path: root/net/8021q
2015-11-17vlan: Do not put vlan headers back on bridge and macvlan portsVlad Yasevich
When a vlan is configured with REORDER_HEADER set to 0, the vlan header is put back into the packet and makes it appear that the vlan header is still there even after it's been processed. This posses a problem for bridge and macvlan ports. The packets passed to those device may be forwarded and at the time of the forward, vlan headers end up being unexpectedly present. With the patch, we make sure that we do not put the vlan header back (when REORDER_HEADER is 0) if a bridge or macvlan has been configured on top of the vlan device. Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-03vlan: Invoke driver vlan hooks only if device is presentPadmanabh Ratnakar
NIC drivers mark device as detached during error recovery. It expects no manangement hooks to be invoked in this state. Invoke driver vlan hooks only if device is present. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@avagotech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-18net: 8021q: convert to using IFF_NO_QUEUEPhil Sutter
Signed-off-by: Phil Sutter <phil@nwl.cc> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-01vlan: Add GRO support for non hardware accelerated vlanToshiaki Makita
Currently packets with non-hardware-accelerated vlan cannot be handled by GRO. This causes low performance for 802.1ad and stacked vlan, as their vlan tags are currently not stripped by hardware. This patch adds GRO support for non-hardware-accelerated vlan and improves receive performance of them. Test Environment: vlan device (.1Q) on vlan device (.1ad) on ixgbe (82599) Result: - Before $ netperf -t TCP_STREAM -H 192.168.20.2 -l 60 Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 60.00 5233.17 Rx side CPU usage: %usr %sys %irq %soft %idle 0.27 58.03 0.00 41.70 0.00 - After $ netperf -t TCP_STREAM -H 192.168.20.2 -l 60 Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 60.00 7586.85 Rx side CPU usage: %usr %sys %irq %soft %idle 0.50 25.83 0.00 59.53 14.14 [ Register VLAN offloads with priority 10 -DaveM ] Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14vlan: Correctly propagate promisc|allmulti flags in notifier.Vlad Yasevich
Currently vlan notifier handler will try to update all vlans for a device when that device comes up. A problem occurs, however, when the vlan device was set to promiscuous, but not by the user (ex: a bridge). In that case, dev->gflags are not updated. What results is that the lower device ends up with an extra promiscuity count. Here are the backtraces that prove this: [62852.052179] [<ffffffff814fe248>] __dev_set_promiscuity+0x38/0x1e0 [62852.052186] [<ffffffff8160bcbb>] ? _raw_spin_unlock_bh+0x1b/0x40 [62852.052188] [<ffffffff814fe4be>] ? dev_set_rx_mode+0x2e/0x40 [62852.052190] [<ffffffff814fe694>] dev_set_promiscuity+0x24/0x50 [62852.052194] [<ffffffffa0324795>] vlan_dev_open+0xd5/0x1f0 [8021q] [62852.052196] [<ffffffff814fe58f>] __dev_open+0xbf/0x140 [62852.052198] [<ffffffff814fe88d>] __dev_change_flags+0x9d/0x170 [62852.052200] [<ffffffff814fe989>] dev_change_flags+0x29/0x60 The above comes from the setting the vlan device to IFF_UP state. [62852.053569] [<ffffffff814fe248>] __dev_set_promiscuity+0x38/0x1e0 [62852.053571] [<ffffffffa032459b>] ? vlan_dev_set_rx_mode+0x2b/0x30 [8021q] [62852.053573] [<ffffffff814fe8d5>] __dev_change_flags+0xe5/0x170 [62852.053645] [<ffffffff814fe989>] dev_change_flags+0x29/0x60 [62852.053647] [<ffffffffa032334a>] vlan_device_event+0x18a/0x690 [8021q] [62852.053649] [<ffffffff8161036c>] notifier_call_chain+0x4c/0x70 [62852.053651] [<ffffffff8109d456>] raw_notifier_call_chain+0x16/0x20 [62852.053653] [<ffffffff814f744d>] call_netdevice_notifiers+0x2d/0x60 [62852.053654] [<ffffffff814fe1a3>] __dev_notify_flags+0x33/0xa0 [62852.053656] [<ffffffff814fe9b2>] dev_change_flags+0x52/0x60 [62852.053657] [<ffffffff8150cd57>] do_setlink+0x397/0xa40 And this one comes from the notification code. What we end up with is a vlan with promiscuity count of 1 and and a physical device with a promiscuity count of 2. They should both have a count 1. To resolve this issue, vlan code can use dev_get_flags() api which correctly masks promiscuity and allmulti flags. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-02vlan: implement ndo_get_iflinkNicolas Dichtel
Don't use dev->iflink anymore. CC: Patrick McHardy <kaber@trash.net> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29vlan: Add features for stacked vlan deviceToshiaki Makita
Stacked vlan devices curretly have few features (GRO, HIGHDMA, LLTX). Since we have software fallbacks in case the NIC can not handle some features for multiple vlans, we can add the same features as the lower vlan devices for stacked vlan devices. This allows stacked vlan devices to create large (GSO) packets and not to segment packets. Those packets will be segmented by software on the real device, or even can be segmented by the NIC once TSO for multiple vlans becomes enabled by the following patches. The exception is those related to FCoE, which does not have a software fallback. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-18net: Fix high overhead of vlan sub-device teardown.David S. Miller
When a networking device is taken down that has a non-trivial number of VLAN devices configured under it, we eat a full synchronize_net() for every such VLAN device. This is because of the call chain: NETDEV_DOWN notifier --> vlan_device_event() --> dev_change_flags() --> __dev_change_flags() --> __dev_close() --> __dev_close_many() --> dev_deactivate_many() --> synchronize_net() This is kind of rediculous because we already have infrastructure for batching doing operation X to a list of net devices so that we only incur one sync. So make use of that by exporting dev_close_many() and adjusting it's interfaace so that the caller can fully manage the batch list. Use this in vlan_device_event() and all the overhead goes away. Reported-by: Salam Noureddine <noureddine@arista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-038021q: Use eth_<foo>_addr instead of memsetJoe Perches
Use the built-in function instead of memset. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: Kill dev_rebuild_headerEric W. Biederman
Now that there are no more users kill dev_rebuild_header and all of it's implementations. This is long overdue. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-23vlan: advertise link netns via netlinkNicolas Dichtel
Assign rtnl_link_ops->get_link_net() callback so that IFLA_LINK_NETNSID is added to rtnetlink messages. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-13net: rename vlan_tx_* helpers since "tx" is misleading thereJiri Pirko
The same macros are used for rx as well. So rename it. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-12vlan: Add ability to always enable TSO/UFOToshiaki Makita
Since the real device can segment packets by software, a vlan device can set TSO/UFO even when the real device doesn't have those features. Unlike GSO, this allows packets to be segmented after Qdisc. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-21vlan: Pass ethtool get_ts_info queries to real device.Richard Cochran
Commit a6111d3c "vlan: Pass SIOC[SG]HWTSTAMP ioctls to real device" intended to enable hardware time stamping on VLAN interfaces, but passing SIOCSHWTSTAMP is only half of the story. This patch adds the second half, by letting user space find out the time stamping capabilities of the device backing a VLAN interface. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-21vlan: make __vlan_hwaccel_put_tag return voidJiri Pirko
Always returns the same skb it gets, so change to void. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-07net: better IFF_XMIT_DST_RELEASE supportEric Dumazet
Testing xmit_more support with netperf and connected UDP sockets, I found strange dst refcount false sharing. Current handling of IFF_XMIT_DST_RELEASE is not optimal. Dropping dst in validate_xmit_skb() is certainly too late in case packet was queued by cpu X but dequeued by cpu Y The logical point to take care of drop/force is in __dev_queue_xmit() before even taking qdisc lock. As Julian Anastasov pointed out, need for skb_dst() might come from some packet schedulers or classifiers. This patch adds new helper to cleanly express needs of various drivers or qdiscs/classifiers. Drivers that need skb_dst() in their ndo_start_xmit() should call following helper in their setup instead of the prior : dev->priv_flags &= ~IFF_XMIT_DST_RELEASE; -> netif_keep_dst(dev); Instead of using a single bit, we use two bits, one being eventually rebuilt in bonding/team drivers. The other one, is permanent and blocks IFF_XMIT_DST_RELEASE being rebuilt in bonding/team. Eventually, we could add something smarter later. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-11net: Always untag vlan-tagged traffic on input.Vlad Yasevich
Currently the functionality to untag traffic on input resides as part of the vlan module and is build only when VLAN support is enabled in the kernel. When VLAN is disabled, the function vlan_untag() turns into a stub and doesn't really untag the packets. This seems to create an interesting interaction between VMs supporting checksum offloading and some network drivers. There are some drivers that do not allow the user to change tx-vlan-offload feature of the driver. These drivers also seem to assume that any VLAN-tagged traffic they transmit will have the vlan information in the vlan_tci and not in the vlan header already in the skb. When transmitting skbs that already have tagged data with partial checksum set, the checksum doesn't appear to be updated correctly by the card thus resulting in a failure to establish TCP connections. The following is a packet trace taken on the receiver where a sender is a VM with a VLAN configued. The host VM is running on doest not have VLAN support and the outging interface on the host is tg3: 10:12:43.503055 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q (0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27243, offset 0, flags [DF], proto TCP (6), length 60) 10.0.100.1.58545 > 10.0.100.10.ircu-2: Flags [S], cksum 0xdc39 (incorrect -> 0x48d9), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val 4294837885 ecr 0,nop,wscale 7], length 0 10:12:44.505556 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q (0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27244, offset 0, flags [DF], proto TCP (6), length 60) 10.0.100.1.58545 > 10.0.100.10.ircu-2: Flags [S], cksum 0xdc39 (incorrect -> 0x44ee), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val 4294838888 ecr 0,nop,wscale 7], length 0 This connection finally times out. I've only access to the TG3 hardware in this configuration thus have only tested this with TG3 driver. There are a lot of other drivers that do not permit user changes to vlan acceleration features, and I don't know if they all suffere from a similar issue. The patch attempt to fix this another way. It moves the vlan header stipping code out of the vlan module and always builds it into the kernel network core. This way, even if vlan is not supported on a virtualizatoin host, the virtual machines running on top of such host will still work with VLANs enabled. CC: Patrick McHardy <kaber@trash.net> CC: Nithin Nayak Sujir <nsujir@broadcom.com> CC: Michael Chan <mchan@broadcom.com> CC: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-29vlan: fail early when creating netdev named configWANG Cong
Similarly, vlan will create /proc/net/vlan/<dev>, so when we create dev with name "config", it will confict with /proc/net/vlan/config. Reported-by: Stephane Chazelas <stephane.chazelas@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-07-15net: set name_assign_type in alloc_netdev()Tom Gundersen
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert all users to pass NET_NAME_UNKNOWN. Coccinelle patch: @@ expression sizeof_priv, name, setup, txqs, rxqs, count; @@ ( -alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs) +alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs) | -alloc_netdev_mq(sizeof_priv, name, setup, count) +alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count) | -alloc_netdev(sizeof_priv, name, setup) +alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup) ) v9: move comments here from the wrong commit Signed-off-by: Tom Gundersen <teg@jklm.no> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-07vlan: Pass SIOC[SG]HWTSTAMP ioctls to real deviceStefan Sørensen
This allows applications to enable hardware timestamping without being aware of it being a vlan device and figuring out the real device. Signed-off-by: Stefan Sørensen <stefan.sorensen@spectralink.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-02vlan: free percpu stats in device destructorEric Dumazet
Madalin-Cristian reported crashs happening after a recent commit (5a4ae5f6e7d4 "vlan: unnecessary to check if vlan_pcpu_stats is NULL") ----------------------------------------------------------------------- root@p5040ds:~# vconfig add eth8 1 root@p5040ds:~# vconfig rem eth8.1 Unable to handle kernel paging request for data at address 0x2bc88028 Faulting instruction address: 0xc058e950 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=8 CoreNet Generic Modules linked in: CPU: 3 PID: 2167 Comm: vconfig Tainted: G W 3.16.0-rc3-00346-g65e85bf #2 task: e7264d90 ti: e2c2c000 task.ti: e2c2c000 NIP: c058e950 LR: c058ea30 CTR: c058e900 REGS: e2c2db20 TRAP: 0300 Tainted: G W (3.16.0-rc3-00346-g65e85bf) MSR: 00029002 <CE,EE,ME> CR: 48000428 XER: 20000000 DEAR: 2bc88028 ESR: 00000000 GPR00: c047299c e2c2dbd0 e7264d90 00000000 2bc88000 00000000 ffffffff 00000000 GPR08: 0000000f 00000000 000000ff 00000000 28000422 10121928 10100000 10100000 GPR16: 10100000 00000000 c07c5968 00000000 00000000 00000000 e2c2dc48 e7838000 GPR24: c07c5bac c07c58a8 e77290cc c07b0000 00000000 c05de6c0 e7838000 e2c2dc48 NIP [c058e950] vlan_dev_get_stats64+0x50/0x170 LR [c058ea30] vlan_dev_get_stats64+0x130/0x170 Call Trace: [e2c2dbd0] [ffffffea] 0xffffffea (unreliable) [e2c2dc20] [c047299c] dev_get_stats+0x4c/0x140 [e2c2dc40] [c0488ca8] rtnl_fill_ifinfo+0x3d8/0x960 [e2c2dd70] [c0489f4c] rtmsg_ifinfo+0x6c/0x110 [e2c2dd90] [c04731d4] rollback_registered_many+0x344/0x3b0 [e2c2ddd0] [c047332c] rollback_registered+0x2c/0x50 [e2c2ddf0] [c0476058] unregister_netdevice_queue+0x78/0xf0 [e2c2de00] [c058d800] unregister_vlan_dev+0xc0/0x160 [e2c2de20] [c058e360] vlan_ioctl_handler+0x1c0/0x550 [e2c2de90] [c045d11c] sock_ioctl+0x28c/0x2f0 [e2c2deb0] [c010d070] do_vfs_ioctl+0x90/0x7b0 [e2c2df20] [c010d7d0] SyS_ioctl+0x40/0x80 [e2c2df40] [c000f924] ret_from_syscall+0x0/0x3c Fix this problem by freeing percpu stats from dev->destructor() instead of ndo_uninit() Reported-by: Madalin-Cristian Bucur <madalin.bucur@freescale.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Madalin-Cristian Bucur <madalin.bucur@freescale.com> Fixes: 5a4ae5f6e7d4 ("vlan: unnecessary to check if vlan_pcpu_stats is NULL") Cc: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-218021q: fix a potential memory leakLi RongQing
skb_cow called in vlan_reorder_header does not free the skb when it failed, and vlan_reorder_header returns NULL to reset original skb when it is called in vlan_untag, lead to a memory leak. Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/bonding/bond_alb.c drivers/net/ethernet/altera/altera_msgdma.c drivers/net/ethernet/altera/altera_sgdma.c net/ipv6/xfrm6_output.c Several cases of overlapping changes. The xfrm6_output.c has a bug fix which overlaps the renaming of skb->local_df to skb->ignore_df. In the Altera TSE driver cases, the register access cleanups in net-next overlapped with bug fixes done in net. Similarly a bug fix to send ALB packets in the bonding driver using the right source address overlaps with cleanups in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-22vlan: more careful checksum features handlingMichal Kubeček
When combining real_dev's features and vlan_features, simple bitwise AND is used. This doesn't work well for checksum offloading features as if one set has NETIF_F_HW_CSUM and the other NETIF_F_IP_CSUM and/or NETIF_F_IPV6_CSUM, we end up with no checksum offloading. However, from the logical point of view (how can_checksum_protocol() works), NETIF_F_HW_CSUM contains the functionality of NETIF_F_IP_CSUM and NETIF_F_IPV6_CSUM so that the result should be IP/IPV6. Add helper function netdev_intersect_features() implementing this logic and use it in vlan_dev_fix_features(). Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16vlan: Fix lockdep warning with stacked vlan devices.Vlad Yasevich
This reverts commit dc8eaaa006350d24030502a4521542e74b5cb39f. vlan: Fix lockdep warning when vlan dev handle notification Instead we use the new new API to find the lock subclass of our vlan device. This way we can support configurations where vlans are interspersed with other devices: bond -> vlan -> macvlan -> vlan Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-12vlan: rename __vlan_find_dev_deep() to __vlan_find_dev_deep_rcu()dingtianhong
The __vlan_find_dev_deep should always called in RCU, according David's suggestion, rename to __vlan_find_dev_deep_rcu looks more reasonable. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-22vlan: unnecessary to check if vlan_pcpu_stats is NULLLi RongQing
if allocating memory for vlan_pcpu_stats failed, the device can not be operated Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-18vlan: Fix lockdep warning when vlan dev handle notificationdingtianhong
When I open the LOCKDEP config and run these steps: modprobe 8021q vconfig add eth2 20 vconfig add eth2.20 30 ifconfig eth2 xx.xx.xx.xx then the Call Trace happened: [32524.386288] ============================================= [32524.386293] [ INFO: possible recursive locking detected ] [32524.386298] 3.14.0-rc2-0.7-default+ #35 Tainted: G O [32524.386302] --------------------------------------------- [32524.386306] ifconfig/3103 is trying to acquire lock: [32524.386310] (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff814275f4>] dev_mc_sync+0x64/0xb0 [32524.386326] [32524.386326] but task is already holding lock: [32524.386330] (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff8141af83>] dev_set_rx_mode+0x23/0x40 [32524.386341] [32524.386341] other info that might help us debug this: [32524.386345] Possible unsafe locking scenario: [32524.386345] [32524.386350] CPU0 [32524.386352] ---- [32524.386354] lock(&vlan_netdev_addr_lock_key/1); [32524.386359] lock(&vlan_netdev_addr_lock_key/1); [32524.386364] [32524.386364] *** DEADLOCK *** [32524.386364] [32524.386368] May be due to missing lock nesting notation [32524.386368] [32524.386373] 2 locks held by ifconfig/3103: [32524.386376] #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff81431d42>] rtnl_lock+0x12/0x20 [32524.386387] #1: (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff8141af83>] dev_set_rx_mode+0x23/0x40 [32524.386398] [32524.386398] stack backtrace: [32524.386403] CPU: 1 PID: 3103 Comm: ifconfig Tainted: G O 3.14.0-rc2-0.7-default+ #35 [32524.386409] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [32524.386414] ffffffff81ffae40 ffff8800d9625ae8 ffffffff814f68a2 ffff8800d9625bc8 [32524.386421] ffffffff810a35fb ffff8800d8a8d9d0 00000000d9625b28 ffff8800d8a8e5d0 [32524.386428] 000003cc00000000 0000000000000002 ffff8800d8a8e5f8 0000000000000000 [32524.386435] Call Trace: [32524.386441] [<ffffffff814f68a2>] dump_stack+0x6a/0x78 [32524.386448] [<ffffffff810a35fb>] __lock_acquire+0x7ab/0x1940 [32524.386454] [<ffffffff810a323a>] ? __lock_acquire+0x3ea/0x1940 [32524.386459] [<ffffffff810a4874>] lock_acquire+0xe4/0x110 [32524.386464] [<ffffffff814275f4>] ? dev_mc_sync+0x64/0xb0 [32524.386471] [<ffffffff814fc07a>] _raw_spin_lock_nested+0x2a/0x40 [32524.386476] [<ffffffff814275f4>] ? dev_mc_sync+0x64/0xb0 [32524.386481] [<ffffffff814275f4>] dev_mc_sync+0x64/0xb0 [32524.386489] [<ffffffffa0500cab>] vlan_dev_set_rx_mode+0x2b/0x50 [8021q] [32524.386495] [<ffffffff8141addf>] __dev_set_rx_mode+0x5f/0xb0 [32524.386500] [<ffffffff8141af8b>] dev_set_rx_mode+0x2b/0x40 [32524.386506] [<ffffffff8141b3cf>] __dev_open+0xef/0x150 [32524.386511] [<ffffffff8141b177>] __dev_change_flags+0xa7/0x190 [32524.386516] [<ffffffff8141b292>] dev_change_flags+0x32/0x80 [32524.386524] [<ffffffff8149ca56>] devinet_ioctl+0x7d6/0x830 [32524.386532] [<ffffffff81437b0b>] ? dev_ioctl+0x34b/0x660 [32524.386540] [<ffffffff814a05b0>] inet_ioctl+0x80/0xa0 [32524.386550] [<ffffffff8140199d>] sock_do_ioctl+0x2d/0x60 [32524.386558] [<ffffffff81401a52>] sock_ioctl+0x82/0x2a0 [32524.386568] [<ffffffff811a7123>] do_vfs_ioctl+0x93/0x590 [32524.386578] [<ffffffff811b2705>] ? rcu_read_lock_held+0x45/0x50 [32524.386586] [<ffffffff811b39e5>] ? __fget_light+0x105/0x110 [32524.386594] [<ffffffff811a76b1>] SyS_ioctl+0x91/0xb0 [32524.386604] [<ffffffff815057e2>] system_call_fastpath+0x16/0x1b ======================================================================== The reason is that all of the addr_lock_key for vlan dev have the same class, so if we change the status for vlan dev, the vlan dev and its real dev will hold the same class of addr_lock_key together, so the warning happened. we should distinguish the lock depth for vlan dev and its real dev. v1->v2: Convert the vlan_netdev_addr_lock_key to an array of eight elements, which could support to add 8 vlan id on a same vlan dev, I think it is enough for current scene, because a netdev's name is limited to IFNAMSIZ which could not hold 8 vlan id, and the vlan dev would not meet the same class key with its real dev. The new function vlan_dev_get_lockdep_subkey() will return the subkey and make the vlan dev could get a suitable class key. v2->v3: According David's suggestion, I use the subclass to distinguish the lock key for vlan dev and its real dev, but it make no sense, because the difference for subclass in the lock_class_key doesn't mean that the difference class for lock_key, so I use lock_depth to distinguish the different depth for every vlan dev, the same depth of the vlan dev could have the same lock_class_key, I import the MAX_LOCK_DEPTH from the include/linux/sched.h, I think it is enough here, the lockdep should never exceed that value. v3->v4: Add a huge array of locking keys will waste static kernel memory and is not a appropriate method, we could use _nested() variants to fix the problem, calculate the depth for every vlan dev, and use the depth as the subclass for addr_lock_key. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/marvell/mvneta.c The mvneta.c conflict is a case of overlapping changes, a conversion to devm_ioremap_resource() vs. a conversion to netdev_alloc_pcpu_stats. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-29netpoll: Remove gfp parameter from __netpoll_setupEric W. Biederman
The gfp parameter was added in: commit 47be03a28cc6c80e3aa2b3e8ed6d960ff0c5c0af Author: Amerigo Wang <amwang@redhat.com> Date: Fri Aug 10 01:24:37 2012 +0000 netpoll: use GFP_ATOMIC in slave_enable_netpoll() and __netpoll_setup() slave_enable_netpoll() and __netpoll_setup() may be called with read_lock() held, so should use GFP_ATOMIC to allocate memory. Eric suggested to pass gfp flags to __netpoll_setup(). Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> The reason for the gfp parameter was removed in: commit c4cdef9b7183159c23c7302aaf270d64c549f557 Author: dingtianhong <dingtianhong@huawei.com> Date: Tue Jul 23 15:25:27 2013 +0800 bonding: don't call slave_xxx_netpoll under spinlocks The slave_xxx_netpoll will call synchronize_rcu_bh(), so the function may schedule and sleep, it should't be called under spinlocks. bond_netpoll_setup() and bond_netpoll_cleanup() are always protected by rtnl lock, it is no need to take the read lock, as the slave list couldn't be changed outside rtnl lock. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net> Nothing else that calls __netpoll_setup or ndo_netpoll_setup requires a gfp paramter, so remove the gfp parameter from both of these functions making the code clearer. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28vlan: Warn the user if lowerdev has bad vlan features.Vlad Yasevich
Some drivers incorrectly assign vlan acceleration features to vlan_features thus causing issues for Q-in-Q vlan configurations. Warn the user of such cases. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-27vlan: Set hard_header_len according to available accelerationVlad Yasevich
Currently, if the card supports CTAG acceleration we do not account for the vlan header even if we are configuring an 8021AD vlan. This may not be best since we'll do software tagging for 8021AD which will cause data copy on skb head expansion Configure the length based on available hw offload capabilities and vlan protocol. CC: Patrick McHardy <kaber@trash.net> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-26vlan: make a new function vlan_dev_vlan_proto() and exportdingtianhong
The vlan support 2 proto: 802.1q and 802.1ad, so make a new function called vlan_dev_vlan_proto() which could return the vlan proto for input dev. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14net: Replace u64_stats_fetch_begin_bh to u64_stats_fetch_begin_irqEric W. Biederman
Replace the bh safe variant with the hard irq safe variant. We need a hard irq safe variant to deal with netpoll transmitting packets from hard irq context, and we need it in most if not all of the places using the bh safe variant. Except on 32bit uni-processor the code is exactly the same so don't bother with a bh variant, just have a hard irq safe variant that everyone can use. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c drivers/net/xen-netback/netback.c Both the r8152 and netback conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-128021q: Convert uses of __constant_<foo> to <foo>Joe Perches
The use of __constant_<foo> has been unnecessary for quite awhile now. Make these uses consistent with the rest of the kernel. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-10vlan: Set correct source MAC address with TX VLAN offload enabledPeter Boström
With TX VLAN offload enabled the source MAC address for frames sent using the VLAN interface is currently set to the address of the real interface. This is wrong since the VLAN interface may be configured with a different address. The bug was introduced in commit 2205369a314e12fcec4781cc73ac9c08fc2b47de ("vlan: Fix header ops passthru when doing TX VLAN offload."). This patch sets the source address before calling the create function of the real interface. Signed-off-by: Peter Boström <peter.bostrom@netrounds.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-09vlan: use use ether_addr_equal_64bits to instead of ether_addr_equaldingtianhong
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be used when each argument is an array within a structure that contains at least two bytes of data beyond the array, so it is safe to use it for vlan, and make sense for fast path. Cc: Joe Perches <joe@perches.com> Cc: Patrick McHardy <kaber@trash.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-09vlan: slight optimization for vlan_do_receive()dingtianhong
According Joe's suggestion, maybe it'd be faster to add an unlikely to the test for PCKET_OTHERHOST, so I add it and see whether the performance could be better, although the differences is so small and negligible, but it is hard to catch that any lower device would set the skb type to PACKET_OTHERHOST, so most of time, I think it make sense to add unlikely for the test. Cc: Joe Perches <joe@perches.com> Cc: Patrick McHardy <kaber@trash.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-14net: introduce netdev_alloc_pcpu_stats() for driversWANG Cong
There are many drivers calling alloc_percpu() to allocate pcpu stats and then initializing ->syncp. So just introduce a helper function for them. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-218021q: Use ether_addr_copyJoe Perches
Use ether_addr_copy instead of memcpy(a, b, ETH_ALEN) to save some cycles on arm and powerpc. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-218021q: update descriptionYegor Yefremov
Replace deprecated 'vconfig' tool with 'ip' from 'iproute2'. Add some beautifications like replacing 'ethernet' with 'Ethernet' and removing unneeded spaces. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-31vlan: Fix header ops passthru when doing TX VLAN offload.David S. Miller
When the vlan code detects that the real device can do TX VLAN offloads in hardware, it tries to arrange for the real device's header_ops to be invoked directly. But it does so illegally, by simply hooking the real device's header_ops up to the VLAN device. This doesn't work because we will end up invoking a set of header_ops routines which expect a device type which matches the real device, but will see a VLAN device instead. Fix this by providing a pass-thru set of header_ops which will arrange to pass the proper real device instead. To facilitate this add a dev_rebuild_header(). There are implementations which provide a ->cache and ->create but not a ->rebuild (f.e. PLIP). So we need a helper function just like dev_hard_header() to avoid crashes. Use this helper in the one existing place where the header_ops->rebuild was being invoked, the neighbour code. With lots of help from Florian Westphal. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: "The biggest changes: - add lockdep support for seqcount/seqlocks structures, this unearthed both bugs and required extra annotation. - move the various kernel locking primitives to the new kernel/locking/ directory" * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) block: Use u64_stats_init() to initialize seqcounts locking/lockdep: Mark __lockdep_count_forward_deps() as static lockdep/proc: Fix lock-time avg computation locking/doc: Update references to kernel/mutex.c ipv6: Fix possible ipv6 seqlock deadlock cpuset: Fix potential deadlock w/ set_mems_allowed seqcount: Add lockdep functionality to seqcount/seqlock structures net: Explicitly initialize u64_stats_sync structures for lockdep locking: Move the percpu-rwsem code to kernel/locking/ locking: Move the lglocks code to kernel/locking/ locking: Move the rwsem code to kernel/locking/ locking: Move the rtmutex code to kernel/locking/ locking: Move the semaphore core to kernel/locking/ locking: Move the spinlock code to kernel/locking/ locking: Move the lockdep code to kernel/locking/ locking: Move the mutex code to kernel/locking/ hung_task debugging: Add tracepoint to report the hang x86/locking/kconfig: Update paravirt spinlock Kconfig description lockstat: Report avg wait and hold times lockdep, x86/alternatives: Drop ancient lockdep fixup message ...
2013-11-11vlan: Implement vlan_dev_get_egress_qos_mask as an inline.David S. Miller
This is to avoid very silly Kconfig dependencies for modules using this routine. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-07net/vlan: Provide read access to the vlan egress mapEyal Perry
Provide a method for read-only access to the vlan device egress mapping. Do this by refactoring vlan_dev_get_egress_qos_mask() such that now it receives as an argument the skb priority instead of pointer to the skb. Such an access is needed for the IBoE stack where the control plane goes through the network stack. This is an add-on step on top of commit d4a968658c "net/route: export symbol ip_tos2prio" which allowed the RDMA-CM to use ip_tos2prio. Signed-off-by: Eyal Perry <eyalpe@mellanox.com> Signed-off-by: Hadar Hen Zion <hadarh@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-06net: Explicitly initialize u64_stats_sync structures for lockdepJohn Stultz
In order to enable lockdep on seqcount/seqlock structures, we must explicitly initialize any locks. The u64_stats_sync structure, uses a seqcount, and thus we need to introduce a u64_stats_init() function and use it to initialize the structure. This unfortunately adds a lot of fairly trivial initialization code to a number of drivers. But the benefit of ensuring correctness makes this worth while. Because these changes are required for lockdep to be enabled, and the changes are quite trivial, I've not yet split this patch out into 30-some separate patches, as I figured it would be better to get the various maintainers thoughts on how to best merge this change along with the seqcount lockdep enablement. Feedback would be appreciated! Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: James Morris <jmorris@namei.org> Cc: Jesse Gross <jesse@nicira.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Mirko Lindner <mlindner@marvell.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Roger Luethi <rl@hellgate.ch> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Simon Horman <horms@verge.net.au> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Wensong Zhang <wensong@linux-vs.org> Cc: netdev@vger.kernel.org Link: http://lkml.kernel.org/r/1381186321-4906-2-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-19net: 8021q/bluetooth/bridge/can/ceph: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: include/linux/netdevice.h net/core/sock.c Trivial merge issues. Removal of "extern" for functions declaration in netdevice.h at the same time "const" was added to an argument. Two parallel line additions in net/core/sock.c Signed-off-by: David S. Miller <davem@davemloft.net>
