path: root/net/8021q
2009-09-26net: fix vlan_get_size to include vlan_flags sizeJohn Fastabend
Fix vlan_get_size to include vlan->flags. Currently, the size of the vlan flags is not included in the nlmsg size. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03vlan: adds drops accountingEric Dumazet
Its hard to tell if vlans are dropping frames, since every frame given to vlan_???_start_xmit() functions is accounted as fully transmitted by lower device. We can test dev_queue_xmit() return values to properly account for dropped frames. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03vlan: enable multiqueue xmitsEric Dumazet
vlan_dev_hard_start_xmit() & vlan_dev_hwaccel_hard_start_xmit() select txqueue number 0, instead of using index provided by skb_get_queue_mapping(). This is not correct after commit 2e59af3dcbdf11635c03f [vlan: multiqueue vlan device] because txq->tx_packets & txq->tx_bytes changes are performed on a single location, and not the right locking. Fix is to take the appropriate struct netdev_queue pointer Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02vlan: multiqueue vlan deviceEric Dumazet
vlan devices are currently not multi-queue capable. We can do that with a new rtnl_link_ops method, get_tx_queues(), called from rtnl_create_link() This new method gets num_tx_queues/real_num_tx_queues from real device. register_vlan_device() is also handled. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01vlan: Add support for net_devices_ops.ndo_fcoe_enable/_disable to VLANYi Zou
This adds implementation of the net_devices_ops.ndo_fcoe_enable/_disable to the VLAN driver. It checks if the real_dev has support for ndo_fcoe_enable/ ndo_fcoe_disable and if so, passes on to call the associated real_dev. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert pseudo-devices to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-14vlan: adds fcoe offload related net_device_ops and updates fcoe_ddp_xid fieldVasu Dev
Adds fcoe offload related net_device_ops functions vlan_dev_fcoe_ddp_setup and vlan_dev_fcoe_ddp_done, their implementation simply calls real eth device net_device_ops for FCoE DDP setup and done operations. Updates VLAN netdev field value for fcoe_ddp_xid from real eth device netdev. Above changes are required for fcoe DDP offload working on a VLAN interface. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: mark read-only arrays as constJan Engelhardt
String literals are constant, and usually, we can also tag the array of pointers const too, moving it to the .rodata section. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30vlan: allow creating vlan when real device is not upStephen Hemminger
There is no reason for the arbitrary restriction that device must be up to create a vlan. This patch was added to Vyatta kernel to resolve startup ordering issues where vlan's are created but real device was disabled. Note: the vlan already correctly inherits the operstate from real device; so if vlan is created and real device is marked down, the vlan is marked down. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-20vlan: Propagate physical MTU changesHerbert Xu
When the physical MTU changes we want to ensure that all existing VLAN device MTUs do not exceed the new underlying MTU. This patch adds that propagation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-108021q: Vlan driver should use rcu_barrier() on unload instead of ↵Jesper Dangaard Brouer
syncronize_net() The VLAN 8021q driver needs to call rcu_barrier() when unloading the module, instead of syncronize_net(). This is needed to make sure that outstanding call_rcu() callbacks have completed, before the callback function code is removed on module unload. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: convert unicast addr listJiri Pirko
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. It also relaxes the locking. Original spinlock (still used for multicast addresses) is not needed and is no longer used for a protection of this list. All reading and writing takes place under rtnl (with no changes). I also removed a possibility to specify the length of the address while adding or deleting unicast address. It's always dev->addr_len. The convertion touched especially e1000 and ixgbe codes when the change is not so trivial. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 13 +-- drivers/net/e1000/e1000_main.c | 24 +++-- drivers/net/ixgbe/ixgbe_common.c | 14 ++-- drivers/net/ixgbe/ixgbe_common.h | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/ixgbe/ixgbe_type.h | 4 +- drivers/net/macvlan.c | 11 +- drivers/net/mv643xx_eth.c | 11 +- drivers/net/niu.c | 7 +- drivers/net/virtio_net.c | 7 +- drivers/s390/net/qeth_l2_main.c | 6 +- drivers/scsi/fcoe/fcoe.c | 16 ++-- include/linux/netdevice.h | 18 ++-- net/8021q/vlan.c | 4 +- net/8021q/vlan_dev.c | 10 +- net/core/dev.c | 195 +++++++++++++++++++++++++++----------- net/dsa/slave.c | 10 +- net/packet/af_packet.c | 4 +- 18 files changed, 227 insertions(+), 137 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25net: remove COMPAT_NET_DEV_OPSAlexander Beregalov
All drivers are already converted to new net_device_ops API and nobody uses old API anymore. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18net: release dst entry in dev_hard_start_xmit()Eric Dumazet
One point of contention in high network loads is the dst_release() performed when a transmited skb is freed. This is because NIC tx completion calls dev_kree_skb() long after original call to dev_queue_xmit(skb). CPU cache is cold and the atomic op in dst_release() stalls. On SMP, this is quite visible if one CPU is 100% handling softirqs for a network device, since dst_clone() is done by other cpus, involving cache line ping pongs. It seems right place to release dst is in dev_hard_start_xmit(), for most devices but ones that are virtual, and some exceptions. David Miller suggested to define a new device flag, set in alloc_netdev_mq() (so that most devices set it at init time), and carefuly unset in devices which dont want a NULL skb->dst in their ndo_start_xmit(). List of devices that must clear this flag is : - loopback device, because it calls netif_rx() and quoting Patrick : "ip_route_input() doesn't accept loopback addresses, so loopback packets already need to have a dst_entry attached." - appletalk/ipddp.c : needs skb->dst in its xmit function - And all devices that call again dev_queue_xmit() from their xmit function (as some classifiers need skb->dst) : bonding, vlan, macvlan, eql, ifb, hdlc_fr Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18vlan: use struct netdev_queue counters instead of dev->statsEric Dumazet
We can update netdev_queue tx_bytes/tx_packets/tx_dropped counters instead of dev->stats ones, to reduce number of cache lines dirtied in xmit path. This fixes a performance problem on SMP when many different cpus take vlan tx path. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/isdn/00-INDEX drivers/net/wireless/iwlwifi/iwl-scan.c drivers/net/wireless/rndis_wlan.c net/mac80211/main.c
2009-04-25vlan: update vlan carrier state for admin up/downJay Vosburgh
Currently, the VLAN event handler does not adjust the VLAN device's carrier state when the real device or the VLAN device is set administratively up or down. The following patch adds a transfer of operating state from the real device to the VLAN device when the real device is administratively set up or down, and sets the carrier state up or down during init, open and close of the VLAN device. This permits observers above the VLAN device that care about the carrier state (bonding's link monitor, for example) to receive updates for administrative changes by more closely mimicing the behavior of real devices. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-04-21net: factor out ethtool invocation of vlan/macvlan driversPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/dev.c
2009-04-17vlan/macvlan: fix NULL pointer dereferences in ethtool handlersPatrick McHardy
Check whether the underlying device provides a set of ethtool ops before checking for individual handlers to avoid NULL pointer dereferences. Reported-by: Art van Breemen <ard@telegraafnet.nl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16Merge branch 'master' of ↵David S. Miller
2009-04-16gro: New frags interface to avoid copying shinfoHerbert Xu
It turns out that copying a 16-byte area at ~800k times a second can be really expensive :) This patch redesigns the frags GRO interface to avoid copying that area twice. The two disciples of the frags interface have been converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-13gro: Normalise skb before bypassing GRO on netpoll VLAN pathHerbert Xu
Hi: gro: Normalise skb before bypassing GRO on netpoll VLAN path When we detect netpoll RX on the GRO VLAN path we bail out and call the normal VLAN receive handler. However, the packet needs to be normalised by calling eth_type_trans since that's what the normal path expects (normally the GRO path does the fixup). This patch adds the necessary call to vlan_gro_frags. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Thanks, Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-17gro: Fix vlan/netpoll check againHerbert Xu
Jarek Poplawski pointed out that my previous fix is broken for VLAN+netpoll as if netpoll is enabled we'd end up in the normal receive path instead of the VLAN receive path. This patch fixes it by calling the VLAN receive hook. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-16GRO: Move netpoll checks to correct locationHerbert Xu
As my netpoll fix for net doesn't really work for net-next, we need this update to move the checks into the right place. As it stands we may pass freed skbs to netpoll_receive_skb. This patch also introduces a netpoll_rx_on function to avoid GRO completely if we're invoked through netpoll. This might seem paranoid but as netpoll may have an external receive hook it's better to be safe than sorry. I don't think we need this for 2.6.29 though since there's nothing immediately broken by it. This patch also moves the GRO_* return values to netdevice.h since VLAN needs them too (I tried to avoid this originally but alas this seems to be the easiest way out). This fixes a bug in VLAN where it continued to use the old return value 2 instead of the correct GRO_DROP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tokenring/tmspci.c drivers/net/ucc_geth_mii.c
2009-03-04vlan: Fix vlan-in-vlan crashes.David S. Miller
As analyzed by Patrick McHardy, vlan needs to reset it's netdev_ops pointer in it's ->init() function but this leaves the compat method pointers stale. Add a netdev_resync_ops() and call it from the vlan code. Any other driver which changes ->netdev_ops after register_netdevice() will need to call this new function after doing so too. With help from Patrick McHardy. Tested-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-tx.c net/8021q/vlan_core.c net/core/dev.c
2009-03-01netpoll: Add drop checks to all entry pointsHerbert Xu
The netpoll entry checks are required to ensure that we don't receive normal packets when invoked via netpoll. Unfortunately it only ever worked for the netif_receive_skb/netif_rx entry points. The VLAN (and subsequently GRO) entry point didn't have the check and therefore can trigger all sorts of weird problems. This patch adds the netpoll check to all entry points. I'm still uneasy with receiving at all under netpoll (which apparently is only used by the out-of-tree kdump code). The reason is it is perfectly legal to receive all data including headers into highmem if netpoll is off, but if you try to do that with netpoll on and someone gets a printk in an IRQ handler you're going to get a nice BUG_ON. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-08gro: Optimise Ethernet header comparisonHerbert Xu
This patch optimises the Ethernet header comparison to use 2-byte and 4-byte xors instead of memcmp. In order to facilitate this, the actual comparison is now carried out by the callers of the shared dev_gro_receive function. This has a significant impact when receiving 1500B packets through 10GbE. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-29gro: Avoid copying headers of unmerged packetsHerbert Xu
Unfortunately simplicity isn't always the best. The fraginfo interface turned out to be suboptimal. The problem was quite obvious. For every packet, we have to copy the headers from the frags structure into skb->head, even though for 99% of the packets this part is immediately thrown away after the merge. LRO didn't have this problem because it directly read the headers from the frags structure. This patch attempts to address this by creating an interface that allows GRO to access the headers in the first frag without having to copy it. Because all drivers that use frags place the headers in the first frag this optimisation should be enough. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-29gro: Move common completion code into helpersHerbert Xu
Currently VLAN still has a bit of common code handling the aftermath of GRO that's shared with the common path. This patch moves them into shared helpers to reduce code duplication. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26vlan: Export symbols as non GPL symbols.Ben Greear
In previous kernels, any kernel module could get access to the 'real-device' and the VLAN-ID for a particular VLAN. In more recent kernels, the code was restructured such that this is hard to do without accessing private .h files for any module that cannot use GPL-only symbols. Attached is a patch to once again allow non-GPL modules the ability to access the real-device and VLAN id for VLANs. Signed-off-by: Ben Greear <greearb@candelatech.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-08vlan: add neigh_setupFrank Blaschka
In case the real device has a neigh_setup function, this neigh_setup function should be used for the vlan device. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-06vlan: Add GRO interfacesHerbert Xu
This patch adds GRO interfaces for hardware-assisted VLAN reception. With this in place we're now at parity with LRO as far as the interface is concerned. That is, you can now take any LRO driver and convert it over to GRO. As the CB memory clashes with GRO's use of CB, I've removed it entirely by storing dev in skb->dev. This is OK because VLAN gets called first thing in netif_receive_skb and skb->dev is not used in between us calling netif_rx and netif_receive_skb getting called. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25vlan: fix convertion to net_device_opsEric Dumazet
commit 656299f706e52e0409733d704c2761f1b12d6954 (vlan: convert to net_device_ops) added a net_device_ops with a NULL ndo_start_xmit field. This gives a crash in dev_hard_start_xmit() Fix it using two net_device_ops structures, one for hwaccel vlan, one for non hwaccel vlan. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19vlan: convert to net_device_opsStephen Hemminger
Convert vlan devices and function pointers to net_device_ops. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/message/fusion/mptlan.c drivers/net/sfc/ethtool.c net/mac80211/debugfs_sta.c
2008-11-10vlan: Fix typos in proc output stringFerenc Wagner
Signed-off-by: Ferenc Wagner <wferi@niif.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath5k/base.c net/8021q/vlan_core.c
2008-11-04net: fix packet socket delivery in rx irq handlerPatrick McHardy
The changes to deliver hardware accelerated VLAN packets to packet sockets (commit bc1d0411) caused a warning for non-NAPI drivers. The __vlan_hwaccel_rx() function is called directly from the drivers RX function, for non-NAPI drivers that means its still in RX IRQ context: [ 27.779463] ------------[ cut here ]------------ [ 27.779509] WARNING: at kernel/softirq.c:136 local_bh_enable+0x37/0x81() ... [ 27.782520] [<c0264755>] netif_nit_deliver+0x5b/0x75 [ 27.782590] [<c02bba83>] __vlan_hwaccel_rx+0x79/0x162 [ 27.782664] [<f8851c1d>] atl1_intr+0x9a9/0xa7c [atl1] [ 27.782738] [<c0155b17>] handle_IRQ_event+0x23/0x51 [ 27.782808] [<c015692e>] handle_edge_irq+0xc2/0x102 [ 27.782878] [<c0105fd5>] do_IRQ+0x4d/0x64 Split hardware accelerated VLAN reception into two parts to fix this: - __vlan_hwaccel_rx just stores the VLAN TCI and performs the VLAN device lookup, then calls netif_receive_skb()/netif_rx() - vlan_hwaccel_do_receive(), which is invoked by netif_receive_skb() in softirq context, performs the real reception and delivery to packet sockets. Reported-and-tested-by: Ramon Casellas <ramon.casellas@cttc.es> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net/: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28vlan: propogate ethtool speed valuesStephen Hemminger
This enables more ethtool information. The speed and settings of the underlying device are propagated up. This makes services like SNMP that use ethtool to get speed setting, work when managing a vlan, without adding silly heurtistics into SNMP daemon. For the driver info, just use existing driver strings. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-20net: Use hton[sl]() instead of __constant_hton[sl]() where applicableArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-11vlan: vlan device not reading gso max size of parent.Alexander Duyck
The vlan devices are not reading the gso max size of the parent device. As a result devices that do not support 64K max gso size are currently failing. This issue is seen on 2.6.26 kernels as well and the same patch should be able to be applied without any issues. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22netdev: Handle ->addr_list_lock just like ->_xmit_lock for lockdep.David S. Miller
The new address list lock needs to handle the same device layering issues that the _xmit_lock one does. This integrates work done by Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
