path: root/net/802
2012-05-15tokenring: delete all remaining driver supportPaul Gortmaker
This represents the mass deletion of the of the tokenring support. It gets rid of: - the net/tr.c which the drivers depended on - the drivers/net component - the Kbuild infrastructure around it - any tokenring related CONFIG_ settings in any defconfigs - the tokenring headers in the include/linux dir - the firmware associated with the tokenring drivers. - any associated token ring documentation. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-15net: delete all instances of special processing for token ringPaul Gortmaker
We are going to delete the Token ring support. This removes any special processing in the core networking for token ring, (aside from net/tr.c itself), leaving the drivers and remaining tokenring support present but inert. The mass removal of the drivers and net/tr.c will be in a separate commit, so that the history of these files that we still care about won't have the giant deletion tied into their history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-09802: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13net/garp: fix GID rbtree orderingDavid Ward
The comparison operators were backwards in both garp_attr_lookup and garp_attr_create, so the entire GID rbtree was in reverse order. (There was no practical side effect to this though, except that PDUs were sent with attributes listed in reverse order, which is still valid by the protocol. This change is only for clarity.) Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Provide device string properly for USB i2400m wimax devices, also don't OOPS when providing firmware string. From Phil Sutter. 2) Add support for sh_eth SH7734 chips, from Nobuhiro Iwamatsu. 3) Add another device ID to USB zaurus driver, from Guan Xin. 4) Loop index start in pool vector iterator is wrong causing MAC to not get configured in bnx2x driver, fix from Dmitry Kravkov. 5) EQL driver assumes HZ=100, fix from Eric Dumazet. 6) Now that skb_add_rx_frag() can specify the truesize increment separately, do so in f_phonet and cdc_phonet, also from Eric Dumazet. 7) virtio_net accidently uses net_ratelimit() not only on the kernel warning but also the statistic bump, fix from Rick Jones. 8) ip_route_input_mc() uses fixed init_net namespace, oops, use dev_net(dev) instead. Fix from Benjamin LaHaise. 9) dev_forward_skb() needs to clear the incoming interface index of the SKB so that it looks like a new incoming packet, also from Benjamin LaHaise. 10) iwlwifi mistakenly initializes a channel entry as 2GHZ instead of 5GHZ, fix from Stanislav Yakovlev. 11) Missing kmalloc() return value checks in orinoco, from Santosh Nayak. 12) ath9k doesn't check for HT capabilities in the right way, it is checking ht_supported instead of the ATH9K_HW_CAP_HT flag. Fix from Sujith Manoharan. 13) Fix x86 BPF JIT emission of 16-bit immediate field of AND instructions, from Feiran Zhuang. 14) Avoid infinite loop in GARP code when registering sysfs entries. From David Ward. 15) rose protocol uses memcpy instead of memcmp in a device address comparison, oops. Fix from Daniel Borkmann. 16) Fix build of lpc_eth due to dev_hw_addr_rancom() interface being renamed to eth_hw_addr_random(). From Roland Stigge. 17) Make ipv6 RTM_GETROUTE interpret RTA_IIF attribute the same way that ipv4 does. Fix from Shmulik Ladkani. 18) via-rhine has an inverted bit test, causing suspend/resume regressions. Fix from Andreas Mohr. 19) RIONET assumes 4K page size, fix from Akinobu Mita. 20) Initialization of imask register in sky2 is buggy, because bits are "or'd" into an uninitialized local variable. Fix from Lino Sanfilippo. 21) Fix FCOE checksum offload handling, from Yi Zou. 22) Fix VLAN processing regression in e1000, from Jiri Pirko. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits) sky2: dont overwrite settings for PHY Quick link tg3: Fix 5717 serdes powerdown problem net: usb: cdc_eem: fix mtu net: sh_eth: fix endian check for architecture independent usb/rtl8150 : Remove duplicated definitions rionet: fix page allocation order of rionet_active via-rhine: fix wait-bit inversion. ipv6: Fix RTM_GETROUTE's interpretation of RTA_IIF to be consistent with ipv4 net: lpc_eth: Fix rename of dev_hw_addr_random net/netfilter/nfnetlink_acct.c: use linux/atomic.h rose_dev: fix memcpy-bug in rose_set_mac_address Fix non TBI PHY access; a bad merge undid bug fix in a previous commit. net/garp: avoid infinite loop if attribute already exists x86 bpf_jit: fix a bug in emitting the 16-bit immediate operand of AND bonding: emit event when bonding changes MAC mac80211: fix oper channel timestamp updation ath9k: Use HW HT capabilites properly MAINTAINERS: adding maintainer for ipw2x00 net: orinoco: add error handling for failed kmalloc(). net/wireless: ipw2x00: fix a typo in wiphy struct initilization ...
2012-04-01net/garp: avoid infinite loop if attribute already existsDavid Ward
An infinite loop occurred if garp_attr_create was called with the values of an existing attribute. This might happen if a previous leave request for the attribute has not yet been followed by a PDU transmission (or, if the application previously issued a join request for the attribute and is now issuing another one, without having issued a leave request). If garp_attr_create finds an existing attribute having the same values, return the address to it. Its state will then get updated (i.e., if it was in a leaving state, it will move into a non-leaving state and not get deleted during the next PDU transmission). To accomplish this fix, collapse garp_attr_insert into garp_attr_create (which is its only caller). Thanks to Jorge Boncompte [DTI2] <jorge@dti2.net> for contributing to this fix. Signed-off-by: David Ward <david.ward@ll.mit.edu> Acked-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31net: Fix files explicitly needing to include module.hPaul Gortmaker
With calls to modular infrastructure, these files really needs the full module.h header. Call it out so some of the cleanups of implicit and unrequired includes elsewhere can be cleaned up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23snap: remove one synchronize_net()Eric Dumazet
No need to wait for a rcu grace period after list insertion. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-21garp: use kfree_rcu()Eric Dumazet
Use kfree_rcu() instead of call_rcu(), remove garp_cleanup_module() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12garp: remove last synchronize_rcu() callEric Dumazet
When removing last vlan from a device, garp_uninit_applicant() calls synchronize_rcu() to make sure no user can still manipulate struct garp_applicant before we free it. Use call_rcu() instead, as a step to further net_device dismantle optimizations. Add the temporary garp_cleanup_module() function to make sure no pending call_rcu() are left at module unload time [ this will be removed when kfree_rcu() is available ] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-09garp: remove one synchronize_rcu() callEric Dumazet
Speedup vlan dismantling in CONFIG_VLAN_8021Q_GVRP=y cases, by using a call_rcu() to free the memory instead of waiting with expensive synchronize_rcu() [ while RTNL is held ] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ben Greear <greearb@candelatech.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-25net/802: add __rcu annotationsEric Dumazet
(struct net_device)->garp_port is rcu protected : (struct garp_port)->applicants is rcu protected : add __rcu annotation and proper rcu primitives. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-05-25net: remove COMPAT_NET_DEV_OPSAlexander Beregalov
All drivers are already converted to new net_device_ops API and nobody uses old API anymore. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-11tr: fix leakage of device in net/802/tr.cWei Yongjun
Add dev_put() after dev_get_by_index() to avoid leakage of device. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-06net/802/fddi.c: add MODULE_LICENSEAdrian Bunk
This patch adds the missing MODULE_LICENSE("GPL"). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21snap: use const for descriptorStephen Hemminger
Protocols should be able to use constant value for the descriptor. Minor whitespace cleanup as well Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tokenring/tmspci.c drivers/net/ucc_geth_mii.c
2009-03-03net: fix tokenring licenseMeelis Roos
Currently, modular tokenring ("tr") lacks a license and fails to load: tr: module license 'unspecified' taints kernel. tr: Unknown symbol proc_net_fops_create Beacuse of this, no tokenring driver can load if it depends on modular tr. Fix this by adding GPL module license as it is in the kernel. With this fix, tr module loads fine and tms380 driver also loads. Well, it does'nt work but that's a different bug. Signed-off-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26net/802: fix sparse warnings: context imbalanceHannes Eder
Impact: Attribute function with __acquires(...) resp. __releases(...). Fix this sparse warnings: net/802/tr.c:492:21: warning: context imbalance in 'rif_seq_start' - wrong count at exit net/802/tr.c:519:13: warning: context imbalance in 'rif_seq_stop' - unexpected unlock Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-22snap: handle registration error and compile warningStephen Hemminger
If this module can't load, it is almost certainly because something else is already bound to that SAP. So in that case, return the same error code as other SAP usage, and fail the module load. Also fixes a compiler warning about printk of non const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20hippi: convert driver to net_device_opsStephen Hemminger
Convert the HIPPI infrastructure for use with net_device_ops. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20fddi: convert to new network device opsStephen Hemminger
Similar to ethernet. Convert infrastructure and the one lone FDDI driver (for the one lone user of that hardware??). Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-15net/802/fc.c: Fix compilation warningsManish Katiyar
Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25list_for_each_rcu must die: networkingPaul E. McKenney
All uses of list_for_each_rcu() can be profitably replaced by the easier-to-use list_for_each_entry_rcu(). This patch makes this change for networking, in preparation for removing the list_for_each_rcu() API entirely. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-16garp: retry sending JoinIn messages after allocation failuresPatrick McHardy
Increase reliability by retrying to send JoinIn messages after memory allocation failures on each TRANSMIT_PDU event until it succeeds. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05net: Add GARP applicant-only participantPatrick McHardy
Add an implementation of the GARP (Generic Attribute Registration Protocol) applicant-only participant. This will be used by the following patch to add GVRP support to the VLAN code. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05net: Add STP demux layerPatrick McHardy
Add small STP demux layer for demuxing STP PDUs based on MAC address. This is needed to run both GARP and STP in parallel (or even load the modules) since both use LLC_SAP_BSPAN. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19rcu: split list.h and move rcu-protected lists into rculist.hFranck Bui-Huu
Move rcu-protected lists from list.h into a new header file rculist.h. This is done because list are a very used primitive structure all over the kernel and it's currently impossible to include other header files in this list.h without creating some circular dependencies. For example, list.h implements rcu-protected list and uses rcu_dereference() without including rcupdate.h. It actually compiles because users of rcu_dereference() are macros. Others RCU functions could be used too but aren't probably because of this. Therefore this patch creates rculist.h which includes rcupdates without to many changes/troubles. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-31[TR] net/802/tr.c: sysctl_tr_rif_timeout staticAdrian Bunk
sysctl_tr_rif_timeout can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TR]: Use ctl paths to register net/token-ring/ tablePavel Emelyanov
The same thing for token-ring - use ctl paths and get rid of external references on the tr_table. Unfortunately, I couldn't split this patch into cleanup and use-the-paths parts. As a lame excuse I can say, that the cleanup is just moving the tr_table from one file to another - closet to a single variable, that this ctl table tunes. Since the source file becomes empty after the move, I remove it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-13[TOKENRING]: rif_timer not initialized properlyEric Dumazet
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap netdevice hardware header creation.Stephen Hemminger
Add inline for common usage of hardware header creation, and fix bug in IPV6 mcast where the assumption about negative return is an errno. Negative return from hard_header means not enough space was available,(ie -N bytes). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
