path: root/net/Kconfig
2013-05-01netlink: kconfig: move mmap i/o into netlink kconfigDaniel Borkmann
Currently, in menuconfig, Netlink's new mmaped IO is the very first entry under the ``Networking support'' item and comes even before ``Networking options'': [ ] Netlink: mmaped IO Networking options ---> ... Lets move this into ``Networking options'' under netlink's Kconfig, since this might be more appropriate. Introduced by commit ccdfcc398 (``netlink: mmaped netlink: ring setup''). Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19netlink: mmaped netlink: ring setupPatrick McHardy
Add support for mmap'ed RX and TX ring setup and teardown based on the af_packet.c code. The following patches will use this to add the real mmap'ed receive and transmit functionality. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-21netlink: Diag core and basic socket info dumping (v2)Andrey Vagin
The netlink_diag can be built as a module, just like it's done in unix sockets. The core dumping message carries the basic info about netlink sockets: family, type and protocol, portis, dst_group, dst_portid, state. Groups can be received as an optional parameter NETLINK_DIAG_GROUPS. Netlink sockets cab be filtered by protocols. The socket inode number and cookie is reserved for future per-socket info retrieving. The per-protocol filtering is also reserved for future by requiring the sdiag_protocol to be zero. The file /proc/net/netlink doesn't provide enough information for dumping netlink sockets. It doesn't provide dst_group, dst_portid, groups above 32. v2: fix NETLINK_DIAG_MAX. Now it's equal to the last constant. Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <edumazet@google.com> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Gao feng <gaofeng@cn.fujitsu.com> Cc: Thomas Graf <tgraf@suug.ch> Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-10VSOCK: Introduce VM SocketsAndy King
VM Sockets allows communication between virtual machines and the hypervisor. User level applications both in a virtual machine and on the host can use the VM Sockets API, which facilitates fast and efficient communication between guest virtual machines and their host. A socket address family, designed to be compatible with UDP and TCP at the interface level, is provided. Today, VM Sockets is used by various VMware Tools components inside the guest for zero-config, network-less access to VMware host services. In addition to this, VMware's users are using VM Sockets for various applications, where network access of the virtual machine is restricted or non-existent. Examples of this are VMs communicating with device proxies for proprietary hardware running as host applications and automated testing of applications running within virtual machines. The VMware VM Sockets are similar to other socket types, like Berkeley UNIX socket interface. The VM Sockets module supports both connection-oriented stream sockets like TCP, and connectionless datagram sockets like UDP. The VM Sockets protocol family is defined as "AF_VSOCK" and the socket operations split for SOCK_DGRAM and SOCK_STREAM. For additional information about the use of VM Sockets, please refer to the VM Sockets Programming Guide available at: https://www.vmware.com/support/developer/vmci-sdk/ Signed-off-by: George Zhang <georgezhang@vmware.com> Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Andy king <acking@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-31wanrouter: completely decouple obsolete code from kernel.Paul Gortmaker
The original suggestion to delete wanrouter started earlier with the mainline commit f0d1b3c2bcc5de8a17af5f2274f7fcde8292b5fc ("net/wanrouter: Deprecate and schedule for removal") in May 2012. More importantly, Dan Carpenter found[1] that the driver had a fundamental breakage introduced back in 2008, with commit 7be6065b39c3 ("netdevice wanrouter: Convert directly reference of netdev->priv"). So we know with certainty that the code hasn't been used by anyone willing to at least take the effort to send an e-mail report of breakage for at least 4 years. This commit does a decouple of the wanrouter subsystem, by going after the Makefile/Kconfig and similar files, so that these mainline files that we are keeping do not have the big wanrouter file/driver deletion commit tied into their history. Once this commit is in place, we then can remove the obsolete cyclomx drivers and similar that have a dependency on CONFIG_WAN_ROUTER_DRIVERS. [1] http://www.spinics.net/lists/netdev/msg218670.html Originally-by: Joe Perches <joe@perches.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-01-11net: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2013-01-10net: Add support for XPS without sysfs being definedAlexander Duyck
This patch makes it so that we can support transmit packet steering without sysfs needing to be enabled. The reason for making this change is to make it so that a driver can make use of the XPS even while the sysfs portion of the interface is not present. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-04net: Add INET dependency on aes crypto for the sake of TCP fastopen.David S. Miller
Stephen Rothwell says: ==================== After merging the final tree, today's linux-next build (powerpc ppc44x_defconfig) failed like this: net/built-in.o: In function `tcp_fastopen_ctx_free': tcp_fastopen.c:(.text+0x5cc5c): undefined reference to `crypto_destroy_tfm' net/built-in.o: In function `tcp_fastopen_reset_cipher': (.text+0x5cccc): undefined reference to `crypto_alloc_base' net/built-in.o: In function `tcp_fastopen_reset_cipher': (.text+0x5cd6c): undefined reference to `crypto_destroy_tfm' Presumably caused by commit 104671636897 ("tcp: TCP Fast Open Server - header & support functions") from the net-next tree. I assume that some dependency on the CRYPTO infrastructure is missing. I have reverted commit 1bed966cc3bd ("Merge branch 'tcp_fastopen_server'") for today. ==================== Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-21net: drop NET dependency from HAVE_BPF_JITSam Ravnborg
There is no point having the NET dependency on the select target, as it forces all users to depend on NET to tell they support BPF_JIT. Move the config option to the bottom of the file - this could be a nice place also for future "selectable" config symbols. Fix up all users to drop the dependency on NET now that it is not required to supress warnings for non-NET builds. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-18econet: remove ancient bug ridden protocolStephen Hemminger
More spring cleaning! The ancient Econet protocol should go. Most of the bug fixes in recent years have been fixing security vulnerabilities. The hardware hasn't been made since the 90s, it is only interesting as an archeological curiosity. For the truly curious, or insomniac, go read up on it. http://en.wikipedia.org/wiki/Econet Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-17drop_monitor: convert to modular buildingNeil Horman
When I first wrote drop monitor I wrote it to just build monolithically. There is no reason it can't be built modularly as well, so lets give it that flexibiity. I've tested this by building it as both a module and monolithically, and it seems to work quite well Change notes: v2) * fixed for_each_present_cpu loops to be more correct as per Eric D. * Converted exit path failures to BUG_ON as per Ben H. v3) * Converted del_timer to del_timer_sync to close race noted by Ben H. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: "David S. Miller" <davem@davemloft.net> CC: Eric Dumazet <eric.dumazet@gmail.com> CC: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: allocation of ieee802154 devicealex.bluesman.smirnov@gmail.com
An interface to allocate and register ieee802154 compatible device. The allocated device has the following representation in memory: +-----------------------+ | struct wpan_phy | +-----------------------+ | struct mac802154_priv | +-----------------------+ | driver's private data | +-----------------------+ Used by device drivers to register new instance in the stack. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-03net: Add Open vSwitch kernel components.Jesse Gross
Open vSwitch is a multilayer Ethernet switch targeted at virtualized environments. In addition to supporting a variety of features expected in a traditional hardware switch, it enables fine-grained programmatic extension and flow-based control of the network. This control is useful in a wide variety of applications but is particularly important in multi-server virtualization deployments, which are often characterized by highly dynamic endpoints and the need to maintain logical abstractions for multiple tenants. The Open vSwitch datapath provides an in-kernel fast path for packet forwarding. It is complemented by a userspace daemon, ovs-vswitchd, which is able to accept configuration from a variety of sources and translate it into packet processing rules. See http://openvswitch.org for more information and userspace utilities. Signed-off-by: Jesse Gross <jesse@nicira.com>
2011-11-29bql: Byte queue limitsTom Herbert
Networking stack support for byte queue limits, uses dynamic queue limits library. Byte queue limits are maintained per transmit queue, and a dql structure has been added to netdev_queue structure for this purpose. Configuration of bql is in the tx-<n> sysfs directory for the queue under the byte_queue_limits directory. Configuration includes: limit_min, bql minimum limit limit_max, bql maximum limit hold_time, bql slack hold time Also under the directory are: limit, current byte limit inflight, current number of bytes on the queue Signed-off-by: Tom Herbert <therbert@google.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22net: add network priority cgroup infrastructure (v4)Neil Horman
This patch adds in the infrastructure code to create the network priority cgroup. The cgroup, in addition to the standard processes file creates two control files: 1) prioidx - This is a read-only file that exports the index of this cgroup. This is a value that is both arbitrary and unique to a cgroup in this subsystem, and is used to index the per-device priority map 2) priomap - This is a writeable file. On read it reports a table of 2-tuples <name:priority> where name is the name of a network interface and priority is indicates the priority assigned to frames egresessing on the named interface and originating from a pid in this cgroup This cgroup allows for skb priority to be set prior to a root qdisc getting selected. This is benenficial for DCB enabled systems, in that it allows for any application to use dcb configured priorities so without application modification Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> CC: Robert Love <robert.w.love@intel.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05NFC: add nfc subsystem coreLauro Ramos Venancio
The NFC subsystem core is responsible for providing the device driver interface. It is also responsible for providing an interface to the control operations and data exchange. Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-29bpf: depends on MODULESEric Dumazet
module_alloc() and module_free() are available only if CONFIG_MODULES=y Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27net: filter: Just In Time compiler for x86-64Eric Dumazet
In order to speedup packet filtering, here is an implementation of a JIT compiler for x86_64 It is disabled by default, and must be enabled by the admin. echo 1 >/proc/sys/net/core/bpf_jit_enable It uses module_alloc() and module_free() to get memory in the 2GB text kernel range since we call helpers functions from the generated code. EAX : BPF A accumulator EBX : BPF X accumulator RDI : pointer to skb (first argument given to JIT function) RBP : frame pointer (even if CONFIG_FRAME_POINTER=n) r9d : skb->len - skb->data_len (headlen) r8 : skb->data To get a trace of generated code, use : echo 2 >/proc/sys/net/core/bpf_jit_enable Example of generated code : # tcpdump -p -n -s 0 -i eth1 host 192.168.20.0/24 flen=18 proglen=147 pass=3 image=ffffffffa00b5000 JIT code: ffffffffa00b5000: 55 48 89 e5 48 83 ec 60 48 89 5d f8 44 8b 4f 60 JIT code: ffffffffa00b5010: 44 2b 4f 64 4c 8b 87 b8 00 00 00 be 0c 00 00 00 JIT code: ffffffffa00b5020: e8 24 7b f7 e0 3d 00 08 00 00 75 28 be 1a 00 00 JIT code: ffffffffa00b5030: 00 e8 fe 7a f7 e0 24 00 3d 00 14 a8 c0 74 49 be JIT code: ffffffffa00b5040: 1e 00 00 00 e8 eb 7a f7 e0 24 00 3d 00 14 a8 c0 JIT code: ffffffffa00b5050: 74 36 eb 3b 3d 06 08 00 00 74 07 3d 35 80 00 00 JIT code: ffffffffa00b5060: 75 2d be 1c 00 00 00 e8 c8 7a f7 e0 24 00 3d 00 JIT code: ffffffffa00b5070: 14 a8 c0 74 13 be 26 00 00 00 e8 b5 7a f7 e0 24 JIT code: ffffffffa00b5080: 00 3d 00 14 a8 c0 75 07 b8 ff ff 00 00 eb 02 31 JIT code: ffffffffa00b5090: c0 c9 c3 BPF program is 144 bytes long, so native program is almost same size ;) (000) ldh [12] (001) jeq #0x800 jt 2 jf 8 (002) ld [26] (003) and #0xffffff00 (004) jeq #0xc0a81400 jt 16 jf 5 (005) ld [30] (006) and #0xffffff00 (007) jeq #0xc0a81400 jt 16 jf 17 (008) jeq #0x806 jt 10 jf 9 (009) jeq #0x8035 jt 10 jf 17 (010) ld [28] (011) and #0xffffff00 (012) jeq #0xc0a81400 jt 16 jf 13 (013) ld [38] (014) and #0xffffff00 (015) jeq #0xc0a81400 jt 16 jf 17 (016) ret #65535 (017) ret #0 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24net: RPS: Enable hardware acceleration of RFSBen Hutchings
Allow drivers for multiqueue hardware with flow filter tables to accelerate RFS. The driver must: 1. Set net_device::rx_cpu_rmap to a cpu_rmap of the RX completion IRQs (in queue order). This will provide a mapping from CPUs to the queues for which completions are handled nearest to them. 2. Implement net_device_ops::ndo_rx_flow_steer. This operation adds or replaces a filter steering the given flow to the given RX queue, if possible. 3. Periodically remove filters for which rps_may_expire_flow() returns true. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2010-12-16net: Add batman-adv meshing protocolSven Eckelmann
B.A.T.M.A.N. (better approach to mobile ad-hoc networking) is a routing protocol for multi-hop ad-hoc mesh networks. The networks may be wired or wireless. See http://www.open-mesh.org/ for more information and user space tools. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28xps: Add CONFIG_XPSTom Herbert
This patch adds XPS_CONFIG option to enable and disable XPS. This is done in the same manner as RPS_CONFIG. This is also fixes build failure in XPS code when SMP is not enabled. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15Docs/Kconfig: Update: osdl.org -> linuxfoundation.orgMichael Witten
Some of the documentation refers to web pages under the domain `osdl.org'. However, `osdl.org' now redirects to `linuxfoundation.org'. Rather than rely on redirections, this patch updates the addresses appropriately; for the most part, only documentation that is meant to be current has been updated. The patch should be pretty quick to scan and check; each new web-page url was gotten by trying out the original URL in a browser and then simply copying the the redirected URL (formatting as necessary). There is some conflict as to which one of these domain names is preferred: linuxfoundation.org linux-foundation.org So, I wrote: info@linuxfoundation.org and got this reply: Message-ID: <4CE17EE6.9040807@linuxfoundation.org> Date: Mon, 15 Nov 2010 10:41:42 -0800 From: David Ames <david@linuxfoundation.org> ... linuxfoundation.org is preferred. The canonical name for our web site is www.linuxfoundation.org. Our list site is actually lists.linux-foundation.org. Regarding email linuxfoundation.org is preferred there are a few people who choose to use linux-foundation.org for their own reasons. Consequently, I used `linuxfoundation.org' for web pages and `lists.linux-foundation.org' for mailing-list web pages and email addresses; the only personal email address I updated from `@osdl.org' was that of Andrew Morton, who prefers `linux-foundation.org' according `git log'. Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-20ceph: factor out libceph from Ceph file systemYehuda Sadeh
This factors out protocol and low-level storage parts of ceph into a separate libceph module living in net/ceph and include/linux/ceph. This is mostly a matter of moving files around. However, a few key pieces of the interface change as well: - ceph_client becomes ceph_fs_client and ceph_client, where the latter captures the mon and osd clients, and the fs_client gets the mds client and file system specific pieces. - Mount option parsing and debugfs setup is correspondingly broken into two pieces. - The mon client gets a generic handler callback for otherwise unknown messages (mds map, in this case). - The basic supported/required feature bits can be expanded (and are by ceph_fs_client). No functional change, aside from some subtle error handling cases that got cleaned up in the refactoring process. Signed-off-by: Sage Weil <sage@newdream.net>
2010-09-14net: RPS needs to depend upon USE_GENERIC_SMP_HELPERSDavid S. Miller
You cannot invoke __smp_call_function_single() unless the architecture sets this symbol. Reported-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-05DNS: Separate out CIFS DNS Resolver codeWang Lei
Separate out the DNS resolver key type from the CIFS filesystem into its own module so that it can be made available for general use, including the AFS filesystem module. This facility makes it possible for the kernel to upcall to userspace to have it issue DNS requests, package up the replies and present them to the kernel in a useful form. The kernel is then able to cache the DNS replies as keys can be retained in keyrings. Resolver keys are of type "dns_resolver" and have a case-insensitive description that is of the form "[<type>:]<domain_name>". The optional <type> indicates the particular DNS lookup and packaging that's required. The <domain_name> is the query to be made. If <type> isn't given, a basic hostname to IP address lookup is made, and the result is stored in the key in the form of a printable string consisting of a comma-separated list of IPv4 and IPv6 addresses. This key type is supported by userspace helpers driven from /sbin/request-key and configured through /etc/request-key.conf. The cifs.upcall utility is invoked for UNC path server name to IP address resolution. The CIFS functionality is encapsulated by the dns_resolve_unc_to_ip() function, which is used to resolve a UNC path to an IP address for CIFS filesystem. This part remains in the CIFS module for now. See the added Documentation/networking/dns_resolver.txt for more information. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-07-26wireless: Make COMPAT_NETLINK_MESSAGES depend upon WEXT_COREDavid S. Miller
WIRELESS_EXT is not the correct dependency. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-18net: support time stamping in phy devices.Richard Cochran
This patch adds a new networking option to allow hardware time stamps from PHY devices. When enabled, likely candidates among incoming and outgoing network packets are offered to the PHY driver for possible time stamping. When accepted by the PHY driver, incoming packets are deferred for later delivery by the driver. The patch also adds phylib driver methods for the SIOCSHWTSTAMP ioctl and callbacks for transmit and receive time stamping. Drivers may optionally implement these functions. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03l2tp: Split pppol2tp patch into separate l2tp and ppp partsJames Chapman
This patch splits the pppol2tp driver into separate L2TP and PPP parts to prepare for L2TPv3 support. In L2TPv3, protocols other than PPP can be carried, so this split creates a common L2TP core that will handle the common L2TP bits which protocol support modules such as PPP will use. Note that the existing pppol2tp module is split into l2tp_core and l2tp_ppp by this change. There are no feature changes here. Internally, however, there are significant changes, mostly to handle the separation of PPP-specific data from the L2TP session and to provide hooks in the core for modules like PPP to access. Signed-off-by: James Chapman <jchapman@katalix.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30net-caif: add CAIF Kconfig and MakefilesSjur Braendeland
Kconfig and Makefiles with options for: CAIF: Including caif CAIF_DEBUG: CAIF Debug CAIF_NETDEV: CAIF Network Device for GPRS Contexts Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-25rps: add CONFIG_RPSEric Dumazet
RPS currently depends on SMP and SYSFS Adding a CONFIG_RPS makes sense in case this requirement changes in the future. This patch saves about 1500 bytes of kernel text in case SMP is on but SYSFS is off. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-15net/compat/wext: send different messages to compat tasksJohannes Berg
Wireless extensions have the unfortunate problem that events are multicast netlink messages, and are not independent of pointer size. Thus, currently 32-bit tasks on 64-bit platforms cannot properly receive events and fail with all kinds of strange problems, for instance wpa_supplicant never notices disassociations, due to the way the 64-bit event looks (to a 32-bit process), the fact that the address is all zeroes is lost, it thinks instead it is 00:00:00:00:01:00. The same problem existed with the ioctls, until David Miller fixed those some time ago in an heroic effort. A different problem caused by this is that we cannot send the ASSOCREQIE/ASSOCRESPIE events because sending them causes a 32-bit wpa_supplicant on a 64-bit system to overwrite its internal information, which is worse than it not getting the information at all -- so we currently resort to sending a custom string event that it then parses. This, however, has a severe size limitation we are frequently hitting with modern access points; this limitation would can be lifted after this patch by sending the correct binary, not custom, event. A similar problem apparently happens for some other netlink users on x86_64 with 32-bit tasks due to the alignment for 64-bit quantities. In order to fix these problems, I have implemented a way to send compat messages to tasks. When sending an event, we send the non-compat event data together with a compat event data in skb_shinfo(main_skb)->frag_list. Then, when the event is read from the socket, the netlink code makes sure to pass out only the skb that is compatible with the task. This approach was suggested by David Miller, my original approach required always sending two skbs but that had various small problems. To determine whether compat is needed or not, I have used the MSG_CMSG_COMPAT flag, and adjusted the call path for recv and recvfrom to include it, even if those calls do not have a cmsg parameter. I have not solved one small part of the problem, and I don't think it is necessary to: if a 32-bit application uses read() rather than any form of recvmsg() it will still get the wrong (64-bit) event. However, neither do applications actually do this, nor would it be a regression. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09net: add IEEE 802.15.4 socket family implementationSergey Lapin
Add support for communication over IEEE 802.15.4 networks. This implementation is neither certified nor complete, but aims to that goal. This commit contains only the socket interface for communication over IEEE 802.15.4 networks. One can either send RAW datagrams or use SOCK_DGRAM to encapsulate data inside normal IEEE 802.15.4 packets. Configuration interface, drivers and software MAC 802.15.4 implementation will follow. Initial implementation was done by Maxim Gorbachyov, Maxim Osipov and Pavel Smolensky as a research project at Siemens AG. Later the stack was heavily reworked to better suit the linux networking model, and is now maitained as an open project partially sponsored by Siemens. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-07net: remove stale reference to fastroute from Kconfig help textAshish Karkare
Signed-off-by: Ashish Karkare <akarkare@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wimax/i2400m/usb-notif.c
2009-03-21netdev: expose net_device_ops compat as config optionStephen Hemminger
Now that most network device drivers in (all but one in x86_64 allmodconfig) support net_device_ops. Expose it as a configuration parameter. Still need to address even older 32 bit drivers, and other arch before compatiablity can be scheduled for removal in some future release. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13Network Drop Monitor: Adding Build changes to enable drop monitorNeil Horman
Network Drop Monitor: Adding Build changes to enable drop monitor Signed-off-by: Neil Horman <nhorman@tuxdriver.com> include/linux/Kbuild | 1 + net/Kconfig | 11 +++++++++++ net/core/Makefile | 1 + 3 files changed, 13 insertions(+) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04netlink: Move netlink attribute parsing support to libGeert Uytterhoeven
Netlink attribute parsing may be used even if CONFIG_NET is not set. Move it from net/netlink to lib and control its inclusion based on the new config symbol CONFIG_NLATTR, which is selected by CONFIG_NET. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-26RDS: Kconfig and MakefileAndy Grover
Add RDS Kconfig and Makefile, and modify net/'s to add us to the build. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26Phonet: move to Networking options like other protocol stacksremi.denis-courmont@nokia
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26net: Move config NET_NS to from net/Kconfig to init/KconfigMatt Helsley
Make NET_NS available underneath the generic Namespaces config option since all of the other namespace options are there. Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07wimax: Makefile, Kconfig and docbook linkage for the stackInaky Perez-Gonzalez
This patch provides Makefile and KConfig for the WiMAX stack, integrating them into the networking stack's Makefile, Kconfig and doc-book templates. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-21net/ieee80211 -> drivers/net/ipw2x00/libipw_* renameJohn W. Linville
The old ieee80211 code only remains as a support library for the ipw2100 and ipw2200 drivers. So, move the code and rename it appropriately to reflects it's true purpose and status. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-20ixgbe: this patch adds support for DCB to the kernel and ixgbe driverAlexander Duyck
This adds support for Data Center Bridging (DCB) features in the ixgbe driver and adds an rtnetlink interface for configuring DCB to the kernel. The DCB feature support included are Priority Grouping (PG) - which allows bandwidth guarantees to be allocated to groups to traffic based on the 802.1q priority, and Priority Based Flow Control (PFC) - which introduces a new MAC control PAUSE frame which works at granularity of the 802.1p priority instead of the link (IEEE 802.3x). Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19netdev: network device operations infrastructureStephen Hemminger
This patch changes the network device internal API to move adminstrative operations out of the network device structure and into a separate structure. This patch involves some hackery to maintain compatablity between the new and old model, so all 300+ drivers don't have to be changed at once. For drivers that aren't converted yet, the netdevice_ops virt function list still resides in the net_device structure. For old protocols, the new net_device_ops are copied out to the old net_device pointers. After the transistion is completed the nag message can be changed to an WARN_ON, and the compatiablity code can be made configurable. Some function pointers aren't moved: * destructor can't be in net_device_ops because it may need to be referenced after the module is unloaded. * neighbor setup is manipulated in a couple of places that need special consideration * hard_start_xmit is in the fast path for transmit. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27netns: Coexist with the sysfs limitations v2Eric W. Biederman
To make testing of the network namespace simpler allow the network namespace code and the sysfs code to be compiled and run at the same time. To do this only virtual devices are allowed in the additional network namespaces and those virtual devices are not placed in the kobject tree. Since virtual devices don't actually do anything interesting hardware wise that needs device management there should be no loss in keeping them out of the kobject tree and by implication sysfs. The gain in ease of testing and code coverage should be significant. Changelog: v2: As pointed out by Benjamin Thery it only makes sense to call device_rename in the initial network namespace for now. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Benjamin Thery <benjamin.thery@bull.net> Tested-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08net: Distributed Switch Architecture protocol supportLennert Buytenhek
Distributed Switch Architecture is a protocol for managing hardware switch chips. It consists of a set of MII management registers and commands to configure the switch, and an ethernet header format to signal which of the ports of the switch a packet was received from or is intended to be sent to. The switches that this driver supports are typically embedded in access points and routers, and a typical setup with a DSA switch looks something like this: +-----------+ +-----------+ | | RGMII | | | +-------+ +------ 1000baseT MDI ("WAN") | | | 6-port +------ 1000baseT MDI ("LAN1") | CPU | | ethernet +------ 1000baseT MDI ("LAN2") | |MIImgmt| switch +------ 1000baseT MDI ("LAN3") | +-------+ w/5 PHYs +------ 1000baseT MDI ("LAN4") | | | | +-----------+ +-----------+ The switch driver presents each port on the switch as a separate network interface to Linux, polls the switch to maintain software link state of those ports, forwards MII management interface accesses to those network interfaces (e.g. as done by ethtool) to the switch, and exposes the switch's hardware statistics counters via the appropriate Linux kernel interfaces. This initial patch supports the MII management interface register layout of the Marvell 88E6123, 88E6161 and 88E6165 switch chips, and supports the "Ethertype DSA" packet tagging format. (There is no officially registered ethertype for the Ethertype DSA packet format, so we just grab a random one. The ethertype to use is programmed into the switch, and the switch driver uses the value of ETH_P_EDSA for this, so this define can be changed at any time in the future if the one we chose is allocated to another protocol or if Ethertype DSA gets its own officially registered ethertype, and everything will continue to work.) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Nicolas Pitre <nico@marvell.com> Tested-by: Byron Bradley <byron.bbradley@gmail.com> Tested-by: Tim Ellis <tim.ellis@mac.com> Tested-by: Peter van Valderen <linux@ddcrew.com> Tested-by: Dirk Teurlings <dirk@upexia.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: add CONFIG_PHONETRemi Denis-Courmont
Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
