commit fd5bb66cd934987e49557455b6497fc006521940 upstream.
Change the zpool/compressor param callback function to release the
zswap_pools_lock spinlock before calling param_set_charp, since that
function may sleep when it calls kmalloc with GFP_KERNEL.
While this problem has existed for a while, I wasn't able to trigger it
using a tight loop changing either/both the zpool and compressor params; I
think it's very unlikely to be an issue on the stable kernels, especially
since most zswap users will change the compressor and/or zpool from sysfs
only one time each boot - or zero times, if they add the params to the
kernel boot.
Fixes: c99b42c3529e ("zswap: use charp for zswap param strings")
Link: http://lkml.kernel.org/r/20170126155821.4545-1-ddstreet@ieee.org
Signed-off-by: Dan Streetman <dan.streetman@canonical.com>
Reported-by: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Minchan Kim <minchan@kernel.org>
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
The kaiser update made an interesting choice, never to free any shadow
page tables. Contention on global spinlock was worrying, particularly
with it held across page table scans when freeing. Something had to be
done: I was going to add refcounting; but simply never to free them is
an appealing choice, minimizing contention without complicating the code
(the more a page table is found already, the less the spinlock is used).
But leaking pages in this way is also a worry: can we get away with it?
At the very least, we need a count to show how bad it actually gets:
in principle, one might end up wasting about 1/256 of memory that way
(1/512 for when direct-mapped pages have to be user-mapped, plus 1/512
for when they are user-mapped from the vmalloc area on another occasion
(but we don't have vmalloc'ed stacks, so only large ldts are vmalloc'ed).
Add per-cpu stat NR_KAISERTABLE: including 256 at startup for the
shared pgd entries, and 1 for each intermediate page table added
thereafter for user-mapping - but leave out the 1 per mm, for its
shadow pgd, because that distracts from the monotonic increase.
Shown in /proc/vmstat as nr_overhead (0 if kaiser not enabled).
In practice, it doesn't look so bad so far: more like 1/12000 after
nine hours of gtests below; and movable pageblock segregation should
tend to cluster the kaiser tables into a subset of the address space
(if not, they will be bad for compaction too). But production may
tell a different story: keep an eye on this number, and bring back
lighter freeing if it gets out of control (maybe a shrinker).
["nr_overhead" should of course say "nr_kaisertable", if it needs
to stay; but for the moment we are being coy, preferring that when
Joe Blow notices a new line in his /proc/vmstat, he does not get
too curious about what this "kaiser" stuff might be.]
[ Upstream commit 1aedcafbf32b3f232c159b14cd0d423fcfe2b861 ]
Use BUG_ON(in_interrupt()) in zs_map_object(). This is not a new
BUG_ON(), it's always been there, but was recently changed to
VM_BUG_ON(). There are several problems there. First, we use use
per-CPU mappings both in zsmalloc and in zram, and interrupt may easily
corrupt those buffers. Second, and more importantly, we believe it's
possible to start leaking sensitive information. Consider the following
case:
-> process P
swap out
zram
per-cpu mapping CPU1
compress page A
-> IRQ
swap out
zram
compress page B
write page from per-cpu mapping CPU1 to zsmalloc pool
iret
-> process P
write page from per-cpu mapping CPU1 to zsmalloc pool [*]
return
* so we store overwritten data that actually belongs to another
page (task) and potentially contains sensitive data. And when
process P will page fault it's going to read (swap in) that
other task's data.
Link: http://lkml.kernel.org/r/20170929045140.4055-1-sergey.senozhatsky@gmail.com
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Acked-by: Minchan Kim <minchan@kernel.org>
commit ced108037c2aa542b3ed8b7afd1576064ad1362a upstream.
In case prot_numa, we are under down_read(mmap_sem). It's critical to
not clear pmd intermittently to avoid race with MADV_DONTNEED which is
also under down_read(mmap_sem):
CPU0: CPU1:
change_huge_pmd(prot_numa=1)
pmdp_huge_get_and_clear_notify()
madvise_dontneed()
zap_pmd_range()
pmd_trans_huge(*pmd) == 0 (without ptl)
// skip the pmd
set_pmd_at();
// pmd is re-established
The race makes MADV_DONTNEED miss the huge pmd and don't clear it
which may break userspace.
Found by code analysis, never saw triggered.
Link: http://lkml.kernel.org/r/20170302151034.27829-3-kirill.shutemov@linux.intel.com
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: <stable@vger.kernel.org>
[jwang: adjust context for 4.9 ]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
commit 0a85e51d37645e9ce57e5e1a30859e07810ed07c upstream.
Patch series "thp: fix few MADV_DONTNEED races"
For MADV_DONTNEED to work properly with huge pages, it's critical to not
clear pmd intermittently unless you hold down_write(mmap_sem).
Otherwise MADV_DONTNEED can miss the THP which can lead to userspace
breakage.
See example of such race in commit message of patch 2/4.
All these races are found by code inspection. I haven't seen them
triggered. I don't think it's worth to apply them to stable@.
This patch (of 4):
Restructure code in preparation for a fix.
Link: http://lkml.kernel.org/r/20170302151034.27829-2-kirill.shutemov@linux.intel.com
Acked-by: Vlastimil Babka <vbabka@suse.cz>
[jwang: adjust context for 4.9]
[ Upstream commit 2df26639e708a88dcc22171949da638a9998f3bc ]
Jia He has noticed that commit b9f00e147f27 ("mm, page_alloc: reduce
branches in zone_statistics") has an unintentional side effect that
remote node allocation requests are accounted as NUMA_MISS rathat than
NUMA_HIT and NUMA_OTHER if such a request doesn't use __GFP_OTHER_NODE.
There are many of these potentially because the flag is used very rarely
while we have many users of __alloc_pages_node.
Fix this by simply ignoring __GFP_OTHER_NODE (it can be removed in a
follow up patch) and treat all allocations that were satisfied from the
preferred zone's node as NUMA_HITS because this is the same node we
requested the allocation from in most cases. If this is not the local
node then we just account it as NUMA_OTHER rather than NUMA_LOCAL.
One downsize would be that an allocation request for a node which is
outside of the mempolicy nodemask would be reported as a hit which is a
bit weird but that was the case before b9f00e147f27 already.
Fixes: b9f00e147f27 ("mm, page_alloc: reduce branches in zone_statistics")
Link: http://lkml.kernel.org/r/20170102153057.9451-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Jia He <hejianet@gmail.com>
Reviewed-by: Vlastimil Babka <vbabka@suse.cz> # with cbmc[1] superpowers
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
commit 687cb0884a714ff484d038e9190edc874edcf146 upstream.
tlb_gather_mmu(&tlb, mm, 0, -1) means gathering the whole virtual memory
space. In this case, tlb->fullmm is true. Some archs like arm64
doesn't flush TLB when tlb->fullmm is true:
commit 5a7862e83000 ("arm64: tlbflush: avoid flushing when fullmm == 1").
Which causes leaking of tlb entries.
Will clarifies his patch:
"Basically, we tag each address space with an ASID (PCID on x86) which
is resident in the TLB. This means we can elide TLB invalidation when
pulling down a full mm because we won't ever assign that ASID to
another mm without doing TLB invalidation elsewhere (which actually
just nukes the whole TLB).
I think that means that we could potentially not fault on a kernel
uaccess, because we could hit in the TLB"
There could be a window between complete_signal() sending IPI to other
cores and all threads sharing this mm are really kicked off from cores.
In this window, the oom reaper may calls tlb_flush_mmu_tlbonly() to
flush TLB then frees pages. However, due to the above problem, the TLB
entries are not really flushed on arm64. Other threads are possible to
access these pages through TLB entries. Moreover, a copy_to_user() can
also write to these pages without generating page fault, causes
use-after-free bugs.
This patch gathers each vma instead of gathering full vm space. In this
case tlb->fullmm is not true. The behavior of oom reaper become similar
to munmapping before do_exit, which should be safe for all archs.
Link: http://lkml.kernel.org/r/20171107095453.179940-1-wangnan0@huawei.com
Fixes: aac453635549 ("mm, oom: introduce oom reaper")
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Bob Liu <liubo95@huawei.com>
Cc: Roman Gushchin <guro@fb.com>
Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
[backported to 4.9 stable tree]
commit 6ea8d958a2c95a1d514015d4e29ba21a8c0a1a91 upstream.
MADVISE_WILLNEED has always been a noop for DAX (formerly XIP) mappings.
Unfortunately madvise_willneed() doesn't communicate this information
properly to the generic madvise syscall implementation. The calling
convention is quite subtle there. madvise_vma() is supposed to either
return an error or update &prev otherwise the main loop will never
advance to the next vma and it will keep looping for ever without a way
to get out of the kernel.
It seems this has been broken since introduction. Nobody has noticed
because nobody seems to be using MADVISE_WILLNEED on these DAX mappings.
[mhocko@suse.com: rewrite changelog]
Link: http://lkml.kernel.org/r/20171127115318.911-1-guoxuenan@huawei.com
Fixes: fe77ba6f4f97 ("[PATCH] xip: madvice/fadvice: execute in place")
Signed-off-by: chenjie <chenjie6@huawei.com>
Signed-off-by: guoxuenan <guoxuenan@huawei.com>
Cc: zhangyi (F) <yi.zhang@huawei.com>
Cc: Miao Xie <miaoxie@huawei.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Shaohua Li <shli@fb.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Dan Williams <dan.j.williams@intel.com>
commit 31383c6865a578834dd953d9dbc88e6b19fe3997 upstream.
Patch series "device-dax: fix unaligned munmap handling"
When device-dax is operating in huge-page mode we want it to behave like
hugetlbfs and fail attempts to split vmas into unaligned ranges. It
would be messy to teach the munmap path about device-dax alignment
constraints in the same (hstate) way that hugetlbfs communicates this
constraint. Instead, these patches introduce a new ->split() vm
operation.
This patch (of 2):
The device-dax interface has similar constraints as hugetlbfs in that it
requires the munmap path to unmap in huge page aligned units. Rather
than add more custom vma handling code in __split_vma() introduce a new
vm operation to perform this vma specific check.
Link: http://lkml.kernel.org/r/151130418135.4029.6783191281930729710.stgit@dwillia2-desk3.amr.corp.intel.com
Fixes: dee410792419 ("/dev/dax, core: file operations and dax-mmap")
Cc: Jeff Moyer <jmoyer@redhat.com>
commit 63cd448908b5eb51d84c52f02b31b9b4ccd1cb5a upstream.
If the call __alloc_contig_migrate_range() in alloc_contig_range returns
-EBUSY, processing continues so that test_pages_isolated() is called
where there is a tracepoint to identify the busy pages. However, it is
possible for busy pages to become available between the calls to these
two routines. In this case, the range of pages may be allocated.
Unfortunately, the original return code (ret == -EBUSY) is still set and
returned to the caller. Therefore, the caller believes the pages were
not allocated and they are leaked.
Update the comment to indicate that allocation is still possible even if
__alloc_contig_migrate_range returns -EBUSY. Also, clear return code in
this case so that it is not accidentally used or returned to caller.
Link: http://lkml.kernel.org/r/20171122185214.25285-1-mike.kravetz@oracle.com
Fixes: 8ef5849fa8a2 ("mm/cma: always check which page caused allocation failure")
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Michal Hocko <mhocko@suse.com>
commit a8f97366452ed491d13cf1e44241bc0b5740b1f0 upstream.
Currently, we unconditionally make page table dirty in touch_pmd().
It may result in false-positive can_follow_write_pmd().
We may avoid the situation, if we would only make the page table entry
dirty if caller asks for write access -- FOLL_WRITE.
The patch also changes touch_pud() in the same way.
[Salvatore Bonaccorso: backport for 4.9:
- Adjust context
- Drop specific part for PUD-sized transparent hugepages. Support
for PUD-sized transparent hugepages was added in v4.11-rc1
commit 373c4557d2aa362702c4c2d41288fb1e54990b7c upstream.
This matters at least for the mincore syscall, which will otherwise copy
uninitialized memory from the page allocator to userspace. It is
probably also a correctness error for /proc/$pid/pagemap, but I haven't
tested that.
Removing the `walk->hugetlb_entry` condition in walk_hugetlb_range() has
no effect because the caller already checks for that.
This only reports holes in hugetlb ranges to callers who have specified
a hugetlb_entry callback.
This issue was found using an AFL-based fuzzer.
v2:
- don't crash on ->pte_hole==NULL (Andrew Morton)
- add Cc stable (Andrew Morton)
Changed for 4.4/4.9 stable backport:
- fix up conflict in the huge_pte_offset() call
Fixes: 1e25a271c8ac ("mincore: apply page table walker on do_mincore()")
Signed-off-by: Jann Horn <jannh@google.com>
commit d135e5750205a21a212a19dbb05aeb339e2cbea7 upstream.
In reset_deferred_meminit() we determine number of pages that must not
be deferred. We initialize pages for at least 2G of memory, but also
pages for reserved memory in this node.
The reserved memory is determined in this function:
memblock_reserved_memory_within(), which operates over physical
addresses, and returns size in bytes. However, reset_deferred_meminit()
assumes that that this function operates with pfns, and returns page
count.
The result is that in the best case machine boots slower than expected
due to initializing more pages than needed in single thread, and in the
worst case panics because fewer than needed pages are initialized early.
Link: http://lkml.kernel.org/r/20171021011707.15191-1-pasha.tatashin@oracle.com
Fixes: 864b9a393dcb ("mm: consider memblock reservations for deferred memory initialization sizing")
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
[ Upstream commit c6e28895a4372992961888ffaadc9efc643b5bfe ]
In case CONFIG_SLUB_DEBUG_ON=n, find_mergeable() gets debug features from
commandline but never checks if there are features from the
SLAB_NEVER_MERGE set.
As a result selected by slub_debug caches are always mergeable if they
have been created without a custom constructor set or without one of the
SLAB_* debug features on.
This moves the SLAB_NEVER_MERGE check below the flags update from
commandline to make sure it won't merge the slab cache if one of the debug
features is on.
Link: http://lkml.kernel.org/r/20170101124451.GA4740@lp-laptop-d
Signed-off-by: Grygorii Maistrenko <grygoriimkd@gmail.com>
Reviewed-by: Pekka Enberg <penberg@kernel.org>
Acked-by: Christoph Lameter <cl@linux.com>
[ Upstream commit ddffe98d166f4a93d996d5aa628fd745311fc1e7 ]
To identify that pages of page table are allocated from bootmem
allocator, magic number sets to page->lru.next.
But page->lru list is initialized in reserve_bootmem_region(). So when
calling free_pagetable(), the function cannot find the magic number of
pages. And free_pagetable() frees the pages by free_reserved_page() not
put_page_bootmem().
But if the pages are allocated from bootmem allocator and used as page
table, the pages have private flag. So before freeing the pages, we
should clear the private flag by put_page_bootmem().
Before applying the commit 7bfec6f47bb0 ("mm, page_alloc: check multiple
page fields with a single branch"), we could find the following visible
issue:
BUG: Bad page state in process kworker/u1024:1
page:ffffea103cfd8040 count:0 mapcount:0 mappi
flags: 0x6fffff80000800(private)
page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
bad because of flags: 0x800(private)
<snip>
Call Trace:
[...] dump_stack+0x63/0x87
[...] bad_page+0x114/0x130
[...] free_pages_prepare+0x299/0x2d0
[...] free_hot_cold_page+0x31/0x150
[...] __free_pages+0x25/0x30
[...] free_pagetable+0x6f/0xb4
[...] remove_pagetable+0x379/0x7ff
[...] vmemmap_free+0x10/0x20
[...] sparse_remove_one_section+0x149/0x180
[...] __remove_pages+0x2e9/0x4f0
[...] arch_remove_memory+0x63/0xc0
[...] remove_memory+0x8c/0xc0
[...] acpi_memory_device_remove+0x79/0xa5
[...] acpi_bus_trim+0x5a/0x8d
[...] acpi_bus_trim+0x38/0x8d
[...] acpi_device_hotplug+0x1b7/0x418
[...] acpi_hotplug_work_fn+0x1e/0x29
[...] process_one_work+0x152/0x400
[...] worker_thread+0x125/0x4b0
[...] kthread+0xd8/0xf0
[...] ret_from_fork+0x22/0x40
And the issue still silently occurs.
Until freeing the pages of page table allocated from bootmem allocator,
the page->freelist is never used. So the patch sets magic number to
page->freelist instead of page->lru.next.
[isimatu.yasuaki@jp.fujitsu.com: fix merge issue]
Link: http://lkml.kernel.org/r/722b1cc4-93ac-dd8b-2be2-7a7e313b3b0b@gmail.com
Link: http://lkml.kernel.org/r/2c29bd9f-5b67-02d0-18a3-8828e78bbb6f@gmail.com
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
commit 4d4bbd8526a8fbeb2c090ea360211fceff952383 upstream.
Andrea has noticed that the oom_reaper doesn't invalidate the range via
mmu notifiers (mmu_notifier_invalidate_range_start/end) and that can
corrupt the memory of the kvm guest for example.
tlb_flush_mmu_tlbonly already invokes mmu notifiers but that is not
sufficient as per Andrea:
"mmu_notifier_invalidate_range cannot be used in replacement of
mmu_notifier_invalidate_range_start/end. For KVM
mmu_notifier_invalidate_range is a noop and rightfully so. A MMU
notifier implementation has to implement either ->invalidate_range
method or the invalidate_range_start/end methods, not both. And if you
implement invalidate_range_start/end like KVM is forced to do, calling
mmu_notifier_invalidate_range in common code is a noop for KVM.
For those MMU notifiers that can get away only implementing
->invalidate_range, the ->invalidate_range is implicitly called by
mmu_notifier_invalidate_range_end(). And only those secondary MMUs
that share the same pagetable with the primary MMU (like AMD iommuv2)
can get away only implementing ->invalidate_range"
As the callback is allowed to sleep and the implementation is out of
hand of the MM it is safer to simply bail out if there is an mmu
notifier registered. In order to not fail too early make the
mm_has_notifiers check under the oom_lock and have a little nap before
failing to give the current oom victim some more time to exit.
Link: http://lkml.kernel.org/r/20170913113427.2291-1-mhocko@kernel.org
Reported-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
[ Upstream commit bfc7228b9a9647e1c353e50b40297a2929801759 ]
The system may panic when initialisation is done when almost all the
memory is assigned to the huge pages using the kernel command line
parameter hugepage=xxxx. Panic may occur like this:
Unable to handle kernel paging request for data at address 0x00000000
Faulting instruction address: 0xc000000000302b88
Oops: Kernel access of bad area, sig: 11 [#1]
SMP NR_CPUS=2048 [ 0.082424] NUMA
pSeries
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.0-15-generic #16-Ubuntu
task: c00000021ed01600 task.stack: c00000010d108000
NIP: c000000000302b88 LR: c000000000270e04 CTR: c00000000016cfd0
REGS: c00000010d10b2c0 TRAP: 0300 Not tainted (4.9.0-15-generic)
MSR: 8000000002009033 <SF,VEC,EE,ME,IR,DR,RI,LE>[ 0.082770] CR: 28424422 XER: 00000000
CFAR: c0000000003d28b8 DAR: 0000000000000000 DSISR: 40000000 SOFTE: 1
GPR00: c000000000270e04 c00000010d10b540 c00000000141a300 c00000010fff6300
GPR04: 0000000000000000 00000000026012c0 c00000010d10b630 0000000487ab0000
GPR08: 000000010ee90000 c000000001454fd8 0000000000000000 0000000000000000
GPR12: 0000000000004400 c00000000fb80000 00000000026012c0 00000000026012c0
GPR16: 00000000026012c0 0000000000000000 0000000000000000 0000000000000002
GPR20: 000000000000000c 0000000000000000 0000000000000000 00000000024200c0
GPR24: c0000000016eef48 0000000000000000 c00000010fff7d00 00000000026012c0
GPR28: 0000000000000000 c00000010fff7d00 c00000010fff6300 c00000010d10b6d0
NIP mem_cgroup_soft_limit_reclaim+0xf8/0x4f0
LR do_try_to_free_pages+0x1b4/0x450
Call Trace:
try_to_free_pages+0xf8/0x270
__alloc_pages_nodemask+0x7a8/0xff0
new_slab+0x104/0x8e0
___slab_alloc+0x620/0x700
__slab_alloc+0x34/0x60
kmem_cache_alloc_node_trace+0xdc/0x310
mem_cgroup_init+0x158/0x1c8
do_one_initcall+0x68/0x1d0
kernel_init_freeable+0x278/0x360
kernel_init+0x24/0x170
ret_from_kernel_thread+0x5c/0x74
Instruction dump:
eb81ffe0 eba1ffe8 ebc1fff0 ebe1fff8 4e800020 3d230001 e9499a42 3d220004
3929acd8 794a1f24 7d295214 eac90100 <e9360000> 2fa90000 419eff74 3b200000
---[ end trace 342f5208b00d01b6 ]---
This is a chicken and egg issue where the kernel try to get free memory
when allocating per node data in mem_cgroup_init(), but in that path
mem_cgroup_soft_limit_reclaim() is called which assumes that these data
are allocated.
As mem_cgroup_soft_limit_reclaim() is best effort, it should return when
these data are not yet allocated.
This patch also fixes potential null pointer access in
mem_cgroup_remove_from_trees() and mem_cgroup_update_tree().
Link: http://lkml.kernel.org/r/1487856999-16581-2-git-send-email-ldufour@linux.vnet.ibm.com
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Acked-by: Balbir Singh <bsingharora@gmail.com>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
commit 4855e4a7f29d6d10b0b9c84e189c770c9a94e91e upstream.
There is race between page freeing and unreserved highatomic.
CPU 0 CPU 1
free_hot_cold_page
mt = get_pfnblock_migratetype
set_pcppage_migratetype(page, mt)
unreserve_highatomic_pageblock
spin_lock_irqsave(&zone->lock)
move_freepages_block
set_pageblock_migratetype(page)
spin_unlock_irqrestore(&zone->lock)
free_pcppages_bulk
__free_one_page(mt) <- mt is stale
By above race, a page on CPU 0 could go non-highorderatomic free list
since the pageblock's type is changed. By that, unreserve logic of
highorderatomic can decrease reserved count on a same pageblock severak
times and then it will make mismatch between nr_reserved_highatomic and
the number of reserved pageblock.
So, this patch verifies whether the pageblock is highatomic or not and
decrease the count only if the pageblock is highatomic.
Link: http://lkml.kernel.org/r/1476259429-18279-3-git-send-email-minchan@kernel.org
Signed-off-by: Minchan Kim <minchan@kernel.org>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Sangseok Lee <sangseok.lee@lge.com>
Cc: Miles Chen <miles.chen@mediatek.com>
commit de0c799bba2610a8e1e9a50d76a28614520a4cd4 upstream.
Seen while reading the code, in handle_mm_fault(), in the case
arch_vma_access_permitted() is failing the call to
mem_cgroup_oom_disable() is not made.
To fix that, move the call to mem_cgroup_oom_enable() after calling
arch_vma_access_permitted() as it should not have entered the memcg OOM.
Link: http://lkml.kernel.org/r/1504625439-31313-1-git-send-email-ldufour@linux.vnet.ibm.com
Fixes: bae473a423f6 ("mm: introduce fault_env")
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
commit c461ad6a63b37ba74632e90c063d14823c884247 upstream.
Wendy Wang reported off-list that a RAS HWPOISON-SOFT test case failed
and bisected it to the commit 479f854a207c ("mm, page_alloc: defer
debugging checks of pages allocated from the PCP").
The problem is that a page that was poisoned with madvise() is reused.
The commit removed a check that would trigger if DEBUG_VM was enabled
but re-enabling the check only fixes the problem as a side-effect by
printing a bad_page warning and recovering.
The root of the problem is that an madvise() can leave a poisoned page
on the per-cpu list. This patch drains all per-cpu lists after pages
are poisoned so that they will not be reused. Wendy reports that the
test case in question passes with this patch applied. While this could
be done in a targeted fashion, it is over-complicated for such a rare
operation.
Link: http://lkml.kernel.org/r/20170828133414.7qro57jbepdcyz5x@techsingularity.net
Fixes: 479f854a207c ("mm, page_alloc: defer debugging checks of pages allocated from the PCP")
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Reported-by: Wang, Wendy <wendy.wang@intel.com>
Tested-by: Wang, Wendy <wendy.wang@intel.com>
Cc: "Hansen, Dave" <dave.hansen@intel.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Naoya Horiguchi <nao.horiguchi@gmail.com>
commit 91b540f98872a206ea1c49e4aa6ea8eed0886644 upstream.
In recently introduced memblock_discard() there is a reversed logic bug.
Memory is freed of static array instead of dynamically allocated one.
Link: http://lkml.kernel.org/r/1503511441-95478-2-git-send-email-pasha.tatashin@oracle.com
Fixes: 3010f876500f ("mm: discard memblock data later")
Reported-by: Woody Suwalski <terraluna977@gmail.com>
Tested-by: Woody Suwalski <terraluna977@gmail.com>
commit 263630e8d176d87308481ebdcd78ef9426739c6b upstream.
If madvise(..., MADV_FREE) split a transparent hugepage, it called
put_page() before unlock_page().
This was wrong because put_page() can free the page, e.g. if a
concurrent madvise(..., MADV_DONTNEED) has removed it from the memory
mapping. put_page() then rightfully complained about freeing a locked
page.
Fix this by moving the unlock_page() before put_page().
This bug was found by syzkaller, which encountered the following splat:
BUG: Bad page state in process syzkaller412798 pfn:1bd800
page:ffffea0006f60000 count:0 mapcount:0 mapping: (null) index:0x20a00
flags: 0x200000000040019(locked|uptodate|dirty|swapbacked)
raw: 0200000000040019 0000000000000000 0000000000020a00 00000000ffffffff
raw: ffffea0006f60020 ffffea0006f60020 0000000000000000 0000000000000000
bad because of flags: 0x1(locked)
Modules linked in:
CPU: 1 PID: 3037 Comm: syzkaller412798 Not tainted 4.13.0-rc5+ #35
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
bad_page+0x230/0x2b0 mm/page_alloc.c:565
free_pages_check_bad+0x1f0/0x2e0 mm/page_alloc.c:943
free_pages_check mm/page_alloc.c:952 [inline]
free_pages_prepare mm/page_alloc.c:1043 [inline]
free_pcp_prepare mm/page_alloc.c:1068 [inline]
free_hot_cold_page+0x8cf/0x12b0 mm/page_alloc.c:2584
__put_single_page mm/swap.c:79 [inline]
__put_page+0xfb/0x160 mm/swap.c:113
put_page include/linux/mm.h:814 [inline]
madvise_free_pte_range+0x137a/0x1ec0 mm/madvise.c:371
walk_pmd_range mm/pagewalk.c:50 [inline]
walk_pud_range mm/pagewalk.c:108 [inline]
walk_p4d_range mm/pagewalk.c:134 [inline]
walk_pgd_range mm/pagewalk.c:160 [inline]
__walk_page_range+0xc3a/0x1450 mm/pagewalk.c:249
walk_page_range+0x200/0x470 mm/pagewalk.c:326
madvise_free_page_range.isra.9+0x17d/0x230 mm/madvise.c:444
madvise_free_single_vma+0x353/0x580 mm/madvise.c:471
madvise_dontneed_free mm/madvise.c:555 [inline]
madvise_vma mm/madvise.c:664 [inline]
SYSC_madvise mm/madvise.c:832 [inline]
SyS_madvise+0x7d3/0x13c0 mm/madvise.c:760
entry_SYSCALL_64_fastpath+0x1f/0xbe
Here is a C reproducer:
#define _GNU_SOURCE
#include <pthread.h>
#include <sys/mman.h>
#include <unistd.h>
#define MADV_FREE 8
#define PAGE_SIZE 4096
static void *mapping;
static const size_t mapping_size = 0x1000000;
static void *madvise_thrproc(void *arg)
madvise(mapping, mapping_size, (long)arg);
int main(void)
pthread_t t[2];
for (;;) {
mapping = mmap(NULL, mapping_size, PROT_WRITE,
MAP_POPULATE|MAP_ANONYMOUS|MAP_PRIVATE, -1, 0);
munmap(mapping + mapping_size / 2, PAGE_SIZE);
pthread_create(&t[0], 0, madvise_thrproc, (void*)MADV_DONTNEED);
pthread_create(&t[1], 0, madvise_thrproc, (void*)MADV_FREE);
pthread_join(t[0], NULL);
pthread_join(t[1], NULL);
munmap(mapping, mapping_size);
Note: to see the splat, CONFIG_TRANSPARENT_HUGEPAGE=y and
CONFIG_DEBUG_VM=y are needed.
Google Bug Id: 64696096
Link: http://lkml.kernel.org/r/20170823205235.132061-1-ebiggers3@gmail.com
Fixes: 854e9ed09ded ("mm: support madvise(MADV_FREE)")
Cc: Dmitry Vyukov <dvyukov@google.com>
commit 435c0b87d661da83771c30ed775f7c37eed193fb upstream.
/sys/kernel/mm/transparent_hugepage/shmem_enabled controls if we want
to allocate huge pages when allocate pages for private in-kernel shmem
mount.
Unfortunately, as Dan noticed, I've screwed it up and the only way to
make kernel allocate huge page for the mount is to use "force" there.
All other values will be effectively ignored.
Link: http://lkml.kernel.org/r/20170822144254.66431-1-kirill.shutemov@linux.intel.com
Fixes: 5a6e75f8110c ("shmem: prepare huge= mount option and sysfs knob")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit 197e7e521384a23b9e585178f3f11c9fa08274b9 upstream.
The 'move_paghes()' system call was introduced long long ago with the
same permission checks as for sending a signal (except using
CAP_SYS_NICE instead of CAP_SYS_KILL for the overriding capability).
That turns out to not be a great choice - while the system call really
only moves physical page allocations around (and you need other
capabilities to do a lot of it), you can check the return value to map
out some the virtual address choices and defeat ASLR of a binary that
still shares your uid.
So change the access checks to the more common 'ptrace_may_access()'
model instead.
This tightens the access checks for the uid, and also effectively
changes the CAP_SYS_NICE check to CAP_SYS_PTRACE, but it's unlikely that
anybody really _uses_ this legacy system call any more (we hav ebetter
NUMA placement models these days), so I expect nobody to notice.
Famous last words.
Reported-by: Otto Ebeling <otto.ebeling@iki.fi>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: Willy Tarreau <w@1wt.eu>
commit 73223e4e2e3867ebf033a5a8eb2e5df0158ccc99 upstream.
I hit a use after free issue when executing trinity and repoduced it
with KASAN enabled. The related call trace is as follows.
BUG: KASan: use after free in SyS_get_mempolicy+0x3c8/0x960 at addr ffff8801f582d766
Read of size 2 by task syz-executor1/798
INFO: Allocated in mpol_new.part.2+0x74/0x160 age=3 cpu=1 pid=799
__slab_alloc+0x768/0x970
kmem_cache_alloc+0x2e7/0x450
mpol_new+0x66/0x80
SyS_mbind+0x267/0x9f0
system_call_fastpath+0x16/0x1b
INFO: Freed in __mpol_put+0x2b/0x40 age=4 cpu=1 pid=799
__slab_free+0x495/0x8e0
kmem_cache_free+0x2f3/0x4c0
SyS_mbind+0x383/0x9f0
INFO: Slab 0xffffea0009cb8dc0 objects=23 used=8 fp=0xffff8801f582de40 flags=0x200000000004080
INFO: Object 0xffff8801f582d760 @offset=5984 fp=0xffff8801f582d600
Bytes b4 ffff8801f582d750: ae 01 ff ff 00 00 00 00 5a 5a 5a 5a 5a 5a 5a 5a ........ZZZZZZZZ
Object ffff8801f582d760: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object ffff8801f582d770: 6b 6b 6b 6b 6b 6b 6b a5 kkkkkkk.
Redzone ffff8801f582d778: bb bb bb bb bb bb bb bb ........
Padding ffff8801f582d8b8: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ
Memory state around the buggy address:
ffff8801f582d600: fb fb fb fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8801f582d680: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff8801f582d700: fc fc fc fc fc fc fc fc fc fc fc fc fb fb fb fc
!shared memory policy is not protected against parallel removal by other
thread which is normally protected by the mmap_sem. do_get_mempolicy,
however, drops the lock midway while we can still access it later.
Early premature up_read is a historical artifact from times when
put_user was called in this path see https://lwn.net/Articles/124754/
but that is gone since 8bccd85ffbaf ("[PATCH] Implement sys_* do_*
layering in the memory policy layer."). but when we have the the
current mempolicy ref count model. The issue was introduced
accordingly.
Fix the issue by removing the premature release.
Link: http://lkml.kernel.org/r/1502950924-27521-1-git-send-email-zhongjiang@huawei.com
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
commit 5b53a6ea886700a128b697a6fe8375340dea2c30 upstream.
Tetsuo Handa has noticed that MMF_UNSTABLE SIGBUS path in
handle_mm_fault causes a lockdep splat
Out of memory: Kill process 1056 (a.out) score 603 or sacrifice child
Killed process 1056 (a.out) total-vm:4268108kB, anon-rss:2246048kB, file-rss:0kB, shmem-rss:0kB
a.out (1169) used greatest stack depth: 11664 bytes left
DEBUG_LOCKS_WARN_ON(depth <= 0)
WARNING: CPU: 6 PID: 1339 at kernel/locking/lockdep.c:3617 lock_release+0x172/0x1e0
CPU: 6 PID: 1339 Comm: a.out Not tainted 4.13.0-rc3-next-20170803+ #142
Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015
RIP: 0010:lock_release+0x172/0x1e0
Call Trace:
up_read+0x1a/0x40
__do_page_fault+0x28e/0x4c0
do_page_fault+0x30/0x80
page_fault+0x28/0x30
The reason is that the page fault path might have dropped the mmap_sem
and returned with VM_FAULT_RETRY. MMF_UNSTABLE check however rewrites
the error path to VM_FAULT_SIGBUS and we always expect mmap_sem taken in
that path. Fix this by taking mmap_sem when VM_FAULT_RETRY is held in
the MMF_UNSTABLE path.
We cannot simply add VM_FAULT_SIGBUS to the existing error code because
all arch specific page fault handlers and g-u-p would have to learn a
new error code combination.
Link: http://lkml.kernel.org/r/20170807113839.16695-2-mhocko@kernel.org
Fixes: 3f70dc38cec2 ("mm: make sure that kthreads will not refault oom reaped memory")
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: Andrea Argangeli <andrea@kernel.org>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Wenwei Tao <wenwei.tww@alibaba-inc.com>
commit 3010f876500f9ba921afaeccec30c45ca6584dc8 upstream.
There is existing use after free bug when deferred struct pages are
enabled:
The memblock_add() allocates memory for the memory array if more than
128 entries are needed. See comment in e820__memblock_setup():
* The bootstrap memblock region count maximum is 128 entries
* (INIT_MEMBLOCK_REGIONS), but EFI might pass us more E820 entries
* than that - so allow memblock resizing.
This memblock memory is freed here:
free_low_memory_core_early()
We access the freed memblock.memory later in boot when deferred pages
are initialized in this path:
deferred_init_memmap()
for_each_mem_pfn_range()
__next_mem_pfn_range()
type = &memblock.memory;
One possible explanation for why this use-after-free hasn't been hit
before is that the limit of INIT_MEMBLOCK_REGIONS has never been
exceeded at least on systems where deferred struct pages were enabled.
Tested by reducing INIT_MEMBLOCK_REGIONS down to 4 from the current 128,
and verifying in qemu that this code is getting excuted and that the
freed pages are sane.
Link: http://lkml.kernel.org/r/1502485554-318703-2-git-send-email-pasha.tatashin@oracle.com
Fixes: 7e18adb4f80b ("mm: meminit: initialise remaining struct pages in parallel with kswapd")
Reviewed-by: Steven Sistare <steven.sistare@oracle.com>
Reviewed-by: Daniel Jordan <daniel.m.jordan@oracle.com>
Reviewed-by: Bob Picco <bob.picco@oracle.com>
commit d041353dc98a6339182cd6f628b4c8f111278cb3 upstream.
We saw many list corruption warnings on shmem shrinklist:
WARNING: CPU: 18 PID: 177 at lib/list_debug.c:59 __list_del_entry+0x9e/0xc0
list_del corruption. prev->next should be ffff9ae5694b82d8, but was ffff9ae5699ba960
Modules linked in: intel_rapl sb_edac edac_core x86_pkg_temp_thermal coretemp iTCO_wdt iTCO_vendor_support crct10dif_pclmul crc32_pclmul ghash_clmulni_intel raid0 dcdbas shpchp wmi hed i2c_i801 ioatdma lpc_ich i2c_smbus acpi_cpufreq tcp_diag inet_diag sch_fq_codel ipmi_si ipmi_devintf ipmi_msghandler igb ptp crc32c_intel pps_core i2c_algo_bit i2c_core dca ipv6 crc_ccitt
CPU: 18 PID: 177 Comm: kswapd1 Not tainted 4.9.34-t3.el7.twitter.x86_64 #1
Hardware name: Dell Inc. PowerEdge C6220/0W6W6G, BIOS 2.2.3 11/07/2013
Call Trace:
dump_stack+0x4d/0x66
__warn+0xcb/0xf0
warn_slowpath_fmt+0x4f/0x60
shmem_unused_huge_shrink+0xfa/0x2e0
shmem_unused_huge_scan+0x20/0x30
super_cache_scan+0x193/0x1a0
shrink_slab.part.41+0x1e3/0x3f0
shrink_slab+0x29/0x30
shrink_node+0xf9/0x2f0
kswapd+0x2d8/0x6c0
kthread+0xd7/0xf0
ret_from_fork+0x22/0x30
WARNING: CPU: 23 PID: 639 at lib/list_debug.c:33 __list_add+0x89/0xb0
list_add corruption. prev->next should be next (ffff9ae5699ba960), but was ffff9ae5694b82d8. (prev=ffff9ae5694b82d8).
CPU: 23 PID: 639 Comm: systemd-udevd Tainted: G W 4.9.34-t3.el7.twitter.x86_64 #1
Call Trace:
__warn+0xcb/0xf0
shmem_setattr+0x204/0x230
notify_change+0x2ef/0x440
do_truncate+0x5d/0x90
path_openat+0x331/0x1190
do_filp_open+0x7e/0xe0
do_sys_open+0x123/0x200
SyS_open+0x1e/0x20
do_syscall_64+0x61/0x170
entry_SYSCALL64_slow_path+0x25/0x25
The problem is that shmem_unused_huge_shrink() moves entries from the
global sbinfo->shrinklist to its local lists and then releases the
spinlock. However, a parallel shmem_setattr() could access one of these
entries directly and add it back to the global shrinklist if it is
removed, with the spinlock held.
The logic itself looks solid since an entry could be either in a local
list or the global list, otherwise it is removed from one of them by
list_del_init(). So probably the race condition is that, one CPU is in
the middle of INIT_LIST_HEAD() but the other CPU calls list_empty()
which returns true too early then the following list_add_tail() sees a
corrupted entry.
list_empty_careful() is designed to fix this situation.
[akpm@linux-foundation.org: add comments]
Link: http://lkml.kernel.org/r/20170803054630.18775-1-xiyou.wangcong@gmail.com
Fixes: 779750d20b93 ("shmem: split huge pages beyond i_size under memory pressure")
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 75dddef32514f7aa58930bde6a1263253bc3d4ba upstream.
The RDMA subsystem can generate several thousand of these messages per
second eventually leading to a kernel crash. Ratelimit these messages
to prevent this crash.
Doug said:
"I've been carrying a version of this for several kernel versions. I
don't remember when they started, but we have one (and only one) class
of machines: Dell PE R730xd, that generate these errors. When it
happens, without a rate limit, we get rcu timeouts and kernel oopses.
With the rate limit, we just get a lot of annoying kernel messages but
the machine continues on, recovers, and eventually the memory
operations all succeed"
And:
"> Well... why are all these EBUSY's occurring? It sounds inefficient
> (at least) but if it is expected, normal and unavoidable then
> perhaps we should just remove that message altogether?
I don't have an answer to that question. To be honest, I haven't
looked real hard. We never had this at all, then it started out of the
blue, but only on our Dell 730xd machines (and it hits all of them),
but no other classes or brands of machines. And we have our 730xd
machines loaded up with different brands and models of cards (for
instance one dedicated to mlx4 hardware, one for qib, one for mlx5, an
ocrdma/cxgb4 combo, etc), so the fact that it hit all of the machines
meant it wasn't tied to any particular brand/model of RDMA hardware.
To me, it always smelled of a hardware oddity specific to maybe the
CPUs or mainboard chipsets in these machines, so given that I'm not an
mm expert anyway, I never chased it down.
A few other relevant details: it showed up somewhere around 4.8/4.9 or
thereabouts. It never happened before, but the prinkt has been there
since the 3.18 days, so possibly the test to trigger this message was
changed, or something else in the allocator changed such that the
situation started happening on these machines?
And, like I said, it is specific to our 730xd machines (but they are
all identical, so that could mean it's something like their specific
ram configuration is causing the allocator to hit this on these
machine but not on other machines in the cluster, I don't want to say
it's necessarily the model of chipset or CPU, there are other bits of
identicalness between these machines)"
Link: http://lkml.kernel.org/r/499c0f6cc10d6eb829a67f2a4d75b4228a9b356e.1501695897.git.jtoppins@redhat.com
Signed-off-by: Jonathan Toppins <jtoppins@redhat.com>
Reviewed-by: Doug Ledford <dledford@redhat.com>
Tested-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit f073bdc51771f5a5c7a8d1191bfc3ae371d44de7 ]
The VM_BUG_ON() check in move_freepages() checks whether the node id of
a page matches the node id of its zone. However, it does this before
having checked whether the struct page pointer refers to a valid struct
page to begin with. This is guaranteed in most cases, but may not be
the case if CONFIG_HOLES_IN_ZONE=y.
So reorder the VM_BUG_ON() with the pfn_valid_within() check.
Link: http://lkml.kernel.org/r/1481706707-6211-2-git-send-email-ard.biesheuvel@linaro.org
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Robert Richter <rrichter@cavium.com>
Cc: James Morse <james.morse@arm.com>
commit adb1fe9ae2ee6ef6bc10f3d5a588020e7664dfa7 upstream.
Linus suggested we try to remove some of the low-hanging fruit related
to kernel address exposure in dmesg. The only leaks I see on my local
system are:
Freeing SMP alternatives memory: 32K (ffffffff9e309000 - ffffffff9e311000)
Freeing initrd memory: 10588K (ffffa0b736b42000 - ffffa0b737599000)
Freeing unused kernel memory: 3592K (ffffffff9df87000 - ffffffff9e309000)
Freeing unused kernel memory: 1352K (ffffa0b7288ae000 - ffffa0b728a00000)
Freeing unused kernel memory: 632K (ffffa0b728d62000 - ffffa0b728e00000)
Linus says:
"I suspect we should just remove [the addresses in the 'Freeing'
messages]. I'm sure they are useful in theory, but I suspect they
were more useful back when the whole "free init memory" was
originally done.
These days, if we have a use-after-free, I suspect the init-mem
situation is the easiest situation by far. Compared to all the dynamic
allocations which are much more likely to show it anyway. So having
debug output for that case is likely not all that productive."
With this patch the freeing messages now look like this:
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/6836ff90c45b71d38e5d4405aec56fa9e5d1d4b2.1477405374.git.jpoimboe@redhat.com
Cc: Kees Cook <keescook@google.com>
leaving stale TLB entries
commit 3ea277194daaeaa84ce75180ec7c7a2075027a68 upstream.
Nadav Amit identified a theoritical race between page reclaim and
mprotect due to TLB flushes being batched outside of the PTL being held.
He described the race as follows:
CPU0 CPU1
user accesses memory using RW PTE
[PTE now cached in TLB]
try_to_unmap_one()
==> ptep_get_and_clear()
==> set_tlb_ubc_flush_pending()
mprotect(addr, PROT_READ)
==> change_pte_range()
==> [ PTE non-present - no flush ]
user writes using cached RW PTE
try_to_unmap_flush()
The same type of race exists for reads when protecting for PROT_NONE and
also exists for operations that can leave an old TLB entry behind such
as munmap, mremap and madvise.
For some operations like mprotect, it's not necessarily a data integrity
issue but it is a correctness issue as there is a window where an
mprotect that limits access still allows access. For munmap, it's
potentially a data integrity issue although the race is massive as an
munmap, mmap and return to userspace must all complete between the
window when reclaim drops the PTL and flushes the TLB. However, it's
theoritically possible so handle this issue by flushing the mm if
reclaim is potentially currently batching TLB flushes.
Other instances where a flush is required for a present pte should be ok
as either the page lock is held preventing parallel reclaim or a page
reference count is elevated preventing a parallel free leading to
corruption. In the case of page_mkclean there isn't an obvious path
that userspace could take advantage of without using the operations that
are guarded by this patch. Other users such as gup as a race with
reclaim looks just at PTEs. huge page variants should be ok as they
don't race with reclaim. mincore only looks at PTEs. userfault also
should be ok as if a parallel reclaim takes place, it will either fault
the page back in or read some of the data before the flush occurs
triggering a fault.
Note that a variant of this patch was acked by Andy Lutomirski but this
was for the x86 parts on top of his PCID work which didn't make the 4.13
merge window as expected. His ack is dropped from this version and
there will be a follow-on patch on top of PCID that will include his
ack.
[akpm@linux-foundation.org: tweak comments]
[akpm@linux-foundation.org: fix spello]
Link: http://lkml.kernel.org/r/20170717155523.emckq2esjro6hf3z@suse.de
Reported-by: Nadav Amit <nadav.amit@gmail.com>
commit 37511fb5c91db93d8bd6e3f52f86e5a7ff7cfcdf upstream.
Jörn Engel noticed that the expand_upwards() function might not return
-ENOMEM in case the requested address is (unsigned long)-PAGE_SIZE and
if the architecture didn't defined TASK_SIZE as multiple of PAGE_SIZE.
Affected architectures are arm, frv, m68k, blackfin, h8300 and xtensa
which all define TASK_SIZE as 0xffffffff, but since none of those have
an upwards-growing stack we currently have no actual issue.
Nevertheless let's fix this just in case any of the architectures with
an upward-growing stack (currently parisc, metag and partly ia64) define
TASK_SIZE similar.
Link: http://lkml.kernel.org/r/20170702192452.GA11868@p100.box
Fixes: bd726c90b6b8 ("Allow stack to grow up to address space limit")
Signed-off-by: Helge Deller <deller@gmx.de>
Reported-by: Jörn Engel <joern@purestorage.com>
commit 2c80cd57c74339889a8752b20862a16c28929c3a upstream.
list_lru_count_node() iterates over all memcgs to get the total number of
entries on the node but it can race with memcg_drain_all_list_lrus(),
which migrates the entries from a dead cgroup to another. This can return
incorrect number of entries from list_lru_count_node().
Fix this by keeping track of entries per node and simply return it in
Link: http://lkml.kernel.org/r/1498707555-30525-1-git-send-email-stummala@codeaurora.org
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Alexander Polakov <apolyakov@beget.ru>
commit bbf29ffc7f963bb894f84f0580c70cfea01c3892 upstream.
Reinette reported the following crash:
BUG: Bad page state in process log2exe pfn:57600
page:ffffea00015d8000 count:0 mapcount:0 mapping: (null) index:0x20200
flags: 0x4000000000040019(locked|uptodate|dirty|swapbacked)
raw: 4000000000040019 0000000000000000 0000000000020200 00000000ffffffff
raw: ffffea00015d8020 ffffea00015d8020 0000000000000000 0000000000000000
Modules linked in: rfcomm 8021q bnep intel_rapl x86_pkg_temp_thermal coretemp efivars btusb btrtl btbcm pwm_lpss_pci snd_hda_codec_hdmi btintel pwm_lpss snd_hda_codec_realtek snd_soc_skl snd_hda_codec_generic snd_soc_skl_ipc spi_pxa2xx_platform snd_soc_sst_ipc snd_soc_sst_dsp i2c_designware_platform i2c_designware_core snd_hda_ext_core snd_soc_sst_match snd_hda_intel snd_hda_codec mei_me snd_hda_core mei snd_soc_rt286 snd_soc_rl6347a snd_soc_core efivarfs
CPU: 1 PID: 354 Comm: log2exe Not tainted 4.12.0-rc7-test-test #19
Hardware name: Intel corporation NUC6CAYS/NUC6CAYB, BIOS AYAPLCEL.86A.0027.2016.1108.1529 11/08/2016
Call Trace:
bad_page+0x16a/0x1f0
free_pages_check_bad+0x117/0x190
free_hot_cold_page+0x7b1/0xad0
__put_page+0x70/0xa0
madvise_free_huge_pmd+0x627/0x7b0
madvise_free_pte_range+0x6f8/0x1150
__walk_page_range+0x6b5/0xe30
walk_page_range+0x13b/0x310
madvise_free_page_range.isra.16+0xad/0xd0
madvise_free_single_vma+0x2e4/0x470
SyS_madvise+0x8ce/0x1450
If somebody frees the page under us and we hold the last reference to
it, put_page() would attempt to free the page before unlocking it.
The fix is trivial reorder of operations.
Dave said:
"I came up with the exact same patch. For posterity, here's the test
case, generated by syzkaller and trimmed down by Reinette:
https://www.sr71.net/~dave/intel/log2.c
And the config that helps detect this:
https://www.sr71.net/~dave/intel/config-log2"
Fixes: b8d3c4c3009d ("mm/huge_memory.c: don't split THP page when MADV_FREE syscall is called")
Link: http://lkml.kernel.org/r/20170628101249.17879-1-kirill.shutemov@linux.intel.com
Reported-by: Reinette Chatre <reinette.chatre@intel.com>
Acked-by: Dave Hansen <dave.hansen@intel.com>
Cc: Huang Ying <ying.huang@intel.com>
commit 029c54b09599573015a5c18dbe59cbdf42742237 upstream.
Existing code that uses vmalloc_to_page() may assume that any address
for which is_vmalloc_addr() returns true may be passed into
vmalloc_to_page() to retrieve the associated struct page.
This is not un unreasonable assumption to make, but on architectures
that have CONFIG_HAVE_ARCH_HUGE_VMAP=y, it no longer holds, and we need
to ensure that vmalloc_to_page() does not go off into the weeds trying
to dereference huge PUDs or PMDs as table entries.
Given that vmalloc() and vmap() themselves never create huge mappings or
deal with compound pages at all, there is no correct answer in this
case, so return NULL instead, and issue a warning.
When reading /proc/kcore on arm64, you will hit an oops as soon as you
hit the huge mappings used for the various segments that make up the
mapping of vmlinux. With this patch applied, you will no longer hit the
oops, but the kcore contents willl be incorrect (these regions will be
zeroed out)
We are fixing this for kcore specifically, so it avoids vread() for
those regions. At least one other problematic user exists, i.e.,
/dev/kmem, but that is currently broken on arm64 for other reasons.
Link: http://lkml.kernel.org/r/20170609082226.26152-1-ard.biesheuvel@linaro.org
Acked-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Cc: zhong jiang <zhongjiang@huawei.com>
[ardb: non-trivial backport to v4.9]
commit 3c226c637b69104f6b9f1c6ec5b08d7b741b3229 upstream.
In do_huge_pmd_numa_page(), we attempt to handle a migrating thp pmd by
waiting until the pmd is unlocked before we return and retry. However,
we can race with migrate_misplaced_transhuge_page():
// do_huge_pmd_numa_page // migrate_misplaced_transhuge_page()
// Holds 0 refs on page // Holds 2 refs on page
vmf->ptl = pmd_lock(vma->vm_mm, vmf->pmd);
if (pmd_trans_migrating(*vmf->pmd)) {
page = pmd_page(*vmf->pmd);
spin_unlock(vmf->ptl);
ptl = pmd_lock(mm, pmd);
if (page_count(page) != 2)) {
/* roll back */
mlock_migrate_page(new_page, page);
spin_unlock(ptl);
put_page(page);
put_page(page); // page freed here
wait_on_page_locked(page);
goto out;
This can result in the freed page having its waiters flag set
unexpectedly, which trips the PAGE_FLAGS_CHECK_AT_PREP checks in the
page alloc/free functions. This has been observed on arm64 KVM guests.
We can avoid this by having do_huge_pmd_numa_page() take a reference on
the page before dropping the pmd lock, mirroring what we do in
__migration_entry_wait().
When we hit the race, migrate_misplaced_transhuge_page() will see the
reference and abort the migration, as it may do today in other cases.
Fixes: b8916634b77bffb2 ("mm: Prevent parallel splits during THP migration")
Link: http://lkml.kernel.org/r/1497349722-6731-2-git-send-email-will.deacon@arm.com
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Steve Capper <steve.capper@arm.com>
commit 460bcec84e11c75122ace5976214abbc596eb91b upstream.
We got need_resched() warnings in swap_cgroup_swapoff() because
swap_cgroup_ctrl[type].length is particularly large.
Reschedule when needed.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1704061315270.80559@chino.kir.corp.google.com
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit f4cb767d76cf7ee72f97dd76f6cfa6c76a5edc89 upstream.
Trinity gets kernel BUG at mm/mmap.c:1963! in about 3 minutes of
mmap testing. That's the VM_BUG_ON(gap_end < gap_start) at the
end of unmapped_area_topdown(). Linus points out how MAP_FIXED
(which does not have to respect our stack guard gap intentions)
could result in gap_end below gap_start there. Fix that, and
the similar case in its alternative, unmapped_area().
Fixes: 1be7107fbe18 ("mm: larger stack guard gap, between vmas")
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Debugged-by: Linus Torvalds <torvalds@linux-foundation.org>
commit bd726c90b6b8ce87602208701b208a208e6d5600 upstream.
Fix expand_upwards() on architectures with an upward-growing stack (parisc,
metag and partly IA-64) to allow the stack to reliably grow exactly up to
the address space limit given by TASK_SIZE.
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit ef70762948dde012146926720b70e79736336764 upstream.
I saw need_resched() warnings when swapping on large swapfile (TBs)
because continuously allocating many pages in swap_cgroup_prepare() took
too long.
We already cond_resched when freeing page in swap_cgroup_swapoff(). Do
the same for the page allocation.
Link: http://lkml.kernel.org/r/20170604200109.17606-1-yuzhao@google.com
Signed-off-by: Yu Zhao <yuzhao@google.com>
commit 7258ae5c5a2ce2f5969e8b18b881be40ab55433d upstream.
memory_failure() chooses a recovery action function based on the page
flags. For huge pages it uses the tail page flags which don't have
anything interesting set, resulting in:
> Memory failure: 0x9be3b4: Unknown page state
> Memory failure: 0x9be3b4: recovery action for unknown page: Failed
Instead, save a copy of the head page's flags if this is a huge page,
this means if there are no relevant flags for this tail page, we use the
head pages flags instead. This results in the me_huge_page() recovery
action being called:
> Memory failure: 0x9b7969: recovery action for huge page: Delayed
For hugepages that have not yet been allocated, this allows the hugepage
to be dequeued.
Fixes: 524fca1e7356 ("HWPOISON: fix misjudgement of page_action() for errors on mlocked pages")
Link: http://lkml.kernel.org/r/20170524130204.21845-1-james.morse@arm.com
Signed-off-by: James Morse <james.morse@arm.com>
Tested-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
[ Upstream commit 4f40c6e5627ea73b4e7c615c59631f38cc880885 ]
After much waiting I finally reproduced a KASAN issue, only to find my
trace-buffer empty of useful information because it got spooled out :/
Make kasan_report honour the /proc/sys/kernel/traceoff_on_warning
interface.
Link: http://lkml.kernel.org/r/20170125164106.3514-1-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Acked-by: Alexander Potapenko <glider@google.com>
[ Upstream commit 253fd0f02040a19c6fe80e4171659fa3482a422d ]
Syzkaller fuzzer managed to trigger this:
BUG: sleeping function called from invalid context at mm/shmem.c:852
in_atomic(): 1, irqs_disabled(): 0, pid: 529, name: khugepaged
3 locks held by khugepaged/529:
#0: (shrinker_rwsem){++++..}, at: [<ffffffff818d7ef1>] shrink_slab.part.59+0x121/0xd30 mm/vmscan.c:451
#1: (&type->s_umount_key#29){++++..}, at: [<ffffffff81a63630>] trylock_super+0x20/0x100 fs/super.c:392
#2: (&(&sbinfo->shrinklist_lock)->rlock){+.+.-.}, at: [<ffffffff818fd83e>] spin_lock include/linux/spinlock.h:302 [inline]
#2: (&(&sbinfo->shrinklist_lock)->rlock){+.+.-.}, at: [<ffffffff818fd83e>] shmem_unused_huge_shrink+0x28e/0x1490 mm/shmem.c:427
CPU: 2 PID: 529 Comm: khugepaged Not tainted 4.10.0-rc5+ #201
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
shmem_undo_range+0xb20/0x2710 mm/shmem.c:852
shmem_truncate_range+0x27/0xa0 mm/shmem.c:939
shmem_evict_inode+0x35f/0xca0 mm/shmem.c:1030
evict+0x46e/0x980 fs/inode.c:553
iput_final fs/inode.c:1515 [inline]
iput+0x589/0xb20 fs/inode.c:1542
shmem_unused_huge_shrink+0xbad/0x1490 mm/shmem.c:446
shmem_unused_huge_scan+0x10c/0x170 mm/shmem.c:512
super_cache_scan+0x376/0x450 fs/super.c:106
do_shrink_slab mm/vmscan.c:378 [inline]
shrink_slab.part.59+0x543/0xd30 mm/vmscan.c:481
shrink_slab mm/vmscan.c:2592 [inline]
shrink_node+0x2c7/0x870 mm/vmscan.c:2592
shrink_zones mm/vmscan.c:2734 [inline]
do_try_to_free_pages+0x369/0xc80 mm/vmscan.c:2776
try_to_free_pages+0x3c6/0x900 mm/vmscan.c:2982
__perform_reclaim mm/page_alloc.c:3301 [inline]
__alloc_pages_direct_reclaim mm/page_alloc.c:3322 [inline]
__alloc_pages_slowpath+0xa24/0x1c30 mm/page_alloc.c:3683
__alloc_pages_nodemask+0x544/0xae0 mm/page_alloc.c:3848
__alloc_pages include/linux/gfp.h:426 [inline]
__alloc_pages_node include/linux/gfp.h:439 [inline]
khugepaged_alloc_page+0xc2/0x1b0 mm/khugepaged.c:750
collapse_huge_page+0x182/0x1fe0 mm/khugepaged.c:955
khugepaged_scan_pmd+0xfdf/0x12a0 mm/khugepaged.c:1208
khugepaged_scan_mm_slot mm/khugepaged.c:1727 [inline]
khugepaged_do_scan mm/khugepaged.c:1808 [inline]
khugepaged+0xe9b/0x1590 mm/khugepaged.c:1853
kthread+0x326/0x3f0 kernel/kthread.c:227
ret_from_fork+0x31/0x40 arch/x86/entry/entry_64.S:430
The iput() from atomic context was a bad idea: if after igrab() somebody
else calls iput() and we left with the last inode reference, our iput()
would lead to inode eviction and therefore sleeping.
This patch should fix the situation.
Link: http://lkml.kernel.org/r/20170131093141.GA15899@node.shutemov.name
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream.
Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs
branch.
This patch also fixes multiple checkpatch warnings: WARNING: Prefer
'unsigned int' to bare use of 'unsigned'
Thanks to Andrew Morton for suggesting more appropriate function instead
of macro.
[geliangtang@gmail.com: truncate: use i_blocksize()]
Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com
Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
commit aa2efd5ea4041754da4046c3d2e7edaac9526258 upstream.
Currently when trace is enabled (e.g. slub_debug=T,kmalloc-128 ) the
trace messages are mostly output at KERN_INFO. However the trace code
also calls print_section() to hexdump the head of a free object. This
is hard coded to use KERN_ERR, meaning the console is deluged with trace
messages even if we've asked for quiet.
Fix this the obvious way but adding a level parameter to
print_section(), allowing calls from the trace code to use the same
trace level as other trace messages.
Link: http://lkml.kernel.org/r/20170113154850.518-1-daniel.thompson@linaro.org
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Pekka Enberg <penberg@kernel.org>
commit 478fe3037b2278d276d4cd9cd0ab06c4cb2e9b32 upstream.
memcg_propagate_slab_attrs() abuses the sysfs attribute file functions
to propagate settings from the root kmem_cache to a newly created
kmem_cache. It does that with:
attr->show(root, buf);
attr->store(new, buf, strlen(bug);
Aside of being a lazy and absurd hackery this is broken because it does
not check the return value of the show() function.
Some of the show() functions return 0 w/o touching the buffer. That
means in such a case the store function is called with the stale content
of the previous show(). That causes nonsense like invoking
kmem_cache_shrink() on a newly created kmem_cache. In the worst case it
would cause handing in an uninitialized buffer.
This should be rewritten proper by adding a propagate() callback to
those slub_attributes which must be propagated and avoid that insane
conversion to and from ASCII, but that's too large for a hot fix.
Check at least the return value of the show() function, so calling
store() with stale content is prevented.
Steven said:
"It can cause a deadlock with get_online_cpus() that has been uncovered
by recent cpu hotplug and lockdep changes that Thomas and Peter have
been doing.
Possible unsafe locking scenario:
CPU0 CPU1
lock(cpu_hotplug.lock);
lock(slab_mutex);
lock(slab_mutex);
*** DEADLOCK ***"
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1705201244540.2255@nanos
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
commit a7306c3436e9c8e584a4b9fad5f3dc91be2a6076 upstream.
"err" needs to be left set to -EFAULT if split_huge_page succeeds.
Otherwise if "err" gets clobbered with zero and write_protect_page
fails, try_to_merge_one_page() will succeed instead of returning -EFAULT
and then try_to_merge_with_ksm_page() will continue thinking kpage is a
PageKsm when in fact it's still an anonymous page. Eventually it'll
crash in page_add_anon_rmap.
This has been reproduced on Fedora25 kernel but I can reproduce with
upstream too.
The bug was introduced in commit f765f540598a ("ksm: prepare to new THP
semantics") introduced in v4.5.
page:fffff67546ce1cc0 count:4 mapcount:2 mapping:ffffa094551e36e1 index:0x7f0f46673
flags: 0x2ffffc0004007c(referenced|uptodate|dirty|lru|active|swapbacked)
page dumped because: VM_BUG_ON_PAGE(!PageLocked(page))
page->mem_cgroup:ffffa09674bf0000
kernel BUG at mm/rmap.c:1222!
CPU: 1 PID: 76 Comm: ksmd Not tainted 4.9.3-200.fc25.x86_64 #1
RIP: do_page_add_anon_rmap+0x1c4/0x240
Call Trace:
page_add_anon_rmap+0x18/0x20
try_to_merge_with_ksm_page+0x50b/0x780
ksm_scan_thread+0x1211/0x1410
? prepare_to_wait_event+0x100/0x100
? try_to_merge_with_ksm_page+0x780/0x780
kthread+0xd9/0xf0
? kthread_park+0x60/0x60
ret_from_fork+0x25/0x30
Fixes: f765f54059 ("ksm: prepare to new THP semantics")
Link: http://lkml.kernel.org/r/20170513131040.21732-1-aarcange@redhat.com
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: Federico Simoncelli <fsimonce@redhat.com>
commit 864b9a393dcb5aed09b8fd31b9bbda0fdda99374 upstream.
We have seen an early OOM killer invocation on ppc64 systems with
crashkernel=4096M:
kthreadd invoked oom-killer: gfp_mask=0x16040c0(GFP_KERNEL|__GFP_COMP|__GFP_NOTRACK), nodemask=7, order=0, oom_score_adj=0
kthreadd cpuset=/ mems_allowed=7
CPU: 0 PID: 2 Comm: kthreadd Not tainted 4.4.68-1.gd7fe927-default #1
Call Trace:
dump_stack+0xb0/0xf0 (unreliable)
dump_header+0xb0/0x258
out_of_memory+0x5f0/0x640
__alloc_pages_nodemask+0xa8c/0xc80
kmem_getpages+0x84/0x1a0
fallback_alloc+0x2a4/0x320
kmem_cache_alloc_node+0xc0/0x2e0
copy_process.isra.25+0x260/0x1b30
_do_fork+0x94/0x470
kernel_thread+0x48/0x60
kthreadd+0x264/0x330
ret_from_kernel_thread+0x5c/0xa4
Mem-Info:
active_anon:0 inactive_anon:0 isolated_anon:0
active_file:0 inactive_file:0 isolated_file:0
unevictable:0 dirty:0 writeback:0 unstable:0
slab_reclaimable:5 slab_unreclaimable:73
mapped:0 shmem:0 pagetables:0 bounce:0
free:0 free_pcp:0 free_cma:0
Node 7 DMA free:0kB min:0kB low:0kB high:0kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:52428800kB managed:110016kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:320kB slab_unreclaimable:4672kB kernel_stack:1152kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
lowmem_reserve[]: 0 0 0 0
Node 7 DMA: 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 0kB
0 total pagecache pages
0 pages in swap cache
Swap cache stats: add 0, delete 0, find 0/0
Free swap = 0kB
Total swap = 0kB
819200 pages RAM
0 pages HighMem/MovableOnly
817481 pages reserved
0 pages cma reserved
0 pages hwpoisoned
the reason is that the managed memory is too low (only 110MB) while the
rest of the the 50GB is still waiting for the deferred intialization to
be done. update_defer_init estimates the initial memoty to initialize
to 2GB at least but it doesn't consider any memory allocated in that
range. In this particular case we've had
Reserving 4096MB of memory at 128MB for crashkernel (System RAM: 51200MB)
so the low 2GB is mostly depleted.
Fix this by considering memblock allocations in the initial static
initialization estimation. Move the max_initialise to
reset_deferred_meminit and implement a simple memblock_reserved_memory
helper which iterates all reserved blocks and sums the size of all that
start below the given address. The cumulative size is than added on top
of the initial estimation. This is still not ideal because
reset_deferred_meminit doesn't consider holes and so reservation might
be above the initial estimation whihch we ignore but let's make the
logic simpler until we really need to handle more complicated cases.
Fixes: 3a80a7fa7989 ("mm: meminit: initialise a subset of struct pages if CONFIG_DEFERRED_STRUCT_PAGE_INIT is set")
Link: http://lkml.kernel.org/r/20170531104010.GI27783@dhcp22.suse.cz
Signed-off-by: Michal Hocko <mhocko@suse.com>
Tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
