commit 74d369443325063a5f0260e63971decb950fd8fa upstream.
Commit 947e9762a8dd ("writeback: update wb_over_bg_thresh() to use
wb_domain aware operations") unintentionally changed this function's
meaning from "are there more dirty pages than the background writeback
threshold" to "are there more dirty pages than the writeback threshold".
The background writeback threshold is typically half of the writeback
threshold, so this had the effect of raising the number of dirty pages
required to cause a writeback worker to perform background writeout.
This can cause a very severe performance regression when a BDI uses
BDI_CAP_STRICTLIMIT because balance_dirty_pages() and the writeback worker
can now disagree on whether writeback should be initiated.
For example, in a system having 1GB of RAM, a single spinning disk, and a
"pass-through" FUSE filesystem mounted over the disk, application code
mmapped a 128MB file on the disk and was randomly dirtying pages in that
mapping.
Because FUSE uses strictlimit and has a default max_ratio of only 1%, in
balance_dirty_pages, thresh is ~200, bg_thresh is ~100, and the
dirty_freerun_ceiling is the average of those, ~150. So, it pauses the
dirtying processes when we have 151 dirty pages and wakes up a background
writeback worker. But the worker tests the wrong threshold (200 instead of
100), so it does not initiate writeback and just returns.
Thus, balance_dirty_pages keeps looping, sleeping and then waking up the
worker who will do nothing. It remains stuck in this state until the few
dirty pages that we have finally expire and we write them back for that
reason. Then the whole process repeats, resulting in near-zero throughput
through the FUSE BDI.
The fix is to call the parameterized variant of wb_calc_thresh, so that the
worker will do writeback if the bg_thresh is exceeded which was the
behavior before the referenced commit.
Fixes: 947e9762a8dd ("writeback: update wb_over_bg_thresh() to use wb_domain aware operations")
Signed-off-by: Howard Cochran <hcochran@kernelspring.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Tested-by Sedat Dilek <sedat.dilek@gmail.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit bc22af74f271ef76b2e6f72f3941f91f0da3f5f8 upstream.
Khugepaged attempts to raise min_free_kbytes if its set too low.
However, on boot khugepaged sets min_free_kbytes first from
subsys_initcall(), and then the mm 'core' over-rides min_free_kbytes
after from init_per_zone_wmark_min(), via a module_init() call.
Khugepaged used to use a late_initcall() to set min_free_kbytes (such
that it occurred after the core initialization), however this was
removed when the initialization of min_free_kbytes was integrated into
the starting of the khugepaged thread.
The fix here is simply to invoke the core initialization using a
core_initcall() instead of module_init(), such that the previous
initialization ordering is restored. I didn't restore the
late_initcall() since start_stop_khugepaged() already sets
min_free_kbytes via set_recommended_min_free_kbytes().
This was noticed when we had a number of page allocation failures when
moving a workload to a kernel with this new initialization ordering. On
an 8GB system this restores min_free_kbytes back to 67584 from 11365
when CONFIG_TRANSPARENT_HUGEPAGE=y is set and either
CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y or
CONFIG_TRANSPARENT_HUGEPAGE_MADVISE=y.
Fixes: 79553da293d3 ("thp: cleanup khugepaged startup")
Signed-off-by: Jason Baron <jbaron@akamai.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Acked-by: David Rientjes <rientjes@google.com>
commit 32a4e169039927bfb6ee9f0ccbbe3a8aaf13a4bc upstream.
Instead of using "zswap" as the name for all zpools created, add an
atomic counter and use "zswap%x" with the counter number for each zpool
created, to provide a unique name for each new zpool.
As zsmalloc, one of the zpool implementations, requires/expects a unique
name for each pool created, zswap should provide a unique name. The
zsmalloc pool creation does not fail if a new pool with a conflicting
name is created, unless CONFIG_ZSMALLOC_STAT is enabled; in that case,
zsmalloc pool creation fails with -ENOMEM. Then zswap will be unable to
change its compressor parameter if its zpool is zsmalloc; it also will
be unable to change its zpool parameter back to zsmalloc, if it has any
existing old zpool using zsmalloc with page(s) in it. Attempts to
change the parameters will result in failure to create the zpool. This
changes zswap to provide a unique name for each zpool creation.
Fixes: f1c54846ee45 ("zswap: dynamic pool creation")
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Dan Streetman <dan.streetman@canonical.com>
Cc: Minchan Kim <minchan@kernel.org>
commit 14af4a5e9b26ad251f81c174e8a43f3e179434a5 upstream.
/proc/sys/vm/stat_refresh warns nr_isolated_anon and nr_isolated_file go
increasingly negative under compaction: which would add delay when
should be none, or no delay when should delay. The bug in compaction
was due to a recent mmotm patch, but much older instance of the bug was
also noticed in isolate_migratepages_range() which is used for CMA and
gigantic hugepage allocations.
The bug is caused by putback_movable_pages() in an error path
decrementing the isolated counters without them being previously
incremented by acct_isolated(). Fix isolate_migratepages_range() by
removing the error-path putback, thus reaching acct_isolated() with
migratepages still isolated, and leaving putback to caller like most
other places do.
Fixes: edc2ca612496 ("mm, compaction: move pageblock checks up from isolate_migratepages_range()")
[vbabka@suse.cz: expanded the changelog]
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Michal Hocko <mhocko@kernel.org>
commit d7e69488bd04de165667f6bc741c1c0ec6042ab9 upstream.
Currently, migration code increses num_poisoned_pages on *failed*
migration page as well as successfully migrated one at the trial of
memory-failure. It will make the stat wrong. As well, it marks the
page as PG_HWPoison even if the migration trial failed. It would mean
we cannot recover the corrupted page using memory-failure facility.
This patches fixes it.
Signed-off-by: Minchan Kim <minchan@kernel.org>
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 7bf52fb891b64b8d61caf0b82060adb9db761aec upstream.
We have been reclaimed highmem zone if buffer_heads is over limit but
commit 6b4f7799c6a5 ("mm: vmscan: invoke slab shrinkers from
shrink_zone()") changed the behavior so it doesn't reclaim highmem zone
although buffer_heads is over the limit. This patch restores the logic.
Fixes: 6b4f7799c6a5 ("mm: vmscan: invoke slab shrinkers from shrink_zone()")
commit 28093f9f34cedeaea0f481c58446d9dac6dd620f upstream.
In gather_pte_stats() a THP pmd is cast into a pte, which is wrong
because the layouts may differ depending on the architecture. On s390
this will lead to inaccurate numa_maps accounting in /proc because of
misguided pte_present() and pte_dirty() checks on the fake pte.
On other architectures pte_present() and pte_dirty() may work by chance,
but there may be an issue with direct-access (dax) mappings w/o
underlying struct pages when HAVE_PTE_SPECIAL is set and THP is
available. In vm_normal_page() the fake pte will be checked with
pte_special() and because there is no "special" bit in a pmd, this will
always return false and the VM_PFNMAP | VM_MIXEDMAP checking will be
skipped. On dax mappings w/o struct pages, an invalid struct page
pointer would then be returned that can crash the kernel.
This patch fixes the numa_maps THP handling by introducing new "_pmd"
variants of the can_gather_numa_stats() and vm_normal_page() functions.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com>
commit 3486b85a29c1741db99d0c522211c82d2b7a56d0 upstream.
Khugepaged detects own VMAs by checking vm_file and vm_ops but this way
it cannot distinguish private /dev/zero mappings from other special
mappings like /dev/hpet which has no vm_ops and popultes PTEs in mmap.
This fixes false-positive VM_BUG_ON and prevents installing THP where
they are not expected.
Link: http://lkml.kernel.org/r/CACT4Y+ZmuZMV5CjSFOeXviwQdABAgT7T+StKfTqan9YDtgEi5g@mail.gmail.com
Fixes: 78f11a255749 ("mm: thp: fix /dev/zero MAP_PRIVATE and vm_flags cleanups")
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Dmitry Vyukov <dvyukov@google.com>
commit 264a0ae164bc0e9144bebcd25ff030d067b1a878 upstream.
So, this ended up a lot simpler than I originally expected. I tested
it lightly and it seems to work fine. Petr, can you please test these
two patches w/o the lru drain drop patch and see whether the problem
is gone?
Thanks.
------ 8< ------
If charge moving is used, memcg performs relabeling of the affected
pages from its ->attach callback which is called under both
cgroup_threadgroup_rwsem and thus can't create new kthreads. This is
fragile as various operations may depend on workqueues making forward
progress which relies on the ability to create new kthreads.
There's no reason to perform charge moving from ->attach which is deep
in the task migration path. Move it to ->post_attach which is called
after the actual migration is finished and cgroup_threadgroup_rwsem is
dropped.
* move_charge_struct->mm is added and ->can_attach is now responsible
for pinning and recording the target mm. mem_cgroup_clear_mc() is
updated accordingly. This also simplifies mem_cgroup_move_task().
* mem_cgroup_move_task() is now called from ->post_attach instead of
->attach.
Acked-by: Michal Hocko <mhocko@kernel.org>
Debugged-and-tested-by: Petr Mladek <pmladek@suse.com>
Reported-by: Cyril Hrubis <chrubis@suse.cz>
Reported-by: Johannes Weiner <hannes@cmpxchg.org>
Fixes: 1ed1328792ff ("sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem")
commit 376bf125ac781d32e202760ed7deb1ae4ed35d31 upstream.
This change is primarily an attempt to make it easier to realize the
optimizations the compiler performs in-case CONFIG_MEMCG_KMEM is not
enabled.
Performance wise, even when CONFIG_MEMCG_KMEM is compiled in, the
overhead is zero. This is because, as long as no process have enabled
kmem cgroups accounting, the assignment is replaced by asm-NOP
operations. This is possible because memcg_kmem_enabled() uses a
static_key_false() construct.
It also helps readability as it avoid accessing the p[] array like:
p[size - 1] which "expose" that the array is processed backwards inside
helper function build_detached_freelist().
Lastly this also makes the code more robust, in error case like passing
NULL pointers in the array. Which were previously handled before commit
033745189b1b ("slub: add missing kmem cgroup support to
kmem_cache_free_bulk").
Fixes: 033745189b1b ("slub: add missing kmem cgroup support to kmem_cache_free_bulk")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
commit 6f25a14a7053b69917e2ebea0d31dd444cd31fd5 upstream.
It is incorrect to use next_node to find a target node, it will return
MAX_NUMNODES or invalid node. This will lead to crash in buddy system
allocation.
Fixes: c8721bbbdd36 ("mm: memory-hotplug: enable memory hotplug to handle hugepage")
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: "Laura Abbott" <lauraa@codeaurora.org>
Cc: Hui Zhu <zhuhui@xiaomi.com>
Cc: Wang Xiaoqiang <wangxq10@lzu.edu.cn>
commit d9dddbf556674bf125ecd925b24e43a5cf2a568a upstream.
Hanjun Guo has reported that a CMA stress test causes broken accounting of
CMA and free pages:
> Before the test, I got:
> -bash-4.3# cat /proc/meminfo | grep Cma
> CmaTotal: 204800 kB
> CmaFree: 195044 kB
> After running the test:
> CmaTotal: 204800 kB
> CmaFree: 6602584 kB
> So the freed CMA memory is more than total..
> Also the the MemFree is more than mem total:
> MemTotal: 16342016 kB
> MemFree: 22367268 kB
> MemAvailable: 22370528 kB
Laura Abbott has confirmed the issue and suspected the freepage accounting
rewrite around 3.18/4.0 by Joonsoo Kim. Joonsoo had a theory that this is
caused by unexpected merging between MIGRATE_ISOLATE and MIGRATE_CMA
pageblocks:
> CMA isolates MAX_ORDER aligned blocks, but, during the process,
> partialy isolated block exists. If MAX_ORDER is 11 and
> pageblock_order is 9, two pageblocks make up MAX_ORDER
> aligned block and I can think following scenario because pageblock
> (un)isolation would be done one by one.
> (each character means one pageblock. 'C', 'I' means MIGRATE_CMA,
> MIGRATE_ISOLATE, respectively.
> CC -> IC -> II (Isolation)
> II -> CI -> CC (Un-isolation)
> If some pages are freed at this intermediate state such as IC or CI,
> that page could be merged to the other page that is resident on
> different type of pageblock and it will cause wrong freepage count.
This was supposed to be prevented by CMA operating on MAX_ORDER blocks,
but since it doesn't hold the zone->lock between pageblocks, a race
window does exist.
It's also likely that unexpected merging can occur between
MIGRATE_ISOLATE and non-CMA pageblocks. This should be prevented in
__free_one_page() since commit 3c605096d315 ("mm/page_alloc: restrict
max order of merging on isolated pageblock"). However, we only check
the migratetype of the pageblock where buddy merging has been initiated,
not the migratetype of the buddy pageblock (or group of pageblocks)
which can be MIGRATE_ISOLATE.
Joonsoo has suggested checking for buddy migratetype as part of
page_is_buddy(), but that would add extra checks in allocator hotpath
and bloat-o-meter has shown significant code bloat (the function is
inline).
This patch reduces the bloat at some expense of more complicated code.
The buddy-merging while-loop in __free_one_page() is initially bounded
to pageblock_border and without any migratetype checks. The checks are
placed outside, bumping the max_order if merging is allowed, and
returning to the while-loop with a statement which can't be possibly
considered harmful.
This fixes the accounting bug and also removes the arguably weird state
in the original commit 3c605096d315 where buddies could be left
unmerged.
Fixes: 3c605096d315 ("mm/page_alloc: restrict max order of merging on isolated pageblock")
Link: https://lkml.org/lkml/2016/3/2/280
Reported-by: Hanjun Guo <guohanjun@huawei.com>
Tested-by: Hanjun Guo <guohanjun@huawei.com>
Debugged-by: Laura Abbott <labbott@redhat.com>
Debugged-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
commit b6e6edcfa40561e9c8abe5eecf1c96f8e5fd9c6f upstream.
Setting the original memory.limit_in_bytes hardlimit is subject to a
race condition when the desired value is below the current usage. The
code tries a few times to first reclaim and then see if the usage has
dropped to where we would like it to be, but there is no locking, and
the workload is free to continue making new charges up to the old limit.
Thus, attempting to shrink a workload relies on pure luck and hope that
the workload happens to cooperate.
To fix this in the cgroup2 memory.max knob, do it the other way round:
set the limit first, then try enforcement. And if reclaim is not able
to succeed, trigger OOM kills in the group. Keep going until the new
limit is met, we run out of OOM victims and there's only unreclaimable
memory left, or the task writing to memory.max is killed. This allows
users to shrink groups reliably, and the behavior is consistent with
what happens when new charges are attempted in excess of memory.max.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
commit 588083bb37a3cea8533c392370a554417c8f29cb upstream.
When setting memory.high below usage, nothing happens until the next
charge comes along, and then it will only reclaim its own charge and not
the now potentially huge excess of the new memory.high. This can cause
groups to stay in excess of their memory.high indefinitely.
To fix that, when shrinking memory.high, kick off a reclaim cycle that
goes after the delta.
commit 3ed47db34f480df7caf44436e3e63e555351ae9a upstream.
commit 21ea9fb69e7c4b1b1559c3e410943d3ff248ffcb upstream.
In balloon_page_dequeue, pages_lock should cover the loop
(ie, list_for_each_entry_safe). Otherwise, the cursor page could
be isolated by compaction and then list_del by isolation could
poison the page->lru.{prev,next} so the loop finally could
access wrong address like this. This patch fixes the bug.
general protection fault: 0000 [#1] SMP
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 2 PID: 82 Comm: vballoon Not tainted 4.4.0-rc5-mm1-access_bit+ #1906
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff8800a7ff0000 ti: ffff8800a7fec000 task.ti: ffff8800a7fec000
RIP: 0010:[<ffffffff8115e754>] [<ffffffff8115e754>] balloon_page_dequeue+0x54/0x130
RSP: 0018:ffff8800a7fefdc0 EFLAGS: 00010246
RAX: ffff88013fff9a70 RBX: ffffea000056fe00 RCX: 0000000000002b7d
RDX: ffff88013fff9a70 RSI: ffffea000056fe00 RDI: ffff88013fff9a68
RBP: ffff8800a7fefde8 R08: ffffea000056fda0 R09: 0000000000000000
R10: ffff8800a7fefd90 R11: 0000000000000001 R12: dead0000000000e0
R13: ffffea000056fe20 R14: ffff880138809070 R15: ffff880138809060
FS: 0000000000000000(0000) GS:ffff88013fc40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007f229c10e000 CR3: 00000000b8b53000 CR4: 00000000000006a0
Stack:
0000000000000100 ffff880138809088 ffff880138809000 ffff880138809060
0000000000000046 ffff8800a7fefe28 ffffffff812c86d3 ffff880138809020
ffff880138809000 fffffffffff91900 0000000000000100 ffff880138809060
Call Trace:
[<ffffffff812c86d3>] leak_balloon+0x93/0x1a0
[<ffffffff812c8bc7>] balloon+0x217/0x2a0
[<ffffffff8143739e>] ? __schedule+0x31e/0x8b0
[<ffffffff81078160>] ? abort_exclusive_wait+0xb0/0xb0
[<ffffffff812c89b0>] ? update_balloon_stats+0xf0/0xf0
[<ffffffff8105b6e9>] kthread+0xc9/0xe0
[<ffffffff8105b620>] ? kthread_park+0x60/0x60
[<ffffffff8143b4af>] ret_from_fork+0x3f/0x70
Code: 8d 60 e0 0f 84 af 00 00 00 48 8b 43 20 a8 01 75 3b 48 89 d8 f0 0f ba 28 00 72 10 48 8b 03 f6 c4 08 75 2f 48 89 df e8 8c 83 f9 ff <49> 8b 44 24 20 4d 8d 6c 24 20 48 83 e8 20 4d 39 f5 74 7a 4c 89
RIP [<ffffffff8115e754>] balloon_page_dequeue+0x54/0x130
RSP <ffff8800a7fefdc0>
---[ end trace 43cf28060d708d5f ]---
Kernel panic - not syncing: Fatal exception
Kernel Offset: disabled
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Rafael Aquini <aquini@redhat.com>
commit 8479eba7781fa9ffb28268840de6facfc12c35a7 upstream.
Commit 4167e9b2cf10 ("mm: remove GFP_THISNODE") removed the GFP_THISNODE
flag combination due to confusing semantics. It noted that
alloc_misplaced_dst_page() was one such user after changes made by
commit e97ca8e5b864 ("mm: fix GFP_THISNODE callers and clarify").
Unfortunately when GFP_THISNODE was removed, users of
alloc_misplaced_dst_page() started waking kswapd and entering direct
reclaim because the wrong GFP flags are cleared. The consequence is
that workloads that used to fit into memory now get reclaimed which is
addressed by this patch.
The problem can be demonstrated with "mutilate" that exercises memcached
which is software dedicated to memory object caching. The configuration
uses 80% of memory and is run 3 times for varying numbers of clients.
The results on a 4-socket NUMA box are
mutilate
4.4.0 4.4.0
vanilla numaswap-v1
Hmean 1 8394.71 ( 0.00%) 8395.32 ( 0.01%)
Hmean 4 30024.62 ( 0.00%) 34513.54 ( 14.95%)
Hmean 7 32821.08 ( 0.00%) 70542.96 (114.93%)
Hmean 12 55229.67 ( 0.00%) 93866.34 ( 69.96%)
Hmean 21 39438.96 ( 0.00%) 85749.21 (117.42%)
Hmean 30 37796.10 ( 0.00%) 50231.49 ( 32.90%)
Hmean 47 18070.91 ( 0.00%) 38530.13 (113.22%)
The metric is queries/second with the more the better. The results are
way outside of the noise and the reason for the improvement is obvious
from some of the vmstats
4.4.0 4.4.0
vanillanumaswap-v1r1
Minor Faults 1929399272 2146148218
Major Faults 19746529 3567
Swap Ins 57307366 9913
Swap Outs 50623229 17094
Allocation stalls 35909 443
DMA allocs 0 0
DMA32 allocs 72976349 170567396
Normal allocs 5306640898 5310651252
Movable allocs 0 0
Direct pages scanned 404130893 799577
Kswapd pages scanned 160230174 0
Kswapd pages reclaimed 55928786 0
Direct pages reclaimed 1843936 41921
Page writes file 2391 0
Page writes anon 50623229 17094
The vanilla kernel is swapping like crazy with large amounts of direct
reclaim and kswapd activity. The figures are aggregate but it's known
that the bad activity is throughout the entire test.
Note that simple streaming anon/file memory consumers also see this
problem but it's not as obvious. In those cases, kswapd is awake when
it should not be.
As there are at least two reclaim-related bugs out there, it's worth
spelling out the user-visible impact. This patch only addresses bugs
related to excessive reclaim on NUMA hardware when the working set is
larger than a NUMA node. There is a bug related to high kswapd CPU
usage but the reports are against laptops and other UMA hardware and is
not addressed by this patch.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
commit ad33bb04b2a6cee6c1f99fabb15cddbf93ff0433 upstream.
pmd_trans_unstable()/pmd_none_or_trans_huge_or_clear_bad() were
introduced to locklessy (but atomically) detect when a pmd is a regular
(stable) pmd or when the pmd is unstable and can infinitely transition
from pmd_none() and pmd_trans_huge() from under us, while only holding
the mmap_sem for reading (for writing not).
While holding the mmap_sem only for reading, MADV_DONTNEED can run from
under us and so before we can assume the pmd to be a regular stable pmd
we need to compare it against pmd_none() and pmd_trans_huge() in an
atomic way, with pmd_trans_unstable(). The old pmd_trans_huge() left a
tiny window for a race.
Useful applications are unlikely to notice the difference as doing
MADV_DONTNEED concurrently with a page fault would lead to undefined
behavior.
[akpm@linux-foundation.org: tidy up comment grammar/layout]
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 6a6ac72fd6ea32594b316513e1826c3f6db4cc93 upstream.
This showed up on ARC when running LMBench bw_mem tests as Overlapping
TLB Machine Check Exception triggered due to STLB entry (2M pages)
overlapping some NTLB entry (regular 8K page).
bw_mem 2m touches a large chunk of vaddr creating NTLB entries. In the
interim khugepaged kicks in, collapsing the contiguous ptes into a
single pmd. pmdp_collapse_flush()->flush_pmd_tlb_range() is called to
flush out NTLB entries for the ptes. This for ARC (by design) can only
shootdown STLB entries (for pmd). The stray NTLB entries cause the
overlap with the subsequent STLB entry for collapsed page. So make
pmdp_collapse_flush() call pte flush interface not pmd flush.
Note that originally all thp flush call sites in generic code called
flush_tlb_range() leaving it to architecture to implement the flush for
pte and/or pmd. Commit 12ebc1581ad11454 changed this by calling a new
opt-in API flush_pmd_tlb_range() which made the semantics more explicit
but failed to distinguish the pte vs pmd flush in generic code, which is
what this patch fixes.
Note that ARC can fixed w/o touching the generic pmdp_collapse_flush()
by defining a ARC version, but that defeats the purpose of generic
version, plus sementically this is the right thing to do.
Fixes STAR 9000961194: LMBench on AXS103 triggering duplicate TLB
exceptions with super pages
Fixes: 12ebc1581ad11454 ("mm,thp: introduce flush_pmd_tlb_range")
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 6611d8d76132f86faa501de9451a89bf23fb2371 upstream.
A spare array holding mem cgroup threshold events is kept around to make
sure we can always safely deregister an event and have an array to store
the new set of events in.
In the scenario where we're going from 1 to 0 registered events, the
pointer to the primary array containing 1 event is copied to the spare
slot, and then the spare slot is freed because no events are left.
However, it is freed before calling synchronize_rcu(), which means
readers may still be accessing threshold->primary after it is freed.
Fixed by only freeing after synchronize_rcu().
Signed-off-by: Martijn Coenen <maco@google.com>
commit 48f7df329474b49d83d0dffec1b6186647f11976 upstream.
Grazvydas Ignotas has reported a regression in remap_file_pages()
emulation.
Testcase:
#define _GNU_SOURCE
#include <assert.h>
#include <stdlib.h>
#include <stdio.h>
#include <sys/mman.h>
#define SIZE (4096 * 3)
int main(int argc, char **argv)
unsigned long *p;
long i;
p = mmap(NULL, SIZE, PROT_READ | PROT_WRITE,
MAP_SHARED | MAP_ANONYMOUS, -1, 0);
if (p == MAP_FAILED) {
perror("mmap");
return -1;
for (i = 0; i < SIZE / 4096; i++)
p[i * 4096 / sizeof(*p)] = i;
if (remap_file_pages(p, 4096, 0, 1, 0)) {
perror("remap_file_pages");
return -1;
if (remap_file_pages(p, 4096 * 2, 0, 1, 0)) {
return -1;
assert(p[0] == 1);
munmap(p, SIZE);
return 0;
The second remap_file_pages() fails with -EINVAL.
The reason is that remap_file_pages() emulation assumes that the target
vma covers whole area we want to over map. That assumption is broken by
first remap_file_pages() call: it split the area into two vma.
The solution is to check next adjacent vmas, if they map the same file
with the same flags.
Fixes: c8d78c1823f4 ("mm: replace remap_file_pages() syscall with emulation")
Reported-by: Grazvydas Ignotas <notasas@gmail.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
commit 12352d3cae2cebe18805a91fab34b534d7444231 upstream.
Sequence vma_lock_anon_vma() - vma_unlock_anon_vma() isn't safe if
anon_vma appeared between lock and unlock. We have to check anon_vma
first or call anon_vma_prepare() to be sure that it's here. There are
only few users of these legacy helpers. Let's get rid of them.
This patch fixes anon_vma lock imbalance in validate_mm(). Write lock
isn't required here, read lock is enough.
And reorders expand_downwards/expand_upwards: security_mmap_addr() and
wrapping-around check don't have to be under anon vma lock.
Link: https://lkml.kernel.org/r/CACT4Y+Y908EjM2z=706dv4rV6dWtxTLK9nFg9_7DhRMLppBo2g@mail.gmail.com
commit 7162a1e87b3e380133dadc7909081bb70d0a7041 upstream.
Tetsuo Handa reported underflow of NR_MLOCK on munlock.
Testcase:
#include <stdio.h>
#include <stdlib.h>
#define BASE ((void *)0x400000000000)
#define SIZE (1UL << 21)
int main(int argc, char *argv[])
void *addr;
system("grep Mlocked /proc/meminfo");
addr = mmap(BASE, SIZE, PROT_READ | PROT_WRITE,
MAP_ANONYMOUS | MAP_PRIVATE | MAP_LOCKED | MAP_FIXED,
-1, 0);
if (addr == MAP_FAILED)
printf("mmap() failed\n"), exit(1);
munmap(addr, SIZE);
return 0;
It happens on munlock_vma_page() due to unfortunate choice of nr_pages
data type:
__mod_zone_page_state(zone, NR_MLOCK, -nr_pages);
For unsigned int nr_pages, implicitly casted to long in
__mod_zone_page_state(), it becomes something around UINT_MAX.
munlock_vma_page() usually called for THP as small pages go though
pagevec.
Let's make nr_pages signed int.
Similar fixes in 6cdb18ad98a4 ("mm/vmstat: fix overflow in
mod_zone_page_state()") used `long' type, but `int' here is OK for a
count of the number of sub-pages in a huge page.
Fixes: ff6a6da60b89 ("mm: accelerate munlock() treatment of THP pages")
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Michel Lespinasse <walken@google.com>
commit d96b339f453997f2f08c52da3f41423be48c978f upstream.
I saw the following BUG_ON triggered in a testcase where a process calls
madvise(MADV_SOFT_OFFLINE) on thps, along with a background process that
calls migratepages command repeatedly (doing ping-pong among different
NUMA nodes) for the first process:
Soft offlining page 0x60000 at 0x700000600000
__get_any_page: 0x60000 free buddy page
page:ffffea0001800000 count:0 mapcount:-127 mapping: (null) index:0x1
flags: 0x1fffc0000000000()
page dumped because: VM_BUG_ON_PAGE(atomic_read(&page->_count) == 0)
kernel BUG at /src/linux-dev/include/linux/mm.h:342!
invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: cfg80211 rfkill crc32c_intel serio_raw virtio_balloon i2c_piix4 virtio_blk virtio_net ata_generic pata_acpi
CPU: 3 PID: 3035 Comm: test_alloc_gene Tainted: G O 4.4.0-rc8-v4.4-rc8-160107-1501-00000-rc8+ #74
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff88007c63d5c0 ti: ffff88007c210000 task.ti: ffff88007c210000
RIP: 0010:[<ffffffff8118998c>] [<ffffffff8118998c>] put_page+0x5c/0x60
RSP: 0018:ffff88007c213e00 EFLAGS: 00010246
Call Trace:
put_hwpoison_page+0x4e/0x80
soft_offline_page+0x501/0x520
SyS_madvise+0x6bc/0x6f0
entry_SYSCALL_64_fastpath+0x12/0x6a
Code: 8b fc ff ff 5b 5d c3 48 89 df e8 b0 fa ff ff 48 89 df 31 f6 e8 c6 7d ff ff 5b 5d c3 48 c7 c6 08 54 a2 81 48 89 df e8 a4 c5 01 00 <0f> 0b 66 90 66 66 66 66 90 55 48 89 e5 41 55 41 54 53 48 8b 47
RIP [<ffffffff8118998c>] put_page+0x5c/0x60
RSP <ffff88007c213e00>
The root cause resides in get_any_page() which retries to get a refcount
of the page to be soft-offlined. This function calls
put_hwpoison_page(), expecting that the target page is putback to LRU
list. But it can be also freed to buddy. So the second check need to
care about such case.
Fixes: af8fae7c0886 ("mm/memory-failure.c: clean up soft_offline_page()")
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Steve Capper <steve.capper@linaro.org>
commit caaee6234d05a58c5b4d05e7bf766131b810a657 upstream.
By checking the effective credentials instead of the real UID / permitted
capabilities, ensure that the calling process actually intended to use its
credentials.
To ensure that all ptrace checks use the correct caller credentials (e.g.
in case out-of-tree code or newly added code omits the PTRACE_MODE_*CREDS
flag), use two new flags and require one of them to be set.
The problem was that when a privileged task had temporarily dropped its
privileges, e.g. by calling setreuid(0, user_uid), with the intent to
perform following syscalls with the credentials of a user, it still passed
ptrace access checks that the user would not be able to pass.
While an attacker should not be able to convince the privileged task to
perform a ptrace() syscall, this is a problem because the ptrace access
check is reused for things in procfs.
In particular, the following somewhat interesting procfs entries only rely
on ptrace access checks:
/proc/$pid/stat - uses the check for determining whether pointers
should be visible, useful for bypassing ASLR
/proc/$pid/maps - also useful for bypassing ASLR
/proc/$pid/cwd - useful for gaining access to restricted
directories that contain files with lax permissions, e.g. in
this scenario:
lrwxrwxrwx root root /proc/13020/cwd -> /root/foobar
drwx------ root root /root
drwxr-xr-x root root /root/foobar
-rw-r--r-- root root /root/foobar/secret
Therefore, on a system where a root-owned mode 6755 binary changes its
effective credentials as described and then dumps a user-specified file,
this could be used by an attacker to reveal the memory layout of root's
processes or reveal the contents of files he is not allowed to access
(through /proc/$pid/cwd).
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Jann Horn <jann@thejh.net>
Cc: Casey Schaufler <casey@schaufler-ca.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Willy Tarreau <w@1wt.eu>
commit 564e81a57f9788b1475127012e0fd44e9049e342 upstream.
Jan Stancek has reported that system occasionally hanging after "oom01"
testcase from LTP triggers OOM. Guessing from a result that there is a
kworker thread doing memory allocation and the values between "Node 0
Normal free:" and "Node 0 Normal:" differs when hanging, vmstat is not
up-to-date for some reason.
According to commit 373ccbe59270 ("mm, vmstat: allow WQ concurrency to
discover memory reclaim doesn't make any progress"), it meant to force
the kworker thread to take a short sleep, but it by error used
schedule_timeout(1). We missed that schedule_timeout() in state
TASK_RUNNING doesn't do anything.
Fix it by using schedule_timeout_uninterruptible(1) which forces the
kworker thread to take a short sleep in order to make sure that vmstat
is up-to-date.
Fixes: 373ccbe59270 ("mm, vmstat: allow WQ concurrency to discover memory reclaim doesn't make any progress")
Reported-by: Jan Stancek <jstancek@redhat.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Cristopher Lameter <clameter@sgi.com>
Cc: Arkadiusz Miskiewicz <arekm@maven.pl>
commit c102f07ca0b04f2cb49cfc161c83f6239d17f491 upstream.
record_obj() in migrate_zspage() does not preserve handle's
HANDLE_PIN_BIT, set by find_aloced_obj()->trypin_tag(), and implicitly
(accidentally) un-pins the handle, while migrate_zspage() still performs
an explicit unpin_tag() on the that handle. This additional explicit
unpin_tag() introduces a race condition with zs_free(), which can pin
that handle by this time, so the handle becomes un-pinned.
Schematically, it goes like this:
CPU0 CPU1
migrate_zspage
find_alloced_obj
trypin_tag
set HANDLE_PIN_BIT zs_free()
pin_tag()
obj_malloc() -- new object, no tag
record_obj() -- remove HANDLE_PIN_BIT set HANDLE_PIN_BIT
unpin_tag() -- remove zs_free's HANDLE_PIN_BIT
The race condition may result in a NULL pointer dereference:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
CPU: 0 PID: 19001 Comm: CookieMonsterCl Tainted:
PC is at get_zspage_mapping+0x0/0x24
LR is at obj_free.isra.22+0x64/0x128
Call trace:
zs_free+0x88/0x114
zram_free_page+0x64/0xcc
zram_slot_free_notify+0x90/0x108
swap_entry_free+0x278/0x294
free_swap_and_cache+0x38/0x11c
unmap_single_vma+0x480/0x5c8
unmap_vmas+0x44/0x60
exit_mmap+0x50/0x110
mmput+0x58/0xe0
do_exit+0x320/0x8dc
do_group_exit+0x44/0xa8
get_signal+0x538/0x580
do_signal+0x98/0x4b8
do_notify_resume+0x14/0x5c
This patch keeps the lock bit in migration path and update value
atomically.
Signed-off-by: Junil Lee <junil0814.lee@lge.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
kernel test robot has reported the following crash:
BUG: unable to handle kernel NULL pointer dereference at 00000100
IP: [<c1074df6>] __queue_work+0x26/0x390
*pdpt = 0000000000000000 *pde = f000ff53f000ff53 *pde = f000ff53f000ff53
Oops: 0000 [#1] PREEMPT PREEMPT SMP SMP
CPU: 0 PID: 24 Comm: kworker/0:1 Not tainted 4.4.0-rc4-00139-g373ccbe #1
Workqueue: events vmstat_shepherd
task: cb684600 ti: cb7ba000 task.ti: cb7ba000
EIP: 0060:[<c1074df6>] EFLAGS: 00010046 CPU: 0
EIP is at __queue_work+0x26/0x390
EAX: 00000046 EBX: cbb37800 ECX: cbb37800 EDX: 00000000
ESI: 00000000 EDI: 00000000 EBP: cb7bbe68 ESP: cb7bbe38
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR0: 8005003b CR2: 00000100 CR3: 01fd5000 CR4: 000006b0
Stack:
Call Trace:
__queue_delayed_work+0xa1/0x160
queue_delayed_work_on+0x36/0x60
vmstat_shepherd+0xad/0xf0
process_one_work+0x1aa/0x4c0
worker_thread+0x41/0x440
kthread+0xb0/0xd0
ret_from_kernel_thread+0x21/0x40
The reason is that start_shepherd_timer schedules the shepherd work item
which uses vmstat_wq (vmstat_shepherd) before setup_vmstat allocates
that workqueue so if the further initialization takes more than HZ we
might end up scheduling on a NULL vmstat_wq. This is really unlikely
but not impossible.
Reported-by: kernel test robot <ying.huang@linux.intel.com>
Signed-off-by: Michal Hocko <mhocko@suse.com>
Tested-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: stable@vger.kernel.org
mod_zone_page_state() takes a "delta" integer argument. delta contains
the number of pages that should be added or subtracted from a struct
zone's vm_stat field.
If a zone is larger than 8TB this will cause overflows. E.g. for a
zone with a size slightly larger than 8TB the line
mod_zone_page_state(zone, NR_ALLOC_BATCH, zone->managed_pages);
in mm/page_alloc.c:free_area_init_core() will result in a negative
result for the NR_ALLOC_BATCH entry within the zone's vm_stat, since 8TB
contain 0x8xxxxxxx pages which will be sign extended to a negative
value.
Fix this by changing the delta argument to long type.
This could fix an early boot problem seen on s390, where we have a 9TB
system with only one node. ZONE_DMA contains 2GB and ZONE_NORMAL the
rest. The system is trying to allocate a GFP_DMA page but ZONE_DMA is
completely empty, so it tries to reclaim pages in an endless loop.
This was seen on a heavily patched 3.10 kernel. One possible
explaination seem to be the overflows caused by mod_zone_page_state().
Unfortunately I did not have the chance to verify that this patch
actually fixes the problem, since I don't have access to the system
right now. However the overflow problem does exist anyway.
Given the description that a system with slightly less than 8TB does
work, this seems to be a candidate for the observed problem.
test_pages_in_a_zone() does not account for the possibility of missing
sections in the given pfn range. pfn_valid_within always returns 1 when
CONFIG_HOLES_IN_ZONE is not set, allowing invalid pfns from missing
sections to pass the test, leading to a kernel oops.
Wrap an additional pfn loop with PAGES_PER_SECTION granularity to check
for missing sections before proceeding into the zone-check code.
This also prevents a crash from offlining memory devices with missing
sections. Despite this, it may be a good idea to keep the related patch
'[PATCH 3/3] drivers: memory: prohibit offlining of memory blocks with
missing sections' because missing sections in a memory block may lead to
other problems not covered by the scope of this fix.
Signed-off-by: Andrew Banman <abanman@sgi.com>
Acked-by: Alex Thorlton <athorlton@sgi.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Alex Thorlton <athorlton@sgi.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Greg KH <greg@kroah.com>
Cc: Seth Jennings <sjennings@variantweb.net>
Cc: <stable@vger.kernel.org>
Memory cgroup reclaim can be interrupted with mem_cgroup_iter_break()
once enough pages have been reclaimed, in which case, in contrast to a
full round-trip over a cgroup sub-tree, the current position stored in
mem_cgroup_reclaim_iter of the target cgroup does not get invalidated
and so is left holding the reference to the last scanned cgroup. If the
target cgroup does not get scanned again (we might have just reclaimed
the last page or all processes might exit and free their memory
voluntary), we will leak it, because there is nobody to put the
reference held by the iterator.
The problem is easy to reproduce by running the following command
sequence in a loop:
mkdir /sys/fs/cgroup/memory/test
echo 100M > /sys/fs/cgroup/memory/test/memory.limit_in_bytes
echo $$ > /sys/fs/cgroup/memory/test/cgroup.procs
memhog 150M
echo $$ > /sys/fs/cgroup/memory/cgroup.procs
rmdir test
The cgroups generated by it will never get freed.
This patch fixes this issue by making mem_cgroup_iter avoid taking
reference to the current position. In order not to hit use-after-free
bug while running reclaim in parallel with cgroup deletion, we make use
of ->css_released cgroup callback to clear references to the dying
cgroup in all reclaim iterators that might refer to it. This callback
is called right before scheduling rcu work which will free css, so if we
access iter->position from rcu read section, we might be sure it won't
go away under us.
[hannes@cmpxchg.org: clean up css ref handling]
Fixes: 5ac8fb31ad2e ("mm: memcontrol: convert reclaim iterator to simple css refcounting")
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: <stable@vger.kernel.org> [3.19+]
Change the use of strncmp in zswap_pool_find_get() to strcmp.
The use of strncmp is no longer correct, now that zswap_zpool_type is
not an array; sizeof() will return the size of a pointer, which isn't
the right length to compare. We don't need to use strncmp anyway,
because the existing params and the passed in params are all guaranteed
to be null terminated, so strcmp should be used.
Reported-by: Weijie Yang <weijie.yang@samsung.com>
It's possible that an oom killed victim shares an ->mm with the init
process and thus oom_kill_process() would end up trying to kill init as
well.
This has been shown in practice:
Out of memory: Kill process 9134 (init) score 3 or sacrifice child
Killed process 9134 (init) total-vm:1868kB, anon-rss:84kB, file-rss:572kB
Kill process 1 (init) sharing same memory
Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000009
And this will result in a kernel panic.
If a process is forked by init and selected for oom kill while still
sharing init_mm, then it's likely this system is in a recoverable state.
However, it's better not to try to kill init and allow the machine to
panic due to unkillable processes.
[rientjes@google.com: rewrote changelog]
[akpm@linux-foundation.org: fix inverted test, per Ben]
Signed-off-by: Chen Jie <chenjie6@huawei.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Li Zefan <lizefan@huawei.com>
Dmitry Vyukov provides a little program, autogenerated by syzkaller,
which races a fault on a mapping of a sparse memfd object, against
truncation of that object below the fault address: run repeatedly for a
few minutes, it reliably generates shmem_evict_inode()'s
WARN_ON(inode->i_blocks).
(But there's nothing specific to memfd here, nor to the fstat which it
happened to use to generate the fault: though that looked suspicious,
since a shmem_recalc_inode() had been added there recently. The same
problem can be reproduced with open+unlink in place of memfd_create, and
with fstatfs in place of fstat.)
v3.7 commit 0f3c42f522dc ("tmpfs: change final i_blocks BUG to WARNING")
explains one cause of such a warning (a race with shmem_writepage to
swap), and possible solutions; but we never took it further, and this
syzkaller incident turns out to have a different cause.
shmem_getpage_gfp()'s error recovery, when a freshly allocated page is
then found to be beyond eof, looks plausible - decrementing the alloced
count that was just before incremented - but in fact can go wrong, if a
racing thread (the truncator, for example) gets its shmem_recalc_inode()
in just after our delete_from_page_cache(). delete_from_page_cache()
decrements nrpages, that shmem_recalc_inode() will balance the books by
decrementing alloced itself, then our decrement of alloced take it one
too low: leading to the WARNING when the object is finally evicted.
Once the new page has been exposed in the page cache,
shmem_getpage_gfp() must leave it to shmem_recalc_inode() itself to get
the accounting right in all cases (and not fall through from "trunc:" to
"decused:"). Adjust that error recovery block; and the reinitialization
of info and sbinfo can be removed too.
While we're here, fix shmem_writepage() to avoid the original issue: it
will be safe against a racing shmem_recalc_inode(), if it merely
increments swapped before the shmem_delete_from_page_cache() which
decrements nrpages (but it must then do its own shmem_recalc_inode()
before that, while still in balance, instead of after). (Aside: why do
we shmem_recalc_inode() here in the swap path? Because its raison d'etre
is to cope with clean sparse shmem pages being reclaimed behind our
back: so here when swapping is a good place to look for that case.) But
I've not now managed to reproduce this bug, even without the patch.
I don't see why I didn't do that earlier: perhaps inhibited by the
preference to eliminate shmem_recalc_inode() altogether. Driven by this
incident, I do now have a patch to do so at last; but still want to sit
on it for a bit, there's a couple of questions yet to be resolved.
Dmitry Vyukov reported the following memory leak
unreferenced object 0xffff88002eaafd88 (size 32):
comm "a.out", pid 5063, jiffies 4295774645 (age 15.810s)
hex dump (first 32 bytes):
28 e9 4e 63 00 88 ff ff 28 e9 4e 63 00 88 ff ff (.Nc....(.Nc....
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
kmalloc include/linux/slab.h:458
region_chg+0x2d4/0x6b0 mm/hugetlb.c:398
__vma_reservation_common+0x2c3/0x390 mm/hugetlb.c:1791
vma_needs_reservation mm/hugetlb.c:1813
alloc_huge_page+0x19e/0xc70 mm/hugetlb.c:1845
hugetlb_no_page mm/hugetlb.c:3543
hugetlb_fault+0x7a1/0x1250 mm/hugetlb.c:3717
follow_hugetlb_page+0x339/0xc70 mm/hugetlb.c:3880
__get_user_pages+0x542/0xf30 mm/gup.c:497
populate_vma_page_range+0xde/0x110 mm/gup.c:919
__mm_populate+0x1c7/0x310 mm/gup.c:969
do_mlock+0x291/0x360 mm/mlock.c:637
SYSC_mlock2 mm/mlock.c:658
SyS_mlock2+0x4b/0x70 mm/mlock.c:648
Dmitry identified a potential memory leak in the routine region_chg,
where a region descriptor is not free'ed on an error path.
However, the root cause for the above memory leak resides in region_del.
In this specific case, a "placeholder" entry is created in region_chg.
The associated page allocation fails, and the placeholder entry is left
in the reserve map. This is "by design" as the entry should be deleted
when the map is released. The bug is in the region_del routine which is
used to delete entries within a specific range (and when the map is
released). region_del did not handle the case where a placeholder entry
exactly matched the start of the range range to be deleted. In this
case, the entry would not be deleted and leaked. The fix is to take
these special placeholder entries into account in region_del.
The region_chg error path leak is also fixed.
Fixes: feba16e25a57 ("mm/hugetlb: add region_del() to delete a specific range of entries")
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: <stable@vger.kernel.org> [4.3+]
Currently at the beginning of hugetlb_fault(), we call huge_pte_offset()
and check whether the obtained *ptep is a migration/hwpoison entry or
not. And if not, then we get to call huge_pte_alloc(). This is racy
because the *ptep could turn into migration/hwpoison entry after the
huge_pte_offset() check. This race results in BUG_ON in
huge_pte_alloc().
We don't have to call huge_pte_alloc() when the huge_pte_offset()
returns non-NULL, so let's fix this bug with moving the code into else
block.
Note that the *ptep could turn into a migration/hwpoison entry after
this block, but that's not a problem because we have another
!pte_present check later (we never go into hugetlb_no_page() in that
case.)
Fixes: 290408d4a250 ("hugetlb: hugepage migration core")
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: <stable@vger.kernel.org> [2.6.36+]
Whoops, I missed removing the kerneldoc comment of the lrucare arg
removed from mem_cgroup_replace_page; but it's a good comment, keep it.
progress
Tetsuo Handa has reported that the system might basically livelock in
OOM condition without triggering the OOM killer.
The issue is caused by internal dependency of the direct reclaim on
vmstat counter updates (via zone_reclaimable) which are performed from
the workqueue context. If all the current workers get assigned to an
allocation request, though, they will be looping inside the allocator
trying to reclaim memory but zone_reclaimable can see stalled numbers so
it will consider a zone reclaimable even though it has been scanned way
too much. WQ concurrency logic will not consider this situation as a
congested workqueue because it relies that worker would have to sleep in
such a situation. This also means that it doesn't try to spawn new
workers or invoke the rescuer thread if the one is assigned to the
queue.
In order to fix this issue we need to do two things. First we have to
let wq concurrency code know that we are in trouble so we have to do a
short sleep. In order to prevent from issues handled by 0e093d99763e
("writeback: do not sleep on the congestion queue if there are no
congested BDIs or if significant congestion is not being encountered in
the current zone") we limit the sleep only to worker threads which are
the ones of the interest anyway.
The second thing to do is to create a dedicated workqueue for vmstat and
mark it WQ_MEM_RECLAIM to note it participates in the reclaim and to
have a spare worker thread for it.
Commit 016c13daa5c9 ("mm, page_alloc: use masks and shifts when
converting GFP flags to migrate types") has swapped MIGRATE_MOVABLE and
MIGRATE_RECLAIMABLE in the enum definition. However, migratetype_names
wasn't updated to reflect that.
As a result, the file /proc/pagetypeinfo shows the counts for Movable as
Reclaimable and vice versa.
Additionally, commit 0aaa29a56e4f ("mm, page_alloc: reserve pageblocks
for high-order atomic allocations on demand") introduced
MIGRATE_HIGHATOMIC, but did not add a letter to distinguish it into
show_migration_types(), so it doesn't appear in the listing of free
areas during page alloc failures or oom kills.
This patch fixes both problems. The atomic reserves will show with a
letter 'H' in the free areas listings.
Fixes: 016c13daa5c9 ("mm, page_alloc: use masks and shifts when converting GFP flags to migrate types")
Fixes: 0aaa29a56e4f ("mm, page_alloc: reserve pageblocks for high-order atomic allocations on demand")
When the memory.high threshold is exceeded, try_charge() schedules a
task_work to reclaim the excess. The reclaim target is set to the
number of pages requested by try_charge().
This is wrong, because try_charge() usually charges more pages than
requested (batch > nr_pages) in order to refill per cpu stocks. As a
result, a process in a cgroup can easily exceed memory.high
significantly when doing a lot of charges w/o returning to userspace
(e.g. reading a file in big chunks).
Fix this issue by assuring that when exceeding memory.high a process
reclaims as many pages as were actually charged (i.e. batch).
When dequeue_huge_page_vma() in alloc_huge_page() fails, we fall back on
alloc_buddy_huge_page() to directly create a hugepage from the buddy
allocator.
In that case, however, if alloc_buddy_huge_page() succeeds we don't
decrement h->resv_huge_pages, which means that successful
hugetlb_fault() returns without releasing the reserve count. As a
result, subsequent hugetlb_fault() might fail despite that there are
still free hugepages.
This patch simply adds decrementing code on that code path.
I reproduced this problem when testing v4.3 kernel in the following situation:
- the test machine/VM is a NUMA system,
- hugepage overcommiting is enabled,
- most of hugepages are allocated and there's only one free hugepage
which is on node 0 (for example),
- another program, which calls set_mempolicy(MPOL_BIND) to bind itself to
node 1, tries to allocate a hugepage,
- the allocation should fail but the reserve count is still hold.
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: <stable@vger.kernel.org> [3.16+]
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fixes from Tejun Heo:
"More change than I'd have liked at this stage. The pids controller
and the changes made to cgroup core to support it introduced and
revealed several important issues.
- Assigning membership to a newly created task and migrating it can
race leading to incorrect accounting. Oleg fixed it by widening
threadgroup synchronization. It looks like we'll be able to merge
it with a different percpu rwsem which is used in fork path making
things simpler and cheaper.
- The recent change to extend cgroup membership to zombies (so that
pid accounting can extend till the pid is actually released) missed
pinning the underlying data structures leading to use-after-free.
Fixed.
- v2 hierarchy was calling subsystem callbacks with the wrong target
cgroup_subsys_state based on the incorrect assumption that they
share the same target. pids is the first controller affected by
this. Subsys callbacks updated so that they can deal with
multi-target migrations"
* 'for-4.4-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup_pids: don't account for the root cgroup
cgroup: fix handling of multi-destination migration from subtree_control enabling
cgroup_freezer: simplify propagation of CGROUP_FROZEN clearing in freezer_attach()
cgroup: pids: kill pids_fork(), simplify pids_can_fork() and pids_cancel_fork()
cgroup: pids: fix race between cgroup_post_fork() and cgroup_migrate()
cgroup: make css_set pin its css's to avoid use-afer-free
cgroup: fix cftype->file_offset handling
The following commit which went into mainline through networking tree
3b13758f51de ("cgroups: Allow dynamically changing net_classid")
conflicts in net/core/netclassid_cgroup.c with the following pending
fix in cgroup/for-4.4-fixes.
1f7dd3e5a6e4 ("cgroup: fix handling of multi-destination migration from subtree_control enabling")
The former separates out update_classid() from cgrp_attach() and
updates it to walk all fds of all tasks in the target css so that it
can be used from both migration and config change paths. The latter
drops @css from cgrp_attach().
Resolve the conflict by making cgrp_attach() call update_classid()
with the css from the first task. We can revive @tset walking in
cgrp_attach() but given that net_cls is v1 only where there always is
only one target css during migration, this is fine.
Cc: Nina Schiff <ninasc@fb.com>
enabling
Consider the following v2 hierarchy.
P0 (+memory) --- P1 (-memory) --- A
\- B
P0 has memory enabled in its subtree_control while P1 doesn't. If
both A and B contain processes, they would belong to the memory css of
P1. Now if memory is enabled on P1's subtree_control, memory csses
should be created on both A and B and A's processes should be moved to
the former and B's processes the latter. IOW, enabling controllers
can cause atomic migrations into different csses.
The core cgroup migration logic has been updated accordingly but the
controller migration methods haven't and still assume that all tasks
migrate to a single target css; furthermore, the methods were fed the
css in which subtree_control was updated which is the parent of the
target csses. pids controller depends on the migration methods to
move charges and this made the controller attribute charges to the
wrong csses often triggering the following warning by driving a
counter negative.
WARNING: CPU: 1 PID: 1 at kernel/cgroup_pids.c:97 pids_cancel.constprop.6+0x31/0x40()
Modules linked in:
CPU: 1 PID: 1 Comm: systemd Not tainted 4.4.0-rc1+ #29
ffffffff81f65382 ffff88007c043b90 ffffffff81551ffc 0000000000000000
ffff88007c043bc8 ffffffff810de202 ffff88007a752000 ffff88007a29ab00
ffff88007c043c80 ffff88007a1d8400 0000000000000001 ffff88007c043bd8
Call Trace:
[<ffffffff81551ffc>] dump_stack+0x4e/0x82
[<ffffffff810de202>] warn_slowpath_common+0x82/0xc0
[<ffffffff810de2fa>] warn_slowpath_null+0x1a/0x20
[<ffffffff8118e031>] pids_cancel.constprop.6+0x31/0x40
[<ffffffff8118e0fd>] pids_can_attach+0x6d/0xf0
[<ffffffff81188a4c>] cgroup_taskset_migrate+0x6c/0x330
[<ffffffff81188e05>] cgroup_migrate+0xf5/0x190
[<ffffffff81189016>] cgroup_attach_task+0x176/0x200
[<ffffffff8118949d>] __cgroup_procs_write+0x2ad/0x460
[<ffffffff81189684>] cgroup_procs_write+0x14/0x20
[<ffffffff811854e5>] cgroup_file_write+0x35/0x1c0
[<ffffffff812e26f1>] kernfs_fop_write+0x141/0x190
[<ffffffff81265f88>] __vfs_write+0x28/0xe0
[<ffffffff812666fc>] vfs_write+0xac/0x1a0
[<ffffffff81267019>] SyS_write+0x49/0xb0
[<ffffffff81bcef32>] entry_SYSCALL_64_fastpath+0x12/0x76
This patch fixes the bug by removing @css parameter from the three
migration methods, ->can_attach, ->cancel_attach() and ->attach() and
updating cgroup_taskset iteration helpers also return the destination
css in addition to the task being migrated. All controllers are
* Controllers which don't care whether there are one or multiple
target csses can be converted trivially. cpu, io, freezer, perf,
netclassid and netprio fall in this category.
* cpuset's current implementation assumes that there's single source
and destination and thus doesn't support v2 hierarchy already. The
only change made by this patchset is how that single destination css
is obtained.
* memory migration path already doesn't do anything on v2. How the
single destination css is obtained is updated and the prep stage of
mem_cgroup_can_attach() is reordered to accomodate the change.
* pids is the only controller which was affected by this bug. It now
correctly handles multi-destination migrations and no longer causes
counter underflow from incorrect accounting.
Reported-and-tested-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Cc: Aleksa Sarai <cyphar@cyphar.com>
There were still a number of references to my old Red Hat email
address in the kernel source. Remove these while keeping the
Red Hat copyright notices intact.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Merge slub bulk allocator updates from Andrew Morton:
"This missed the merge window because I was waiting for some repairs to
come in. Nothing actually uses the bulk allocator yet and the changes
to other code paths are pretty small. And the net guys are waiting
for this so they can start merging the client code"
More comments from Jesper Dangaard Brouer:
"The kmem_cache_alloc_bulk() call, in mm/slub.c, were included in
previous kernel. The present version contains a bug. Vladimir
Davydov noticed it contained a bug, when kernel is compiled with
CONFIG_MEMCG_KMEM (see commit 03ec0ed57ffc: "slub: fix kmem cgroup
bug in kmem_cache_alloc_bulk"). Plus the mem cgroup counterpart in
kmem_cache_free_bulk() were missing (see commit 033745189b1b "slub:
add missing kmem cgroup support to kmem_cache_free_bulk").
I don't consider the fix stable-material because there are no in-tree
users of the API.
But with known bugs (for memcg) I cannot start using the API in the
net-tree"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
slab/slub: adjust kmem_cache_alloc_bulk API
slub: fix kmem cgroup bug in kmem_cache_alloc_bulk
slub: optimize bulk slowpath free by detached freelist
slub: support for bulk free with SLUB freelists
Adjust kmem_cache_alloc_bulk API before we have any real users.
Adjust API to return type 'int' instead of previously type 'bool'. This
is done to allow future extension of the bulk alloc API.
A future extension could be to allow SLUB to stop at a page boundary, when
specified by a flag, and then return the number of objects.
The advantage of this approach, would make it easier to make bulk alloc
run without local IRQs disabled. With an approach of cmpxchg "stealing"
the entire c->freelist or page->freelist. To avoid overshooting we would
stop processing at a slab-page boundary. Else we always end up returning
some objects at the cost of another cmpxchg.
To keep compatible with future users of this API linking against an older
kernel when using the new flag, we need to return the number of allocated
objects with this API change.
Acked-by: Christoph Lameter <cl@linux.com>
Initial implementation missed support for kmem cgroup support in
kmem_cache_free_bulk() call, add this.
If CONFIG_MEMCG_KMEM is not enabled, the compiler should be smart enough
to not add any asm code.
Incoming bulk free objects can belong to different kmem cgroups, and
object free call can happen at a later point outside memcg context. Thus,
we need to keep the orig kmem_cache, to correctly verify if a memcg object
match against its "root_cache" (s->memcg_params.root_cache).
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>
The call slab_pre_alloc_hook() interacts with kmemgc and is not allowed to
be called several times inside the bulk alloc for loop, due to the call to
memcg_kmem_get_cache().
This would result in hitting the VM_BUG_ON in __memcg_kmem_get_cache.
As suggested by Vladimir Davydov, change slab_post_alloc_hook() to be able
to handle an array of objects.
A subtle detail is, loop iterator "i" in slab_post_alloc_hook() must have
same type (size_t) as size argument. This helps the compiler to easier
realize that it can remove the loop, when all debug statements inside loop
evaluates to nothing. Note, this is only an issue because the kernel is
compiled with GCC option: -fno-strict-overflow
In slab_alloc_node() the compiler inlines and optimizes the invocation of
slab_post_alloc_hook(s, flags, 1, &object) by removing the loop and access
object directly.
Reported-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Suggested-by: Vladimir Davydov <vdavydov@virtuozzo.com>
This change focus on improving the speed of object freeing in the
"slowpath" of kmem_cache_free_bulk.
The calls slab_free (fastpath) and __slab_free (slowpath) have been
extended with support for bulk free, which amortize the overhead of
the (locked) cmpxchg_double.
To use the new bulking feature, we build what I call a detached
freelist. The detached freelist takes advantage of three properties:
1) the free function call owns the object that is about to be freed,
thus writing into this memory is synchronization-free.
2) many freelist's can co-exist side-by-side in the same slab-page
each with a separate head pointer.
3) it is the visibility of the head pointer that needs synchronization.
Given these properties, the brilliant part is that the detached
freelist can be constructed without any need for synchronization. The
freelist is constructed directly in the page objects, without any
synchronization needed. The detached freelist is allocated on the
stack of the function call kmem_cache_free_bulk. Thus, the freelist
head pointer is not visible to other CPUs.
All objects in a SLUB freelist must belong to the same slab-page.
Thus, constructing the detached freelist is about matching objects
that belong to the same slab-page. The bulk free array is scanned is
a progressive manor with a limited look-ahead facility.
Kmem debug support is handled in call of slab_free().
Notice kmem_cache_free_bulk no longer need to disable IRQs. This
only slowed down single free bulk with approx 3 cycles.
Performance data:
Benchmarked[1] obj size 256 bytes on CPU i7-4790K @ 4.00GHz
SLUB fastpath single object quick reuse: 47 cycles(tsc) 11.931 ns
To get stable and comparable numbers, the kernel have been booted with
"slab_merge" (this also improve performance for larger bulk sizes).
Performance data, compared against fallback bulking:
bulk - fallback bulk - improvement with this patch
1 - 62 cycles(tsc) 15.662 ns - 49 cycles(tsc) 12.407 ns- improved 21.0%
2 - 55 cycles(tsc) 13.935 ns - 30 cycles(tsc) 7.506 ns - improved 45.5%
3 - 53 cycles(tsc) 13.341 ns - 23 cycles(tsc) 5.865 ns - improved 56.6%
4 - 52 cycles(tsc) 13.081 ns - 20 cycles(tsc) 5.048 ns - improved 61.5%
8 - 50 cycles(tsc) 12.627 ns - 18 cycles(tsc) 4.659 ns - improved 64.0%
16 - 49 cycles(tsc) 12.412 ns - 17 cycles(tsc) 4.495 ns - improved 65.3%
30 - 49 cycles(tsc) 12.484 ns - 18 cycles(tsc) 4.533 ns - improved 63.3%
32 - 50 cycles(tsc) 12.627 ns - 18 cycles(tsc) 4.707 ns - improved 64.0%
34 - 96 cycles(tsc) 24.243 ns - 23 cycles(tsc) 5.976 ns - improved 76.0%
48 - 83 cycles(tsc) 20.818 ns - 21 cycles(tsc) 5.329 ns - improved 74.7%
64 - 74 cycles(tsc) 18.700 ns - 20 cycles(tsc) 5.127 ns - improved 73.0%
128 - 90 cycles(tsc) 22.734 ns - 27 cycles(tsc) 6.833 ns - improved 70.0%
158 - 99 cycles(tsc) 24.776 ns - 30 cycles(tsc) 7.583 ns - improved 69.7%
250 - 104 cycles(tsc) 26.089 ns - 37 cycles(tsc) 9.280 ns - improved 64.4%
Performance data, compared current in-kernel bulking:
bulk - curr in-kernel - improvement with this patch
1 - 46 cycles(tsc) - 49 cycles(tsc) - improved (cycles:-3) -6.5%
2 - 27 cycles(tsc) - 30 cycles(tsc) - improved (cycles:-3) -11.1%
3 - 21 cycles(tsc) - 23 cycles(tsc) - improved (cycles:-2) -9.5%
4 - 18 cycles(tsc) - 20 cycles(tsc) - improved (cycles:-2) -11.1%
8 - 17 cycles(tsc) - 18 cycles(tsc) - improved (cycles:-1) -5.9%
16 - 18 cycles(tsc) - 17 cycles(tsc) - improved (cycles: 1) 5.6%
30 - 18 cycles(tsc) - 18 cycles(tsc) - improved (cycles: 0) 0.0%
32 - 18 cycles(tsc) - 18 cycles(tsc) - improved (cycles: 0) 0.0%
34 - 78 cycles(tsc) - 23 cycles(tsc) - improved (cycles:55) 70.5%
48 - 60 cycles(tsc) - 21 cycles(tsc) - improved (cycles:39) 65.0%
64 - 49 cycles(tsc) - 20 cycles(tsc) - improved (cycles:29) 59.2%
128 - 69 cycles(tsc) - 27 cycles(tsc) - improved (cycles:42) 60.9%
158 - 79 cycles(tsc) - 30 cycles(tsc) - improved (cycles:49) 62.0%
250 - 86 cycles(tsc) - 37 cycles(tsc) - improved (cycles:49) 57.0%
Performance with normal SLUB merging is significantly slower for
larger bulking. This is believed to (primarily) be an effect of not
having to share the per-CPU data-structures, as tuning per-CPU size
can achieve similar performance.
bulk - slab_nomerge - normal SLUB merge
1 - 49 cycles(tsc) - 49 cycles(tsc) - merge slower with cycles:0
2 - 30 cycles(tsc) - 30 cycles(tsc) - merge slower with cycles:0
3 - 23 cycles(tsc) - 23 cycles(tsc) - merge slower with cycles:0
4 - 20 cycles(tsc) - 20 cycles(tsc) - merge slower with cycles:0
8 - 18 cycles(tsc) - 18 cycles(tsc) - merge slower with cycles:0
16 - 17 cycles(tsc) - 17 cycles(tsc) - merge slower with cycles:0
30 - 18 cycles(tsc) - 23 cycles(tsc) - merge slower with cycles:5
32 - 18 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:4
34 - 23 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:-1
48 - 21 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:1
64 - 20 cycles(tsc) - 48 cycles(tsc) - merge slower with cycles:28
128 - 27 cycles(tsc) - 57 cycles(tsc) - merge slower with cycles:30
158 - 30 cycles(tsc) - 59 cycles(tsc) - merge slower with cycles:29
250 - 37 cycles(tsc) - 56 cycles(tsc) - merge slower with cycles:19
Joint work with Alexander Duyck.
[1] https://github.com/netoptimizer/prototype-kernel/blob/master/kernel/mm/slab_bulk_test01.c
[akpm@linux-foundation.org: BUG_ON -> WARN_ON;return]
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
