path: root/net/9p
2011-03-22[net/9p]: Introduce basic flow-control for VirtIO transport.Venkateswararao Jujjuri (JV)
Recent zerocopy work in the 9P VirtIO transport maps and pins user buffers into kernel memory for the server to work on them. Since the user process can initiate this kind of pinning with a simple read/write call, thousands of IO threads initiated by the user process can hog the system resources and could result into denial of service. This patch introduces flow control to avoid that extreme scenario. The ceiling limit to avoid denial of service attacks is set to relatively high (nr_free_pagecache_pages()/4) so that it won't interfere with regular usage, but can step in extreme cases to limit the total system hang. Since we don't have a global structure to accommodate this variable, I choose the virtio_chan as the home for this. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Reviewed-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22[net/9p] Don't re-pin pages on retrying virtqueue_add_buf().Venkateswararao Jujjuri (JV)
Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22[net/9p] Set the condition just before waking up.Venkateswararao Jujjuri (JV)
Given that the sprious wake-ups are common, we need to move the condition setting right next to the wake_up(). After setting the condition to req->status = REQ_STATUS_RCVD, sprious wakeups may cause the virtqueue back on the free list for someone else to use. This may result in kernel panic while relasing the pinned pages in p9_release_req_pages(). Also rearranged the while loop in req_done() for better redability. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22[net/9p] unconditional wake_up to proc waiting for space on VirtIO ringVenkateswararao Jujjuri (JV)
Process may wait to get space on VirtIO ring to send a transaction to VirtFS server. Current code just does a conditional wake_up() which means only one process will be woken up even if multiple processes are waiting. This fix makes the wake_up unconditional. Hence we won't have any processes waiting for-ever. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22net/9p: Fix compile warningAneesh Kumar K.V
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22net/9p: Convert the in the 9p rpc call path to GFP_NOFSAneesh Kumar K.V
Without this we can cause reclaim allocation in writepage. [ 3433.448430] ================================= [ 3433.449117] [ INFO: inconsistent lock state ] [ 3433.449117] 2.6.38-rc5+ #84 [ 3433.449117] --------------------------------- [ 3433.449117] inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-R} usage. [ 3433.449117] kswapd0/505 [HC0[0]:SC0[0]:HE1:SE1] takes: [ 3433.449117] (iprune_sem){+++++-}, at: [<ffffffff810ebbab>] shrink_icache_memory+0x45/0x2b1 [ 3433.449117] {RECLAIM_FS-ON-W} state was registered at: [ 3433.449117] [<ffffffff8107fe5f>] mark_held_locks+0x52/0x70 [ 3433.449117] [<ffffffff8107ff02>] lockdep_trace_alloc+0x85/0x9f [ 3433.449117] [<ffffffff810d353d>] slab_pre_alloc_hook+0x18/0x3c [ 3433.449117] [<ffffffff810d3fd5>] kmem_cache_alloc+0x23/0xa2 [ 3433.449117] [<ffffffff8127be77>] idr_pre_get+0x2d/0x6f [ 3433.449117] [<ffffffff815434eb>] p9_idpool_get+0x30/0xae [ 3433.449117] [<ffffffff81540123>] p9_client_rpc+0xd7/0x9b0 [ 3433.449117] [<ffffffff815427b0>] p9_client_clunk+0x88/0xdb [ 3433.449117] [<ffffffff811d56e5>] v9fs_evict_inode+0x3c/0x48 [ 3433.449117] [<ffffffff810eb511>] evict+0x1f/0x87 [ 3433.449117] [<ffffffff810eb5c0>] dispose_list+0x47/0xe3 [ 3433.449117] [<ffffffff810eb8da>] evict_inodes+0x138/0x14f [ 3433.449117] [<ffffffff810d90e2>] generic_shutdown_super+0x57/0xe8 [ 3433.449117] [<ffffffff810d91e8>] kill_anon_super+0x11/0x50 [ 3433.449117] [<ffffffff811d4951>] v9fs_kill_super+0x49/0xab [ 3433.449117] [<ffffffff810d926e>] deactivate_locked_super+0x21/0x46 [ 3433.449117] [<ffffffff810d9e84>] deactivate_super+0x40/0x44 [ 3433.449117] [<ffffffff810ef848>] mntput_no_expire+0x100/0x109 [ 3433.449117] [<ffffffff810f0aeb>] sys_umount+0x2f1/0x31c [ 3433.449117] [<ffffffff8102c87b>] system_call_fastpath+0x16/0x1b [ 3433.449117] irq event stamp: 192941 [ 3433.449117] hardirqs last enabled at (192941): [<ffffffff81568dcf>] _raw_spin_unlock_irq+0x2b/0x30 [ 3433.449117] hardirqs last disabled at (192940): [<ffffffff810b5f97>] shrink_inactive_list+0x290/0x2f5 [ 3433.449117] softirqs last enabled at (188470): [<ffffffff8105fd65>] __do_softirq+0x133/0x152 [ 3433.449117] softirqs last disabled at (188455): [<ffffffff8102d7cc>] call_softirq+0x1c/0x28 [ 3433.449117] [ 3433.449117] other info that might help us debug this: [ 3433.449117] 1 lock held by kswapd0/505: [ 3433.449117] #0: (shrinker_rwsem){++++..}, at: [<ffffffff810b52e2>] shrink_slab+0x38/0x15f [ 3433.449117] [ 3433.449117] stack backtrace: [ 3433.449117] Pid: 505, comm: kswapd0 Not tainted 2.6.38-rc5+ #84 [ 3433.449117] Call Trace: [ 3433.449117] [<ffffffff8107fbce>] ? valid_state+0x17e/0x191 [ 3433.449117] [<ffffffff81036896>] ? save_stack_trace+0x28/0x45 [ 3433.449117] [<ffffffff81080426>] ? check_usage_forwards+0x0/0x87 [ 3433.449117] [<ffffffff8107fcf4>] ? mark_lock+0x113/0x22c [ 3433.449117] [<ffffffff8108105f>] ? __lock_acquire+0x37a/0xcf7 [ 3433.449117] [<ffffffff8107fc0e>] ? mark_lock+0x2d/0x22c [ 3433.449117] [<ffffffff81081077>] ? __lock_acquire+0x392/0xcf7 [ 3433.449117] [<ffffffff810b14d2>] ? determine_dirtyable_memory+0x15/0x28 [ 3433.449117] [<ffffffff81081a33>] ? lock_acquire+0x57/0x6d [ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1 [ 3433.449117] [<ffffffff81567d85>] ? down_read+0x47/0x5c [ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1 [ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1 [ 3433.449117] [<ffffffff810b5385>] ? shrink_slab+0xdb/0x15f [ 3433.449117] [<ffffffff810b69bc>] ? kswapd+0x574/0x96a [ 3433.449117] [<ffffffff810b6448>] ? kswapd+0x0/0x96a [ 3433.449117] [<ffffffff810714e2>] ? kthread+0x7d/0x85 [ 3433.449117] [<ffffffff8102d6d4>] ? kernel_thread_helper+0x4/0x10 [ 3433.449117] [<ffffffff81569200>] ? restore_args+0x0/0x30 [ 3433.449117] [<ffffffff81071465>] ? kthread+0x0/0x85 [ 3433.449117] [<ffffffff8102d6d0>] ? kernel_thread_helper+0x0/0x10 Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: (46 commits) fs/9p: Make the writeback_fid owned by root fs/9p: Writeback dirty data before setattr fs/9p: call vmtruncate before setattr 9p opeation fs/9p: Properly update inode attributes on link fs/9p: Prevent multiple inclusion of same header fs/9p: Workaround vfs rename rehash bug fs/9p: Mark directory inode invalid for many directory inode operations fs/9p: Add . and .. dentry revalidation flag fs/9p: mark inode attribute invalid on rename, unlink and setattr fs/9p: Add support for marking inode attribute invalid fs/9p: Initialize root inode number for dotl fs/9p: Update link count correctly on different file system operations fs/9p: Add drop_inode 9p callback fs/9p: Add direct IO support in cached mode fs/9p: Fix inode i_size update in file_write fs/9p: set default readahead pages in cached mode fs/9p: Move writeback fid to v9fs_inode fs/9p: Add v9fs_inode fs/9p: Don't set stat.st_blocks based on nrpages fs/9p: Add inode hashing ...
2011-03-15net/9p: Implement syncfs 9P operationAneesh Kumar K.V
2011-03-15[net/9p] Small non-IO PDUs for zero-copy supporting transports.Venkateswararao Jujjuri (JV)
If a transport prefers payload to be sent separate from the PDU (P9_TRANS_PREF_PAYLOAD_SEP), there is no need to allocate msize PDU buffers(struct p9_fcall). This patch allocates only upto 4k buffers for this kind of transports and there won't be any change to the legacy transports. Hence, this patch on top of zero copy changes allows user to specify higher msizes through the mount option without hogging the kernel heap. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Handle Zero Copy TREAD/RERROR case in !dotl case.Venkateswararao Jujjuri (JV)
This takes care of copying out error buffers from user buffer payloads when we are using zero copy. This happens because the only payload buffer the server has to respond to the request is the user buffer given for the zero copy read. Because we only use zerocopy when the amount of data to transfer is greater than a certain size (currently 4K) and error strings are limited to ERRMAX (currently 128) we don't need to worry about there being sufficient space for the error to fit in the payload. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] readdir zerocopy changes for 9P2000.L protocol.Venkateswararao Jujjuri (JV)
Modify p9_client_readdir() to check the transport preference and act according If the preference is P9_TRANS_PREF_PAYLOAD_SEP, send the payload separately instead of putting it directly on PDU. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Write side zerocopy changes for 9P2000.L protocol.Venkateswararao Jujjuri (JV)
Modify p9_client_write() to check the transport preference and act accordingly. If the preference is P9_TRANS_PREF_PAYLOAD_SEP, send the payload separately instead of putting it directly on PDU. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Read side zerocopy changes for 9P2000.L protocol.Venkateswararao Jujjuri (JV)
Modify p9_client_read() to check the transport preference and act accordingly. If the preference is P9_TRANS_PREF_PAYLOAD_SEP, send the payload separately instead of putting it directly on PDU. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Add preferences to transport layer.Venkateswararao Jujjuri (JV)
This patch adds preferences field to the p9_trans_module. Through this, now transport layer can express its preference about the payload. i.e if payload neds to be part of the PDU or it prefers it to be sent sepearetly so that the transport layer can handle it in a better way. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Add gup/zero_copy support to VirtIO transport layer.Venkateswararao Jujjuri (JV)
Modify p9_virtio_request() and req_done() functions to support additional payload sent down to the transport layer through tc->pubuf and tc->pkbuf. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Assign type of transaction to tc->pdu->id which is otherwise unsed.Venkateswararao Jujjuri (JV)
This will be used by the transport layer to determine the out going request type. Transport layer uses this information to correctly place the mapped pages in the PDU. Patches following this will make use of this to achieve zero copy. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Preparation and helper functions for zero copyVenkateswararao Jujjuri (JV)
This patch prepares p9_fcall structure for zero copy. Added fields send the payload buffer information to the transport layer. In addition it adds a 'private' field for the transport layer to store mapped/pinned page information so that it can be freed/unpinned during req_done. This patch also creates trans_common.[ch] to house helper functions. It adds the following helper functions. p9_release_req_pages - Release pages after the transaction. p9_nr_pages - Return number of pages needed to accomodate the payload. payload_gup - Translates user buffer into kernel pages. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-02-01net/9p: replace p9_poll_task with a workTejun Heo
Now that cmwq can handle high concurrency, it's more efficient to use work than a dedicated kthread. Convert p9_poll_proc() to a work function for p9_poll_work and make p9_pollwake() schedule it on each poll event. The work is sync flushed on module exit. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: v9fs-developer@lists.sourceforge.net
2011-02-01net/9p: use system_wq instead of p9_mux_wqTejun Heo
With cmwq, there's no reason to use a dedicated workqueue in trans_fd. Drop p9_mux_wq and use system_wq instead. The used work items are already sync canceled in p9_conn_destroy() and doesn't require further synchronization. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: v9fs-developer@lists.sourceforge.net
2011-01-19net: cleanup unused macros in net directoryShan Wei
Clean up some unused macros in net/*. 1. be left for code change. e.g. PGV_FROM_VMALLOC, PGV_FROM_VMALLOC, KMEM_SAFETYZONE. 2. never be used since introduced to kernel. e.g. P9_RDMA_MAX_SGE, UTIL_CTRL_PKT_SIZE. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11net/9p: Use proper data typesM. Mohan Kumar
Use proper data types for storing the count of the binary blob and length of a string. Without this patch length calculation of string will always result in -1 because of comparision between signed and unsigned integer. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-12-08net/9p/protocol.c: Remove duplicated macros.Thiago Farina
Use the macros already provided by kernel.h file. Signed-off-by: Thiago Farina <tfransosi@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-28net/9p: Return error on read with NULL bufferSanchit Garg
This patch ensures that a read(fd, NULL, 10) returns EFAULT on a 9p file. Signed-off-by: Sanchit Garg <sancgarg@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Add datasync to client side TFSYNC/RFSYNC for dotlVenkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tfsync tag[2] fid[4] datasync[4] size[4] Rfsync tag[2] DESCRIPTION The Tfsync transaction transfers ("flushes") all modified in-core data of file identified by fid to the disk device (or other permanent storage device) where that file resides. If datasync flag is specified data will be fleshed but does not flush modified metadata unless that metadata is needed in order to allow a subsequent data retrieval to be correctly handled. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28net/9p: Return error if we fail to encode protocol dataAneesh Kumar K.V
We need to return error in case we fail to encode data in protocol buffer. This patch also return error in case of a failed copy_from_user. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28net/9p: Add waitq to VirtIO transport.Venkateswararao Jujjuri (JV)
If there is not enough space for the PDU on the VirtIO ring, current code returns -EIO propagating the error to user. This patch introduced a wqit_queue on the channel, and lets the process wait on this queue until VirtIO ring frees up. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28[net/9p]Serialize virtqueue operations to make VirtIO transport SMP safe.Venkateswararao Jujjuri (JV)
2010-10-289p: Implement TREADLINK operation for 9p2000.LM. Mohan Kumar
Synopsis size[4] TReadlink tag[2] fid[4] size[4] RReadlink tag[2] target[s] Description Readlink is used to return the contents of the symoblic link referred by fid. Contents of symboic link is returned as a response. target[s] - Contents of the symbolic link referred by fid. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Implement TGETLOCKM. Mohan Kumar
Synopsis size[4] TGetlock tag[2] fid[4] getlock[n] size[4] RGetlock tag[2] getlock[n] Description TGetlock is used to test for the existence of byte range posix locks on a file identified by given fid. The reply contains getlock structure. If the lock could be placed it returns F_UNLCK in type field of getlock structure. Otherwise it returns the details of the conflicting locks in the getlock structure getlock structure: type[1] - Type of lock: F_RDLCK, F_WRLCK start[8] - Starting offset for lock length[8] - Number of bytes to check for the lock If length is 0, check for lock in all bytes starting at the location 'start' through to the end of file pid[4] - PID of the process that wants to take lock/owns the task in case of reply client[4] - Client id of the system that owns the process which has the conflicting lock Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Implement TLOCKM. Mohan Kumar
Synopsis size[4] TLock tag[2] fid[4] flock[n] size[4] RLock tag[2] status[1] Description Tlock is used to acquire/release byte range posix locks on a file identified by given fid. The reply contains status of the lock request flock structure: type[1] - Type of lock: F_RDLCK, F_WRLCK, F_UNLCK flags[4] - Flags could be either of P9_LOCK_FLAGS_BLOCK - Blocked lock request, if there is a conflicting lock exists, wait for that lock to be released. P9_LOCK_FLAGS_RECLAIM - Reclaim lock request, used when client is trying to reclaim a lock after a server restrart (due to crash) start[8] - Starting offset for lock length[8] - Number of bytes to lock If length is 0, lock all bytes starting at the location 'start' through to the end of file pid[4] - PID of the process that wants to take lock client_id[4] - Unique client id status[1] - Status of the lock request, can be P9_LOCK_SUCCESS(0), P9_LOCK_BLOCKED(1), P9_LOCK_ERROR(2) or P9_LOCK_GRACE(3) P9_LOCK_SUCCESS - Request was successful P9_LOCK_BLOCKED - A conflicting lock is held by another process P9_LOCK_ERROR - Error while processing the lock request P9_LOCK_GRACE - Server is in grace period, it can't accept new lock requests in this period (except locks with P9_LOCK_FLAGS_RECLAIM flag set) Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28[9p] Introduce client side TFSYNC/RFSYNC for dotl.Venkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tfsync tag[2] fid[4] size[4] Rfsync tag[2] DESCRIPTION The Tfsync transaction transfers ("flushes") all modified in-core data of file identified by fid to the disk device (or other permanent storage device) where that file resides. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28net/9p: Add a Warning to catch NULL fids passed to p9_client_clunk().jvrao
2010-10-28net/9p: This patch implements TLERROR/RLERROR on the 9P client.Arun R Bharadwaj
Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-219p: client code cleanupstephen hemminger
Make p9_client_version static since only used in one file. Remove p9_client_auth because it is defined but never used. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/pcmcia/pcnet_cs.c net/caif/caif_socket.c
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-09-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) tcp: Fix >4GB writes on 64-bit. net/9p: Mount only matching virtio channels de2104x: fix ethtool tproxy: check for transparent flag in ip_route_newports ipv6: add IPv6 to neighbour table overflow warning tcp: fix TSO FACK loss marking in tcp_mark_head_lost 3c59x: fix regression from patch "Add ethtool WOL support" ipv6: add a missing unregister_pernet_subsys call s390: use free_netdev(netdev) instead of kfree() sgiseeq: use free_netdev(netdev) instead of kfree() rionet: use free_netdev(netdev) instead of kfree() ibm_newemac: use free_netdev(netdev) instead of kfree() smsc911x: Add MODULE_ALIAS() net: reset skb queue mapping when rx'ing over tunnel br2684: fix scheduling while atomic de2104x: fix TP link detection de2104x: fix power management de2104x: disable autonegotiation on broken hardware net: fix a lockdep splat e1000e: 82579 do not gate auto config of PHY by hardware during nominal use ...
2010-09-27net/9p: Mount only matching virtio channelsSven Eckelmann
p9_virtio_create will only compare the the channel's tag characters against the device name till the end of the channel's tag but not till the end of the device name. This means that if a user defines channels with the tags foo and foobar then he would mount foo when he requested foonot and may mount foo when he requested foobar. Thus it is necessary to check both string lengths against each other in case of a successful partial string match. Signed-off-by: Sven Eckelmann <sven.eckelmann@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27net/9p: fix memory handling/allocation in rdma_request()Davidlohr Bueso
Return -ENOMEM when erroring on kmalloc and fix memory leaks when returning on error. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-13fs/9p, net/9p: memory leak fixesLatchesar Ionkov
Four memory leak fixes in the 9P code. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-09-06net/9p/trans_fd.c: Fix unsigned return typeJulia Lawall
The function has an unsigned return type, but returns a negative constant to indicate an error condition. The result of calling the function is always stored in a variable of type (signed) int, and thus unsigned can be dropped from the return type. A sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @exists@ identifier f; constant C; @@ unsigned f(...) { <+... * return -C; ...+> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02fs/9p: destroy fid on failed removeAneesh Kumar K.V
9P spec says: "It is correct to consider remove to be a clunk with the side effect of removing the file if permissions allow. " So even if remove fails we need to destroy the fid. Without this patch an rmdir on a directory with contents leave the new cloned directory fid fid attached to fidlist. On umount we dump the fids on the fidlist ~# rmdir /mnt2/test4/ rmdir: failed to remove `/mnt2/test4/': Directory not empty ~# umount /mnt2/ ~# dmesg [ 228.474323] Found fid 3 not clunked Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-02net/9p: Implement TXATTRCREATE 9p callAneesh Kumar K.V
TXATTRCREATE: Prepare a fid for setting xattr value on a file system object. size[4] TXATTRCREATE tag[2] fid[4] name[s] attr_size[8] flags[4] size[4] RXATTRCREATE tag[2] txattrcreate gets a fid pointing to xattr. This fid can later be used to set the xattr value. flag value is derived from set Linux setxattr. The manpage says "The flags parameter can be used to refine the semantics of the operation. XATTR_CREATE specifies a pure create, which fails if the named attribute exists already. XATTR_REPLACE specifies a pure replace operation, which fails if the named attribute does not already exist. By default (no flags), the extended attribute will be created if need be, or will simply replace the value if the attribute exists." The actual setxattr operation happens when the fid is clunked. At that point the written byte count and the attr_size specified in TXATTRCREATE should be same otherwise an error will be returned. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-02net/9p: Implement attrwalk 9p callAneesh Kumar K.V
TXATTRWALK: Descend a ATTR namespace size[4] TXATTRWALK tag[2] fid[4] newfid[4] name[s] size[4] RXATTRWALK tag[2] size[8] txattrwalk gets a fid pointing to xattr. This fid can later be used to read the xattr value. If name is NULL the fid returned can be used to get the list of extended attribute associated to the file system object. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Implement LOPENM. Mohan Kumar
Implement 9p2000.L version of open(LOPEN) interface in 9p client. For LOPEN, no need to convert the flags to and from 9p mode to VFS mode. Synopsis: size[4] Tlopen tag[2] fid[4] mode[4] size[4] Rlopen tag[2] qid[13] iounit[4] [Fix mode bit format - jvrao@linux.vnet.ibm.com] Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbegren <ericvh@gmail.com>
2010-08-02fs/9p: This patch implements TLCREATE for 9p2000.L protocol.Venkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tlcreate tag[2] fid[4] name[s] flags[4] mode[4] gid[4] size[4] Rlcreate tag[2] qid[13] iounit[4] DESCRIPTION The Tlreate request asks the file server to create a new regular file with the name supplied, in the directory (dir) represented by fid. The mode argument specifies the permissions to use. New file is created with the uid if the fid and with supplied gid. The flags argument represent Linux access mode flags with which the caller is requesting to open the file with. Protocol allows all the Linux access modes but it is upto the server to allow/disallow any of these acess modes. If the server doesn't support any of the access mode, it is expected to return error. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Implement TMKDIRM. Mohan Kumar
Implement TMKDIR as part of 2000.L Work Synopsis size[4] Tmkdir tag[2] fid[4] name[s] mode[4] gid[4] size[4] Rmkdir tag[2] qid[13] Description mkdir asks the file server to create a directory with given name, mode and gid. The qid for the new directory is returned with the mkdir reply message. Note: 72 is selected as the opcode for TMKDIR from the reserved list. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Implement TMKNODM. Mohan Kumar
Synopsis size[4] Tmknod tag[2] fid[4] name[s] mode[4] major[4] minor[4] gid[4] size[4] Rmknod tag[2] qid[13] Description mknod asks the file server to create a device node with given major and minor number, mode and gid. The qid for the new device node is returned with the mknod reply message. [sripathik@in.ibm.com: Fix error handling code] Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
