path: root/mm
2015-02-11mm: pagewalk: call pte_hole() for VM_PFNMAP during walk_page_rangeShiraz Hashim
commit 23aaed6659df9adfabe9c583e67a36b54e21df46 upstream. walk_page_range() silently skips vma having VM_PFNMAP set, which leads to undesirable behaviour at client end (who called walk_page_range). Userspace applications get the wrong data, so the effect is like just confusing users (if the applications just display the data) or sometimes killing the processes (if the applications do something with misunderstanding virtual addresses due to the wrong data.) For example for pagemap_read, when no callbacks are called against VM_PFNMAP vma, pagemap_read may prepare pagemap data for next virtual address range at wrong index. Eventually userspace may get wrong pagemap data for a task. Corresponding to a VM_PFNMAP marked vma region, kernel may report mappings from subsequent vma regions. User space in turn may account more pages (than really are) to the task. In my case I was using procmem, procrack (Android utility) which uses pagemap interface to account RSS pages of a task. Due to this bug it was giving a wrong picture for vmas (with VM_PFNMAP set). Fixes: a9ff785e4437 ("mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas") Signed-off-by: Shiraz Hashim <shashim@codeaurora.org> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: get rid of radix tree gfp mask for pagecache_get_pageMichal Hocko
commit 45f87de57f8fad59302fd263dd81ffa4843b5b24 upstream. Commit 2457aec63745 ("mm: non-atomically mark page accessed during page cache allocation where possible") has added a separate parameter for specifying gfp mask for radix tree allocations. Not only this is less than optimal from the API point of view because it is error prone, it is also buggy currently because grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then the radix tree allocation wouldn't obey the restriction and might recurse into filesystem and cause deadlocks. This is the case for most filesystems unfortunately because only ext4 and gfs2 are using AOP_FLAG_NOFS. Let's simply remove radix_gfp_mask parameter because the allocation context is same for both page cache and for the radix tree. Just make sure that the radix tree gets only the sane subset of the mask (e.g. do not pass __GFP_WRITE). Long term it is more preferable to convert remaining users of AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this interface even further. Reported-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: reduce cost of the fair zone allocation policyMel Gorman
commit 4ffeaf3560a52b4a69cc7909873d08c0ef5909d4 upstream. The fair zone allocation policy round-robins allocations between zones within a node to avoid age inversion problems during reclaim. If the first allocation fails, the batch counts are reset and a second attempt made before entering the slow path. One assumption made with this scheme is that batches expire at roughly the same time and the resets each time are justified. This assumption does not hold when zones reach their low watermark as the batches will be consumed at uneven rates. Allocation failure due to watermark depletion result in additional zonelist scans for the reset and another watermark check before hitting the slowpath. On UMA, the benefit is negligible -- around 0.25%. On 4-socket NUMA machine it's variable due to the variability of measuring overhead with the vmstat changes. The system CPU overhead comparison looks like 3.16.0-rc3 3.16.0-rc3 3.16.0-rc3 vanilla vmstat-v5 lowercost-v5 User 746.94 774.56 802.00 System 65336.22 32847.27 40852.33 Elapsed 27553.52 27415.04 27368.46 However it is worth noting that the overall benchmark still completed faster and intuitively it makes sense to take as few passes as possible through the zonelists. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: abort fair zone allocation policy when remotes nodes are ↵Mel Gorman
encountered commit f7b5d647946aae1647bf5cd26c16b3a793c1ac49 upstream. The purpose of numa_zonelist_order=zone is to preserve lower zones for use with 32-bit devices. If locality is preferred then the numa_zonelist_order=node policy should be used. Unfortunately, the fair zone allocation policy overrides this by skipping zones on remote nodes until the lower one is found. While this makes sense from a page aging and performance perspective, it breaks the expected zonelist policy. This patch restores the expected behaviour for zone-list ordering. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: vmscan: only update per-cpu thresholds for online CPUMel Gorman
commit bb0b6dffa2ccfbd9747ad0cc87c7459622896e60 upstream. When kswapd is awake reclaiming, the per-cpu stat thresholds are lowered to get more accurate counts to avoid breaching watermarks. This threshold update iterates over all possible CPUs which is unnecessary. Only online CPUs need to be updated. If a new CPU is onlined, refresh_zone_stat_thresholds() will set the thresholds correctly. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: move zone->pages_scanned into a vmstat counterMel Gorman
commit 0d5d823ab4e608ec7b52ac4410de4cb74bbe0edd upstream. zone->pages_scanned is a write-intensive cache line during page reclaim and it's also updated during page free. Move the counter into vmstat to take advantage of the per-cpu updates and do not update it in the free paths unless necessary. On a small UMA machine running tiobench the difference is marginal. On a 4-node machine the overhead is more noticable. Note that automatic NUMA balancing was disabled for this test as otherwise the system CPU overhead is unpredictable. 3.16.0-rc3 3.16.0-rc3 3.16.0-rc3 vanillarearrange-v5 vmstat-v5 User 746.94 759.78 774.56 System 65336.22 58350.98 32847.27 Elapsed 27553.52 27282.02 27415.04 Note that the overhead reduction will vary depending on where exactly pages are allocated and freed. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: rearrange zone fields into read-only, page alloc, statistics and page ↵Mel Gorman
reclaim lines commit 3484b2de9499df23c4604a513b36f96326ae81ad upstream. The arrangement of struct zone has changed over time and now it has reached the point where there is some inappropriate sharing going on. On x86-64 for example o The zone->node field is shared with the zone lock and zone->node is accessed frequently from the page allocator due to the fair zone allocation policy. o span_seqlock is almost never used by shares a line with free_area o Some zone statistics share a cache line with the LRU lock so reclaim-intensive and allocator-intensive workloads can bounce the cache line on a stat update This patch rearranges struct zone to put read-only and read-mostly fields together and then splits the page allocator intensive fields, the zone statistics and the page reclaim intensive fields into their own cache lines. Note that the type of lowmem_reserve changes due to the watermark calculations being signed and avoiding a signed/unsigned conversion there. On the test configuration I used the overall size of struct zone shrunk by one cache line. On smaller machines, this is not likely to be noticable. However, on a 4-node NUMA machine running tiobench the system CPU overhead is reduced by this patch. 3.16.0-rc3 3.16.0-rc3 vanillarearrange-v5r9 User 746.94 759.78 System 65336.22 58350.98 Elapsed 27553.52 27282.02 Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: pagemap: avoid unnecessary overhead when tracepoints are deactivatedMel Gorman
commit 24b7e5819ad5cbef2b7c7376510862aa8319d240 upstream. This was formerly the series "Improve sequential read throughput" which noted some major differences in performance of tiobench since 3.0. While there are a number of factors, two that dominated were the introduction of the fair zone allocation policy and changes to CFQ. The behaviour of fair zone allocation policy makes more sense than tiobench as a benchmark and CFQ defaults were not changed due to insufficient benchmarking. This series is what's left. It's one functional fix to the fair zone allocation policy when used on NUMA machines and a reduction of overhead in general. tiobench was used for the comparison despite its flaws as an IO benchmark as in this case we are primarily interested in the overhead of page allocator and page reclaim activity. On UMA, it makes little difference to overhead 3.16.0-rc3 3.16.0-rc3 vanilla lowercost-v5 User 383.61 386.77 System 403.83 401.74 Elapsed 5411.50 5413.11 On a 4-socket NUMA machine it's a bit more noticable 3.16.0-rc3 3.16.0-rc3 vanilla lowercost-v5 User 746.94 802.00 System 65336.22 40852.33 Elapsed 27553.52 27368.46 This patch (of 6): The LRU insertion and activate tracepoints take PFN as a parameter forcing the overhead to the caller. Move the overhead to the tracepoint fast-assign method to ensure the cost is only incurred when the tracepoint is active. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29memcg, vmscan: Fix forced scan of anonymous pagesJerome Marchand
commit 2ab051e11bfa3cbb7b24177f3d6aaed10a0d743e upstream. When memory cgoups are enabled, the code that decides to force to scan anonymous pages in get_scan_count() compares global values (free, high_watermark) to a value that is restricted to a memory cgroup (file). It make the code over-eager to force anon scan. For instance, it will force anon scan when scanning a memcg that is mainly populated by anonymous page, even when there is plenty of file pages to get rid of in others memcgs, even when swappiness == 0. It breaks user's expectation about swappiness and hurts performance. This patch makes sure that forced anon scan only happens when there not enough file pages for the all zone, not just in one random memcg. [hannes@cmpxchg.org: cleanups] Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29vmalloc: use rcu list iterator to reduce vmap_area_lock contentionJoonsoo Kim
commit 474750aba88817c53f39424e5567b8e4acc4b39b upstream. Richard Yao reported a month ago that his system have a trouble with vmap_area_lock contention during performance analysis by /proc/meminfo. Andrew asked why his analysis checks /proc/meminfo stressfully, but he didn't answer it. https://lkml.org/lkml/2014/4/10/416 Although I'm not sure that this is right usage or not, there is a solution reducing vmap_area_lock contention with no side-effect. That is just to use rcu list iterator in get_vmalloc_info(). rcu can be used in this function because all RCU protocol is already respected by writers, since Nick Piggin commit db64fe02258f1 ("mm: rewrite vmap layer") back in linux-2.6.28 Specifically : insertions use list_add_rcu(), deletions use list_del_rcu() and kfree_rcu(). Note the rb tree is not used from rcu reader (it would not be safe), only the vmap_area_list has full RCU protection. Note that __purge_vmap_area_lazy() already uses this rcu protection. rcu_read_lock(); list_for_each_entry_rcu(va, &vmap_area_list, list) { if (va->flags & VM_LAZY_FREE) { if (va->va_start < *start) *start = va->va_start; if (va->va_end > *end) *end = va->va_end; nr += (va->va_end - va->va_start) >> PAGE_SHIFT; list_add_tail(&va->purge_list, &valist); va->flags |= VM_LAZY_FREEING; va->flags &= ~VM_LAZY_FREE; } } rcu_read_unlock(); Peter: : While rcu list traversal over the vmap_area_list is safe, this may : arrive at different results than the spinlocked version. The rcu list : traversal version will not be a 'snapshot' of a single, valid instant : of the entire vmap_area_list, but rather a potential amalgam of : different list states. Joonsoo: : Yes, you are right, but I don't think that we should be strict here. : Meminfo is already not a 'snapshot' at specific time. While we try to get : certain stats, the other stats can change. And, although we may arrive at : different results than the spinlocked version, the difference would not be : large and would not make serious side-effect. [edumazet@google.com: add more commit description] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reported-by: Richard Yao <ryao@gentoo.org> Acked-by: Eric Dumazet <edumazet@google.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Zhang Yanfei <zhangyanfei.yes@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: make copy_pte_range static againJerome Marchand
commit 21bda264f4243f61dfcc485174055f12ad0530b4 upstream. Commit 71e3aac0724f ("thp: transparent hugepage core") adds copy_pte_range prototype to huge_mm.h. I'm not sure why (or if) this function have been used outside of memory.c, but it currently isn't. This patch makes copy_pte_range() static again. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm, thp: only collapse hugepages to nodes with affinity for zone_reclaim_modeDavid Rientjes
commit 14a4e2141e24304fff2c697be6382ffb83888185 upstream. Commit 9f1b868a13ac ("mm: thp: khugepaged: add policy for finding target node") improved the previous khugepaged logic which allocated a transparent hugepages from the node of the first page being collapsed. However, it is still possible to collapse pages to remote memory which may suffer from additional access latency. With the current policy, it is possible that 255 pages (with PAGE_SHIFT == 12) will be collapsed remotely if the majority are allocated from that node. When zone_reclaim_mode is enabled, it means the VM should make every attempt to allocate locally to prevent NUMA performance degradation. In this case, we do not want to collapse hugepages to remote nodes that would suffer from increased access latency. Thus, when zone_reclaim_mode is enabled, only allow collapsing to nodes with RECLAIM_DISTANCE or less. There is no functional change for systems that disable zone_reclaim_mode. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Bob Liu <bob.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm/memory.c: use entry = ACCESS_ONCE(*pte) in handle_pte_fault()Hugh Dickins
commit c0d73261f5c1355a35b8b40e871d31578ce0c044 upstream. Use ACCESS_ONCE() in handle_pte_fault() when getting the entry or orig_pte upon which all subsequent decisions and pte_same() tests will be made. I have no evidence that its lack is responsible for the mm/filemap.c:202 BUG_ON(page_mapped(page)) in __delete_from_page_cache() found by trinity, and I am not optimistic that it will fix it. But I have found no other explanation, and ACCESS_ONCE() here will surely not hurt. If gcc does re-access the pte before passing it down, then that would be disastrous for correct page fault handling, and certainly could explain the page_mapped() BUGs seen (concurrent fault causing page to be mapped in a second time on top of itself: mapcount 2 for a single pte). Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29shmem: fix init_page_accessed use to stop !PageLRU bugHugh Dickins
commit 66d2f4d28cd030220e7ea2a628993fcabcb956d1 upstream. Under shmem swapping load, I sometimes hit the VM_BUG_ON_PAGE(!PageLRU) in isolate_lru_pages() at mm/vmscan.c:1281! Commit 2457aec63745 ("mm: non-atomically mark page accessed during page cache allocation where possible") looks like interrupted work-in-progress. mm/filemap.c's call to init_page_accessed() is fine, but not mm/shmem.c's - shmem_write_begin() is clearly wrong to use it after shmem_getpage(), when the page is always visible in radix_tree, and often already on LRU. Revert change to shmem_write_begin(), and use init_page_accessed() or mark_page_accessed() appropriately for SGP_WRITE in shmem_getpage_gfp(). SGP_WRITE also covers shmem_symlink(), which did not mark_page_accessed() before; but since many other filesystems use [__]page_symlink(), which did and does mark the page accessed, consider this as rectifying an oversight. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Prabhakar Lad <prabhakar.csengg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: avoid unnecessary atomic operations during end_page_writeback()Mel Gorman
commit 888cf2db475a256fb0cda042140f73d7881f81fe upstream. If a page is marked for immediate reclaim then it is moved to the tail of the LRU list. This occurs when the system is under enough memory pressure for pages under writeback to reach the end of the LRU but we test for this using atomic operations on every writeback. This patch uses an optimistic non-atomic test first. It'll miss some pages in rare cases but the consequences are not severe enough to warrant such a penalty. While the function does not dominate profiles during a simple dd test the cost of it is reduced. 73048 0.7428 vmlinux-3.15.0-rc5-mmotm-20140513 end_page_writeback 23740 0.2409 vmlinux-3.15.0-rc5-lessatomic end_page_writeback Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: non-atomically mark page accessed during page cache allocation where ↵Mel Gorman
possible commit 2457aec63745e235bcafb7ef312b182d8682f0fc upstream. aops->write_begin may allocate a new page and make it visible only to have mark_page_accessed called almost immediately after. Once the page is visible the atomic operations are necessary which is noticable overhead when writing to an in-memory filesystem like tmpfs but should also be noticable with fast storage. The objective of the patch is to initialse the accessed information with non-atomic operations before the page is visible. The bulk of filesystems directly or indirectly use grab_cache_page_write_begin or find_or_create_page for the initial allocation of a page cache page. This patch adds an init_page_accessed() helper which behaves like the first call to mark_page_accessed() but may called before the page is visible and can be done non-atomically. The primary APIs of concern in this care are the following and are used by most filesystems. find_get_page find_lock_page find_or_create_page grab_cache_page_nowait grab_cache_page_write_begin All of them are very similar in detail to the patch creates a core helper pagecache_get_page() which takes a flags parameter that affects its behavior such as whether the page should be marked accessed or not. Then old API is preserved but is basically a thin wrapper around this core function. Each of the filesystems are then updated to avoid calling mark_page_accessed when it is known that the VM interfaces have already done the job. There is a slight snag in that the timing of the mark_page_accessed() has now changed so in rare cases it's possible a page gets to the end of the LRU as PageReferenced where as previously it might have been repromoted. This is expected to be rare but it's worth the filesystem people thinking about it in case they see a problem with the timing change. It is also the case that some filesystems may be marking pages accessed that previously did not but it makes sense that filesystems have consistent behaviour in this regard. The test case used to evaulate this is a simple dd of a large file done multiple times with the file deleted on each iterations. The size of the file is 1/10th physical memory to avoid dirty page balancing. In the async case it will be possible that the workload completes without even hitting the disk and will have variable results but highlight the impact of mark_page_accessed for async IO. The sync results are expected to be more stable. The exception is tmpfs where the normal case is for the "IO" to not hit the disk. The test machine was single socket and UMA to avoid any scheduling or NUMA artifacts. Throughput and wall times are presented for sync IO, only wall times are shown for async as the granularity reported by dd and the variability is unsuitable for comparison. As async results were variable do to writback timings, I'm only reporting the maximum figures. The sync results were stable enough to make the mean and stddev uninteresting. The performance results are reported based on a run with no profiling. Profile data is based on a separate run with oprofile running. async dd 3.15.0-rc3 3.15.0-rc3 vanilla accessed-v2 ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%) tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%) btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%) ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%) xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%) The XFS figure is a bit strange as it managed to avoid a worst case by sheer luck but the average figures looked reasonable. samples percentage ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed [akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: do not use unnecessary atomic operations when adding pages to the LRUMel Gorman
commit 6fb81a17d21f2a138b8f424af4cf379f2b694060 upstream. When adding pages to the LRU we clear the active bit unconditionally. As the page could be reachable from other paths we cannot use unlocked operations without risk of corruption such as a parallel mark_page_accessed. This patch tests if is necessary to clear the active flag before using an atomic operation. This potentially opens a tiny race when PageActive is checked as mark_page_accessed could be called after PageActive was checked. The race already exists but this patch changes it slightly. The consequence is that that the page may be promoted to the active list that might have been left on the inactive list before the patch. It's too tiny a race and too marginal a consequence to always use atomic operations for. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: do not use atomic operations when releasing pagesMel Gorman
commit e3741b506c5088fa8c911bb5884c430f770fb49d upstream. There should be no references to it any more and a parallel mark should not be reordered against us. Use non-locked varient to clear page active. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: shmem: avoid atomic operation during shmem_getpage_gfpMel Gorman
commit 07a427884348d38a6fd56fa4d78249c407196650 upstream. shmem_getpage_gfp uses an atomic operation to set the SwapBacked field before it's even added to the LRU or visible. This is unnecessary as what could it possible race against? Use an unlocked variant. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: lookup pageblock migratetype with IRQs enabled during freeMel Gorman
commit cfc47a2803db42140167b92d991ef04018e162c7 upstream. get_pageblock_migratetype() is called during free with IRQs disabled. This is unnecessary and disables IRQs for longer than necessary. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: convert hot/cold parameter and immediate callers to boolMel Gorman
commit b745bc85f21ea707e4ea1a91948055fa3e72c77b upstream. cold is a bool, make it one. Make the likely case the "if" part of the block instead of the else as according to the optimisation manual this is preferred. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: reduce number of times page_to_pfn is calledMel Gorman
commit dc4b0caff24d9b2918e9f27bc65499ee63187eba upstream. In the free path we calculate page_to_pfn multiple times. Reduce that. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: use unsigned int for order in more placesMel Gorman
commit 7aeb09f9104b760fc53c98cb7d20d06640baf9e6 upstream. X86 prefers the use of unsigned types for iterators and there is a tendency to mix whether a signed or unsigned type if used for page order. This converts a number of sites in mm/page_alloc.c to use unsigned int for order where possible. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: take the ALLOC_NO_WATERMARK check out of the fast pathMel Gorman
commit 5dab29113ca56335c78be3f98bf5ddf2ef8eb6a6 upstream. ALLOC_NO_WATERMARK is set in a few cases. Always by kswapd, always for __GFP_MEMALLOC, sometimes for swap-over-nfs, tasks etc. Each of these cases are relatively rare events but the ALLOC_NO_WATERMARK check is an unlikely branch in the fast path. This patch moves the check out of the fast path and after it has been determined that the watermarks have not been met. This helps the common fast path at the cost of making the slow path slower and hitting kswapd with a performance cost. It's a reasonable tradeoff. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: only check the alloc flags and gfp_mask for dirty onceMel Gorman
commit a6e21b14f22041382e832d30deda6f26f37b1097 upstream. Currently it's calculated once per zone in the zonelist. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: only check the zone id check if pages are buddiesMel Gorman
commit d34c5fa06fade08a689fc171bf756fba2858ae73 upstream. A node/zone index is used to check if pages are compatible for merging but this happens unconditionally even if the buddy page is not free. Defer the calculation as long as possible. Ideally we would check the zone boundary but nodes can overlap. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: calculate classzone_idx once from the zonelist refMel Gorman
commit d8846374a85f4290a473a4e2a64c1ba046c4a0e1 upstream. There is no need to calculate zone_idx(preferred_zone) multiple times or use the pgdat to figure it out. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: use jump labels to avoid checking number_of_cpusetsMel Gorman
commit 664eeddeef6539247691197c1ac124d4aa872ab6 upstream. If cpusets are not in use then we still check a global variable on every page allocation. Use jump labels to avoid the overhead. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: do not treat a zone that cannot be used for dirty pages as ↵Mel Gorman
"full" commit 800a1e750c7b04c2aa2459afca77e936e01c0029 upstream. If a zone cannot be used for a dirty page then it gets marked "full" which is cached in the zlc and later potentially skipped by allocation requests that have nothing to do with dirty zones. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: do not update zlc unless the zlc is activeMel Gorman
commit 65bb371984d6a2c909244eb749e482bb40b72e36 upstream. The zlc is used on NUMA machines to quickly skip over zones that are full. However it is always updated, even for the first zone scanned when the zlc might not even be active. As it's a write to a bitmap that potentially bounces cache line it's deceptively expensive and most machines will not care. Only update the zlc if it was active. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm/swap.c: clean up *lru_cache_add* functionsJianyu Zhan
commit 2329d3751b082b4fd354f334a88662d72abac52d upstream. In mm/swap.c, __lru_cache_add() is exported, but actually there are no users outside this file. This patch unexports __lru_cache_add(), and makes it static. It also exports lru_cache_add_file(), as it is use by cifs and fuse, which can loaded as modules. Signed-off-by: Jianyu Zhan <nasa4836@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Shaohua Li <shli@kernel.org> Cc: Bob Liu <bob.liu@oracle.com> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Khalid Aziz <khalid.aziz@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm: Don't count the stack guard page towards RLIMIT_STACKLinus Torvalds
commit 690eac53daff34169a4d74fc7bfbd388c4896abb upstream. Commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page") made sure that we return the error properly for stack growth conditions. It also theorized that counting the guard page towards the stack limit might break something, but also said "Let's see if anybody notices". Somebody did notice. Apparently android-x86 sets the stack limit very close to the limit indeed, and including the guard page in the rlimit check causes the android 'zygote' process problems. So this adds the (fairly trivial) code to make the stack rlimit check be against the actual real stack size, rather than the size of the vma that includes the guard page. Reported-and-tested-by: Chih-Wei Huang <cwhuang@android-x86.org> Cc: Jay Foad <jay.foad@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm: propagate error from stack expansion even for guard pageLinus Torvalds
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream. Jay Foad reports that the address sanitizer test (asan) sometimes gets confused by a stack pointer that ends up being outside the stack vma that is reported by /proc/maps. This happens due to an interaction between RLIMIT_STACK and the guard page: when we do the guard page check, we ignore the potential error from the stack expansion, which effectively results in a missing guard page, since the expected stack expansion won't have been done. And since /proc/maps explicitly ignores the guard page (commit d7824370e263: "mm: fix up some user-visible effects of the stack guard page"), the stack pointer ends up being outside the reported stack area. This is the minimal patch: it just propagates the error. It also effectively makes the guard page part of the stack limit, which in turn measn that the actual real stack is one page less than the stack limit. Let's see if anybody notices. We could teach acct_stack_growth() to allow an extra page for a grow-up/grow-down stack in the rlimit test, but I don't want to add more complexity if it isn't needed. Reported-and-tested-by: Jay Foad <jay.foad@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm, vmscan: prevent kswapd livelock due to pfmemalloc-throttled process ↵Vlastimil Babka
being killed commit 9e5e3661727eaf960d3480213f8e87c8d67b6956 upstream. Charles Shirron and Paul Cassella from Cray Inc have reported kswapd stuck in a busy loop with nothing left to balance, but kswapd_try_to_sleep() failing to sleep. Their analysis found the cause to be a combination of several factors: 1. A process is waiting in throttle_direct_reclaim() on pgdat->pfmemalloc_wait 2. The process has been killed (by OOM in this case), but has not yet been scheduled to remove itself from the waitqueue and die. 3. kswapd checks for throttled processes in prepare_kswapd_sleep(): if (waitqueue_active(&pgdat->pfmemalloc_wait)) { wake_up(&pgdat->pfmemalloc_wait); return false; // kswapd will not go to sleep } However, for a process that was already killed, wake_up() does not remove the process from the waitqueue, since try_to_wake_up() checks its state first and returns false when the process is no longer waiting. 4. kswapd is running on the same CPU as the only CPU that the process is allowed to run on (through cpus_allowed, or possibly single-cpu system). 5. CONFIG_PREEMPT_NONE=y kernel is used. If there's nothing to balance, kswapd encounters no voluntary preemption points and repeatedly fails prepare_kswapd_sleep(), blocking the process from running and removing itself from the waitqueue, which would let kswapd sleep. So, the source of the problem is that we prevent kswapd from going to sleep until there are processes waiting on the pfmemalloc_wait queue, and a process waiting on a queue is guaranteed to be removed from the queue only when it gets scheduled. This was done to make sure that no process is left sleeping on pfmemalloc_wait when kswapd itself goes to sleep. However, it isn't necessary to postpone kswapd sleep until the pfmemalloc_wait queue actually empties. To prevent processes from being left sleeping, it's actually enough to guarantee that all processes waiting on pfmemalloc_wait queue have been woken up by the time we put kswapd to sleep. This patch therefore fixes this issue by substituting 'wake_up' with 'wake_up_all' and removing 'return false' in the code snippet from prepare_kswapd_sleep() above. Note that if any process puts itself in the queue after this waitqueue_active() check, or after the wake up itself, it means that the process will also wake up kswapd - and since we are under prepare_to_wait(), the wake up won't be missed. Also we update the comment prepare_kswapd_sleep() to hopefully more clearly describe the races it is preventing. Fixes: 5515061d22f0 ("mm: throttle direct reclaimers if PF_MEMALLOC reserves are low and swap is backed by network storage") Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-16mm: fix anon_vma_clone() error treatmentDaniel Forrest
commit c4ea95d7cd08d9ffd7fa75e6c5e0332d596dd11e upstream. Andrew Morton noticed that the error return from anon_vma_clone() was being dropped and replaced with -ENOMEM (which is not itself a bug because the only error return value from anon_vma_clone() is -ENOMEM). I did an audit of callers of anon_vma_clone() and discovered an actual bug where the error return was being lost. In __split_vma(), between Linux 3.11 and 3.12 the code was changed so the err variable is used before the call to anon_vma_clone() and the default initial value of -ENOMEM is overwritten. So a failure of anon_vma_clone() will return success since err at this point is now zero. Below is a patch which fixes this bug and also propagates the error return value from anon_vma_clone() in all cases. Fixes: ef0855d334e1 ("mm: mempolicy: turn vma_set_policy() into vma_dup_policy()") Signed-off-by: Daniel Forrest <dan.forrest@ssec.wisc.edu> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Tim Hartrick <tim@edgecast.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-16mm: fix swapoff hang after page migration and forkHugh Dickins
commit 2022b4d18a491a578218ce7a4eca8666db895a73 upstream. I've been seeing swapoff hangs in recent testing: it's cycling around trying unsuccessfully to find an mm for some remaining pages of swap. I have been exercising swap and page migration more heavily recently, and now notice a long-standing error in copy_one_pte(): it's trying to add dst_mm to swapoff's mmlist when it finds a swap entry, but is doing so even when it's a migration entry or an hwpoison entry. Which wouldn't matter much, except it adds dst_mm next to src_mm, assuming src_mm is already on the mmlist: which may not be so. Then if pages are later swapped out from dst_mm, swapoff won't be able to find where to replace them. There's already a !non_swap_entry() test for stats: move that up before the swap_duplicate() and the addition to mmlist. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Kelley Nielsen <kelleynnn@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-16mm/vmpressure.c: fix race in vmpressure_work_fn()Andrew Morton
commit 91b57191cfd152c02ded0745250167d0263084f8 upstream. In some android devices, there will be a "divide by zero" exception. vmpr->scanned could be zero before spin_lock(&vmpr->sr_lock). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=88051 [akpm@linux-foundation.org: neaten] Reported-by: ji_ang <ji_ang@163.com> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-16mm: frontswap: invalidate expired data on a dup-store failureWeijie Yang
commit fb993fa1a2f669215fa03a09eed7848f2663e336 upstream. If a frontswap dup-store failed, it should invalidate the expired page in the backend, or it could trigger some data corruption issue. Such as: 1. use zswap as the frontswap backend with writeback feature 2. store a swap page(version_1) to entry A, success 3. dup-store a newer page(version_2) to the same entry A, fail 4. use __swap_writepage() write version_2 page to swapfile, success 5. zswap do shrink, writeback version_1 page to swapfile 6. version_2 page is overwrited by version_1, data corrupt. This patch fixes this issue by invalidating expired data immediately when meet a dup-store failure. Signed-off-by: Weijie Yang <weijie.yang@samsung.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Seth Jennings <sjennings@variantweb.net> Cc: Dan Streetman <ddstreet@ieee.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Bob Liu <bob.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm/page_alloc: prevent MIGRATE_RESERVE pages from being misplacedVlastimil Babka
commit 5bcc9f86ef09a933255ee66bd899d4601785dad5 upstream. For the MIGRATE_RESERVE pages, it is useful when they do not get misplaced on free_list of other migratetype, otherwise they might get allocated prematurely and e.g. fragment the MIGRATE_RESEVE pageblocks. While this cannot be avoided completely when allocating new MIGRATE_RESERVE pageblocks in min_free_kbytes sysctl handler, we should prevent the misplacement where possible. Currently, it is possible for the misplacement to happen when a MIGRATE_RESERVE page is allocated on pcplist through rmqueue_bulk() as a fallback for other desired migratetype, and then later freed back through free_pcppages_bulk() without being actually used. This happens because free_pcppages_bulk() uses get_freepage_migratetype() to choose the free_list, and rmqueue_bulk() calls set_freepage_migratetype() with the *desired* migratetype and not the page's original MIGRATE_RESERVE migratetype. This patch fixes the problem by moving the call to set_freepage_migratetype() from rmqueue_bulk() down to __rmqueue_smallest() and __rmqueue_fallback() where the actual page's migratetype (e.g. from which free_list the page is taken from) is used. Note that this migratetype might be different from the pageblock's migratetype due to freepage stealing decisions. This is OK, as page stealing never uses MIGRATE_RESERVE as a fallback, and also takes care to leave all MIGRATE_CMA pages on the correct freelist. Therefore, as an additional benefit, the call to get_pageblock_migratetype() from rmqueue_bulk() when CMA is enabled, can be removed completely. This relies on the fact that MIGRATE_CMA pageblocks are created only during system init, and the above. The related is_migrate_isolate() check is also unnecessary, as memory isolation has other ways to move pages between freelists, and drain pcp lists containing pages that should be isolated. The buffered_rmqueue() can also benefit from calling get_freepage_migratetype() instead of get_pageblock_migratetype(). Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: Yong-Taek Lee <ytk.lee@samsung.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Suggested-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Suggested-by: Mel Gorman <mgorman@suse.de> Acked-by: Minchan Kim <minchan@kernel.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: "Wang, Yalin" <Yalin.Wang@sonymobile.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: vmscan: use proportional scanning during direct reclaim and full scan at ↵Mel Gorman
DEF_PRIORITY commit 1a501907bbea8e6ebb0b16cf6db9e9cbf1d2c813 upstream. Commit "mm: vmscan: obey proportional scanning requirements for kswapd" ensured that file/anon lists were scanned proportionally for reclaim from kswapd but ignored it for direct reclaim. The intent was to minimse direct reclaim latency but Yuanhan Liu pointer out that it substitutes one long stall for many small stalls and distorts aging for normal workloads like streaming readers/writers. Hugh Dickins pointed out that a side-effect of the same commit was that when one LRU list dropped to zero that the entirety of the other list was shrunk leading to excessive reclaim in memcgs. This patch scans the file/anon lists proportionally for direct reclaim to similarly age page whether reclaimed by kswapd or direct reclaim but takes care to abort reclaim if one LRU drops to zero after reclaiming the requested number of pages. Based on ext4 and using the Intel VM scalability test 3.15.0-rc5 3.15.0-rc5 shrinker proportion Unit lru-file-readonce elapsed 5.3500 ( 0.00%) 5.4200 ( -1.31%) Unit lru-file-readonce time_range 0.2700 ( 0.00%) 0.1400 ( 48.15%) Unit lru-file-readonce time_stddv 0.1148 ( 0.00%) 0.0536 ( 53.33%) Unit lru-file-readtwice elapsed 8.1700 ( 0.00%) 8.1700 ( 0.00%) Unit lru-file-readtwice time_range 0.4300 ( 0.00%) 0.2300 ( 46.51%) Unit lru-file-readtwice time_stddv 0.1650 ( 0.00%) 0.0971 ( 41.16%) The test cases are running multiple dd instances reading sparse files. The results are within the noise for the small test machine. The impact of the patch is more noticable from the vmstats 3.15.0-rc5 3.15.0-rc5 shrinker proportion Minor Faults 35154 36784 Major Faults 611 1305 Swap Ins 394 1651 Swap Outs 4394 5891 Allocation stalls 118616 44781 Direct pages scanned 4935171 4602313 Kswapd pages scanned 15921292 16258483 Kswapd pages reclaimed 15913301 16248305 Direct pages reclaimed 4933368 4601133 Kswapd efficiency 99% 99% Kswapd velocity 670088.047 682555.961 Direct efficiency 99% 99% Direct velocity 207709.217 193212.133 Percentage direct scans 23% 22% Page writes by reclaim 4858.000 6232.000 Page writes file 464 341 Page writes anon 4394 5891 Note that there are fewer allocation stalls even though the amount of direct reclaim scanning is very approximately the same. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Dave Chinner <david@fromorbit.com> Tested-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Jan Kara <jack@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: fix direct reclaim writeback regressionHugh Dickins
commit 8bdd638091605dc66d92c57c4b80eb87fffc15f7 upstream. Shortly before 3.16-rc1, Dave Jones reported: WARNING: CPU: 3 PID: 19721 at fs/xfs/xfs_aops.c:971 xfs_vm_writepage+0x5ce/0x630 [xfs]() CPU: 3 PID: 19721 Comm: trinity-c61 Not tainted 3.15.0+ #3 Call Trace: xfs_vm_writepage+0x5ce/0x630 [xfs] shrink_page_list+0x8f9/0xb90 shrink_inactive_list+0x253/0x510 shrink_lruvec+0x563/0x6c0 shrink_zone+0x3b/0x100 shrink_zones+0x1f1/0x3c0 try_to_free_pages+0x164/0x380 __alloc_pages_nodemask+0x822/0xc90 alloc_pages_vma+0xaf/0x1c0 handle_mm_fault+0xa31/0xc50 etc. 970 if (WARN_ON_ONCE((current->flags & (PF_MEMALLOC|PF_KSWAPD)) == 971 PF_MEMALLOC)) I did not respond at the time, because a glance at the PageDirty block in shrink_page_list() quickly shows that this is impossible: we don't do writeback on file pages (other than tmpfs) from direct reclaim nowadays. Dave was hallucinating, but it would have been disrespectful to say so. However, my own /var/log/messages now shows similar complaints WARNING: CPU: 1 PID: 28814 at fs/ext4/inode.c:1881 ext4_writepage+0xa7/0x38b() WARNING: CPU: 0 PID: 27347 at fs/ext4/inode.c:1764 ext4_writepage+0xa7/0x38b() from stressing some mmotm trees during July. Could a dirty xfs or ext4 file page somehow get marked PageSwapBacked, so fail shrink_page_list()'s page_is_file_cache() test, and so proceed to mapping->a_ops->writepage()? Yes, 3.16-rc1's commit 68711a746345 ("mm, migration: add destination page freeing callback") has provided such a way to compaction: if migrating a SwapBacked page fails, its newpage may be put back on the list for later use with PageSwapBacked still set, and nothing will clear it. Whether that can do anything worse than issue WARN_ON_ONCEs, and get some statistics wrong, is unclear: easier to fix than to think through the consequences. Fixing it here, before the put_new_page(), addresses the bug directly, but is probably the worst place to fix it. Page migration is doing too many parts of the job on too many levels: fixing it in move_to_new_page() to complement its SetPageSwapBacked would be preferable, except why is it (and newpage->mapping and newpage->index) done there, rather than down in migrate_page_move_mapping(), once we are sure of success? Not a cleanup to get into right now, especially not with memcg cleanups coming in 3.17. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm, compaction: properly signal and act upon lock and need_sched() contentionVlastimil Babka
commit be9765722e6b7ece8263cbab857490332339bd6f upstream. Compaction uses compact_checklock_irqsave() function to periodically check for lock contention and need_resched() to either abort async compaction, or to free the lock, schedule and retake the lock. When aborting, cc->contended is set to signal the contended state to the caller. Two problems have been identified in this mechanism. First, compaction also calls directly cond_resched() in both scanners when no lock is yet taken. This call either does not abort async compaction, or set cc->contended appropriately. This patch introduces a new compact_should_abort() function to achieve both. In isolate_freepages(), the check frequency is reduced to once by SWAP_CLUSTER_MAX pageblocks to match what the migration scanner does in the preliminary page checks. In case a pageblock is found suitable for calling isolate_freepages_block(), the checks within there are done on higher frequency. Second, isolate_freepages() does not check if isolate_freepages_block() aborted due to contention, and advances to the next pageblock. This violates the principle of aborting on contention, and might result in pageblocks not being scanned completely, since the scanning cursor is advanced. This problem has been noticed in the code by Joonsoo Kim when reviewing related patches. This patch makes isolate_freepages_block() check the cc->contended flag and abort. In case isolate_freepages() has already isolated some pages before aborting due to contention, page migration will proceed, which is OK since we do not want to waste the work that has been done, and page migration has own checks for contention. However, we do not want another isolation attempt by either of the scanners, so cc->contended flag check is added also to compaction_alloc() and compact_finished() to make sure compaction is aborted right after the migration. The outcome of the patch should be reduced lock contention by async compaction and lower latencies for higher-order allocations where direct compaction is involved. [akpm@linux-foundation.org: fix typo in comment] Reported-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Christoph Lameter <cl@linux.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Tested-by: Kevin Hilman <khilman@linaro.org> Tested-by: Stephen Warren <swarren@nvidia.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: David Rientjes <rientjes@google.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm/compaction: avoid rescanning pageblocks in isolate_freepagesVlastimil Babka
commit e9ade569910a82614ff5f2c2cea2b65a8d785da4 upstream. The compaction free scanner in isolate_freepages() currently remembers PFN of the highest pageblock where it successfully isolates, to be used as the starting pageblock for the next invocation. The rationale behind this is that page migration might return free pages to the allocator when migration fails and we don't want to skip them if the compaction continues. Since migration now returns free pages back to compaction code where they can be reused, this is no longer a concern. This patch changes isolate_freepages() so that the PFN for restarting is updated with each pageblock where isolation is attempted. Using stress-highalloc from mmtests, this resulted in 10% reduction of the pages scanned by the free scanner. Note that the somewhat similar functionality that records highest successful pageblock in zone->compact_cached_free_pfn, remains unchanged. This cache is used when the whole compaction is restarted, not for multiple invocations of the free scanner during single compaction. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Christoph Lameter <cl@linux.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm/compaction: do not count migratepages when unnecessaryVlastimil Babka
commit f8c9301fa5a2a8b873c67f2a3d8230d5c13f61b7 upstream. During compaction, update_nr_listpages() has been used to count remaining non-migrated and free pages after a call to migrage_pages(). The freepages counting has become unneccessary, and it turns out that migratepages counting is also unnecessary in most cases. The only situation when it's needed to count cc->migratepages is when migrate_pages() returns with a negative error code. Otherwise, the non-negative return value is the number of pages that were not migrated, which is exactly the count of remaining pages in the cc->migratepages list. Furthermore, any non-zero count is only interesting for the tracepoint of mm_compaction_migratepages events, because after that all remaining unmigrated pages are put back and their count is set to 0. This patch therefore removes update_nr_listpages() completely, and changes the tracepoint definition so that the manual counting is done only when the tracepoint is enabled, and only when migrate_pages() returns a negative error code. Furthermore, migrate_pages() and the tracepoints won't be called when there's nothing to migrate. This potentially avoids some wasted cycles and reduces the volume of uninteresting mm_compaction_migratepages events where "nr_migrated=0 nr_failed=0". In the stress-highalloc mmtest, this was about 75% of the events. The mm_compaction_isolate_migratepages event is better for determining that nothing was isolated for migration, and this one was just duplicating the info. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Christoph Lameter <cl@linux.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm, compaction: terminate async compaction when reschedulingDavid Rientjes
commit aeef4b83806f49a0c454b7d4578671b71045bee2 upstream. Async compaction terminates prematurely when need_resched(), see compact_checklock_irqsave(). This can never trigger, however, if the cond_resched() in isolate_migratepages_range() always takes care of the scheduling. If the cond_resched() actually triggers, then terminate this pageblock scan for async compaction as well. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm, compaction: embed migration mode in compact_controlDavid Rientjes
commit e0b9daeb453e602a95ea43853dc12d385558ce1f upstream. We're going to want to manipulate the migration mode for compaction in the page allocator, and currently compact_control's sync field is only a bool. Currently, we only do MIGRATE_ASYNC or MIGRATE_SYNC_LIGHT compaction depending on the value of this bool. Convert the bool to enum migrate_mode and pass the migration mode in directly. Later, we'll want to avoid MIGRATE_SYNC_LIGHT for thp allocations in the pagefault patch to avoid unnecessary latency. This also alters compaction triggered from sysfs, either for the entire system or for a node, to force MIGRATE_SYNC. [akpm@linux-foundation.org: fix build] [iamjoonsoo.kim@lge.com: use MIGRATE_SYNC in alloc_contig_range()] Signed-off-by: David Rientjes <rientjes@google.com> Suggested-by: Mel Gorman <mgorman@suse.de> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm, compaction: add per-zone migration pfn cache for async compactionDavid Rientjes
commit 35979ef3393110ff3c12c6b94552208d3bdf1a36 upstream. Each zone has a cached migration scanner pfn for memory compaction so that subsequent calls to memory compaction can start where the previous call left off. Currently, the compaction migration scanner only updates the per-zone cached pfn when pageblocks were not skipped for async compaction. This creates a dependency on calling sync compaction to avoid having subsequent calls to async compaction from scanning an enormous amount of non-MOVABLE pageblocks each time it is called. On large machines, this could be potentially very expensive. This patch adds a per-zone cached migration scanner pfn only for async compaction. It is updated everytime a pageblock has been scanned in its entirety and when no pages from it were successfully isolated. The cached migration scanner pfn for sync compaction is updated only when called for sync compaction. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Greg Thelen <gthelen@google.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm, compaction: return failed migration target pages back to freelistDavid Rientjes
commit d53aea3d46d64e95da9952887969f7533b9ab25e upstream. Greg reported that he found isolated free pages were returned back to the VM rather than the compaction freelist. This will cause holes behind the free scanner and cause it to reallocate additional memory if necessary later. He detected the problem at runtime seeing that ext4 metadata pages (esp the ones read by "sbi->s_group_desc[i] = sb_bread(sb, block)") were constantly visited by compaction calls of migrate_pages(). These pages had a non-zero b_count which caused fallback_migrate_page() -> try_to_release_page() -> try_to_free_buffers() to fail. Memory compaction works by having a "freeing scanner" scan from one end of a zone which isolates pages as migration targets while another "migrating scanner" scans from the other end of the same zone which isolates pages for migration. When page migration fails for an isolated page, the target page is returned to the system rather than the freelist built by the freeing scanner. This may require the freeing scanner to continue scanning memory after suitable migration targets have already been returned to the system needlessly. This patch returns destination pages to the freeing scanner freelist when page migration fails. This prevents unnecessary work done by the freeing scanner but also encourages memory to be as compacted as possible at the end of the zone. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Greg Thelen <gthelen@google.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm, migration: add destination page freeing callbackDavid Rientjes
commit 68711a746345c44ae00c64d8dbac6a9ce13ac54a upstream. Memory migration uses a callback defined by the caller to determine how to allocate destination pages. When migration fails for a source page, however, it frees the destination page back to the system. This patch adds a memory migration callback defined by the caller to determine how to free destination pages. If a caller, such as memory compaction, builds its own freelist for migration targets, this can reuse already freed memory instead of scanning additional memory. If the caller provides a function to handle freeing of destination pages, it is called when page migration fails. If the caller passes NULL then freeing back to the system will be handled as usual. This patch introduces no functional change. Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Greg Thelen <gthelen@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm/compaction: cleanup isolate_freepages()Vlastimil Babka
commit c96b9e508f3d06ddb601dcc9792d62c044ab359e upstream. isolate_freepages() is currently somewhat hard to follow thanks to many looks like it is related to the 'low_pfn' variable, but in fact it is not. This patch renames the 'high_pfn' variable to a hopefully less confusing name, and slightly changes its handling without a functional change. A comment made obsolete by recent changes is also updated. [akpm@linux-foundation.org: comment fixes, per Minchan] [iamjoonsoo.kim@lge.com: cleanups] Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Christoph Lameter <cl@linux.com> Cc: Rik van Riel <riel@redhat.com> Cc: Dongjun Shin <d.j.shin@samsung.com> Cc: Sunghwan Yun <sunghwan.yun@samsung.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
