path: root/net/atm/mpoa_caches.c
2007-02-10[NET] ATM: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[ATM]: Use kmemdup & kzalloc where applicableArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[ATM]: Annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[ATM]: use NIPQUAD instead of open-coding itAl Viro
2006-06-20[ATM]: fix broken uses of NIPQUAD in net/atmAl Viro
NIPQUAD expects an l-value of type __be32, _NOT_ a pointer to __be32. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
