lock. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] mempool: NOMEMALLOC and NORETRYNick Piggin
Mempools have 2 problems. The first is that mempool_alloc can possibly get stuck in __alloc_pages when they should opt to fail, and take an element from their reserved pool. The second is that it will happily eat emergency PF_MEMALLOC reserves instead of going to their reserved pools. Fix the first by passing __GFP_NORETRY in the allocation calls in mempool_alloc. Fix the second by introducing a __GFP_MEMPOOL flag which directs the page allocator not to allocate from the reserve pool. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] mm: pcp use non powers of 2 for batch sizeNick Piggin
Jack Steiner reported this to have fixed his problem (bad colouring): "The patches fix both problems that I found - bad coloring & excessive pages in pagesets." In most workloads this is not likely to be such a pronounced problem, however it should help corner cases. And avoiding powers of 2 in these types of memory operations is always a good idea. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] mm: rmap.c cleanupNikita Danilov
mm/rmap.c:page_referenced_one() and mm/rmap.c:try_to_unmap_one() contain identical code that - takes mm->page_table_lock; - drills through page tables; - checks that correct pte is reached. Coalesce this into page_check_address() Signed-off-by: Nikita Danilov <nikita@clusterfs.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] RLIMIT_AS checking fixakpm@osdl.org
Address bug #4508: there's potential for wraparound in the various places where we perform RLIMIT_AS checking. (I'm a bit worried about acct_stack_growth(). Are we sure that vma->vm_mm is always equal to current->mm? If not, then we're comparing some other process's total_vm with the calling process's rlimits). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] generic_file_buffered_write fixesakpm@osdl.org
Anton Altaparmakov <aia21@cam.ac.uk> points out: - It calls fault_in_pages_readable() which is completely bogus if @nr_segs > 1. It needs to be replaced by a to be written "fault_in_pages_readable_iovec()". - It increments @buf even in the iovec case thus @buf can point to random memory really quickly (in the iovec case) and then it calls fault_in_pages_readable() on this random memory. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[PATCH] mempolicy.c GFP fixAl Viro
zonelist_policy() forgot to mask non-zone bits from gfp when comparing zone number with policy_zone. ACKed-by: Andi Kleen <ak@suse.de> Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: remove FIRST_USER_ADDRESS hackHugh Dickins
Once all the MMU architectures define FIRST_USER_ADDRESS, remove hack from mmap.c which derived it from FIRST_USER_PGD_NR. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: sys_mincore ignore FIRST_USER_PGD_NRHugh Dickins
Remove use of FIRST_USER_PGD_NR from sys_mincore: it's inconsistent (no other syscall refers to it), unnecessary (sys_mincore loops over vmas further down) and incorrect (misses user addresses in ARM's first pgd). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: free_pgtables from FIRST_USER_ADDRESSHugh Dickins
The patches to free_pgtables by vma left problems on any architectures which leave some user address page table entries unencapsulated by vma. Andi has fixed the 32-bit vDSO on x86_64 to use a vma. Now fix arm (and arm26), whose first PAGE_SIZE is reserved (perhaps) for machine vectors. Our calls to free_pgtables must not touch that area, and exit_mmap's BUG_ON(nr_ptes) must allow that arm's get_pgd_slow may (or may not) have allocated an extra page table, which its free_pgd_slow would free later. FIRST_USER_PGD_NR has misled me and others: until all the arches define FIRST_USER_ADDRESS instead, a hack in mmap.c to derive one from t'other. This patch fixes the bugs, the remaining patches just clean it up. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: mpnt to vma cleanupHugh Dickins
While dabbling here in mmap.c, clean up mysterious "mpnt"s to "vma"s. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: hugetlb_free_pgd_rangeHugh Dickins
ia64 and ppc64 had hugetlb_free_pgtables functions which were no longer being called, and it wasn't obvious what to do about them. The ppc64 case turns out to be easy: the associated tables are noted elsewhere and freed later, safe to either skip its hugetlb areas or go through the motions of freeing nothing. Since ia64 does need a special case, restore to ppc64 the special case of skipping them. The ia64 hugetlb case has been broken since pgd_addr_end went in, though it probably appeared to work okay if you just had one such area; in fact it's been broken much longer if you consider a long munmap spanning from another region into the hugetlb region. In the ia64 hugetlb region, more virtual address bits are available than in the other regions, yet the page tables are structured the same way: the page at the bottom is larger. Here we need to scale down each addr before passing it to the standard free_pgd_range. Was about to write a hugely_scaled_down macro, but found htlbpage_to_page already exists for just this purpose. Fixed off-by-one in ia64 is_hugepage_only_range. Uninline free_pgd_range to make it available to ia64. Make sure the vma-gathering loop in free_pgtables cannot join a hugepage_only_range to any other (safe to join huges? probably but don't bother). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: remove MM_VM_SIZE(mm)Hugh Dickins
There's only one usage of MM_VM_SIZE(mm) left, and it's a troublesome macro because mm doesn't contain the (32-bit emulation?) info needed. But it too is only needed because we ignore the end from the vma list. We could make flush_pgtables return that end, or unmap_vmas. Choose the latter, since it's a natural fit with unmap_mapping_range_vma needing to know its restart addr. This does make more than minimal change, but if unmap_vmas had returned the end before, this is how we'd have done it, rather than storing the break_addr in zap_details. unmap_vmas used to return count of vmas scanned, but that's just debug which hasn't been useful in a while; and if we want the map_count 0 on exit check back, it can easily come from the final remove_vm_struct loop. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: free_pgtables use vma listHugh Dickins
Recent woes with some arches needing their own pgd_addr_end macro; and 4-level clear_page_range regression since 2.6.10's clear_page_tables; and its long-standing well-known inefficiency in searching throughout the higher-level page tables for those few entries to clear and free: all can be blamed on ignoring the list of vmas when we free page tables. Replace exit_mmap's clear_page_range of the total user address space by free_pgtables operating on the mm's vma list; unmap_region use it in the same way, giving floor and ceiling beyond which it may not free tables. This brings lmbench fork/exec/sh numbers back to 2.6.10 (unless preempt is enabled, in which case latency fixes spoil unmap_vmas throughput). Beware: the do_mmap_pgoff driver failure case must now use unmap_region instead of zap_page_range, since a page table might have been allocated, and can only be freed while it is touched by some vma. Move free_pgtables from mmap.c to memory.c, where its lower levels are adapted from the clear_page_range levels. (Most of free_pgtables' old code was actually for a non-existent case, prev not properly set up, dating from before hch gave us split_vma.) Pass mmu_gather** in the public interfaces, since we might want to add latency lockdrops later; but no attempt to do so yet, going by vma should itself reduce latency. But what if is_hugepage_only_range? Those ia64 and ppc64 cases need careful examination: put that off until a later patch of the series. What of x86_64's 32bit vdso page __map_syscall32 maps outside any vma? And the range to sparc64's flush_tlb_pgtables? It's less clear to me now that we need to do more than is done here - every PMD_SIZE ever occupied will be flushed, do we really have to flush every PGDIR_SIZE ever partially occupied? A shame to complicate it unnecessarily. Special thanks to David Miller for time spent repairing my ceilings. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] vmscan: pageout(): remove unneeded testakpm@osdl.org
) We only call pageout() for dirty pages, so this test is redundant. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] oom-killer disable for iscsi/lvm2/multipath userland critical sectionsAndrea Arcangeli
iscsi/lvm2/multipath needs guaranteed protection from the oom-killer, so make the magical value of -17 in /proc/<pid>/oom_adj defeat the oom-killer altogether. (akpm: we still need to document oom_adj and friends in Documentation/filesystems/proc.txt!) Signed-off-by: Andrea Arcangeli <andrea@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] filemap_getpage can block when MAP_NONBLOCK specifiedJeff Moyer
We will return NULL from filemap_getpage when a page does not exist in the page cache and MAP_NONBLOCK is specified, here: page = find_get_page(mapping, pgoff); if (!page) { if (nonblock) return NULL; goto no_cached_page; } But we forget to do so when the page in the cache is not uptodate. The following could result in a blocking call: /* * Ok, found a page in the page cache, now we need to check * that it's up-to-date. */ if (!PageUptodate(page)) goto page_not_uptodate; Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
