path: root/mm
2013-11-01memcg: remove incorrect underflow checkGreg Thelen
When a memcg is deleted mem_cgroup_reparent_charges() moves charged memory to the parent memcg. As of v3.11-9444-g3ea67d0 "memcg: add per cgroup writeback pages accounting" there's bad pointer read. The goal was to check for counter underflow. The counter is a per cpu counter and there are two problems with the code: (1) per cpu access function isn't used, instead a naked pointer is used which easily causes oops. (2) the check doesn't sum all cpus Test: $ cd /sys/fs/cgroup/memory $ mkdir x $ echo 3 > /proc/sys/vm/drop_caches $ (echo $BASHPID >> x/tasks && exec cat) & [1] 7154 $ grep ^mapped x/memory.stat mapped_file 53248 $ echo 7154 > tasks $ rmdir x <OOPS> The fix is to remove the check. It's currently dangerous and isn't worth fixing it to use something expensive, such as percpu_counter_sum(), for each reparented page. __this_cpu_read() isn't enough to fix this because there's no guarantees of the current cpus count. The only guarantees is that the sum of all per-cpu counter is >= nr_pages. Fixes: 3ea67d06e467 ("memcg: add per cgroup writeback pages accounting") Reported-and-tested-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: Greg Thelen <gthelen@google.com> Reviewed-by: Sha Zhengju <handai.szj@taobao.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-31Merge branch 'akpm' (fixes from Andrew Morton)Linus Torvalds
Merge four more fixes from Andrew Morton. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: lib/scatterlist.c: don't flush_kernel_dcache_page on slab page mm: memcg: fix test for child groups mm: memcg: lockdep annotation for memcg OOM lock mm: memcg: use proper memcg in limit bypass
2013-10-31mm: memcg: fix test for child groupsJohannes Weiner
When memcg code needs to know whether any given memcg has children, it uses the cgroup child iteration primitives and returns true/false depending on whether the iteration loop is executed at least once or not. Because a cgroup's list of children is RCU protected, these primitives require the RCU read-lock to be held, which is not the case for all memcg callers. This results in the following splat when e.g. enabling hierarchy mode: WARNING: CPU: 3 PID: 1 at kernel/cgroup.c:3043 css_next_child+0xa3/0x160() CPU: 3 PID: 1 Comm: systemd Not tainted 3.12.0-rc5-00117-g83f11a9-dirty #18 Hardware name: LENOVO 3680B56/3680B56, BIOS 6QET69WW (1.39 ) 04/26/2012 Call Trace: dump_stack+0x54/0x74 warn_slowpath_common+0x78/0xa0 warn_slowpath_null+0x1a/0x20 css_next_child+0xa3/0x160 mem_cgroup_hierarchy_write+0x5b/0xa0 cgroup_file_write+0x108/0x2a0 vfs_write+0xbd/0x1e0 SyS_write+0x4c/0xa0 system_call_fastpath+0x16/0x1b In the memcg case, we only care about children when we are attempting to modify inheritable attributes interactively. Racing with deletion could mean a spurious -EBUSY, no problem. Racing with addition is handled just fine as well through the memcg_create_mutex: if the child group is not on the list after the mutex is acquired, it won't be initialized from the parent's attributes until after the unlock. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-31mm: memcg: lockdep annotation for memcg OOM lockJohannes Weiner
The memcg OOM lock is a mutex-type lock that is open-coded due to memcg's special needs. Add annotations for lockdep coverage. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-31mm: memcg: use proper memcg in limit bypassJohannes Weiner
Commit 84235de394d9 ("fs: buffer: move allocation failure loop into the allocator") allowed __GFP_NOFAIL allocations to bypass the limit if they fail to reclaim enough memory for the charge. But because the main test case was on a 3.2-based system, the patch missed the fact that on newer kernels the charge function needs to return root_mem_cgroup when bypassing the limit, and not NULL. This will corrupt whatever memory is at NULL + percpu pointer offset. Fix this quickly before problems are reported. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-31Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull NUMA balancing memory corruption fixes from Ingo Molnar: "So these fixes are definitely not something I'd like to sit on, but as I said to Mel at the KS the timing is quite tight, with Linus planning v3.12-final within a week. Fedora-19 is affected: comet:~> grep NUMA_BALANCING /boot/config-3.11.3-201.fc19.x86_64 CONFIG_ARCH_SUPPORTS_NUMA_BALANCING=y CONFIG_NUMA_BALANCING_DEFAULT_ENABLED=y CONFIG_NUMA_BALANCING=y AFAICS Ubuntu will be affected as well, once it updates the kernel: hubble:~> grep NUMA_BALANCING /boot/config-3.8.0-32-generic CONFIG_ARCH_SUPPORTS_NUMA_BALANCING=y CONFIG_NUMA_BALANCING_DEFAULT_ENABLED=y CONFIG_NUMA_BALANCING=y These 6 commits are a minimalized set of cherry-picks needed to fix the memory corruption bugs. All commits are fixes, except "mm: numa: Sanitize task_numa_fault() callsites" which is a cleanup that made two followup fixes simpler. I've done targeted testing with just this SHA1 to try to make sure there are no cherry-picking artifacts. The original non-cherry-picked set of fixes were exposed to linux-next for a couple of weeks" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: mm: Account for a THP NUMA hinting update as one PTE update mm: Close races between THP migration and PMD numa clearing mm: numa: Sanitize task_numa_fault() callsites mm: Prevent parallel splits during THP migration mm: Wait for THP migrations to complete during NUMA hinting faults mm: numa: Do not account for a hinting fault if we raced
2013-10-30Merge branch 'akpm' (fixes from Andrew Morton)Linus Torvalds
Merge three fixes from Andrew Morton. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: memcg: use __this_cpu_sub() to dec stats to avoid incorrect subtrahend casting percpu: fix this_cpu_sub() subtrahend casting for unsigneds mm/pagewalk.c: fix walk_page_range() access of wrong PTEs
2013-10-30memcg: use __this_cpu_sub() to dec stats to avoid incorrect subtrahend castingGreg Thelen
As of commit 3ea67d06e467 ("memcg: add per cgroup writeback pages accounting") memcg counter errors are possible when moving charged memory to a different memcg. Charge movement occurs when processing writes to memory.force_empty, moving tasks to a memcg with memcg.move_charge_at_immigrate=1, or memcg deletion. An example showing error after memory.force_empty: $ cd /sys/fs/cgroup/memory $ mkdir x $ rm /data/tmp/file $ (echo $BASHPID >> x/tasks && exec mmap_writer /data/tmp/file 1M) & [1] 13600 $ grep ^mapped x/memory.stat mapped_file 1048576 $ echo 13600 > tasks $ echo 1 > x/memory.force_empty $ grep ^mapped x/memory.stat mapped_file 4503599627370496 mapped_file should end with 0. 4503599627370496 == 0x10,0000,0000,0000 == 0x100,0000,0000 pages 1048576 == 0x10,0000 == 0x100 pages This issue only affects the source memcg on 64 bit machines; the destination memcg counters are correct. So the rmdir case is not too important because such counters are soon disappearing with the entire memcg. But the memcg.force_empty and memory.move_charge_at_immigrate=1 cases are larger problems as the bogus counters are visible for the (possibly long) remaining life of the source memcg. The problem is due to memcg use of __this_cpu_from(.., -nr_pages), which is subtly wrong because it subtracts the unsigned int nr_pages (either -1 or -512 for THP) from a signed long percpu counter. When nr_pages=-1, -nr_pages=0xffffffff. On 64 bit machines stat->count[idx] is signed 64 bit. So memcg's attempt to simply decrement a count (e.g. from 1 to 0) boils down to: long count = 1 unsigned int nr_pages = 1 count += -nr_pages /* -nr_pages == 0xffff,ffff */ count is now 0x1,0000,0000 instead of 0 The fix is to subtract the unsigned page count rather than adding its negation. This only works once "percpu: fix this_cpu_sub() subtrahend casting for unsigneds" is applied to fix this_cpu_sub(). Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-30mm/pagewalk.c: fix walk_page_range() access of wrong PTEsChen LinX
When walk_page_range walk a memory map's page tables, it'll skip VM_PFNMAP area, then variable 'next' will to assign to vma->vm_end, it maybe larger than 'end'. In next loop, 'addr' will be larger than 'next'. Then in /proc/XXXX/pagemap file reading procedure, the 'addr' will growing forever in pagemap_pte_range, pte_to_pagemap_entry will access the wrong pte. BUG: Bad page map in process procrank pte:8437526f pmd:785de067 addr:9108d000 vm_flags:00200073 anon_vma:f0d99020 mapping: (null) index:9108d CPU: 1 PID: 4974 Comm: procrank Tainted: G B W O 3.10.1+ #1 Call Trace: dump_stack+0x16/0x18 print_bad_pte+0x114/0x1b0 vm_normal_page+0x56/0x60 pagemap_pte_range+0x17a/0x1d0 walk_page_range+0x19e/0x2c0 pagemap_read+0x16e/0x200 vfs_read+0x84/0x150 SyS_read+0x4a/0x80 syscall_call+0x7/0xb Signed-off-by: Liu ShuoX <shuox.liu@intel.com> Signed-off-by: Chen LinX <linx.z.chen@intel.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: <stable@vger.kernel.org> [3.10.x+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-30mm: list_lru: fix almost infinite loop causing effective livelockRussell King
I've seen a fair number of issues with kswapd and other processes appearing to get stuck in v3.12-rc. Using sysrq-p many times seems to indicate that it gets stuck somewhere in list_lru_walk_node(), called from prune_icache_sb() and super_cache_scan(). I never seem to be able to trigger a calltrace for functions above that point. So I decided to add the following to super_cache_scan(): @@ -81,10 +81,14 @@ static unsigned long super_cache_scan(struct shrinker *shrink, inodes = list_lru_count_node(&sb->s_inode_lru, sc->nid); dentries = list_lru_count_node(&sb->s_dentry_lru, sc->nid); total_objects = dentries + inodes + fs_objects + 1; +printk("%s:%u: %s: dentries %lu inodes %lu total %lu\n", current->comm, current->pid, __func__, dentries, inodes, total_objects); /* proportion the scan between the caches */ dentries = mult_frac(sc->nr_to_scan, dentries, total_objects); inodes = mult_frac(sc->nr_to_scan, inodes, total_objects); +printk("%s:%u: %s: dentries %lu inodes %lu\n", current->comm, current->pid, __func__, dentries, inodes); +BUG_ON(dentries == 0); +BUG_ON(inodes == 0); /* * prune the dcache first as the icache is pinned by it, then @@ -99,7 +103,7 @@ static unsigned long super_cache_scan(struct shrinker *shrink, freed += sb->s_op->free_cached_objects(sb, fs_objects, sc->nid); } - +printk("%s:%u: %s: dentries %lu inodes %lu freed %lu\n", current->comm, current->pid, __func__, dentries, inodes, freed); drop_super(sb); return freed; } and shortly thereafter, having applied some pressure, I got this: update-apt-xapi:1616: super_cache_scan: dentries 25632 inodes 2 total 25635 update-apt-xapi:1616: super_cache_scan: dentries 1023 inodes 0 ------------[ cut here ]------------ Kernel BUG at c0101994 [verbose debug info unavailable] Internal error: Oops - BUG: 0 [#3] SMP ARM Modules linked in: fuse rfcomm bnep bluetooth hid_cypress CPU: 0 PID: 1616 Comm: update-apt-xapi Tainted: G D 3.12.0-rc7+ #154 task: daea1200 ti: c3bf8000 task.ti: c3bf8000 PC is at super_cache_scan+0x1c0/0x278 LR is at trace_hardirqs_on+0x14/0x18 Process update-apt-xapi (pid: 1616, stack limit = 0xc3bf8240) ... Backtrace: (super_cache_scan) from [<c00cd69c>] (shrink_slab+0x254/0x4c8) (shrink_slab) from [<c00d09a0>] (try_to_free_pages+0x3a0/0x5e0) (try_to_free_pages) from [<c00c59cc>] (__alloc_pages_nodemask+0x5) (__alloc_pages_nodemask) from [<c00e07c0>] (__pte_alloc+0x2c/0x13) (__pte_alloc) from [<c00e3a70>] (handle_mm_fault+0x84c/0x914) (handle_mm_fault) from [<c001a4cc>] (do_page_fault+0x1f0/0x3bc) (do_page_fault) from [<c001a7b0>] (do_translation_fault+0xac/0xb8) (do_translation_fault) from [<c000840c>] (do_DataAbort+0x38/0xa0) (do_DataAbort) from [<c00133f8>] (__dabt_usr+0x38/0x40) Notice that we had a very low number of inodes, which were reduced to zero my mult_frac(). Now, prune_icache_sb() calls list_lru_walk_node() passing that number of inodes (0) into that as the number of objects to scan: long prune_icache_sb(struct super_block *sb, unsigned long nr_to_scan, int nid) { LIST_HEAD(freeable); long freed; freed = list_lru_walk_node(&sb->s_inode_lru, nid, inode_lru_isolate, &freeable, &nr_to_scan); which does: unsigned long list_lru_walk_node(struct list_lru *lru, int nid, list_lru_walk_cb isolate, void *cb_arg, unsigned long *nr_to_walk) { struct list_lru_node *nlru = &lru->node[nid]; struct list_head *item, *n; unsigned long isolated = 0; spin_lock(&nlru->lock); restart: list_for_each_safe(item, n, &nlru->list) { enum lru_status ret; /* * decrement nr_to_walk first so that we don't livelock if we * get stuck on large numbesr of LRU_RETRY items */ if (--(*nr_to_walk) == 0) break; So, if *nr_to_walk was zero when this function was entered, that means we're wanting to operate on (~0UL)+1 objects - which might as well be infinite. Clearly this is not correct behaviour. If we think about the behaviour of this function when *nr_to_walk is 1, then clearly it's wrong - we decrement first and then test for zero - which results in us doing nothing at all. A post-decrement would give the desired behaviour - we'd try to walk one object and one object only if *nr_to_walk were one. It also gives the correct behaviour for zero - we exit at this point. Fixes: 5cedf721a7cd ("list_lru: fix broken LRU_RETRY behaviour") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Dave Chinner <dchinner@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> [ Modified to make sure we never underflow the count: this function gets called in a loop, so the 0 -> ~0ul transition is dangerous - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-29mm: Account for a THP NUMA hinting update as one PTE updateMel Gorman
A THP PMD update is accounted for as 512 pages updated in vmstat. This is large difference when estimating the cost of automatic NUMA balancing and can be misleading when comparing results that had collapsed versus split THP. This patch addresses the accounting issue. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-10-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-29mm: Close races between THP migration and PMD numa clearingMel Gorman
THP migration uses the page lock to guard against parallel allocations but there are cases like this still open Task A Task B --------------------- --------------------- do_huge_pmd_numa_page do_huge_pmd_numa_page lock_page mpol_misplaced == -1 unlock_page goto clear_pmdnuma lock_page mpol_misplaced == 2 migrate_misplaced_transhuge pmd = pmd_mknonnuma set_pmd_at During hours of testing, one crashed with weird errors and while I have no direct evidence, I suspect something like the race above happened. This patch extends the page lock to being held until the pmd_numa is cleared to prevent migration starting in parallel while the pmd_numa is being cleared. It also flushes the old pmd entry and orders pagetable insertion before rmap insertion. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-9-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-29mm: numa: Sanitize task_numa_fault() callsitesMel Gorman
There are three callers of task_numa_fault(): - do_huge_pmd_numa_page(): Accounts against the current node, not the node where the page resides, unless we migrated, in which case it accounts against the node we migrated to. - do_numa_page(): Accounts against the current node, not the node where the page resides, unless we migrated, in which case it accounts against the node we migrated to. - do_pmd_numa_page(): Accounts not at all when the page isn't migrated, otherwise accounts against the node we migrated towards. This seems wrong to me; all three sites should have the same sementaics, furthermore we should accounts against where the page really is, we already know where the task is. So modify all three sites to always account; we did after all receive the fault; and always account to where the page is after migration, regardless of success. They all still differ on when they clear the PTE/PMD; ideally that would get sorted too. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-8-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-29mm: Prevent parallel splits during THP migrationMel Gorman
THP migrations are serialised by the page lock but on its own that does not prevent THP splits. If the page is split during THP migration then the pmd_same checks will prevent page table corruption but the unlock page and other fix-ups potentially will cause corruption. This patch takes the anon_vma lock to prevent parallel splits during migration. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-7-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-29mm: Wait for THP migrations to complete during NUMA hinting faultsMel Gorman
The locking for migrating THP is unusual. While normal page migration prevents parallel accesses using a migration PTE, THP migration relies on a combination of the page_table_lock, the page lock and the existance of the NUMA hinting PTE to guarantee safety but there is a bug in the scheme. If a THP page is currently being migrated and another thread traps a fault on the same page it checks if the page is misplaced. If it is not, then pmd_numa is cleared. The problem is that it checks if the page is misplaced without holding the page lock meaning that the racing thread can be migrating the THP when the second thread clears the NUMA bit and faults a stale page. This patch checks if the page is potentially being migrated and stalls using the lock_page if it is potentially being migrated before checking if the page is misplaced or not. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-6-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-29mm: numa: Do not account for a hinting fault if we racedMel Gorman
If another task handled a hinting fault in parallel then do not double account for it. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-5-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-16mm: revert mremap pud_free anti-fixHugh Dickins
Revert commit 1ecfd533f4c5 ("mm/mremap.c: call pud_free() after fail calling pmd_alloc()"). The original code was correct: pud_alloc(), pmd_alloc(), pte_alloc_map() ensure that the pud, pmd, pt is already allocated, and seldom do they need to allocate; on failure, upper levels are freed if appropriate by the subsequent do_munmap(). Whereas commit 1ecfd533f4c5 did an unconditional pud_free() of a most-likely still-in-use pud: saved only by the near-impossiblity of pmd_alloc() failing. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Chen Gang <gang.chen@asianux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm: fix BUG in __split_huge_page_pmdHugh Dickins
Occasionally we hit the BUG_ON(pmd_trans_huge(*pmd)) at the end of __split_huge_page_pmd(): seen when doing madvise(,,MADV_DONTNEED). It's invalid: we don't always have down_write of mmap_sem there: a racing do_huge_pmd_wp_page() might have copied-on-write to another huge page before our split_huge_page() got the anon_vma lock. Forget the BUG_ON, just go back and try again if this happens. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16swap: fix set_blocksize race during swapon/swapoffKrzysztof Kozlowski
Fix race between swapoff and swapon. Swapoff used old_block_size from swap_info outside of swapon_mutex so it could be overwritten by concurrent swapon. The race has visible effect only if more than one swap block device exists with different block sizes (e.g. /dev/sda1 with block size 4096 and /dev/sdb1 with 512). In such case it leads to setting the blocksize of swapped off device with wrong blocksize. The bug can be triggered with multiple concurrent swapoff and swapon: 0. Swap for some device is on. 1. swapoff: First the swapoff is called on this device and "struct swap_info_struct *p" is assigned. This is done under swap_lock however this lock is released for the call try_to_unuse(). 2. swapon: After the assignment above (and before acquiring swapon_mutex & swap_lock by swapoff) the swapon is called on the same device. The p->old_block_size is assigned to the value of block_size the device. This block size should be the same as previous but sometimes it is not. The swapon ends successfully. 3. swapoff: Swapoff resumes, grabs the locks and mutex and continues to disable this swap device. Now it sets the block size to value taken from swap_info which was overwritten by swapon in 2. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reported-by: Weijie Yang <weijie.yang.kh@gmail.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Shaohua Li <shli@fusionio.com> Cc: Minchan Kim <minchan@kernel.org> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16writeback: fix negative bdi max pauseFengguang Wu
Toralf runs trinity on UML/i386. After some time it hangs and the last message line is BUG: soft lockup - CPU#0 stuck for 22s! [trinity-child0:1521] It's found that pages_dirtied becomes very large. More than 1000000000 pages in this case: period = HZ * pages_dirtied / task_ratelimit; BUG_ON(pages_dirtied > 2000000000); BUG_ON(pages_dirtied > 1000000000); <--------- UML debug printf shows that we got negative pause here: ick: pause : -984 ick: pages_dirtied : 0 ick: task_ratelimit: 0 pause: + if (pause < 0) { + extern int printf(char *, ...); + printf("ick : pause : %li\n", pause); + printf("ick: pages_dirtied : %lu\n", pages_dirtied); + printf("ick: task_ratelimit: %lu\n", task_ratelimit); + BUG_ON(1); + } trace_balance_dirty_pages(bdi, Since pause is bounded by [min_pause, max_pause] where min_pause is also bounded by max_pause. It's suspected and demonstrated that the max_pause calculation goes wrong: ick: pause : -717 ick: min_pause : -177 ick: max_pause : -717 ick: pages_dirtied : 14 ick: task_ratelimit: 0 The problem lies in the two "long = unsigned long" assignments in bdi_max_pause() which might go negative if the highest bit is 1, and the min_t(long, ...) check failed to protect it falling under 0. Fix all of them by using "unsigned long" throughout the function. Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Toralf Förster <toralf.foerster@gmx.de> Tested-by: Toralf Förster <toralf.foerster@gmx.de> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Richard Weinberger <richard@nod.at> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16fs: buffer: move allocation failure loop into the allocatorJohannes Weiner
Buffer allocation has a very crude indefinite loop around waking the flusher threads and performing global NOFS direct reclaim because it can not handle allocation failures. The most immediate problem with this is that the allocation may fail due to a memory cgroup limit, where flushers + direct reclaim might not make any progress towards resolving the situation at all. Because unlike the global case, a memory cgroup may not have any cache at all, only anonymous pages but no swap. This situation will lead to a reclaim livelock with insane IO from waking the flushers and thrashing unrelated filesystem cache in a tight loop. Use __GFP_NOFAIL allocations for buffers for now. This makes sure that any looping happens in the page allocator, which knows how to orchestrate kswapd, direct reclaim, and the flushers sensibly. It also allows memory cgroups to detect allocations that can't handle failure and will allow them to ultimately bypass the limit if reclaim can not make progress. Reported-by: azurIt <azurit@pobox.sk> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm: memcg: handle non-error OOM situations more gracefullyJohannes Weiner
Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full callstack on OOM") assumed that only a few places that can trigger a memcg OOM situation do not return VM_FAULT_OOM, like optional page cache readahead. But there are many more and it's impractical to annotate them all. First of all, we don't want to invoke the OOM killer when the failed allocation is gracefully handled, so defer the actual kill to the end of the fault handling as well. This simplifies the code quite a bit for added bonus. Second, since a failed allocation might not be the abrupt end of the fault, the memcg OOM handler needs to be re-entrant until the fault finishes for subsequent allocation attempts. If an allocation is attempted after the task already OOMed, allow it to bypass the limit so that it can quickly finish the fault and invoke the OOM killer. Reported-by: azurIt <azurit@pobox.sk> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm: hugetlb: initialize PG_reserved for tail pages of gigantic compound pagesAndrea Arcangeli
Commit 11feeb498086 ("kvm: optimize away THP checks in kvm_is_mmio_pfn()") introduced a memory leak when KVM is run on gigantic compound pages. That commit depends on the assumption that PG_reserved is identical for all head and tail pages of a compound page. So that if get_user_pages returns a tail page, we don't need to check the head page in order to know if we deal with a reserved page that requires different refcounting. The assumption that PG_reserved is the same for head and tail pages is certainly correct for THP and regular hugepages, but gigantic hugepages allocated through bootmem don't clear the PG_reserved on the tail pages (the clearing of PG_reserved is done later only if the gigantic hugepage is freed). This patch corrects the gigantic compound page initialization so that we can retain the optimization in 11feeb498086. The cacheline was already modified in order to set PG_tail so this won't affect the boot time of large memory systems. [akpm@linux-foundation.org: tweak comment layout and grammar] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: andy123 <ajs124.ajs124@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Acked-by: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm/zswap: bugfix: memory leak when re-swaponWeijie Yang
zswap_tree is not freed when swapoff, and it got re-kmalloced in swapon, so a memory leak occurs. Free the memory of zswap_tree in zswap_frontswap_invalidate_area(). Signed-off-by: Weijie Yang <weijie.yang@samsung.com> Reviewed-by: Bob Liu <bob.liu@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: <stable@vger.kernel.org> From: Weijie Yang <weijie.yang@samsung.com> Subject: mm/zswap: bugfix: memory leak when invalidate and reclaim occur concurrently Consider the following scenario: thread 0: reclaim entry x (get refcount, but not call zswap_get_swap_cache_page) thread 1: call zswap_frontswap_invalidate_page to invalidate entry x. finished, entry x and its zbud is not freed as its refcount != 0 now, the swap_map[x] = 0 thread 0: now call zswap_get_swap_cache_page swapcache_prepare return -ENOENT because entry x is not used any more zswap_get_swap_cache_page return ZSWAP_SWAPCACHE_NOMEM zswap_writeback_entry do nothing except put refcount Now, the memory of zswap_entry x and its zpage leak. Modify: - check the refcount in fail path, free memory if it is not referenced. - use ZSWAP_SWAPCACHE_FAIL instead of ZSWAP_SWAPCACHE_NOMEM as the fail path can be not only caused by nomem but also by invalidate. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Weijie Yang <weijie.yang@samsung.com> Reviewed-by: Bob Liu <bob.liu@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Cc: <stable@vger.kernel.org> Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm: migration: do not lose soft dirty bit if page is in migration stateCyrill Gorcunov
If page migration is turned on in config and the page is migrating, we may lose the soft dirty bit. If fork and mprotect are called on migrating pages (once migration is complete) pages do not obtain the soft dirty bit in the correspond pte entries. Fix it adding an appropriate test on swap entries. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm/hugetlb.c: correct missing private flag clearingJoonsoo Kim
We should clear the page's private flag when returing the page to the hugepage pool. Otherwise, marked hugepage can be allocated to the user who tries to allocate the non-reserved hugepage. If this user fail to map this hugepage, he would try to return the page to the hugepage pool. Since this page has a private flag, resv_huge_pages would mistakenly increase. This patch fixes this situation. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm/vmscan.c: don't forget to free shrinker->nr_deferredAndrew Vagin
This leak was added by commit 1d3d4437eae1 ("vmscan: per-node deferred work"). unreferenced object 0xffff88006ada3bd0 (size 8): comm "criu", pid 14781, jiffies 4295238251 (age 105.641s) hex dump (first 8 bytes): 00 00 00 00 00 00 00 00 ........ backtrace: [<ffffffff8170caee>] kmemleak_alloc+0x5e/0xc0 [<ffffffff811c0527>] __kmalloc+0x247/0x310 [<ffffffff8117848c>] register_shrinker+0x3c/0xa0 [<ffffffff811e115b>] sget+0x5ab/0x670 [<ffffffff812532f4>] proc_mount+0x54/0x170 [<ffffffff811e1893>] mount_fs+0x43/0x1b0 [<ffffffff81202dd2>] vfs_kern_mount+0x72/0x110 [<ffffffff81202e89>] kern_mount_data+0x19/0x30 [<ffffffff812530a0>] pid_ns_prepare_proc+0x20/0x40 [<ffffffff81083c56>] alloc_pid+0x466/0x4a0 [<ffffffff8105aeda>] copy_process+0xc6a/0x1860 [<ffffffff8105beab>] do_fork+0x8b/0x370 [<ffffffff8105c1a6>] SyS_clone+0x16/0x20 [<ffffffff8171f739>] stub_clone+0x69/0x90 [<ffffffffffffffff>] 0xffffffffffffffff Signed-off-by: Andrew Vagin <avagin@openvz.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Glauber Costa <glommer@openvz.org> Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm, memcg: protect mem_cgroup_read_events for cpu hotplugDavid Rientjes
for_each_online_cpu() needs the protection of {get,put}_online_cpus() so cpu_online_mask doesn't change during the iteration. cpu_hotplug.lock is held while a cpu is going down, it's a coarse lock that is used kernel-wide to synchronize cpu hotplug activity. Memcg has a cpu hotplug notifier, called while there may not be any cpu hotplug refcounts, which drains per-cpu event counts to memcg->nocpu_base.events to maintain a cumulative event count as cpus disappear. Without get_online_cpus() in mem_cgroup_read_events(), it's possible to account for the event count on a dying cpu twice, and this value may be significantly large. In fact, all memcg->pcp_counter_lock use should be nested by {get,put}_online_cpus(). This fixes that issue and ensures the reported statistics are not vastly over-reported during cpu hotplug. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-14Merge branch 'slab/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull SLAB fix from Pekka Enberg: "A regression fix for overly eager slab cache name checks" * 'slab/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: slab_common: Do not check for duplicate slab names
2013-10-03Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fixes from Ben Herrenschmidt: "Here are a few powerpc fixes, all aimed at -stable, found in part thanks to the ramping up of a major distro testing and in part thanks to the LE guys hitting all sort interesting corner cases. The most scary are probably the register clobber issues in csum_partial_copy_generic(), especially since Anton even had a test case for that thing, which didn't manage to hit the bugs :-) Another highlight is that memory hotplug should work again with these fixes. Oh and the vio modalias one is worse than the cset implies as it upsets distro installers, so I've been told at least, which is why I'm shooting it to stable" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/tm: Switch out userspace PPR and DSCR sooner powerpc/tm: Turn interrupts hard off in tm_reclaim() powerpc/perf: Fix handling of FAB events powerpc/vio: Fix modalias_show return values powerpc/iommu: Use GFP_KERNEL instead of GFP_ATOMIC in iommu_init_table() powerpc/sysfs: Disable writing to PURR in guest mode powerpc: Restore registers on error exit from csum_partial_copy_generic() powerpc: Fix parameter clobber in csum_partial_copy_generic() powerpc: Fix memory hotplug with sparse vmemmap
2013-10-03powerpc: Fix memory hotplug with sparse vmemmapNathan Fontenot
Previous commit 46723bfa540... introduced a new config option HAVE_BOOTMEM_INFO_NODE that ended up breaking memory hot-remove for ppc when sparse vmemmap is not defined. This patch defines HAVE_BOOTMEM_INFO_NODE for ppc and adds the call to register_page_bootmem_info_node. Without this we get a BUG_ON for memory hot remove in put_page_bootmem(). This also adds a stub for register_page_bootmem_memmap to allow ppc to build with sparse vmemmap defined. Leaving this as a stub is fine since the same vmemmap addresses are also handled in vmemmap_populate and as such are properly mapped. Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: <stable@vger.kernel.org> [v3.9+]
2013-09-30mm/hwpoison: fix the lack of one reference count against poisoned pageWanpeng Li
The lack of one reference count against poisoned page for hwpoison_inject w/o hwpoison_filter enabled result in hwpoison detect -1 users still referenced the page, however, the number should be 0 except the poison handler held one after successfully unmap. This patch fix it by hold one referenced count against poisoned page for hwpoison_inject w/ and w/o hwpoison_filter enabled. Before patch: [ 71.902112] Injecting memory failure at pfn 224706 [ 71.902137] MCE 0x224706: dirty LRU page recovery: Failed [ 71.902138] MCE 0x224706: dirty LRU page still referenced by -1 users After patch: [ 94.710860] Injecting memory failure at pfn 215b68 [ 94.710885] MCE 0x215b68: dirty LRU page recovery: Recovered Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30mm/hwpoison: fix false report on 2nd attempt at page recoveryWanpeng Li
If the page is poisoned by software injection w/ MF_COUNT_INCREASED flag, there is a false report during the 2nd attempt at page recovery which is not truthful. This patch fixes it by reporting the first attempt to try free buddy page recovery if MF_COUNT_INCREASED is set. Before patch: [ 346.332041] Injecting memory failure at pfn 200010 [ 346.332189] MCE 0x200010: free buddy, 2nd try page recovery: Delayed After patch: [ 297.742600] Injecting memory failure at pfn 200010 [ 297.742941] MCE 0x200010: free buddy page recovery: Delayed Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30mm/hwpoison: fix test for a transparent huge pageWanpeng Li
PageTransHuge() can't guarantee the page is a transparent huge page since it returns true for both transparent huge and hugetlbfs pages. This patch fixes it by checking the page is also !hugetlbfs page. Before patch: [ 121.571128] Injecting memory failure at pfn 23a200 [ 121.571141] MCE 0x23a200: huge page recovery: Delayed [ 140.355100] MCE: Memory failure is now running on 0x23a200 After patch: [ 94.290793] Injecting memory failure at pfn 23a000 [ 94.290800] MCE 0x23a000: huge page recovery: Delayed [ 105.722303] MCE: Software-unpoisoned page 0x23a000 Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30mm/hwpoison: fix traversal of hugetlbfs pages to avoid printk floodWanpeng Li
madvise_hwpoison won't check if the page is small page or huge page and traverses in small page granularity against the range unconditionally, which result in a printk flood "MCE xxx: already hardware poisoned" if the page is a huge page. This patch fixes it by using compound_order(compound_head(page)) for huge page iterator. Testcase: #define _GNU_SOURCE #include <stdlib.h> #include <stdio.h> #include <sys/mman.h> #include <unistd.h> #include <fcntl.h> #include <sys/types.h> #include <errno.h> #define PAGES_TO_TEST 3 #define PAGE_SIZE 4096 * 512 int main(void) { char *mem; int i; mem = mmap(NULL, PAGES_TO_TEST * PAGE_SIZE, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS | MAP_HUGETLB, 0, 0); if (madvise(mem, PAGES_TO_TEST * PAGE_SIZE, MADV_HWPOISON) == -1) return -1; munmap(mem, PAGES_TO_TEST * PAGE_SIZE); return 0; } Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30mm/mlock.c: prevent walking off the end of a pagetable in no-pmd configurationVlastimil Babka
The function __munlock_pagevec_fill() introduced in commit 7a8010cd3627 ("mm: munlock: manual pte walk in fast path instead of follow_page_mask()") uses pmd_addr_end() for restricting its operation within current page table. This is insufficient on architectures/configurations where pmd is folded and pmd_addr_end() just returns the end of the full range to be walked. In this case, it allows pte++ to walk off the end of a page table resulting in unpredictable behaviour. This patch fixes the function by using pgd_addr_end() and pud_addr_end() before pmd_addr_end(), which will yield correct page table boundary on all configurations. This is similar to what existing page walkers do when walking each level of the page table. Additionaly, the patch clarifies a comment for get_locked_pte() call in the function. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reviewed-by: Bob Liu <bob.liu@oracle.com> Cc: Jörn Engel <joern@logfs.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michel Lespinasse <walken@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30mm: avoid reinserting isolated balloon pages into LRU listsRafael Aquini
Isolated balloon pages can wrongly end up in LRU lists when migrate_pages() finishes its round without draining all the isolated page list. The same issue can happen when reclaim_clean_pages_from_list() tries to reclaim pages from an isolated page list, before migration, in the CMA path. Such balloon page leak opens a race window against LRU lists shrinkers that leads us to the following kernel panic: BUG: unable to handle kernel NULL pointer dereference at 0000000000000028 IP: [<ffffffff810c2625>] shrink_page_list+0x24e/0x897 PGD 3cda2067 PUD 3d713067 PMD 0 Oops: 0000 [#1] SMP CPU: 0 PID: 340 Comm: kswapd0 Not tainted 3.12.0-rc1-22626-g4367597 #87 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 RIP: shrink_page_list+0x24e/0x897 RSP: 0000:ffff88003da499b8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: ffff88003e82bd60 RCX: 00000000000657d5 RDX: 0000000000000000 RSI: 000000000000031f RDI: ffff88003e82bd40 RBP: ffff88003da49ab0 R08: 0000000000000001 R09: 0000000081121a45 R10: ffffffff81121a45 R11: ffff88003c4a9a28 R12: ffff88003e82bd40 R13: ffff88003da0e800 R14: 0000000000000001 R15: ffff88003da49d58 FS: 0000000000000000(0000) GS:ffff88003fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000067d9000 CR3: 000000003ace5000 CR4: 00000000000407b0 Call Trace: shrink_inactive_list+0x240/0x3de shrink_lruvec+0x3e0/0x566 __shrink_zone+0x94/0x178 shrink_zone+0x3a/0x82 balance_pgdat+0x32a/0x4c2 kswapd+0x2f0/0x372 kthread+0xa2/0xaa ret_from_fork+0x7c/0xb0 Code: 80 7d 8f 01 48 83 95 68 ff ff ff 00 4c 89 e7 e8 5a 7b 00 00 48 85 c0 49 89 c5 75 08 80 7d 8f 00 74 3e eb 31 48 8b 80 18 01 00 00 <48> 8b 74 0d 48 8b 78 30 be 02 00 00 00 ff d2 eb RIP [<ffffffff810c2625>] shrink_page_list+0x24e/0x897 RSP <ffff88003da499b8> CR2: 0000000000000028 ---[ end trace 703d2451af6ffbfd ]--- Kernel panic - not syncing: Fatal exception This patch fixes the issue, by assuring the proper tests are made at putback_movable_pages() & reclaim_clean_pages_from_list() to avoid isolated balloon pages being wrongly reinserted in LRU lists. [akpm@linux-foundation.org: clarify awkward comment text] Signed-off-by: Rafael Aquini <aquini@redhat.com> Reported-by: Luiz Capitulino <lcapitulino@redhat.com> Tested-by: Luiz Capitulino <lcapitulino@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30mm/bounce.c: fix a regression where MS_SNAP_STABLE (stable pages ↵Darrick J. Wong
snapshotting) was ignored The "force" parameter in __blk_queue_bounce was being ignored, which means that stable page snapshots are not always happening (on ext3). This of course leads to DIF disks reporting checksum errors, so fix this regression. The regression was introduced in commit 6bc454d15004 ("bounce: Refactor __blk_queue_bounce to not use bi_io_vec") Reported-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Cc: Kent Overstreet <koverstreet@google.com> Cc: <stable@vger.kernel.org> [3.10+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30mm/compaction.c: periodically schedule when freeing pagesDavid Rientjes
We've been getting warnings about an excessive amount of time spent allocating pages for migration during memory compaction without scheduling. isolate_freepages_block() already periodically checks for contended locks or the need to schedule, but isolate_freepages() never does. When a zone is massively long and no suitable targets can be found, this iteration can be quite expensive without ever doing cond_resched(). Check periodically for the need to reschedule while the compaction free scanner iterates. Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30revert "mm/memory-hotplug: fix lowmem count overflow when offline pages"Joonyoung Shim
This reverts commit cea27eb2a202 ("mm/memory-hotplug: fix lowmem count overflow when offline pages"). The fixed bug by commit cea27eb was fixed to another way by commit 3dcc0571cd64 ("mm: correctly update zone->managed_pages"). That commit enhances memory_hotplug.c to adjust totalhigh_pages when hot-removing memory, for details please refer to: http://marc.info/?l=linux-mm&m=136957578620221&w=2 As a result, commit cea27eb2a202 currently causes duplicated decreasing of totalhigh_pages, thus the revert. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Jiang Liu <liuj97@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-28slab_common: Do not check for duplicate slab namesChristoph Lameter
SLUB can alias multiple slab kmem_create_requests to one slab cache to save memory and increase the cache hotness. As a result the name of the slab can be stale. Only check the name for duplicates if we are in debug mode where we do not merge multiple caches. This fixes the following problem reported by Jonathan Brassow: The problem with kmem_cache* is this: *) Assume CONFIG_SLUB is set 1) kmem_cache_create(name="foo-a") - creates new kmem_cache structure 2) kmem_cache_create(name="foo-b") - If identical cache characteristics, it will be merged with the previously created cache associated with "foo-a". The cache's refcount will be incremented and an alias will be created via sysfs_slab_alias(). 3) kmem_cache_destroy(<ptr>) - Attempting to destroy cache associated with "foo-a", but instead the refcount is simply decremented. I don't even think the sysfs aliases are ever removed... 4) kmem_cache_create(name="foo-a") - This FAILS because kmem_cache_sanity_check colides with the existing name ("foo-a") associated with the non-removed cache. This is a problem for RAID (specifically dm-raid) because the name used for the kmem_cache_create is ("raid%d-%p", level, mddev). If the cache persists for long enough, the memory address of an old mddev will be reused for a new mddev - causing an identical formulation of the cache name. Even though kmem_cache_destory had long ago been used to delete the old cache, the merging of caches has cause the name and cache of that old instance to be preserved and causes a colision (and thus failure) in kmem_cache_create(). I see this regularly in my testing. Reported-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2013-09-24mm: Place preemption point in do_mlockall() loopPaul E. McKenney
There is a loop in do_mlockall() that lacks a preemption point, which means that the following can happen on non-preemptible builds of the kernel. Dave Jones reports: "My fuzz tester keeps hitting this. Every instance shows the non-irq stack came in from mlockall. I'm only seeing this on one box, but that has more ram (8gb) than my other machines, which might explain it. INFO: rcu_preempt self-detected stall on CPU { 3} (t=6500 jiffies g=470344 c=470343 q=0) sending NMI to all CPUs: NMI backtrace for cpu 3 CPU: 3 PID: 29664 Comm: trinity-child2 Not tainted 3.11.0-rc1+ #32 Call Trace: lru_add_drain_all+0x15/0x20 SyS_mlockall+0xa5/0x1a0 tracesys+0xdd/0xe2" This commit addresses this problem by inserting the required preemption point. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Michel Lespinasse <walken@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "memcg, vmscan: integrate soft reclaim tighter with zone shrinking code"Andrew Morton
Revert commit 3b38722efd9f ("memcg, vmscan: integrate soft reclaim tighter with zone shrinking code") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "memcg: get rid of soft-limit tree infrastructure"Andrew Morton
Revert commit e883110aad71 ("memcg: get rid of soft-limit tree infrastructure") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "vmscan, memcg: do softlimit reclaim also for targeted reclaim"Andrew Morton
Revert commit a5b7c87f9207 ("vmscan, memcg: do softlimit reclaim also for targeted reclaim") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "memcg: enhance memcg iterator to support predicates"Andrew Morton
Revert commit de57780dc659 ("memcg: enhance memcg iterator to support predicates") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "memcg: track children in soft limit excess to improve soft limit"Andrew Morton
Revert commit 7d910c054be4 ("memcg: track children in soft limit excess to improve soft limit") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "memcg, vmscan: do not attempt soft limit reclaim if it would not ↵Andrew Morton
scan anything" Revert commit e839b6a1c8d0 ("memcg, vmscan: do not attempt soft limit reclaim if it would not scan anything") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "memcg: track all children over limit in the root"Andrew Morton
Revert commit 1be171d60bdd ("memcg: track all children over limit in the root") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "memcg, vmscan: do not fall into reclaim-all pass too quickly"Andrew Morton
Revert commit e975de998b96 ("memcg, vmscan: do not fall into reclaim-all pass too quickly") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
