[ Upstream commit 473c7dd1d7b59ff8f88a5154737e3eac78a96e5b ]
the client c is always dereferenced to get the rdma struct, so c has to
be a valid pointer at this point.
Gcc would optimize that away but let's make coverity happy...
Link: http://lkml.kernel.org/r/1536339057-21974-3-git-send-email-asmadeus@codewreck.org
Addresses-Coverity-ID: 102778 ("Dereference before null check")
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
[ Upstream commit 8b894adb2b7e1d1e64b8954569c761eaf3d51ab5 ]
9p/rdma would sometimes drop the connection and display errors in
recv_done when the user does ^C.
The errors were caused by recv buffers that were posted at the time
of disconnect, and we just do not want to disconnect when
down_interruptible is... interrupted.
Link: http://lkml.kernel.org/r/1535625307-18019-1-git-send-email-asmadeus@codewreck.org
commit 10aa14527f458e9867cf3d2cc6b8cb0f6704448b upstream.
Added checks to prevent GPFs from raising.
Link: http://lkml.kernel.org/r/20180727110558.5479-1-tomasbortoli@gmail.com
Signed-off-by: Tomas Bortoli <tomasbortoli@gmail.com>
Reported-by: syzbot+1a262da37d3bead15c39@syzkaller.appspotmail.com
Cc: stable@vger.kernel.org
Instead of exposing ib_get_dma_mr to ULPs and letting them use it more or
less unchecked, this moves the capability of creating a global rkey into
the RDMA core, where it can be easily audited. It also prints a warning
everytime this feature is used as well.
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
Trivial conversion to the new RDMA CQ API.
Acked-by: Dominique Martinet <dominique.martinet@cea.fr>
Add support for network namespaces in the ib_cma module. This is
accomplished by:
1. Adding network namespace parameter for rdma_create_id. This parameter is
used to populate the network namespace field in rdma_id_private.
rdma_create_id keeps a reference on the network namespace.
2. Using the network namespace from the rdma_id instead of init_net inside
of ib_cma, when listening on an ID and when looking for an ID for an
incoming request.
3. Decrementing the reference count for the appropriate network namespace
when calling rdma_destroy_id.
In order to preserve the current behavior init_net is passed when calling
from other modules.
Signed-off-by: Guy Shapiro <guysh@mellanox.com>
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
Signed-off-by: Yotam Kenneth <yotamke@mellanox.com>
Signed-off-by: Shachar Raindel <raindel@mellanox.com>
The pd now has a local_dma_lkey member which completely replaces
ib_get_dma_mr, use it instead.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Tested-by: Dominique Martinet <dominique.martinet@cea.fr>
Currently, ib_create_cq uses cqe and comp_vecotr instead
of the extendible ib_cq_init_attr struct.
Earlier patches already changed the vendors to work with
ib_cq_init_attr. This patch changes the consumers too.
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
RDMA can use the same kind of weak security as TCP by checking the
client can bind to a privileged port, which is better than nothing
if TAUTH isn't implemented.
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
When parsing options, make sure we have found a proper token before
doing a numeric conversion.
Without this check, the current code will end up following random
pointers that just happened to be on the stack when this function was
called, because match_token() will not touch the 'args' list unless a
valid token is found.
Signed-off-by: Simon Derr <simon.derr@bull.net>
Take into account posted recv buffers that will never receive their
reply.
The RDMA code posts a recv buffer for each request that it sends.
When a request is flushed, it is possible that this request will
never receive a reply, and that one recv buffer will stay unused on
the recv queue.
It is then possible, if this scenario happens several times, to have the
recv queue full, and have the 9pnet_rmda module unable to send new requests.
This will be needed by the flush logic.
We need barriers to guarantee this pattern works as intended:
[w] req->rc, 1 [r] req->status, 1
wmb rmb
[w] req->status, 1 [r] req->rc
Where the wmb ensures that rc gets written before status,
and the rmb ensures that if you observe status == 1, rc is the new value.
This patch gets rid of the following warning:
net/9p/trans_rdma.c:594:12: warning: ‘rdma_cancelled’ defined but not used [-Wunused-function]
static int rdma_cancelled(struct p9_client *client, struct p9_req_t *req)
The rdma_cancelled function is not called anywhere in the kernel
Signed-off-by: Andi Shyti <andi@etezian.org>
RDMA needs to post a buffer for each incoming reply.
Hence it needs to keep count of these and needs to be
aware of whether a flushed request has received a reply
or not.
This patch adds the cancelled() callback to the transport modules.
It is called when RFLUSH has been received and that the corresponding
request will never receive a reply.
In rdma_request():
If an error occurs between posting the recv and the send,
there will be a reply context posted without a pending
request.
Since there is no way to "un-post" it, we remember it and
skip post_recv() for the next request.
Most importantly:
- do not free the recv context (rpl_context) after a successful post_recv()
- but do free the send context (c) after a failed send.
rdma_request() should never be in charge of freeing rc.
When an error occurs:
* Either the rc buffer has been recv_post()'ed.
then kfree()'ing it certainly is a bad idea.
* Or is has not, and in that case req->rc still points to it,
hence it needs not be freed.
The current code keeps track of the number of buffers posted in the RQ,
and will prevent it from overflowing. But it does so by simply dropping
post requests (And leaking memory in the process).
When this happens there will actually be too few buffers posted, and
soon the 9P server will complain about 'RNR retry counter exceeded'
errors.
Instead, use a semaphore, and block until the RQ is ready for another
buffer to be posted.
A well-behaved server would not send twice the reply to a request.
But if it ever happens...
This additional check prevents the kernel from leaking memory
and possibly more nasty consequences in that unlikely event.
The current value is too low to get good performance.
p9_tag_alloc() takes care of that.
Reduce object size by deduplicating formats.
Use vsprintf extension %pV.
Rename P9_DPRINTK uses to p9_debug, align arguments.
Add function for _p9_debug and macro to add __func__.
Add missing "\n"s to p9_debug uses.
Remove embedded function names as p9_debug adds it.
Remove P9_EPRINTK macro and convert use to pr_<level>.
Add and use pr_fmt and pr_<level>.
$ size fs/9p/built-in.o*
62133 984 16000 79117 1350d fs/9p/built-in.o.new
67342 984 16928 85254 14d06 fs/9p/built-in.o.old
$ size net/9p/built-in.o*
88792 4148 22024 114964 1c114 net/9p/built-in.o.new
94072 4148 23232 121452 1da6c net/9p/built-in.o.old
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
RDMA/cma: Save PID of ID's owner
RDMA/cma: Add support for netlink statistics export
RDMA/cma: Pass QP type into rdma_create_id()
RDMA: Update exported headers list
RDMA/cma: Export enum cma_state in <rdma/rdma_cm.h>
RDMA/nes: Add a check for strict_strtoul()
RDMA/cxgb3: Don't post zero-byte read if endpoint is going away
RDMA/cxgb4: Use completion objects for event blocking
IB/srp: Fix integer -> pointer cast warnings
IB: Add devnode methods to cm_class and umad_class
IB/mad: Return EPROTONOSUPPORT when an RDMA device lacks the QP required
IB/uverbs: Add devnode method to set path/mode
RDMA/ucma: Add .nodename/.mode to tell userspace where to create device node
RDMA: Add netlink infrastructure
RDMA: Add error handling to ib_core_init()
The RDMA CM currently infers the QP type from the port space selected
by the user. In the future (eg with RDMA_PS_IB or XRC), there may not
be a 1-1 correspondence between port space and QP type. For netlink
export of RDMA CM state, we want to export the QP type to userspace,
so it is cleaner to explicitly associate a QP type to an ID.
Modify rdma_create_id() to allow the user to specify the QP type, and
use it to make our selections of datagram versus connected mode.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Probably just cut and pasted from the other parse_opts() implementations
in the 9p sources.
Without this we can cause reclaim allocation in writepage.
[ 3433.448430] =================================
[ 3433.449117] [ INFO: inconsistent lock state ]
[ 3433.449117] 2.6.38-rc5+ #84
[ 3433.449117] ---------------------------------
[ 3433.449117] inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-R} usage.
[ 3433.449117] kswapd0/505 [HC0[0]:SC0[0]:HE1:SE1] takes:
[ 3433.449117] (iprune_sem){+++++-}, at: [<ffffffff810ebbab>] shrink_icache_memory+0x45/0x2b1
[ 3433.449117] {RECLAIM_FS-ON-W} state was registered at:
[ 3433.449117] [<ffffffff8107fe5f>] mark_held_locks+0x52/0x70
[ 3433.449117] [<ffffffff8107ff02>] lockdep_trace_alloc+0x85/0x9f
[ 3433.449117] [<ffffffff810d353d>] slab_pre_alloc_hook+0x18/0x3c
[ 3433.449117] [<ffffffff810d3fd5>] kmem_cache_alloc+0x23/0xa2
[ 3433.449117] [<ffffffff8127be77>] idr_pre_get+0x2d/0x6f
[ 3433.449117] [<ffffffff815434eb>] p9_idpool_get+0x30/0xae
[ 3433.449117] [<ffffffff81540123>] p9_client_rpc+0xd7/0x9b0
[ 3433.449117] [<ffffffff815427b0>] p9_client_clunk+0x88/0xdb
[ 3433.449117] [<ffffffff811d56e5>] v9fs_evict_inode+0x3c/0x48
[ 3433.449117] [<ffffffff810eb511>] evict+0x1f/0x87
[ 3433.449117] [<ffffffff810eb5c0>] dispose_list+0x47/0xe3
[ 3433.449117] [<ffffffff810eb8da>] evict_inodes+0x138/0x14f
[ 3433.449117] [<ffffffff810d90e2>] generic_shutdown_super+0x57/0xe8
[ 3433.449117] [<ffffffff810d91e8>] kill_anon_super+0x11/0x50
[ 3433.449117] [<ffffffff811d4951>] v9fs_kill_super+0x49/0xab
[ 3433.449117] [<ffffffff810d926e>] deactivate_locked_super+0x21/0x46
[ 3433.449117] [<ffffffff810d9e84>] deactivate_super+0x40/0x44
[ 3433.449117] [<ffffffff810ef848>] mntput_no_expire+0x100/0x109
[ 3433.449117] [<ffffffff810f0aeb>] sys_umount+0x2f1/0x31c
[ 3433.449117] [<ffffffff8102c87b>] system_call_fastpath+0x16/0x1b
[ 3433.449117] irq event stamp: 192941
[ 3433.449117] hardirqs last enabled at (192941): [<ffffffff81568dcf>] _raw_spin_unlock_irq+0x2b/0x30
[ 3433.449117] hardirqs last disabled at (192940): [<ffffffff810b5f97>] shrink_inactive_list+0x290/0x2f5
[ 3433.449117] softirqs last enabled at (188470): [<ffffffff8105fd65>] __do_softirq+0x133/0x152
[ 3433.449117] softirqs last disabled at (188455): [<ffffffff8102d7cc>] call_softirq+0x1c/0x28
[ 3433.449117]
[ 3433.449117] other info that might help us debug this:
[ 3433.449117] 1 lock held by kswapd0/505:
[ 3433.449117] #0: (shrinker_rwsem){++++..}, at: [<ffffffff810b52e2>] shrink_slab+0x38/0x15f
[ 3433.449117]
[ 3433.449117] stack backtrace:
[ 3433.449117] Pid: 505, comm: kswapd0 Not tainted 2.6.38-rc5+ #84
[ 3433.449117] Call Trace:
[ 3433.449117] [<ffffffff8107fbce>] ? valid_state+0x17e/0x191
[ 3433.449117] [<ffffffff81036896>] ? save_stack_trace+0x28/0x45
[ 3433.449117] [<ffffffff81080426>] ? check_usage_forwards+0x0/0x87
[ 3433.449117] [<ffffffff8107fcf4>] ? mark_lock+0x113/0x22c
[ 3433.449117] [<ffffffff8108105f>] ? __lock_acquire+0x37a/0xcf7
[ 3433.449117] [<ffffffff8107fc0e>] ? mark_lock+0x2d/0x22c
[ 3433.449117] [<ffffffff81081077>] ? __lock_acquire+0x392/0xcf7
[ 3433.449117] [<ffffffff810b14d2>] ? determine_dirtyable_memory+0x15/0x28
[ 3433.449117] [<ffffffff81081a33>] ? lock_acquire+0x57/0x6d
[ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1
[ 3433.449117] [<ffffffff81567d85>] ? down_read+0x47/0x5c
[ 3433.449117] [<ffffffff810b5385>] ? shrink_slab+0xdb/0x15f
[ 3433.449117] [<ffffffff810b69bc>] ? kswapd+0x574/0x96a
[ 3433.449117] [<ffffffff810b6448>] ? kswapd+0x0/0x96a
[ 3433.449117] [<ffffffff810714e2>] ? kthread+0x7d/0x85
[ 3433.449117] [<ffffffff8102d6d4>] ? kernel_thread_helper+0x4/0x10
[ 3433.449117] [<ffffffff81569200>] ? restore_args+0x0/0x30
[ 3433.449117] [<ffffffff81071465>] ? kthread+0x0/0x85
[ 3433.449117] [<ffffffff8102d6d0>] ? kernel_thread_helper+0x0/0x10
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
Clean up some unused macros in net/*.
1. be left for code change. e.g. PGV_FROM_VMALLOC, PGV_FROM_VMALLOC, KMEM_SAFETYZONE.
2. never be used since introduced to kernel.
e.g. P9_RDMA_MAX_SGE, UTIL_CTRL_PKT_SIZE.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com>
Return -ENOMEM when erroring on kmalloc and fix memory leaks when returning on error.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Options pointer is being moved before calling kfree() which seems
to cause problems. This uses a separate pointer to track and free
original allocation.
Signed-off-by: Venkateswararao Jujjuri <jvrao@us.ibm.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>w
Fix the comments -- mostly the improper and/or missing descriptions
of function parameters.
Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu>
Currently the 9p code crashes when a operation is interrupted, i.e. for
example when the user presses ^C while reading from a file.
This patch fixes the code that is responsible for interruption and flushing
of 9P operations.
Signed-off-by: Latchesar Ionkov <lucho@ionkov.net>
Remove redundant argument comments in files of net/*
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
Removed duplicated #include <rdma/ib_verbs.h> in
net/9p/trans_rdma.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
The RDMA connection manager is fundamentally asynchronous.
Since the async callback context is the client pointer, the
transport in the client struct needs to be set prior to calling
the first async op.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
This patch implements the RDMA transport provider for 9P. It allows
mounts to be performed over iWARP and IB capable network interfaces.
Signed-off-by: Latchesar Ionkov <lionkov@lanl.gov>
