path: root/net/atm/resources.c
2008-12-03atm: 32-bit ioctl compatibilityDavid Woodhouse
We lack compat ioctl support through most of the ATM code. This patch deals with most of it, and I can now at least use BR2684 and PPPoATM with 32-bit userspace. I haven't added a .compat_ioctl method to struct atm_ioctl, because AFAICT none of the current users need any conversion -- so we can just call the ->ioctl() method in every case. I looked at br2684, clip, lec, mpc, pppoatm and atmtcp. In svc_compat_ioctl() the only mangling which is needed is to change COMPAT_ATM_ADDPARTY to ATM_ADDPARTY. Although it's defined as _IOW('a', ATMIOC_SPECIAL+4,struct atm_iobuf) it doesn't actually _take_ a struct atm_iobuf as an argument -- it takes a struct sockaddr_atmsvc, which _is_ the same between 32-bit and 64-bit code, so doesn't need conversion. Almost all of vcc_ioctl() would have been identical, so I converted that into a core do_vcc_ioctl() function with an 'int compat' argument. I've done the same with atm_dev_ioctl(), where there _are_ a few differences, but still it's relatively contained and there would otherwise have been a lot of duplication. I haven't done any of the actual device-specific ioctls, although I've added a compat_ioctl method to struct atmdev_ops. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-10[ATM]: Use SEQ_START_TOKENJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] ATM: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[ATM]: basic sysfs support for ATM devicesRoman Kagan
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: sem2mutex part 2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-29[ATM]: deregistration removes device from atm_devs list immediatelyStanislaw Gruszka
atm_dev_deregister() removes device from atm_dev list immediately to prevent operations on a phantom device. Decision to free device based only on ->refcnt now. Remove shutdown_atm_dev() use atm_dev_deregister() instead. atm_dev_deregister() also asynchronously releases all vccs related to device. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[ATM]: avoid race conditions related to atm_devs listStanislaw Gruszka
Use semaphore to protect atm_devs list, as no one need access to it from interrupt context. Avoid race conditions between atm_dev_register(), atm_dev_lookup() and atm_dev_deregister(). Fix double spin_unlock() bug. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[ATM]: attempt to autoload atm driversMitchell Blank Jr
From: Mitchell Blank Jr <mitch@sfgoth.com> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-06[ATM]: add support for LECS addresses learned from networkEric Kinzie
From: Eric Kinzie <ekinzie@cmf.nrl.navy.mil> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-21[ATM]: net/atm/resources.c: remove __free_atm_devAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
