path: root/net/8021q/vlan.c
2015-05-14vlan: Correctly propagate promisc|allmulti flags in notifier.Vlad Yasevich
Currently vlan notifier handler will try to update all vlans for a device when that device comes up. A problem occurs, however, when the vlan device was set to promiscuous, but not by the user (ex: a bridge). In that case, dev->gflags are not updated. What results is that the lower device ends up with an extra promiscuity count. Here are the backtraces that prove this: [62852.052179] [<ffffffff814fe248>] __dev_set_promiscuity+0x38/0x1e0 [62852.052186] [<ffffffff8160bcbb>] ? _raw_spin_unlock_bh+0x1b/0x40 [62852.052188] [<ffffffff814fe4be>] ? dev_set_rx_mode+0x2e/0x40 [62852.052190] [<ffffffff814fe694>] dev_set_promiscuity+0x24/0x50 [62852.052194] [<ffffffffa0324795>] vlan_dev_open+0xd5/0x1f0 [8021q] [62852.052196] [<ffffffff814fe58f>] __dev_open+0xbf/0x140 [62852.052198] [<ffffffff814fe88d>] __dev_change_flags+0x9d/0x170 [62852.052200] [<ffffffff814fe989>] dev_change_flags+0x29/0x60 The above comes from the setting the vlan device to IFF_UP state. [62852.053569] [<ffffffff814fe248>] __dev_set_promiscuity+0x38/0x1e0 [62852.053571] [<ffffffffa032459b>] ? vlan_dev_set_rx_mode+0x2b/0x30 [8021q] [62852.053573] [<ffffffff814fe8d5>] __dev_change_flags+0xe5/0x170 [62852.053645] [<ffffffff814fe989>] dev_change_flags+0x29/0x60 [62852.053647] [<ffffffffa032334a>] vlan_device_event+0x18a/0x690 [8021q] [62852.053649] [<ffffffff8161036c>] notifier_call_chain+0x4c/0x70 [62852.053651] [<ffffffff8109d456>] raw_notifier_call_chain+0x16/0x20 [62852.053653] [<ffffffff814f744d>] call_netdevice_notifiers+0x2d/0x60 [62852.053654] [<ffffffff814fe1a3>] __dev_notify_flags+0x33/0xa0 [62852.053656] [<ffffffff814fe9b2>] dev_change_flags+0x52/0x60 [62852.053657] [<ffffffff8150cd57>] do_setlink+0x397/0xa40 And this one comes from the notification code. What we end up with is a vlan with promiscuity count of 1 and and a physical device with a promiscuity count of 2. They should both have a count 1. To resolve this issue, vlan code can use dev_get_flags() api which correctly masks promiscuity and allmulti flags. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-18net: Fix high overhead of vlan sub-device teardown.David S. Miller
When a networking device is taken down that has a non-trivial number of VLAN devices configured under it, we eat a full synchronize_net() for every such VLAN device. This is because of the call chain: NETDEV_DOWN notifier --> vlan_device_event() --> dev_change_flags() --> __dev_change_flags() --> __dev_close() --> __dev_close_many() --> dev_deactivate_many() --> synchronize_net() This is kind of rediculous because we already have infrastructure for batching doing operation X to a list of net devices so that we only incur one sync. So make use of that by exporting dev_close_many() and adjusting it's interfaace so that the caller can fully manage the batch list. Use this in vlan_device_event() and all the overhead goes away. Reported-by: Salam Noureddine <noureddine@arista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-29vlan: fail early when creating netdev named configWANG Cong
Similarly, vlan will create /proc/net/vlan/<dev>, so when we create dev with name "config", it will confict with /proc/net/vlan/config. Reported-by: Stephane Chazelas <stephane.chazelas@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-15net: set name_assign_type in alloc_netdev()Tom Gundersen
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert all users to pass NET_NAME_UNKNOWN. Coccinelle patch: @@ expression sizeof_priv, name, setup, txqs, rxqs, count; @@ ( -alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs) +alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs) | -alloc_netdev_mq(sizeof_priv, name, setup, count) +alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count) | -alloc_netdev(sizeof_priv, name, setup) +alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup) ) v9: move comments here from the wrong commit Signed-off-by: Tom Gundersen <teg@jklm.no> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16vlan: Fix lockdep warning with stacked vlan devices.Vlad Yasevich
This reverts commit dc8eaaa006350d24030502a4521542e74b5cb39f. vlan: Fix lockdep warning when vlan dev handle notification Instead we use the new new API to find the lock subclass of our vlan device. This way we can support configurations where vlans are interspersed with other devices: bond -> vlan -> macvlan -> vlan Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-27vlan: Set hard_header_len according to available accelerationVlad Yasevich
Currently, if the card supports CTAG acceleration we do not account for the vlan header even if we are configuring an 8021AD vlan. This may not be best since we'll do software tagging for 8021AD which will cause data copy on skb head expansion Configure the length based on available hw offload capabilities and vlan protocol. CC: Patrick McHardy <kaber@trash.net> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-218021q: Use ether_addr_copyJoe Perches
Use ether_addr_copy instead of memcpy(a, b, ETH_ALEN) to save some cycles on arm and powerpc. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-26vlan: unlink the upper neighbour before unregisteringVeaceslav Falico
On netdev unregister we're removing also all of its sysfs-associated stuff, including the sysfs symlinks that are controlled by netdev neighbour code. Also, it's a subtle race condition - cause we can still access it after unregistering. Move the unlinking right before the unregistering to fix both. CC: Patrick McHardy <kaber@trash.net> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-26vlan: link the upper neighbour only after registeringVeaceslav Falico
Otherwise users might access it without being fully registered, as per sysfs - it only inits in register_netdevice(), so is unusable till it is called. CC: Patrick McHardy <kaber@trash.net> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-03vlan: cleanup the usage of vlan_dev_priv(dev)Wang Sheng-Hui
This patch cleanup 2 points for the usage of vlan_dev_priv(dev): * In vlan_dev.c/vlan_dev_hard_header, we should use the var *vlan directly after grabing the pointer at the beginning with *vlan = vlan_dev_priv(dev); when we need to access the fields of *vlan. * In vlan.c/register_vlan_device, add the var *vlan pointer struct vlan_dev_priv *vlan; to cleanup the code to access the fields of vlan_dev_priv(new_dev). Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-23net: convert resend IGMP to notifier eventJiri Pirko
Until now, bond_resend_igmp_join_requests() looks for vlans attached to bonding device, bridge where bonding act as port manually. It does not care of other scenarios, like stacked bonds or team device above. Make this more generic and use netdev notifier to propagate the event to upper devices and to actually call ip_mc_rejoin_groups(). Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: prepare for 802.1ad supportPatrick McHardy
Make the encapsulation protocol value a property of VLAN devices and change the device lookup functions to take the protocol value into account. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: prepare for 802.1ad VLAN filtering offloadPatrick McHardy
Change the rx_{add,kill}_vid callbacks to take a protocol argument in preparation of 802.1ad support. The protocol argument used so far is always htons(ETH_P_8021Q). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: rename NETIF_F_HW_VLAN_* feature flags to NETIF_F_HW_VLAN_CTAG_*Patrick McHardy
Rename the hardware VLAN acceleration features to include "CTAG" to indicate that they only support CTAGs. Follow up patches will introduce 802.1ad server provider tagging (STAGs) and require the distinction for hardware not supporting acclerating both. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-248021q: fix a potential use-after-freeCong Wang
vlan_vid_del() could possibly free ->vlan_info after a RCU grace period, however, we may still refer to the freed memory area by 'grp' pointer. Found by code inspection. This patch moves vlan_vid_del() as behind as possible. Cc: Patrick McHardy <kaber@trash.net> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-10net/8021q: Implement Multiple VLAN Registration Protocol (MVRP)David Ward
Initial implementation of the Multiple VLAN Registration Protocol (MVRP) from IEEE 802.1Q-2011, based on the existing implementation of the GARP VLAN Registration Protocol (GVRP). Signed-off-by: David Ward <david.ward@ll.mit.edu> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-29net: disallow drivers with buggy VLAN accel to register_netdevice()Michał Mirosław
Instead of jumping aroung bugs that are easily fixed just don't let them in: affected drivers should be either fixed or have NETIF_F_HW_VLAN_FILTER removed from advertised features. Quick grep in drivers/net shows two drivers that have NETIF_F_HW_VLAN_FILTER but not ndo_vlan_rx_add/kill_vid(), but those are false-positives (features are commented out). OTOH two drivers have ndo_vlan_rx_add/kill_vid() implemented but don't advertise NETIF_F_HW_VLAN_FILTER. Those are: +ethernet/cisco/enic/enic_main.c +ethernet/qlogic/qlcnic/qlcnic_main.c Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-04vlan: add link to upper deviceJiri Pirko
Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-308021q: fix vlan device to inherit the unicast filtering capability flagYi Zou
This bug is observed on running FCoE over a VLAN device associated w/ a real device that has IFF_UNICAST_FLT set since FCoE would add unicast address such as FLOGI MAC to the VLAN interface that FCoE is on. Since currently, VLAN device is not inheriting the IFF_UNICAST_FLT flag from the parent real device even though the real device is capable of doing unicast filtering. This forces the VLAN device and its real device go to promiscuous mode unnecessarily even the added address is actually being added to the available unicast filter table in real device. Signed-off-by: Yi Zou <yi.zou@intel.com> Cc: devel@open-fcoe.org Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Allow the userns root to control vlans.Eric W. Biederman
Allow an unpriviled user who has created a user namespace, and then created a network namespace to effectively use the new network namespace, by reducing capable(CAP_NET_ADMIN) and capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns, CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls. Allow the vlan ioctls: SET_VLAN_INGRESS_PRIORITY_CMD SET_VLAN_EGRESS_PRIORITY_CMD SET_VLAN_FLAG_CMD SET_VLAN_NAME_TYPE_CMD ADD_VLAN_CMD DEL_VLAN_CMD Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01vlan: use IS_ENABLED()Amerigo Wang
#if defined(CONFIG_FOO) || defined(CONFIG_FOO_MODULE) can be replaced by #if IS_ENABLED(CONFIG_FOO) Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-18vlan: allow to change type when no vlan device is hooked on netdevJiri Pirko
vlan_info might be present but still no vlan devices might be there. That is in case of vlan0 automatically added. So in that case, allow to change netdev type. Reported-by: Jon Stanley <jstanley@rmrf.net> Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10net: Fix memory leak - vlan_info structAmir Hanania
In driver reload test there is a memory leak. The structure vlan_info was not freed when the driver was removed. It was not released since the nr_vids var is one after last vlan was removed. The nr_vids is one, since vlan zero is added to the interface when the interface is being set, but the vlan zero is not deleted at unregister. Fix - delete vlan zero when we unregister the device. Signed-off-by: Amir Hanania <amir.hanania@intel.com> Acked-by: John Fastabend <john.r.fastabend@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-098021q: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08vlan: introduce vid list with reference countingJiri Pirko
This allows to keep track of vids needed to be in rx vlan filters of devices even if they are used in bond/team etc. vlan_info as well as vlan_group previously was, is allocated when first vid is added and dealocated whan last vid is deleted. vlan_group definition is moved to private header. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08net: introduce vlan_vid_[add/del] and use them instead of direct ↵Jiri Pirko
[add/kill]_vid ndo calls This patch adds wrapper for ndo_vlan_rx_add_vid/ndo_vlan_rx_kill_vid functions. Check for NETIF_F_HW_VLAN_FILTER feature is done in this wrapper. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08vlan: rename vlan_dev_info to vlan_dev_privJiri Pirko
As this structure is priv, name it approprietely. Also for pointer to it use name "vlan". Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-21vlan: kill ndo_vlan_rx_registerJiri Pirko
has no users so remove it Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-rxon.c drivers/net/wireless/rtlwifi/pci.c net/netfilter/ipvs/ip_vs_core.c
2011-06-17vlan: don't call ndo_vlan_rx_register on hardware that doesn't have vlan supportAntoine Reversat
This patch removes the call to ndo_vlan_rx_register if the underlying device doesn't have hardware support for VLAN. Signed-off-by: Antoine Reversat <a.reversat@gmail.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-02net: 8021q: Add pr_fmtJoe Perches
Use the current logging style. Add #define pr_fmt and remove embedded prefix from formats. Not converting the current pr_<level> uses to netdev_<level> because all the output here is nicely prefaced with "8021q: ". Remove __func__ use from proc registration failure message. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26net:8021q:vlan.c Fix pr_info to just give the vlan fullname and version.Justin Mattock
The below patch removes vlan_buggyright and vlan_copyright from vlan_proto_init, so that it prints out just the fullname of vlan and the version number. before: [ 30.438203] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com> [ 30.441542] All bugs added by David S. Miller <davem@redhat.com> after: [ 31.513910] 802.1Q VLAN Support v1.8 Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> CC: Joe Perches <joe@perches.com> CC: David S. Miller <davem@davemloft.net> CC: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6 Conflicts: drivers/net/benet/be_main.c
2011-05-10vlan: fix GVRP at dismantle timeEric Dumazet
ip link add link eth2 eth2.103 type vlan id 103 gvrp on loose_binding on ip link set eth2.103 up rmmod tg3 # driver providing eth2 BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffffa0030c9e>] garp_request_leave+0x3e/0xc0 [garp] PGD 11d251067 PUD 11b9e0067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/virtual/net/eth2.104/ifindex CPU 0 Modules linked in: tg3(-) 8021q garp nfsd lockd auth_rpcgss sunrpc libphy sg [last unloaded: x_tables] Pid: 11494, comm: rmmod Tainted: G W 2.6.39-rc6-00261-gfd71257-dirty #580 HP ProLiant BL460c G6 RIP: 0010:[<ffffffffa0030c9e>] [<ffffffffa0030c9e>] garp_request_leave+0x3e/0xc0 [garp] RSP: 0018:ffff88007a19bae8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: ffff88011b5e2000 RCX: 0000000000000002 RDX: 0000000000000000 RSI: 0000000000000175 RDI: ffffffffa0030d5b RBP: ffff88007a19bb18 R08: 0000000000000001 R09: ffff88011bd64a00 R10: ffff88011d34ec00 R11: 0000000000000000 R12: 0000000000000002 R13: ffff88007a19bc48 R14: ffff88007a19bb88 R15: 0000000000000001 FS: 0000000000000000(0000) GS:ffff88011fc00000(0063) knlGS:00000000f77d76c0 CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b CR2: 0000000000000000 CR3: 000000011a675000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rmmod (pid: 11494, threadinfo ffff88007a19a000, task ffff8800798595c0) Stack: ffff88007a19bb36 ffff88011c84b800 ffff88011b5e2000 ffff88007a19bc48 ffff88007a19bb88 0000000000000006 ffff88007a19bb38 ffffffffa003a5f6 ffff88007a19bb38 670088007a19bba8 ffff88007a19bb58 ffffffffa00397e7 Call Trace: [<ffffffffa003a5f6>] vlan_gvrp_request_leave+0x46/0x50 [8021q] [<ffffffffa00397e7>] vlan_dev_stop+0xb7/0xc0 [8021q] [<ffffffff8137e427>] __dev_close_many+0x87/0xe0 [<ffffffff8137e507>] dev_close_many+0x87/0x110 [<ffffffff8137e630>] rollback_registered_many+0xa0/0x240 [<ffffffff8137e7e9>] unregister_netdevice_many+0x19/0x60 [<ffffffffa00389eb>] vlan_device_event+0x53b/0x550 [8021q] [<ffffffff8143f448>] ? ip6mr_device_event+0xa8/0xd0 [<ffffffff81479d03>] notifier_call_chain+0x53/0x80 [<ffffffff81062539>] __raw_notifier_call_chain+0x9/0x10 [<ffffffff81062551>] raw_notifier_call_chain+0x11/0x20 [<ffffffff8137df82>] call_netdevice_notifiers+0x32/0x60 [<ffffffff8137e69f>] rollback_registered_many+0x10f/0x240 [<ffffffff8137e85f>] rollback_registered+0x2f/0x40 [<ffffffff8137e8c8>] unregister_netdevice_queue+0x58/0x90 [<ffffffff8137e9eb>] unregister_netdev+0x1b/0x30 [<ffffffffa005d73f>] tg3_remove_one+0x6f/0x10b [tg3] We should call vlan_gvrp_request_leave() from unregister_vlan_dev(), not from vlan_dev_stop(), because vlan_gvrp_uninit_applicant() is called right after unregister_netdevice_queue(). In batch mode, unregister_netdevice_queue() doesn’t immediately call vlan_dev_stop(). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-09vlan: remove one synchronize_net() callEric Dumazet
At VLAN dismantle phase, unregister_vlan_dev() makes one synchronize_net() call after vlan_group_set_device(grp, vlan_id, NULL). This call can be safely removed because we are calling unregister_netdevice_queue() to queue device for deletion, and this process needs at least one rcu grace period to complete. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ben Greear <greearb@candelatech.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jesse Gross <jesse@nicira.com> Cc: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17bonding, ipv4, ipv6, vlan: Handle NETDEV_BONDING_FAILOVER like ↵Ben Hutchings
NETDEV_NOTIFY_PEERS It is undesirable for the bonding driver to be poking into higher level protocols, and notifiers provide a way to avoid that. This does mean removing the ability to configure reptitition of gratuitous ARPs and unsolicited NAs. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17vlan: Propagate NETDEV_NOTIFY_PEERS notifierBen Hutchings
The NETDEV_NOTIFY_PEERS notifier indicates that a device moved to a different physical link; this also applies to any VLAN devices on top of it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12net: vlan: make non-hw-accel rx path similar to hw-accelJiri Pirko
Now there are 2 paths for rx vlan frames. When rx-vlan-hw-accel is enabled, skb is untagged by NIC, vlan_tci is set and the skb gets into vlan code in __netif_receive_skb - vlan_hwaccel_do_receive. For non-rx-vlan-hw-accel however, tagged skb goes thru whole __netif_receive_skb, it's untagged in ptype_base hander and reinjected This incosistency is fixed by this patch. Vlan untagging happens early in __netif_receive_skb so the rest of code (ptype_all handlers, rx_handlers) see the skb like it was untagged by hw. Signed-off-by: Jiri Pirko <jpirko@redhat.com> v1->v2: remove "inline" from vlan_core.c functions Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-02vlan: convert VLAN devices to use ndo_fix_features()Michał Mirosław
Note: get_flags was actually broken, because it should return the flags capped with vlan_features. This is now done implicitly by limiting netdev->hw_features. RX checksumming offload control is (and was) broken, as there was no way before to say whether it's done for tagged packets. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24net: change netdev->features to u32Michał Mirosław
Quoting Ben Hutchings: we presumably won't be defining features that can only be enabled on 64-bit architectures. Occurences found by `grep -r` on net/, drivers/net, include/ [ Move features and vlan_features next to each other in struct netdev, as per Eric Dumazet's suggestion -DaveM ] Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-288021q: vlan device is lockless do not transfer real_num_{tx|rx}_queuesJohn Fastabend
Now that the vlan device is lockless and single queue do not transfer the real num queues. This is causing a BUG_ON to occur. kernel BUG at net/8021q/vlan.c:345! Call Trace: [<ffffffff813fd6e8>] ? fib_rules_event+0x28/0x1b0 [<ffffffff814ad2b5>] notifier_call_chain+0x55/0x80 [<ffffffff81089156>] raw_notifier_call_chain+0x16/0x20 [<ffffffff813e5af7>] call_netdevice_notifiers+0x37/0x70 [<ffffffff813e6756>] netdev_features_change+0x16/0x20 [<ffffffffa02995be>] ixgbe_fcoe_enable+0xae/0x100 [ixgbe] [<ffffffffa01da06a>] vlan_dev_fcoe_enable+0x2a/0x30 [8021q] [<ffffffffa02d08c3>] fcoe_create+0x163/0x630 [fcoe] [<ffffffff811244d5>] ? mmap_region+0x255/0x5a0 [<ffffffff81080ef0>] param_attr_store+0x50/0x80 [<ffffffff810809b6>] module_attr_store+0x26/0x30 [<ffffffff811b9db2>] sysfs_write_file+0xf2/0x180 [<ffffffff8114fc88>] vfs_write+0xc8/0x190 [<ffffffff81150621>] sys_write+0x51/0x90 [<ffffffff8100c0b2>] system_call_fastpath+0x16/0x1b Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-16vlan: lockless transmit pathEric Dumazet
vlan is a stacked device, like tunnels. We should use the lockless mechanism we are using in tunnels and loopback. This patch completely removes locking in TX path. tx stat counters are added into existing percpu stat structure, renamed from vlan_rx_stats to vlan_pcpu_stats. Note : this partially reverts commit 2e59af3dcbdf (vlan: multiqueue vlan device) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-158021q: set hard_header_len when VLAN offload features are toggledJohn Fastabend
Toggling the vlan tx|rx hw offloads needs to set the hard_header_len as well otherwise we end up using LL_RESERVED_SPACE incorrectly. This results in pskb_expand_head() being used unnecessarily. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-25vlan: rcu annotationsEric Dumazet
(struct net_device)->vlgrp is rcu protected : add __rcu annotation and proper rcu primitives. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Centralize handling of hardware acceleration.Jesse Gross
Currently each driver that is capable of vlan hardware acceleration must be aware of the vlan groups that are configured and then pass the stripped tag to a specialized receive function. This is different from other types of hardware offload in that it places a significant amount of knowledge in the driver itself rather keeping it in the networking core. This makes vlan offloading function more similarly to other forms of offloading (such as checksum offloading or TSO) by doing the following: * On receive, stripped vlans are passed directly to the network core, without attempting to check for vlan groups or reconstructing the header if no group * vlans are made less special by folding the logic into the main receive routines * On transmit, the device layer will add the vlan header in software if the hardware doesn't support it, instead of spreading that logic out in upper layers, such as bonding. There are a number of advantages to this: * Fixes all bugs with drivers incorrectly dropping vlan headers at once. * Avoids having to disable VLAN acceleration when in promiscuous mode (good for bridging since it always puts devices in promiscuous mode). * Keeps VLAN tag separate until given to ultimate consumer, which avoids needing to do header reconstruction as in tg3 unless absolutely necessary. * Consolidates common code in core networking. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Avoid hash table lookup to find group.Jesse Gross
A struct net_device always maps to zero or one vlan groups and we always know the device when we are looking up a group. We currently do a hash table lookup on the device to find the group but it is much simpler to just store a pointer. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Rename VLAN_GROUP_ARRAY_LEN to VLAN_N_VID.Jesse Gross
VLAN_GROUP_ARRAY_LEN is simply the number of possible vlan VIDs. Since vlan groups will soon be more of an implementation detail for vlan devices, rename the constant to be descriptive of its actual purpose. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-278021q: Use netif_copy_real_num_queues() to set queue countsBen Hutchings
This covers RX if necessary, as well as TX. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
