path: root/mm
2013-08-20vm: add no-mmu vm_iomap_memory() stubLinus Torvalds
commit 3c0b9de6d37a481673e81001c57ca0e410c72346 upstream. I think we could just move the full vm_iomap_memory() function into util.h or similar, but I didn't get any reply from anybody actually using nommu even to this trivial patch, so I'm not going to touch it any more than required. Here's the fairly minimal stub to make the nommu case at least potentially work. It doesn't seem like anybody cares, though. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20futex: Take hugepages into account when generating futex_keyZhang Yi
commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream. The futex_keys of process shared futexes are generated from the page offset, the mapping host and the mapping index of the futex user space address. This should result in an unique identifier for each futex. Though this is not true when futexes are located in different subpages of an hugepage. The reason is, that the mapping index for all those futexes evaluates to the index of the base page of the hugetlbfs mapping. So a futex at offset 0 of the hugepage mapping and another one at offset PAGE_SIZE of the same hugepage mapping have identical futex_keys. This happens because the futex code blindly uses page->index. Steps to reproduce the bug: 1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0 and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs mapping. The mutexes must be initialized as PTHREAD_PROCESS_SHARED because PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as their keys solely depend on the user space address. 2. Lock mutex1 and mutex2 3. Create thread1 and in the thread function lock mutex1, which results in thread1 blocking on the locked mutex1. 4. Create thread2 and in the thread function lock mutex2, which results in thread2 blocking on the locked mutex2. 5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2 still blocks on mutex2 because the futex_key points to mutex1. To solve this issue we need to take the normal page index of the page which contains the futex into account, if the futex is in an hugetlbfs mapping. In other words, we calculate the normal page mapping index of the subpage in the hugetlbfs mapping. Mappings which are not based on hugetlbfs are not affected and still use page->index. Thanks to Mel Gorman who provided a patch for adding proper evaluation functions to the hugetlbfs code to avoid exposing hugetlbfs specific details to the futex code. [ tglx: Massaged changelog ] Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn> Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn> Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn> Reviewed-by: 'Mel Gorman' <mgorman@suse.de> Acked-by: 'Darren Hart' <dvhart@linux.intel.com> Cc: 'Peter Zijlstra' <peterz@infradead.org> Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Galbraith <mgalbraith@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04mm/memory-hotplug: fix lowmem count overflow when offline pagesWanpeng Li
commit cea27eb2a202959783f81254c48c250ddd80e129 upstream. The logic for the memory-remove code fails to correctly account the Total High Memory when a memory block which contains High Memory is offlined as shown in the example below. The following patch fixes it. Before logic memory remove: MemTotal: 7603740 kB MemFree: 6329612 kB Buffers: 94352 kB Cached: 872008 kB SwapCached: 0 kB Active: 626932 kB Inactive: 519216 kB Active(anon): 180776 kB Inactive(anon): 222944 kB Active(file): 446156 kB Inactive(file): 296272 kB Unevictable: 0 kB Mlocked: 0 kB HighTotal: 7294672 kB HighFree: 5704696 kB LowTotal: 309068 kB LowFree: 624916 kB After logic memory remove: MemTotal: 7079452 kB MemFree: 5805976 kB Buffers: 94372 kB Cached: 872000 kB SwapCached: 0 kB Active: 626936 kB Inactive: 519236 kB Active(anon): 180780 kB Inactive(anon): 222944 kB Active(file): 446156 kB Inactive(file): 296292 kB Unevictable: 0 kB Mlocked: 0 kB HighTotal: 7294672 kB HighFree: 5181024 kB LowTotal: 4294752076 kB LowFree: 624952 kB [mhocko@suse.cz: fix CONFIG_HIGHMEM=n build] Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> [2.6.24+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Zhouping Liu <zliu@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20mm: migration: add migrate_entry_wait_huge()Naoya Horiguchi
commit 30dad30922ccc733cfdbfe232090cf674dc374dc upstream. When we have a page fault for the address which is backed by a hugepage under migration, the kernel can't wait correctly and do busy looping on hugepage fault until the migration finishes. As a result, users who try to kick hugepage migration (via soft offlining, for example) occasionally experience long delay or soft lockup. This is because pte_offset_map_lock() can't get a correct migration entry or a correct page table lock for hugepage. This patch introduces migration_entry_wait_huge() to solve this. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20swap: avoid read_swap_cache_async() race to deadlock while waiting on ↵Rafael Aquini
discard I/O completion commit cbab0e4eec299e9059199ebe6daf48730be46d2b upstream. read_swap_cache_async() can race against get_swap_page(), and stumble across a SWAP_HAS_CACHE entry in the swap map whose page wasn't brought into the swapcache yet. This transient swap_map state is expected to be transitory, but the actual placement of discard at scan_swap_map() inserts a wait for I/O completion thus making the thread at read_swap_cache_async() to loop around its -EEXIST case, while the other end at get_swap_page() is scheduled away at scan_swap_map(). This can leave the system deadlocked if the I/O completion happens to be waiting on the CPU waitqueue where read_swap_cache_async() is busy looping and !CONFIG_PREEMPT. This patch introduces a cond_resched() call to make the aforementioned read_swap_cache_async() busy loop condition to bail out when necessary, thus avoiding the subtle race window. Signed-off-by: Rafael Aquini <aquini@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Shaohua Li <shli@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07mm/THP: use pmd_populate() to update the pmd with pgtable_t pointerAneesh Kumar K.V
commit 7c3425123ddfdc5f48e7913ff59d908789712b18 upstream. We should not use set_pmd_at to update pmd_t with pgtable_t pointer. set_pmd_at is used to set pmd with huge pte entries and architectures like ppc64, clear few flags from the pte when saving a new entry. Without this change we observe bad pte errors like below on ppc64 with THP enabled. BUG: Bad page map in process ld mm=0xc000001ee39f4780 pte:7fc3f37848000001 pmd:c000001ec0000000 Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07mm: mmu_notifier: re-fix freed page still mapped in secondary MMUXiao Guangrong
commit d34883d4e35c0a994e91dd847a82b4c9e0c31d83 upstream. Commit 751efd8610d3 ("mmu_notifier_unregister NULL Pointer deref and multiple ->release()") breaks the fix 3ad3d901bbcf ("mm: mmu_notifier: fix freed page still mapped in secondary MMU"). Since hlist_for_each_entry_rcu() is changed now, we can not revert that patch directly, so this patch reverts the commit and simply fix the bug spotted by that patch This bug spotted by commit 751efd8610d3 is: There is a race condition between mmu_notifier_unregister() and __mmu_notifier_release(). Assume two tasks, one calling mmu_notifier_unregister() as a result of a filp_close() ->flush() callout (task A), and the other calling mmu_notifier_release() from an mmput() (task B). A B t1 srcu_read_lock() t2 if (!hlist_unhashed()) t3 srcu_read_unlock() t4 srcu_read_lock() t5 hlist_del_init_rcu() t6 synchronize_srcu() t7 srcu_read_unlock() t8 hlist_del_rcu() <--- NULL pointer deref. This can be fixed by using hlist_del_init_rcu instead of hlist_del_rcu. The another issue spotted in the commit is "multiple ->release() callouts", we needn't care it too much because it is really rare (e.g, can not happen on kvm since mmu-notify is unregistered after exit_mmap()) and the later call of multiple ->release should be fast since all the pages have already been released by the first call. Anyway, this issue should be fixed in a separate patch. -stable suggestions: Any version that has commit 751efd8610d3 need to be backported. I find the oldest version has this commit is 3.0-stable. [akpm@linux-foundation.org: tweak comments] Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Tested-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07mm compaction: fix of improper cache flush in migration codeLeonid Yegoshin
commit c2cc499c5bcf9040a738f49e8051b42078205748 upstream. Page 'new' during MIGRATION can't be flushed with flush_cache_page(). Using flush_cache_page(vma, addr, pfn) is justified only if the page is already placed in process page table, and that is done right after flush_cache_page(). But without it the arch function has no knowledge of process PTE and does nothing. Besides that, flush_cache_page() flushes an application cache page, but the kernel has a different page virtual address and dirtied it. Replace it with flush_dcache_page(new) which is the proper usage. The old page is flushed in try_to_unmap_one() before migration. This bug takes place in Sead3 board with M14Kc MIPS CPU without cache aliasing (but Harvard arch - separate I and D cache) in tight memory environment (128MB) each 1-3days on SOAK test. It fails in cc1 during kernel build (SIGILL, SIGBUS, SIGSEG) if CONFIG_COMPACTION is switched ON. Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com> Cc: Leonid Yegoshin <yegoshin@mips.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Michal Hocko <mhocko@suse.cz> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25vm: add vm_iomap_memory() helper functionLinus Torvalds
commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e upstream. Various drivers end up replicating the code to mmap() their memory buffers into user space, and our core memory remapping function may be very flexible but it is unnecessarily complicated for the common cases to use. Our internal VM uses pfn's ("page frame numbers") which simplifies things for the VM, and allows us to pass physical addresses around in a denser and more efficient format than passing a "phys_addr_t" around, and having to shift it up and down by the page size. But it just means that drivers end up doing that shifting instead at the interface level. It also means that drivers end up mucking around with internal VM things like the vma details (vm_pgoff, vm_start/end) way more than they really need to. So this just exports a function to map a certain physical memory range into user space (using a phys_addr_t based interface that is much more natural for a driver) and hides all the complexity from the driver. Some drivers will still end up tweaking the vm_page_prot details for things like prefetching or cacheability etc, but that's actually relevant to the driver, rather than caring about what the page offset of the mapping is into the particular IO memory region. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-25hugetlbfs: add swap entry check in follow_hugetlb_page()Naoya Horiguchi
commit 9cc3a5bd40067b9a0fbd49199d0780463fc2140f upstream. With applying the previous patch "hugetlbfs: stop setting VM_DONTDUMP in initializing vma(VM_HUGETLB)" to reenable hugepage coredump, if a memory error happens on a hugepage and the affected processes try to access the error hugepage, we hit VM_BUG_ON(atomic_read(&page->_count) <= 0) in get_page(). The reason for this bug is that coredump-related code doesn't recognise "hugepage hwpoison entry" with which a pmd entry is replaced when a memory error occurs on a hugepage. In other words, physical address information is stored in different bit layout between hugepage hwpoison entry and pmd entry, so follow_hugetlb_page() which is called in get_dump_page() returns a wrong page from a given address. The expected behavior is like this: absent is_swap_pte FOLL_DUMP Expected behavior ------------------------------------------------------------------- true false false hugetlb_fault false true false hugetlb_fault false false false return page true false true skip page (to avoid allocation) false true true hugetlb_fault false false true return page With this patch, we can call hugetlb_fault() and take proper actions (we wait for migration entries, fail with VM_FAULT_HWPOISON_LARGE for hwpoisoned entries,) and as the result we can dump all hugepages except for hwpoisoned ones. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12mm: prevent mmap_cache race in find_vma()Jan Stancek
commit b6a9b7f6b1f21735a7456d534dc0e68e61359d2c upstream. find_vma() can be called by multiple threads with read lock held on mm->mmap_sem and any of them can update mm->mmap_cache. Prevent compiler from re-fetching mm->mmap_cache, because other readers could update it in the meantime: thread 1 thread 2 | find_vma() | find_vma() struct vm_area_struct *vma = NULL; | vma = mm->mmap_cache; | if (!(vma && vma->vm_end > addr | && vma->vm_start <= addr)) { | | mm->mmap_cache = vma; return vma; | ^^ compiler may optimize this | local variable out and re-read | mm->mmap_cache | This issue can be reproduced with gcc-4.8.0-1 on s390x by running mallocstress testcase from LTP, which triggers: kernel BUG at mm/rmap.c:1088! Call Trace: ([<000003d100c57000>] 0x3d100c57000) [<000000000023a1c0>] do_wp_page+0x2fc/0xa88 [<000000000023baae>] handle_pte_fault+0x41a/0xac8 [<000000000023d832>] handle_mm_fault+0x17a/0x268 [<000000000060507a>] do_protection_exception+0x1e2/0x394 [<0000000000603a04>] pgm_check_handler+0x138/0x13c [<000003fffcf1f07a>] 0x3fffcf1f07a Last Breaking-Event-Address: [<000000000024755e>] page_add_new_anon_rmap+0xc2/0x168 Thanks to Jakub Jelinek for his insight on gcc and helping to track this down. Signed-off-by: Jan Stancek <jstancek@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: adjust context, indentation] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05mm/hotplug: correctly add new zone to all other nodes' zone listsJiang Liu
commit 08dff7b7d629807dbb1f398c68dd9cd58dd657a1 upstream. When online_pages() is called to add new memory to an empty zone, it rebuilds all zone lists by calling build_all_zonelists(). But there's a bug which prevents the new zone to be added to other nodes' zone lists. online_pages() { build_all_zonelists() ..... node_set_state(zone_to_nid(zone), N_HIGH_MEMORY) } Here the node of the zone is put into N_HIGH_MEMORY state after calling build_all_zonelists(), but build_all_zonelists() only adds zones from nodes in N_HIGH_MEMORY state to the fallback zone lists. build_all_zonelists() ->__build_all_zonelists() ->build_zonelists() ->find_next_best_node() ->for_each_node_state(n, N_HIGH_MEMORY) So memory in the new zone will never be used by other nodes, and it may cause strange behavor when system is under memory pressure. So put node into N_HIGH_MEMORY state before calling build_all_zonelists(). Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <liuj97@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Keping Chen <chenkeping@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28mm/hugetlb: fix total hugetlbfs pages count when using memory overcommit ↵Wanpeng Li
accouting commit d00285884c0892bb1310df96bce6056e9ce9b9d9 upstream. hugetlb_total_pages is used for overcommit calculations but the current implementation considers only the default hugetlb page size (which is either the first defined hugepage size or the one specified by default_hugepagesz kernel boot parameter). If the system is configured for more than one hugepage size, which is possible since commit a137e1cc6d6e ("hugetlbfs: per mount huge page sizes") then the overcommit estimation done by __vm_enough_memory() (resp. shown by meminfo_proc_show) is not precise - there is an impression of more available/allowed memory. This can lead to an unexpected ENOMEM/EFAULT resp. SIGSEGV when memory is accounted. Testcase: boot: hugepagesz=1G hugepages=1 the default overcommit ratio is 50 before patch: egrep 'CommitLimit' /proc/meminfo CommitLimit: 55434168 kB after patch: egrep 'CommitLimit' /proc/meminfo CommitLimit: 54909880 kB [akpm@linux-foundation.org: coding-style tweak] Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28mm/fadvise.c: drain all pagevecs if POSIX_FADV_DONTNEED fails to discard all ↵Mel Gorman
pages commit 67d46b296a1ba1477c0df8ff3bc5e0167a0b0732 upstream. Rob van der Heij reported the following (paraphrased) on private mail. The scenario is that I want to avoid backups to fill up the page cache and purge stuff that is more likely to be used again (this is with s390x Linux on z/VM, so I don't give it as much memory that we don't care anymore). So I have something with LD_PRELOAD that intercepts the close() call (from tar, in this case) and issues a posix_fadvise() just before closing the file. This mostly works, except for small files (less than 14 pages) that remains in page cache after the face. Unfortunately Rob has not had a chance to test this exact patch but the test program below should be reproducing the problem he described. The issue is the per-cpu pagevecs for LRU additions. If the pages are added by one CPU but fadvise() is called on another then the pages remain resident as the invalidate_mapping_pages() only drains the local pagevecs via its call to pagevec_release(). The user-visible effect is that a program that uses fadvise() properly is not obeyed. A possible fix for this is to put the necessary smarts into invalidate_mapping_pages() to globally drain the LRU pagevecs if a pagevec page could not be discarded. The downside with this is that an inode cache shrink would send a global IPI and memory pressure potentially causing global IPI storms is very undesirable. Instead, this patch adds a check during fadvise(POSIX_FADV_DONTNEED) to check if invalidate_mapping_pages() discarded all the requested pages. If a subset of pages are discarded it drains the LRU pagevecs and tries again. If the second attempt fails, it assumes it is due to the pages being mapped, locked or dirty and does not care. With this patch, an application using fadvise() correctly will be obeyed but there is a downside that a malicious application can force the kernel to send global IPIs and increase overhead. If accepted, I would like this to be considered as a -stable candidate. It's not an urgent issue but it's a system call that is not working as advertised which is weak. The following test program demonstrates the problem. It should never report that pages are still resident but will without this patch. It assumes that CPU 0 and 1 exist. int main() { int fd; int pagesize = getpagesize(); ssize_t written = 0, expected; char *buf; unsigned char *vec; int resident, i; cpu_set_t set; /* Prepare a buffer for writing */ expected = FILESIZE_PAGES * pagesize; buf = malloc(expected + 1); if (buf == NULL) { printf("ENOMEM\n"); exit(EXIT_FAILURE); } buf[expected] = 0; memset(buf, 'a', expected); /* Prepare the mincore vec */ vec = malloc(FILESIZE_PAGES); if (vec == NULL) { printf("ENOMEM\n"); exit(EXIT_FAILURE); } /* Bind ourselves to CPU 0 */ CPU_ZERO(&set); CPU_SET(0, &set); if (sched_setaffinity(getpid(), sizeof(set), &set) == -1) { perror("sched_setaffinity"); exit(EXIT_FAILURE); } /* open file, unlink and write buffer */ fd = open("fadvise-test-file", O_CREAT|O_EXCL|O_RDWR); if (fd == -1) { perror("open"); exit(EXIT_FAILURE); } unlink("fadvise-test-file"); while (written < expected) { ssize_t this_write; this_write = write(fd, buf + written, expected - written); if (this_write == -1) { perror("write"); exit(EXIT_FAILURE); } written += this_write; } free(buf); /* * Force ourselves to another CPU. If fadvise only flushes the local * CPUs pagevecs then the fadvise will fail to discard all file pages */ CPU_ZERO(&set); CPU_SET(1, &set); if (sched_setaffinity(getpid(), sizeof(set), &set) == -1) { perror("sched_setaffinity"); exit(EXIT_FAILURE); } /* sync and fadvise to discard the page cache */ fsync(fd); if (posix_fadvise(fd, 0, expected, POSIX_FADV_DONTNEED) == -1) { perror("posix_fadvise"); exit(EXIT_FAILURE); } /* map the file and use mincore to see which parts of it are resident */ buf = mmap(NULL, expected, PROT_READ, MAP_SHARED, fd, 0); if (buf == NULL) { perror("mmap"); exit(EXIT_FAILURE); } if (mincore(buf, expected, vec) == -1) { perror("mincore"); exit(EXIT_FAILURE); } /* Check residency */ for (i = 0, resident = 0; i < FILESIZE_PAGES; i++) { if (vec[i]) resident++; } if (resident != 0) { printf("Nr unexpected pages resident: %d\n", resident); exit(EXIT_FAILURE); } munmap(buf, expected); close(fd); free(vec); exit(EXIT_SUCCESS); } Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Rob van der Heij <rvdheij@gmail.com> Tested-by: Rob van der Heij <rvdheij@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28tmpfs: fix use-after-free of mempolicy objectGreg Thelen
commit 5f00110f7273f9ff04ac69a5f85bb535a4fd0987 upstream. The tmpfs remount logic preserves filesystem mempolicy if the mpol=M option is not specified in the remount request. A new policy can be specified if mpol=M is given. Before this patch remounting an mpol bound tmpfs without specifying mpol= mount option in the remount request would set the filesystem's mempolicy object to a freed mempolicy object. To reproduce the problem boot a DEBUG_PAGEALLOC kernel and run: # mkdir /tmp/x # mount -t tmpfs -o size=100M,mpol=interleave nodev /tmp/x # grep /tmp/x /proc/mounts nodev /tmp/x tmpfs rw,relatime,size=102400k,mpol=interleave:0-3 0 0 # mount -o remount,size=200M nodev /tmp/x # grep /tmp/x /proc/mounts nodev /tmp/x tmpfs rw,relatime,size=204800k,mpol=??? 0 0 # note ? garbage in mpol=... output above # dd if=/dev/zero of=/tmp/x/f count=1 # panic here Panic: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [< (null)>] (null) [...] Oops: 0010 [#1] SMP DEBUG_PAGEALLOC Call Trace: mpol_shared_policy_init+0xa5/0x160 shmem_get_inode+0x209/0x270 shmem_mknod+0x3e/0xf0 shmem_create+0x18/0x20 vfs_create+0xb5/0x130 do_last+0x9a1/0xea0 path_openat+0xb3/0x4d0 do_filp_open+0x42/0xa0 do_sys_open+0xfe/0x1e0 compat_sys_open+0x1b/0x20 cstar_dispatch+0x7/0x1f Non-debug kernels will not crash immediately because referencing the dangling mpol will not cause a fault. Instead the filesystem will reference a freed mempolicy object, which will cause unpredictable behavior. The problem boils down to a dropped mpol reference below if shmem_parse_options() does not allocate a new mpol: config = *sbinfo shmem_parse_options(data, &config, true) mpol_put(sbinfo->mpol) sbinfo->mpol = config.mpol /* BUG: saves unreferenced mpol */ This patch avoids the crash by not releasing the mempolicy if shmem_parse_options() doesn't create a new mpol. How far back does this issue go? I see it in both 2.6.36 and 3.3. I did not look back further. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28mmu_notifier_unregister NULL Pointer deref and multiple ->release() calloutsRobin Holt
commit 751efd8610d3d7d67b7bdf7f62646edea7365dd7 upstream. There is a race condition between mmu_notifier_unregister() and __mmu_notifier_release(). Assume two tasks, one calling mmu_notifier_unregister() as a result of a filp_close() ->flush() callout (task A), and the other calling mmu_notifier_release() from an mmput() (task B). A B t1 srcu_read_lock() t2 if (!hlist_unhashed()) t3 srcu_read_unlock() t4 srcu_read_lock() t5 hlist_del_init_rcu() t6 synchronize_srcu() t7 srcu_read_unlock() t8 hlist_del_rcu() <--- NULL pointer deref. Additionally, the list traversal in __mmu_notifier_release() is not protected by the by the mmu_notifier_mm->hlist_lock which can result in callouts to the ->release() notifier from both mmu_notifier_unregister() and __mmu_notifier_release(). -stable suggestions: The stable trees prior to 3.7.y need commits 21a92735f660 and 70400303ce0c cherry-picked in that order prior to cherry-picking this commit. The 3.7.y tree already has those two commits. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Sagi Grimberg <sagig@mellanox.co.il> Cc: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28mm: mmu_notifier: make the mmu_notifier srcu staticAndrea Arcangeli
commit 70400303ce0c4ced3139499c676d5c79636b0c72 upstream. The variable must be static especially given the variable name. s/RCU/SRCU/ over a few comments. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Sagi Grimberg <sagig@mellanox.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28mm: mmu_notifier: have mmu_notifiers use a global SRCU so they may safely ↵Sagi Grimberg
schedule commit 21a92735f660eaecf69a6f2e777f18463760ec32 upstream. With an RCU based mmu_notifier implementation, any callout to mmu_notifier_invalidate_range_{start,end}() or mmu_notifier_invalidate_page() would not be allowed to call schedule() as that could potentially allow a modification to the mmu_notifier structure while it is currently being used. Since srcu allocs 4 machine words per instance per cpu, we may end up with memory exhaustion if we use srcu per mm. So all mms share a global srcu. Note that during large mmu_notifier activity exit & unregister paths might hang for longer periods, but it is tolerable for current mmu_notifier clients. Signed-off-by: Sagi Grimberg <sagig@mellanox.co.il> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Haggai Eran <haggaie@mellanox.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28mm: fix pageblock bitmap allocationLinus Torvalds
commit 7c45512df987c5619db041b5c9b80d281e26d3db upstream. Commit c060f943d092 ("mm: use aligned zone start for pfn_to_bitidx calculation") fixed out calculation of the index into the pageblock bitmap when a !SPARSEMEM zome was not aligned to pageblock_nr_pages. However, the _allocation_ of that bitmap had never taken this alignment requirement into accout, so depending on the exact size and alignment of the zone, the use of that index could then access past the allocation, resulting in some very subtle memory corruption. This was reported (and bisected) by Ingo Molnar: one of his random config builds would hang with certain very specific kernel command line options. In the meantime, commit c060f943d092 has been marked for stable, so this fix needs to be back-ported to the stable kernels that backported the commit to use the right alignment. Bisected-and-tested-by: Ingo Molnar <mingo@kernel.org> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17thp, memcg: split hugepage for memcg oom on cowDavid Rientjes
commit 1f1d06c34f7675026326cd9f39ff91e4555cf355 upstream. On COW, a new hugepage is allocated and charged to the memcg. If the system is oom or the charge to the memcg fails, however, the fault handler will return VM_FAULT_OOM which results in an oom kill. Instead, it's possible to fallback to splitting the hugepage so that the COW results only in an order-0 page being allocated and charged to the memcg which has a higher liklihood to succeed. This is expensive because the hugepage must be split in the page fault handler, but it is much better than unnecessarily oom killing a process. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <jweiner@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17mm: use aligned zone start for pfn_to_bitidx calculationLaura Abbott
commit c060f943d0929f3e429c5d9522290584f6281d6e upstream. The current calculation in pfn_to_bitidx assumes that (pfn - zone->zone_start_pfn) >> pageblock_order will return the same bit for all pfn in a pageblock. If zone_start_pfn is not aligned to pageblock_nr_pages, this may not always be correct. Consider the following with pageblock order = 10, zone start 2MB: pfn | pfn - zone start | (pfn - zone start) >> page block order ---------------------------------------------------------------- 0x26000 | 0x25e00 | 0x97 0x26100 | 0x25f00 | 0x97 0x26200 | 0x26000 | 0x98 0x26300 | 0x26100 | 0x98 This means that calling {get,set}_pageblock_migratetype on a single page will not set the migratetype for the full block. Fix this by rounding down zone_start_pfn when doing the bitidx calculation. For our use case, the effects of this bug were mostly tied to the fact that CMA allocations would either take a long time or fail to happen. Depending on the driver using CMA, this could result in anything from visual glitches to application failures. Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17mm: compaction: fix echo 1 > compact_memory return error issueJason Liu
commit 7964c06d66c76507d8b6b662bffea770c29ef0ce upstream. when run the folloing command under shell, it will return error sh/$ echo 1 > /proc/sys/vm/compact_memory sh/$ sh: write error: Bad address After strace, I found the following log: ... write(1, "1\n", 2) = 3 write(1, "", 4294967295) = -1 EFAULT (Bad address) write(2, "echo: write error: Bad address\n", 31echo: write error: Bad address ) = 31 This tells system return 3(COMPACT_COMPLETE) after write data to compact_memory. The fix is to make the system just return 0 instead 3(COMPACT_COMPLETE) from sysctl_compaction_handler after compaction_nodes finished. Signed-off-by: Jason Liu <r64343@freescale.com> Suggested-by: David Rientjes <rientjes@google.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11mm: limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPTMichal Hocko
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream. Since commit e303297e6c3a ("mm: extended batches for generic mmu_gather") we are batching pages to be freed until either tlb_next_batch cannot allocate a new batch or we are done. This works just fine most of the time but we can get in troubles with non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY) on large machines where too aggressive batching might lead to soft lockups during process exit path (exit_mmap) because there are no scheduling points down the free_pages_and_swap_cache path and so the freeing can take long enough to trigger the soft lockup. The lockup is harmless except when the system is setup to panic on softlockup which is not that unusual. The simplest way to work around this issue is to limit the maximum number of batches in a single mmu_gather. 10k of collected pages should be safe to prevent from soft lockups (we would have 2ms for one) even if they are all freed without an explicit scheduling point. This patch doesn't add any new explicit scheduling points because it relies on zap_pmd_range during page tables zapping which calls cond_resched per PMD. The following lockup has been reported for 3.0 kernel with a huge process (in order of hundreds gigs but I do know any more details). BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053] Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod Supported: Yes CPU 56 Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7 RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10 RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206 RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80 RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206 RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400 R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100) Call Trace: release_pages+0xc5/0x260 free_pages_and_swap_cache+0x9d/0xc0 tlb_flush_mmu+0x5c/0x80 tlb_finish_mmu+0xe/0x50 exit_mmap+0xbd/0x120 mmput+0x49/0x120 exit_mm+0x122/0x160 do_exit+0x17a/0x430 do_group_exit+0x3d/0xb0 get_signal_to_deliver+0x247/0x480 do_signal+0x71/0x1b0 do_notify_resume+0x98/0xb0 int_signal+0x12/0x17 DWARF2 unwinder stuck at int_signal+0x12/0x17 Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tmpfs mempolicy: fix /proc/mounts corrupting memoryHugh Dickins
commit f2a07f40dbc603c15f8b06e6ec7f768af67b424f upstream. Recently I suggested using "mount -o remount,mpol=local /tmp" in NUMA mempolicy testing. Very nasty. Reading /proc/mounts, /proc/pid/mounts or /proc/pid/mountinfo may then corrupt one bit of kernel memory, often in a page table (causing "Bad swap" or "Bad page map" warning or "Bad pagetable" oops), sometimes in a vm_area_struct or rbnode or somewhere worse. "mpol=prefer" and "mpol=prefer:Node" are equally toxic. Recent NUMA enhancements are not to blame: this dates back to 2.6.35, when commit e17f74af351c "mempolicy: don't call mpol_set_nodemask() when no_context" skipped mpol_parse_str()'s call to mpol_set_nodemask(), which used to initialize v.preferred_node, or set MPOL_F_LOCAL in flags. With slab poisoning, you can then rely on mpol_to_str() to set the bit for node 0x6b6b, probably in the next page above the caller's stack. mpol_parse_str() is only called from shmem_parse_options(): no_context is always true, so call it unused for now, and remove !no_context code. Set v.nodes or v.preferred_node or MPOL_F_LOCAL as mpol_to_str() might expect. Then mpol_to_str() can ignore its no_context argument also, the mpol being appropriately initialized whether contextualized or not. Rename its no_context unused too, and let subsequent patch remove them (that's not needed for stable backporting, which would involve rejects). I don't understand why MPOL_LOCAL is described as a pseudo-policy: it's a reasonable policy which suffers from a confusing implementation in terms of MPOL_PREFERRED with MPOL_F_LOCAL. I believe this would be much more robust if MPOL_LOCAL were recognized in switch statements throughout, MPOL_F_LOCAL deleted, and MPOL_PREFERRED use the (possibly empty) nodes mask like everyone else, instead of its preferred_node variant (I presume an optimization from the days before MPOL_LOCAL). But that would take me too long to get right and fully tested. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17tmpfs: fix shared mempolicy leakMel Gorman
commit 18a2f371f5edf41810f6469cb9be39931ef9deb9 upstream. This fixes a regression in 3.7-rc, which has since gone into stable. Commit 00442ad04a5e ("mempolicy: fix a memory corruption by refcount imbalance in alloc_pages_vma()") changed get_vma_policy() to raise the refcount on a shmem shared mempolicy; whereas shmem_alloc_page() went on expecting alloc_page_vma() to drop the refcount it had acquired. This deserves a rework: but for now fix the leak in shmem_alloc_page(). Hugh: shmem_swapin() did not need a fix, but surely it's clearer to use the same refcounting there as in shmem_alloc_page(), delete its onstack mempolicy, and the strange mpol_cond_copy() and __mpol_cond_copy() - those were invented to let swapin_readahead() make an unknown number of calls to alloc_pages_vma() with one mempolicy; but since 00442ad04a5e, alloc_pages_vma() has kept refcount in balance, so now no problem. Reported-and-tested-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17mm: dmapool: use provided gfp flags for all dma_alloc_coherent() callsMarek Szyprowski
commit 387870f2d6d679746020fa8e25ef786ff338dc98 upstream. dmapool always calls dma_alloc_coherent() with GFP_ATOMIC flag, regardless the flags provided by the caller. This causes excessive pruning of emergency memory pools without any good reason. Additionaly, on ARM architecture any driver which is using dmapools will sooner or later trigger the following error: "ERROR: 256 KiB atomic DMA coherent pool is too small! Please increase it with coherent_pool= kernel parameter!". Increasing the coherent pool size usually doesn't help much and only delays such error, because all GFP_ATOMIC DMA allocations are always served from the special, very limited memory pool. This patch changes the dmapool code to correctly use gfp flags provided by the dmapool caller. Reported-by: Soeren Moch <smoch@web.de> Reported-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Soeren Moch <smoch@web.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-10mm: soft offline: split thp at the beginning of soft_offline_page()Naoya Horiguchi
commit 783657a7dc20e5c0efbc9a09a9dd38e238a723da upstream. When we try to soft-offline a thp tail page, put_page() is called on the tail page unthinkingly and VM_BUG_ON is triggered in put_compound_page(). This patch splits thp before going into the main body of soft-offlining. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Andi Kleen <andi.kleen@intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-10mm/vmemmap: fix wrong use of virt_to_pageJianguo Wu
commit ae64ffcac35de0db628ba9631edf8ff34c5cd7ac upstream. I enable CONFIG_DEBUG_VIRTUAL and CONFIG_SPARSEMEM_VMEMMAP, when doing memory hotremove, there is a kernel BUG at arch/x86/mm/physaddr.c:20. It is caused by free_section_usemap()->virt_to_page(), virt_to_page() is only used for kernel direct mapping address, but sparse-vmemmap uses vmemmap address, so it is going wrong here. ------------[ cut here ]------------ kernel BUG at arch/x86/mm/physaddr.c:20! invalid opcode: 0000 [#1] SMP Modules linked in: acpihp_drv acpihp_slot edd cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf fuse vfat fat loop dm_mod coretemp kvm crc32c_intel ipv6 ixgbe igb iTCO_wdt i7core_edac edac_core pcspkr iTCO_vendor_support ioatdma microcode joydev sr_mod i2c_i801 dca lpc_ich mfd_core mdio tpm_tis i2c_core hid_generic tpm cdrom sg tpm_bios rtc_cmos button ext3 jbd mbcache usbhid hid uhci_hcd ehci_hcd usbcore usb_common sd_mod crc_t10dif processor thermal_sys hwmon scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh_emc scsi_dh ata_generic ata_piix libata megaraid_sas scsi_mod CPU 39 Pid: 6454, comm: sh Not tainted 3.7.0-rc1-acpihp-final+ #45 QCI QSSC-S4R/QSSC-S4R RIP: 0010:[<ffffffff8103c908>] [<ffffffff8103c908>] __phys_addr+0x88/0x90 RSP: 0018:ffff8804440d7c08 EFLAGS: 00010006 RAX: 0000000000000006 RBX: ffffea0012000000 RCX: 000000000000002c ... Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reviewd-by: Wen Congyang <wency@cn.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26mm: bugfix: set current->reclaim_state to NULL while returning from kswapd()Takamori Yamaguchi
commit b0a8cc58e6b9aaae3045752059e5e6260c0b94bc upstream. In kswapd(), set current->reclaim_state to NULL before returning, as current->reclaim_state holds reference to variable on kswapd()'s stack. In rare cases, while returning from kswapd() during memory offlining, __free_slab() and freepages() can access the dangling pointer of current->reclaim_state. Signed-off-by: Takamori Yamaguchi <takamori.yamaguchi@jp.sony.com> Signed-off-by: Aaditya Kumar <aaditya.kumar@ap.sony.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-05mm: fix XFS oops due to dirty pages without buffers on s390Jan Kara
commit ef5d437f71afdf4afdbab99213add99f4b1318fd upstream. On s390 any write to a page (even from kernel itself) sets architecture specific page dirty bit. Thus when a page is written to via buffered write, HW dirty bit gets set and when we later map and unmap the page, page_remove_rmap() finds the dirty bit and calls set_page_dirty(). Dirtying of a page which shouldn't be dirty can cause all sorts of problems to filesystems. The bug we observed in practice is that buffers from the page get freed, so when the page gets later marked as dirty and writeback writes it, XFS crashes due to an assertion BUG_ON(!PagePrivate(page)) in page_buffers() called from xfs_count_page_state(). Similar problem can also happen when zero_user_segment() call from xfs_vm_writepage() (or block_write_full_page() for that matter) set the hardware dirty bit during writeback, later buffers get freed, and then page unmapped. Fix the issue by ignoring s390 HW dirty bit for page cache pages of mappings with mapping_cap_account_dirty(). This is safe because for such mappings when a page gets marked as writeable in PTE it is also marked dirty in do_wp_page() or do_page_fault(). When the dirty bit is cleared by clear_page_dirty_for_io(), the page gets writeprotected in page_mkclean(). So pagecache page is writeable if and only if it is dirty. Thanks to Hugh Dickins for pointing out mapping has to have mapping_cap_account_dirty() for things to work and proposing a cleaned up variant of the patch. The patch has survived about two hours of running fsx-linux on tmpfs while heavily swapping and several days of running on out build machines where the original problem was triggered. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21tmpfs,ceph,gfs2,isofs,reiserfs,xfs: fix fh_len checkingHugh Dickins
commit 35c2a7f4908d404c9124c2efc6ada4640ca4d5d5 upstream. Fuzzing with trinity oopsed on the 1st instruction of shmem_fh_to_dentry(), u64 inum = fid->raw[2]; which is unhelpfully reported as at the end of shmem_alloc_inode(): BUG: unable to handle kernel paging request at ffff880061cd3000 IP: [<ffffffff812190d0>] shmem_alloc_inode+0x40/0x40 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Call Trace: [<ffffffff81488649>] ? exportfs_decode_fh+0x79/0x2d0 [<ffffffff812d77c3>] do_handle_open+0x163/0x2c0 [<ffffffff812d792c>] sys_open_by_handle_at+0xc/0x10 [<ffffffff83a5f3f8>] tracesys+0xe1/0xe6 Right, tmpfs is being stupid to access fid->raw[2] before validating that fh_len includes it: the buffer kmalloc'ed by do_sys_name_to_handle() may fall at the end of a page, and the next page not be present. But some other filesystems (ceph, gfs2, isofs, reiserfs, xfs) are being careless about fh_len too, in fh_to_dentry() and/or fh_to_parent(), and could oops in the same way: add the missing fh_len checks to those. Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Sage Weil <sage@inktank.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mempolicy: fix a memory corruption by refcount imbalance in alloc_pages_vma()Mel Gorman
commit 00442ad04a5eac08a98255697c510e708f6082e2 upstream. Commit cc9a6c877661 ("cpuset: mm: reduce large amounts of memory barrier related damage v3") introduced a potential memory corruption. shmem_alloc_page() uses a pseudo vma and it has one significant unique combination, vma->vm_ops=NULL and vma->policy->flags & MPOL_F_SHARED. get_vma_policy() does NOT increase a policy ref when vma->vm_ops=NULL and mpol_cond_put() DOES decrease a policy ref when a policy has MPOL_F_SHARED. Therefore, when a cpuset update race occurs, alloc_pages_vma() falls in 'goto retry_cpuset' path, decrements the reference count and frees the policy prematurely. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mempolicy: fix refcount leak in mpol_set_shared_policy()KOSAKI Motohiro
commit 63f74ca21f1fad36d075e063f06dcc6d39fe86b2 upstream. When shared_policy_replace() fails to allocate new->policy is not freed correctly by mpol_set_shared_policy(). The problem is that shared mempolicy code directly call kmem_cache_free() in multiple places where it is easy to make a mistake. This patch creates an sp_free wrapper function and uses it. The bug was introduced pre-git age (IOW, before 2.6.12-rc2). [mgorman@suse.de: Editted changelog] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mempolicy: fix a race in shared_policy_replace()Mel Gorman
commit b22d127a39ddd10d93deee3d96e643657ad53a49 upstream. shared_policy_replace() use of sp_alloc() is unsafe. 1) sp_node cannot be dereferenced if sp->lock is not held and 2) another thread can modify sp_node between spin_unlock for allocating a new sp node and next spin_lock. The bug was introduced before 2.6.12-rc2. Kosaki's original patch for this problem was to allocate an sp node and policy within shared_policy_replace and initialise it when the lock is reacquired. I was not keen on this approach because it partially duplicates sp_alloc(). As the paths were sp->lock is taken are not that performance critical this patch converts sp->lock to sp->mutex so it can sleep when calling sp_alloc(). [kosaki.motohiro@jp.fujitsu.com: Original patch] Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mempolicy: remove mempolicy sharingKOSAKI Motohiro
commit 869833f2c5c6e4dd09a5378cfc665ffb4615e5d2 upstream. Dave Jones' system call fuzz testing tool "trinity" triggered the following bug error with slab debugging enabled ============================================================================= BUG numa_policy (Not tainted): Poison overwritten ----------------------------------------------------------------------------- INFO: 0xffff880146498250-0xffff880146498250. First byte 0x6a instead of 0x6b INFO: Allocated in mpol_new+0xa3/0x140 age=46310 cpu=6 pid=32154 __slab_alloc+0x3d3/0x445 kmem_cache_alloc+0x29d/0x2b0 mpol_new+0xa3/0x140 sys_mbind+0x142/0x620 system_call_fastpath+0x16/0x1b INFO: Freed in __mpol_put+0x27/0x30 age=46268 cpu=6 pid=32154 __slab_free+0x2e/0x1de kmem_cache_free+0x25a/0x260 __mpol_put+0x27/0x30 remove_vma+0x68/0x90 exit_mmap+0x118/0x140 mmput+0x73/0x110 exit_mm+0x108/0x130 do_exit+0x162/0xb90 do_group_exit+0x4f/0xc0 sys_exit_group+0x17/0x20 system_call_fastpath+0x16/0x1b INFO: Slab 0xffffea0005192600 objects=27 used=27 fp=0x (null) flags=0x20000000004080 INFO: Object 0xffff880146498250 @offset=592 fp=0xffff88014649b9d0 The problem is that the structure is being prematurely freed due to a reference count imbalance. In the following case mbind(addr, len) should replace the memory policies of both vma1 and vma2 and thus they will become to share the same mempolicy and the new mempolicy will have the MPOL_F_SHARED flag. +-------------------+-------------------+ | vma1 | vma2(shmem) | +-------------------+-------------------+ | | addr addr+len alloc_pages_vma() uses get_vma_policy() and mpol_cond_put() pair for maintaining the mempolicy reference count. The current rule is that get_vma_policy() only increments refcount for shmem VMA and mpol_conf_put() only decrements refcount if the policy has MPOL_F_SHARED. In above case, vma1 is not shmem vma and vma->policy has MPOL_F_SHARED! The reference count will be decreased even though was not increased whenever alloc_page_vma() is called. This has been broken since commit [52cd3b07: mempolicy: rework mempolicy Reference Counting] in 2008. There is another serious bug with the sharing of memory policies. Currently, mempolicy rebind logic (it is called from cpuset rebinding) ignores a refcount of mempolicy and override it forcibly. Thus, any mempolicy sharing may cause mempolicy corruption. The bug was introduced by commit [68860ec1: cpusets: automatic numa mempolicy rebinding]. Ideally, the shared policy handling would be rewritten to either properly handle COW of the policy structures or at least reference count MPOL_F_SHARED based exclusively on information within the policy. However, this patch takes the easier approach of disabling any policy sharing between VMAs. Each new range allocated with sp_alloc will allocate a new policy, set the reference count to 1 and drop the reference count of the old policy. This increases the memory footprint but is not expected to be a major problem as mbind() is unlikely to be used for fine-grained ranges. It is also inefficient because it means we allocate a new policy even in cases where mbind_range() could use the new_policy passed to it. However, it is more straight-forward and the change should be invisible to the user. [mgorman@suse.de: Edited changelog] Reported-by: Dave Jones <davej@redhat.com> Cc: Christoph Lameter <cl@linux.com> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13revert "mm: mempolicy: Let vma_merge and vma_split handle vma->vm_policy ↵KOSAKI Motohiro
linkages" commit 8d34694c1abf29df1f3c7317936b7e3e2e308d9b upstream. Commit 05f144a0d5c2 ("mm: mempolicy: Let vma_merge and vma_split handle vma->vm_policy linkages") removed vma->vm_policy updates code but it is the purpose of mbind_range(). Now, mbind_range() is virtually a no-op and while it does not allow memory corruption it is not the right fix. This patch is a revert. [mgorman@suse.de: Edited changelog] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Christoph Lameter <cl@linux.com> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mm: fix invalidate_complete_page2() lock orderingHugh Dickins
commit ec4d9f626d5908b6052c2973f37992f1db52e967 upstream. In fuzzing with trinity, lockdep protested "possible irq lock inversion dependency detected" when isolate_lru_page() reenabled interrupts while still holding the supposedly irq-safe tree_lock: invalidate_inode_pages2 invalidate_complete_page2 spin_lock_irq(&mapping->tree_lock) clear_page_mlock isolate_lru_page spin_unlock_irq(&zone->lru_lock) isolate_lru_page() is correct to enable interrupts unconditionally: invalidate_complete_page2() is incorrect to call clear_page_mlock() while holding tree_lock, which is supposed to nest inside lru_lock. Both truncate_complete_page() and invalidate_complete_page() call clear_page_mlock() before taking tree_lock to remove page from radix_tree. I guess invalidate_complete_page2() preferred to test PageDirty (again) under tree_lock before committing to the munlock; but since the page has already been unmapped, its state is already somewhat inconsistent, and no worse if clear_page_mlock() moved up. Reported-by: Sasha Levin <levinsasha928@gmail.com> Deciphered-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michel Lespinasse <walken@google.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02memory hotplug: fix section info double registration bugqiuxishi
commit f14851af0ebb32745c6c5a2e400aa0549f9d20df upstream. There may be a bug when registering section info. For example, on my Itanium platform, the pfn range of node0 includes the other nodes, so other nodes' section info will be double registered, and memmap's page count will equal to 3. node0: start_pfn=0x100, spanned_pfn=0x20fb00, present_pfn=0x7f8a3, => 0x000100-0x20fc00 node1: start_pfn=0x80000, spanned_pfn=0x80000, present_pfn=0x80000, => 0x080000-0x100000 node2: start_pfn=0x100000, spanned_pfn=0x80000, present_pfn=0x80000, => 0x100000-0x180000 node3: start_pfn=0x180000, spanned_pfn=0x80000, present_pfn=0x80000, => 0x180000-0x200000 free_all_bootmem_node() register_page_bootmem_info_node() register_page_bootmem_info_section() When hot remove memory, we can't free the memmap's page because page_count() is 2 after put_page_bootmem(). sparse_remove_one_section() free_section_usemap() free_map_bootmem() put_page_bootmem() [akpm@linux-foundation.org: add code comment] Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02mm/page_alloc: fix the page address of higher page's buddy calculationLi Haifeng
commit 0ba8f2d59304dfe69b59c034de723ad80f7ab9ac upstream. The heuristic method for buddy has been introduced since commit 43506fad21ca ("mm/page_alloc.c: simplify calculation of combined index of adjacent buddy lists"). But the page address of higher page's buddy was wrongly calculated, which will lead page_is_buddy to fail for ever. IOW, the heuristic method would be disabled with the wrong page address of higher page's buddy. Calculating the page address of higher page's buddy should be based higher_page with the offset between index of higher page and index of higher page's buddy. Signed-off-by: Haifeng Li <omycle@gmail.com> Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KyongHo Cho <pullip.cho@samsung.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-14Remove user-triggerable BUG from mpol_to_strDave Jones
commit 80de7c3138ee9fd86a98696fd2cf7ad89b995d0a upstream. Trivially triggerable, found by trinity: kernel BUG at mm/mempolicy.c:2546! Process trinity-child2 (pid: 23988, threadinfo ffff88010197e000, task ffff88007821a670) Call Trace: show_numa_map+0xd5/0x450 show_pid_numa_map+0x13/0x20 traverse+0xf2/0x230 seq_read+0x34b/0x3e0 vfs_read+0xac/0x180 sys_pread64+0xa2/0xc0 system_call_fastpath+0x1a/0x1f RIP: mpol_to_str+0x156/0x360 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mm: hugetlbfs: close race during teardown of hugetlbfs shared page tablesMel Gorman
commit d833352a4338dc31295ed832a30c9ccff5c7a183 upstream. If a process creates a large hugetlbfs mapping that is eligible for page table sharing and forks heavily with children some of whom fault and others which destroy the mapping then it is possible for page tables to get corrupted. Some teardowns of the mapping encounter a "bad pmd" and output a message to the kernel log. The final teardown will trigger a BUG_ON in mm/filemap.c. This was reproduced in 3.4 but is known to have existed for a long time and goes back at least as far as 2.6.37. It was probably was introduced in 2.6.20 by [39dde65c: shared page table for hugetlb page]. The messages look like this; [ ..........] Lots of bad pmd messages followed by this [ 127.164256] mm/memory.c:391: bad pmd ffff880412e04fe8(80000003de4000e7). [ 127.164257] mm/memory.c:391: bad pmd ffff880412e04ff0(80000003de6000e7). [ 127.164258] mm/memory.c:391: bad pmd ffff880412e04ff8(80000003de0000e7). [ 127.186778] ------------[ cut here ]------------ [ 127.186781] kernel BUG at mm/filemap.c:134! [ 127.186782] invalid opcode: 0000 [#1] SMP [ 127.186783] CPU 7 [ 127.186784] Modules linked in: af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf ext3 jbd dm_mod coretemp crc32c_intel usb_storage ghash_clmulni_intel aesni_intel i2c_i801 r8169 mii uas sr_mod cdrom sg iTCO_wdt iTCO_vendor_support shpchp serio_raw cryptd aes_x86_64 e1000e pci_hotplug dcdbas aes_generic container microcode ext4 mbcache jbd2 crc16 sd_mod crc_t10dif i915 drm_kms_helper drm i2c_algo_bit ehci_hcd ahci libahci usbcore rtc_cmos usb_common button i2c_core intel_agp video intel_gtt fan processor thermal thermal_sys hwmon ata_generic pata_atiixp libata scsi_mod [ 127.186801] [ 127.186802] Pid: 9017, comm: hugetlbfs-test Not tainted 3.4.0-autobuild #53 Dell Inc. OptiPlex 990/06D7TR [ 127.186804] RIP: 0010:[<ffffffff810ed6ce>] [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160 [ 127.186809] RSP: 0000:ffff8804144b5c08 EFLAGS: 00010002 [ 127.186810] RAX: 0000000000000001 RBX: ffffea000a5c9000 RCX: 00000000ffffffc0 [ 127.186811] RDX: 0000000000000000 RSI: 0000000000000009 RDI: ffff88042dfdad00 [ 127.186812] RBP: ffff8804144b5c18 R08: 0000000000000009 R09: 0000000000000003 [ 127.186813] R10: 0000000000000000 R11: 000000000000002d R12: ffff880412ff83d8 [ 127.186814] R13: ffff880412ff83d8 R14: 0000000000000000 R15: ffff880412ff83d8 [ 127.186815] FS: 00007fe18ed2c700(0000) GS:ffff88042dce0000(0000) knlGS:0000000000000000 [ 127.186816] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 127.186817] CR2: 00007fe340000503 CR3: 0000000417a14000 CR4: 00000000000407e0 [ 127.186818] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 127.186819] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 127.186820] Process hugetlbfs-test (pid: 9017, threadinfo ffff8804144b4000, task ffff880417f803c0) [ 127.186821] Stack: [ 127.186822] ffffea000a5c9000 0000000000000000 ffff8804144b5c48 ffffffff810ed83b [ 127.186824] ffff8804144b5c48 000000000000138a 0000000000001387 ffff8804144b5c98 [ 127.186825] ffff8804144b5d48 ffffffff811bc925 ffff8804144b5cb8 0000000000000000 [ 127.186827] Call Trace: [ 127.186829] [<ffffffff810ed83b>] delete_from_page_cache+0x3b/0x80 [ 127.186832] [<ffffffff811bc925>] truncate_hugepages+0x115/0x220 [ 127.186834] [<ffffffff811bca43>] hugetlbfs_evict_inode+0x13/0x30 [ 127.186837] [<ffffffff811655c7>] evict+0xa7/0x1b0 [ 127.186839] [<ffffffff811657a3>] iput_final+0xd3/0x1f0 [ 127.186840] [<ffffffff811658f9>] iput+0x39/0x50 [ 127.186842] [<ffffffff81162708>] d_kill+0xf8/0x130 [ 127.186843] [<ffffffff81162812>] dput+0xd2/0x1a0 [ 127.186845] [<ffffffff8114e2d0>] __fput+0x170/0x230 [ 127.186848] [<ffffffff81236e0e>] ? rb_erase+0xce/0x150 [ 127.186849] [<ffffffff8114e3ad>] fput+0x1d/0x30 [ 127.186851] [<ffffffff81117db7>] remove_vma+0x37/0x80 [ 127.186853] [<ffffffff81119182>] do_munmap+0x2d2/0x360 [ 127.186855] [<ffffffff811cc639>] sys_shmdt+0xc9/0x170 [ 127.186857] [<ffffffff81410a39>] system_call_fastpath+0x16/0x1b [ 127.186858] Code: 0f 1f 44 00 00 48 8b 43 08 48 8b 00 48 8b 40 28 8b b0 40 03 00 00 85 f6 0f 88 df fe ff ff 48 89 df e8 e7 cb 05 00 e9 d2 fe ff ff <0f> 0b 55 83 e2 fd 48 89 e5 48 83 ec 30 48 89 5d d8 4c 89 65 e0 [ 127.186868] RIP [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160 [ 127.186870] RSP <ffff8804144b5c08> [ 127.186871] ---[ end trace 7cbac5d1db69f426 ]--- The bug is a race and not always easy to reproduce. To reproduce it I was doing the following on a single socket I7-based machine with 16G of RAM. $ hugeadm --pool-pages-max DEFAULT:13G $ echo $((18*1048576*1024)) > /proc/sys/kernel/shmmax $ echo $((18*1048576*1024)) > /proc/sys/kernel/shmall $ for i in `seq 1 9000`; do ./hugetlbfs-test; done On my particular machine, it usually triggers within 10 minutes but enabling debug options can change the timing such that it never hits. Once the bug is triggered, the machine is in trouble and needs to be rebooted. The machine will respond but processes accessing proc like "ps aux" will hang due to the BUG_ON. shutdown will also hang and needs a hard reset or a sysrq-b. The basic problem is a race between page table sharing and teardown. For the most part page table sharing depends on i_mmap_mutex. In some cases, it is also taking the mm->page_table_lock for the PTE updates but with shared page tables, it is the i_mmap_mutex that is more important. Unfortunately it appears to be also insufficient. Consider the following situation Process A Process B --------- --------- hugetlb_fault shmdt LockWrite(mmap_sem) do_munmap unmap_region unmap_vmas unmap_single_vma unmap_hugepage_range Lock(i_mmap_mutex) Lock(mm->page_table_lock) huge_pmd_unshare/unmap tables <--- (1) Unlock(mm->page_table_lock) Unlock(i_mmap_mutex) huge_pte_alloc ... Lock(i_mmap_mutex) ... vma_prio_walk, find svma, spte ... Lock(mm->page_table_lock) ... share spte ... Unlock(mm->page_table_lock) ... Unlock(i_mmap_mutex) ... hugetlb_no_page <--- (2) free_pgtables unlink_file_vma hugetlb_free_pgd_range remove_vma_list In this scenario, it is possible for Process A to share page tables with Process B that is trying to tear them down. The i_mmap_mutex on its own does not prevent Process A walking Process B's page tables. At (1) above, the page tables are not shared yet so it unmaps the PMDs. Process A sets up page table sharing and at (2) faults a new entry. Process B then trips up on it in free_pgtables. This patch fixes the problem by adding a new function __unmap_hugepage_range_final that is only called when the VMA is about to be destroyed. This function clears VM_MAYSHARE during unmap_hugepage_range() under the i_mmap_mutex. This makes the VMA ineligible for sharing and avoids the race. Superficially this looks like it would then be vunerable to truncate and madvise issues but hugetlbfs has its own truncate handlers so does not use unmap_mapping_range() and does not support madvise(DONTNEED). This should be treated as a -stable candidate if it is merged. Test program is as follows. The test case was mostly written by Michal Hocko with a few minor changes to reproduce this bug. ==== CUT HERE ==== static size_t huge_page_size = (2UL << 20); static size_t nr_huge_page_A = 512; static size_t nr_huge_page_B = 5632; unsigned int get_random(unsigned int max) { struct timeval tv; gettimeofday(&tv, NULL); srandom(tv.tv_usec); return random() % max; } static void play(void *addr, size_t size) { unsigned char *start = addr, *end = start + size, *a; start += get_random(size/2); /* we could itterate on huge pages but let's give it more time. */ for (a = start; a < end; a += 4096) *a = 0; } int main(int argc, char **argv) { key_t key = IPC_PRIVATE; size_t sizeA = nr_huge_page_A * huge_page_size; size_t sizeB = nr_huge_page_B * huge_page_size; int shmidA, shmidB; void *addrA = NULL, *addrB = NULL; int nr_children = 300, n = 0; if ((shmidA = shmget(key, sizeA, IPC_CREAT|SHM_HUGETLB|0660)) == -1) { perror("shmget:"); return 1; } if ((addrA = shmat(shmidA, addrA, SHM_R|SHM_W)) == (void *)-1UL) { perror("shmat"); return 1; } if ((shmidB = shmget(key, sizeB, IPC_CREAT|SHM_HUGETLB|0660)) == -1) { perror("shmget:"); return 1; } if ((addrB = shmat(shmidB, addrB, SHM_R|SHM_W)) == (void *)-1UL) { perror("shmat"); return 1; } fork_child: switch(fork()) { case 0: switch (n%3) { case 0: play(addrA, sizeA); break; case 1: play(addrB, sizeB); break; case 2: break; } break; case -1: perror("fork:"); break; default: if (++n < nr_children) goto fork_child; play(addrA, sizeA); break; } shmdt(addrA); shmdt(addrB); do { wait(NULL); } while (--n > 0); shmctl(shmidA, IPC_RMID, NULL); shmctl(shmidB, IPC_RMID, NULL); return 0; } [akpm@linux-foundation.org: name the declaration's args, fix CONFIG_HUGETLBFS=n build] Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mm: mmu_notifier: fix freed page still mapped in secondary MMUXiao Guangrong
commit 3ad3d901bbcfb15a5e4690e55350db0899095a68 upstream. mmu_notifier_release() is called when the process is exiting. It will delete all the mmu notifiers. But at this time the page belonging to the process is still present in page tables and is present on the LRU list, so this race will happen: CPU 0 CPU 1 mmu_notifier_release: try_to_unmap: hlist_del_init_rcu(&mn->hlist); ptep_clear_flush_notify: mmu nofifler not found free page !!!!!! /* * At the point, the page has been * freed, but it is still mapped in * the secondary MMU. */ mn->ops->release(mn, mm); Then the box is not stable and sometimes we can get this bug: [ 738.075923] BUG: Bad page state in process migrate-perf pfn:03bec [ 738.075931] page:ffffea00000efb00 count:0 mapcount:0 mapping: (null) index:0x8076 [ 738.075936] page flags: 0x20000000000014(referenced|dirty) The same issue is present in mmu_notifier_unregister(). We can call ->release before deleting the notifier to ensure the page has been unmapped from the secondary MMU before it is freed. Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mm: fix wrong argument of migrate_huge_pages() in soft_offline_huge_page()Joonsoo Kim
commit dc32f63453f56d07a1073a697dcd843dd3098c09 upstream. Commit a6bc32b89922 ("mm: compaction: introduce sync-light migration for use by compaction") changed the declaration of migrate_pages() and migrate_huge_pages(). But it missed changing the argument of migrate_huge_pages() in soft_offline_huge_page(). In this case, we should call migrate_huge_pages() with MIGRATE_SYNC. Additionally, there is a mismatch between type the of argument and the function declaration for migrate_pages(). Signed-off-by: Joonsoo Kim <js1304@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Mel Gorman <mgorman@suse.de> Acked-by: David Rientjes <rientjes@google.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01vmscan: fix initial shrinker size handlingKonstantin Khlebnikov
commit 635697c663f38106063d5659f0cf2e45afcd4bb5 upstream. Stable note: The commit [acf92b48: vmscan: shrinker->nr updates race and go wrong] aimed to reduce excessive reclaim of slab objects but had bug in how it treated shrinker functions that returned -1. A shrinker function can return -1, means that it cannot do anything without a risk of deadlock. For example prune_super() does this if it cannot grab a superblock refrence, even if nr_to_scan=0. Currently we interpret this -1 as a ULONG_MAX size shrinker and evaluate `total_scan' according to this. So the next time around this shrinker can cause really big pressure. Let's skip such shrinkers instead. Also make total_scan signed, otherwise the check (total_scan < 0) below never works. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm/hugetlb: fix warning in alloc_huge_page/dequeue_huge_page_vmaKonstantin Khlebnikov
commit b1c12cbcd0a02527c180a862e8971e249d3b347d upstream. Stable note: Not tracked in Bugzilla. [get|put]_mems_allowed() is extremely expensive and severely impacted page allocator performance. This is part of a series of patches that reduce page allocator overhead. Fix a gcc warning (and bug?) introduced in cc9a6c877 ("cpuset: mm: reduce large amounts of memory barrier related damage v3") Local variable "page" can be uninitialized if the nodemask from vma policy does not intersects with nodemask from cpuset. Even if it doesn't happens it is better to initialize this variable explicitly than to introduce a kernel oops in a weird corner case. mm/hugetlb.c: In function `alloc_huge_page': mm/hugetlb.c:1135:5: warning: `page' may be used uninitialized in this function Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01cpuset: mm: reduce large amounts of memory barrier related damage v3Mel Gorman
commit cc9a6c8776615f9c194ccf0b63a0aa5628235545 upstream. Stable note: Not tracked in Bugzilla. [get|put]_mems_allowed() is extremely expensive and severely impacted page allocator performance. This is part of a series of patches that reduce page allocator overhead. Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when changing cpuset's mems") wins a super prize for the largest number of memory barriers entered into fast paths for one commit. [get|put]_mems_allowed is incredibly heavy with pairs of full memory barriers inserted into a number of hot paths. This was detected while investigating at large page allocator slowdown introduced some time after 2.6.32. The largest portion of this overhead was shown by oprofile to be at an mfence introduced by this commit into the page allocator hot path. For extra style points, the commit introduced the use of yield() in an implementation of what looks like a spinning mutex. This patch replaces the full memory barriers on both read and write sides with a sequence counter with just read barriers on the fast path side. This is much cheaper on some architectures, including x86. The main bulk of the patch is the retry logic if the nodemask changes in a manner that can cause a false failure. While updating the nodemask, a check is made to see if a false failure is a risk. If it is, the sequence number gets bumped and parallel allocators will briefly stall while the nodemask update takes place. In a page fault test microbenchmark, oprofile samples from __alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The actual results were 3.3.0-rc3 3.3.0-rc3 rc3-vanilla nobarrier-v2r1 Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%) Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%) Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%) Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%) Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%) Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%) Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%) Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%) Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%) Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%) Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%) Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%) Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%) Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%) Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%) MMTests Statistics: duration Sys Time Running Test (seconds) 135.68 132.17 User+Sys Time Running Test (seconds) 164.2 160.13 Total Elapsed Time (seconds) 123.46 120.87 The overall improvement is small but the System CPU time is much improved and roughly in correlation to what oprofile reported (these performance figures are without profiling so skew is expected). The actual number of page faults is noticeably improved. For benchmarks like kernel builds, the overall benefit is marginal but the system CPU time is slightly reduced. To test the actual bug the commit fixed I opened two terminals. The first ran within a cpuset and continually ran a small program that faulted 100M of anonymous data. In a second window, the nodemask of the cpuset was continually randomised in a loop. Without the commit, the program would fail every so often (usually within 10 seconds) and obviously with the commit everything worked fine. With this patch applied, it also worked fine so the fix should be functionally equivalent. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: vmscan: convert global reclaim to per-memcg LRU listsJohannes Weiner
commit b95a2f2d486d0d768a92879c023a03757b9c7e58 upstream - WARNING: this is a substitute patch. Stable note: Not tracked in Bugzilla. This is a partial backport of an upstream commit addressing a completely different issue that accidentally contained an important fix. The workload this patch helps was memcached when IO is started in the background. memcached should stay resident but without this patch it gets swapped. Sometimes this manifests as a drop in throughput but mostly it was observed through /proc/vmstat. Commit [246e87a9: memcg: fix get_scan_count() for small targets] was meant to fix a problem whereby small scan targets on memcg were ignored causing priority to raise too sharply. It forced scanning to take place if the target was small, memcg or kswapd. From the time it was introduced it caused excessive reclaim by kswapd with workloads being pushed to swap that previously would have stayed resident. This was accidentally fixed in commit [b95a2f2d: mm: vmscan: convert global reclaim to per-memcg LRU lists] by making it harder for kswapd to force scan small targets but that patchset is not suitable for backporting. This was later changed again by commit [90126375: mm/vmscan: push lruvec pointer into get_scan_count()] into a format that looks like it would be a straight-forward backport but there is a subtle difference due to the use of lruvecs. The impact of the accidental fix is to make it harder for kswapd to force scan small targets by taking zone->all_unreclaimable into account. This patch is the closest equivalent available based on what is backported. Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: test PageSwapBacked in lumpy reclaimHugh Dickins
commit 043bcbe5ec51e0478ef2b44acef17193e01d7f70 upstream. Stable note: Not tracked in Bugzilla. There were reports of shared mapped pages being unfairly reclaimed in comparison to older kernels. This is being addressed over time. Even though the subject refers to lumpy reclaim, it impacts compaction as well. Lumpy reclaim does well to stop at a PageAnon when there's no swap, but better is to stop at any PageSwapBacked, which includes shmem/tmpfs too. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-08-01mm/vmscan.c: consider swap space when deciding whether to continue reclaimMinchan Kim
commit 86cfd3a45042ab242d47f3935a02811a402beab6 upstream. Stable note: Not tracked in Bugzilla. This patch reduces kswapd CPU usage on swapless systems with high anonymous memory usage. It's pointless to continue reclaiming when we have no swap space and lots of anon pages in the inactive list. Without this patch, it is possible when swap is disabled to continue trying to reclaim when there are only anonymous pages in the system even though that will not make any progress. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01vmscan: activate executable pages after first usageKonstantin Khlebnikov
commit c909e99364c8b6ca07864d752950b6b4ecf6bef4 upstream. Stable note: Not tracked in Bugzilla. There were reports of shared mapped pages being unfairly reclaimed in comparison to older kernels. This is being addressed over time. Logic added in commit 8cab4754d24a0 ("vmscan: make mapped executable pages the first class citizen") was noticeably weakened in commit 645747462435d84 ("vmscan: detect mapped file pages used only once"). Currently these pages can become "first class citizens" only after second usage. After this patch page_check_references() will activate they after first usage, and executable code gets yet better chance to stay in memory. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
