path: root/mm
2018-08-15x86/speculation/l1tf: Limit swap file size to MAX_PA/2Andi Kleen
commit 377eeaa8e11fe815b1d07c81c4a0e2843a8c15eb upstream For the L1TF workaround its necessary to limit the swap file size to below MAX_PA/2, so that the higher bits of the swap offset inverted never point to valid memory. Add a mechanism for the architecture to override the swap file size check in swapfile.c and add a x86 specific max swapfile check function that enforces that limit. The check is only enabled if the CPU is vulnerable to L1TF. In VMs with 42bit MAX_PA the typical limit is 2TB now, on a native system with 46bit PA it is 32TB. The limit is only per individual swap file, so it's always possible to exceed these limits with multiple swap files or partitions. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Dave Hansen <dave.hansen@intel.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15x86/speculation/l1tf: Disallow non privileged high MMIO PROT_NONE mappingsAndi Kleen
commit 42e4089c7890725fcd329999252dc489b72f2921 upstream For L1TF PROT_NONE mappings are protected by inverting the PFN in the page table entry. This sets the high bits in the CPU's address space, thus making sure to point to not point an unmapped entry to valid cached memory. Some server system BIOSes put the MMIO mappings high up in the physical address space. If such an high mapping was mapped to unprivileged users they could attack low memory by setting such a mapping to PROT_NONE. This could happen through a special device driver which is not access protected. Normal /dev/mem is of course access protected. To avoid this forbid PROT_NONE mappings or mprotect for high MMIO mappings. Valid page mappings are allowed because the system is then unsafe anyways. It's not expected that users commonly use PROT_NONE on MMIO. But to minimize any impact this is only enforced if the mapping actually refers to a high MMIO address (defined as the MAX_PA-1 bit being set), and also skip the check for root. For mmaps this is straight forward and can be handled in vm_insert_pfn and in remap_pfn_range(). For mprotect it's a bit trickier. At the point where the actual PTEs are accessed a lot of state has been changed and it would be difficult to undo on an error. Since this is a uncommon case use a separate early page talk walk pass for MMIO PROT_NONE mappings that checks for this condition early. For non MMIO and non PROT_NONE there are no changes. [dwmw2: Backport to 4.9] Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Dave Hansen <dave.hansen@intel.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03mm/slub.c: add __printf verification to slab_err()Mathieu Malaterre
[ Upstream commit a38965bf941b7c2af50de09c96bc5f03e136caef ] __printf is useful to verify format and arguments. Remove the following warning (with W=1): mm/slub.c:721:2: warning: function might be possible candidate for `gnu_printf' format attribute [-Wsuggest-attribute=format] Link: http://lkml.kernel.org/r/20180505200706.19986-1-malat@debian.org Signed-off-by: Mathieu Malaterre <malat@debian.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03mm: vmalloc: avoid racy handling of debugobjects in vunmapChintan Pandya
[ Upstream commit f3c01d2f3ade6790db67f80fef60df84424f8964 ] Currently, __vunmap flow is, 1) Release the VM area 2) Free the debug objects corresponding to that vm area. This leave some race window open. 1) Release the VM area 1.5) Some other client gets the same vm area 1.6) This client allocates new debug objects on the same vm area 2) Free the debug objects corresponding to this vm area. Here, we actually free 'other' client's debug objects. Fix this by freeing the debug objects first and then releasing the VM area. Link: http://lkml.kernel.org/r/1523961828-9485-2-git-send-email-cpandya@codeaurora.org Signed-off-by: Chintan Pandya <cpandya@codeaurora.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Laura Abbott <labbott@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wei Yang <richard.weiyang@gmail.com> Cc: Yisheng Xie <xieyisheng1@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25mm/huge_memory.c: fix data loss when splitting a file pmdHugh Dickins
commit e1f1b1572e8db87a56609fd05bef76f98f0e456a upstream. __split_huge_pmd_locked() must check if the cleared huge pmd was dirty, and propagate that to PageDirty: otherwise, data may be lost when a huge tmpfs page is modified then split then reclaimed. How has this taken so long to be noticed? Because there was no problem when the huge page is written by a write system call (shmem_write_end() calls set_page_dirty()), nor when the page is allocated for a write fault (fault_dirty_shared_page() calls set_page_dirty()); but when allocated for a read fault (which MAP_POPULATE simulates), no set_page_dirty(). Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1807111741430.1106@eggly.anvils Fixes: d21b9e57c74c ("thp: handle file pages in split_huge_pmd()") Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Ashwin Chaugule <ashwinch@google.com> Reviewed-by: Yang Shi <yang.shi@linux.alibaba.com> Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: "Huang, Ying" <ying.huang@intel.com> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25mm: memcg: fix use after free in mem_cgroup_iter()Jing Xia
commit 9f15bde671355c351cf20d9f879004b234353100 upstream. It was reported that a kernel crash happened in mem_cgroup_iter(), which can be triggered if the legacy cgroup-v1 non-hierarchical mode is used. Unable to handle kernel paging request at virtual address 6b6b6b6b6b6b8f ...... Call trace: mem_cgroup_iter+0x2e0/0x6d4 shrink_zone+0x8c/0x324 balance_pgdat+0x450/0x640 kswapd+0x130/0x4b8 kthread+0xe8/0xfc ret_from_fork+0x10/0x20 mem_cgroup_iter(): ...... if (css_tryget(css)) <-- crash here break; ...... The crashing reason is that mem_cgroup_iter() uses the memcg object whose pointer is stored in iter->position, which has been freed before and filled with POISON_FREE(0x6b). And the root cause of the use-after-free issue is that invalidate_reclaim_iterators() fails to reset the value of iter->position to NULL when the css of the memcg is released in non- hierarchical mode. Link: http://lkml.kernel.org/r/1531994807-25639-1-git-send-email-jing.xia@unisoc.com Fixes: 6df38689e0e9 ("mm: memcontrol: fix possible memcg leak due to interrupted reclaim") Signed-off-by: Jing Xia <jing.xia.mail@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: <chunyan.zhang@unisoc.com> Cc: Shakeel Butt <shakeelb@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-11mm, page_alloc: do not break __GFP_THISNODE by zonelist resetVlastimil Babka
commit 7810e6781e0fcbca78b91cf65053f895bf59e85f upstream. In __alloc_pages_slowpath() we reset zonelist and preferred_zoneref for allocations that can ignore memory policies. The zonelist is obtained from current CPU's node. This is a problem for __GFP_THISNODE allocations that want to allocate on a different node, e.g. because the allocating thread has been migrated to a different CPU. This has been observed to break SLAB in our 4.4-based kernel, because there it relies on __GFP_THISNODE working as intended. If a slab page is put on wrong node's list, then further list manipulations may corrupt the list because page_to_nid() is used to determine which node's list_lock should be locked and thus we may take a wrong lock and race. Current SLAB implementation seems to be immune by luck thanks to commit 511e3a058812 ("mm/slab: make cache_grow() handle the page allocated on arbitrary node") but there may be others assuming that __GFP_THISNODE works as promised. We can fix it by simply removing the zonelist reset completely. There is actually no reason to reset it, because memory policies and cpusets don't affect the zonelist choice in the first place. This was different when commit 183f6371aac2 ("mm: ignore mempolicies when using ALLOC_NO_WATERMARK") introduced the code, as mempolicies provided their own restricted zonelists. We might consider this for 4.17 although I don't know if there's anything currently broken. SLAB is currently not affected, but in kernels older than 4.7 that don't yet have 511e3a058812 ("mm/slab: make cache_grow() handle the page allocated on arbitrary node") it is. That's at least 4.4 LTS. Older ones I'll have to check. So stable backports should be more important, but will have to be reviewed carefully, as the code went through many changes. BTW I think that also the ac->preferred_zoneref reset is currently useless if we don't also reset ac->nodemask from a mempolicy to NULL first (which we probably should for the OOM victims etc?), but I would leave that for a separate patch. Link: http://lkml.kernel.org/r/20180525130853.13915-1-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Fixes: 183f6371aac2 ("mm: ignore mempolicies when using ALLOC_NO_WATERMARK") Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: Michal Hocko <mhocko@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-11mm: hugetlb: yield when prepping struct pagesCannon Matthews
commit 520495fe96d74e05db585fc748351e0504d8f40d upstream. When booting with very large numbers of gigantic (i.e. 1G) pages, the operations in the loop of gather_bootmem_prealloc, and specifically prep_compound_gigantic_page, takes a very long time, and can cause a softlockup if enough pages are requested at boot. For example booting with 3844 1G pages requires prepping (set_compound_head, init the count) over 1 billion 4K tail pages, which takes considerable time. Add a cond_resched() to the outer loop in gather_bootmem_prealloc() to prevent this lockup. Tested: Booted with softlockup_panic=1 hugepagesz=1G hugepages=3844 and no softlockup is reported, and the hugepages are reported as successfully setup. Link: http://lkml.kernel.org/r/20180627214447.260804-1-cannonmatthews@google.com Signed-off-by: Cannon Matthews <cannonmatthews@google.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Peter Feiner <pfeiner@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13mmap: relax file size limit for regular filesLinus Torvalds
commit 423913ad4ae5b3e8fb8983f70969fb522261ba26 upstream. Commit be83bbf80682 ("mmap: introduce sane default mmap limits") was introduced to catch problems in various ad-hoc character device drivers doing mmap and getting the size limits wrong. In the process, it used "known good" limits for the normal cases of mapping regular files and block device drivers. It turns out that the "s_maxbytes" limit was less "known good" than I thought. In particular, /proc doesn't set it, but exposes one regular file to mmap: /proc/vmcore. As a result, that file got limited to the default MAX_INT s_maxbytes value. This went unnoticed for a while, because apparently the only thing that needs it is the s390 kernel zfcpdump, but there might be other tools that use this too. Vasily suggested just changing s_maxbytes for all of /proc, which isn't wrong, but makes me nervous at this stage. So instead, just make the new mmap limit always be MAX_LFS_FILESIZE for regular files, which won't affect anything else. It wasn't the regular file case I was worried about. I'd really prefer for maxsize to have been per-inode, but that is not how things are today. Fixes: be83bbf80682 ("mmap: introduce sane default mmap limits") Reported-by: Vasily Gorbik <gor@linux.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13mmap: introduce sane default mmap limitsLinus Torvalds
commit be83bbf806822b1b89e0a0f23cd87cddc409e429 upstream. The internal VM "mmap()" interfaces are based on the mmap target doing everything using page indexes rather than byte offsets, because traditionally (ie 32-bit) we had the situation that the byte offset didn't fit in a register. So while the mmap virtual address was limited by the word size of the architecture, the backing store was not. So we're basically passing "pgoff" around as a page index, in order to be able to describe backing store locations that are much bigger than the word size (think files larger than 4GB etc). But while this all makes a ton of sense conceptually, we've been dogged by various drivers that don't really understand this, and internally work with byte offsets, and then try to work with the page index by turning it into a byte offset with "pgoff << PAGE_SHIFT". Which obviously can overflow. Adding the size of the mapping to it to get the byte offset of the end of the backing store just exacerbates the problem, and if you then use this overflow-prone value to check various limits of your device driver mmap capability, you're just setting yourself up for problems. The correct thing for drivers to do is to do their limit math in page indices, the way the interface is designed. Because the generic mmap code _does_ test that the index doesn't overflow, since that's what the mmap code really cares about. HOWEVER. Finding and fixing various random drivers is a sisyphean task, so let's just see if we can just make the core mmap() code do the limiting for us. Realistically, the only "big" backing stores we need to care about are regular files and block devices, both of which are known to do this properly, and which have nice well-defined limits for how much data they can access. So let's special-case just those two known cases, and then limit other random mmap users to a backing store that still fits in "unsigned long". Realistically, that's not much of a limit at all on 64-bit, and on 32-bit architectures the only worry might be the GPU drivers, which can have big physical address spaces. To make it possible for drivers like that to say that they are 64-bit clean, this patch does repurpose the "FMODE_UNSIGNED_OFFSET" bit in the file flags to allow drivers to mark their file descriptors as safe in the full 64-bit mmap address space. [ The timing for doing this is less than optimal, and this should really go in a merge window. But realistically, this needs wide testing more than it needs anything else, and being main-line is the only way to do that. So the earlier the better, even if it's outside the proper development cycle - Linus ] Cc: Kees Cook <keescook@chromium.org> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Willy Tarreau <w@1wt.eu> Cc: Dave Airlie <airlied@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-06mm: fix the NULL mapping case in __isolate_lru_page()Hugh Dickins
commit 145e1a71e090575c74969e3daa8136d1e5b99fc8 upstream. George Boole would have noticed a slight error in 4.16 commit 69d763fc6d3a ("mm: pin address_space before dereferencing it while isolating an LRU page"). Fix it, to match both the comment above it, and the original behaviour. Although anonymous pages are not marked PageDirty at first, we have an old habit of calling SetPageDirty when a page is removed from swap cache: so there's a category of ex-swap pages that are easily migratable, but were inadvertently excluded from compaction's async migration in 4.16. Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1805302014001.12558@eggly.anvils Fixes: 69d763fc6d3a ("mm: pin address_space before dereferencing it while isolating an LRU page") Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Minchan Kim <minchan@kernel.org> Acked-by: Mel Gorman <mgorman@techsingularity.net> Reported-by: Ivan Kalvachev <ikalvachev@gmail.com> Cc: "Huang, Ying" <ying.huang@intel.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm: fix races between address_space dereference and free in page_evicatableHuang Ying
[ Upstream commit e92bb4dd9673945179b1fc738c9817dd91bfb629 ] When page_mapping() is called and the mapping is dereferenced in page_evicatable() through shrink_active_list(), it is possible for the inode to be truncated and the embedded address space to be freed at the same time. This may lead to the following race. CPU1 CPU2 truncate(inode) shrink_active_list() ... page_evictable(page) truncate_inode_page(mapping, page); delete_from_page_cache(page) spin_lock_irqsave(&mapping->tree_lock, flags); __delete_from_page_cache(page, NULL) page_cache_tree_delete(..) ... mapping = page_mapping(page); page->mapping = NULL; ... spin_unlock_irqrestore(&mapping->tree_lock, flags); page_cache_free_page(mapping, page) put_page(page) if (put_page_testzero(page)) -> false - inode now has no pages and can be freed including embedded address_space mapping_unevictable(mapping) test_bit(AS_UNEVICTABLE, &mapping->flags); - we've dereferenced mapping which is potentially already free. Similar race exists between swap cache freeing and page_evicatable() too. The address_space in inode and swap cache will be freed after a RCU grace period. So the races are fixed via enclosing the page_mapping() and address_space usage in rcu_read_lock/unlock(). Some comments are added in code to make it clear what is protected by the RCU read lock. Link: http://lkml.kernel.org/r/20180212081227.1940-1-ying.huang@intel.com Signed-off-by: "Huang, Ying" <ying.huang@intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Minchan Kim <minchan@kernel.org> Cc: "Huang, Ying" <ying.huang@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm/ksm: fix interaction with THPClaudio Imbrenda
[ Upstream commit 77da2ba0648a4fd52e5ff97b8b2b8dd312aec4b0 ] This patch fixes a corner case for KSM. When two pages belong or belonged to the same transparent hugepage, and they should be merged, KSM fails to split the page, and therefore no merging happens. This bug can be reproduced by: * making sure ksm is running (in case disabling ksmtuned) * enabling transparent hugepages * allocating a THP-aligned 1-THP-sized buffer e.g. on amd64: posix_memalign(&p, 1<<21, 1<<21) * filling it with the same values e.g. memset(p, 42, 1<<21) * performing madvise to make it mergeable e.g. madvise(p, 1<<21, MADV_MERGEABLE) * waiting for KSM to perform a few scans The expected outcome is that the all the pages get merged (1 shared and the rest sharing); the actual outcome is that no pages get merged (1 unshared and the rest volatile) The reason of this behaviour is that we increase the reference count once for both pages we want to merge, but if they belong to the same hugepage (or compound page), the reference counter used in both cases is the one of the head of the compound page. This means that split_huge_page will find a value of the reference counter too high and will fail. This patch solves this problem by testing if the two pages to merge belong to the same hugepage when attempting to merge them. If so, the hugepage is split safely. This means that the hugepage is not split if not necessary. Link: http://lkml.kernel.org/r/1521548069-24758-1-git-send-email-imbrenda@linux.vnet.ibm.com Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com> Co-authored-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30swap: divide-by-zero when zero length swap file on ssdTom Abraham
[ Upstream commit a06ad633a37c64a0cd4c229fc605cee8725d376e ] Calling swapon() on a zero length swap file on SSD can lead to a divide-by-zero. Although creating such files isn't possible with mkswap and they woud be considered invalid, it would be better for the swapon code to be more robust and handle this condition gracefully (return -EINVAL). Especially since the fix is small and straightforward. To help with wear leveling on SSD, the swapon syscall calculates a random position in the swap file using modulo p->highest_bit, which is set to maxpages - 1 in read_swap_header. If the swap file is zero length, read_swap_header sets maxpages=1 and last_page=0, resulting in p->highest_bit=0 and we divide-by-zero when we modulo p->highest_bit in swapon syscall. This can be prevented by having read_swap_header return zero if last_page is zero. Link: http://lkml.kernel.org/r/5AC747C1020000A7001FA82C@prv-mh.provo.novell.com Signed-off-by: Thomas Abraham <tabraham@suse.com> Reported-by: <Mark.Landis@Teradata.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm/kmemleak.c: wait for scan completion before disabling freeVinayak Menon
[ Upstream commit 914b6dfff790544d9b77dfd1723adb3745ec9700 ] A crash is observed when kmemleak_scan accesses the object->pointer, likely due to the following race. TASK A TASK B TASK C kmemleak_write (with "scan" and NOT "scan=on") kmemleak_scan() create_object kmem_cache_alloc fails kmemleak_disable kmemleak_do_cleanup kmemleak_free_enabled = 0 kfree kmemleak_free bails out (kmemleak_free_enabled is 0) slub frees object->pointer update_checksum crash - object->pointer freed (DEBUG_PAGEALLOC) kmemleak_do_cleanup waits for the scan thread to complete, but not for direct call to kmemleak_scan via kmemleak_write. So add a wait for kmemleak_scan completion before disabling kmemleak_free, and while at it fix the comment on stop_scan_thread. [vinmenon@codeaurora.org: fix stop_scan_thread comment] Link: http://lkml.kernel.org/r/1522219972-22809-1-git-send-email-vinmenon@codeaurora.org Link: http://lkml.kernel.org/r/1522063429-18992-1-git-send-email-vinmenon@codeaurora.org Signed-off-by: Vinayak Menon <vinmenon@codeaurora.org> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm, thp: do not cause memcg oom for thpDavid Rientjes
[ Upstream commit 9d3c3354bb85bab4d865fe95039443f09a4c8394 ] Commit 2516035499b9 ("mm, thp: remove __GFP_NORETRY from khugepaged and madvised allocations") changed the page allocator to no longer detect thp allocations based on __GFP_NORETRY. It did not, however, modify the mem cgroup try_charge() path to avoid oom kill for either khugepaged collapsing or thp faulting. It is never expected to oom kill a process to allocate a hugepage for thp; reclaim is governed by the thp defrag mode and MADV_HUGEPAGE, but allocations (and charging) should fallback instead of oom killing processes. Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1803191409420.124411@chino.kir.corp.google.com Fixes: 2516035499b9 ("mm, thp: remove __GFP_NORETRY from khugepaged and madvised allocations") Signed-off-by: David Rientjes <rientjes@google.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm/mempolicy.c: avoid use uninitialized preferred_nodeYisheng Xie
[ Upstream commit 8970a63e965b43288c4f5f40efbc2bbf80de7f16 ] Alexander reported a use of uninitialized memory in __mpol_equal(), which is caused by incorrect use of preferred_node. When mempolicy in mode MPOL_PREFERRED with flags MPOL_F_LOCAL, it uses numa_node_id() instead of preferred_node, however, __mpol_equal() uses preferred_node without checking whether it is MPOL_F_LOCAL or not. [akpm@linux-foundation.org: slight comment tweak] Link: http://lkml.kernel.org/r/4ebee1c2-57f6-bcb8-0e2d-1833d1ee0bb7@huawei.com Fixes: fc36b8d3d819 ("mempolicy: use MPOL_F_LOCAL to Indicate Preferred Local Policy") Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com> Reported-by: Alexander Potapenko <glider@google.com> Tested-by: Alexander Potapenko <glider@google.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Dmitriy Vyukov <dvyukov@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm/fadvise: discard partial page if endbyte is also EOFshidao.ytt
[ Upstream commit a7ab400d6fe73d0119fdc234e9982a6f80faea9f ] During our recent testing with fadvise(FADV_DONTNEED), we find that if given offset/length is not page-aligned, the last page will not be discarded. The tool we use is vmtouch (https://hoytech.com/vmtouch/), we map a 10KB-sized file into memory and then try to run this tool to evict the whole file mapping, but the last single page always remains staying in the memory: $./vmtouch -e test_10K Files: 1 Directories: 0 Evicted Pages: 3 (12K) Elapsed: 2.1e-05 seconds $./vmtouch test_10K Files: 1 Directories: 0 Resident Pages: 1/3 4K/12K 33.3% Elapsed: 5.5e-05 seconds However when we test with an older kernel, say 3.10, this problem is gone. So we wonder if this is a regression: $./vmtouch -e test_10K Files: 1 Directories: 0 Evicted Pages: 3 (12K) Elapsed: 8.2e-05 seconds $./vmtouch test_10K Files: 1 Directories: 0 Resident Pages: 0/3 0/12K 0% <-- partial page also discarded Elapsed: 5e-05 seconds After digging a little bit into this problem, we find it seems not a regression. Not discarding partial page is likely to be on purpose according to commit 441c228f817f ("mm: fadvise: document the fadvise(FADV_DONTNEED) behaviour for partial pages") written by Mel Gorman. He explained why partial pages should be preserved instead of being discarded when using fadvise(FADV_DONTNEED). However, the interesting part is that the actual code did NOT work as the same as it was described, the partial page was still discarded anyway, due to a calculation mistake of `end_index' passed to invalidate_mapping_pages(). This mistake has not been fixed until recently, that's why we fail to reproduce our problem in old kernels. The fix is done in commit 18aba41cbf ("mm/fadvise.c: do not discard partial pages with POSIX_FADV_DONTNEED") by Oleg Drokin. Back to the original testing, our problem becomes that there is a special case that, if the page-unaligned `endbyte' is also the end of file, it is not necessary at all to preserve the last partial page, as we all know no one else will use the rest of it. It should be safe enough if we just discard the whole page. So we add an EOF check in this patch. We also find a poosbile real world issue in mainline kernel. Assume such scenario: A userspace backup application want to backup a huge amount of small files (<4k) at once, the developer might (I guess) want to use fadvise(FADV_DONTNEED) to save memory. However, FADV_DONTNEED won't really happen since the only page mapped is a partial page, and kernel will preserve it. Our patch also fixes this problem, since we know the endbyte is EOF, so we discard it. Here is a simple reproducer to reproduce and verify each scenario we described above: test_fadvise.c ============================== #include <sys/mman.h> #include <sys/stat.h> #include <fcntl.h> #include <stdlib.h> #include <string.h> #include <stdio.h> #include <unistd.h> int main(int argc, char **argv) { int i, fd, ret, len; struct stat buf; void *addr; unsigned char *vec; char *strbuf; ssize_t pagesize = getpagesize(); ssize_t filesize; fd = open(argv[1], O_RDWR|O_CREAT, S_IRUSR|S_IWUSR); if (fd < 0) return -1; filesize = strtoul(argv[2], NULL, 10); strbuf = malloc(filesize); memset(strbuf, 42, filesize); write(fd, strbuf, filesize); free(strbuf); fsync(fd); len = (filesize + pagesize - 1) / pagesize; printf("length of pages: %d\n", len); addr = mmap(NULL, filesize, PROT_READ, MAP_SHARED, fd, 0); if (addr == MAP_FAILED) return -1; ret = posix_fadvise(fd, 0, filesize, POSIX_FADV_DONTNEED); if (ret < 0) return -1; vec = malloc(len); ret = mincore(addr, filesize, (void *)vec); if (ret < 0) return -1; for (i = 0; i < len; i++) printf("pages[%d]: %x\n", i, vec[i] & 0x1); free(vec); close(fd); return 0; } ============================== Test 1: running on kernel with commit 18aba41cbf reverted: [root@caspar ~]# uname -r 4.15.0-rc6.revert+ [root@caspar ~]# ./test_fadvise file1 1024 length of pages: 1 pages[0]: 0 # <-- partial page discarded [root@caspar ~]# ./test_fadvise file2 8192 length of pages: 2 pages[0]: 0 pages[1]: 0 [root@caspar ~]# ./test_fadvise file3 10240 length of pages: 3 pages[0]: 0 pages[1]: 0 pages[2]: 0 # <-- partial page discarded Test 2: running on mainline kernel: [root@caspar ~]# uname -r 4.15.0-rc6+ [root@caspar ~]# ./test_fadvise test1 1024 length of pages: 1 pages[0]: 1 # <-- partial and the only page not discarded [root@caspar ~]# ./test_fadvise test2 8192 length of pages: 2 pages[0]: 0 pages[1]: 0 [root@caspar ~]# ./test_fadvise test3 10240 length of pages: 3 pages[0]: 0 pages[1]: 0 pages[2]: 1 # <-- partial page not discarded Test 3: running on kernel with this patch: [root@caspar ~]# uname -r 4.15.0-rc6.patched+ [root@caspar ~]# ./test_fadvise test1 1024 length of pages: 1 pages[0]: 0 # <-- partial page and EOF, discarded [root@caspar ~]# ./test_fadvise test2 8192 length of pages: 2 pages[0]: 0 pages[1]: 0 [root@caspar ~]# ./test_fadvise test3 10240 length of pages: 3 pages[0]: 0 pages[1]: 0 pages[2]: 0 # <-- partial page and EOF, discarded [akpm@linux-foundation.org: tweak code comment] Link: http://lkml.kernel.org/r/5222da9ee20e1695eaabb69f631f200d6e6b8876.1515132470.git.jinli.zjl@alibaba-inc.com Signed-off-by: shidao.ytt <shidao.ytt@alibaba-inc.com> Signed-off-by: Caspar Zhang <jinli.zjl@alibaba-inc.com> Reviewed-by: Oliver Yang <zhiche.yy@alibaba-inc.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm: pin address_space before dereferencing it while isolating an LRU pageMel Gorman
[ Upstream commit 69d763fc6d3aee787a3e8c8c35092b4f4960fa5d ] Minchan Kim asked the following question -- what locks protects address_space destroying when race happens between inode trauncation and __isolate_lru_page? Jan Kara clarified by describing the race as follows CPU1 CPU2 truncate(inode) __isolate_lru_page() ... truncate_inode_page(mapping, page); delete_from_page_cache(page) spin_lock_irqsave(&mapping->tree_lock, flags); __delete_from_page_cache(page, NULL) page_cache_tree_delete(..) ... mapping = page_mapping(page); page->mapping = NULL; ... spin_unlock_irqrestore(&mapping->tree_lock, flags); page_cache_free_page(mapping, page) put_page(page) if (put_page_testzero(page)) -> false - inode now has no pages and can be freed including embedded address_space if (mapping && !mapping->a_ops->migratepage) - we've dereferenced mapping which is potentially already free. The race is theoretically possible but unlikely. Before the delete_from_page_cache, truncate_cleanup_page is called so the page is likely to be !PageDirty or PageWriteback which gets skipped by the only caller that checks the mappping in __isolate_lru_page. Even if the race occurs, a substantial amount of work has to happen during a tiny window with no preemption but it could potentially be done using a virtual machine to artifically slow one CPU or halt it during the critical window. This patch should eliminate the race with truncation by try-locking the page before derefencing mapping and aborting if the lock was not acquired. There was a suggestion from Huang Ying to use RCU as a side-effect to prevent mapping being freed. However, I do not like the solution as it's an unconventional means of preserving a mapping and it's not a context where rcu_read_lock is obviously protecting rcu data. Link: http://lkml.kernel.org/r/20180104102512.2qos3h5vqzeisrek@techsingularity.net Fixes: c82449352854 ("mm: compaction: make isolate_lru_page() filter-aware again") Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Minchan Kim <minchan@kernel.org> Cc: "Huang, Ying" <ying.huang@intel.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm: thp: use down_read_trylock() in khugepaged to avoid long blockYang Shi
[ Upstream commit 3b454ad35043dfbd3b5d2bb92b0991d6342afb44 ] In the current design, khugepaged needs to acquire mmap_sem before scanning an mm. But in some corner cases, khugepaged may scan a process which is modifying its memory mapping, so khugepaged blocks in uninterruptible state. But the process might hold the mmap_sem for a long time when modifying a huge memory space and it may trigger the below khugepaged hung issue: INFO: task khugepaged:270 blocked for more than 120 seconds. Tainted: G E 4.9.65-006.ali3000.alios7.x86_64 #1 "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. khugepaged D 0 270 2 0x00000000  ffff883f3deae4c0 0000000000000000 ffff883f610596c0 ffff883f7d359440 ffff883f63818000 ffffc90019adfc78 ffffffff817079a5 d67e5aa8c1860a64 0000000000000246 ffff883f7d359440 ffffc90019adfc88 ffff883f610596c0 Call Trace: schedule+0x36/0x80 rwsem_down_read_failed+0xf0/0x150 call_rwsem_down_read_failed+0x18/0x30 down_read+0x20/0x40 khugepaged+0x476/0x11d0 kthread+0xe6/0x100 ret_from_fork+0x25/0x30 So it sounds pointless to just block khugepaged waiting for the semaphore so replace down_read() with down_read_trylock() to move to scan the next mm quickly instead of just blocking on the semaphore so that other processes can get more chances to install THP. Then khugepaged can come back to scan the skipped mm when it has finished the current round full_scan. And it appears that the change can improve khugepaged efficiency a little bit. Below is the test result when running LTP on a 24 cores 4GB memory 2 nodes NUMA VM: pristine w/ trylock full_scan 197 187 pages_collapsed 21 26 thp_fault_alloc 40818 44466 thp_fault_fallback 18413 16679 thp_collapse_alloc 21 150 thp_collapse_alloc_failed 14 16 thp_file_alloc 369 369 [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: tweak comment] [arnd@arndb.de: avoid uninitialized variable use] Link: http://lkml.kernel.org/r/20171215125129.2948634-1-arnd@arndb.de Link: http://lkml.kernel.org/r/1513281203-54878-1-git-send-email-yang.s@alibaba-inc.com Signed-off-by: Yang Shi <yang.s@alibaba-inc.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Hugh Dickins <hughd@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm/mempolicy: add nodes_empty check in SYSC_migrate_pagesYisheng Xie
[ Upstream commit 0486a38bcc4749808edbc848f1bcf232042770fc ] As in manpage of migrate_pages, the errno should be set to EINVAL when none of the node IDs specified by new_nodes are on-line and allowed by the process's current cpuset context, or none of the specified nodes contain memory. However, when test by following case: new_nodes = 0; old_nodes = 0xf; ret = migrate_pages(pid, old_nodes, new_nodes, MAX); The ret will be 0 and no errno is set. As the new_nodes is empty, we should expect EINVAL as documented. To fix the case like above, this patch check whether target nodes AND current task_nodes is empty, and then check whether AND node_states[N_MEMORY] is empty. Link: http://lkml.kernel.org/r/1510882624-44342-4-git-send-email-xieyisheng1@huawei.com Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andi Kleen <ak@linux.intel.com> Cc: Chris Salls <salls@cs.ucsb.edu> Cc: Christopher Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Tan Xiaojun <tanxiaojun@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm/mempolicy: fix the check of nodemask from userYisheng Xie
[ Upstream commit 56521e7a02b7b84a5e72691a1fb15570e6055545 ] As Xiaojun reported the ltp of migrate_pages01 will fail on arm64 system which has 4 nodes[0...3], all have memory and CONFIG_NODES_SHIFT=2: migrate_pages01 0 TINFO : test_invalid_nodes migrate_pages01 14 TFAIL : migrate_pages_common.c:45: unexpected failure - returned value = 0, expected: -1 migrate_pages01 15 TFAIL : migrate_pages_common.c:55: call succeeded unexpectedly In this case the test_invalid_nodes of migrate_pages01 will call: SYSC_migrate_pages as: migrate_pages(0, , {0x0000000000000001}, 64, , {0x0000000000000010}, 64) = 0 The new nodes specifies one or more node IDs that are greater than the maximum supported node ID, however, the errno is not set to EINVAL as expected. As man pages of set_mempolicy[1], mbind[2], and migrate_pages[3] mentioned, when nodemask specifies one or more node IDs that are greater than the maximum supported node ID, the errno should set to EINVAL. However, get_nodes only check whether the part of bits [BITS_PER_LONG*BITS_TO_LONGS(MAX_NUMNODES), maxnode) is zero or not, and remain [MAX_NUMNODES, BITS_PER_LONG*BITS_TO_LONGS(MAX_NUMNODES) unchecked. This patch is to check the bits of [MAX_NUMNODES, maxnode) in get_nodes to let migrate_pages set the errno to EINVAL when nodemask specifies one or more node IDs that are greater than the maximum supported node ID, which follows the manpage's guide. [1] http://man7.org/linux/man-pages/man2/set_mempolicy.2.html [2] http://man7.org/linux/man-pages/man2/mbind.2.html [3] http://man7.org/linux/man-pages/man2/migrate_pages.2.html Link: http://lkml.kernel.org/r/1510882624-44342-3-git-send-email-xieyisheng1@huawei.com Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com> Reported-by: Tan Xiaojun <tanxiaojun@huawei.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andi Kleen <ak@linux.intel.com> Cc: Chris Salls <salls@cs.ucsb.edu> Cc: Christopher Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30kasan: fix memory hotplug during bootDavid Hildenbrand
commit 3f1959721558a976aaf9c2024d5bc884e6411bf7 upstream. Using module_init() is wrong. E.g. ACPI adds and onlines memory before our memory notifier gets registered. This makes sure that ACPI memory detected during boot up will not result in a kernel crash. Easily reproducible with QEMU, just specify a DIMM when starting up. Link: http://lkml.kernel.org/r/20180522100756.18478-3-david@redhat.com Fixes: 786a8959912e ("kasan: disable memory hotplug") Signed-off-by: David Hildenbrand <david@redhat.com> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22mm: don't allow deferred pages with NEED_PER_CPU_KMPavel Tatashin
commit ab1e8d8960b68f54af42b6484b5950bd13a4054b upstream. It is unsafe to do virtual to physical translations before mm_init() is called if struct page is needed in order to determine the memory section number (see SECTION_IN_PAGE_FLAGS). This is because only in mm_init() we initialize struct pages for all the allocated memory when deferred struct pages are used. My recent fix in commit c9e97a1997 ("mm: initialize pages on demand during boot") exposed this problem, because it greatly reduced number of pages that are initialized before mm_init(), but the problem existed even before my fix, as Fengguang Wu found. Below is a more detailed explanation of the problem. We initialize struct pages in four places: 1. Early in boot a small set of struct pages is initialized to fill the first section, and lower zones. 2. During mm_init() we initialize "struct pages" for all the memory that is allocated, i.e reserved in memblock. 3. Using on-demand logic when pages are allocated after mm_init call (when memblock is finished) 4. After smp_init() when the rest free deferred pages are initialized. The problem occurs if we try to do va to phys translation of a memory between steps 1 and 2. Because we have not yet initialized struct pages for all the reserved pages, it is inherently unsafe to do va to phys if the translation itself requires access of "struct page" as in case of this combination: CONFIG_SPARSE && !CONFIG_SPARSE_VMEMMAP The following path exposes the problem: start_kernel() trap_init() setup_cpu_entry_areas() setup_cpu_entry_area(cpu) get_cpu_gdt_paddr(cpu) per_cpu_ptr_to_phys(addr) pcpu_addr_to_page(addr) virt_to_page(addr) pfn_to_page(__pa(addr) >> PAGE_SHIFT) We disable this path by not allowing NEED_PER_CPU_KM with deferred struct pages feature. The problems are discussed in these threads: http://lkml.kernel.org/r/20180418135300.inazvpxjxowogyge@wfg-t540p.sh.intel.com http://lkml.kernel.org/r/20180419013128.iurzouiqxvcnpbvz@wfg-t540p.sh.intel.com http://lkml.kernel.org/r/20180426202619.2768-1-pasha.tatashin@oracle.com Link: http://lkml.kernel.org/r/20180515175124.1770-1-pasha.tatashin@oracle.com Fixes: 3a80a7fa7989 ("mm: meminit: initialise a subset of struct pages if CONFIG_DEFERRED_STRUCT_PAGE_INIT is set") Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Steven Sistare <steven.sistare@oracle.com> Cc: Daniel Jordan <daniel.m.jordan@oracle.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Dennis Zhou <dennisszhou@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19proc: do not access cmdline nor environ from file-backed areasWilly Tarreau
commit 7f7ccc2ccc2e70c6054685f5e3522efa81556830 upstream. proc_pid_cmdline_read() and environ_read() directly access the target process' VM to retrieve the command line and environment. If this process remaps these areas onto a file via mmap(), the requesting process may experience various issues such as extra delays if the underlying device is slow to respond. Let's simply refuse to access file-backed areas in these functions. For this we add a new FOLL_ANON gup flag that is passed to all calls to access_remote_vm(). The code already takes care of such failures (including unmapped areas). Accesses via /proc/pid/mem were not changed though. This was assigned CVE-2018-1120. Note for stable backports: the patch may apply to kernels prior to 4.11 but silently miss one location; it must be checked that no call to access_remote_vm() keeps zero as the last argument. Reported-by: Qualys Security Advisory <qsa@qualys.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Oleg Nesterov <oleg@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-09percpu: include linux/sched.h for cond_resched()Tejun Heo
commit 71546d100422bcc2c543dadeb9328728997cd23a upstream. microblaze build broke due to missing declaration of the cond_resched() invocation added recently. Let's include linux/sched.h explicitly. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24writeback: safer lock nestingGreg Thelen
commit 2e898e4c0a3897ccd434adac5abb8330194f527b upstream. lock_page_memcg()/unlock_page_memcg() use spin_lock_irqsave/restore() if the page's memcg is undergoing move accounting, which occurs when a process leaves its memcg for a new one that has memory.move_charge_at_immigrate set. unlocked_inode_to_wb_begin,end() use spin_lock_irq/spin_unlock_irq() if the given inode is switching writeback domains. Switches occur when enough writes are issued from a new domain. This existing pattern is thus suspicious: lock_page_memcg(page); unlocked_inode_to_wb_begin(inode, &locked); ... unlocked_inode_to_wb_end(inode, locked); unlock_page_memcg(page); If both inode switch and process memcg migration are both in-flight then unlocked_inode_to_wb_end() will unconditionally enable interrupts while still holding the lock_page_memcg() irq spinlock. This suggests the possibility of deadlock if an interrupt occurs before unlock_page_memcg(). truncate __cancel_dirty_page lock_page_memcg unlocked_inode_to_wb_begin unlocked_inode_to_wb_end <interrupts mistakenly enabled> <interrupt> end_page_writeback test_clear_page_writeback lock_page_memcg <deadlock> unlock_page_memcg Due to configuration limitations this deadlock is not currently possible because we don't mix cgroup writeback (a cgroupv2 feature) and memory.move_charge_at_immigrate (a cgroupv1 feature). If the kernel is hacked to always claim inode switching and memcg moving_account, then this script triggers lockup in less than a minute: cd /mnt/cgroup/memory mkdir a b echo 1 > a/memory.move_charge_at_immigrate echo 1 > b/memory.move_charge_at_immigrate ( echo $BASHPID > a/cgroup.procs while true; do dd if=/dev/zero of=/mnt/big bs=1M count=256 done ) & while true; do sync done & sleep 1h & SLEEP=$! while true; do echo $SLEEP > a/cgroup.procs echo $SLEEP > b/cgroup.procs done The deadlock does not seem possible, so it's debatable if there's any reason to modify the kernel. I suggest we should to prevent future surprises. And Wang Long said "this deadlock occurs three times in our environment", so there's more reason to apply this, even to stable. Stable 4.4 has minor conflicts applying this patch. For a clean 4.4 patch see "[PATCH for-4.4] writeback: safer lock nesting" https://lkml.org/lkml/2018/4/11/146 Wang Long said "this deadlock occurs three times in our environment" [gthelen@google.com: v4] Link: http://lkml.kernel.org/r/20180411084653.254724-1-gthelen@google.com [akpm@linux-foundation.org: comment tweaks, struct initialization simplification] Change-Id: Ibb773e8045852978f6207074491d262f1b3fb613 Link: http://lkml.kernel.org/r/20180410005908.167976-1-gthelen@google.com Fixes: 682aa8e1a6a1 ("writeback: implement unlocked_inode_to_wb transaction and use it for stat updates") Signed-off-by: Greg Thelen <gthelen@google.com> Reported-by: Wang Long <wanglong19@meituan.com> Acked-by: Wang Long <wanglong19@meituan.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: <stable@vger.kernel.org> [v4.2+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [natechancellor: Adjust context due to lack of b93b016313b3b] Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24mm/filemap.c: fix NULL pointer in page_cache_tree_insert()Matthew Wilcox
commit abc1be13fd113ddef5e2d807a466286b864caed3 upstream. f2fs specifies the __GFP_ZERO flag for allocating some of its pages. Unfortunately, the page cache also uses the mapping's GFP flags for allocating radix tree nodes. It always masked off the __GFP_HIGHMEM flag, and masks off __GFP_ZERO in some paths, but not all. That causes radix tree nodes to be allocated with a NULL list_head, which causes backtraces like: __list_del_entry+0x30/0xd0 list_lru_del+0xac/0x1ac page_cache_tree_insert+0xd8/0x110 The __GFP_DMA and __GFP_DMA32 flags would also be able to sneak through if they are ever used. Fix them all by using GFP_RECLAIM_MASK at the innermost location, and remove it from earlier in the callchain. Link: http://lkml.kernel.org/r/20180411060320.14458-2-willy@infradead.org Fixes: 449dd6984d0e ("mm: keep page cache radix tree nodes in check") Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com> Reported-by: Chris Fries <cfries@google.com> Debugged-by: Minchan Kim <minchan@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24mm, slab: reschedule cache_reap() on the same CPUVlastimil Babka
commit a9f2a846f0503e7d729f552e3ccfe2279010fe94 upstream. cache_reap() is initially scheduled in start_cpu_timer() via schedule_delayed_work_on(). But then the next iterations are scheduled via schedule_delayed_work(), i.e. using WORK_CPU_UNBOUND. Thus since commit ef557180447f ("workqueue: schedule WORK_CPU_UNBOUND work on wq_unbound_cpumask CPUs") there is no guarantee the future iterations will run on the originally intended cpu, although it's still preferred. I was able to demonstrate this with /sys/module/workqueue/parameters/debug_force_rr_cpu. IIUC, it may also happen due to migrating timers in nohz context. As a result, some cpu's would be calling cache_reap() more frequently and others never. This patch uses schedule_delayed_work_on() with the current cpu when scheduling the next iteration. Link: http://lkml.kernel.org/r/20180411070007.32225-1-vbabka@suse.cz Fixes: ef557180447f ("workqueue: schedule WORK_CPU_UNBOUND work on wq_unbound_cpumask CPUs") Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Pekka Enberg <penberg@kernel.org> Acked-by: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Lai Jiangshan <jiangshanlai@gmail.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Stephen Boyd <sboyd@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13mm, vmstat: Remove spurious WARN() during zoneinfo printReza Arbab
[ Upstream commit 8d35bb310698c69d73073b26fc581f2e3f7f621d ] After commit e2ecc8a79ed4 ("mm, vmstat: print non-populated zones in zoneinfo"), /proc/zoneinfo will show unpopulated zones. A memoryless node, having no populated zones at all, was previously ignored, but will now trigger the WARN() in is_zone_first_populated(). Remove this warning, as its only purpose was to warn of a situation that has since been enabled. Aside: The "per-node stats" are still printed under the first populated zone, but that's not necessarily the first stanza any more. I'm not sure which criteria is more important with regard to not breaking parsers, but it looks a little weird to the eye. Fixes: e2ecc8a79ed4 ("mm, vmstat: print node-based stats in zoneinfo file") Link: http://lkml.kernel.org/r/1493854905-10918-1-git-send-email-arbab@linux.vnet.ibm.com Signed-off-by: Reza Arbab <arbab@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08mm/vmscan.c: fix unsequenced modification and access warningNick Desaulniers
commit f2f43e566a02a3bdde0a65e6a2e88d707c212a29 upstream. Clang and its -Wunsequenced emits a warning mm/vmscan.c:2961:25: error: unsequenced modification and access to 'gfp_mask' [-Wunsequenced] .gfp_mask = (gfp_mask = current_gfp_context(gfp_mask)), ^ While it is not clear to me whether the initialization code violates the specification (6.7.8 par 19 (ISO/IEC 9899) looks like it disagrees) the code is quite confusing and worth cleaning up anyway. Fix this by reusing sc.gfp_mask rather than the updated input gfp_mask parameter. Link: http://lkml.kernel.org/r/20170510154030.10720-1-nick.desaulniers@gmail.com Signed-off-by: Nick Desaulniers <nick.desaulniers@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [natechancellor: Adjust context due to abscence of 7dea19f9ee63] Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28mm/shmem: do not wait for lock_page() in shmem_unused_huge_shrink()Kirill A. Shutemov
commit b3cd54b257ad95d344d121dc563d943ca39b0921 upstream. shmem_unused_huge_shrink() gets called from reclaim path. Waiting for page lock may lead to deadlock there. There was a bug report that may be attributed to this: http://lkml.kernel.org/r/alpine.LRH.2.11.1801242349220.30642@mail.ewheeler.net Replace lock_page() with trylock_page() and skip the page if we failed to lock it. We will get to the page on the next scan. We can test for the PageTransHuge() outside the page lock as we only need protection against splitting the page under us. Holding pin oni the page is enough for this. Link: http://lkml.kernel.org/r/20180316210830.43738-1-kirill.shutemov@linux.intel.com Fixes: 779750d20b93 ("shmem: split huge pages beyond i_size under memory pressure") Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Eric Wheeler <linux-mm@lists.ewheeler.net> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28mm/thp: do not wait for lock_page() in deferred_split_scan()Kirill A. Shutemov
commit fa41b900c30b45fab03783724932dc30cd46a6be upstream. deferred_split_scan() gets called from reclaim path. Waiting for page lock may lead to deadlock there. Replace lock_page() with trylock_page() and skip the page if we failed to lock it. We will get to the page on the next scan. Link: http://lkml.kernel.org/r/20180315150747.31945-1-kirill.shutemov@linux.intel.com Fixes: 9a982250f773 ("thp: introduce deferred_split_huge_page()") Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28mm/khugepaged.c: convert VM_BUG_ON() to collapse failKirill A. Shutemov
commit fece2029a9e65b9a990831afe2a2b83290cbbe26 upstream. khugepaged is not yet able to convert PTE-mapped huge pages back to PMD mapped. We do not collapse such pages. See check khugepaged_scan_pmd(). But if between khugepaged_scan_pmd() and __collapse_huge_page_isolate() somebody managed to instantiate THP in the range and then split the PMD back to PTEs we would have a problem -- VM_BUG_ON_PAGE(PageCompound(page)) will get triggered. It's possible since we drop mmap_sem during collapse to re-take for write. Replace the VM_BUG_ON() with graceful collapse fail. Link: http://lkml.kernel.org/r/20180315152353.27989-1-kirill.shutemov@linux.intel.com Fixes: b1caa957ae6d ("khugepaged: ignore pmd tables with THP mapped with ptes") Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Laura Abbott <labbott@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24mm: hwpoison: call shake_page() after try_to_unmap() for mlocked pageNaoya Horiguchi
[ Upstream commit 286c469a988fbaf68e3a97ddf1e6c245c1446968 ] Memory error handler calls try_to_unmap() for error pages in various states. If the error page is a mlocked page, error handling could fail with "still referenced by 1 users" message. This is because the page is linked to and stays in lru cache after the following call chain. try_to_unmap_one page_remove_rmap clear_page_mlock putback_lru_page lru_cache_add memory_failure() calls shake_page() to hanlde the similar issue, but current code doesn't cover because shake_page() is called only before try_to_unmap(). So this patches adds shake_page(). Fixes: 23a003bfd23ea9ea0b7756b920e51f64b284b468 ("mm/madvise: pass return code of memory_failure() to userspace") Link: http://lkml.kernel.org/r/20170417055948.GM31394@yexl-desktop Link: http://lkml.kernel.org/r/1493197841-23986-3-git-send-email-n-horiguchi@ah.jp.nec.com Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: kernel test robot <lkp@intel.com> Cc: Xiaolong Ye <xiaolong.ye@intel.com> Cc: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24mm, vmstat: suppress pcp stats for unpopulated zones in zoneinfoDavid Rientjes
[ Upstream commit 7dfb8bf3b9caef4049bee51d2c22e1c3a311d483 ] After "mm, vmstat: print non-populated zones in zoneinfo", /proc/zoneinfo will show unpopulated zones. The per-cpu pageset statistics are not relevant for unpopulated zones and can be potentially lengthy, so supress them when they are not interesting. Also moves lowmem reserve protection information above pcp stats since it is relevant for all zones per vm.lowmem_reserve_ratio. Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1703061400500.46428@chino.kir.corp.google.com Signed-off-by: David Rientjes <rientjes@google.com> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24mm: fix check for reclaimable pages in PF_MEMALLOC reclaim throttlingJohannes Weiner
[ Upstream commit d450abd81b081d45adb12f303a07dd44b15eb1bc ] PF_MEMALLOC direct reclaimers get throttled on a node when the sum of all free pages in each zone fall below half the min watermark. During the summation, we want to exclude zones that don't have reclaimables. Checking the same pgdat over and over again doesn't make sense. Fixes: 599d0c954f91 ("mm, vmscan: move LRU lists to node") Link: http://lkml.kernel.org/r/20170228214007.5621-3-hannes@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Jia He <hejianet@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28mm: fail get_vaddr_frames() for filesystem-dax mappingsDan Williams
commit b7f0554a56f21fb3e636a627450a9add030889be upstream. Until there is a solution to the dma-to-dax vs truncate problem it is not safe to allow V4L2, Exynos, and other frame vector users to create long standing / irrevocable memory registrations against filesytem-dax vmas. [dan.j.williams@intel.com: add comment for vma_is_fsdax() check in get_vaddr_frames(), per Jan] Link: http://lkml.kernel.org/r/151197874035.26211.4061781453123083667.stgit@dwillia2-desk3.amr.corp.intel.com Link: http://lkml.kernel.org/r/151068939985.7446.15684639617389154187.stgit@dwillia2-desk3.amr.corp.intel.com Fixes: 3565fce3a659 ("mm, x86: get_user_pages() for dax mappings") Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Inki Dae <inki.dae@samsung.com> Cc: Seung-Woo Kim <sw0312.kim@samsung.com> Cc: Joonyoung Shim <jy0922.shim@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Cc: Doug Ledford <dledford@redhat.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: Jason Gunthorpe <jgg@mellanox.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28mm: introduce get_user_pages_longtermDan Williams
commit 2bb6d2837083de722bfdc369cb0d76ce188dd9b4 upstream. Patch series "introduce get_user_pages_longterm()", v2. Here is a new get_user_pages api for cases where a driver intends to keep an elevated page count indefinitely. This is distinct from usages like iov_iter_get_pages where the elevated page counts are transient. The iov_iter_get_pages cases immediately turn around and submit the pages to a device driver which will put_page when the i/o operation completes (under kernel control). In the longterm case userspace is responsible for dropping the page reference at some undefined point in the future. This is untenable for filesystem-dax case where the filesystem is in control of the lifetime of the block / page and needs reasonable limits on how long it can wait for pages in a mapping to become idle. Fixing filesystems to actually wait for dax pages to be idle before blocks from a truncate/hole-punch operation are repurposed is saved for a later patch series. Also, allowing longterm registration of dax mappings is a future patch series that introduces a "map with lease" semantic where the kernel can revoke a lease and force userspace to drop its page references. I have also tagged these for -stable to purposely break cases that might assume that longterm memory registrations for filesystem-dax mappings were supported by the kernel. The behavior regression this policy change implies is one of the reasons we maintain the "dax enabled. Warning: EXPERIMENTAL, use at your own risk" notification when mounting a filesystem in dax mode. It is worth noting the device-dax interface does not suffer the same constraints since it does not support file space management operations like hole-punch. This patch (of 4): Until there is a solution to the dma-to-dax vs truncate problem it is not safe to allow long standing memory registrations against filesytem-dax vmas. Device-dax vmas do not have this problem and are explicitly allowed. This is temporary until a "memory registration with layout-lease" mechanism can be implemented for the affected sub-systems (RDMA and V4L2). [akpm@linux-foundation.org: use kcalloc()] Link: http://lkml.kernel.org/r/151068939435.7446.13560129395419350737.stgit@dwillia2-desk3.amr.corp.intel.com Fixes: 3565fce3a659 ("mm, x86: get_user_pages() for dax mappings") Signed-off-by: Dan Williams <dan.j.williams@intel.com> Suggested-by: Christoph Hellwig <hch@lst.de> Cc: Doug Ledford <dledford@redhat.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: Inki Dae <inki.dae@samsung.com> Cc: Jan Kara <jack@suse.cz> Cc: Jason Gunthorpe <jgg@mellanox.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Joonyoung Shim <jy0922.shim@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Seung-Woo Kim <sw0312.kim@samsung.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28mm: avoid spurious 'bad pmd' warning messagesRoss Zwisler
commit d0f0931de936a0a468d7e59284d39581c16d3a73 upstream. When the pmd_devmap() checks were added by 5c7fb56e5e3f ("mm, dax: dax-pmd vs thp-pmd vs hugetlbfs-pmd") to add better support for DAX huge pages, they were all added to the end of if() statements after existing pmd_trans_huge() checks. So, things like: - if (pmd_trans_huge(*pmd)) + if (pmd_trans_huge(*pmd) || pmd_devmap(*pmd)) When further checks were added after pmd_trans_unstable() checks by commit 7267ec008b5c ("mm: postpone page table allocation until we have page to map") they were also added at the end of the conditional: + if (pmd_trans_unstable(fe->pmd) || pmd_devmap(*fe->pmd)) This ordering is fine for pmd_trans_huge(), but doesn't work for pmd_trans_unstable(). This is because DAX huge pages trip the bad_pmd() check inside of pmd_none_or_trans_huge_or_clear_bad() (called by pmd_trans_unstable()), which prints out a warning and returns 1. So, we do end up doing the right thing, but only after spamming dmesg with suspicious looking messages: mm/pgtable-generic.c:39: bad pmd ffff8808daa49b88(84000001006000a5) Reorder these checks in a helper so that pmd_devmap() is checked first, avoiding the error messages, and add a comment explaining why the ordering is important. Fixes: commit 7267ec008b5c ("mm: postpone page table allocation until we have page to map") Link: http://lkml.kernel.org/r/20170522215749.23516-1-ross.zwisler@linux.intel.com Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Pawel Lebioda <pawel.lebioda@intel.com> Cc: "Darrick J. Wong" <darrick.wong@oracle.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Matthew Wilcox <mawilcox@microsoft.com> Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Xiong Zhou <xzhou@redhat.com> Cc: Eryu Guan <eguan@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25shmem: fix compilation warnings on unused functionsJérémy Lefaure
commit f1f5929cd9715c1cdfe07a890f12ac7d2c5304ec upstream. Compiling shmem.c with SHMEM and TRANSAPRENT_HUGE_PAGECACHE enabled raises warnings on two unused functions when CONFIG_TMPFS and CONFIG_SYSFS are both disabled: mm/shmem.c:390:20: warning: `shmem_format_huge' defined but not used [-Wunused-function] static const char *shmem_format_huge(int huge) ^~~~~~~~~~~~~~~~~ mm/shmem.c:373:12: warning: `shmem_parse_huge' defined but not used [-Wunused-function] static int shmem_parse_huge(const char *str) ^~~~~~~~~~~~~~~~ A conditional compilation on tmpfs or sysfs removes the warnings. Link: http://lkml.kernel.org/r/20161118055749.11313-1-jeremy.lefaure@lse.epita.fr Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25shmem: avoid maybe-uninitialized warningArnd Bergmann
commit 23f919d4ad0eb325595f10f55be4301b2965d6d6 upstream. After enabling -Wmaybe-uninitialized warnings, we get a false-postive warning for shmem: mm/shmem.c: In function `shmem_getpage_gfp': include/linux/spinlock.h:332:21: error: `info' may be used uninitialized in this function [-Werror=maybe-uninitialized] This can be easily avoided, since the correct 'info' pointer is known at the time we first enter the function, so we can simply move the initialization up. Moving it before the first label avoids the warning and lets us remove two later initializations. Note that the function is so hard to read that it not only confuses the compiler, but also most readers and without this patch it could\ easily break if one of the 'goto's changed. Link: https://www.spinics.net/lists/kernel/msg2368133.html Link: http://lkml.kernel.org/r/20161024205725.786455-1-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25mm/early_ioremap: Fix boot hang with earlyprintk=efi,keepDave Young
[ Upstream commit 7f6f60a1ba52538c16f26930bfbcfe193d9d746a ] earlyprintk=efi,keep does not work any more with a warning in mm/early_ioremap.c: WARN_ON(system_state != SYSTEM_BOOTING): Boot just hangs because of the earlyprintk within the earlyprintk implementation code itself. This is caused by a new introduced middle state in: 69a78ff226fe ("init: Introduce SYSTEM_SCHEDULING state") early_ioremap() is fine in both SYSTEM_BOOTING and SYSTEM_SCHEDULING states, original condition should be updated accordingly. Signed-off-by: Dave Young <dyoung@redhat.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: bp@suse.de Cc: linux-efi@vger.kernel.org Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20171209041610.GA3249@dhcp-128-65.nay.redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25Provide a function to create a NUL-terminated string from unterminated dataDavid Howells
commit f35157417215ec138c920320c746fdb3e04ef1d5 upstream. Provide a function, kmemdup_nul(), that will create a NUL-terminated string from an unterminated character array where the length is known in advance. This is better than kstrndup() in situations where we already know the string length as the strnlen() in kstrndup() is superfluous. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25mm,vmscan: Make unregister_shrinker() no-op if register_shrinker() failed.Tetsuo Handa
commit bb422a738f6566f7439cd347d54e321e4fe92a9f upstream. Syzbot caught an oops at unregister_shrinker() because combination of commit 1d3d4437eae1bb29 ("vmscan: per-node deferred work") and fault injection made register_shrinker() fail and the caller of register_shrinker() did not check for failure. ---------- [ 554.881422] FAULT_INJECTION: forcing a failure. [ 554.881422] name failslab, interval 1, probability 0, space 0, times 0 [ 554.881438] CPU: 1 PID: 13231 Comm: syz-executor1 Not tainted 4.14.0-rc8+ #82 [ 554.881443] Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 [ 554.881445] Call Trace: [ 554.881459] dump_stack+0x194/0x257 [ 554.881474] ? arch_local_irq_restore+0x53/0x53 [ 554.881486] ? find_held_lock+0x35/0x1d0 [ 554.881507] should_fail+0x8c0/0xa40 [ 554.881522] ? fault_create_debugfs_attr+0x1f0/0x1f0 [ 554.881537] ? check_noncircular+0x20/0x20 [ 554.881546] ? find_next_zero_bit+0x2c/0x40 [ 554.881560] ? ida_get_new_above+0x421/0x9d0 [ 554.881577] ? find_held_lock+0x35/0x1d0 [ 554.881594] ? __lock_is_held+0xb6/0x140 [ 554.881628] ? check_same_owner+0x320/0x320 [ 554.881634] ? lock_downgrade+0x990/0x990 [ 554.881649] ? find_held_lock+0x35/0x1d0 [ 554.881672] should_failslab+0xec/0x120 [ 554.881684] __kmalloc+0x63/0x760 [ 554.881692] ? lock_downgrade+0x990/0x990 [ 554.881712] ? register_shrinker+0x10e/0x2d0 [ 554.881721] ? trace_event_raw_event_module_request+0x320/0x320 [ 554.881737] register_shrinker+0x10e/0x2d0 [ 554.881747] ? prepare_kswapd_sleep+0x1f0/0x1f0 [ 554.881755] ? _down_write_nest_lock+0x120/0x120 [ 554.881765] ? memcpy+0x45/0x50 [ 554.881785] sget_userns+0xbcd/0xe20 (...snipped...) [ 554.898693] kasan: CONFIG_KASAN_INLINE enabled [ 554.898724] kasan: GPF could be caused by NULL-ptr deref or user memory access [ 554.898732] general protection fault: 0000 [#1] SMP KASAN [ 554.898737] Dumping ftrace buffer: [ 554.898741] (ftrace buffer empty) [ 554.898743] Modules linked in: [ 554.898752] CPU: 1 PID: 13231 Comm: syz-executor1 Not tainted 4.14.0-rc8+ #82 [ 554.898755] Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 [ 554.898760] task: ffff8801d1dbe5c0 task.stack: ffff8801c9e38000 [ 554.898772] RIP: 0010:__list_del_entry_valid+0x7e/0x150 [ 554.898775] RSP: 0018:ffff8801c9e3f108 EFLAGS: 00010246 [ 554.898780] RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 0000000000000000 [ 554.898784] RDX: 0000000000000000 RSI: ffff8801c53c6f98 RDI: ffff8801c53c6fa0 [ 554.898788] RBP: ffff8801c9e3f120 R08: 1ffff100393c7d55 R09: 0000000000000004 [ 554.898791] R10: ffff8801c9e3ef70 R11: 0000000000000000 R12: 0000000000000000 [ 554.898795] R13: dffffc0000000000 R14: 1ffff100393c7e45 R15: ffff8801c53c6f98 [ 554.898800] FS: 0000000000000000(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000 [ 554.898804] CS: 0010 DS: 002b ES: 002b CR0: 0000000080050033 [ 554.898807] CR2: 00000000dbc23000 CR3: 00000001c7269000 CR4: 00000000001406e0 [ 554.898813] DR0: 0000000020000000 DR1: 0000000020000000 DR2: 0000000000000000 [ 554.898816] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600 [ 554.898818] Call Trace: [ 554.898828] unregister_shrinker+0x79/0x300 [ 554.898837] ? perf_trace_mm_vmscan_writepage+0x750/0x750 [ 554.898844] ? down_write+0x87/0x120 [ 554.898851] ? deactivate_super+0x139/0x1b0 [ 554.898857] ? down_read+0x150/0x150 [ 554.898864] ? check_same_owner+0x320/0x320 [ 554.898875] deactivate_locked_super+0x64/0xd0 [ 554.898883] deactivate_super+0x141/0x1b0 ---------- Since allowing register_shrinker() callers to call unregister_shrinker() when register_shrinker() failed can simplify error recovery path, this patch makes unregister_shrinker() no-op when register_shrinker() failed. Also, reset shrinker->nr_deferred in case unregister_shrinker() was by error called twice. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Aliaksei Karaliou <akaraliou.dev@gmail.com> Reported-by: syzbot <syzkaller@googlegroups.com> Cc: Glauber Costa <glauber@scylladb.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22mm: hide a #warning for COMPILE_TESTArnd Bergmann
commit af27d9403f5b80685b79c88425086edccecaf711 upstream. We get a warning about some slow configurations in randconfig kernels: mm/memory.c:83:2: error: #warning Unfortunate NUMA and NUMA Balancing config, growing page-frame for last_cpupid. [-Werror=cpp] The warning is reasonable by itself, but gets in the way of randconfig build testing, so I'm hiding it whenever CONFIG_COMPILE_TEST is set. The warning was added in 2013 in commit 75980e97dacc ("mm: fold page->_last_nid into page->flags where possible"). Cc: stable@vger.kernel.org Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03kmemleak: add scheduling point to kmemleak_scan()Yisheng Xie
[ Upstream commit bde5f6bc68db51128f875a756e9082a6c6ff7b4c ] kmemleak_scan() will scan struct page for each node and it can be really large and resulting in a soft lockup. We have seen a soft lockup when do scan while compile kernel: watchdog: BUG: soft lockup - CPU#53 stuck for 22s! [bash:10287] [...] Call Trace: kmemleak_scan+0x21a/0x4c0 kmemleak_write+0x312/0x350 full_proxy_write+0x5a/0xa0 __vfs_write+0x33/0x150 vfs_write+0xad/0x1a0 SyS_write+0x52/0xc0 do_syscall_64+0x61/0x1a0 entry_SYSCALL64_slow_path+0x25/0x25 Fix this by adding cond_resched every MAX_SCAN_SIZE. Link: http://lkml.kernel.org/r/1511439788-20099-1-git-send-email-xieyisheng1@huawei.com Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com> Suggested-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31mm: fix 100% CPU kswapd busyloop on unreclaimable nodesJohannes Weiner
commit c73322d098e4b6f5f0f0fa1330bf57e218775539 upstream. Patch series "mm: kswapd spinning on unreclaimable nodes - fixes and cleanups". Jia reported a scenario in which the kswapd of a node indefinitely spins at 100% CPU usage. We have seen similar cases at Facebook. The kernel's current method of judging its ability to reclaim a node (or whether to back off and sleep) is based on the amount of scanned pages in proportion to the amount of reclaimable pages. In Jia's and our scenarios, there are no reclaimable pages in the node, however, and the condition for backing off is never met. Kswapd busyloops in an attempt to restore the watermarks while having nothing to work with. This series reworks the definition of an unreclaimable node based not on scanning but on whether kswapd is able to actually reclaim pages in MAX_RECLAIM_RETRIES (16) consecutive runs. This is the same criteria the page allocator uses for giving up on direct reclaim and invoking the OOM killer. If it cannot free any pages, kswapd will go to sleep and leave further attempts to direct reclaim invocations, which will either make progress and re-enable kswapd, or invoke the OOM killer. Patch #1 fixes the immediate problem Jia reported, the remainder are smaller fixlets, cleanups, and overall phasing out of the old method. Patch #6 is the odd one out. It's a nice cleanup to get_scan_count(), and directly related to #5, but in itself not relevant to the series. If the whole series is too ambitious for 4.11, I would consider the first three patches fixes, the rest cleanups. This patch (of 9): Jia He reports a problem with kswapd spinning at 100% CPU when requesting more hugepages than memory available in the system: $ echo 4000 >/proc/sys/vm/nr_hugepages top - 13:42:59 up 3:37, 1 user, load average: 1.09, 1.03, 1.01 Tasks: 1 total, 1 running, 0 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 12.5 sy, 0.0 ni, 85.5 id, 2.0 wa, 0.0 hi, 0.0 si, 0.0 st KiB Mem: 31371520 total, 30915136 used, 456384 free, 320 buffers KiB Swap: 6284224 total, 115712 used, 6168512 free. 48192 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 76 root 20 0 0 0 0 R 100.0 0.000 217:17.29 kswapd3 At that time, there are no reclaimable pages left in the node, but as kswapd fails to restore the high watermarks it refuses to go to sleep. Kswapd needs to back away from nodes that fail to balance. Up until commit 1d82de618ddd ("mm, vmscan: make kswapd reclaim in terms of nodes") kswapd had such a mechanism. It considered zones whose theoretically reclaimable pages it had reclaimed six times over as unreclaimable and backed away from them. This guard was erroneously removed as the patch changed the definition of a balanced node. However, simply restoring this code wouldn't help in the case reported here: there *are* no reclaimable pages that could be scanned until the threshold is met. Kswapd would stay awake anyway. Introduce a new and much simpler way of backing off. If kswapd runs through MAX_RECLAIM_RETRIES (16) cycles without reclaiming a single page, make it back off from the node. This is the same number of shots direct reclaim takes before declaring OOM. Kswapd will go to sleep on that node until a direct reclaimer manages to reclaim some pages, thus proving the node reclaimable again. [hannes@cmpxchg.org: check kswapd failure against the cumulative nr_reclaimed count] Link: http://lkml.kernel.org/r/20170306162410.GB2090@cmpxchg.org [shakeelb@google.com: fix condition for throttle_direct_reclaim] Link: http://lkml.kernel.org/r/20170314183228.20152-1-shakeelb@google.com Link: http://lkml.kernel.org/r/20170228214007.5621-2-hannes@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Shakeel Butt <shakeelb@google.com> Reported-by: Jia He <hejianet@gmail.com> Tested-by: Jia He <hejianet@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Dmitry Shmidt <dimitrysh@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31mm, page_alloc: fix potential false positive in __zone_watermark_okVlastimil Babka
commit b050e3769c6b4013bb937e879fc43bf1847ee819 upstream. Since commit 97a16fc82a7c ("mm, page_alloc: only enforce watermarks for order-0 allocations"), __zone_watermark_ok() check for high-order allocations will shortcut per-migratetype free list checks for ALLOC_HARDER allocations, and return true as long as there's free page of any migratetype. The intention is that ALLOC_HARDER can allocate from MIGRATE_HIGHATOMIC free lists, while normal allocations can't. However, as a side effect, the watermark check will then also return true when there are pages only on the MIGRATE_ISOLATE list, or (prior to CMA conversion to ZONE_MOVABLE) on the MIGRATE_CMA list. Since the allocation cannot actually obtain isolated pages, and might not be able to obtain CMA pages, this can result in a false positive. The condition should be rare and perhaps the outcome is not a fatal one. Still, it's better if the watermark check is correct. There also shouldn't be a performance tradeoff here. Link: http://lkml.kernel.org/r/20171102125001.23708-1-vbabka@suse.cz Fixes: 97a16fc82a7c ("mm, page_alloc: only enforce watermarks for order-0 allocations") Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31cma: fix calculation of aligned offsetDoug Berger
commit e048cb32f69038aa1c8f11e5c1b331be4181659d upstream. The align_offset parameter is used by bitmap_find_next_zero_area_off() to represent the offset of map's base from the previous alignment boundary; the function ensures that the returned index, plus the align_offset, honors the specified align_mask. The logic introduced by commit b5be83e308f7 ("mm: cma: align to physical address, not CMA region position") has the cma driver calculate the offset to the *next* alignment boundary. In most cases, the base alignment is greater than that specified when making allocations, resulting in a zero offset whether we align up or down. In the example given with the commit, the base alignment (8MB) was half the requested alignment (16MB) so the math also happened to work since the offset is 8MB in both directions. However, when requesting allocations with an alignment greater than twice that of the base, the returned index would not be correctly aligned. Also, the align_order arguments of cma_bitmap_aligned_mask() and cma_bitmap_aligned_offset() should not be negative so the argument type was made unsigned. Fixes: b5be83e308f7 ("mm: cma: align to physical address, not CMA region position") Link: http://lkml.kernel.org/r/20170628170742.2895-1-opendmb@gmail.com Signed-off-by: Angus Clark <angus@angusclark.org> Signed-off-by: Doug Berger <opendmb@gmail.com> Acked-by: Gregory Fong <gregory.0xf0@gmail.com> Cc: Doug Berger <opendmb@gmail.com> Cc: Angus Clark <angus@angusclark.org> Cc: Laura Abbott <labbott@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Lucas Stach <l.stach@pengutronix.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Shiraz Hashim <shashim@codeaurora.org> Cc: Jaewon Kim <jaewon31.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
