commit 48b47c561e41525061b5bc0cfd67d6367fd11dc4 upstream.
Direct IO can invalidate and sync a lot of pagecache pages in the mapping.
A 4K direct IO will actually try to sync and/or invalidate the pagecache
of the entire file, for example (which might be many GB or TB large).
Improve this by doing range syncs. Also, memory no longer has to be
unmapped to catch the dirty bits for syncing, as dirty bits would remain
coherent due to dirty mmap accounting.
This fixes the immediate DM deadlocks when doing direct IO reads to block
device with a mounted filesystem, if only by papering over the problem
somewhat rather than addressing the fsync starvation cases.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
commit 82fd1a9a8ced9607312b54859572bcc6211e8919 upstream.
Now that we have the early-termination logic in place, it makes sense to
bail out early in all other cases where done is set to 1.
Cc: Chris Mason <chris.mason@oracle.com>
commit d5482cdf8a0aacb1e6468a97d5544f5829c8d8c4 upstream.
Terminate the write_cache_pages loop upon encountering the first page past
end, without locking the page. Pages cannot have their index change when
we have a reference on them (truncate, eg truncate_inode_pages_range
performs the same check without the page lock).
commit 515f4a037fb9ab736f8bad733fcd2ffd350cf265 upstream.
In write_cache_pages, if we get stuck behind another process that is
cleaning pages, we will be forced to wait for them to finish, then perform
our own writeout (if it was redirtied during the long wait), then wait for
that.
If a page under writeout is still clean, we can skip waiting for it (if
we're part of a data integrity sync, we'll be waiting for all writeout
pages afterwards, so we'll still be waiting for the other guy's write
that's cleaned the page).
commit 5a3d5c9813db56a75934eb1015367fda23a8b0b4 upstream.
Get rid of some complex expressions from flow control statements, add a
comment, remove some duplicate code.
commit 05fe478dd04e02fa230c305ab9b5616669821dd3 upstream.
In write_cache_pages, nr_to_write is heeded even for data-integrity syncs,
so the function will return success after writing out nr_to_write pages,
even if that was not sufficient to guarantee data integrity.
The callers tend to set it to values that could break data interity
semantics easily in practice. For example, nr_to_write can be set to
mapping->nr_pages * 2, however if a file has a single, dirty page, then
fsync is called, subsequent pages might be concurrently added and dirtied,
then write_cache_pages might writeout two of these newly dirty pages,
while not writing out the old page that should have been written out.
Fix this by ignoring nr_to_write if it is a data integrity sync.
This is a data integrity bug.
The reason this has been done in the past is to avoid stalling sync
operations behind page dirtiers.
"If a file has one dirty page at offset 1000000000000000 then someone
does an fsync() and someone else gets in first and starts madly writing
pages at offset 0, we want to write that page at 1000000000000000.
Somehow."
What we do today is return success after an arbitrary amount of pages are
written, whether or not we have provided the data-integrity semantics that
the caller has asked for. Even this doesn't actually fix all stall cases
completely: in the above situation, if the file has a huge number of pages
in pagecache (but not dirty), then mapping->nrpages is going to be huge,
even if pages are being dirtied.
This change does indeed make the possibility of long stalls lager, and
that's not a good thing, but lying about data integrity is even worse. We
have to either perform the sync, or return -ELINUXISLAME so at least the
caller knows what has happened.
There are subsequent competing approaches in the works to solve the stall
problems properly, without compromising data integrity.
commit 00266770b8b3a6a77f896ca501a0613739086832 upstream.
In write_cache_pages, if ret signals a real error, but we still have some
pages left in the pagevec, done would be set to 1, but the remaining pages
would continue to be processed and ret will be overwritten in the process.
It could easily be overwritten with success, and thus success will be
returned even if there is an error. Thus the caller is told all writes
succeeded, wheras in reality some did not.
Fix this by bailing immediately if there is an error, and retaining the
first error code.
commit bd19e012f6fd3b7309689165ea865cbb7bb88c1e upstream.
We'd like to break out of the loop early in many situations, however the
existing code has been setting mapping->writeback_index past the final
page in the pagevec lookup for cyclic writeback. This is a problem if we
don't process all pages up to the final page.
Currently the code mostly keeps writeback_index reasonable and hacked
around this by not breaking out of the loop or writing pages outside the
range in these cases. Keep track of a real "done index" that enables us
to terminate the loop in a much more flexible manner.
Needed by the subsequent patch to preserve writepage errors, and then
further patches to break out of the loop early for other reasons. However
there are no functional changes with this patch alone.
commit 31a12666d8f0c22235297e1c1575f82061480029 upstream.
In write_cache_pages, scanned == 1 is supposed to mean that cyclic
writeback has circled through zero, thus we should not circle again.
However it gets set to 1 after the first successful pagevec lookup. This
leads to cases where not enough data gets written.
Counterexample: file with first 10 pages dirty, writeback_index == 5,
nr_to_write == 10. Then the 5 last pages will be found, and scanned will
be set to 1, after writing those out, we will not cycle back to get the
first 5.
Rework this logic, now we'll always cycle unless we started off from index
0. When cycling, only write out as far as 1 page before the start page
from the first cycle (so we don't write parts of the file twice).
commit 54566b2c1594c2326a645a3551f9d989f7ba3c5e upstream.
With the write_begin/write_end aops, page_symlink was broken because it
could no longer pass a GFP_NOFS type mask into the point where the
allocations happened. They are done in write_begin, which would always
assume that the filesystem can be entered from reclaim. This bug could
cause filesystem deadlocks.
The funny thing with having a gfp_t mask there is that it doesn't really
allow the caller to arbitrarily tinker with the context in which it can be
called. It couldn't ever be GFP_ATOMIC, for example, because it needs to
take the page lock. The only thing any callers care about is __GFP_FS
anyway, so turn that into a single flag.
Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on
this flag in their write_begin function. Change __grab_cache_page to
accept a nofs argument as well, to honour that flag (while we're there,
change the name to grab_cache_page_write_begin which is more instructive
and does away with random leading underscores).
This is really a more flexible way to go in the end anyway -- if a
filesystem happens to want any extra allocations aside from the pagecache
ones in ints write_begin function, it may now use GFP_KERNEL (rather than
GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a
random example).
[kosaki.motohiro@jp.fujitsu.com: fix ubifs]
[kosaki.motohiro@jp.fujitsu.com: fix fuse]
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: <stable@kernel.org>
[ Cleaned up the calling convention: just pass in the AOP flags
untouched to the grab_cache_page_write_begin() function. That
just simplifies everybody, and may even allow future expansion of the
logic. - Linus ]
commit 938bb9f5e840eddbf54e4f62f6c5ba9b3ae12c9d upstream.
commit c4ea37c26a691ad0b7e86aa5884aab27830e95c9 upstream.
commit 3480b25743cb7404928d57efeaa3d085708b04c2 upstream.
commit 6a6160a7b5c27b3c38651baef92a14fa7072b3c1 upstream.
commit 6673e0c3fbeaed2cd08e2fd4a4aa97382d6fedb0 upstream.
System calls with an unsigned long long argument can't be converted with
the standard wrappers since that would include a cast to long, which in
turn means that we would lose the upper 32 bit on 32 bit architectures.
Also semctl can't use the standard wrapper since it has a 'union'
parameter.
So we handle them as special case and add some extra wrappers instead.
commit 2ed7c03ec17779afb4fcfa3b8c61df61bd4879ba upstream.
Convert all system calls to return a long. This should be a NOP since all
converted types should have the same size anyway.
With the exception of sys_exit_group which returned void. But that doesn't
matter since the system call doesn't return.
commit 1125b4e3949949b44a7c80b619507c6f61d62911 upstream.
This replaces zone->lru_lock in setup_per_zone_pages_min() with zone->lock.
There seems to be no need for the lru_lock anymore, but there is a need for
zone->lock instead, because that function may call move_freepages() via
setup_zone_migrate_reserve().
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Tested-by: Yasunori Goto <y-goto@jp.fujitsu.com>
commit a70dcb969f64e2fa98c24f47854f20bf02ff0092 upstream.
My last bugfix here (adding zone->lock) introduced a new problem: Using
page_zone(pfn_to_page(pfn)) to get the zone after the for() loop is wrong.
pfn will then be >= end_pfn, which may be in a different zone or not
present at all. This may lead to an addressing exception in page_zone()
or spin_lock_irqsave().
Now I use __first_valid_page() again after the loop to find a valid page
for page_zone().
Acked-by: Nathan Fontenot <nfont@austin.ibm.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 7526674de0c921e7f1e9b6f71a1f9d832557b554 upstream.
Oops. Part of the hugetlb private reservation code was not fully
converted to use hstates.
When a huge page must be unmapped from VMAs due to a failed COW,
HPAGE_SIZE is used in the call to unmap_hugepage_range() regardless of
the page size being used. This works if the VMA is using the default
huge page size. Otherwise we might unmap too much, too little, or
trigger a BUG_ON. Rare but serious -- fix it.
Signed-off-by: Adam Litke <agl@us.ibm.com>
Cc: Jon Tollefson <kniht@linux.vnet.ibm.com>
commit 69d177c2fc702d402b17fdca2190d5a7e3ca55c5 upstream
When working with hugepages, hugetlbfs assumes that those hugepages are
smaller than MAX_ORDER. Specifically it assumes that the mem_map is
contigious and uses that to optimise access to the elements of the mem_map
that represent the hugepage. Gigantic pages (such as 16GB pages on
powerpc) by definition are of greater order than MAX_ORDER (larger than
MAX_ORDER_NR_PAGES in size). This means that we can no longer make use of
the buddy alloctor guarentees for the contiguity of the mem_map, which
ensures that the mem_map is at least contigious for maximmally aligned
areas of MAX_ORDER_NR_PAGES pages.
This patch adds new mem_map accessors and iterator helpers which handle
any discontiguity at MAX_ORDER_NR_PAGES boundaries. It then uses these to
implement gigantic page versions of copy_huge_page and clear_huge_page,
and to allow follow_hugetlb_page handle gigantic pages.
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
commit 18229df5b613ed0732a766fc37850de2e7988e43 upstream
As we can determine exactly when a gigantic page is in use we can optimise
the common regular page cases by pulling out gigantic page initialisation
into its own function. As gigantic pages are never released to buddy we
do not need a destructor. This effectivly reverts the previous change to
the main buddy allocator. It also adds a paranoid check to ensure we
never release gigantic pages from hugetlbfs to the main buddy.
commit d9d332e0874f46b91d8ac4604b68ee42b8a7a2c6 upstream
The anon_vma code is very subtle, and we end up doing optimistic lookups
of anon_vmas under RCU in page_lock_anon_vma() with no locking. Other
CPU's can also see the newly allocated entry immediately after we've
exposed it by setting "vma->anon_vma" to the new value.
We protect against the anon_vma being destroyed by having the SLAB
marked as SLAB_DESTROY_BY_RCU, so the RCU lookup can depend on the
allocation not being destroyed - but it might still be free'd and
re-allocated here to a new vma.
As a result, we should not do the anon_vma list ops on a newly allocated
vma without proper locking.
Acked-by: Nick Piggin <npiggin@suse.de>
Acked-by: Hugh Dickins <hugh@veritas.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
This fixes the previous fix, which was completely wrong on closer
inspection. This version has been manually tested with a user-space
test harness and generates sane values. A nearly identical patch has
been boot-tested.
The problem arose from changing how kmalloc/kfree handled alignment
padding without updating ksize to match. This brings it in sync.
Signed-off-by: Matt Mackall <mpm@selenic.com>
SLOB's ksize calculation was braindamaged and generally harmlessly
underreported the allocation size. But for very small buffers, it could
in fact overreport them, leading code depending on krealloc to overrun
the allocation and trample other data.
Tested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
When we initialise a compound page we initialise the page flags and head
page pointer for all base pages spanned by that page. When we initialise
a gigantic page (a page of order greater than or equal to MAX_ORDER) we
have to initialise more than MAX_ORDER_NR_PAGES pages. Currently we
assume that all elements of the mem_map in this page are contigious in
memory. However this is only guarenteed out to MAX_ORDER_NR_PAGES pages,
and with SPARSEMEM enabled they will not be contigious. This leads us to
walk off the end of the first section and scribble on everything which
follows, BAD.
When we reach a MAX_ORDER_NR_PAGES boundary we much locate the next
section of the mem_map. As gigantic pages can only be maximally aligned
we know this will occur at exact multiple of MAX_ORDER_NR_PAGES pages from
the start of the page.
This is a bug fix for the gigantic page support in hugetlbfs.
Credit to Mel Gorman for spotting the issue.
The previous patch db203d53d474aa068984e409d807628f5841da1b ("mm:
tiny-shmem fix lock ordering: mmap_sem vs i_mutex") to fix the lock
ordering in tiny-shmem breaks shared anonymous and IPC memory on NOMMU
architectures because it was using the expanding truncate to signal ramfs
to allocate a physically contiguous RAM backing the inode (otherwise it is
unusable for "memory mapping" it to userspace).
However do_truncate is what caused the lock ordering error, due to it
taking i_mutex. In this case, we can actually just call ramfs directly to
allocate memory for the mapping, rather than go via truncate.
Cc: Matt Mackall <mpm@selenic.com>
__test_page_isolated_in_pageblock() in mm/page_isolation.c has a comment
saying that the caller must hold zone->lock. But the only caller of that
function, test_pages_isolated(), does not hold zone->lock and the lock is
also not acquired anywhere before. This patch adds the missing zone->lock
to test_pages_isolated().
We reproducibly run into BUG_ON(!PageBuddy(page)) in __offline_isolated_pages()
during memory hotplug stress test, see trace below. This patch fixes that
problem, it would be good if we could have it in 2.6.27.
kernel BUG at /home/autobuild/BUILD/linux-2.6.26-20080909/mm/page_alloc.c:4561!
illegal operation: 0001 [#1] PREEMPT SMP
Modules linked in: dm_multipath sunrpc bonding qeth_l3 dm_mod qeth ccwgroup vmur
CPU: 1 Not tainted 2.6.26-29.x.20080909-s390default #1
Process memory_loop_all (pid: 10025, task: 2f444028, ksp: 2b10dd28)
Krnl PSW : 040c0000 801727ea (__offline_isolated_pages+0x18e/0x1c4)
R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:0 CC:0 PM:0
Krnl GPRS: 00000000 7e27fc00 00000000 7e27fc00
00000000 00000400 00014000 7e27fc01
00606f00 7e27fc00 00013fe0 2b10dd28
00000005 80172662 801727b2 2b10dd28
Krnl Code: 801727de: 5810900c l %r1,12(%r9)
801727e2: a7f4ffb3 brc 15,80172748
801727e6: a7f40001 brc 15,801727e8
>801727ea: a7f4ffbc brc 15,80172762
801727ee: a7f40001 brc 15,801727f0
801727f2: a7f4ffaf brc 15,80172750
801727f6: 0707 bcr 0,%r7
801727f8: 0017 unknown
Call Trace:
([<0000000000172772>] __offline_isolated_pages+0x116/0x1c4)
[<00000000001953a2>] offline_isolated_pages_cb+0x22/0x34
[<000000000013164c>] walk_memory_resource+0xcc/0x11c
[<000000000019520e>] offline_pages+0x36a/0x498
[<00000000001004d6>] remove_memory+0x36/0x44
[<000000000028fb06>] memory_block_change_state+0x112/0x150
[<000000000028ffb8>] store_mem_state+0x90/0xe4
[<0000000000289c00>] sysdev_store+0x34/0x40
[<00000000001ee048>] sysfs_write_file+0xd0/0x178
[<000000000019b1a8>] vfs_write+0x74/0x118
[<000000000019b9ae>] sys_write+0x46/0x7c
[<000000000011160e>] sysc_do_restart+0x12/0x16
[<0000000077f3e8ca>] 0x77f3e8ca
There's a race between mm->owner assignment and swapoff, more easily
seen when task slab poisoning is turned on. The condition occurs when
try_to_unuse() runs in parallel with an exiting task. A similar race
can occur with callers of get_task_mm(), such as /proc/<pid>/<mmstats>
or ptrace or page migration.
CPU0 CPU1
try_to_unuse
looks at mm = task0->mm
increments mm->mm_users
task 0 exits
mm->owner needs to be updated, but no
new owner is found (mm_users > 1, but
no other task has task->mm = task0->mm)
mm_update_next_owner() leaves
mmput(mm) decrements mm->mm_users
task0 freed
dereferencing mm->owner fails
The fix is to notify the subsystem via mm_owner_changed callback(),
if no new owner is found, by specifying the new task as NULL.
Jiri Slaby:
mm->owner was set to NULL prior to calling cgroup_mm_owner_callbacks(), but
must be set after that, so as not to pass NULL as old owner causing oops.
Daisuke Nishimura:
mm_update_next_owner() may set mm->owner to NULL, but mem_cgroup_from_task()
and its callers need to take account of this situation to avoid oops.
Hugh Dickins:
Lockdep warning and hang below exec_mmap() when testing these patches.
exit_mm() up_reads mmap_sem before calling mm_update_next_owner(),
so exec_mmap() now needs to do the same. And with that repositioning,
there's now no point in mm_need_new_owner() allowing for NULL mm.
Reported-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Cc: Paul Menage <menage@google.com>
Current memory cgroup(both in mainline and -mm) doesn't account swap
caches as memory(swap cache support is dropped temporarily now).
So try_to_free_mem_cgroup_pages doesn't reflect the count of pages that
have been moved to swap cache.
But this makes mem_cgroup_shrink_usage fail easily if most of the pages
are anon/shmem, and then shmem_getpage returns -ENOMEM and the process
will be killed.
This patch adds res_counter_check_under_limit to avoid these cases.
BTW, even if swap cache support is enabled again, if a process is moved to
another cgroup, which has been just made, between precharge and
shrink_usage in shmem_getpage, shrink_usage may fail just because there is
no pages to reclaim.
So this change would make sense anyway.
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Hugh Dickins <hugh@veritas.com>
tiny-shmem calls do_truncate in shmem_file_setup. do_truncate takes
i_mutex, and shmem_file_setup is called with mmap_sem held. However
i_mutex nests outside mmap_sem.
Copy the code in shmem.c to avoid this problem.
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Initialized total objects atomic for the node in init_kmem_cache_node. The
uninitialized value was ruining the stats in /proc/slabinfo.
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Signed-off-by: Salman Qazi <sqazi@google.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
The iterator for_each_zone_zonelist() uses a struct zoneref *z cursor when
scanning zonelists to keep track of where in the zonelist it is. The
zoneref that is returned corresponds to the the next zone that is to be
scanned, not the current one. It was intended to be treated as an opaque
list.
When the page allocator is scanning a zonelist, it marks elements in the
zonelist corresponding to zones that are temporarily full. As the
zonelist is being updated, it uses the cursor here;
if (NUMA_BUILD)
zlc_mark_zone_full(zonelist, z);
This is intended to prevent rescanning in the near future but the zoneref
cursor does not correspond to the zone that has been found to be full.
This is an easy misunderstanding to make so this patch corrects the
problem by changing zoneref cursor to be the current zone being scanned
instead of the next one.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: <stable@kernel.org> [2.6.26.x]
Anonymous mappings should ignore offset but shared anonymous mapping
forgot to clear it and makes the following legit test program trigger
SIGBUS.
#include <sys/mman.h>
#include <stdio.h>
#include <errno.h>
#define PAGE_SIZE 4096
int main(void)
char *p;
int i;
p = mmap(NULL, 2 * PAGE_SIZE, PROT_READ|PROT_WRITE,
MAP_SHARED|MAP_ANONYMOUS, -1, PAGE_SIZE);
if (p == MAP_FAILED) {
perror("mmap");
return 1;
for (i = 0; i < 2; i++) {
printf("page %d\n", i);
p[i * 4096] = i;
return 0;
Fix it.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Quicklists store pages for each CPU as caches. (Each CPU can cache
node_free_pages/16 pages)
It is used for page table cache. exit() will increase the cache size,
while fork() consumes it.
So for example if an apache-style application runs (one parent and many
child model), one CPU process will fork() while another CPU will process
the middleware work and exit().
At that time, the CPU on which the parent runs doesn't have page table
cache at all. Others (on which children runs) have maximum caches.
QList_max = (#ofCPUs - 1) x Free / 16
=> QList_max / (Free + QList_max) = (#ofCPUs - 1) / (16 + #ofCPUs - 1)
So, How much quicklist memory is used in the maximum case?
This is proposional to # of CPUs because the limit of per cpu quicklist
cache doesn't see the number of cpus.
Above calculation mean
Number of CPUs per node 2 4 8 16
QList_max / (Free + QList_max) 5.8% 16% 30% 48%
Wow! Quicklist can spend about 50% memory at worst case.
My demonstration program is here
#define _GNU_SOURCE
#include <stdio.h>
#include <errno.h>
#include <stdlib.h>
#include <string.h>
#include <sched.h>
#include <unistd.h>
#include <sys/wait.h>
#define BUFFSIZE 512
int max_cpu(void) /* get max number of logical cpus from /proc/cpuinfo */
FILE *fd;
char *ret, buffer[BUFFSIZE];
int cpu = 1;
fd = fopen("/proc/cpuinfo", "r");
if (fd == NULL) {
perror("fopen(/proc/cpuinfo)");
exit(EXIT_FAILURE);
while (1) {
ret = fgets(buffer, BUFFSIZE, fd);
if (ret == NULL)
break;
if (!strncmp(buffer, "processor", 9))
cpu = atoi(strchr(buffer, ':') + 2);
fclose(fd);
return cpu;
void cpu_bind(int cpu) /* bind current process to one cpu */
cpu_set_t mask;
int ret;
CPU_ZERO(&mask);
CPU_SET(cpu, &mask);
ret = sched_setaffinity(0, sizeof(mask), &mask);
if (ret == -1) {
perror("sched_setaffinity()");
exit(EXIT_FAILURE);
sched_yield(); /* not necessary */
#define MMAP_SIZE (10 * 1024 * 1024) /* 10 MB */
#define FORK_INTERVAL 1 /* 1 second */
main(int argc, char *argv[])
int cpu_max, nextcpu;
long pagesize;
pid_t pid;
/* set max number of logical cpu */
if (argc > 1)
cpu_max = atoi(argv[1]) - 1;
else
cpu_max = max_cpu();
/* get the page size */
pagesize = sysconf(_SC_PAGESIZE);
if (pagesize == -1) {
perror("sysconf(_SC_PAGESIZE)");
exit(EXIT_FAILURE);
/* prepare parent process */
cpu_bind(0);
nextcpu = cpu_max;
loop:
/* select destination cpu for child process by round-robin rule */
if (++nextcpu > cpu_max)
nextcpu = 1;
pid = fork();
if (pid == 0) { /* child action */
char *p;
int i;
/* consume page tables */
p = mmap(0, MMAP_SIZE, PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS, 0, 0);
i = MMAP_SIZE / pagesize;
while (i-- > 0) {
*p = 1;
p += pagesize;
/* move to other cpu */
cpu_bind(nextcpu);
printf("a child moved to cpu%d after mmap().\n", nextcpu);
fflush(stdout);
/* back page tables to pgtable_quicklist */
exit(0);
} else if (pid > 0) { /* parent action */
sleep(FORK_INTERVAL);
waitpid(pid, NULL, WNOHANG);
goto loop;
When above program which does task migration runs, my 8GB box spends
800MB of memory for quicklist. This is not memory leak but doesn't seem
good.
% cat /proc/meminfo
MemTotal: 7701568 kB
MemFree: 4724672 kB
(snip)
Quicklists: 844800 kB
because
- My machine spec is
number of numa node: 2
number of cpus: 8 (4CPU x2 node)
total mem: 8GB (4GB x2 node)
free mem: about 5GB
- Then, 4.7GB x 16% ~= 880MB.
So, Quicklist can use 800MB.
So, if following spec machine run that program
CPUs: 64 (8cpu x 8node)
Mem: 1TB (128GB x8node)
Then, quicklist can waste 300GB (= 1TB x 30%). It is too large.
So, I don't like cache policies which is proportional to # of cpus.
My patch changes the number of caches
per-cpu-cache-amount = memory_on_node / 16
to
per-cpu-cache-amount = memory_on_node / 16 / number_of_cpus_on_node.
Cc: Keiichiro Tokunaga <tokunaga.keiich@jp.fujitsu.com>
Tested-by: David Miller <davem@davemloft.net>
Acked-by: Mike Travis <travis@sgi.com>
contig_page_data/bootmem_node_data
WARNING: vmlinux.o(.data+0x1f5c0): Section mismatch in reference from the variable contig_page_data to the variable .init.data:bootmem_node_data
The variable contig_page_data references
the variable __initdata bootmem_node_data
If the reference is valid then annotate the
variable with __init* (see linux/init.h) or name the variable:
*driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console,
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Johannes Weiner <hannes@saeurebad.de>
Cc: Sean MacLennan <smaclennan@pikatech.com>
Dio write returns EIO when try_to_release_page fails because bh is
still referenced.
The patch
commit 3f31fddfa26b7594b44ff2b34f9a04ba409e0f91
Author: Mingming Cao <cmm@us.ibm.com>
Date: Fri Jul 25 01:46:22 2008 -0700
jbd: fix race between free buffer and commit transaction
was merged into 2.6.27-rc1, but I noticed that this patch is not enough
to fix the race.
I did fsstress test heavily to 2.6.27-rc1, and found that dio write still
sometimes got EIO through this test.
The patch above fixed race between freeing buffer(dio) and committing
transaction(jbd) but I discovered that there is another race, freeing
buffer(dio) and ext3/4_ordered_writepage.
: background_writeout()
->write_cache_pages()
->ext3_ordered_writepage()
walk_page_buffers() -> take a bh ref
block_write_full_page() -> unlock_page
: <- end_page_writeback
: <- race! (dio write->try_to_release_page fails)
walk_page_buffers() ->release a bh ref
ext3_ordered_writepage holds bh ref and does unlock_page remaining
taking a bh ref, so this causes the race and failure of
try_to_release_page.
To fix this race, I used the approach of falling back to buffered
writes if try_to_release_page() fails on a page.
[akpm@linux-foundation.org: cleanups]
Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp>
Cc: Jan Kara <jack@suse.cz>
Cc: Mingming Cao <cmm@us.ibm.com>
Cc: Zach Brown <zach.brown@oracle.com>
I have gotten to the root cause of the hugetlb badness I reported back on
August 15th. My system has the following memory topology (note the
overlapping node):
Node 0 Memory: 0x8000000-0x44000000
Node 1 Memory: 0x0-0x8000000 0x44000000-0x80000000
setup_zone_migrate_reserve() scans the address range 0x0-0x8000000 looking
for a pageblock to move onto the MIGRATE_RESERVE list. Finding no
candidates, it happily continues the scan into 0x8000000-0x44000000. When
a pageblock is found, the pages are moved to the MIGRATE_RESERVE list on
the wrong zone. Oops.
setup_zone_migrate_reserve() should skip pageblocks in overlapping nodes.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x]
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 5226/1: remove unmatched comment end.
[ARM] Skip memory holes in FLATMEM when reading /proc/pagetypeinfo
[ARM] use bcd2bin/bin2bcd
[ARM] use the new byteorder headers
[ARM] OMAP: Fix 2430 SMC91x ethernet IRQ
[ARM] OMAP: Add and update OMAP default configuration files
[ARM] OMAP: Change mailing list for OMAP in MAINTAINERS
[ARM] S3C2443: Fix the S3C2443 clock register definitions
[ARM] JIVE: Fix the spi bus numbering
[ARM] S3C24XX: pwm.c: stop debugging output
[ARM] S3C24XX: Fix sparse warnings in pwm.c
[ARM] S3C24XX: Fix spare errors in pwm-clock driver
[ARM] S3C24XX: Fix sparse warnings in arch/arm/plat-s3c24xx/gpiolib.c
[ARM] S3C24XX: Fix nor-simtec driver sparse errors
[ARM] 5225/1: zaurus: Register I2C controller for audio codecs
[ARM] orion5x: update defconfig to v2.6.27-rc4
[ARM] Orion: register UART1 on QNAP TS-209 and TS-409
[ARM] Orion: activate lm75 driver on DNS-323
[ARM] Orion: fix MAC detection on QNAP TS-209 and TS-409
[ARM] Orion: Fix boot crash on Kurobox Pro
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
slub: Disable NUMA remote node defragmentation by default
Ordinarily, memory holes in flatmem still have a valid memmap and is safe
to use. However, an architecture (ARM) frees up the memmap backing memory
holes on the assumption it is never used. /proc/pagetypeinfo reads the
whole range of pages in a zone believing that the memmap is valid and that
pfn_valid will return false if it is not. On ARM, freeing the memmap breaks
the page->zone linkages even though pfn_valid() returns true and the kernel
can oops shortly afterwards due to accessing a bogus struct zone *.
This patch lets architectures say when FLATMEM can have holes in the
memmap. Rather than an expensive check for valid memory, /proc/pagetypeinfo
will confirm that the page linkages are still valid by checking page->zone
is still the expected zone. The lookup of page_zone is safe as there is a
limited range of memory that is accessed when calling page_zone. Even if
page_zone happens to return the correct zone, the impact is that the counters
in /proc/pagetypeinfo are slightly off but fragmentation monitoring is
unlikely to be relevant on an embedded system.
Reported-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com>
XIP can call into get_xip_mem concurrently with the same file,offset with
create=1. This usually maps down to get_block, which expects the page
lock to prevent such a situation. This causes ext2 to explode for one
reason or another.
Serialise those calls for the moment. For common usages today, I suspect
get_xip_mem rarely is called to create new blocks. In future as XIP
technologies evolve we might need to look at which operations require
scalability, and rework the locking to suit.
Cc: Jared Hulbert <jaredeh@gmail.com>
Acked-by: Carsten Otte <cotte@freenet.de>
XIP has a race between sparse pages being inserted into page tables, and
sparse pages being zapped when its time to put a non-sparse page in.
What can happen is that a process can be left with a dangling sparse page
in a MAP_SHARED mapping, while the rest of the world sees the non-sparse
version. Ie. data corruption.
Guard these operations with a seqlock, making fault-in-sparse-pages the
slowpath, and try-to-unmap-sparse-pages the fastpath.
There is a race with dirty page accounting where a page may not properly
be accounted for.
clear_page_dirty_for_io() calls page_mkclean; then TestClearPageDirty.
page_mkclean walks the rmaps for that page, and for each one it cleans and
write protects the pte if it was dirty. It uses page_check_address to
find the pte. That function has a shortcut to avoid the ptl if the pte is
not present. Unfortunately, the pte can be switched to not-present then
back to present by other code while holding the page table lock -- this
should not be a signal for page_mkclean to ignore that pte, because it may
be dirty.
For example, powerpc64's set_pte_at will clear a previously present pte
before setting it to the desired value. There may also be other code in
core mm or in arch which do similar things.
The consequence of the bug is loss of data integrity due to msync, and
loss of dirty page accounting accuracy. XIP's __xip_unmap could easily
also be unreliable (depending on the exact XIP locking scheme), which can
lead to data corruption.
Fix this by having an option to always take ptl to check the pte in
page_check_address.
It's possible to retain this optimization for page_referenced and
try_to_unmap.
Cc: Carsten Otte <cotte@freenet.de>
Absolute alignment requirements may never be applied to node-relative
offsets. Andreas Herrmann spotted this flaw when a bootmem allocation on
an unaligned node was itself not aligned because the combination of an
unaligned node with an aligned offset into that node is not garuanteed to
be aligned itself.
This patch introduces two helper functions that align a node-relative
index or offset with respect to the node's starting address so that the
absolute PFN or virtual address that results from combining the two
satisfies the requested alignment.
Then all the broken ALIGN()s in alloc_bootmem_core() are replaced by these
helpers.
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
Reported-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Debugged-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Reviewed-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com>
mminit_loglevel is now used from mminit_verify_zonelist <- build_all_zonelists <-
1. online_pages <- memory_block_action <- memory_block_change_state <- store_mem_state (sys handler)
2. numa_zonelist_order_handler (proc handler)
so it cannot be annotated __meminit - drop it
fixes following section mismatch warning:
WARNING: vmlinux.o(.text+0x71628): Section mismatch in reference from the function mminit_verify_zonelist() to the variable .meminit.data:mminit_loglevel
The function mminit_verify_zonelist() references
the variable __meminitdata mminit_loglevel.
This is often because mminit_verify_zonelist lacks a __meminitdata
annotation or the annotation of mminit_loglevel is wrong.
Adjust <Alt><SysRq>m show_swap_cache_info() to show "Free swap" as a
signed long: the signed format is preferable, because during swapoff
nr_swap_pages can legitimately go negative, so makes more sense thus
(it used to be shown redundantly, once as signed and once as unsigned).
Add a comment to s390's page_test_dirty/page_clear_dirty/page_set_dirty
dance in page_remove_rmap(): I was wrong to think the PageSwapCache test
could be avoided, and would like a comment in there to remind me. And
mention s390, to help us remember that this block is not really common.
Also move down the "It would be tidy to reset PageAnon" comment: it does
not belong to s390's block, and it would be unwise to reset PageAnon
before we're done with testing it.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Switch remote node defragmentation off by default. The current settings can
cause excessive node local allocations with hackbench:
SLAB:
% cat /proc/meminfo
MemTotal: 7701760 kB
MemFree: 5940096 kB
Slab: 123840 kB
SLUB:
% cat /proc/meminfo
MemTotal: 7701376 kB
MemFree: 4740928 kB
Slab: 1591680 kB
[Note: this feature is not related to slab defragmentation.]
You can find the original discussion here:
http://lkml.org/lkml/2008/8/4/308
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
security: Fix setting of PF_SUPERPRIV by __capable()
