This patch removes the call to ndo_vlan_rx_register if the underlying
device doesn't have hardware support for VLAN.
Signed-off-by: Antoine Reversat <a.reversat@gmail.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
The below patch removes vlan_buggyright and vlan_copyright from vlan_proto_init,
so that it prints out just the fullname of vlan and the version number.
before:
[ 30.438203] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
[ 30.441542] All bugs added by David S. Miller <davem@redhat.com>
after:
[ 31.513910] 802.1Q VLAN Support v1.8
CC: Joe Perches <joe@perches.com>
CC: David S. Miller <davem@davemloft.net>
CC: Ben Greear <greearb@candelatech.com>
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6
drivers/net/benet/be_main.c
ip link add link eth2 eth2.103 type vlan id 103 gvrp on loose_binding on
ip link set eth2.103 up
rmmod tg3 # driver providing eth2
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffffa0030c9e>] garp_request_leave+0x3e/0xc0 [garp]
PGD 11d251067 PUD 11b9e0067 PMD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/virtual/net/eth2.104/ifindex
CPU 0
Modules linked in: tg3(-) 8021q garp nfsd lockd auth_rpcgss sunrpc libphy sg [last unloaded: x_tables]
Pid: 11494, comm: rmmod Tainted: G W 2.6.39-rc6-00261-gfd71257-dirty #580 HP ProLiant BL460c G6
RIP: 0010:[<ffffffffa0030c9e>] [<ffffffffa0030c9e>] garp_request_leave+0x3e/0xc0 [garp]
RSP: 0018:ffff88007a19bae8 EFLAGS: 00010286
RAX: 0000000000000000 RBX: ffff88011b5e2000 RCX: 0000000000000002
RDX: 0000000000000000 RSI: 0000000000000175 RDI: ffffffffa0030d5b
RBP: ffff88007a19bb18 R08: 0000000000000001 R09: ffff88011bd64a00
R10: ffff88011d34ec00 R11: 0000000000000000 R12: 0000000000000002
R13: ffff88007a19bc48 R14: ffff88007a19bb88 R15: 0000000000000001
FS: 0000000000000000(0000) GS:ffff88011fc00000(0063) knlGS:00000000f77d76c0
CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b
CR2: 0000000000000000 CR3: 000000011a675000 CR4: 00000000000006f0
Process rmmod (pid: 11494, threadinfo ffff88007a19a000, task ffff8800798595c0)
Stack:
ffff88007a19bb36 ffff88011c84b800 ffff88011b5e2000 ffff88007a19bc48
ffff88007a19bb88 0000000000000006 ffff88007a19bb38 ffffffffa003a5f6
ffff88007a19bb38 670088007a19bba8 ffff88007a19bb58 ffffffffa00397e7
Call Trace:
[<ffffffffa003a5f6>] vlan_gvrp_request_leave+0x46/0x50 [8021q]
[<ffffffffa00397e7>] vlan_dev_stop+0xb7/0xc0 [8021q]
[<ffffffff8137e427>] __dev_close_many+0x87/0xe0
[<ffffffff8137e507>] dev_close_many+0x87/0x110
[<ffffffff8137e630>] rollback_registered_many+0xa0/0x240
[<ffffffff8137e7e9>] unregister_netdevice_many+0x19/0x60
[<ffffffffa00389eb>] vlan_device_event+0x53b/0x550 [8021q]
[<ffffffff8143f448>] ? ip6mr_device_event+0xa8/0xd0
[<ffffffff81479d03>] notifier_call_chain+0x53/0x80
[<ffffffff81062539>] __raw_notifier_call_chain+0x9/0x10
[<ffffffff81062551>] raw_notifier_call_chain+0x11/0x20
[<ffffffff8137df82>] call_netdevice_notifiers+0x32/0x60
[<ffffffff8137e69f>] rollback_registered_many+0x10f/0x240
[<ffffffff8137e85f>] rollback_registered+0x2f/0x40
[<ffffffff8137e8c8>] unregister_netdevice_queue+0x58/0x90
[<ffffffff8137e9eb>] unregister_netdev+0x1b/0x30
[<ffffffffa005d73f>] tg3_remove_one+0x6f/0x10b [tg3]
We should call vlan_gvrp_request_leave() from unregister_vlan_dev(),
not from vlan_dev_stop(), because vlan_gvrp_uninit_applicant()
is called right after unregister_netdevice_queue(). In batch mode,
unregister_netdevice_queue() doesn’t immediately call vlan_dev_stop().
At VLAN dismantle phase, unregister_vlan_dev() makes one
synchronize_net() call after vlan_group_set_device(grp, vlan_id, NULL).
This call can be safely removed because we are calling
unregister_netdevice_queue() to queue device for deletion, and this
process needs at least one rcu grace period to complete.
Cc: Ben Greear <greearb@candelatech.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Jesse Gross <jesse@nicira.com>
Cc: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Acked-by: Jesse Gross <jesse@nicira.com>
NETDEV_NOTIFY_PEERS
It is undesirable for the bonding driver to be poking into higher
level protocols, and notifiers provide a way to avoid that. This does
mean removing the ability to configure reptitition of gratuitous ARPs
and unsolicited NAs.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
The NETDEV_NOTIFY_PEERS notifier indicates that a device moved to a
different physical link; this also applies to any VLAN devices on top
of it.
Now there are 2 paths for rx vlan frames. When rx-vlan-hw-accel is
enabled, skb is untagged by NIC, vlan_tci is set and the skb gets into
vlan code in __netif_receive_skb - vlan_hwaccel_do_receive.
For non-rx-vlan-hw-accel however, tagged skb goes thru whole
__netif_receive_skb, it's untagged in ptype_base hander and reinjected
This incosistency is fixed by this patch. Vlan untagging happens early in
__netif_receive_skb so the rest of code (ptype_all handlers, rx_handlers)
see the skb like it was untagged by hw.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
v1->v2:
remove "inline" from vlan_core.c functions
Note: get_flags was actually broken, because it should return the
flags capped with vlan_features. This is now done implicitly by
limiting netdev->hw_features.
RX checksumming offload control is (and was) broken, as there was no way
before to say whether it's done for tagged packets.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Quoting Ben Hutchings: we presumably won't be defining features that
can only be enabled on 64-bit architectures.
Occurences found by `grep -r` on net/, drivers/net, include/
[ Move features and vlan_features next to each other in
struct netdev, as per Eric Dumazet's suggestion -DaveM ]
Now that the vlan device is lockless and single queue do not
transfer the real num queues. This is causing a BUG_ON to occur.
kernel BUG at net/8021q/vlan.c:345!
Call Trace:
[<ffffffff813fd6e8>] ? fib_rules_event+0x28/0x1b0
[<ffffffff814ad2b5>] notifier_call_chain+0x55/0x80
[<ffffffff81089156>] raw_notifier_call_chain+0x16/0x20
[<ffffffff813e5af7>] call_netdevice_notifiers+0x37/0x70
[<ffffffff813e6756>] netdev_features_change+0x16/0x20
[<ffffffffa02995be>] ixgbe_fcoe_enable+0xae/0x100 [ixgbe]
[<ffffffffa01da06a>] vlan_dev_fcoe_enable+0x2a/0x30 [8021q]
[<ffffffffa02d08c3>] fcoe_create+0x163/0x630 [fcoe]
[<ffffffff811244d5>] ? mmap_region+0x255/0x5a0
[<ffffffff81080ef0>] param_attr_store+0x50/0x80
[<ffffffff810809b6>] module_attr_store+0x26/0x30
[<ffffffff811b9db2>] sysfs_write_file+0xf2/0x180
[<ffffffff8114fc88>] vfs_write+0xc8/0x190
[<ffffffff81150621>] sys_write+0x51/0x90
[<ffffffff8100c0b2>] system_call_fastpath+0x16/0x1b
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
vlan is a stacked device, like tunnels. We should use the lockless
mechanism we are using in tunnels and loopback.
This patch completely removes locking in TX path.
tx stat counters are added into existing percpu stat structure, renamed
from vlan_rx_stats to vlan_pcpu_stats.
Note : this partially reverts commit 2e59af3dcbdf (vlan: multiqueue vlan
device)
Toggling the vlan tx|rx hw offloads needs to set the hard_header_len
as well otherwise we end up using LL_RESERVED_SPACE incorrectly.
This results in pskb_expand_head() being used unnecessarily.
(struct net_device)->vlgrp is rcu protected :
add __rcu annotation and proper rcu primitives.
Currently each driver that is capable of vlan hardware acceleration
must be aware of the vlan groups that are configured and then pass
the stripped tag to a specialized receive function. This is
different from other types of hardware offload in that it places a
significant amount of knowledge in the driver itself rather keeping
it in the networking core.
This makes vlan offloading function more similarly to other forms
of offloading (such as checksum offloading or TSO) by doing the
following:
* On receive, stripped vlans are passed directly to the network
core, without attempting to check for vlan groups or reconstructing
the header if no group
* vlans are made less special by folding the logic into the main
receive routines
* On transmit, the device layer will add the vlan header in software
if the hardware doesn't support it, instead of spreading that logic
out in upper layers, such as bonding.
There are a number of advantages to this:
* Fixes all bugs with drivers incorrectly dropping vlan headers at once.
* Avoids having to disable VLAN acceleration when in promiscuous mode
(good for bridging since it always puts devices in promiscuous mode).
* Keeps VLAN tag separate until given to ultimate consumer, which
avoids needing to do header reconstruction as in tg3 unless absolutely
necessary.
* Consolidates common code in core networking.
Signed-off-by: Jesse Gross <jesse@nicira.com>
A struct net_device always maps to zero or one vlan groups and we
always know the device when we are looking up a group. We currently
do a hash table lookup on the device to find the group but it is
much simpler to just store a pointer.
VLAN_GROUP_ARRAY_LEN is simply the number of possible vlan VIDs.
Since vlan groups will soon be more of an implementation detail
for vlan devices, rename the constant to be descriptive of its
actual purpose.
This covers RX if necessary, as well as TX.
previously, if a vlan master device was moved from one network namespace
to another, all 802.1q and macvlan slaves were deleted.
we can use dev->reg_state to figure out whether dev_change_net_namespace
is happening, since that won't set dev->reg_state NETREG_UNREGISTERING.
so, this changes 8021q and macvlan to ignore NETDEV_UNREGISTER when
reg_state is not NETREG_UNREGISTERING.
Signed-off-by: David Lamparter <equinox@diac24.net>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
Acked-by: Patrick McHardy <kaber@trash.net>
- Without the 8021q module loaded in the kernel, all 802.1p packets
(VLAN 0 but QoS tagging) are silently discarded (as expected, as
the protocol is not loaded).
- Without this patch in 8021q module, these packets are forwarded to
the module, but they are discarded also if VLAN 0 is not configured,
which should not be the default behaviour, as VLAN 0 is not really
a VLANed packet but a 802.1p packet. Defining VLAN 0 makes it almost
impossible to communicate with mixed 802.1p and non 802.1p devices on
the same network due to arp table issues.
- Changed logic to skip vlan specific code in vlan_skb_recv if VLAN
is 0 and we have not defined a VLAN with ID 0, but we accept the
packet with the encapsulated proto and pass it later to netif_rx.
- In the vlan device event handler, added some logic to add VLAN 0
to HW filter in devices that support it (this prevented any traffic
in VLAN 0 to reach the stack in e1000e with HW filter under 2.6.35,
and probably also with other HW filtered cards, so we fix it here).
- In the vlan unregister logic, prevent the elimination of VLAN 0
in devices with HW filter.
- The default behaviour is to ignore the VLAN 0 tagging and accept
the packet as if it was not tagged, but we can still define a
VLAN 0 if desired (so it is backwards compatible).
Signed-off-by: Pedro Garcia <pedro.netdev@dondevamos.com>
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
drivers/net/bonding/bond_main.c
drivers/net/via-velocity.c
drivers/net/wireless/iwlwifi/iwl-agn.c
+little renaming of unicast functions to be smooth with multicast ones
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Updates real_num_tx_queues in case underlying real device
has changed real_num_tx_queues.
-v2
As per Eric Dumazet<eric.dumazet@gmail.com> comment:-
-- adds BUG_ON to catch case of real_num_tx_queues exceeding num_tx_queues.
-- created this self contained patch to just update real_num_tx_queues.
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
It's not desired for underlaying devices to change type. At the time,
there is for example possible to have bond with changed type from
Ethernet to Infiniband as a port of a bridge. This patch fixes this.
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
Provide common routine for the transition of operational state for a leaf
device during a root device transition.
Signed-off-by: Patrick Mullaney <pmullaney@novell.com>
Take advantage of the fact that an explicit rtnl_kill_links is
unnecessary (and skipping it improves batching), as network namespace
exit calls dellink on all remaining virtual devices, and
rtnl_link_unregister calls dellink on all outstanding devices in that
network namespace. To do this we need to leave the vlan proc
directories in place until after network device exit time, which is
done by using register_pernet_subsys instead of
register_pernet_device.
Take advantage of the new pernet automatic storage management,
and stop using compatibility network namespace functions.
Currently the UP/DOWN state of VLANs is synchronized to the state of the
underlying device, meaning all VLANs are set down once the underlying
device is set down. This causes all routes to the VLAN devices to vanish.
Add a flag to specify a "loose binding" mode, in which only the operstate
is transfered, but the VLAN device state is independant.
drivers/net/sfc/sfe4001.c
drivers/net/wireless/libertas/cmd.c
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/rtl8187se/Kconfig
drivers/staging/rtl8192e/Kconfig
In case register_netdevice() returns an error, and a new vlan_group
was allocated and inserted in vlan_group_hash[] we call
vlan_group_free() without deleting group from hash table. Future
lookups can give infinite loops or crashes.
We must delete the vlan_group using RCU safe procedure.
The temporary copy of the VLAN group is not neccessary since the lower device
is already in the process of being unregistered, if it was neccessary the
memset of the global group would introduce a race condition.
With this removed, the changes to the original code are only a few lines, so
remove the new function and move the code back into vlan_device_event().
Use unregister_netdevice_many() to speedup master device unregister.
Adding a list_head parameter to rtnl_link_ops->dellink() methods
allow us to queue devices on a list, in order to dismantle
them all at once.
vlan devices are currently not multi-queue capable.
We can do that with a new rtnl_link_ops method,
get_tx_queues(), called from rtnl_create_link()
This new method gets num_tx_queues/real_num_tx_queues
from real device.
register_vlan_device() is also handled.
Adds fcoe offload related net_device_ops functions vlan_dev_fcoe_ddp_setup
and vlan_dev_fcoe_ddp_done, their implementation simply calls real eth device
net_device_ops for FCoE DDP setup and done operations.
Updates VLAN netdev field value for fcoe_ddp_xid from real eth device netdev.
Above changes are required for fcoe DDP offload working on a VLAN interface.
There is no reason for the arbitrary restriction that device must be
up to create a vlan. This patch was added to Vyatta kernel to resolve startup
ordering issues where vlan's are created but real device was disabled.
Note: the vlan already correctly inherits the operstate from real device; so
if vlan is created and real device is marked down, the vlan is marked
down.
When the physical MTU changes we want to ensure that all existing
VLAN device MTUs do not exceed the new underlying MTU. This patch
adds that propagation.
syncronize_net()
The VLAN 8021q driver needs to call rcu_barrier() when unloading the module,
instead of syncronize_net(). This is needed to make sure that outstanding
call_rcu() callbacks have completed, before the callback function code is
removed on module unload.
Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
This patch converts unicast address list to standard list_head using
previously introduced struct netdev_hw_addr. It also relaxes the
locking. Original spinlock (still used for multicast addresses) is not
needed and is no longer used for a protection of this list. All
reading and writing takes place under rtnl (with no changes).
I also removed a possibility to specify the length of the address
while adding or deleting unicast address. It's always dev->addr_len.
The convertion touched especially e1000 and ixgbe codes when the
change is not so trivial.
drivers/net/bnx2.c | 13 +--
drivers/net/e1000/e1000_main.c | 24 +++--
drivers/net/ixgbe/ixgbe_common.c | 14 ++--
drivers/net/ixgbe/ixgbe_common.h | 4 +-
drivers/net/ixgbe/ixgbe_main.c | 6 +-
drivers/net/ixgbe/ixgbe_type.h | 4 +-
drivers/net/macvlan.c | 11 +-
drivers/net/mv643xx_eth.c | 11 +-
drivers/net/niu.c | 7 +-
drivers/net/virtio_net.c | 7 +-
drivers/s390/net/qeth_l2_main.c | 6 +-
drivers/scsi/fcoe/fcoe.c | 16 ++--
include/linux/netdevice.h | 18 ++--
net/8021q/vlan.c | 4 +-
net/8021q/vlan_dev.c | 10 +-
net/core/dev.c | 195 +++++++++++++++++++++++++++-----------
net/dsa/slave.c | 10 +-
net/packet/af_packet.c | 4 +-
18 files changed, 227 insertions(+), 137 deletions(-)
Currently, the VLAN event handler does not adjust the VLAN
device's carrier state when the real device or the VLAN device is set
administratively up or down.
The following patch adds a transfer of operating state from the
real device to the VLAN device when the real device is administratively
set up or down, and sets the carrier state up or down during init, open
and close of the VLAN device.
This permits observers above the VLAN device that care about the
carrier state (bonding's link monitor, for example) to receive updates
for administrative changes by more closely mimicing the behavior of real
devices.
Protocols that use packet_type can be __read_mostly section for better
locality. Elminate any unnecessary initializations of NULL.
Base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Convert vlan devices and function pointers to net_device_ops.
This enables more ethtool information. The speed and settings of the
underlying device are propagated up. This makes services like SNMP that
use ethtool to get speed setting, work when managing a vlan, without adding
silly heurtistics into SNMP daemon.
For the driver info, just use existing driver strings.
The vlan devices are not reading the gso max size of the parent device. As
a result devices that do not support 64K max gso size are currently
failing.
This issue is seen on 2.6.26 kernels as well and the same patch should be
able to be applied without any issues.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/powerpc/booting-without-of.txt
drivers/atm/Makefile
drivers/net/fs_enet/fs_enet-main.c
drivers/pci/pci-acpi.c
net/8021q/vlan.c
net/iucv/iucv.c
