path: root/net/Makefile
2015-03-04mpls: Refactor how the mpls module is builtEric W. Biederman
This refactoring is needed to allow more than just mpls gso support to be built into the mpls moddule. Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #2 from Al Viro: "Next pile (and there'll be one or two more). The large piece in this one is getting rid of /proc/*/ns/* weirdness; among other things, it allows to (finally) make nameidata completely opaque outside of fs/namei.c, making for easier further cleanups in there" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coda_venus_readdir(): use file_inode() fs/namei.c: fold link_path_walk() call into path_init() path_init(): don't bother with LOOKUP_PARENT in argument fs/namei.c: new helper (path_cleanup()) path_init(): store the "base" pointer to file in nameidata itself make default ->i_fop have ->open() fail with ENXIO make nameidata completely opaque outside of fs/namei.c kill proc_ns completely take the targets of /proc/*/ns/* symlinks to separate fs bury struct proc_ns in fs/proc copy address of proc_ns_ops into ns_common new helpers: ns_alloc_inum/ns_free_inum make proc_ns_operations work with struct ns_common * instead of void * switch the rest of proc_ns_operations to working with &...->ns netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns common object embedded into various struct ....ns
2014-12-10make default ->i_fop have ->open() fail with ENXIOAl Viro
As it is, default ->i_fop has NULL ->open() (along with all other methods). The only case where it matters is reopening (via procfs symlink) a file that didn't get its ->f_op from ->i_fop - anything else will have ->i_fop assigned to something sane (default would fail on read/write/ioctl/etc.). Unfortunately, such case exists - alloc_file() users, especially anon_get_file() ones. There we have tons of opened files of very different kinds sharing the same inode. As the result, attempt to reopen those via procfs succeeds and you get a descriptor you can't do anything with. Moreover, in case of sockets we set ->i_fop that will only be used on such reopen attempts - and put a failing ->open() into it to make sure those do not succeed. It would be simpler to put such ->open() into default ->i_fop and leave it unchanged both for anon inode (as we do anyway) and for socket ones. Result: * everything going through do_dentry_open() works as it used to * sock_no_open() kludge is gone * attempts to reopen anon-inode files fail as they really ought to * ditto for aio_private_file() * ditto for perfmon - this one actually tried to imitate sock_no_open() trick, but failed to set ->i_fop, so in the current tree reopens succeed and yield completely useless descriptor. Intent clearly had been to fail with -ENXIO on such reopens; now it actually does. * everything else that used alloc_file() keeps working - it has ->i_fop set for its inodes anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-02net: introduce generic switch devices supportJiri Pirko
The goal of this is to provide a possibility to support various switch chips. Drivers should implement relevant ndos to do so. Now there is only one ndo defined: - for getting physical switch id is in place. Note that user can use random port netdevice to access the switch. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Reviewed-by: Thomas Graf <tgraf@suug.ch> Acked-by: Andy Gospodarek <gospo@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-126lowpan: introduce new net/6lowpan directoryAlexander Aring
This patch moves generic code which is used by bluetooth and ieee802154 6lowpan to a new net/6lowpan directory. This directory contains generic 6LoWPAN code which is shared between bluetooth and ieee802154 MAC-Layer. This is the IPHC - "IPv6 Header Compression" format at the moment. Which is described by RFC 6282 [0]. The BLTE 6LoWPAN draft describes that the IPHC is the same format like IEEE 802.15.4, see [1]. Futuremore we can put more code into this directory which is shared between BLTE and IEEE 802.15.4 6LoWPAN like RFC 6775 or the routing protocol RPL RFC 6550. To avoid naming conflicts I renamed 6lowpan-y to ieee802154_6lowpan-y in net/ieee802154/Makefile. [0] http://tools.ietf.org/html/rfc6282 [1] http://tools.ietf.org/html/draft-ietf-6lowpan-btle-12#section-3.2 [2] http://tools.ietf.org/html/rfc6775 [3] http://tools.ietf.org/html/rfc6550 Signed-off-by: Alexander Aring <alex.aring@gmail.com> Acked-by: Jukka Rissanen <jukka.rissanen@linux.intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-01-15net: move 6lowpan compression code to separate moduleDmitry Eremin-Solenikov
IEEE 802.15.4 and Bluetooth networking stacks share 6lowpan compression code. Instead of introducing Makefile/Kconfig hacks, build this code as a separate module referenced from both ieee802154 and bluetooth modules. This fixes the following build error observed in some kernel configurations: net/built-in.o: In function `header_create': 6lowpan.c:(.text+0x166149): undefined reference to `lowpan_header_compress' net/built-in.o: In function `bt_6lowpan_recv': (.text+0x166b3c): undefined reference to `lowpan_process_data' Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Dmitry Eremin-Solenikov <dmitry_eremin@mentor.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-03net/hsr: Add support for the High-availability Seamless Redundancy protocol ↵Arvid Brodin
(HSRv0) High-availability Seamless Redundancy ("HSR") provides instant failover redundancy for Ethernet networks. It requires a special network topology where all nodes are connected in a ring (each node having two physical network interfaces). It is suited for applications that demand high availability and very short reaction time. HSR acts on the Ethernet layer, using a registered Ethernet protocol type to send special HSR frames in both directions over the ring. The driver creates virtual network interfaces that can be used just like any ordinary Linux network interface, for IP/TCP/UDP traffic etc. All nodes in the network ring must be HSR capable. This code is a "best effort" to comply with the HSR standard as described in IEC 62439-3:2010 (HSRv0). Signed-off-by: Arvid Brodin <arvid.brodin@xdin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-27MPLS: Add limited GSO supportSimon Horman
In the case where a non-MPLS packet is received and an MPLS stack is added it may well be the case that the original skb is GSO but the NIC used for transmit does not support GSO of MPLS packets. The aim of this code is to provide GSO in software for MPLS packets whose skbs are GSO. SKB Usage: When an implementation adds an MPLS stack to a non-MPLS packet it should do the following to skb metadata: * Set skb->inner_protocol to the old non-MPLS ethertype of the packet. skb->inner_protocol is added by this patch. * Set skb->protocol to the new MPLS ethertype of the packet. * Set skb->network_header to correspond to the end of the L3 header, including the MPLS label stack. I have posted a patch, "[PATCH v3.29] datapath: Add basic MPLS support to kernel" which adds MPLS support to the kernel datapath of Open vSwtich. That patch sets the above requirements in datapath/actions.c:push_mpls() and was used to exercise this code. The datapath patch is against the Open vSwtich tree but it is intended that it be added to the Open vSwtich code present in the mainline Linux kernel at some point. Features: I believe that the approach that I have taken is at least partially consistent with the handling of other protocols. Jesse, I understand that you have some ideas here. I am more than happy to change my implementation. This patch adds dev->mpls_features which may be used by devices to advertise features supported for MPLS packets. A new NETIF_F_MPLS_GSO feature is added for devices which support hardware MPLS GSO offload. Currently no devices support this and MPLS GSO always falls back to software. Alternate Implementation: One possible alternate implementation is to teach netif_skb_features() and skb_network_protocol() about MPLS, in a similar way to their understanding of VLANs. I believe this would avoid the need for net/mpls/mpls_gso.c and in particular the calls to __skb_push() and __skb_push() in mpls_gso_segment(). I have decided on the implementation in this patch as it should not introduce any overhead in the case where mpls_gso is not compiled into the kernel or inserted as a module. MPLS GSO suggested by Jesse Gross. Based in part on "v4 GRE: Add TCP segmentation offload for GRE" by Pravin B Shelar. Cc: Jesse Gross <jesse@nicira.com> Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-10VSOCK: Introduce VM SocketsAndy King
VM Sockets allows communication between virtual machines and the hypervisor. User level applications both in a virtual machine and on the host can use the VM Sockets API, which facilitates fast and efficient communication between guest virtual machines and their host. A socket address family, designed to be compatible with UDP and TCP at the interface level, is provided. Today, VM Sockets is used by various VMware Tools components inside the guest for zero-config, network-less access to VMware host services. In addition to this, VMware's users are using VM Sockets for various applications, where network access of the virtual machine is restricted or non-existent. Examples of this are VMs communicating with device proxies for proprietary hardware running as host applications and automated testing of applications running within virtual machines. The VMware VM Sockets are similar to other socket types, like Berkeley UNIX socket interface. The VM Sockets module supports both connection-oriented stream sockets like TCP, and connectionless datagram sockets like UDP. The VM Sockets protocol family is defined as "AF_VSOCK" and the socket operations split for SOCK_DGRAM and SOCK_STREAM. For additional information about the use of VM Sockets, please refer to the VM Sockets Programming Guide available at: https://www.vmware.com/support/developer/vmci-sdk/ Signed-off-by: George Zhang <georgezhang@vmware.com> Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Andy king <acking@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-31wanrouter: completely decouple obsolete code from kernel.Paul Gortmaker
The original suggestion to delete wanrouter started earlier with the mainline commit f0d1b3c2bcc5de8a17af5f2274f7fcde8292b5fc ("net/wanrouter: Deprecate and schedule for removal") in May 2012. More importantly, Dan Carpenter found[1] that the driver had a fundamental breakage introduced back in 2008, with commit 7be6065b39c3 ("netdevice wanrouter: Convert directly reference of netdev->priv"). So we know with certainty that the code hasn't been used by anyone willing to at least take the effort to send an e-mail report of breakage for at least 4 years. This commit does a decouple of the wanrouter subsystem, by going after the Makefile/Kconfig and similar files, so that these mainline files that we are keeping do not have the big wanrouter file/driver deletion commit tied into their history. Once this commit is in place, we then can remove the obsolete cyclomx drivers and similar that have a dependency on CONFIG_WAN_ROUTER_DRIVERS. [1] http://www.spinics.net/lists/netdev/msg218670.html Originally-by: Joe Perches <joe@perches.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-18econet: remove ancient bug ridden protocolStephen Hemminger
More spring cleaning! The ancient Econet protocol should go. Most of the bug fixes in recent years have been fixing security vulnerabilities. The hardware hasn't been made since the 90s, it is only interesting as an archeological curiosity. For the truly curious, or insomniac, go read up on it. http://en.wikipedia.org/wiki/Econet Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: allocation of ieee802154 devicealex.bluesman.smirnov@gmail.com
An interface to allocate and register ieee802154 compatible device. The allocated device has the following representation in memory: +-----------------------+ | struct wpan_phy | +-----------------------+ | struct mac802154_priv | +-----------------------+ | driver's private data | +-----------------------+ Used by device drivers to register new instance in the stack. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-03net: Add Open vSwitch kernel components.Jesse Gross
Open vSwitch is a multilayer Ethernet switch targeted at virtualized environments. In addition to supporting a variety of features expected in a traditional hardware switch, it enables fine-grained programmatic extension and flow-based control of the network. This control is useful in a wide variety of applications but is particularly important in multi-server virtualization deployments, which are often characterized by highly dynamic endpoints and the need to maintain logical abstractions for multiple tenants. The Open vSwitch datapath provides an in-kernel fast path for packet forwarding. It is complemented by a userspace daemon, ovs-vswitchd, which is able to accept configuration from a variety of sources and translate it into packet processing rules. See http://openvswitch.org for more information and userspace utilities. Signed-off-by: Jesse Gross <jesse@nicira.com>
2011-07-05NFC: add nfc subsystem coreLauro Ramos Venancio
The NFC subsystem core is responsible for providing the device driver interface. It is also responsible for providing an interface to the control operations and data exchange. Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-07net: Enter net/ipv6/ even if CONFIG_IPV6=nThomas Graf
exthdrs_core.c and addrconf_core.c in net/ipv6/ contain bits which must be made available even if IPv6 is disabled. net/ipv6/Makefile already correctly includes them if CONFIG_IPV6=n but net/Makefile prevents entering the subdirectory. Signed-off-by: Thomas Graf <tgraf@infradead.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16net: Add batman-adv meshing protocolSven Eckelmann
B.A.T.M.A.N. (better approach to mobile ad-hoc networking) is a routing protocol for multi-hop ad-hoc mesh networks. The networks may be wired or wireless. See http://www.open-mesh.org/ for more information and user space tools. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-20ceph: factor out libceph from Ceph file systemYehuda Sadeh
This factors out protocol and low-level storage parts of ceph into a separate libceph module living in net/ceph and include/linux/ceph. This is mostly a matter of moving files around. However, a few key pieces of the interface change as well: - ceph_client becomes ceph_fs_client and ceph_client, where the latter captures the mon and osd clients, and the fs_client gets the mds client and file system specific pieces. - Mount option parsing and debugfs setup is correspondingly broken into two pieces. - The mon client gets a generic handler callback for otherwise unknown messages (mds map, in this case). - The basic supported/required feature bits can be expanded (and are by ceph_fs_client). No functional change, aside from some subtle error handling cases that got cleaned up in the refactoring process. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-05DNS: Separate out CIFS DNS Resolver codeWang Lei
Separate out the DNS resolver key type from the CIFS filesystem into its own module so that it can be made available for general use, including the AFS filesystem module. This facility makes it possible for the kernel to upcall to userspace to have it issue DNS requests, package up the replies and present them to the kernel in a useful form. The kernel is then able to cache the DNS replies as keys can be retained in keyrings. Resolver keys are of type "dns_resolver" and have a case-insensitive description that is of the form "[<type>:]<domain_name>". The optional <type> indicates the particular DNS lookup and packaging that's required. The <domain_name> is the query to be made. If <type> isn't given, a basic hostname to IP address lookup is made, and the result is stored in the key in the form of a printable string consisting of a comma-separated list of IPv4 and IPv6 addresses. This key type is supported by userspace helpers driven from /sbin/request-key and configured through /etc/request-key.conf. The cifs.upcall utility is invoked for UNC path server name to IP address resolution. The CIFS functionality is encapsulated by the dns_resolve_unc_to_ip() function, which is used to resolve a UNC path to an IP address for CIFS filesystem. This part remains in the CIFS module for now. See the added Documentation/networking/dns_resolver.txt for more information. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-06-29net/Makefile: conditionally descend to wireless and ieee802154Nicolas Kaiser
Don't descend to wireless and ieee802154 unless they are actually used. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03l2tp: Split pppol2tp patch into separate l2tp and ppp partsJames Chapman
This patch splits the pppol2tp driver into separate L2TP and PPP parts to prepare for L2TPv3 support. In L2TPv3, protocols other than PPP can be carried, so this split creates a common L2TP core that will handle the common L2TP bits which protocol support modules such as PPP will use. Note that the existing pppol2tp module is split into l2tp_core and l2tp_ppp by this change. There are no feature changes here. Internally, however, there are significant changes, mostly to handle the separation of PPP-specific data from the L2TP session and to provide hooks in the core for modules like PPP to access. Signed-off-by: James Chapman <jchapman@katalix.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03l2tp: Relocate pppol2tp driver to new net/l2tp directoryJames Chapman
This patch moves the existing pppol2tp driver from drivers/net into a new net/l2tp directory, which is where the upcoming L2TPv3 code will live. The existing CONFIG_PPPOL2TP config option is left in its current place to avoid "make oldconfig" issues when an existing pppol2tp user takes this change. (This is the same approach used for the pppoatm driver, which moved to net/atm.) There are no code changes. The existing drivers/net/pppol2tp.c is simply moved to net/l2tp. Signed-off-by: James Chapman <jchapman@katalix.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30net-caif: add CAIF Kconfig and MakefilesSjur Braendeland
Kconfig and Makefiles with options for: CAIF: Including caif CAIF_DEBUG: CAIF Debug CAIF_NETDEV: CAIF Network Device for GPRS Contexts Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12net: remove redundant sched/ in net/MakefileChangli Gao
Remove redundant sched/ in net/Makefile. sched/ is contained in previous: obj-$(CONFIG_NET) += ethernet/ 802/ sched/ netlink/, so the later obj-$(CONFIG_NET_SCHED) += sched/ isn't necessary. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- Makefile | 1 - 1 file changed, 1 deletion(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09net: add IEEE 802.15.4 socket family implementationSergey Lapin
Add support for communication over IEEE 802.15.4 networks. This implementation is neither certified nor complete, but aims to that goal. This commit contains only the socket interface for communication over IEEE 802.15.4 networks. One can either send RAW datagrams or use SOCK_DGRAM to encapsulate data inside normal IEEE 802.15.4 packets. Configuration interface, drivers and software MAC 802.15.4 implementation will follow. Initial implementation was done by Maxim Gorbachyov, Maxim Osipov and Pavel Smolensky as a research project at Siemens AG. Later the stack was heavily reworked to better suit the linux networking model, and is now maitained as an open project partially sponsored by Siemens. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26RDS: Kconfig and MakefileAndy Grover
Add RDS Kconfig and Makefile, and modify net/'s to add us to the build. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07wimax: Makefile, Kconfig and docbook linkage for the stackInaky Perez-Gonzalez
This patch provides Makefile and KConfig for the WiMAX stack, integrating them into the networking stack's Makefile, Kconfig and doc-book templates. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-25DCB: fix kconfig optionJeff Kirsher
Since the netlink option for DCB is necessary to actually be useful, simplified the Kconfig option. In addition, added useful help text for the Kconfig option. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21net/ieee80211 -> drivers/net/ipw2x00/libipw_* renameJohn W. Linville
The old ieee80211 code only remains as a support library for the ipw2100 and ipw2200 drivers. So, move the code and rename it appropriately to reflects it's true purpose and status. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-20ixgbe: this patch adds support for DCB to the kernel and ixgbe driverAlexander Duyck
This adds support for Data Center Bridging (DCB) features in the ixgbe driver and adds an rtnetlink interface for configuring DCB to the kernel. The DCB feature support included are Priority Grouping (PG) - which allows bandwidth guarantees to be allocated to groups to traffic based on the 802.1q priority, and Priority Based Flow Control (PFC) - which introduces a new MAC control PAUSE frame which works at granularity of the 802.1p priority instead of the link (IEEE 802.3x). Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08net: Distributed Switch Architecture protocol supportLennert Buytenhek
Distributed Switch Architecture is a protocol for managing hardware switch chips. It consists of a set of MII management registers and commands to configure the switch, and an ethernet header format to signal which of the ports of the switch a packet was received from or is intended to be sent to. The switches that this driver supports are typically embedded in access points and routers, and a typical setup with a DSA switch looks something like this: +-----------+ +-----------+ | | RGMII | | | +-------+ +------ 1000baseT MDI ("WAN") | | | 6-port +------ 1000baseT MDI ("LAN1") | CPU | | ethernet +------ 1000baseT MDI ("LAN2") | |MIImgmt| switch +------ 1000baseT MDI ("LAN3") | +-------+ w/5 PHYs +------ 1000baseT MDI ("LAN4") | | | | +-----------+ +-----------+ The switch driver presents each port on the switch as a separate network interface to Linux, polls the switch to maintain software link state of those ports, forwards MII management interface accesses to those network interfaces (e.g. as done by ethtool) to the switch, and exposes the switch's hardware statistics counters via the appropriate Linux kernel interfaces. This initial patch supports the MII management interface register layout of the Marvell 88E6123, 88E6161 and 88E6165 switch chips, and supports the "Ethertype DSA" packet tagging format. (There is no officially registered ethertype for the Ethertype DSA packet format, so we just grab a random one. The ethertype to use is programmed into the switch, and the switch driver uses the value of ETH_P_EDSA for this, so this define can be changed at any time in the future if the one we chose is allocated to another protocol or if Ethertype DSA gets its own officially registered ethertype, and everything will continue to work.) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Nicolas Pitre <nico@marvell.com> Tested-by: Byron Bradley <byron.bbradley@gmail.com> Tested-by: Tim Ellis <tim.ellis@mac.com> Tested-by: Peter van Valderen <linux@ddcrew.com> Tested-by: Dirk Teurlings <dirk@upexia.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: add CONFIG_PHONETRemi Denis-Courmont
Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: uninline __vlan_hwaccel_rxPatrick McHardy
The function is huge and included at least once in every VLAN acceleration capable driver. Uninline it; to avoid having drivers depend on the VLAN module, the function is always built in statically when VLAN is enabled. With all VLAN acceleration capable drivers that build on x86_64 enabled, this results in: text data bss dec hex filename 6515227 854044 343968 7713239 75b1d7 vmlinux.inlined 6505637 854044 343968 7703649 758c61 vmlinux.uninlined ---------------------------------------------------------- -9590 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CAN]: Add PF_CAN core moduleOliver Hartkopp
This patch adds the CAN core functionality but no protocols or drivers. No protocol implementations are included here. They come as separate patches. Protocol numbers are already in include/linux/can.h. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-149p: Reorganization of 9p file system codeLatchesar Ionkov
This patchset moves non-filesystem interfaces of v9fs from fs/9p to net/9p. It moves the transport, packet marshalling and connection layers to net/9p leaving only the VFS related files in fs/9p. This work is being done in preparation for in-kernel 9p servers as well as alternate 9p clients (other than VFS). Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-07-10[RXRPC]: Remove Makefile reference to obsolete RXRPC config variableRobert P. J. Day
Since there is no Kconfig variable RXRPC anywhere in the tree, and the variable AF_RXRPC performs exactly the same function, remove the reference to CONFIG_RXRPC from net/Makefile. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-07[NET]: rfkill: add support for input key to control wireless radioIvo van Doorn
The RF kill patch that provides infrastructure for implementing switches controlling radio states on various network and other cards. [dtor@insightbb.com: address review comments] [akpm@linux-foundation.org: cleanups, build fixes] Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-05[MAC80211]: Add mac80211 wireless stack.Jiri Benc
Add mac80211, the IEEE 802.11 software MAC layer. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-26[AF_RXRPC]: Provide secure RxRPC sockets for use by userspace and kernel bothDavid Howells
Provide AF_RXRPC sockets that can be used to talk to AFS servers, or serve answers to AFS clients. KerberosIV security is fully supported. The patches and some example test programs can be found in: http://people.redhat.com/~dhowells/rxrpc/ This will eventually replace the old implementation of kernel-only RxRPC currently resident in net/rxrpc/. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[WIRELESS]: Refactor wireless Kconfig.Johannes Berg
This patch refactors the wireless Kconfig all over and already introduces net/wireless/Kconfig with just the WEXT bit for now, the cfg80211 patch will add to that as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[S390]: Rewrite of the IUCV base code, part 2Martin Schwidefsky
Add rewritten IUCV base code to net/iucv. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: core NetLabel subsystemPaul Moore
Add a new kernel subsystem, NetLabel, to provide explicit packet labeling services (CIPSO, RIPSO, etc.) to LSM developers. NetLabel is designed to work in conjunction with a LSM to intercept and decode security labels on incoming network packets as well as ensure that outgoing network packets are labeled according to the security mechanism employed by the LSM. The NetLabel subsystem is configured through a Generic NETLINK interface described in the header files included in this patch. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-12[TIPC] Initial mergePer Liden
TIPC (Transparent Inter Process Communication) is a protocol designed for intra cluster communication. For more information see http://tipc.sourceforge.net Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2005-11-14[NETFILTER]: link 'netfilter' before ipv4Krzysztof Oledzki
Staticaly linked nf_conntrack_ipv4 requires nf_conntrack. but currently nf_conntrack is linked after it. This changes the order of ipv4 and netfilter to fix this. Signed-off-by: Krzysztof Oledzki <olenf@ans.pl> Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01/spare/repo/netdev-2.6 branch 'master'Jeff Garzik
2005-08-29[DCCP]: Initial implementationArnaldo Carvalho de Melo
Development to this point was done on a subversion repository at: http://oops.ghostprotocols.net:81/cgi-bin/viewcvs.cgi/dccp-2.6/ This repository will be kept at this site for the foreseable future, so that interested parties can see the history of this code, attributions, etc. If I ever decide to take this offline I'll provide the full history at some other suitable place. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFITLER]: Add nfnetlink layer.Harald Welte
Introduce "nfnetlink" (netfilter netlink) layer. This layer is used as transport layer for all userspace communication of the new upcoming netfilter subsystems, such as ctnetlink, nfnetlink_queue and some day even the mythical pkttables ;) Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-12[NET] ieee80211 subsystemJeff Garzik
Contributors: Host AP contributors James Ketrenos <jketreno@linux.intel.com> Francois Romieu <romieu@fr.zoreil.com> Adrian Bunk <bunk@stusta.de> Matthew Galgoci <mgalgoci@parcelfarce.linux.th eplanet.co.uk>
