commit c93ad1337ad06a718890a89cdd85188ff9a5a5cc upstream.
If register_snap_client fails in atalk_init,
error code should be set, otherwise it will
triggers NULL pointer dereference while unloading
module.
Fixes: 9804501fa122 ("appletalk: Fix potential NULL pointer dereference in unregister_snap_client")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
commit 9804501fa1228048857910a6bf23e085aade37cc upstream.
register_snap_client may return NULL, all the callers
check it, but only print a warning. This will result in
NULL pointer dereference in unregister_snap_client and other
places.
It has always been used like this since v2.6
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
[bwh: Backported to <4.15: adjust context]
[ Upstream commit 6cc03e8aa36c51f3b26a0d21a3c4ce2809c842ac ]
When creating a raw AF_APPLETALK socket, CAP_NET_RAW needs to be checked
first.
Signed-off-by: Ori Nimron <orinimron123@gmail.com>
[ Upstream commit 6377f787aeb945cae7abbb6474798de129e1f3ac ]
KASAN report this:
BUG: KASAN: use-after-free in pde_subdir_find+0x12d/0x150 fs/proc/generic.c:71
Read of size 8 at addr ffff8881f41fe5b0 by task syz-executor.0/2806
CPU: 0 PID: 2806 Comm: syz-executor.0 Not tainted 5.0.0-rc7+ #45
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xfa/0x1ce lib/dump_stack.c:113
print_address_description+0x65/0x270 mm/kasan/report.c:187
kasan_report+0x149/0x18d mm/kasan/report.c:317
remove_proc_entry+0xe8/0x420 fs/proc/generic.c:667
atalk_proc_exit+0x18/0x820 [appletalk]
atalk_exit+0xf/0x5a [appletalk]
__do_sys_delete_module kernel/module.c:1018 [inline]
__se_sys_delete_module kernel/module.c:961 [inline]
__x64_sys_delete_module+0x3dc/0x5e0 kernel/module.c:961
do_syscall_64+0x147/0x600 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x462e99
Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007fb2de6b9c58 EFLAGS: 00000246 ORIG_RAX: 00000000000000b0
RAX: ffffffffffffffda RBX: 000000000073bf00 RCX: 0000000000462e99
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 00000000200001c0
RBP: 0000000000000002 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fb2de6ba6bc
R13: 00000000004bccaa R14: 00000000006f6bc8 R15: 00000000ffffffff
Allocated by task 2806:
set_track mm/kasan/common.c:85 [inline]
__kasan_kmalloc.constprop.3+0xa0/0xd0 mm/kasan/common.c:496
slab_post_alloc_hook mm/slab.h:444 [inline]
slab_alloc_node mm/slub.c:2739 [inline]
slab_alloc mm/slub.c:2747 [inline]
kmem_cache_alloc+0xcf/0x250 mm/slub.c:2752
kmem_cache_zalloc include/linux/slab.h:730 [inline]
__proc_create+0x30f/0xa20 fs/proc/generic.c:408
proc_mkdir_data+0x47/0x190 fs/proc/generic.c:469
0xffffffffc10c01bb
0xffffffffc10c0166
do_one_initcall+0xfa/0x5ca init/main.c:887
do_init_module+0x204/0x5f6 kernel/module.c:3460
load_module+0x66b2/0x8570 kernel/module.c:3808
__do_sys_finit_module+0x238/0x2a0 kernel/module.c:3902
Freed by task 2806:
__kasan_slab_free+0x130/0x180 mm/kasan/common.c:458
slab_free_hook mm/slub.c:1409 [inline]
slab_free_freelist_hook mm/slub.c:1436 [inline]
slab_free mm/slub.c:2986 [inline]
kmem_cache_free+0xa6/0x2a0 mm/slub.c:3002
pde_put+0x6e/0x80 fs/proc/generic.c:647
remove_proc_entry+0x1d3/0x420 fs/proc/generic.c:684
0xffffffffc10c031c
0xffffffffc10c0166
The buggy address belongs to the object at ffff8881f41fe500
which belongs to the cache proc_dir_entry of size 256
The buggy address is located 176 bytes inside of
256-byte region [ffff8881f41fe500, ffff8881f41fe600)
The buggy address belongs to the page:
page:ffffea0007d07f80 count:1 mapcount:0 mapping:ffff8881f6e69a00 index:0x0
flags: 0x2fffc0000000200(slab)
raw: 02fffc0000000200 dead000000000100 dead000000000200 ffff8881f6e69a00
raw: 0000000000000000 00000000800c000c 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8881f41fe480: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
ffff8881f41fe500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8881f41fe580: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881f41fe600: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8881f41fe680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
It should check the return value of atalk_proc_init fails,
otherwise atalk_exit will trgger use-after-free in pde_subdir_find
while unload the module.This patch fix error cleanup path of atalk_init
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
type T;
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
Now that %z is standartised in C99 there is no reason to support %Z.
Unlike %L it doesn't even make format strings smaller.
Use BUILD_BUG_ON in a couple ATM drivers.
In case anyone didn't notice lib/vsprintf.o is about half of SLUB which
is in my opinion is quite an achievement. Hopefully this patch inspires
someone else to trim vsprintf.c more.
Link: http://lkml.kernel.org/r/20170103230126.GA30170@avx2
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled either
built-in or as a module, use that macro instead of open coding the same.
Using the macro makes the code more readable by helping abstract away some
of the Kconfig built-in and module enable details.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The atalk_sendmsg() function might return wrong value ENETUNREACH
instead of -ENETUNREACH.
Signed-off-by: Anton Protopopov <a.s.protopopov@gmail.com>
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
Use the built-in function instead of memset.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Setting just skb->sk without taking its reference and setting a
destructor is invalid. However, in the places where this was done, skb
is used in a way not requiring skb->sk setting. So dropping the setting
of skb->sk.
Thanks to Eric Dumazet <eric.dumazet@gmail.com> for correct solution.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=79441
Reported-by: Ed Martin <edman007@edman007.com>
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
This warning is introduced by commit 7b30600cc6 ("appletalk:
fix checkpatch error with indent"), So fix it.
Signed-off-by: Wang Weidong <wangweidong1@huawei.com>
Define separate fields in the sock structure for configuring disabling
checksums in both TX and RX-- sk_no_check_tx and sk_no_check_rx.
The SO_NO_CHECK socket option only affects sk_no_check_tx. Also,
removed UDP_CSUM_* defines since they are no longer necessary.
Signed-off-by: Tom Herbert <therbert@google.com>
checkpatch error: switch and case should be at the same indent.
fix checkpatch errors below:
ERROR: "foo* bar" should be "foo *bar"
ERROR: "foo * bar" should be "foo *bar"
fix checkpatch errors while the space is required or prohibited
net/appletalk/aarp.c: In function ‘__aarp_send_query’:
net/appletalk/aarp.c:137:2: error: implicit declaration of function ‘ether_addr_copy’ [-Werror=implicit-function-declaration]
net/atm/lec.c: In function ‘send_to_lecd’:
net/atm/lec.c:524:3: warning: passing argument 1 of ‘ether_addr_copy’ from incompatible pointer type [enabled by default]
In file included from net/atm/lec.c:17:0:
include/linux/etherdevice.h:227:20: note: expected ‘u8 *’ but argument is of type ‘unsigned char (*)[6]’
net/caif/caif_usb.c: In function ‘cfusbl_create’:
net/caif/caif_usb.c:108:2: error: implicit declaration of function ‘ether_addr_copy’ [-Werror=implicit-function-declaration]
Use ether_addr_copy instead of memcpy(a, b, ETH_ALEN) to
save some cycles on arm and powerpc.
Convert struct aarp_entry.hwaddr[6] to hwaddr[ETH_ALEN].
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
UIDs are printed in the proc_fs as signed int, whereas
they are unsigned int.
Signed-off-by: Francesco Fusco <ffusco@redhat.com>
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
There is a one byte hole between ->sat_port and ->sat_addr.
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Fix incorrect start markers, wrapped summary lines, missing section
breaks, incorrect separators, and some name mismatches.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
I accidentally triggered this printk, which amused me for a few moments.
Given we're post 2.2, we could just -EACCES, but does anyone even care about Appletalk now ?
I figure it's better to leave sleeping dogs lie, and just update the message.
Signed-off-by: Dave Jones <davej@redhat.com>
This results in code with less boiler plate that is a bit easier
to read.
Additionally stops us from using compatibility code in the sysctl
core, hastening the day when the compatibility code can be removed.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
This makes it clearer which sysctls are relative to your current network
namespace.
This makes it a little less error prone by not exposing sysctls for the
initial network namespace in other namespaces.
This is the same way we handle all of our other network interfaces to
userspace and I can't honestly remember why we didn't do this for
sysctls right from the start.
Since commit 3e4d3af501 (mm: stack based kmap_atomic()) we dont have
to disable BH anymore while mapping skb frags.
We can remove kmap_skb_frag() / kunmap_skb_frag() helpers and use
kmap_atomic() / kunmap_atomic()
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
To ease skb->truesize sanitization, its better to be able to localize
all references to skb frags size.
Define accessors : skb_frag_size() to fetch frag size, and
skb_frag_size_{set|add|sub}() to manipulate it.
Make the case labels the same indent as the switch.
(git diff -w net/appletalk shows no difference)
Commit 60d9f461a20ba59219fdcdc30cbf8e3a4ad3f625 ("appletalk: remove
the BKL") added a dereference of "sk" before checking for NULL in
atalk_release().
Guard the code block completely, rather than partially, with the
NULL check.
Reported-by: Dave Jones <davej@redhat.com>
The BKL removal in appletalk introduced a use-after-free problem,
where atalk_destroy_socket frees a sock, but we still release
the socket lock on it.
An easy fix is to take an extra reference on the sock and sock_put
it when returning from atalk_release.
This changes appletalk to use lock_sock instead of
lock_kernel for serialization. I tried to make sure
that we don't hold the socket lock during sleeping
functions, but I did not try to prove whether the
locks are necessary in the first place.
Compile-tested only.
Cc: netdev@vger.kernel.org
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Simplify seq_file code.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
da.s_net was not copied but assigned to itself.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits)
mac80211: fix reorder buffer release
iwmc3200wifi: Enable wimax core through module parameter
iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter
iwmc3200wifi: Coex table command does not expect a response
iwmc3200wifi: Update wiwi priority table
iwlwifi: driver version track kernel version
iwlwifi: indicate uCode type when fail dump error/event log
iwl3945: remove duplicated event logging code
b43: fix two warnings
ipw2100: fix rebooting hang with driver loaded
cfg80211: indent regulatory messages with spaces
iwmc3200wifi: fix NULL pointer dereference in pmkid update
mac80211: Fix TX status reporting for injected data frames
ath9k: enable 2GHz band only if the device supports it
airo: Fix integer overflow warning
rt2x00: Fix padding bug on L2PAD devices.
WE: Fix set events not propagated
b43legacy: avoid PPC fault during resume
b43: avoid PPC fault during resume
tcp: fix a timewait refcnt race
Fix up conflicts due to sysctl cleanups (dead sysctl_check code and
CTL_UNNUMBERED removed) in
kernel/sysctl_check.c
net/ipv4/sysctl_net_ipv4.c
net/ipv6/addrconf.c
net/sctp/sysctl.c
Generated with the following semantic patch
struct net *n1;
struct net *n2;
- n1 == n2
+ net_eq(n1, n2)
struct net *n1;
struct net *n2;
- n1 != n2
+ !net_eq(n1, n2)
applied over {include,net,drivers/net}.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
