path: root/net/appletalk
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ATALK]: In notifier handlers convert the void pointer to a netdeviceEric W. Biederman
This slightly improves code safety and clarity. Later network namespace patches touch this code so this is a preliminary cleanup. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-27[NET]: Revert sk_buff walker cleanups.David S. Miller
This reverts eefa3906283a2b60a6d02a2cda593a7d7d7946c5 The simplification made in that change works with the assumption that the 'offset' parameter to these functions is always positive or zero, which is not true. It can be and often is negative in order to access SKB header values in front of skb->data. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NET]: Clean up sk_buff walkers.Jean Delvare
I noticed recently that, in skb_checksum(), "offset" and "start" are essentially the same thing and have the same value throughout the function, despite being computed differently. Using a single variable allows some cleanups and makes the skb_checksum() function smaller, more readable, and presumably marginally faster. We appear to have many other "sk_buff walker" functions built on the exact same model, so the cleanup applies to them, too. Here is a list of the functions I found to be affected: net/appletalk/ddp.c:atalk_sum_skb() net/core/datagram.c:skb_copy_datagram_iovec() net/core/datagram.c:skb_copy_and_csum_datagram() net/core/skbuff.c:skb_copy_bits() net/core/skbuff.c:skb_store_bits() net/core/skbuff.c:skb_checksum() net/core/skbuff.c:skb_copy_and_csum_bit() net/core/user_dma.c:dma_skb_copy_datagram_iovec() net/xfrm/xfrm_algo.c:skb_icv_walk() net/xfrm/xfrm_algo.c:skb_to_sgvec() OTOH, I admit I'm a bit surprised, the cleanup is rather obvious so I'm really wondering if I am missing something. Can anyone please comment on this? Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use skb_reset_network_header where the skb_pull return was being usedArnaldo Carvalho de Melo
But only in the cases where its a newly allocated skb, i.e. one where skb->tail is equal to skb->data, or just after skb_reserve, where this requirement is maintained. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_mac_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the mac header, it is still legal to touch skb->mac.raw directly if just adding to, subtracting from or setting it to another layer header. This one also converts some more cases to skb_reset_mac_header() that my regex missed as it had no spaces before nor after '=', ugh. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Introduce SIOCGSTAMPNS ioctl to get timestamps with nanosec resolutionEric Dumazet
Now network timestamps use ktime_t infrastructure, we can add a new ioctl() SIOCGSTAMPNS command to get timestamps in 'struct timespec'. User programs can thus access to nanosecond resolution. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-04[APPLETALK]: Fix a remotely triggerable crashJean Delvare
When we receive an AppleTalk frame shorter than what its header says, we still attempt to verify its checksum, and trip on the BUG_ON() at the end of function atalk_sum_skb() because of the length mismatch. This has security implications because this can be triggered by simply sending a specially crafted ethernet frame to a target victim, effectively crashing that host. Thus this qualifies, I think, as a remote DoS. Here is the frame I used to trigger the crash, in npg format: <Appletalk Killer> { # Ethernet header ----- XX XX XX XX XX XX # Destination MAC 00 00 00 00 00 00 # Source MAC 00 1D # Length # LLC header ----- AA AA 03 08 00 07 80 9B # Appletalk # Appletalk header ----- 00 1B # Packet length (invalid) 00 01 # Fake checksum 00 00 00 00 # Destination and source networks 00 00 00 00 # Destination and source nodes and ports # Payload ----- 0C 0D 0E 0F 10 11 12 13 14 } The destination MAC address must be set to those of the victim. The severity is mitigated by two requirements: * The target host must have the appletalk kernel module loaded. I suspect this isn't so frequent. * AppleTalk frames are non-IP, thus I guess they can only travel on local networks. I am no network expert though, maybe it is possible to somehow encapsulate AppleTalk packets over IP. The bug has been reported back in June 2004: http://bugzilla.kernel.org/show_bug.cgi?id=2979 But it wasn't investigated, and was closed in July 2006 as both reporters had vanished meanwhile. This code was new in kernel 2.6.0-test5: http://git.kernel.org/?p=linux/kernel/git/tglx/history.git;a=commitdiff;h=7ab442d7e0a76402c12553ee256f756097cae2d2 And not modified since then, so we can assume that vanilla kernels 2.6.0-test5 and later, and distribution kernels based thereon, are affected. Note that I still do not know for sure what triggered the bug in the real-world cases. The frame could have been corrupted by the kernel if we have a bug hiding somewhere. But more likely, we are receiving the faulty frame from the network. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: atalk: remove unnecessary insert_at_head flagEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] APPLETALK: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] severing skbuff.h -> highmem.hAl Viro
2006-10-30[APPLETALK]: Fix potential OOPS in atalk_sendmsg().David S. Miller
atrtr_find() can return NULL, so do not blindly dereference rt->dev before we check for rt being NULL. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[ATALK]: endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[NET]: Fix ipx/econet/appletalk/irda ioctl crashesPetr Vandrovec
Fix kernel oopses whenever somebody issues compatible ioctl on AppleTalk, Econet, IPX or IRDA socket. For AppleTalk/Econet/IRDA it restores state in which these sockets were before compat_ioctl was introduced to the socket ops, for IPX it implements support for 4 ioctls which were not implemented before - as these ioctls use structures which match between 32bit and 64bit userspace, no special code is needed, just call 64bit ioctl handler. Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[NET]: Add a dev_ioctl() fallback to sock_ioctl()Christoph Hellwig
Currently all network protocols need to call dev_ioctl as the default fallback in their ioctl implementations. This patch adds a fallback to dev_ioctl to sock_ioctl if the protocol returned -ENOIOCTLCMD. This way all the procotol ioctl handlers can be simplified and we don't need to export dev_ioctl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-27[APPLETALK]: Fix broadcast bug.Oliver Dawid
From: Oliver Dawid <oliver@helios.de> we found a bug in net/appletalk/ddp.c concerning broadcast packets. In kernel 2.4 it was working fine. The bug first occured 4 years ago when switching to new SNAP layer handling. This bug can be splitted up into a sending(1) and reception(2) problem: Sending(1) In kernel 2.4 broadcast packets were sent to a matching ethernet device and atalk_rcv() was called to receive it as "loopback" (so loopback packets were shortcutted and handled in DDP layer). When switching to the new SNAP structure, this shortcut was removed and the loopback packet was send to SNAP layer. The author forgot to replace the remote device pointer by the loopback device pointer before sending the packet to SNAP layer (by calling ddp_dl->request() ) therfor the packet was not sent back by underlying layers to ddp's atalk_rcv(). Reception(2) In atalk_rcv() a packet received by this loopback mechanism contains now the (rigth) loopback device pointer (in Kernel 2.4 it was the (wrong) remote ethernet device pointer) and therefor no matching socket will be found to deliver this packet to. Because a broadcast packet should be send to the first matching socket (as it is done in many other protocols (?)), we removed the network comparison in broadcast case. Below you will find a patch to correct this bug. Its diffed to kernel 2.6.14-rc1 Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[ATALK] aarp: replace schedule_timeout() with msleep()Nishanth Aravamudan
From: Nishanth Aravamudan <nacc@us.ibm.com> Use msleep() instead of schedule_timeout() to guarantee the task delays as expected. The current code is not wrong, but it does not account for early return due to signals, so I think msleep() should be appropriate. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[ATALK]: endian annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[ATALK]: Add alloc_ltalkdev().Christoph Hellwig
this matches the API used by other link layer like ethernet or token ring. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-19[ATALK]: Add missing dev_hold() to atrtr_create().Herbert Xu
Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
