is valid
[ Upstream commit 7ca1db21ef8e0e6725b4d25deed1ca196f7efb28 ]
In p9_fd_create_unix, checking is performed to see if the addr (passed
as an argument) is NULL or not.
However, no check is performed to see if addr is a valid address, i.e.,
it doesn't entirely consist of only 0's.
The initialization of sun_server.sun_path to be equal to this faulty
addr value leads to an uninitialized variable, as detected by KMSAN.
Checking for this (faulty addr) and returning a negative error number
appropriately, resolves this issue.
Link: http://lkml.kernel.org/r/20201012042404.2508-1-anant.thazhemadam@gmail.com
Reported-by: syzbot+75d51fe5bf4ebe988518@syzkaller.appspotmail.com
Tested-by: syzbot+75d51fe5bf4ebe988518@syzkaller.appspotmail.com
Signed-off-by: Anant Thazhemadam <anant.thazhemadam@gmail.com>
Signed-off-by: Dominique Martinet <asmadeus@codewreck.org>
[ Upstream commit a39c46067c845a8a2d7144836e9468b7f072343e ]
p9_fd_open just fgets file descriptors passed in from userspace, but
doesn't verify that they are valid for read or writing. This gets
cought down in the VFS when actually attempting a read or write, but
a new warning added in linux-next upsets syzcaller.
Fix this by just verifying the fds early on.
Link: http://lkml.kernel.org/r/20200710085722.435850-1-hch@lst.de
Reported-by: syzbot+e6f77e16ff68b2434a2c@syzkaller.appspotmail.com
[Dominique: amend goto as per Doug Nazar's review]
commit 10aa14527f458e9867cf3d2cc6b8cb0f6704448b upstream.
Added checks to prevent GPFs from raising.
Link: http://lkml.kernel.org/r/20180727110558.5479-1-tomasbortoli@gmail.com
Signed-off-by: Tomas Bortoli <tomasbortoli@gmail.com>
Reported-by: syzbot+1a262da37d3bead15c39@syzkaller.appspotmail.com
Cc: stable@vger.kernel.org
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
commit 430ac66eb4c5b5c4eb846b78ebf65747510b30f1 upstream.
The patch adds the flush in p9_mux_poll_stop() as it the function used by
p9_conn_destroy(), in turn called by p9_fd_close() to stop the async
polling associated with the data regarding the connection.
Link: http://lkml.kernel.org/r/20180720092730.27104-1-tomasbortoli@gmail.com
Reported-by: syzbot+39749ed7d9ef6dfb23f6@syzkaller.appspotmail.com
To: Eric Van Hensbergen <ericvh@gmail.com>
To: Ron Minnich <rminnich@sandia.gov>
To: Latchesar Ionkov <lucho@ionkov.net>
Cc: Yiwen Jiang <jiangyiwen@huwei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
Pull 9pfs updates from Eric Van Hensbergen:
"Some accumulated cleanup patches for kerneldoc and unused variables as
well as some lock bug fixes and adding privateport option for RDMA"
* tag 'for-linus-4.1-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
net/9p: add a privport option for RDMA transport.
fs/9p: Initialize status in v9fs_file_do_lock.
net/9p: Initialize opts->privport as it should be.
net/9p: use memcpy() instead of snprintf() in p9_mount_tag_show()
9p: use unsigned integers for nwqid/count
9p: do not crash on unknown lock status code
9p: fix error handling in v9fs_file_do_lock
9p: remove unused variable in p9_fd_create()
9p: kerneldoc warning fixes
We're currently using an uninitialized value if option privport is not set,
thus (almost) always using a privileged port.
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
p is initialized but unused.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Having to say
> #ifdef CONFIG_NET_NS
> struct net *net;
> #endif
in structures is a little bit wordy and a little bit error prone.
Instead it is possible to say:
> typedef struct {
> struct net *net;
> #endif
> } possible_net_t;
And then in a header say:
> possible_net_t net;
Which is cleaner and easier to use and easier to test, as the
possible_net_t is always there no matter what the compile options.
Further this allows read_pnet and write_pnet to be functions in all
cases which is better at catching typos.
This change adds possible_net_t, updates the definitions of read_pnet
and write_pnet, updates optional struct net * variables that
write_pnet uses on to have the type possible_net_t, and finally fixes
up the b0rked users of read_pnet and write_pnet.
There is no point in allocating these structs separately.
Changing this makes the code a little simpler and saves a few bytes of
memory.
Reported-by: Herve Vico
Signed-off-by: Simon Derr <simon.derr@bull.net>
This request state is mostly useless, and properly implementing it
for RDMA would require an extra lock to be taken in handle_recv()
and in rdma_cancel() to avoid this race:
handle_recv() rdma_cancel()
. if req->state == SENT
req->state = RCVD .
. req->state = FLSH
So just get rid of it.
And move transport-specific code out of net/9p/client.c
We need barriers to guarantee this pattern works as intended:
[w] req->rc, 1 [r] req->status, 1
wmb rmb
[w] req->status, 1 [r] req->rc
Where the wmb ensures that rc gets written before status,
and the rmb ensures that if you observe status == 1, rc is the new value.
A few releases back a patch made virtio the default transport, however
it was done in a way which side-stepped the mechanism put in place to
allow for this selection. This patch cleans that up while maintaining
virtio as the default transport.
If the privport option is specified, the tcp transport binds local
address to a reserved port before connecting to the 9p server.
In some cases when 9P AUTH cannot be implemented, this is better than
nothing.
Signed-off-by: Jim Garlick <garlick@llnl.gov>
Pull v9fs update from Eric Van Hensbergen.
* tag 'for-linus-merge-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9P: Fix race between p9_write_work() and p9_fd_request()
9P: Fix race in p9_write_work()
9P: fix test at the end of p9_write_work()
9P: Fix race in p9_read_work()
9p: don't use __getname/__putname for uname/aname
net/9p: Check errno validity
fs/9p: avoid debug OOPS when reading a long symlink
Race scenario:
thread A thread B
p9_write_work() p9_fd_request()
if (list_empty
(&m->unsent_req_list))
spin_lock(&client->lock);
req->status = REQ_STATUS_UNSENT;
list_add_tail(..., &m->unsent_req_list);
spin_unlock(&client->lock);
if (n & POLLOUT &&
!test_and_set_bit(Wworksched, &m->wsched)
schedule_work(&m->wq);
--> not done because Wworksched is set
clear_bit(Wworksched, &m->wsched);
return;
--> nobody will take care of sending the new request.
This is not very likely to happen though, because p9_write_work()
being called with an empty unsent_req_list is not frequent.
But this also means that taking the lock earlier will not be costly.
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
Both modular callers of sock_map_fd() had been buggy; sctp one leaks
descriptor and file if copy_to_user() fails, 9p one shouldn't be
exposing file in the descriptor table at all.
Switch both to sock_alloc_file(), export it, unexport sock_map_fd() and
make it static.
See previous commit about p9_read_work() for details.
This fixes a similar race between p9_write_work() and p9_poll_mux()
At the end of p9_write_work() we want to test if there is still data to send.
This means:
- either the current request still has data to send (wsize != 0)
- or there are requests in the unsent queue
Race scenario between p9_read_work() and p9_poll_mux()
Data arrive, Rworksched is set, p9_read_work() is called.
thread A thread B
p9_read_work()
reads data
checks if new data ready. No.
gets preempted
More data arrive, p9_poll_mux() is called. .
p9_poll_mux() .
if (!test_and_set_bit(Rworksched, .
&m->wsched)) { .
schedule_work(&m->rq); .
-> does not schedule work because .
Rworksched is set .
clear_bit(Rworksched, &m->wsched);
return;
No work has been scheduled, and yet data are waiting.
Currently p9_read_work() checks if there is data to read,
and if not, it clears Rworksched.
I think it should clear Rworksched first, and then check if there is data to read.
flush[_delayed]_work_sync() are now spurious. Mark them deprecated
and convert all users to flush[_delayed]_work().
If you're cc'd and wondering what's going on: Now all workqueues are
non-reentrant and the regular flushes guarantee that the work item is
not pending or running on any CPU on return, so there's no reason to
use the sync flushes at all and they're going away.
This patch doesn't make any functional difference.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: linux-wireless@vger.kernel.org
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Avi Kivity <avi@redhat.com>
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
Reduce object size by deduplicating formats.
Use vsprintf extension %pV.
Rename P9_DPRINTK uses to p9_debug, align arguments.
Add function for _p9_debug and macro to add __func__.
Add missing "\n"s to p9_debug uses.
Remove embedded function names as p9_debug adds it.
Remove P9_EPRINTK macro and convert use to pr_<level>.
Add and use pr_fmt and pr_<level>.
$ size fs/9p/built-in.o*
62133 984 16000 79117 1350d fs/9p/built-in.o.new
67342 984 16928 85254 14d06 fs/9p/built-in.o.old
$ size net/9p/built-in.o*
88792 4148 22024 114964 1c114 net/9p/built-in.o.new
94072 4148 23232 121452 1da6c net/9p/built-in.o.old
Teach 9p filesystem to work in container with non-default network namespace.
(Note: I also patched the unix domain socket code but don't have a test case
for that. It's the same fix, I just don't have a server for it...)
To test, run diod server (http://code.google.com/p/diod):
diod -n -f -L stderr -l 172.23.255.1:9999 -c /dev/null -e /root
and then mount like so:
mount -t 9p -o port=9999,aname=/root,version=9p2000.L 172.23.255.1 /mnt
A container test environment is described at http://landley.net/lxc
Signed-off-by: Rob Landley <rob@landley.net>
Without this we can cause reclaim allocation in writepage.
[ 3433.448430] =================================
[ 3433.449117] [ INFO: inconsistent lock state ]
[ 3433.449117] 2.6.38-rc5+ #84
[ 3433.449117] ---------------------------------
[ 3433.449117] inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-R} usage.
[ 3433.449117] kswapd0/505 [HC0[0]:SC0[0]:HE1:SE1] takes:
[ 3433.449117] (iprune_sem){+++++-}, at: [<ffffffff810ebbab>] shrink_icache_memory+0x45/0x2b1
[ 3433.449117] {RECLAIM_FS-ON-W} state was registered at:
[ 3433.449117] [<ffffffff8107fe5f>] mark_held_locks+0x52/0x70
[ 3433.449117] [<ffffffff8107ff02>] lockdep_trace_alloc+0x85/0x9f
[ 3433.449117] [<ffffffff810d353d>] slab_pre_alloc_hook+0x18/0x3c
[ 3433.449117] [<ffffffff810d3fd5>] kmem_cache_alloc+0x23/0xa2
[ 3433.449117] [<ffffffff8127be77>] idr_pre_get+0x2d/0x6f
[ 3433.449117] [<ffffffff815434eb>] p9_idpool_get+0x30/0xae
[ 3433.449117] [<ffffffff81540123>] p9_client_rpc+0xd7/0x9b0
[ 3433.449117] [<ffffffff815427b0>] p9_client_clunk+0x88/0xdb
[ 3433.449117] [<ffffffff811d56e5>] v9fs_evict_inode+0x3c/0x48
[ 3433.449117] [<ffffffff810eb511>] evict+0x1f/0x87
[ 3433.449117] [<ffffffff810eb5c0>] dispose_list+0x47/0xe3
[ 3433.449117] [<ffffffff810eb8da>] evict_inodes+0x138/0x14f
[ 3433.449117] [<ffffffff810d90e2>] generic_shutdown_super+0x57/0xe8
[ 3433.449117] [<ffffffff810d91e8>] kill_anon_super+0x11/0x50
[ 3433.449117] [<ffffffff811d4951>] v9fs_kill_super+0x49/0xab
[ 3433.449117] [<ffffffff810d926e>] deactivate_locked_super+0x21/0x46
[ 3433.449117] [<ffffffff810d9e84>] deactivate_super+0x40/0x44
[ 3433.449117] [<ffffffff810ef848>] mntput_no_expire+0x100/0x109
[ 3433.449117] [<ffffffff810f0aeb>] sys_umount+0x2f1/0x31c
[ 3433.449117] [<ffffffff8102c87b>] system_call_fastpath+0x16/0x1b
[ 3433.449117] irq event stamp: 192941
[ 3433.449117] hardirqs last enabled at (192941): [<ffffffff81568dcf>] _raw_spin_unlock_irq+0x2b/0x30
[ 3433.449117] hardirqs last disabled at (192940): [<ffffffff810b5f97>] shrink_inactive_list+0x290/0x2f5
[ 3433.449117] softirqs last enabled at (188470): [<ffffffff8105fd65>] __do_softirq+0x133/0x152
[ 3433.449117] softirqs last disabled at (188455): [<ffffffff8102d7cc>] call_softirq+0x1c/0x28
[ 3433.449117]
[ 3433.449117] other info that might help us debug this:
[ 3433.449117] 1 lock held by kswapd0/505:
[ 3433.449117] #0: (shrinker_rwsem){++++..}, at: [<ffffffff810b52e2>] shrink_slab+0x38/0x15f
[ 3433.449117]
[ 3433.449117] stack backtrace:
[ 3433.449117] Pid: 505, comm: kswapd0 Not tainted 2.6.38-rc5+ #84
[ 3433.449117] Call Trace:
[ 3433.449117] [<ffffffff8107fbce>] ? valid_state+0x17e/0x191
[ 3433.449117] [<ffffffff81036896>] ? save_stack_trace+0x28/0x45
[ 3433.449117] [<ffffffff81080426>] ? check_usage_forwards+0x0/0x87
[ 3433.449117] [<ffffffff8107fcf4>] ? mark_lock+0x113/0x22c
[ 3433.449117] [<ffffffff8108105f>] ? __lock_acquire+0x37a/0xcf7
[ 3433.449117] [<ffffffff8107fc0e>] ? mark_lock+0x2d/0x22c
[ 3433.449117] [<ffffffff81081077>] ? __lock_acquire+0x392/0xcf7
[ 3433.449117] [<ffffffff810b14d2>] ? determine_dirtyable_memory+0x15/0x28
[ 3433.449117] [<ffffffff81081a33>] ? lock_acquire+0x57/0x6d
[ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1
[ 3433.449117] [<ffffffff81567d85>] ? down_read+0x47/0x5c
[ 3433.449117] [<ffffffff810b5385>] ? shrink_slab+0xdb/0x15f
[ 3433.449117] [<ffffffff810b69bc>] ? kswapd+0x574/0x96a
[ 3433.449117] [<ffffffff810b6448>] ? kswapd+0x0/0x96a
[ 3433.449117] [<ffffffff810714e2>] ? kthread+0x7d/0x85
[ 3433.449117] [<ffffffff8102d6d4>] ? kernel_thread_helper+0x4/0x10
[ 3433.449117] [<ffffffff81569200>] ? restore_args+0x0/0x30
[ 3433.449117] [<ffffffff81071465>] ? kthread+0x0/0x85
[ 3433.449117] [<ffffffff8102d6d0>] ? kernel_thread_helper+0x0/0x10
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
Now that cmwq can handle high concurrency, it's more efficient to use
work than a dedicated kthread. Convert p9_poll_proc() to a work
function for p9_poll_work and make p9_pollwake() schedule it on each
poll event. The work is sync flushed on module exit.
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Cc: v9fs-developer@lists.sourceforge.net
With cmwq, there's no reason to use a dedicated workqueue in trans_fd.
Drop p9_mux_wq and use system_wq instead. The used work items are
already sync canceled in p9_conn_destroy() and doesn't require further
synchronization.
The function has an unsigned return type, but returns a negative constant
to indicate an error condition. The result of calling the function is
always stored in a variable of type (signed) int, and thus unsigned can be
dropped from the return type.
A sematic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@exists@
identifier f;
constant C;
unsigned f(...)
* return -C;
// </smpl>
This is an off by one bug because strlen() doesn't count the NULL
terminator. We strcpy() addr into a fixed length array of size
UNIX_PATH_MAX later on.
The addr variable is the name of the device being mounted.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Options pointer is being moved before calling kfree() which seems
to cause problems. This uses a separate pointer to track and free
original allocation.
Signed-off-by: Venkateswararao Jujjuri <jvrao@us.ibm.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>w
* if we fail in p9_conn_create(), we shouldn't leak references to struct file.
Logics in ->close() doesn't help - ->trans is already gone by the time it's
called.
* sock_create_kern() can fail.
* use of sock_map_fd() is all fscked up; I'd fixed most of that, but the
rest will have to wait for a bit more work in net/socket.c (we still are
violating the basic rule of working with descriptor table: "once the reference
is installed there, don't rely on finding it there again").
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
Fix the comments -- mostly the improper and/or missing descriptions
of function parameters.
Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu>
It is not safe to use match_int without checking the token type returned
by match_token (especially when the token type returned is Opt_err and
args is empty). Fix it.
Currently the 9p code crashes when a operation is interrupted, i.e. for
example when the user presses ^C while reading from a file.
This patch fixes the code that is responsible for interruption and flushing
of 9P operations.
Signed-off-by: Latchesar Ionkov <lucho@ionkov.net>
Impact: Trust in the comment and add '__force' to the cast.
Fix this sparse warning:
net/9p/trans_fd.c:420:34: warning: cast adds address space to expression (<asn:1>)
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Fixes build problem with 9p when building with debug disabled.
Also contains some fixes for warnings which pop up when
CONFIG_NET_9P_DEBUG is disabled.
During the reorganization some of the multi-theaded locking assumptions were
accidently relaxed. This patch moves us back towards a more conservative
locking strategy.
Now that the new protocol functions are in place, this patch switches
the client code to using the new support code.
This removes the vestigial tag field from the p9_req_t structure.
One of the current debug options allows users to get a verbose dump of fcalls.
This isn't really necessary as correctly parsed protocol frames can be printed
as part of the code in the client functions. The consolidated printfcalls
structure would require new entries to be added for every extension. This
patch removes the debug print methods and their use.
Post p9_fd_poll() error path which checks m->poll_waddr[i] for PTR_ERR
value has the following problems.
* It's completely unused. Error value is set iff NULL @wait_address
has been specified to p9_pollwait() which is guaranteed not to
happen.
* It dereferences @m after deallocating it (introduced by 571ffeaf and
spotted by Raja R Harinath.
* It returned the wrong value on error. It should return
poll_waddr[i] but it returnes poll_waddr (introduced by 571ffeaf).
* p9_mux_poll_stop() doesn't handle PTR_ERR value. It will try to
operate on the PTR_ERR value as if it's a normal pointer and cause
oops.
As the error path is bogus in the first place, there's no reason to
hold onto it. Kill it.
Cc: Raja R Harinath <harinath@hurrynot.org>
This code moves the rpc function to the common client base,
reorganizes the flush code to be more simple and stable, and
makes the necessary adjustments to the underlying transports
to adapt to the new structure.
This reduces the overall amount of code duplication between the
transports and should make adding new transports more straightforward.
This patch reworks the read_work function to enable it to directly use a passed
in rcall structure. This should help allow us to remove unnecessary copies
in the future.
Apply the now common p9_req_t structure to the fd transport.
Simplify trans_fd by using new common client tagpool structure.
