net/appletalk/aarp.c: In function ‘__aarp_send_query’:
net/appletalk/aarp.c:137:2: error: implicit declaration of function ‘ether_addr_copy’ [-Werror=implicit-function-declaration]
net/atm/lec.c: In function ‘send_to_lecd’:
net/atm/lec.c:524:3: warning: passing argument 1 of ‘ether_addr_copy’ from incompatible pointer type [enabled by default]
In file included from net/atm/lec.c:17:0:
include/linux/etherdevice.h:227:20: note: expected ‘u8 *’ but argument is of type ‘unsigned char (*)[6]’
net/caif/caif_usb.c: In function ‘cfusbl_create’:
net/caif/caif_usb.c:108:2: error: implicit declaration of function ‘ether_addr_copy’ [-Werror=implicit-function-declaration]
Use ether_addr_copy instead of memcpy(a, b, ETH_ALEN) to
save some cycles on arm and powerpc.
Convert struct aarp_entry.hwaddr[6] to hwaddr[ETH_ALEN].
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
Make the case labels the same indent as the switch.
(git diff -w net/appletalk shows no difference)
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
da.s_net was not copied but assigned to itself.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
And also do a better job of returning proper NET_{RX,XMIT}_ values.
Based on a patch and suggestions by Mark Smith.
This fixes CVE-2009-2903
Reported-by: Mark Smith <lk-netdev@lk-netdev.nosense.org>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Without CONFIG_NET_NS, namespace is always &init_net.
Compiler will be able to omit namespace comparisons with this patch.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Introduce per-net_device inlines: dev_net(), dev_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
These two also perform manual seq_open_private, so patch them both at
once. But unlike ATM code, these already use the seq_release_private,
so I splitted this patch from the previous one.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
CHECK net/appletalk/aarp.c
net/appletalk/aarp.c:951:14: warning: context imbalance in 'aarp_seq_start' - wrong count at exit
net/appletalk/aarp.c:977:13: warning: context imbalance in 'aarp_seq_stop' - unexpected unlock
CHECK net/appletalk/atalk_proc.c
net/appletalk/atalk_proc.c:34:11: warning: context imbalance in 'atalk_seq_interface_start' - wrong count at exit
net/appletalk/atalk_proc.c:54:13: warning: context imbalance in 'atalk_seq_interface_stop' - unexpected unlock
net/appletalk/atalk_proc.c:93:11: warning: context imbalance in 'atalk_seq_route_start' - wrong count at exit
net/appletalk/atalk_proc.c:113:13: warning: context imbalance in 'atalk_seq_route_stop' - unexpected unlock
net/appletalk/atalk_proc.c:161:11: warning: context imbalance in 'atalk_seq_socket_start' - wrong count at exit
net/appletalk/atalk_proc.c:178:13: warning: context imbalance in 'atalk_seq_socket_stop' - unexpected unlock
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Many-many code in the kernel initialized the timer->function
and timer->data together with calling init_timer(timer). There
is already a helper for this. Use it for networking code.
The patch is HUGE, but makes the code 130 lines shorter
(98 insertions(+), 228 deletions(-)).
Fix a bunch of sparse warnings. Mostly about 0 used as
NULL pointer, and shadowed variable declarations.
One notable case was that hash size should have been unsigned.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This is nicer than the MAC_FMT stuff.
Every user of the network device notifiers is either a protocol
stack or a pseudo device. If a protocol stack that does not have
support for multiple network namespaces receives an event for a
device that is not in the initial network namespace it quite possibly
can get confused and do the wrong thing.
To avoid problems until all of the protocol stacks are converted
this patch modifies all netdev event handlers to ignore events on
devices that are not in the initial network namespace.
As the rest of the code is made network namespace aware these
checks can be removed.
This patch modifies every packet receive function
registered with dev_add_pack() to drop packets if they
are not from the initial network namespace.
This should ensure that the various network stacks do
not receive packets in a anything but the initial network
namespace until the code has been converted and is ready
for them.
This slightly improves code safety and clarity.
Later network namespace patches touch this code so this is a
preliminary cleanup.
Make all initialized struct seq_operations in net/ const
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can
later turn skb->h.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple cases:
skb->h.raw = skb->data;
skb->h.raw = {skb_push|[__]skb_pull}()
The next ones will handle the slightly more "complex" cases.
But only in the cases where its a newly allocated skb, i.e. one where skb->tail
is equal to skb->data, or just after skb_reserve, where this requirement is
maintained.
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can
later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Bonding just wants the device before the skb_bond()
decapsulation occurs, so simply pass that original
device into packet_type->func() as an argument.
It remains to be seen whether we can use this same
exact thing to get rid of skb->input_dev as well.
Use msleep() instead of schedule_timeout() to guarantee the task
delays as expected. The current code is not wrong, but it does not account for
early return due to signals, so I think msleep() should be appropriate.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Signed-off-by: Domen Puncer <domen@coderock.org>
infrastructure for it.
Let it rip!
