commit f5e03a4989e80a86f8b514659dca8539132e6e09 upstream.
It has been reported that 965GM might trigger
VM_BUG_ON_PAGE(!lrucare && PageLRU(oldpage), oldpage)
in mem_cgroup_migrate when shmem wants to replace a swap cache page
because of shmem_should_replace_page (the page is allocated from an
inappropriate zone). shmem_replace_page expects that the oldpage is not
on LRU list and calls mem_cgroup_migrate without lrucare. This is
obviously incorrect because swapcache pages might be on the LRU list
(e.g. swapin readahead page).
Fix this by enabling lrucare for the migration in shmem_replace_page.
Also clarify that lrucare should be used even if one of the pages might
be on LRU list.
The BUG_ON will trigger only when CONFIG_DEBUG_VM is enabled but even
without that the migration code might leave the old page on an
inappropriate memcg' LRU which is not that critical because the page
would get removed with its last reference but it is still confusing.
Fixes: 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API")
Reported-by: Chris Wilson <chris@chris-wilson.co.uk>
Reported-by: Dave Airlie <airlied@gmail.com>
commit 23aaed6659df9adfabe9c583e67a36b54e21df46 upstream.
walk_page_range() silently skips vma having VM_PFNMAP set, which leads
to undesirable behaviour at client end (who called walk_page_range).
Userspace applications get the wrong data, so the effect is like just
confusing users (if the applications just display the data) or sometimes
killing the processes (if the applications do something with
misunderstanding virtual addresses due to the wrong data.)
For example for pagemap_read, when no callbacks are called against
VM_PFNMAP vma, pagemap_read may prepare pagemap data for next virtual
address range at wrong index.
Eventually userspace may get wrong pagemap data for a task.
Corresponding to a VM_PFNMAP marked vma region, kernel may report
mappings from subsequent vma regions. User space in turn may account
more pages (than really are) to the task.
In my case I was using procmem, procrack (Android utility) which uses
pagemap interface to account RSS pages of a task. Due to this bug it
was giving a wrong picture for vmas (with VM_PFNMAP set).
Fixes: a9ff785e4437 ("mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas")
Signed-off-by: Shiraz Hashim <shashim@codeaurora.org>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 0346dadbf041a2606bcb5bd27828b0d105897f4a upstream.
Commit e61734c55c24 ("cgroup: remove cgroup->name") added two extra
newlines to memcg oom kill log messages. This makes dmesg hard to read
and parse. The issue affects 3.15+.
Example:
Task in /t <<< extra #1
killed as a result of limit of /t
<<< extra #2
memory: usage 102400kB, limit 102400kB, failcnt 274712
Remove the extra newlines from memcg oom kill messages, so the messages
look like:
Task in /t killed as a result of limit of /t
memory: usage 102400kB, limit 102400kB, failcnt 240649
Fixes: e61734c55c24 ("cgroup: remove cgroup->name")
Signed-off-by: Greg Thelen <gthelen@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
commit 9c145c56d0c8a0b62e48c8d71e055ad0fb2012ba upstream.
The stack guard page error case has long incorrectly caused a SIGBUS
rather than a SIGSEGV, but nobody actually noticed until commit
fee7e49d4514 ("mm: propagate error from stack expansion even for guard
page") because that error case was never actually triggered in any
normal situations.
Now that we actually report the error, people noticed the wrong signal
that resulted. So far, only the test suite of libsigsegv seems to have
actually cared, but there are real applications that use libsigsegv, so
let's not wait for any of those to break.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
commit 45f87de57f8fad59302fd263dd81ffa4843b5b24 upstream.
Commit 2457aec63745 ("mm: non-atomically mark page accessed during page
cache allocation where possible") has added a separate parameter for
specifying gfp mask for radix tree allocations.
Not only this is less than optimal from the API point of view because it
is error prone, it is also buggy currently because
grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if
fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by
AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then
the radix tree allocation wouldn't obey the restriction and might
recurse into filesystem and cause deadlocks. This is the case for most
filesystems unfortunately because only ext4 and gfs2 are using
AOP_FLAG_NOFS.
Let's simply remove radix_gfp_mask parameter because the allocation
context is same for both page cache and for the radix tree. Just make
sure that the radix tree gets only the sane subset of the mask (e.g. do
not pass __GFP_WRITE).
Long term it is more preferable to convert remaining users of
AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this
interface even further.
Reported-by: Dave Chinner <david@fromorbit.com>
commit 690eac53daff34169a4d74fc7bfbd388c4896abb upstream.
Commit fee7e49d4514 ("mm: propagate error from stack expansion even for
guard page") made sure that we return the error properly for stack
growth conditions. It also theorized that counting the guard page
towards the stack limit might break something, but also said "Let's see
if anybody notices".
Somebody did notice. Apparently android-x86 sets the stack limit very
close to the limit indeed, and including the guard page in the rlimit
check causes the android 'zygote' process problems.
So this adds the (fairly trivial) code to make the stack rlimit check be
against the actual real stack size, rather than the size of the vma that
includes the guard page.
Reported-and-tested-by: Chih-Wei Huang <cwhuang@android-x86.org>
Cc: Jay Foad <jay.foad@gmail.com>
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream.
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
being killed
commit 9e5e3661727eaf960d3480213f8e87c8d67b6956 upstream.
Charles Shirron and Paul Cassella from Cray Inc have reported kswapd
stuck in a busy loop with nothing left to balance, but
kswapd_try_to_sleep() failing to sleep. Their analysis found the cause
to be a combination of several factors:
1. A process is waiting in throttle_direct_reclaim() on pgdat->pfmemalloc_wait
2. The process has been killed (by OOM in this case), but has not yet been
scheduled to remove itself from the waitqueue and die.
3. kswapd checks for throttled processes in prepare_kswapd_sleep():
if (waitqueue_active(&pgdat->pfmemalloc_wait)) {
wake_up(&pgdat->pfmemalloc_wait);
return false; // kswapd will not go to sleep
However, for a process that was already killed, wake_up() does not remove
the process from the waitqueue, since try_to_wake_up() checks its state
first and returns false when the process is no longer waiting.
4. kswapd is running on the same CPU as the only CPU that the process is
allowed to run on (through cpus_allowed, or possibly single-cpu system).
5. CONFIG_PREEMPT_NONE=y kernel is used. If there's nothing to balance, kswapd
encounters no voluntary preemption points and repeatedly fails
prepare_kswapd_sleep(), blocking the process from running and removing
itself from the waitqueue, which would let kswapd sleep.
So, the source of the problem is that we prevent kswapd from going to
sleep until there are processes waiting on the pfmemalloc_wait queue,
and a process waiting on a queue is guaranteed to be removed from the
queue only when it gets scheduled. This was done to make sure that no
process is left sleeping on pfmemalloc_wait when kswapd itself goes to
sleep.
However, it isn't necessary to postpone kswapd sleep until the
pfmemalloc_wait queue actually empties. To prevent processes from being
left sleeping, it's actually enough to guarantee that all processes
waiting on pfmemalloc_wait queue have been woken up by the time we put
kswapd to sleep.
This patch therefore fixes this issue by substituting 'wake_up' with
'wake_up_all' and removing 'return false' in the code snippet from
prepare_kswapd_sleep() above. Note that if any process puts itself in
the queue after this waitqueue_active() check, or after the wake up
itself, it means that the process will also wake up kswapd - and since
we are under prepare_to_wait(), the wake up won't be missed. Also we
update the comment prepare_kswapd_sleep() to hopefully more clearly
describe the races it is preventing.
Fixes: 5515061d22f0 ("mm: throttle direct reclaimers if PF_MEMALLOC reserves are low and swap is backed by network storage")
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
commit 2d6d7f98284648c5ed113fe22a132148950b140f upstream.
Tejun, while reviewing the code, spotted the following race condition
between the dirtying and truncation of a page:
__set_page_dirty_nobuffers() __delete_from_page_cache()
if (TestSetPageDirty(page))
page->mapping = NULL
if (PageDirty())
dec_zone_page_state(page, NR_FILE_DIRTY);
dec_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE);
if (page->mapping)
account_page_dirtied(page)
__inc_zone_page_state(page, NR_FILE_DIRTY);
__inc_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE);
which results in an imbalance of NR_FILE_DIRTY and BDI_RECLAIMABLE.
Dirtiers usually lock out truncation, either by holding the page lock
directly, or in case of zap_pte_range(), by pinning the mapcount with
the page table lock held. The notable exception to this rule, though,
is do_wp_page(), for which this race exists. However, do_wp_page()
already waits for a locked page to unlock before setting the dirty bit,
in order to prevent a race where clear_page_dirty() misses the page bit
in the presence of dirty ptes. Upgrade that wait to a fully locked
set_page_dirty() to also cover the situation explained above.
Afterwards, the code in set_page_dirty() dealing with a truncation race
is no longer needed. Remove it.
Reported-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 6b101e2a3ce4d2a0312087598bd1ab4a1db2ac40 upstream.
high_memory isn't direct mapped memory so retrieving it's physical address
isn't appropriate. But, it would be useful to check physical address of
highmem boundary so it's justfiable to get physical address from it. In
x86, there is a validation check if CONFIG_DEBUG_VIRTUAL and it triggers
following boot failure reported by Ingo.
BUG: Int 6: CR2 00f06f53
Call Trace:
dump_stack+0x41/0x52
early_idt_handler+0x6b/0x6b
cma_declare_contiguous+0x33/0x212
dma_contiguous_reserve_area+0x31/0x4e
dma_contiguous_reserve+0x11d/0x125
setup_arch+0x7b5/0xb63
start_kernel+0xb8/0x3e6
i386_start_kernel+0x79/0x7d
To fix boot regression, this patch implements workaround to avoid
validation check in x86 when retrieving physical address of high_memory.
__pa_nodebug() used by this patch is implemented only in x86 so there is
no choice but to use dirty #ifdef.
[akpm@linux-foundation.org: tweak comment]
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Reported-by: Ingo Molnar <mingo@kernel.org>
Tested-by: Ingo Molnar <mingo@kernel.org>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
The bounds check for nodeid in ____cache_alloc_node gives false
positives on machines where the node IDs are not contiguous, leading to
a panic at boot time. For example, on a POWER8 machine the node IDs are
typically 0, 1, 16 and 17. This means that num_online_nodes() returns
4, so when ____cache_alloc_node is called with nodeid = 16 the VM_BUG_ON
triggers, like this:
kernel BUG at /home/paulus/kernel/kvm/mm/slab.c:3079!
Call Trace:
.____cache_alloc_node+0x5c/0x270 (unreliable)
.kmem_cache_alloc_node_trace+0xdc/0x360
.init_list+0x3c/0x128
.kmem_cache_init+0x1dc/0x258
.start_kernel+0x2a0/0x568
start_here_common+0x20/0xa8
To fix this, we instead compare the nodeid with MAX_NUMNODES, and
additionally make sure it isn't negative (since nodeid is an int). The
check is there mainly to protect the array dereference in the get_node()
call in the next line, and the array being dereferenced is of size
MAX_NUMNODES. If the nodeid is in range but invalid (for example if the
node is off-line), the BUG_ON in the next line will catch that.
Fixes: 14e50c6a9bc2 ("mm: slab: Verify the nodeid passed to ____cache_alloc_node")
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Pekka Enberg <penberg@kernel.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: <stable@vger.kernel.org>
Andrew Morton noticed that the error return from anon_vma_clone() was
being dropped and replaced with -ENOMEM (which is not itself a bug
because the only error return value from anon_vma_clone() is -ENOMEM).
I did an audit of callers of anon_vma_clone() and discovered an actual
bug where the error return was being lost. In __split_vma(), between
Linux 3.11 and 3.12 the code was changed so the err variable is used
before the call to anon_vma_clone() and the default initial value of
-ENOMEM is overwritten. So a failure of anon_vma_clone() will return
success since err at this point is now zero.
Below is a patch which fixes this bug and also propagates the error
return value from anon_vma_clone() in all cases.
Fixes: ef0855d334e1 ("mm: mempolicy: turn vma_set_policy() into vma_dup_policy()")
Signed-off-by: Daniel Forrest <dan.forrest@ssec.wisc.edu>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Tim Hartrick <tim@edgecast.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: <stable@vger.kernel.org> [3.12+]
I've been seeing swapoff hangs in recent testing: it's cycling around
trying unsuccessfully to find an mm for some remaining pages of swap.
I have been exercising swap and page migration more heavily recently,
and now notice a long-standing error in copy_one_pte(): it's trying to
add dst_mm to swapoff's mmlist when it finds a swap entry, but is doing
so even when it's a migration entry or an hwpoison entry.
Which wouldn't matter much, except it adds dst_mm next to src_mm,
assuming src_mm is already on the mmlist: which may not be so. Then if
pages are later swapped out from dst_mm, swapoff won't be able to find
where to replace them.
There's already a !non_swap_entry() test for stats: move that up before
the swap_duplicate() and the addition to mmlist.
Cc: Kelley Nielsen <kelleynnn@gmail.com>
Cc: <stable@vger.kernel.org> [2.6.18+]
In some android devices, there will be a "divide by zero" exception.
vmpr->scanned could be zero before spin_lock(&vmpr->sr_lock).
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=88051
[akpm@linux-foundation.org: neaten]
Reported-by: ji_ang <ji_ang@163.com>
Cc: Anton Vorontsov <anton.vorontsov@linaro.org>
If a frontswap dup-store failed, it should invalidate the expired page
in the backend, or it could trigger some data corruption issue.
Such as:
1. use zswap as the frontswap backend with writeback feature
2. store a swap page(version_1) to entry A, success
3. dup-store a newer page(version_2) to the same entry A, fail
4. use __swap_writepage() write version_2 page to swapfile, success
5. zswap do shrink, writeback version_1 page to swapfile
6. version_2 page is overwrited by version_1, data corrupt.
This patch fixes this issue by invalidating expired data immediately
when meet a dup-store failure.
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Seth Jennings <sjennings@variantweb.net>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Pull vfs fix from Al Viro:
"Fix for a really embarrassing braino in iov_iter. Kudos to paulus..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
Fix thinko in iov_iter_single_seg_count
When memory is hot-added, all the memory is in offline state. So clear
all zones' present_pages because they will be updated in online_pages()
and offline_pages(). Otherwise, /proc/zoneinfo will corrupt:
When the memory of node2 is offline:
# cat /proc/zoneinfo
Node 2, zone Movable
spanned 8388608
present 8388608
managed 0
When we online memory on node2:
spanned 8388608
present 16777216
managed 8388608
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Cc: <stable@vger.kernel.org> [3.16+]
In free_area_init_core(), zone->managed_pages is set to an approximate
value for lowmem, and will be adjusted when the bootmem allocator frees
pages into the buddy system.
But free_area_init_core() is also called by hotadd_new_pgdat() when
hot-adding memory. As a result, zone->managed_pages of the newly added
node's pgdat is set to an approximate value in the very beginning.
Even if the memory on that node has node been onlined,
/sys/device/system/node/nodeXXX/meminfo has wrong value:
hot-add node2 (memory not onlined)
cat /sys/device/system/node/node2/meminfo
Node 2 MemTotal: 33554432 kB
Node 2 MemFree: 0 kB
Node 2 MemUsed: 33554432 kB
Node 2 Active: 0 kB
This patch fixes this problem by reset node managed pages to 0 after
hot-adding a new node.
1. Move reset_managed_pages_done from reset_node_managed_pages() to
reset_all_zones_managed_pages()
2. Make reset_node_managed_pages() non-static
3. Call reset_node_managed_pages() in hotadd_new_pgdat() after pgdat
is initialized
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
One thing I did in this patch is fixing freepage accounting. If we
clear guard page and link it onto isolate buddy list, we should not
increase freepage count. This patch adds conditional branch to skip
counting in this case. Without this patch, this overcounting happens
frequently if guard order is set and CMA is used.
Another thing fixed in this patch is the target to reset order. In
__free_one_page(), we check the buddy page whether it is a guard page or
not. And, if so, we should clear guard attribute on the buddy page and
reset order of it to 0. But, current code resets original page's order
rather than buddy one's. Maybe, this doesn't have any problem, because
whole merged page's order will be re-assigned soon. But, it is better
to correct code.
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Gioh Kim <gioh.kim@lge.com>
Several people have reported occasionally seeing processes stuck in
compact_zone(), even triggering soft lockups, in 3.18-rc2+.
Testing a revert of commit e14c720efdd7 ("mm, compaction: remember
position within pageblock in free pages scanner") fixed the issue,
although the stuck processes do not appear to involve the free scanner.
Finally, by code inspection, the bug was found in isolate_migratepages()
which uses a slightly different condition to detect if the migration and
free scanners have met, than compact_finished(). That has not been a
problem until commit e14c720efdd7 allowed the free scanner position
between individual invocations to be in the middle of a pageblock.
In a relatively rare case, the migration scanner position can end up at
the beginning of a pageblock, with the free scanner position in the
middle of the same pageblock. If it's the migration scanner's turn,
isolate_migratepages() exits immediately (without updating the
position), while compact_finished() decides to continue compaction,
resulting in a potentially infinite loop. The system can recover only
if another process creates enough high-order pages to make the watermark
checks in compact_finished() pass.
This patch fixes the immediate problem by bumping the migration
scanner's position to meet the free scanner in isolate_migratepages(),
when both are within the same pageblock. This causes compact_finished()
to terminate properly. A more robust check in compact_finished() is
planned as a cleanup for better future maintainability.
Fixes: e14c720efdd73 ("mm, compaction: remember position within pageblock in free pages scanner)
Reported-by: P. Christeas <xrg@linux.gr>
Tested-by: P. Christeas <xrg@linux.gr>
Link: http://marc.info/?l=linux-mm&m=141508604232522&w=2
Reported-by: Norbert Preining <preining@logic.at>
Tested-by: Norbert Preining <preining@logic.at>
Link: https://lkml.org/lkml/2014/11/4/904
Reported-by: Pavel Machek <pavel@ucw.cz>
Link: https://lkml.org/lkml/2014/11/7/164
Having test_pages_isolated failure message as a warning confuses users
into thinking that it is more serious than it really is. In reality, if
called via CMA, allocation will be retried so a single
test_pages_isolated failure does not prevent allocation from succeeding.
Demote the warning message to an info message and reformat it such that
the text "failed" does not appear and instead a less worrying "PFNS
busy" is used.
This message is trivially reproducible on a 10GB x86 machine on 3.16.y
kernels configured with CONFIG_DMA_CMA.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Peter Hurley <peter@hurleysoftware.com>
Unlike SLUB, sometimes, object isn't started at the beginning of the
slab in SLAB. This causes the unalignment problem after slab merging is
supported by commit 12220dea07f1 ("mm/slab: support slab merge").
Following is the report from Markos that fail to boot on Malta with EVA.
Calibrating delay loop... 19.86 BogoMIPS (lpj=99328)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 4096 (order: 0, 16384 bytes)
Mountpoint-cache hash table entries: 4096 (order: 0, 16384 bytes)
Kernel bug detected[#1]:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.17.0-05639-g12220dea07f1 #1631
task: 1f04f5d8 ti: 1f050000 task.ti: 1f050000
epc : 80141190 alloc_unbound_pwq+0x234/0x304
Not tainted
ra : 80141184 alloc_unbound_pwq+0x228/0x304
Process swapper/0 (pid: 1, threadinfo=1f050000, task=1f04f5d8, tls=00000000)
Call Trace:
apply_workqueue_attrs+0x11c/0x294
__alloc_workqueue_key+0x23c/0x470
init_workqueues+0x320/0x400
do_one_initcall+0xe8/0x23c
kernel_init_freeable+0x9c/0x224
kernel_init+0x10/0x100
ret_from_kernel_thread+0x14/0x1c
[ end trace cb88537fdc8fa200 ]
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
alloc_unbound_pwq() allocates slab object from pool_workqueue. This
kmem_cache requires 256 bytes alignment, but, current merging code
doesn't honor that, and merge it with kmalloc-256. kmalloc-256 requires
only cacheline size alignment so that above failure occurs. However, in
x86, kmalloc-256 is luckily aligned in 256 bytes, so the problem didn't
happen on it.
To fix this problem, this patch introduces alignment mismatch check in
find_mergeable(). This will fix the problem.
Reported-by: Markos Chandras <Markos.Chandras@imgtec.com>
Tested-by: Markos Chandras <Markos.Chandras@imgtec.com>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Current pageblock isolation logic could isolate each pageblock
individually. This causes freepage accounting problem if freepage with
pageblock order on isolate pageblock is merged with other freepage on
normal pageblock. We can prevent merging by restricting max order of
merging to pageblock order if freepage is on isolate pageblock.
A side-effect of this change is that there could be non-merged buddy
freepage even if finishing pageblock isolation, because undoing
pageblock isolation is just to move freepage from isolate buddy list to
normal buddy list rather than to consider merging. So, the patch also
makes undoing pageblock isolation consider freepage merge. When
un-isolation, freepage with more than pageblock order and it's buddy are
checked. If they are on normal pageblock, instead of just moving, we
isolate the freepage and free it in order to get merged.
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Laura Abbott <lauraa@codeaurora.org>
Cc: Heesub Shin <heesub.shin@samsung.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Ritesh Harjani <ritesh.list@gmail.com>
All the caller of __free_one_page() has similar freepage counting logic,
so we can move it to __free_one_page(). This reduce line of code and
help future maintenance.
This is also preparation step for "mm/page_alloc: restrict max order of
merging on isolated pageblock" which fix the freepage counting problem
on freepage with more than pageblock order.
In free_pcppages_bulk(), we use cached migratetype of freepage to
determine type of buddy list where freepage will be added. This
information is stored when freepage is added to pcp list, so if
isolation of pageblock of this freepage begins after storing, this
cached information could be stale. In other words, it has original
migratetype rather than MIGRATE_ISOLATE.
There are two problems caused by this stale information.
One is that we can't keep these freepages from being allocated.
Although this pageblock is isolated, freepage will be added to normal
buddy list so that it could be allocated without any restriction. And
the other problem is incorrect freepage accounting. Freepages on
isolate pageblock should not be counted for number of freepage.
Following is the code snippet in free_pcppages_bulk().
/* MIGRATE_MOVABLE list may include MIGRATE_RESERVEs */
__free_one_page(page, page_to_pfn(page), zone, 0, mt);
trace_mm_page_pcpu_drain(page, 0, mt);
if (likely(!is_migrate_isolate_page(page))) {
__mod_zone_page_state(zone, NR_FREE_PAGES, 1);
if (is_migrate_cma(mt))
__mod_zone_page_state(zone, NR_FREE_CMA_PAGES, 1);
As you can see above snippet, current code already handle second
problem, incorrect freepage accounting, by re-fetching pageblock
migratetype through is_migrate_isolate_page(page).
But, because this re-fetched information isn't used for
__free_one_page(), first problem would not be solved. This patch try to
solve this situation to re-fetch pageblock migratetype before
__free_one_page() and to use it for __free_one_page().
In addition to move up position of this re-fetch, this patch use
optimization technique, re-fetching migratetype only if there is isolate
pageblock. Pageblock isolation is rare event, so we can avoid
re-fetching in common case with this optimization.
This patch also correct migratetype of the tracepoint output.
Acked-by: Minchan Kim <minchan@kernel.org>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Before describing bugs itself, I first explain definition of freepage.
1. pages on buddy list are counted as freepage.
2. pages on isolate migratetype buddy list are *not* counted as freepage.
3. pages on cma buddy list are counted as CMA freepage, too.
Now, I describe problems and related patch.
Patch 1: There is race conditions on getting pageblock migratetype that
it results in misplacement of freepages on buddy list, incorrect
freepage count and un-availability of freepage.
Patch 2: Freepages on pcp list could have stale cached information to
determine migratetype of buddy list to go. This causes misplacement of
freepages on buddy list and incorrect freepage count.
Patch 4: Merging between freepages on different migratetype of
pageblocks will cause freepages accouting problem. This patch fixes it.
Without patchset [3], above problem doesn't happens on my CMA allocation
test, because CMA reserved pages aren't used at all. So there is no
chance for above race.
With patchset [3], I did simple CMA allocation test and get below
result:
- Virtual machine, 4 cpus, 1024 MB memory, 256 MB CMA reservation
- run kernel build (make -j16) on background
- 30 times CMA allocation(8MB * 30 = 240MB) attempts in 5 sec interval
- Result: more than 5000 freepage count are missed
With patchset [3] and this patchset, I found that no freepage count are
missed so that I conclude that problems are solved.
On my simple memory offlining test, these problems also occur on that
environment, too.
This patch (of 4):
There are two paths to reach core free function of buddy allocator,
__free_one_page(), one is free_one_page()->__free_one_page() and the
other is free_hot_cold_page()->free_pcppages_bulk()->__free_one_page().
Each paths has race condition causing serious problems. At first, this
patch is focused on first type of freepath. And then, following patch
will solve the problem in second type of freepath.
In the first type of freepath, we got migratetype of freeing page
without holding the zone lock, so it could be racy. There are two cases
of this race.
1. pages are added to isolate buddy list after restoring orignal
migratetype
CPU1 CPU2
get migratetype => return MIGRATE_ISOLATE
call free_one_page() with MIGRATE_ISOLATE
grab the zone lock
unisolate pageblock
release the zone lock
grab the zone lock
call __free_one_page() with MIGRATE_ISOLATE
freepage go into isolate buddy list,
although pageblock is already unisolated
This may cause two problems. One is that we can't use this page anymore
until next isolation attempt of this pageblock, because freepage is on
isolate buddy list. The other is that freepage accouting could be wrong
due to merging between different buddy list. Freepages on isolate buddy
list aren't counted as freepage, but ones on normal buddy list are
counted as freepage. If merge happens, buddy freepage on normal buddy
list is inevitably moved to isolate buddy list without any consideration
of freepage accouting so it could be incorrect.
2. pages are added to normal buddy list while pageblock is isolated.
It is similar with above case.
This also may cause two problems. One is that we can't keep these
freepages from being allocated. Although this pageblock is isolated,
freepage would be added to normal buddy list so that it could be
allocated without any restriction. And the other problem is same as
case 1, that it, incorrect freepage accouting.
This race condition would be prevented by checking migratetype again
with holding the zone lock. Because it is somewhat heavy operation and
it isn't needed in common case, we want to avoid rechecking as much as
possible. So this patch introduce new variable, nr_isolate_pageblock in
struct zone to check if there is isolated pageblock. With this, we can
avoid to re-check migratetype in common case and do it only if there is
isolated pageblock or migratetype is MIGRATE_ISOLATE. This solve above
mentioned problems.
Changes from v3:
Add one more check in free_one_page() that checks whether migratetype is
MIGRATE_ISOLATE or not. Without this, abovementioned case 1 could happens.
Commit 7d49d8868336 ("mm, compaction: reduce zone checking frequency in
the migration scanner") has a side-effect that changes the iteration
range calculation. Before the change, block_end_pfn is calculated using
start_pfn, but now it blindly adds pageblock_nr_pages to the previous
value.
This causes the problem that isolation_start_pfn is larger than
block_end_pfn when we isolate the page with more than pageblock order.
In this case, isolation would fail due to an invalid range parameter.
To prevent this, this patch implements skipping the range until a proper
target pageblock is met. Without this patch, CMA with more than
pageblock order always fails but with this patch it will succeed.
The branches of the if (i->type & ITER_BVEC) statement in
iov_iter_single_seg_count() are the wrong way around; if ITER_BVEC is
clear then we use i->bvec, when we should be using i->iov. This fixes
it.
In my case, the symptom that this caused was that a KVM guest doing
filesystem operations on a virtual disk would result in one of qemu's
threads on the host going into an infinite loop in
generic_perform_write(). The loop would hit the copied == 0 case and
call iov_iter_single_seg_count() to reduce the number of bytes to try
to process, but because of the error, iov_iter_single_seg_count()
would just return i->count and the loop made no progress and continued
forever.
Cc: stable@vger.kernel.org # 3.16+
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
Pull xfs fixes from Dave Chinner:
"This update fixes a warning in the new pagecache_isize_extended() and
updates some related comments, another fix for zero-range
misbehaviour, and an unforntuately large set of fixes for regressions
in the bulkstat code.
The bulkstat fixes are large but necessary. I wouldn't normally push
such a rework for a -rcX update, but right now xfsdump can silently
create incomplete dumps on 3.17 and it's possible that even xfsrestore
won't notice that the dumps were incomplete. Hence we need to get
this update into 3.17-stable kernels ASAP.
In more detail, the refactoring work I committed in 3.17 has exposed a
major hole in our QA coverage. With both xfsdump (the major user of
bulkstat) and xfsrestore silently ignoring missing files in the
dump/restore process, incomplete dumps were going unnoticed if they
were being triggered. Many of the dump/restore filesets were so small
that they didn't evenhave a chance of triggering the loop iteration
bugs we introduced in 3.17, so we didn't exercise the code
sufficiently, either.
We have already taken steps to improve QA coverage in xfstests to
avoid this happening again, and I've done a lot of manual verification
of dump/restore on very large data sets (tens of millions of inodes)
of the past week to verify this patch set results in bulkstat behaving
the same way as it does on 3.16.
Unfortunately, the fixes are not exactly simple - in tracking down the
problem historic API warts were discovered (e.g xfsdump has been
working around a 20 year old bug in the bulkstat API for the past 10
years) and so that complicated the process of diagnosing and fixing
the problems. i.e. we had to fix bugs in the code as well as
discover and re-introduce the userspace visible API bugs that we
unwittingly "fixed" in 3.17 that xfsdump relied on to work correctly.
Summary:
- incorrect warnings about i_mutex locking in pagecache_isize_extended()
and updates comments to match expected locking
- another zero-range bug fix for stray file size updates
- a bunch of fixes for regression in the bulkstat code introduced in
3.17"
* tag 'xfs-for-linus-3.18-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs:
xfs: track bulkstat progress by agino
xfs: bulkstat error handling is broken
xfs: bulkstat main loop logic is a mess
xfs: bulkstat chunk-formatter has issues
xfs: bulkstat chunk formatting cursor is broken
xfs: bulkstat btree walk doesn't terminate
mm: Fix comment before truncate_setsize()
xfs: rework zero range to prevent invalid i_size updates
mm: Remove false WARN_ON from pagecache_isize_extended()
xfs: Check error during inode btree iteration in xfs_bulkstat()
xfs: bulkstat doesn't release AGI buffer on error
XFS doesn't always hold i_mutex when calling truncate_setsize() and it
uses a different lock to serialize truncates and writes. So fix the
comment before truncate_setsize().
Reported-by: Jan Beulich <JBeulich@suse.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull CMA and DMA-mapping fixes from Marek Szyprowski:
"This contains important fixes for recently introduced highmem support
for default contiguous memory region used for dma-mapping subsystem"
* 'fixes-for-v3.18' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
mm, cma: make parameters order consistent in func declaration and definition
mm: cma: Use %pa to print physical addresses
mm: cma: Ensure that reservations never cross the low/high mem boundary
mm: cma: Always consider a 0 base address reservation as dynamic
mm: cma: Don't crash on allocation if CMA area can't be activated
The WARN_ON checking whether i_mutex is held in
pagecache_isize_extended() was wrong because some filesystems (e.g.
XFS) use different locks for serialization of truncates / writes. So
just remove the check.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
If CONFIG_BALLOON_COMPACTION=n balloon_page_insert() does not link pages
with balloon and doesn't set PagePrivate flag, as a result
balloon_page_dequeue() cannot get any pages because it thinks that all
of them are isolated. Without balloon compaction nobody can isolate
ballooned pages. It's safe to remove this check.
Fixes: d6d86c0a7f8d ("mm/balloon_compaction: redesign ballooned pages management").
Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com>
Reported-by: Matt Mullins <mmullins@mmlx.us>
Cc: <stable@vger.kernel.org> [3.17]
The SLUB cache merges caches with the same size and alignment and there
was long standing bug with this behavior:
- create the cache named "foo"
- create the cache named "bar" (which is merged with "foo")
- delete the cache named "foo" (but it stays allocated because "bar"
uses it)
- create the cache named "foo" again - it fails because the name "foo"
is already used
That bug was fixed in commit 694617474e33 ("slab_common: fix the check
for duplicate slab names") by not warning on duplicate cache names when
the SLUB subsystem is used.
Recently, cache merging was implemented the with SLAB subsystem too, in
12220dea07f1 ("mm/slab: support slab merge")). Therefore we need stop
checking for duplicate names even for the SLAB subsystem.
This patch fixes the bug by removing the check.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
page_remove_rmap() has too many branches on PageAnon() and is hard to
follow. Move the file part into a separate function.
Cc: Vladimir Davydov <vdavydov@parallels.com>
Commit 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API") changed
page migration to uncharge the old page right away. The page is locked,
unmapped, truncated, and off the LRU, but it could race with writeback
ending, which then doesn't unaccount the page properly:
test_clear_page_writeback() migration
wait_on_page_writeback()
TestClearPageWriteback()
mem_cgroup_migrate()
clear PCG_USED
mem_cgroup_update_page_stat()
if (PageCgroupUsed(pc))
decrease memcg pages under writeback
release pc->mem_cgroup->move_lock
The per-page statistics interface is heavily optimized to avoid a
function call and a lookup_page_cgroup() in the file unmap fast path,
which means it doesn't verify whether a page is still charged before
clearing PageWriteback() and it has to do it in the stat update later.
Rework it so that it looks up the page's memcg once at the beginning of
the transaction and then uses it throughout. The charge will be
verified before clearing PageWriteback() and migration can't uncharge
the page as long as that is still set. The RCU lock will protect the
memcg past uncharge.
As far as losing the optimization goes, the following test results are
from a microbenchmark that maps, faults, and unmaps a 4GB sparse file
three times in a nested fashion, so that there are two negative passes
that don't account but still go through the new transaction overhead.
There is no actual difference:
old: 33.195102545 seconds time elapsed ( +- 0.01% )
new: 33.199231369 seconds time elapsed ( +- 0.03% )
The time spent in page_remove_rmap()'s callees still adds up to the
same, but the time spent in the function itself seems reduced:
# Children Self Command Shared Object Symbol
old: 0.12% 0.11% filemapstress [kernel.kallsyms] [k] page_remove_rmap
new: 0.12% 0.08% filemapstress [kernel.kallsyms] [k] page_remove_rmap
Cc: <stable@vger.kernel.org> [3.17.x]
A follow-up patch would have changed the call signature. To save the
trouble, just fold it instead.
When hot adding the same memory after hot removal, the following
messages are shown:
WARNING: CPU: 20 PID: 6 at mm/page_alloc.c:4968 free_area_init_node+0x3fe/0x426()
Call Trace:
dump_stack+0x46/0x58
warn_slowpath_common+0x81/0xa0
warn_slowpath_null+0x1a/0x20
hotadd_new_pgdat+0x90/0x110
add_memory+0xd4/0x200
acpi_memory_device_add+0x1aa/0x289
acpi_bus_attach+0xfd/0x204
acpi_bus_attach+0x178/0x204
acpi_bus_scan+0x6a/0x90
acpi_device_hotplug+0xe8/0x418
acpi_hotplug_work_fn+0x1f/0x2b
process_one_work+0x14e/0x3f0
worker_thread+0x11b/0x510
kthread+0xe1/0x100
ret_from_fork+0x7c/0xb0
The detaled explanation is as follows:
When hot removing memory, pgdat is set to 0 in try_offline_node(). But
if the pgdat is allocated by bootmem allocator, the clearing step is
skipped.
And when hot adding the same memory, the uninitialized pgdat is reused.
But free_area_init_node() checks wether pgdat is set to zero. As a
result, free_area_init_node() hits WARN_ON().
This patch clears pgdat which is allocated by bootmem allocator in
try_offline_node().
Cc: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: Wang Nan <wangnan0@huawei.com>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
If an anonymous mapping is not allowed to fault thp memory and then
madvise(MADV_HUGEPAGE) is used after fault, khugepaged will never
collapse this memory into thp memory.
This occurs because the madvise(2) handler for thp, hugepage_madvise(),
clears VM_NOHUGEPAGE on the stack and it isn't stored in vma->vm_flags
until the final action of madvise_behavior(). This causes the
khugepaged_enter_vma_merge() to be a no-op in hugepage_madvise() when
the vma had previously had VM_NOHUGEPAGE set.
Fix this by passing the correct vma flags to the khugepaged mm slot
handler. There's no chance khugepaged can run on this vma until after
madvise_behavior() returns since we hold mm->mmap_sem.
It would be possible to clear VM_NOHUGEPAGE directly from vma->vm_flags
in hugepage_advise(), but I didn't want to introduce special case
behavior into madvise_behavior(). I think it's best to just let it
always set vma->vm_flags itself.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Suleiman Souhlal <suleiman@google.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Compound page should be freed by put_page() or free_pages() with correct
order. Not doing so will cause tail pages leaked.
The compound order can be obtained by compound_order() or use
HPAGE_PMD_ORDER in our case. Some people would argue the latter is
faster but I prefer the former which is more general.
This bug was observed not just on our servers (the worst case we saw is
11G leaked on a 48G machine) but also on our workstations running Ubuntu
based distro.
$ cat /proc/vmstat | grep thp_zero_page_alloc
thp_zero_page_alloc 55
thp_zero_page_alloc_failed 0
This means there is (thp_zero_page_alloc - 1) * (2M - 4K) memory leaked.
Fixes: 97ae17497e99 ("thp: implement refcounting for huge zero page")
Signed-off-by: Yu Zhao <yuzhao@google.com>
Cc: Bob Liu <lliubbo@gmail.com>
Cc: <stable@vger.kernel.org> [3.8+]
Commit edc2ca612496 ("mm, compaction: move pageblock checks up from
isolate_migratepages_range()") commonizes isolate_migratepages variants
and make them use isolate_migratepages_block().
isolate_migratepages_block() could stop the execution when enough pages
are isolated, but, there is no code in isolate_migratepages_range() to
handle this case. In the result, even if isolate_migratepages_block()
returns prematurely without checking all pages in the range,
isolate_migratepages_block() is called repeately on the following
pageblock and some pages in the previous range are skipped to check.
Then, CMA is failed frequently due to this fact.
To fix this problem, this patch let isolate_migratepages_range() know
the situation that enough pages are isolated and stop the isolation in
that case.
Note that isolate_migratepages() has no such problem, because, it always
stops the isolation after just one call of isolate_migratepages_block().
Commit ff7ee93f4715 ("cgroup/kmemleak: Annotate alloc_page() for cgroup
allocations") introduces kmemleak_alloc() for alloc_page_cgroup(), but
corresponding kmemleak_free() is missing, which makes kmemleak be
wrongly disabled after memory offlining. Log is pasted at the end of
this commit message.
This patch add kmemleak_free() into free_page_cgroup(). During page
offlining, this patch removes corresponding entries in kmemleak rbtree.
After that, the freed memory can be allocated again by other subsystems
without killing kmemleak.
bash # for x in 1 2 3 4; do echo offline > /sys/devices/system/memory/memory$x/state ; sleep 1; done ; dmesg | grep leak
Offlined Pages 32768
kmemleak: Cannot insert 0xffff880016969000 into the object search tree (overlaps existing)
CPU: 0 PID: 412 Comm: sleep Not tainted 3.17.0-rc5+ #86
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
create_object+0x266/0x2c0
kmemleak_alloc+0x26/0x50
kmem_cache_alloc+0xd3/0x160
__sigqueue_alloc+0x49/0xd0
__send_signal+0xcb/0x410
send_signal+0x45/0x90
__group_send_sig_info+0x13/0x20
do_notify_parent+0x1bb/0x260
do_exit+0x767/0xa40
do_group_exit+0x44/0xa0
SyS_exit_group+0x17/0x20
system_call_fastpath+0x16/0x1b
kmemleak: Kernel memory leak detector disabled
kmemleak: Object 0xffff880016900000 (size 524288):
kmemleak: comm "swapper/0", pid 0, jiffies 4294667296
kmemleak: min_count = 0
kmemleak: count = 0
kmemleak: flags = 0x1
kmemleak: checksum = 0
kmemleak: backtrace:
log_early+0x63/0x77
kmemleak_alloc+0x4b/0x50
init_section_page_cgroup+0x7f/0xf5
page_cgroup_init+0xc5/0xd0
start_kernel+0x333/0x408
x86_64_start_reservations+0x2a/0x2c
x86_64_start_kernel+0xf5/0xfc
Fixes: ff7ee93f4715 (cgroup/kmemleak: Annotate alloc_page() for cgroup allocations)
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Cc: <stable@vger.kernel.org> [3.2+]
When unmapping a range of pages in zap_pte_range, the page being
unmapped is added to an mmu_gather_batch structure for asynchronous
freeing. If we run out of space in the batch structure before the range
has been completely unmapped, then we break out of the loop, force a
TLB flush and free the pages that we have batched so far. If there are
further pages to unmap, then we resume the loop where we left off.
Unfortunately, we forget to update addr when we break out of the loop,
which causes us to truncate the range being invalidated as the end
address is exclusive. When we re-enter the loop at the same address, the
page has already been freed and the pte_present test will fail, meaning
that we do not reconsider the address for invalidation.
This patch fixes the problem by incrementing addr by the PAGE_SIZE
before breaking out of the loop on batch failure.
Casting physical addresses to unsigned long and using %lu truncates the
values on systems where physical addresses are larger than 32 bits. Use
%pa and get rid of the cast instead.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Commit 95b0e655f914 ("ARM: mm: don't limit default CMA region only to
low memory") extended CMA memory reservation to allow usage of high
memory. It relied on commit f7426b983a6a ("mm: cma: adjust address limit
to avoid hitting low/high memory boundary") to ensure that the reserved
block never crossed the low/high memory boundary. While the
implementation correctly lowered the limit, it failed to consider the
case where the base..limit range crossed the low/high memory boundary
with enough space on each side to reserve the requested size on either
low or high memory.
Rework the base and limit adjustment to fix the problem. The function
now starts by rejecting the reservation altogether for fixed
reservations that cross the boundary, tries to reserve from high memory
first and then falls back to low memory.
The fixed parameter to cma_declare_contiguous() tells the function
whether the given base address must be honoured or should be considered
as a hint only. The API considers a zero base address as meaning any
base address, which must never be considered as a fixed value.
Part of the implementation correctly checks both fixed and base != 0,
but two locations check the fixed value only. Set fixed to false when
base is 0 to fix that and simplify the code.
If activation of the CMA area fails its mutex won't be initialized,
leading to an oops at allocation time when trying to lock the mutex. Fix
this by setting the cma area count field to 0 when activation fails,
leading to allocation returning NULL immediately.
Cc: <stable@vger.kernel.org> # v3.17
Pull vfs updates from Al Viro:
"overlayfs merge + leak fix for d_splice_alias() failure exits"
overlayfs: embed middle into overlay_readdir_data
overlayfs: embed root into overlay_readdir_data
overlayfs: make ovl_cache_entry->name an array instead of pointer
overlayfs: don't hold ->i_mutex over opening the real directory
fix inode leaks on d_splice_alias() failure exits
fs: limit filesystem stacking depth
overlay: overlay filesystem documentation
overlayfs: implement show_options
overlayfs: add statfs support
overlay filesystem
shmem: support RENAME_WHITEOUT
ext4: support RENAME_WHITEOUT
vfs: add RENAME_WHITEOUT
vfs: add whiteout support
vfs: export check_sticky()
vfs: introduce clone_private_mount()
vfs: export __inode_permission() to modules
vfs: export do_splice_direct() to modules
vfs: add i_op->dentry_open()
Pull ACPI and power management updates from Rafael Wysocki:
"This is material that didn't make it to my 3.18-rc1 pull request for
various reasons, mostly related to timing and travel (LinuxCon EU /
LPC) plus a couple of fixes for recent bugs.
The only really new thing here is the PM QoS class for memory
bandwidth, but it is simple enough and users of it will be added in
the next cycle. One major change in behavior is that platform devices
enumerated by ACPI will use 32-bit DMA mask by default. Also included
is an ACPICA update to a new upstream release, but that's mostly
cleanups, changes in tools and similar. The rest is fixes and
cleanups mostly.
Specifics:
- Fix for a recent PCI power management change that overlooked the
fact that some IRQ chips might not be able to configure PCIe PME
for system wakeup from Lucas Stach.
- Fix for a bug introduced in 3.17 where acpi_device_wakeup() is
called with a wrong ordering of arguments from Zhang Rui.
- A bunch of intel_pstate driver fixes (all -stable candidates) from
Dirk Brandewie, Gabriele Mazzotta and Pali Rohár.
- Fixes for a rather long-standing problem with the OOM killer and
the freezer that frozen processes killed by the OOM do not actually
release any memory until they are thawed, so OOM-killing them is
rather pointless, with a couple of cleanups on top (Michal Hocko,
Cong Wang, Rafael J Wysocki).
- ACPICA update to upstream release 20140926, inlcuding mostly
cleanups reducing differences between the upstream ACPICA and the
kernel code, tools changes (acpidump, acpiexec) and support for the
_DDN object (Bob Moore, Lv Zheng).
- New PM QoS class for memory bandwidth from Tomeu Vizoso.
- Default 32-bit DMA mask for platform devices enumerated by ACPI
(this change is mostly needed for some drivers development in
progress targeted at 3.19) from Heikki Krogerus.
- ACPI EC driver cleanups, mostly related to debugging, from Lv
Zheng.
- cpufreq-dt driver updates from Thomas Petazzoni.
- powernv cpuidle driver update from Preeti U Murthy"
* tag 'pm+acpi-3.18-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (34 commits)
intel_pstate: Correct BYT VID values.
intel_pstate: Fix BYT frequency reporting
intel_pstate: Don't lose sysfs settings during cpu offline
cpufreq: intel_pstate: Reflect current no_turbo state correctly
cpufreq: expose scaling_cur_freq sysfs file for set_policy() drivers
cpufreq: intel_pstate: Fix setting max_perf_pct in performance policy
PCI / PM: handle failure to enable wakeup on PCIe PME
ACPI: invoke acpi_device_wakeup() with correct parameters
PM / freezer: Clean up code after recent fixes
PM: convert do_each_thread to for_each_process_thread
OOM, PM: OOM killed task shouldn't escape PM suspend
freezer: remove obsolete comments in __thaw_task()
freezer: Do not freeze tasks killed by OOM killer
ACPI / platform: provide default DMA mask
cpuidle: powernv: Populate cpuidle state details by querying the device-tree
cpufreq: cpufreq-dt: adjust message related to regulators
cpufreq: cpufreq-dt: extend with platform_data
cpufreq: allow driver-specific data
ACPI / EC: Cleanup coding style.
ACPI / EC: Refine event/query debugging messages.
