path: root/net/atm/mpc.c
2010-12-19net: kill unused macrosShan Wei
These macros never be used, so remove them. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-11ATM: mpc, fix use after freeJiri Slaby
Stanse found that mpc_push frees skb and then it dereferences it. It is a typo, new_skb should be dereferenced there. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-26net/atm: Cleanup dprint/ddprintk #defines and usesJoe Perches
Move "mpoa:%s: ", __func__/__FILE__ to #defines Remove mpoa __func__/__FILE__ from dprintk uses Add and use #define dprint_cont where appropriate Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26net/atm/mpc.c: checkpatch cleanupsJoe Perches
Convert #include <asm... to #include <linux... Add printk argument verification to dprintk and ddprintk Spacing cleanups Mostly 80 column wrapped. printk->pr_info and pr_cont Moved labels to column 1 Move trailing statements to new lines switch/case cleanups remove unnecessary breaks after returns Remove unnecessary braces around single line statements Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26net/atm: Convert printk to pr_<level>Joe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s: " fmt, __func__ Remove function names from output Use single line pr_debug instead of broken multiple uses without newline Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01convert ATM drivers to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: convert remaining non-symbolic return values in ndo_start_xmit() functionsPatrick McHardy
This patch converts the remaining occurences of raw return values to their symbolic counterparts in ndo_start_xmit() functions that were missed by the previous automatic conversion. Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero is changed to explicitly use NETDEV_TX_OK. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21atm: convert mpc device to using netdev_opsStephen Hemminger
This converts the mpc device to using new netdevice_ops. Compile tested only, needs more than usual review since device was swaping pointers around etc. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-08netdevice: Kill netdev->privWang Chen
This is the last shoot of this series. After I removing all directly reference of netdev->priv, I am killing "priv" of "struct net_device" and fixing relative comments/docs. Anyone will not be allowed to reference netdev->priv directly. If you want to reference the memory of private data, use netdev_priv() instead. If the private data is not allocted when alloc_netdev(), use netdev->ml_priv to point that memory after you creating that private data. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-4Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-30atm: fix const assignment/discard warnings in the ATM networking driverDavid Howells
Fix const assignment/discard warnings in the ATM networking driver. The lane2_assoc_ind() function needed its arguments changing to match changes in the lane2_ops struct (patch 61c33e012964ce358b42d2a1e9cd309af5dab02b "atm: use const where reasonable"). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-09[ATM]: Check IP header validity in mpc_send_packetHerbert Xu
Al went through the ip_fast_csum callers and found this piece of code that did not validate the IP header. While root crashing the machine by sending bogus packets through raw or AF_PACKET sockets isn't that serious, it is still nice to react gracefully. This patch ensures that the skb has enough data for an IP header and that the header length field is valid. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NET]: SPIN_LOCK_UNLOCKED cleanup in drivers/atm, netMilind Arun Choudhary
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] ATM: Fix whitespace errors.YOSHIFUJI Hideaki
2006-12-02[ATM]: Use kmemdup & kzalloc where applicableArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[ATM]: Annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[ATM]: use NIPQUAD instead of open-coding itAl Viro
2006-09-22[ATM]: proper prototypes in net/atm/mpc.h (and reduce ifdef clutter)Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-26[ATM]: atm/mpc.c warning fixAndrew Morton
net/atm/mpc.c: In function 'MPOA_res_reply_rcvd': net/atm/mpc.c:1116: warning: unused variable 'ip' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-20[ATM]: fix broken uses of NIPQUAD in net/atmAl Viro
NIPQUAD expects an l-value of type __be32, _NOT_ a pointer to __be32. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[NET]: Change memcmp(,,ETH_ALEN) to compare_ether_addr()Kris Katterjohn
This changes some memcmp(one,two,ETH_ALEN) to compare_ether_addr(one,two). Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-09[PATCH] timer initialization cleanup: DEFINE_TIMERIngo Molnar
Clean up timer initialization by introducing DEFINE_TIMER a'la DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been been in the -RT tree for some time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
