path: root/net/802
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-20net: introduce __skb_put_[zero, data, u8]yuan linyu
follow Johannes Berg, semantic patch file as below, @@ identifier p, p2; expression len; expression skb; type t, t2; @@ ( -p = __skb_put(skb, len); +p = __skb_put_zero(skb, len); | -p = (t)__skb_put(skb, len); +p = __skb_put_zero(skb, len); ) ... when != p ( p2 = (t2)p; -memset(p2, 0, len); | -memset(p, 0, len); ) @@ identifier p; expression len; expression skb; type t; @@ ( -t p = __skb_put(skb, len); +t p = __skb_put_zero(skb, len); ) ... when != p ( -memset(p, 0, len); ) @@ type t, t2; identifier p, p2; expression skb; @@ t *p; ... ( -p = __skb_put(skb, sizeof(t)); +p = __skb_put_zero(skb, sizeof(t)); | -p = (t *)__skb_put(skb, sizeof(t)); +p = __skb_put_zero(skb, sizeof(t)); ) ... when != p ( p2 = (t2)p; -memset(p2, 0, sizeof(*p)); | -memset(p, 0, sizeof(*p)); ) @@ expression skb, len; @@ -memset(__skb_put(skb, len), 0, len); +__skb_put_zero(skb, len); @@ expression skb, len, data; @@ -memcpy(__skb_put(skb, len), data, len); +__skb_put_data(skb, data, len); @@ expression SKB, C, S; typedef u8; identifier fn = {__skb_put}; fresh identifier fn2 = fn ## "_u8"; @@ - *(u8 *)fn(SKB, S) = C; + fn2(SKB, C); Signed-off-by: yuan linyu <Linyu.Yuan@alcatel-sbell.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-16networking: make skb_push & __skb_push return void pointersJohannes Berg
It seems like a historic accident that these return unsigned char *, and in many places that means casts are required, more often than not. Make these functions return void * and remove all the casts across the tree, adding a (u8 *) cast only where the unsigned char pointer was used directly, all done with the following spatch: @@ expression SKB, LEN; typedef u8; identifier fn = { skb_push, __skb_push, skb_push_rcsum }; @@ - *(fn(SKB, LEN)) + *(u8 *)fn(SKB, LEN) @@ expression E, SKB, LEN; identifier fn = { skb_push, __skb_push, skb_push_rcsum }; type T; @@ - E = ((T *)(fn(SKB, LEN))) + E = fn(SKB, LEN) @@ expression SKB, LEN; identifier fn = { skb_push, __skb_push, skb_push_rcsum }; @@ - fn(SKB, LEN)[0] + *(u8 *)fn(SKB, LEN) Note that the last part there converts from push(...)[0] to the more idiomatic *(u8 *)push(...). Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-16networking: make skb_put & friends return void pointersJohannes Berg
It seems like a historic accident that these return unsigned char *, and in many places that means casts are required, more often than not. Make these functions (skb_put, __skb_put and pskb_put) return void * and remove all the casts across the tree, adding a (u8 *) cast only where the unsigned char pointer was used directly, all done with the following spatch: @@ expression SKB, LEN; typedef u8; identifier fn = { skb_put, __skb_put }; @@ - *(fn(SKB, LEN)) + *(u8 *)fn(SKB, LEN) @@ expression E, SKB, LEN; identifier fn = { skb_put, __skb_put }; type T; @@ - E = ((T *)(fn(SKB, LEN))) + E = fn(SKB, LEN) which actually doesn't cover pskb_put since there are only three users overall. A handful of stragglers were converted manually, notably a macro in drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many instances in net/bluetooth/hci_sock.c. In the former file, I also had to fix one whitespace problem spatch introduced. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-20net: use core MTU range checking in misc driversJarod Wilson
firewire-net: - set min/max_mtu - remove fwnet_change_mtu nes: - set max_mtu - clean up nes_netdev_change_mtu xpnet: - set min/max_mtu - remove xpnet_dev_change_mtu hippi: - set min/max_mtu - remove hippi_change_mtu batman-adv: - set max_mtu - remove batadv_interface_change_mtu - initialization is a little async, not 100% certain that max_mtu is set in the optimal place, don't have hardware to test with rionet: - set min/max_mtu - remove rionet_change_mtu slip: - set min/max_mtu - streamline sl_change_mtu um/net_kern: - remove pointless ndo_change_mtu hsi/clients/ssi_protocol: - use core MTU range checking - remove now redundant ssip_pn_set_mtu ipoib: - set a default max MTU value - Note: ipoib's actual max MTU can vary, depending on if the device is in connected mode or not, so we'll just set the max_mtu value to the max possible, and let the ndo_change_mtu function continue to validate any new MTU change requests with checks for CM or not. Note that ipoib has no min_mtu set, and thus, the network core's mtu > 0 check is the only lower bounds here. mptlan: - use net core MTU range checking - remove now redundant mpt_lan_change_mtu fddi: - min_mtu = 21, max_mtu = 4470 - remove now redundant fddi_change_mtu (including export) fjes: - min_mtu = 8192, max_mtu = 65536 - The max_mtu value is actually one over IP_MAX_MTU here, but the idea is to get past the core net MTU range checks so fjes_change_mtu can validate a new MTU against what it supports (see fjes_support_mtu in fjes_hw.c) hsr: - min_mtu = 0 (calls ether_setup, max_mtu is 1500) f_phonet: - min_mtu = 6, max_mtu = 65541 u_ether: - min_mtu = 14, max_mtu = 15412 phonet/pep-gprs: - min_mtu = 576, max_mtu = 65530 - remove redundant gprs_set_mtu CC: netdev@vger.kernel.org CC: linux-rdma@vger.kernel.org CC: Stefan Richter <stefanr@s5r6.in-berlin.de> CC: Faisal Latif <faisal.latif@intel.com> CC: linux-rdma@vger.kernel.org CC: Cliff Whickman <cpw@sgi.com> CC: Robin Holt <robinmholt@gmail.com> CC: Jes Sorensen <jes@trained-monkey.org> CC: Marek Lindner <mareklindner@neomailbox.ch> CC: Simon Wunderlich <sw@simonwunderlich.de> CC: Antonio Quartulli <a@unstable.cc> CC: Sathya Prakash <sathya.prakash@broadcom.com> CC: Chaitra P B <chaitra.basappa@broadcom.com> CC: Suganath Prabu Subramani <suganath-prabu.subramani@broadcom.com> CC: MPT-FusionLinux.pdl@broadcom.com CC: Sebastian Reichel <sre@kernel.org> CC: Felipe Balbi <balbi@kernel.org> CC: Arvid Brodin <arvid.brodin@alten.se> CC: Remi Denis-Courmont <courmisch@gmail.com> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: Kill dev_rebuild_headerEric W. Biederman
Now that there are no more users kill dev_rebuild_header and all of it's implementations. This is long overdue. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-15net: set name_assign_type in alloc_netdev()Tom Gundersen
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert all users to pass NET_NAME_UNKNOWN. Coccinelle patch: @@ expression sizeof_priv, name, setup, txqs, rxqs, count; @@ ( -alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs) +alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs) | -alloc_netdev_mq(sizeof_priv, name, setup, count) +alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count) | -alloc_netdev(sizeof_priv, name, setup) +alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup) ) v9: move comments here from the wrong commit Signed-off-by: Tom Gundersen <teg@jklm.no> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-16neigh: use NEIGH_VAR_INIT in ndo_neigh_setup functions.Jiri Pirko
When ndo_neigh_setup is called, the bitfield used by NEIGH_VAR_SET is not initialized yet. This might cause confusion for the people who use NEIGH_VAR_SET in ndo_neigh_setup. So rather introduce NEIGH_VAR_INIT for usage in ndo_neigh_setup. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-14net: replace macros net_random and net_srandom with direct calls to prandomAruna-Hewapathirane
This patch removes the net_random and net_srandom macros and replaces them with direct calls to the prandom ones. As new commits only seem to use prandom_u32 there is no use to keep them around. This change makes it easier to grep for users of prandom_u32. Signed-off-by: Aruna-Hewapathirane <aruna.hewapathirane@gmail.com> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-09neigh: convert parms to an arrayJiri Pirko
This patch converts the neigh param members to an array. This allows easier manipulation which will be needed later on to provide better management of default values. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-23mrp: add periodictimer to allow retries when packets get lostNoel Burton-Krahn
MRP doesn't implement the periodictimer in 802.1Q, so it never retries if packets get lost. I ran into this problem when MRP sent a MVRP JoinIn before the interface was fully up. The JoinIn was lost, MRP didn't retry, and MVRP registration failed. Tested against Juniper QFabric switches Signed-off-by: Noel Burton-Krahn <noel@burton-krahn.com> Acked-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-14net/802/mrp: fix lockdep splatEric Dumazet
commit fb745e9a037895 ("net/802/mrp: fix possible race condition when calling mrp_pdu_queue()") introduced a lockdep splat. [ 19.735147] ================================= [ 19.735235] [ INFO: inconsistent lock state ] [ 19.735324] 3.9.2-build-0063 #4 Not tainted [ 19.735412] --------------------------------- [ 19.735500] inconsistent {IN-SOFTIRQ-W} -> {SOFTIRQ-ON-W} usage. [ 19.735592] rmmod/1840 [HC0[0]:SC0[0]:HE1:SE1] takes: [ 19.735682] (&(&app->lock)->rlock#2){+.?...}, at: [<f862bb5b>] mrp_uninit_applicant+0x69/0xba [mrp] app->lock is normally taken under softirq context, so disable BH to avoid the splat. Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: David Ward <david.ward@ll.mit.edu> Cc: Cong Wang <amwang@redhat.com> Tested-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-12net/802/mrp: fix possible race condition when calling mrp_pdu_queue()David Ward
(Adapted from a very similar change to net/802/garp.c by Cong Wang.) mrp_pdu_queue() should ways be called with the applicant spin lock. mrp_uninit_applicant() only holds the rtnl lock which is not enough; a race is possible because mrp_rcv() is called in BH context: mrp_rcv() |->mrp_pdu_parse_msg() |->mrp_pdu_parse_vecattr() |->mrp_pdu_parse_vecattr_event() |-> mrp_attr_event() |-> mrp_pdu_append_vecattr_event() |-> mrp_pdu_queue() Cc: Cong Wang <amwang@redhat.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David Ward <david.ward@ll.mit.edu> Acked-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07802: fix a possible race conditionCong Wang
(Resend with a better changelog) garp_pdu_queue() should ways be called with this spin lock. garp_uninit_applicant() only holds rtnl lock which is not enough here. A possible race can happen as garp_pdu_rcv() is called in BH context: garp_pdu_rcv() |->garp_pdu_parse_msg() |->garp_pdu_parse_attr() |-> garp_gid_event() Found by code inspection. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: David Ward <david.ward@ll.mit.edu> Cc: "Jorge Boncompte [DTI2]" <jorge@dti2.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-11mrp: make mrp_rcv staticStephen Hemminger
Sparse spotted local function that could be static. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-10net/802: Implement Multiple Registration Protocol (MRP)David Ward
Initial implementation of the Multiple Registration Protocol (MRP) from IEEE 802.1Q-2011, based on the existing implementation of the Generic Attribute Registration Protocol (GARP). Signed-off-by: David Ward <david.ward@ll.mit.edu> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-15tokenring: delete all remaining driver supportPaul Gortmaker
This represents the mass deletion of the of the tokenring support. It gets rid of: - the net/tr.c which the drivers depended on - the drivers/net component - the Kbuild infrastructure around it - any tokenring related CONFIG_ settings in any defconfigs - the tokenring headers in the include/linux dir - the firmware associated with the tokenring drivers. - any associated token ring documentation. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-15net: delete all instances of special processing for token ringPaul Gortmaker
We are going to delete the Token ring support. This removes any special processing in the core networking for token ring, (aside from net/tr.c itself), leaving the drivers and remaining tokenring support present but inert. The mass removal of the drivers and net/tr.c will be in a separate commit, so that the history of these files that we still care about won't have the giant deletion tied into their history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-09802: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13net/garp: fix GID rbtree orderingDavid Ward
The comparison operators were backwards in both garp_attr_lookup and garp_attr_create, so the entire GID rbtree was in reverse order. (There was no practical side effect to this though, except that PDUs were sent with attributes listed in reverse order, which is still valid by the protocol. This change is only for clarity.) Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Provide device string properly for USB i2400m wimax devices, also don't OOPS when providing firmware string. From Phil Sutter. 2) Add support for sh_eth SH7734 chips, from Nobuhiro Iwamatsu. 3) Add another device ID to USB zaurus driver, from Guan Xin. 4) Loop index start in pool vector iterator is wrong causing MAC to not get configured in bnx2x driver, fix from Dmitry Kravkov. 5) EQL driver assumes HZ=100, fix from Eric Dumazet. 6) Now that skb_add_rx_frag() can specify the truesize increment separately, do so in f_phonet and cdc_phonet, also from Eric Dumazet. 7) virtio_net accidently uses net_ratelimit() not only on the kernel warning but also the statistic bump, fix from Rick Jones. 8) ip_route_input_mc() uses fixed init_net namespace, oops, use dev_net(dev) instead. Fix from Benjamin LaHaise. 9) dev_forward_skb() needs to clear the incoming interface index of the SKB so that it looks like a new incoming packet, also from Benjamin LaHaise. 10) iwlwifi mistakenly initializes a channel entry as 2GHZ instead of 5GHZ, fix from Stanislav Yakovlev. 11) Missing kmalloc() return value checks in orinoco, from Santosh Nayak. 12) ath9k doesn't check for HT capabilities in the right way, it is checking ht_supported instead of the ATH9K_HW_CAP_HT flag. Fix from Sujith Manoharan. 13) Fix x86 BPF JIT emission of 16-bit immediate field of AND instructions, from Feiran Zhuang. 14) Avoid infinite loop in GARP code when registering sysfs entries. From David Ward. 15) rose protocol uses memcpy instead of memcmp in a device address comparison, oops. Fix from Daniel Borkmann. 16) Fix build of lpc_eth due to dev_hw_addr_rancom() interface being renamed to eth_hw_addr_random(). From Roland Stigge. 17) Make ipv6 RTM_GETROUTE interpret RTA_IIF attribute the same way that ipv4 does. Fix from Shmulik Ladkani. 18) via-rhine has an inverted bit test, causing suspend/resume regressions. Fix from Andreas Mohr. 19) RIONET assumes 4K page size, fix from Akinobu Mita. 20) Initialization of imask register in sky2 is buggy, because bits are "or'd" into an uninitialized local variable. Fix from Lino Sanfilippo. 21) Fix FCOE checksum offload handling, from Yi Zou. 22) Fix VLAN processing regression in e1000, from Jiri Pirko. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits) sky2: dont overwrite settings for PHY Quick link tg3: Fix 5717 serdes powerdown problem net: usb: cdc_eem: fix mtu net: sh_eth: fix endian check for architecture independent usb/rtl8150 : Remove duplicated definitions rionet: fix page allocation order of rionet_active via-rhine: fix wait-bit inversion. ipv6: Fix RTM_GETROUTE's interpretation of RTA_IIF to be consistent with ipv4 net: lpc_eth: Fix rename of dev_hw_addr_random net/netfilter/nfnetlink_acct.c: use linux/atomic.h rose_dev: fix memcpy-bug in rose_set_mac_address Fix non TBI PHY access; a bad merge undid bug fix in a previous commit. net/garp: avoid infinite loop if attribute already exists x86 bpf_jit: fix a bug in emitting the 16-bit immediate operand of AND bonding: emit event when bonding changes MAC mac80211: fix oper channel timestamp updation ath9k: Use HW HT capabilites properly MAINTAINERS: adding maintainer for ipw2x00 net: orinoco: add error handling for failed kmalloc(). net/wireless: ipw2x00: fix a typo in wiphy struct initilization ...
2012-04-01net/garp: avoid infinite loop if attribute already existsDavid Ward
An infinite loop occurred if garp_attr_create was called with the values of an existing attribute. This might happen if a previous leave request for the attribute has not yet been followed by a PDU transmission (or, if the application previously issued a join request for the attribute and is now issuing another one, without having issued a leave request). If garp_attr_create finds an existing attribute having the same values, return the address to it. Its state will then get updated (i.e., if it was in a leaving state, it will move into a non-leaving state and not get deleted during the next PDU transmission). To accomplish this fix, collapse garp_attr_insert into garp_attr_create (which is its only caller). Thanks to Jorge Boncompte [DTI2] <jorge@dti2.net> for contributing to this fix. Signed-off-by: David Ward <david.ward@ll.mit.edu> Acked-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31net: Fix files explicitly needing to include module.hPaul Gortmaker
With calls to modular infrastructure, these files really needs the full module.h header. Call it out so some of the cleanups of implicit and unrequired includes elsewhere can be cleaned up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23snap: remove one synchronize_net()Eric Dumazet
No need to wait for a rcu grace period after list insertion. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-21garp: use kfree_rcu()Eric Dumazet
Use kfree_rcu() instead of call_rcu(), remove garp_cleanup_module() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12garp: remove last synchronize_rcu() callEric Dumazet
When removing last vlan from a device, garp_uninit_applicant() calls synchronize_rcu() to make sure no user can still manipulate struct garp_applicant before we free it. Use call_rcu() instead, as a step to further net_device dismantle optimizations. Add the temporary garp_cleanup_module() function to make sure no pending call_rcu() are left at module unload time [ this will be removed when kfree_rcu() is available ] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-09garp: remove one synchronize_rcu() callEric Dumazet
Speedup vlan dismantling in CONFIG_VLAN_8021Q_GVRP=y cases, by using a call_rcu() to free the memory instead of waiting with expensive synchronize_rcu() [ while RTNL is held ] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ben Greear <greearb@candelatech.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-25net/802: add __rcu annotationsEric Dumazet
(struct net_device)->garp_port is rcu protected : (struct garp_port)->applicants is rcu protected : add __rcu annotation and proper rcu primitives. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-05-25net: remove COMPAT_NET_DEV_OPSAlexander Beregalov
All drivers are already converted to new net_device_ops API and nobody uses old API anymore. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-11tr: fix leakage of device in net/802/tr.cWei Yongjun
Add dev_put() after dev_get_by_index() to avoid leakage of device. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-06net/802/fddi.c: add MODULE_LICENSEAdrian Bunk
This patch adds the missing MODULE_LICENSE("GPL"). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21snap: use const for descriptorStephen Hemminger
Protocols should be able to use constant value for the descriptor. Minor whitespace cleanup as well Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tokenring/tmspci.c drivers/net/ucc_geth_mii.c
2009-03-03net: fix tokenring licenseMeelis Roos
Currently, modular tokenring ("tr") lacks a license and fails to load: tr: module license 'unspecified' taints kernel. tr: Unknown symbol proc_net_fops_create Beacuse of this, no tokenring driver can load if it depends on modular tr. Fix this by adding GPL module license as it is in the kernel. With this fix, tr module loads fine and tms380 driver also loads. Well, it does'nt work but that's a different bug. Signed-off-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26net/802: fix sparse warnings: context imbalanceHannes Eder
Impact: Attribute function with __acquires(...) resp. __releases(...). Fix this sparse warnings: net/802/tr.c:492:21: warning: context imbalance in 'rif_seq_start' - wrong count at exit net/802/tr.c:519:13: warning: context imbalance in 'rif_seq_stop' - unexpected unlock Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-22snap: handle registration error and compile warningStephen Hemminger
If this module can't load, it is almost certainly because something else is already bound to that SAP. So in that case, return the same error code as other SAP usage, and fail the module load. Also fixes a compiler warning about printk of non const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
