path: root/mm
2012-07-31mm/hotplug: free zone->pageset when a zone becomes emptyJiang Liu
When a zone becomes empty after memory offlining, free zone->pageset. Otherwise it will cause memory leak when adding memory to the empty zone again because build_all_zonelists() will allocate zone->pageset for an empty zone. Signed-off-by: Jiang Liu <liuj97@gmail.com> Signed-off-by: Wei Wang <Bessel.Wang@huawei.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Keping Chen <chenkeping@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/hotplug: correctly add new zone to all other nodes' zone listsJiang Liu
When online_pages() is called to add new memory to an empty zone, it rebuilds all zone lists by calling build_all_zonelists(). But there's a bug which prevents the new zone to be added to other nodes' zone lists. online_pages() { build_all_zonelists() ..... node_set_state(zone_to_nid(zone), N_HIGH_MEMORY) } Here the node of the zone is put into N_HIGH_MEMORY state after calling build_all_zonelists(), but build_all_zonelists() only adds zones from nodes in N_HIGH_MEMORY state to the fallback zone lists. build_all_zonelists() ->__build_all_zonelists() ->build_zonelists() ->find_next_best_node() ->for_each_node_state(n, N_HIGH_MEMORY) So memory in the new zone will never be used by other nodes, and it may cause strange behavor when system is under memory pressure. So put node into N_HIGH_MEMORY state before calling build_all_zonelists(). Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <liuj97@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Keping Chen <chenkeping@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/hotplug: correctly setup fallback zonelists when creating new pgdatJiang Liu
When hotadd_new_pgdat() is called to create new pgdat for a new node, a fallback zonelist should be created for the new node. There's code to try to achieve that in hotadd_new_pgdat() as below: /* * The node we allocated has no zone fallback lists. For avoiding * to access not-initialized zonelist, build here. */ mutex_lock(&zonelists_mutex); build_all_zonelists(pgdat, NULL); mutex_unlock(&zonelists_mutex); But it doesn't work as expected. When hotadd_new_pgdat() is called, the new node is still in offline state because node_set_online(nid) hasn't been called yet. And build_all_zonelists() only builds zonelists for online nodes as: for_each_online_node(nid) { pg_data_t *pgdat = NODE_DATA(nid); build_zonelists(pgdat); build_zonelist_cache(pgdat); } Though we hope to create zonelist for the new pgdat, but it doesn't. So add a new parameter "pgdat" the build_all_zonelists() to build pgdat for the new pgdat too. Signed-off-by: Jiang Liu <liuj97@gmail.com> Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Keping Chen <chenkeping@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/memcg: replace inexistence move_lock_page_cgroup() by ↵Wanpeng Li
move_lock_mem_cgroup() in comment Signed-off-by: Wanpeng Li <liwp.linux@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/memcg: mem_cgroup_relize_xxx_limit can guarantee memcg->res.limit <= ↵Wanpeng Li
memcg->memsw.limit Signed-off-by: Wanpeng Li <liwp.linux@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: setup pageblock_order before it's used by sparsememXishi Qiu
On architectures with CONFIG_HUGETLB_PAGE_SIZE_VARIABLE set, such as Itanium, pageblock_order is a variable with default value of 0. It's set to the right value by set_pageblock_order() in function free_area_init_core(). But pageblock_order may be used by sparse_init() before free_area_init_core() is called along path: sparse_init() ->sparse_early_usemaps_alloc_node() ->usemap_size() ->SECTION_BLOCKFLAGS_BITS ->((1UL << (PFN_SECTION_SHIFT - pageblock_order)) * NR_PAGEBLOCK_BITS) The uninitialized pageblock_size will cause memory wasting because usemap_size() returns a much bigger value then it's really needed. For example, on an Itanium platform, sparse_init() pageblock_order=0 usemap_size=24576 free_area_init_core() before pageblock_order=0, usemap_size=24576 free_area_init_core() after pageblock_order=12, usemap_size=8 That means 24K memory has been wasted for each section, so fix it by calling set_pageblock_order() from sparse_init(). Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Jiang Liu <liuj97@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Keping Chen <chenkeping@huawei.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/memory.c:print_vma_addr(): call up_read(&mm->mmap_sem) directlyJeff Liu
Call up_read(&mm->mmap_sem) directly since we have already got mm via current->mm at the beginning of print_vma_addr(). Signed-off-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: have order > 0 compaction start off where it leftRik van Riel
Order > 0 compaction stops when enough free pages of the correct page order have been coalesced. When doing subsequent higher order allocations, it is possible for compaction to be invoked many times. However, the compaction code always starts out looking for things to compact at the start of the zone, and for free pages to compact things to at the end of the zone. This can cause quadratic behaviour, with isolate_freepages starting at the end of the zone each time, even though previous invocations of the compaction code already filled up all free memory on that end of the zone. This can cause isolate_freepages to take enormous amounts of CPU with certain workloads on larger memory systems. The obvious solution is to have isolate_freepages remember where it left off last time, and continue at that point the next time it gets invoked for an order > 0 compaction. This could cause compaction to fail if cc->free_pfn and cc->migrate_pfn are close together initially, in that case we restart from the end of the zone and try once more. Forced full (order == -1) compactions are left alone. [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: s/laste/last/, use 80 cols] Signed-off-by: Rik van Riel <riel@redhat.com> Reported-by: Jim Schutt <jaschut@sandia.gov> Tested-by: Jim Schutt <jaschut@sandia.gov> Cc: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: rename mem_control_xxx to memcg_xxxWanpeng Li
Replace memory_cgroup_xxx() with memcg_xxx() Signed-off-by: Wanpeng Li <liwp.linux@gmail.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: fix bad behavior in use_hierarchy fileGlauber Costa
I have an application that does the following: * copy the state of all controllers attached to a hierarchy * replicate it as a child of the current level. I would expect writes to the files to mostly succeed, since they are inheriting sane values from parents. But that is not the case for use_hierarchy. If it is set to 0, we succeed ok. If we're set to 1, the value of the file is automatically set to 1 in the children, but if userspace tries to write the very same 1, it will fail. That same situation happens if we set use_hierarchy, create a child, and then try to write 1 again. Now, there is no reason whatsoever for failing to write a value that is already there. It doesn't even match the comments, that states: /* If parent's use_hierarchy is set, we can't make any modifications * in the child subtrees... since we are not changing anything. So test the new value against the one we're storing, and automatically return 0 if we're not proposing a change. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Dhaval Giani <dhaval.giani@gmail.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: rename config variablesAndrew Morton
Sanity: CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM [mhocko@suse.cz: fix missed bits] Cc: Glauber Costa <glommer@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: clean up __count_immobile_pages()Minchan Kim
The __count_immobile_pages() naming is rather awkward. Choose a more clear name and add a comment. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: do not use page_count() without a page pinMinchan Kim
d179e84ba ("mm: vmscan: do not use page_count without a page pin") fixed this problem in vmscan.c but same problem is in __count_immobile_pages(). I copy and paste d179e84ba's contents for description. "It is unsafe to run page_count during the physical pfn scan because compound_head could trip on a dangling pointer when reading page->first_page if the compound page is being freed by another CPU." Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wanpeng Li <liwp.linux@gmail.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, oom: replace some information in tasklist dumpDavid Rientjes
The number of ptes and swap entries are used in the oom killer's badness heuristic, so they should be shown in the tasklist dump. This patch adds those fields and replaces cpu and oom_adj values that are currently emitted. Cpu isn't interesting and oom_adj is deprecated and will be removed later this year, the same information is already displayed as oom_score_adj which is used internally. At the same time, make the documentation a little more clear to state this information is helpful to determine why the oom killer chose the task it did to kill. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, oom: fix potential killing of thread that is disabled from oom killingDavid Rientjes
/proc/sys/vm/oom_kill_allocating_task will immediately kill current when the oom killer is called to avoid a potentially expensive tasklist scan for large systems. Currently, however, it is not checking current's oom_score_adj value which may be OOM_SCORE_ADJ_MIN, meaning that it has been disabled from oom killing. This patch avoids killing current in such a condition and simply falls back to the tasklist scan since memory still needs to be freed. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: clear pages_scanned only if draining a pcp adds pages to the buddy ↵KOSAKI Motohiro
allocator again commit 2ff754fa8f ("mm: clear pages_scanned only if draining a pcp adds pages to the buddy allocator again") fixed one free_pcppages_bulk() misuse. But two another miuse still exist. This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, fadvise: don't return -EINVAL when filesystem cannot implement fadvise()KOSAKI Motohiro
Eric Wong reported his test suite failex when /tmp is tmpfs. https://lkml.org/lkml/2012/2/24/479 Currentlt the input check of POSIX_FADV_WILLNEED has two problems. - requires a_ops->readpage. But in fact, force_page_cache_readahead() requires that the target filesystem has either ->readpage or ->readpages. - returns -EINVAL when the filesystem doesn't have ->readpage. But posix says that fadvise is merely a hint. Thus fadvise() should return 0 if filesystem has no means of implementing fadvise(). The userland application should not know nor care whcih type of filesystem backs the TMPDIR directory, as Eric pointed out. There is nothing which userspace can do to solve this error. So change the return value to 0 when filesytem doesn't support readahead. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Eric Wong <normalperson@yhbt.net> Tested-by: Eric Wong <normalperson@yhbt.net> Reviewed-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: make mem_cgroup_force_empty_list() return boolKAMEZAWA Hiroyuki
mem_cgroup_force_empty_list() just returns 0 or -EBUSY and -EBUSY indicates 'you need to retry'. Make mem_cgroup_force_empty_list() return a bool to simplify the logic. [akpm@linux-foundation.org: rework mem_cgroup_force_empty_list()'s comment] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: mem_cgroup_move_parent() doesn't need gfp_maskKAMEZAWA Hiroyuki
2012-07-31memcg: clean up force_empty_list() return value checkKamezawa Hiroyuki
After bf544fdc241da8 "memcg: move charges to root cgroup if use_hierarchy=0 in mem_cgroup_move_hugetlb_parent()" mem_cgroup_move_parent() returns only -EBUSY or -EINVAL. So we can remove the -ENOMEM and -EINTR checks. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: remove check for signal_pending() during rmdir()Kamezawa Hiroyuki
After bf544fdc241da8 "memcg: move charges to root cgroup if use_hierarchy=0 in mem_cgroup_move_hugetlb_parent()", no memory reclaim will occur when removing a memory cgroup. If -EINTR is returned here, cgroup will show a warning. We don't need to handle any user interruption signal. Remove this. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/memblock.c:memblock_double_array(): cosmetic cleanupsAndrew Morton
This function is an 80-column eyesore, quite unnecessarily. Clean that up, and use standard comment layout style. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Greg Pearson <greg.pearson@hp.com> Cc: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, oom: do not schedule if current has been killedDavid Rientjes
The oom killer currently schedules away from current in an uninterruptible sleep if it does not have access to memory reserves. It's possible that current was killed because it shares memory with the oom killed thread or because it was killed by the user in the interim, however. This patch only schedules away from current if it does not have a pending kill, i.e. if it does not share memory with the oom killed thread. It's possible that it will immediately retry its memory allocation and fail, but it will immediately be given access to memory reserves if it calls the oom killer again. This prevents the delay of memory freeing when threads that share memory with the oom killed thread get unnecessarily scheduled. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: remove exclude and wakeup rmdir calls from migrateAneesh Kumar K.V
We already hold the hugetlb_lock. That should prevent a parallel cgroup rmdir from touching page's hugetlb cgroup. So remove the exclude and wakeup calls. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: assign the page hugetlb cgroup when we move the page to ↵Aneesh Kumar K.V
active list. A page's hugetlb cgroup assignment and movement to the active list should occur with hugetlb_lock held. Otherwise when we remove the hugetlb cgroup we will iterate the active list and find pages with NULL hugetlb cgroup values. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb: move all the in use pages to active listAneesh Kumar K.V
When we fail to allocate pages from the reserve pool, hugetlb tries to allocate huge pages using alloc_buddy_huge_page. Add these to the active list. We also need to add the huge page we allocate when we soft offline the oldpage to active list. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: migrate hugetlb cgroup info from oldpage to new page during ↵Aneesh Kumar K.V
migration With HugeTLB pages, hugetlb cgroup is uncharged in compound page destructor. Since we are holding a hugepage reference, we can be sure that old page won't get uncharged till the last put_page(). Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: add hugetlb cgroup control filesAneesh Kumar K.V
Add the control files for hugetlb controller [akpm@linux-foundation.org: s/CONFIG_CGROUP_HUGETLB_RES_CTLR/CONFIG_MEMCG_HUGETLB/g] [akpm@linux-foundation.org: s/CONFIG_MEMCG_HUGETLB/CONFIG_CGROUP_HUGETLB/] Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: add support for cgroup removalAneesh Kumar K.V
Add support for cgroup removal. If we don't have parent cgroup, the charges are moved to root cgroup. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: add charge/uncharge routines for hugetlb cgroupAneesh Kumar K.V
Add the charge and uncharge routines for hugetlb cgroup. We do cgroup charging in page alloc and uncharge in compound page destructor. Assigning page's hugetlb cgroup is protected by hugetlb_lock. [liwp@linux.vnet.ibm.com: add huge_page_order check to avoid incorrect uncharge] Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Wanpeng Li <liwp.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: add the cgroup pointer to page lruAneesh Kumar K.V
Add the hugetlb cgroup pointer to 3rd page lru.next. This limit the usage to hugetlb cgroup to only hugepages with 3 or more normal pages. I guess that is an acceptable limitation. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/hugetlb: add new HugeTLB cgroupAneesh Kumar K.V
Implement a new controller that allows us to control HugeTLB allocations. The extension allows to limit the HugeTLB usage per control group and enforces the controller limit during page fault. Since HugeTLB doesn't support page reclaim, enforcing the limit at page fault time implies that, the application will get SIGBUS signal if it tries to access HugeTLB pages beyond its limit. This requires the application to know beforehand how much HugeTLB pages it would require for its use. The charge/uncharge calls will be added to HugeTLB code in later patch. Support for cgroup removal will be added in later patches. [akpm@linux-foundation.org: s/CONFIG_CGROUP_HUGETLB_RES_CTLR/CONFIG_MEMCG_HUGETLB/g] [akpm@linux-foundation.org: s/CONFIG_MEMCG_HUGETLB/CONFIG_CGROUP_HUGETLB/g] Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb: make some static variables globalAneesh Kumar K.V
We will use them later in hugetlb_cgroup.c Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb: add a list for tracking in-use HugeTLB pagesAneesh Kumar K.V
hugepage_activelist will be used to track currently used HugeTLB pages. We need to find the in-use HugeTLB pages to support HugeTLB cgroup removal. On cgroup removal we update the page's HugeTLB cgroup to point to parent cgroup. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb: simplify migrate_huge_page()Aneesh Kumar K.V
Since we migrate only one hugepage, don't use linked list for passing the page around. Directly pass the page that need to be migrated as argument. This also removes the usage of page->lru in the migrate path. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb: use mmu_gather instead of a temporary linked list for accumulating ↵Aneesh Kumar K.V
pages Use a mmu_gather instead of a temporary linked list for accumulating pages when we unmap a hugepage range Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb: add an inline helper for finding hstate indexAneesh Kumar K.V
Add an inline helper and use it in the code. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb: don't use ERR_PTR with VM_FAULT* valuesAneesh Kumar K.V
The current use of VM_FAULT_* codes with ERR_PTR requires us to ensure VM_FAULT_* values will not exceed MAX_ERRNO value. Decouple the VM_FAULT_* values from MAX_ERRNO. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Hillf Danton <dhillf@gmail.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb: rename max_hstate to hugetlb_max_hstateAneesh Kumar K.V
This patchset implements a cgroup resource controller for HugeTLB pages. The controller allows to limit the HugeTLB usage per control group and enforces the controller limit during page fault. Since HugeTLB doesn't support page reclaim, enforcing the limit at page fault time implies that, the application will get SIGBUS signal if it tries to access HugeTLB pages beyond its limit. This requires the application to know beforehand how much HugeTLB pages it would require for its use. The goal is to control how many HugeTLB pages a group of task can allocate. It can be looked at as an extension of the existing quota interface which limits the number of HugeTLB pages per hugetlbfs superblock. HPC job scheduler requires jobs to specify their resource requirements in the job file. Once their requirements can be met, job schedulers like (SLURM) will schedule the job. We need to make sure that the jobs won't consume more resources than requested. If they do we should either error out or kill the application. This patch: Rename max_hstate to hugetlb_max_hstate. We will be using this from other subsystems like hugetlb controller in later patches. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hillf Danton <dhillf@gmail.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: prepare for removal of obsolete /proc/sys/vm/nr_pdflush_threadsWanpeng Li
Since per-BDI flusher threads were introduced in 2.6, the pdflush mechanism is not used any more. But the old interface exported through /proc/sys/vm/nr_pdflush_threads still exists and is obviously useless. For back-compatibility, printk warning information and return 2 to notify the users that the interface is removed. Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/buddy: cleanup on should_fail_alloc_pageGavin Shan
Currently, function should_fail() has "bool" for its return value, so it's reasonable to change the return value of function should_fail_alloc_page() into "bool" as well. The patch does cleanup on function should_fail_alloc_page() to have "bool" for its return value. Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: account the total_vm in the vm_stat_account()Huang Shijie
vm_stat_account() accounts the shared_vm, stack_vm and reserved_vm now. But we can also account for total_vm in the vm_stat_account() which makes the code tidy. Even for mprotect_fixup(), we can get the right result in the end. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31swap: allow swap readahead to be mergedChristian Ehrhardt
Swap readahead works fine, but the I/O to disk is almost always done in page size requests, despite the fact that readahead submits 1<<page-cluster pages at a time. On older kernels the old per device plugging behavior might have captured this and merged the requests, but currently all comes down to much more I/Os than required. On a single device this might not be an issue, but as soon as a server runs on shared san resources savin I/Os not only improves swapin throughput but also provides a lower resource utilization. With a load running KVM in a lot of memory overcommitment (the hot memory is 1.5 times the host memory) swapping throughput improves significantly and the lead feels more responsive as well as achieves more throughput. In a test setup with 16 swap disks running blocktrace on one of those disks shows the improved merging: Prior: Reads Queued: 560,888, 2,243MiB Writes Queued: 226,242, 904,968KiB Read Dispatches: 544,701, 2,243MiB Write Dispatches: 159,318, 904,968KiB Reads Requeued: 0 Writes Requeued: 0 Reads Completed: 544,716, 2,243MiB Writes Completed: 159,321, 904,980KiB Read Merges: 16,187, 64,748KiB Write Merges: 61,744, 246,976KiB IO unplugs: 149,614 Timer unplugs: 2,940 With the patch: Reads Queued: 734,315, 2,937MiB Writes Queued: 300,188, 1,200MiB Read Dispatches: 214,972, 2,937MiB Write Dispatches: 215,176, 1,200MiB Reads Requeued: 0 Writes Requeued: 0 Reads Completed: 214,971, 2,937MiB Writes Completed: 215,177, 1,200MiB Read Merges: 519,343, 2,077MiB Write Merges: 73,325, 293,300KiB IO unplugs: 337,130 Timer unplugs: 11,184 I got ~10% to ~40% more throughput in my cases and at the same time much lower cpu consumption when broken down per transferred kilobyte (the majority of that due to saved interrupts and better cache handling). In a shared SAN others might get an additional benefit as well, because this now causes less protocol overhead. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Jens Axboe <axboe@kernel.dk> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: remove MEM_CGROUP_CHARGE_TYPE_FORCEKamezawa Hiroyuki
There are no users since commit b24028572fb69 ("memcg: remove PCG_CACHE"). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: rename MEM_CGROUP_CHARGE_TYPE_MAPPED as MEM_CGROUP_CHARGE_TYPE_ANONKamezawa Hiroyuki
Now, in memcg, 2 "MAPPED" enum/macro are found MEM_CGROUP_CHARGE_TYPE_MAPPED MEM_CGROUP_STAT_FILE_MAPPED Thier names looks similar to each other but the former is used for accounting anonymous memory. rename it as TYPE_ANON. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: rename MEM_CGROUP_STAT_SWAPOUT as MEM_CGROUP_STAT_SWAPKamezawa Hiroyuki
MEM_CGROUP_STAT_SWAPOUT represents the usage of swap rather than the number of swap-out events. Rename it to be MEM_CGROUP_STAT_SWAP. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: make vb_alloc() more foolproofJan Kara
If someone calls vb_alloc() (or vm_map_ram() for that matter) to allocate 0 bytes (0 pages), get_order() returns BITS_PER_LONG - PAGE_CACHE_SHIFT and interesting stuff happens. So make debugging such problems easier and warn about 0-size allocation. [akpm@linux-foundation.org: use WARN_ON-return-value feature] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31vmalloc: walk vmap_areas by sorted list instead of rb_next()Hong zhi guo
There's a walk by repeating rb_next to find a suitable hole. Could be simply replaced by walk on the sorted vmap_area_list. More simpler and efficient. Mutation of the list and tree only happens in pair within __insert_vmap_area and __free_vmap_area, under protection of vmap_area_lock. The patch code is also under vmap_area_lock, so the list walk is safe, and consistent with the tree walk. Tested on SMP by repeating batch of vmalloc anf vfree for random sizes and rounds for hours. Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "The biggest changes are Intel Nehalem-EX PMU uncore support, uprobes updates/cleanups/fixes from Oleg and diverse tooling updates (mostly fixes) now that Arnaldo is back from vacation." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) uprobes: __replace_page() needs munlock_vma_page() uprobes: Rename vma_address() and make it return "unsigned long" uprobes: Fix register_for_each_vma()->vma_address() check uprobes: Introduce vaddr_to_offset(vma, vaddr) uprobes: Teach build_probe_list() to consider the range uprobes: Remove insert_vm_struct()->uprobe_mmap() uprobes: Remove copy_vma()->uprobe_mmap() uprobes: Fix overflow in vma_address()/find_active_uprobe() uprobes: Suppress uprobe_munmap() from mmput() uprobes: Uprobe_mmap/munmap needs list_for_each_entry_safe() uprobes: Clean up and document write_opcode()->lock_page(old_page) uprobes: Kill write_opcode()->lock_page(new_page) uprobes: __replace_page() should not use page_address_in_vma() uprobes: Don't recheck vma/f_mapping in write_opcode() perf/x86: Fix missing struct before structure name perf/x86: Fix format definition of SNB-EP uncore QPI box perf/x86: Make bitfield unsigned perf/x86: Fix LLC-* and node-* events on Intel SandyBridge perf/x86: Add Intel Nehalem-EX uncore support perf/x86: Fix typo in format definition of uncore PCU filter ...
2012-07-31fs: Protect write paths by sb_start_write - sb_end_writeJan Kara
There are several entry points which dirty pages in a filesystem. mmap (handled by block_page_mkwrite()), buffered write (handled by __generic_file_aio_write()), splice write (generic_file_splice_write), truncate, and fallocate (these can dirty last partial page - handled inside each filesystem separately). Protect these places with sb_start_write() and sb_end_write(). ->page_mkwrite() calls are particularly complex since they are called with mmap_sem held and thus we cannot use standard sb_start_write() due to lock ordering constraints. We solve the problem by using a special freeze protection sb_start_pagefault() which ranks below mmap_sem. BugLink: https://bugs.launchpad.net/bugs/897421 Tested-by: Kamal Mostafa <kamal@canonical.com> Tested-by: Peter M. Petrakis <peter.petrakis@canonical.com> Tested-by: Dann Frazier <dann.frazier@canonical.com> Tested-by: Massimo Morana <massimo.morana@canonical.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
