commit 8ca3eb08097f6839b2206e2242db4179aee3cfb3 upstream.
pa-risc and ia64 have stacks that grow upwards. Check that
they do not run into other mappings. By making VM_GROWSUP
0x0 on architectures that do not ever use it, we can avoid
some unpleasant #ifdefs in check_stack_guard_page().
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: dann frazier <dannf@debian.org>
free list
commit 72853e2991a2702ae93aaf889ac7db743a415dd3 upstream.
When allocating a page, the system uses NR_FREE_PAGES counters to
determine if watermarks would remain intact after the allocation was made.
This check is made without interrupts disabled or the zone lock held and
so is race-prone by nature. Unfortunately, when pages are being freed in
batch, the counters are updated before the pages are added on the list.
During this window, the counters are misleading as the pages do not exist
yet. When under significant pressure on systems with large numbers of
CPUs, it's possible for processes to make progress even though they should
have been stalled. This is particularly problematic if a number of the
processes are using GFP_ATOMIC as the min watermark can be accidentally
breached and in extreme cases, the system can livelock.
This patch updates the counters after the pages have been added to the
list. This makes the allocator more cautious with respect to preserving
the watermarks and mitigates livelock possibilities.
[akpm@linux-foundation.org: avoid modifying incoming args]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
is low and kswapd is awake
commit aa45484031ddee09b06350ab8528bfe5b2c76d1c upstream.
Ordinarily watermark checks are based on the vmstat NR_FREE_PAGES as it is
cheaper than scanning a number of lists. To avoid synchronization
overhead, counter deltas are maintained on a per-cpu basis and drained
both periodically and when the delta is above a threshold. On large CPU
systems, the difference between the estimated and real value of
NR_FREE_PAGES can be very high. If NR_FREE_PAGES is much higher than
number of real free page in buddy, the VM can allocate pages below min
watermark, at worst reducing the real number of pages to zero. Even if
the OOM killer kills some victim for freeing memory, it may not free
memory if the exit path requires a new page resulting in livelock.
This patch introduces a zone_page_state_snapshot() function (courtesy of
Christoph) that takes a slightly more accurate view of an arbitrary vmstat
counter. It is used to read NR_FREE_PAGES while kswapd is awake to avoid
the watermark being accidentally broken. The estimate is not perfect and
may result in cache line bounces but is expected to be lighter than the
IPI calls necessary to continually drain the per-cpu counters while kswapd
is awake.
Signed-off-by: Christoph Lameter <cl@linux.com>
commit 9ee493ce0a60bf42c0f8fd0b0fe91df5704a1cbf upstream.
When under significant memory pressure, a process enters direct reclaim
and immediately afterwards tries to allocate a page. If it fails and no
further progress is made, it's possible the system will go OOM. However,
on systems with large amounts of memory, it's possible that a significant
number of pages are on per-cpu lists and inaccessible to the calling
process. This leads to a process entering direct reclaim more often than
it should increasing the pressure on the system and compounding the
problem.
This patch notes that if direct reclaim is making progress but allocations
are still failing that the system is already under heavy pressure. In
this case, it drains the per-cpu lists and tries the allocation a second
time before continuing.
Cc: Wu Fengguang <fengguang.wu@intel.com>
commit 46b30ea9bc3698bc1d1e6fd726c9601d46fa0a91 upstream.
pcpu_first/last_unit_cpu are used to track which cpu has the first and
last units assigned. This in turn is used to determine the span of a
chunk for man/unmap cache flushes and whether an address belongs to
the first chunk or not in per_cpu_ptr_to_phys().
When the number of possible CPUs isn't power of two, a chunk may
contain unassigned units towards the end of a chunk. The logic to
determine pcpu_last_unit_cpu was incorrect when there was an unused
unit at the end of a chunk. It failed to ignore the unused unit and
assigned the unused marker NR_CPUS to pcpu_last_unit_cpu.
This was discovered through kdump failure which was caused by
malfunctioning per_cpu_ptr_to_phys() on a kvm setup with 50 possible
CPUs by CAI Qian.
Reported-by: CAI Qian <caiqian@redhat.com>
commit 0dcc48c15f63ee86c2fcd33968b08d651f0360a5 upstream.
next_active_pageblock() is for finding next _used_ freeblock. It skips
several blocks when it finds there are a chunk of free pages lager than
pageblock. But it has 2 bugs.
1. We have no lock. page_order(page) - pageblock_order can be minus.
2. pageblocks_stride += is wrong. it should skip page_order(p) of pages.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit ac8456d6f9a3011c824176bd6084d39e5f70a382 upstream.
I have been seeing problems on Tegra 2 (ARMv7 SMP) systems with HIGHMEM
enabled on 2.6.35 (plus some patches targetted at 2.6.36 to perform cache
maintenance lazily), and the root cause appears to be that the mm bouncing
code is calling flush_dcache_page before it copies the bounce buffer into
the bio.
The bounced page needs to be flushed after data is copied into it, to
ensure that architecture implementations can synchronize instruction and
data caches if necessary.
Signed-off-by: Gary King <gking@nvidia.com>
Cc: Tejun Heo <tj@kernel.org>
Acked-by: Jens Axboe <axboe@kernel.dk>
commit e31f3698cd3499e676f6b0ea12e3528f569c4fa3 upstream.
Fix "system goes unresponsive under memory pressure and lots of
dirty/writeback pages" bug.
http://lkml.org/lkml/2010/4/4/86
In the above thread, Andreas Mohr described that
Invoking any command locked up for minutes (note that I'm
talking about attempted additional I/O to the _other_,
_unaffected_ main system HDD - such as loading some shell
binaries -, NOT the external SSD18M!!).
This happens when the two conditions are both meet:
- under memory pressure
- writing heavily to a slow device
OOM also happens in Andreas' system. The OOM trace shows that 3 processes
are stuck in wait_on_page_writeback() in the direct reclaim path. One in
do_fork() and the other two in unix_stream_sendmsg(). They are blocked on
this condition:
(sc->order && priority < DEF_PRIORITY - 2)
which was introduced in commit 78dc583d (vmscan: low order lumpy reclaim
also should use PAGEOUT_IO_SYNC) one year ago. That condition may be too
permissive. In Andreas' case, 512MB/1024 = 512KB. If the direct reclaim
for the order-1 fork() allocation runs into a range of 512KB
hard-to-reclaim LRU pages, it will be stalled.
It's a severe problem in three ways.
Firstly, it can easily happen in daily desktop usage. vmscan priority can
easily go below (DEF_PRIORITY - 2) on _local_ memory pressure. Even if
the system has 50% globally reclaimable pages, it still has good
opportunity to have 0.1% sized hard-to-reclaim ranges. For example, a
simple dd can easily create a big range (up to 20%) of dirty pages in the
LRU lists. And order-1 to order-3 allocations are more than common with
SLUB. Try "grep -v '1 :' /proc/slabinfo" to get the list of high order
slab caches. For example, the order-1 radix_tree_node slab cache may
stall applications at swap-in time; the order-3 inode cache on most
filesystems may stall applications when trying to read some file; the
order-2 proc_inode_cache may stall applications when trying to open a
/proc file.
Secondly, once triggered, it will stall unrelated processes (not doing IO
at all) in the system. This "one slow USB device stalls the whole system"
avalanching effect is very bad.
Thirdly, once stalled, the stall time could be intolerable long for the
users. When there are 20MB queued writeback pages and USB 1.1 is writing
them in 1MB/s, wait_on_page_writeback() will stuck for up to 20 seconds.
Not to mention it may be called multiple times.
So raise the bar to only enable PAGEOUT_IO_SYNC when priority goes below
DEF_PRIORITY/3, or 6.25% LRU size. As the default dirty throttle ratio is
20%, it will hardly be triggered by pure dirty pages. We'd better treat
PAGEOUT_IO_SYNC as some last resort workaround -- its stall time is so
uncomfortably long (easily goes beyond 1s).
The bar is only raised for (order < PAGE_ALLOC_COSTLY_ORDER) allocations,
which are easy to satisfy in 1TB memory boxes. So, although 6.25% of
memory could be an awful lot of pages to scan on a system with 1TB of
memory, it won't really have to busy scan that much.
Andreas tested an older version of this patch and reported that it mostly
fixed his problem. Mel Gorman helped improve it and KOSAKI Motohiro will
fix it further in the next patch.
Reported-by: Andreas Mohr <andi@lisas.de>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
commit 1ab335d8f85792e3b107ff8237d53cf64db714df upstream.
This patch fixes alignment of slab objects in case CONFIG_DEBUG_PAGEALLOC is
active.
Before this spot in kmem_cache_create, we have this situation:
- align contains the required alignment of the object
- cachep->obj_offset is 0 or equals align in case of CONFIG_DEBUG_SLAB
- size equals the size of the object, or object plus trailing redzone in case
This spot tries to fill one page per object if the object is in certain size
limits, however setting obj_offset to PAGE_SIZE - size does break the object
alignment since size may not be aligned with the required alignment.
This patch simply adds an ALIGN(size, align) to the equation and fixes the
object size detection accordingly.
This code in drivers/s390/cio/qdio_setup_init has lead to incorrectly aligned
slab objects (sizeof(struct qdio_q) equals 1792):
qdio_q_cache = kmem_cache_create("qdio_q", sizeof(struct qdio_q),
256, 0, NULL);
Acked-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
commit 0e8e50e20c837eeec8323bba7dcd25fe5479194c upstream.
Like the mlock() change previously, this makes the stack guard check
code use vma->vm_prev to see what the mapping below the current stack
is, rather than have to look it up with find_vma().
Also, accept an abutting stack segment, since that happens naturally if
you split the stack with mlock or mprotect.
Tested-by: Ian Campbell <ijc@hellion.org.uk>
commit 7798330ac8114c731cfab83e634c6ecedaa233d7 upstream.
If we've split the stack vma, only the lowest one has the guard page.
Now that we have a doubly linked list of vma's, checking this is trivial.
commit 297c5eee372478fc32fec5fe8eed711eedb13f3d upstream.
It's a really simple list, and several of the users want to go backwards
in it to find the previous vma. So rather than have to look up the
previous entry with 'find_vma_prev()' or something similar, just make it
doubly linked instead.
commit d7824370e26325c881b665350ce64fb0a4fde24a upstream.
This commit makes the stack guard page somewhat less visible to user
space. It does this by:
- not showing the guard page in /proc/<pid>/maps
It looks like lvm-tools will actually read /proc/self/maps to figure
out where all its mappings are, and effectively do a specialized
"mlockall()" in user space. By not showing the guard page as part of
the mapping (by just adding PAGE_SIZE to the start for grows-up
pages), lvm-tools ends up not being aware of it.
- by also teaching the _real_ mlock() functionality not to try to lock
the guard page.
That would just expand the mapping down to create a new guard page,
so there really is no point in trying to lock it in place.
It would perhaps be nice to show the guard page specially in
/proc/<pid>/maps (or at least mark grow-down segments some way), but
let's not open ourselves up to more breakage by user space from programs
that depends on the exact deails of the 'maps' file.
Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools
source code to see what was going on with the whole new warning.
Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be
Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
commit 11ac552477e32835cb6970bf0a70c210807f5673 upstream.
We do in fact need to unmap the page table _before_ doing the whole
stack guard page logic, because if it is needed (mainly 32-bit x86 with
PAE and CONFIG_HIGHPTE, but other architectures may use it too) then it
will do a kmap_atomic/kunmap_atomic.
And those kmaps will create an atomic region that we cannot do
allocations in. However, the whole stack expand code will need to do
anon_vma_prepare() and vma_lock_anon_vma() and they cannot do that in an
atomic region.
Now, a better model might actually be to do the anon_vma_prepare() when
_creating_ a VM_GROWSDOWN segment, and not have to worry about any of
this at page fault time. But in the meantime, this is the
straightforward fix for the issue.
See https://bugzilla.kernel.org/show_bug.cgi?id=16588 for details.
Reported-by: Wylda <wylda@volny.cz>
Reported-by: Sedat Dilek <sedat.dilek@gmail.com>
Reported-by: Mike Pagano <mpagano@gentoo.org>
Reported-by: François Valenduc <francois.valenduc@tvcablenet.be>
Tested-by: Ed Tomlinson <edt@aei.ca>
Cc: Pekka Enberg <penberg@kernel.org>
commit 5528f9132cf65d4d892bcbc5684c61e7822b21e9 upstream.
.. which didn't show up in my tests because it's a no-op on x86-64 and
most other architectures. But we enter the function with the last-level
page table mapped, and should unmap it at exit.
commit 320b2b8de12698082609ebbc1a17165727f4c893 upstream.
This is a rather minimally invasive patch to solve the problem of the
user stack growing into a memory mapped area below it. Whenever we fill
the first page of the stack segment, expand the segment down by one
page.
Now, admittedly some odd application might _want_ the stack to grow down
into the preceding memory mapping, and so we may at some point need to
make this a process tunable (some people might also want to have more
than a single page of guarding), but let's try the minimal approach
first.
Tested with trivial application that maps a single page just below the
stack, and then starts recursing. Without this, we will get a SIGSEGV
_after_ the stack has smashed the mapping. With this patch, we'll get a
nice SIGBUS just as the stack touches the page just above the mapping.
Requested-by: Keith Packard <keithp@keithp.com>
commit 966cca029f739716fbcc8068b8c6dfe381f86fc3 upstream.
Since 2.6.31, swap_map[]'s refcounting was changed to show that a used
swap entry is just for swap-cache, can be reused. Then, while scanning
free entry in swap_map[], a swap entry may be able to be reclaimed and
reused. It was caused by commit c9e444103b5e7a5 ("mm: reuse unused swap
entry if necessary").
But this caused deta corruption at resume. The scenario is
- Assume a clean-swap cache, but mapped.
- at hibernation_snapshot[], clean-swap-cache is saved as
clean-swap-cache and swap_map[] is marked as SWAP_HAS_CACHE.
- then, save_image() is called. And reuse SWAP_HAS_CACHE entry to save
image, and break the contents.
After resume:
- the memory reclaim runs and finds clean-not-referenced-swap-cache and
discards it because it's marked as clean. But here, the contents on
disk and swap-cache is inconsistent.
Hance memory is corrupted.
This patch avoids the bug by not reclaiming swap-entry during hibernation.
This is a quick fix for backporting.
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Reported-by: Ondreg Zary <linux@rainbow-software.org>
Tested-by: Ondreg Zary <linux@rainbow-software.org>
Tested-by: Andrea Gelmini <andrea.gelmini@gmail.com>
commit 1668bfd5be9d8a52536c4865000fbbe065a3613b upstream.
Don't try to isolate a still mapped page. Otherwise we will hit the
BUG_ON(page_mapped(page)) in __remove_from_page_cache().
Signed-off-by: Thomas Renninger <trenn@suse.de>
commit 9b9a29ecd75e310f75a9243e1c3538ad34598fcb upstream.
(PG_swapbacked && !PG_lru) pages should not happen.
Better to treat them as unknown pages.
commit de51257aa301652876ab6e8f13ea4eadbe4a3846 upstream.
Debian's ia64 autobuilders have been seeing kernel freeze or reboot
when running the gdb testsuite (Debian bug 588574): dannf bisected to
2.6.32 62eede62dafb4a6633eae7ffbeb34c60dba5e7b1 "mm: ZERO_PAGE without
PTE_SPECIAL"; and reproduced it with gdb's gcore on a simple target.
I'd missed updating the gate_vma handling in __get_user_pages(): that
happens to use vm_normal_page() (nowadays failing on the zero page),
yet reported success even when it failed to get a page - boom when
access_process_vm() tried to copy that to its intermediate buffer.
Fix this, resisting cleanups: in particular, leave it for now reporting
success when not asked to get any pages - very probably safe to change,
but let's not risk it without testing exposure.
Why did ia64 crash with 16kB pages, but succeed with 64kB pages?
Because setup_gate() pads each 64kB of its gate area with zero pages.
Reported-by: Andreas Barth <aba@not.so.argh.org>
Bisected-by: dann frazier <dannf@debian.org>
Tested-by: dann frazier <dannf@dannf.org>
commit 91803b499cca2fe558abad709ce83dc896b80950 upstream.
I/O errors can happen due to temporary failures, like multipath
errors or losing network contact with the iSCSI server. Because
of that, the VM will retry readpage on the page.
However, do_generic_file_read does not clear PG_error. This
causes the system to be unable to actually use the data in the
page cache page, even if the subsequent readpage completes
successfully!
The function filemap_fault has had a ClearPageError before
readpage forever. This patch simply adds the same to
do_generic_file_read.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Rik van Riel <riel@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
commit e9d6c157385e4efa61cb8293e425c9d8beba70d3 upstream.
Shaohua Li reported parallel file copy on tmpfs can lead to OOM killer.
This is regression of caused by commit 9ff473b9a7 ("vmscan: evict
streaming IO first"). Wow, It is 2 years old patch!
Currently, tmpfs file cache is inserted active list at first. This means
that the insertion doesn't only increase numbers of pages in anon LRU, but
it also reduces anon scanning ratio. Therefore, vmscan will get totally
confused. It scans almost only file LRU even though the system has plenty
unused tmpfs pages.
Historically, lru_cache_add_active_anon() was used for two reasons.
1) Intend to priotize shmem page rather than regular file cache.
2) Intend to avoid reclaim priority inversion of used once pages.
But we've lost both motivation because (1) Now we have separate anon and
file LRU list. then, to insert active list doesn't help such priotize.
(2) In past, one pte access bit will cause page activation. then to
insert inactive list with pte access bit mean higher priority than to
insert active list. Its priority inversion may lead to uninteded lru
chun. but it was already solved by commit 645747462 (vmscan: detect
mapped file pages used only once). (Thanks Hannes, you are great!)
Thus, now we can use lru_cache_add_anon() instead.
Reported-by: Shaohua Li <shaohua.li@intel.com>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
commit 74dbdd239bb1348ad86d28b18574d9c1f28b62ca upstream.
sz is in bytes, MAX_ORDER_NR_PAGES is in pages.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: David Gibson <dwg@au1.ibm.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
OOM-killer
commit 4a6018f7f4f1075c1a5403b5ec0ee7262187b86c upstream.
Ordinarily, application using hugetlbfs will create mappings with
reserves. For shared mappings, these pages are reserved before mmap()
returns success and for private mappings, the caller process is guaranteed
and a child process that cannot get the pages gets killed with sigbus.
An application that uses MAP_NORESERVE gets no reservations and mmap()
will always succeed at the risk the page will not be available at fault
time. This might be used for example on very large sparse mappings where
the developer is confident the necessary huge pages exist to satisfy all
faults even though the whole mapping cannot be backed by huge pages.
Unfortunately, if an allocation does fail, VM_FAULT_OOM is returned to the
fault handler which proceeds to trigger the OOM-killer. This is
unhelpful.
Even without hugetlbfs mounted, a user using mmap() can trivially trigger
the OOM-killer because VM_FAULT_OOM is returned (will provide example
program if desired - it's a whopping 24 lines long). It could be
considered a DOS available to an unprivileged user.
This patch alters hugetlbfs to kill a process that uses MAP_NORESERVE
where huge pages were not available with SIGBUS instead of triggering the
OOM killer.
This change affects hugetlb_cow() as well. I feel there is a failure case
in there, but I didn't create one. It would need a fairly specific target
in terms of the faulting application and the hugepage pool size. The
hugetlb_no_page() path is much easier to hit but both might as well be
closed.
commit 23be7468e8802a2ac1de6ee3eecb3ec7f14dc703 upstream.
If a futex key happens to be located within a huge page mapped
MAP_PRIVATE, get_futex_key() can go into an infinite loop waiting for a
page->mapping that will never exist.
See https://bugzilla.redhat.com/show_bug.cgi?id=552257 for more details
about the problem.
This patch makes page->mapping a poisoned value that includes
PAGE_MAPPING_ANON mapped MAP_PRIVATE. This is enough for futex to
continue but because of PAGE_MAPPING_ANON, the poisoned value is not
dereferenced or used by futex. No other part of the VM should be
dereferencing the page->mapping of a hugetlbfs page as its page cache is
not on the LRU.
This patch fixes the problem with the test case described in the bugzilla.
[akpm@linux-foundation.org: mel cant spel]
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Darren Hart <darren@dvhart.com>
commit 93d5c9be1ddd57d4063ce463c9ac2be1e5ee14f1 upstream.
If a signal is pending (task being killed by sigkill)
__mem_cgroup_try_charge will write NULL into &mem, and css_put will oops
on null pointer dereference.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: [<ffffffff810fc6cc>] mem_cgroup_prepare_migration+0x7c/0xc0
PGD a5d89067 PUD a5d8a067 PMD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/platform/microcode/firmware/microcode/loading
CPU 0
Modules linked in: nfs lockd nfs_acl auth_rpcgss sunrpc acpi_cpufreq pcspkr sg [last unloaded: microcode]
Pid: 5299, comm: largepages Tainted: G W 2.6.34-rc3 #3 Penryn1600SLI-110dB/To Be Filled By O.E.M.
RIP: 0010:[<ffffffff810fc6cc>] [<ffffffff810fc6cc>] mem_cgroup_prepare_migration+0x7c/0xc0
[nishimura@mxp.nes.nec.co.jp: fix merge issues]
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
commit 70655c06bd3f25111312d63985888112aed15ac5 upstream.
btrfs relocate_file_extent_cluster() calls us with NULL filp:
[ 4005.426805] BUG: unable to handle kernel NULL pointer dereference at 00000021
[ 4005.426818] IP: [<c109a130>] page_cache_sync_readahead+0x18/0x3e
Cc: Yan Zheng <yanzheng@21cn.com>
Reported-by: Kirill A. Shutemov <kirill@shutemov.name>
Tested-by: Kirill A. Shutemov <kirill@shutemov.name>
commit 926f2ae04f183098cf9a30521776fb2759c8afeb upstream.
mpol_parse_str() made lots 'err' variable related bug. Because it is ugly
and reviewing unfriendly.
This patch simplifies it.
Cc: Ravikiran Thirumalai <kiran@scalex86.org>
Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
commit 12821f5fb942e795f8009ece14bde868893bd811 upstream.
commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in
shmem_sb_info) added mpol=local mount option. but its feature is broken
since it was born. because such code always return 1 (i.e. mount
failure).
This patch fixes it.
commit d69b2e63e9172afb4d07c305601b79a55509ac4c upstream.
Currently, following mount operation cause mount error.
% mount -t tmpfs -ompol=bind:0 none /tmp
Because commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in
shmem_sb_info) corrupted MPOL_BIND parse code.
This patch restore the needed one.
commit 413b43deab8377819aba1dbad2abf0c15d59b491 upstream.
Fix an 'oops' when a tmpfs mount point is mounted with the mpol=default
mempolicy.
Upon remounting a tmpfs mount point with 'mpol=default' option, the mount
code crashed with a null pointer dereference. The initial problem report
was on 2.6.27, but the problem exists in mainline 2.6.34-rc as well. On
examining the code, we see that mpol_new returns NULL if default mempolicy
was requested. This 'NULL' mempolicy is accessed to store the node mask
resulting in oops.
The following patch fixes it.
Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org>
commit 65a80b4c61f5b5f6eb0f5669c8fb120893bfb388 upstream.
I added blk_run_backing_dev on page_cache_async_readahead so readahead I/O
is unpluged to improve throughput on especially RAID environment.
The normal case is, if page N become uptodate at time T(N), then T(N) <=
T(N+1) holds. With RAID (and NFS to some degree), there is no strict
ordering, the data arrival time depends on runtime status of individual
disks, which breaks that formula. So in do_generic_file_read(), just
after submitting the async readahead IO request, the current page may well
be uptodate, so the page won't be locked, and the block device won't be
implicitly unplugged:
if (PageReadahead(page))
page_cache_async_readahead()
if (!PageUptodate(page))
goto page_not_up_to_date;
page_not_up_to_date:
lock_page_killable(page);
Therefore explicit unplugging can help.
Following is the test result with dd.
#dd if=testdir/testfile of=/dev/null bs=16384
-2.6.30-rc6
1048576+0 records in
1048576+0 records out
17179869184 bytes (17 GB) copied, 224.182 seconds, 76.6 MB/s
-2.6.30-rc6-patched
17179869184 bytes (17 GB) copied, 206.465 seconds, 83.2 MB/s
(7Disks RAID-0 Array)
-2.6.30-rc6
1054976+0 records in
1054976+0 records out
17284726784 bytes (17 GB) copied, 212.233 seconds, 81.4 MB/s
-2.6.30-rc6-patched
17284726784 bytes (17 GB) copied, 198.878 seconds, 86.9 MB/s
(7Disks RAID-5 Array)
The patch was found to improve performance with the SCST scsi target
driver. See
http://sourceforge.net/mailarchive/forum.php?thread_name=a0272b440906030714g67eabc5k8f847fb1e538cc62%40mail.gmail.com&forum_name=scst-devel
[akpm@linux-foundation.org: unbust comment layout]
[akpm@linux-foundation.org: "fix" CONFIG_BLOCK=n]
Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Tested-by: Ronald <intercommit@gmail.com>
Cc: Bart Van Assche <bart.vanassche@gmail.com>
Cc: Vladislav Bolkhovitin <vst@vlnb.net>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
commit 0141450f66c3c12a3aaa869748caa64241885cdf upstream.
This fixes inefficient page-by-page reads on POSIX_FADV_RANDOM.
POSIX_FADV_RANDOM used to set ra_pages=0, which leads to poor performance:
a 16K read will be carried out in 4 _sync_ 1-page reads.
In other places, ra_pages==0 means
- it's ramfs/tmpfs/hugetlbfs/sysfs/configfs
- some IO error happened
where multi-page read IO won't help or should be avoided.
POSIX_FADV_RANDOM actually want a different semantics: to disable the
*heuristic* readahead algorithm, and to use a dumb one which faithfully
submit read IO for whatever application requests.
So introduce a flag FMODE_RANDOM for POSIX_FADV_RANDOM.
Note that the random hint is not likely to help random reads performance
noticeably. And it may be too permissive on huge request size (its IO
size is not limited by read_ahead_kb).
In Quentin's report (http://lkml.org/lkml/2009/12/24/145), the overall
(NFS read) performance of the application increased by 313%!
Tested-by: Quentin Barnes <qbarnes+nfs@yahoo-inc.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Chuck Lever <chuck.lever@oracle.com>
Cc: <qbarnes+nfs@yahoo-inc.com>
commit f3186a9c51eabe75b2780153ed7f07778d78b16e upstream.
Comparing with existing code, it's a simpler way to use kzalloc_node()
to ensure that each unused alien cache entry is NULL.
CC: Eric Dumazet <eric.dumazet@gmail.com>
Acked-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Matt Mackall <mpm@selenic.com>
Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
commit 5a2d41961dd6815b874b5c0afec0ac96cd90eea4 upstream.
Presently the oom-killer is memcg aware and it finds the worst process
from processes under memcg(s) in oom. Then, it kills victim's child
first.
It may kill a child in another cgroup and may not be any help for
recovery. And it will break the assumption users have.
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: David Rientjes <rientjes@google.com>
commit 6f5a55f1a6c5abee15a0e878e5c74d9f1569b8b0 upstream.
We incorrectly depended on the 'node_state/node_isset()' functions
testing the node range, rather than checking it explicitly. That's not
reliable, even if it might often happen to work. So do the proper
explicit test.
Reported-by: Marcus Meissner <meissner@suse.de>
Acked-and-tested-by: Brice Goglin <Brice.Goglin@inria.fr>
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
commit 931e80e4b3263db75c8e34f078d22f11bbabd3a3 upstream.
The cache alias problem will happen if the changes of user shared mapping
is not flushed before copying, then user and kernel mapping may be mapped
into two different cache line, it is impossible to guarantee the coherence
after iov_iter_copy_from_user_atomic. So the right steps should be:
flush_dcache_page(page);
kmap_atomic(page);
write to page;
kunmap_atomic(page);
More precisely, we might create two new APIs flush_dcache_user_page and
flush_dcache_kern_page to replace the two flush_dcache_page accordingly.
Here is a snippet tested on omap2430 with VIPT cache, and I think it is
not ARM-specific:
int val = 0x11111111;
fd = open("abc", O_RDWR);
addr = mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
*(addr+0) = 0x44444444;
tmp = *(addr+0);
*(addr+1) = 0x77777777;
write(fd, &val, sizeof(int));
close(fd);
The results are not always 0x11111111 0x77777777 at the beginning as expected. Sometimes we see 0x44444444 0x77777777.
Signed-off-by: Anfei <anfei.zhou@gmail.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: <linux-arch@vger.kernel.org>
commit 02b709df817c0db174f249cc59e5f7fd01b64d92 upstream.
Improve handling of fragmented per-CPU vmaps. We previously don't free
up per-CPU maps until all its addresses have been used and freed. So
fragmented blocks could fill up vmalloc space even if they actually had
no active vmap regions within them.
Add some logic to allow all CPUs to have these blocks purged in the case
of failure to allocate a new vm area, and also put some logic to trim
such blocks of a current CPU if we hit them in the allocation path (so
as to avoid a large build up of them).
Christoph reported some vmap allocation failures when using the per CPU
vmap APIs in XFS, which cannot be reproduced after this patch and the
previous bug fix.
Cc: linux-mm@kvack.org
Tested-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Nick Piggin <npiggin@suse.de>
commit de5604231ce4bc8db1bc1dcd27d8540cbedf1518 upstream.
RCU list walking of the per-cpu vmap cache was broken. It did not use
RCU primitives, and also the union of free_list and rcu_head is
obviously wrong (because free_list is indeed the list we are RCU
walking).
While we are there, remove a couple of unused fields from an earlier
iteration.
These APIs aren't actually used anywhere, because of problems with the
XFS conversion. Christoph has now verified that the problems are solved
with these patches. Also it is an exported interface, so I think it
will be good to be merged now (and Christoph wants to get the XFS
changes into their local tree).
commit a7016235a61d520e6806f38129001d935c4b6661 upstream.
After memory pressure has forced it to dip into the reserves, 2.6.32's
5f8dcc21211a3d4e3a7a5ca366b469fb88117f61 "page-allocator: split per-cpu
list into one-list-per-migrate-type" has been returning MIGRATE_RESERVE
pages to the MIGRATE_MOVABLE free_list: in some sense depleting reserves.
Fix that in the most straightforward way (which, considering the overheads
of alternative approaches, is Mel's preference): the right migratetype is
already in page_private(page), but free_pcppages_bulk() wasn't using it.
How did this bug show up? As a 20% slowdown in my tmpfs loop kbuild
swapping tests, on PowerMac G5 with SLUB allocator. Bisecting to that
commit was easy, but explaining the magnitude of the slowdown not easy.
The same effect appears, but much less markedly, with SLAB, and even
less markedly on other machines (the PowerMac divides into fewer zones
than x86, I think that may be a factor). We guess that lumpy reclaim
of short-lived high-order pages is implicated in some way, and probably
this bug has been tickling a poor decision somewhere in page reclaim.
But instrumentation hasn't told me much, I've run out of time and
imagination to determine exactly what's going on, and shouldn't hold up
the fix any longer: it's valid, and might even fix other misbehaviours.
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Acked-by: Mel Gorman <mel@csn.ul.ie>
commit 0531b2aac59c2296570ac52bfc032ef2ace7d5e1 upstream.
It's a simplified 'read_cache_page()' which takes a page allocation
flag, so that different paths can control how aggressive the memory
allocations are that populate a address space.
In particular, the intel GPU object mapping code wants to be able to do
a certain amount of own internal memory management by automatically
shrinking the address space when memory starts getting tight. This
allows it to dynamically use different memory allocation policies on a
per-allocation basis, rather than depend on the (static) address space
gfp policy.
The actual new function is a one-liner, but re-organizing the helper
functions to the point where you can do this with a single line of code
is what most of the patch is all about.
Tested-by: Chris Wilson <chris@chris-wilson.co.uk>
commit 88f5004430babb836cfce886d5d54c82166f8ba4 upstream.
In free_unmap_area_noflush(), va->flags is marked as VM_LAZY_FREE first, and
then vmap_lazy_nr is increased atomically.
But, in __purge_vmap_area_lazy(), while traversing of vmap_are_list, nr
is counted by checking VM_LAZY_FREE is set to va->flags. After counting
the variable nr, kernel reads vmap_lazy_nr atomically and checks a
BUG_ON condition whether nr is greater than vmap_lazy_nr to prevent
vmap_lazy_nr from being negative.
The problem is that, if interrupted right after marking VM_LAZY_FREE,
increment of vmap_lazy_nr can be delayed. Consequently, BUG_ON
condition can be met because nr is counted more than vmap_lazy_nr.
It is highly probable when vmalloc/vfree are called frequently. This
scenario have been verified by adding delay between marking VM_LAZY_FREE
and increasing vmap_lazy_nr in free_unmap_area_noflush().
Even the vmap_lazy_nr is for checking high watermark, it never be the
strict watermark. Although the BUG_ON condition is to prevent
vmap_lazy_nr from being negative, vmap_lazy_nr is signed variable. So,
it could go down to negative value temporarily.
Consequently, removing the BUG_ON condition is proper.
A possible BUG_ON message is like the below.
kernel BUG at mm/vmalloc.c:517!
invalid opcode: 0000 [#1] SMP
EIP: 0060:[<c04824a4>] EFLAGS: 00010297 CPU: 3
EIP is at __purge_vmap_area_lazy+0x144/0x150
EAX: ee8a8818 EBX: c08e77d4 ECX: e7c7ae40 EDX: c08e77ec
ESI: 000081fe EDI: e7c7ae60 EBP: e7c7ae64 ESP: e7c7ae3c
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
Call Trace:
[<c0482ad9>] free_unmap_vmap_area_noflush+0x69/0x70
[<c0482b02>] remove_vm_area+0x22/0x70
[<c0482c15>] __vunmap+0x45/0xe0
[<c04831ec>] vmalloc+0x2c/0x30
Code: 8d 59 e0 eb 04 66 90 89 cb 89 d0 e8 87 fe ff ff 8b 43 20 89 da 8d 48 e0 8d 43 20 3b 04 24 75 e7 fe 05 a8 a5 a3 c0 e9 78 ff ff ff <0f> 0b eb fe 90 8d b4 26 00 00 00 00 56 89 c6 b8 ac a5 a3 c0 31
EIP: [<c04824a4>] __purge_vmap_area_lazy+0x144/0x150 SS:ESP 0068:e7c7ae3c
[ See also http://marc.info/?l=linux-kernel&m=126335856228090&w=2 ]
Signed-off-by: Yongseok Koh <yongseok.koh@samsung.com>
commit cedabed49b39b4319bccc059a63344b6232b619c upstream.
If __block_prepare_write() was failed in block_write_begin(), the
allocated blocks can be outside of ->i_size.
But new truncate_pagecache() in vmtuncate() does nothing if new < old.
It means the above usage is not working anymore.
So, this patch fixes it by removing "new < old" check. It would need
more cleanup/change. But, now -rc and truncate working is in progress,
so, this tried to fix it minimum change.
Acked-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
commit 6ccf80eb15ccaca4d3f1ab5162b9ded5eecd9971 upstream.
commit f2260e6b (page allocator: update NR_FREE_PAGES only as necessary)
made one minor regression. if __rmqueue() was failed, NR_FREE_PAGES stat
go wrong. this patch fixes it.
Reported-by: Huang Shijie <shijie8@gmail.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
commit fce66477578d081f19aef5ea218664ff7758c33a upstream.
Current mem_cgroup_force_empty() only ensures mem->res.usage == 0 on
success. But this doesn't guarantee memcg's LRU is really empty, because
there are some cases in which !PageCgrupUsed pages exist on memcg's LRU.
For example:
- Pages can be uncharged by its owner process while they are on LRU.
- race between mem_cgroup_add_lru_list() and __mem_cgroup_uncharge_common().
So there can be a case in which the usage is zero but some of the LRUs are not empty.
OTOH, mem_cgroup_del_lru_list(), which can be called asynchronously with
rmdir, accesses the mem_cgroup, so this access can cause a problem if it
races with rmdir because the mem_cgroup might have been freed by rmdir.
Actually, I saw a bug which seems to be caused by this race.
[1530745.949906] BUG: unable to handle kernel NULL pointer dereference at 0000000000000230
[1530745.950651] IP: [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80
[1530745.950651] PGD 3863de067 PUD 3862c7067 PMD 0
[1530745.950651] Oops: 0002 [#1] SMP
[1530745.950651] last sysfs file: /sys/devices/system/cpu/cpu7/cache/index1/shared_cpu_map
[1530745.950651] CPU 3
[1530745.950651] Modules linked in: configs ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp nfsd nfs_acl auth_rpcgss exportfs autofs4 hidp rfcomm l2cap crc16 bluetooth lockd sunrpc ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp bnx2i cnic uio ipv6 cxgb3i cxgb3 mdio libiscsi_tcp libiscsi scsi_transport_iscsi dm_mirror dm_multipath scsi_dh video output sbs sbshc battery ac lp kvm_intel kvm sg ide_cd_mod cdrom serio_raw tpm_tis tpm tpm_bios acpi_memhotplug button parport_pc parport rtc_cmos rtc_core rtc_lib e1000 i2c_i801 i2c_core pcspkr dm_region_hash dm_log dm_mod ata_piix libata shpchp megaraid_mbox sd_mod scsi_mod megaraid_mm ext3 jbd uhci_hcd ohci_hcd ehci_hcd [last unloaded: freq_table]
[1530745.950651] Pid: 19653, comm: shmem_test_02 Tainted: G M 2.6.32-mm1-00701-g2b04386 #3 Express5800/140Rd-4 [N8100-1065]
[1530745.950651] RIP: 0010:[<ffffffff810fbc11>] [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80
[1530745.950651] RSP: 0018:ffff8803863ddcb8 EFLAGS: 00010002
[1530745.950651] RAX: 00000000000001e0 RBX: ffff8803abc02238 RCX: 00000000000001e0
[1530745.950651] RDX: 0000000000000000 RSI: ffff88038611a000 RDI: ffff8803abc02238
[1530745.950651] RBP: ffff8803863ddcc8 R08: 0000000000000002 R09: ffff8803a04c8643
[1530745.950651] R10: 0000000000000000 R11: ffffffff810c7333 R12: 0000000000000000
[1530745.950651] R13: ffff880000017f00 R14: 0000000000000092 R15: ffff8800179d0310
[1530745.950651] FS: 0000000000000000(0000) GS:ffff880017800000(0000) knlGS:0000000000000000
[1530745.950651] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[1530745.950651] CR2: 0000000000000230 CR3: 0000000379d87000 CR4: 00000000000006e0
[1530745.950651] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[1530745.950651] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[1530745.950651] Process shmem_test_02 (pid: 19653, threadinfo ffff8803863dc000, task ffff88038612a8a0)
[1530745.950651] Stack:
[1530745.950651] ffffea00040c2fe8 0000000000000000 ffff8803863ddd98 ffffffff810c739a
[1530745.950651] <0> 00000000863ddd18 000000000000000c 0000000000000000 0000000000000000
[1530745.950651] <0> 0000000000000002 0000000000000000 ffff8803863ddd68 0000000000000046
[1530745.950651] Call Trace:
[1530745.950651] [<ffffffff810c739a>] release_pages+0x142/0x1e7
[1530745.950651] [<ffffffff810c778f>] ? pagevec_move_tail+0x6e/0x112
[1530745.950651] [<ffffffff810c781e>] pagevec_move_tail+0xfd/0x112
[1530745.950651] [<ffffffff810c78a9>] lru_add_drain+0x76/0x94
[1530745.950651] [<ffffffff810dba0c>] exit_mmap+0x6e/0x145
[1530745.950651] [<ffffffff8103f52d>] mmput+0x5e/0xcf
[1530745.950651] [<ffffffff81043ea8>] exit_mm+0x11c/0x129
[1530745.950651] [<ffffffff8108fb29>] ? audit_free+0x196/0x1c9
[1530745.950651] [<ffffffff81045353>] do_exit+0x1f5/0x6b7
[1530745.950651] [<ffffffff8106133f>] ? up_read+0x2b/0x2f
[1530745.950651] [<ffffffff8137d187>] ? lockdep_sys_exit_thunk+0x35/0x67
[1530745.950651] [<ffffffff81045898>] do_group_exit+0x83/0xb0
[1530745.950651] [<ffffffff810458dc>] sys_exit_group+0x17/0x1b
[1530745.950651] [<ffffffff81002c1b>] system_call_fastpath+0x16/0x1b
[1530745.950651] Code: 54 53 0f 1f 44 00 00 83 3d cc 29 7c 00 00 41 89 f4 75 63 eb 4e 48 83 7b 08 00 75 04 0f 0b eb fe 48 89 df e8 18 f3 ff ff 44 89 e2 <48> ff 4c d0 50 48 8b 05 2b 2d 7c 00 48 39 43 08 74 39 48 8b 4b
[1530745.950651] RIP [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80
[1530745.950651] RSP <ffff8803863ddcb8>
[1530745.950651] ---[ end trace c3419c1bb8acc34f ]---
[1530745.950651] Fixing recursive fault but reboot is needed!
The problem here is pages on LRU may contain pointer to stale memcg. To
make res->usage to be 0, all pages on memcg must be uncharged or moved to
another(parent) memcg. Moved page_cgroup have already removed from
original LRU, but uncharged page_cgroup contains pointer to memcg withou
PCG_USED bit. (This asynchronous LRU work is for improving performance.)
If PCG_USED bit is not set, page_cgroup will never be added to memcg's
LRU. So, about pages not on LRU, they never access stale pointer. Then,
what we have to take care of is page_cgroup _on_ LRU list. This patch
fixes this problem by making mem_cgroup_force_empty() visit all LRUs
before exiting its loop and guarantee there are no pages on its LRU.
This backports the following upstream commits all as one patch:
54f5de709984bae0d31d823ff03de755f9dcac54
ecc1a8993751de4e82eb18640d631dae1f626bd6
1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f
f106af4e90eadd76cfc0b5325f659619e08fb762
097eed103862f9c6a97f2e415e21d1134017b135
935874141df839c706cd6cdc438e85eb69d1525e
0ec62d290912bb4b989be7563851bc364ec73b56
c4caa778157dbbf04116f0ac2111e389b5cd7a29
2ea1d13f64efdf49319e86c87d9ba38c30902782
570dcf2c15463842e384eb597a87c1e39bead99b
564b3bffc619dcbdd160de597b0547a7017ea010
0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301
f8b7256096a20436f6d0926747e3ac3d64c81d24
8c7b49b3ecd48923eb64ff57e07a1cdb74782970
9206de95b1ea68357996ec02be5db0638a0de2c1
2c6a10161d0b5fc047b5bd81b03693b9af99fab5
05d72faa6d13c9d857478a5d35c85db9adada685
bb52d6694002b9d632bb355f64daa045c6293a4e
e77414e0aad6a1b063ba5e5750c582c75327ea6a
aa65607373a4daf2010e8c3867b6317619f3c1a3
Backport done by Greg Kroah-Hartman. Only minor tweaks were needed.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
2.6.33-rc1 commit 73848b4684e84a84cfd1555af78d41158f31e16b, adjusted
to include 31e855ea7173bdb0520f9684580423a9560f66e0's movement of
the unlock_page(oldpage), but omit other intervening cleanups.
When KSM merges an mlocked page, it has been forgetting to munlock it:
that's been left to free_page_mlock(), which reports it in /proc/vmstat
as unevictable_pgs_mlockfreed instead of unevictable_pgs_munlocked,
which indicates that such pages _might_ be left unevictable for long
after they should be evictable. Call munlock_vma_page() to fix that.
commit b39415b2731d7dec5e612d2d12595da82399eedf upstream.
In AIM7 runs, recent kernels start swapping out anonymous pages well
before they should. This is due to shrink_list falling through to
shrink_inactive_list if !inactive_anon_is_low(zone, sc), when all we
really wanted to do is pre-age some anonymous pages to give them extra
time to be referenced while on the inactive list.
The obvious fix is to make sure that shrink_list does not fall through to
scanning/reclaiming inactive pages when we called it to scan one of the
active lists.
This change should be safe because the loop in shrink_zone ensures that we
will still shrink the anon and file inactive lists whenever we should.
[kosaki.motohiro@jp.fujitsu.com: inactive_file_is_low() should be inactive_anon_is_low()]
Reported-by: Larry Woodman <lwoodman@redhat.com>
Cc: Tomasz Chmielewski <mangoo@wpkg.org>
Cc: Rik Theys <rik.theys@gmail.com>
commit d31f56dbf8bafaacb0c617f9a6f137498d5c7aed upstream.
task_in_mem_cgroup(), which is called by select_bad_process() to check
whether a task can be a candidate for being oom-killed from memcg's limit,
checks "curr->use_hierarchy"("curr" is the mem_cgroup the task belongs
to).
But this check return true(it's false positive) when:
<some path>/aa use_hierarchy == 0 <- hitting limit
<some path>/aa/00 use_hierarchy == 1 <- the task belongs to
This leads to killing an innocent task in aa/00. This patch is a fix for
this bug. And this patch also fixes the arg for
mem_cgroup_print_oom_info(). We should print information of mem_cgroup
which the task being killed, not current, belongs to.
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
commit 6e1415467614e854fee660ff6648bd10fa976e95 upstream.
In NOMMU mode clamp dac_mmap_min_addr to zero to cause the tests on it to be
skipped by the compiler. We do this as the minimum mmap address doesn't make
any sense in NOMMU mode.
mmap_min_addr and round_hint_to_min() can be discarded entirely in NOMMU mode.
Acked-by: Eric Paris <eparis@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
