[ Upstream commit 3ef7cf57c72f32f61e97f8fa401bc39ea1f1a5d4 ]
Many poll() handlers are lockless. Using skb_queue_empty_lockless()
instead of skb_queue_empty() is more appropriate.
[ Upstream commit 899537b73557aafbdd11050b501cf54b4f5c45af ]
arg is controlled by user-space, hence leading to a potential
exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
net/atm/lec.c:715 lec_mcast_attach() warn: potential spectre issue 'dev_lec' [r] (local cap)
Fix this by sanitizing arg before using it to index dev_lec.
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://lore.kernel.org/lkml/20180423164740.GY17484@dhcp22.suse.cz/
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
[ Upstream commit 9bbe60a67be5a1c6f79b3c9be5003481a50529ff ]
ATM accounts for in-flight TX packets in sk_wmem_alloc of the VCC on
which they are to be sent. But it doesn't take ownership of those
packets from the sock (if any) which originally owned them. They should
remain owned by their actual sender until they've left the box.
There's a hack in pskb_expand_head() to avoid adjusting skb->truesize
for certain skbs, precisely to avoid messing up sk_wmem_alloc
accounting. Ideally that hack would cover the ATM use case too, but it
doesn't — skbs which aren't owned by any sock, for example PPP control
frames, still get their truesize adjusted when the low-level ATM driver
adds headroom.
This has always been an issue, it seems. The truesize of a packet
increases, and sk_wmem_alloc on the VCC goes negative. But this wasn't
for normal traffic, only for control frames. So I think we just got away
with it, and we probably needed to send 2GiB of LCP echo frames before
the misaccounting would ever have caused a problem and caused
atm_may_send() to start refusing packets.
Commit 14afee4b609 ("net: convert sock.sk_wmem_alloc from atomic_t to
refcount_t") did exactly what it was intended to do, and turned this
mostly-theoretical problem into a real one, causing PPPoATM to fail
immediately as sk_wmem_alloc underflows and atm_may_send() *immediately*
starts refusing to allow new packets.
The least intrusive solution to this problem is to stash the value of
skb->truesize that was accounted to the VCC, in a new member of the
ATM_SKB(skb) structure. Then in atm_pop_raw() subtract precisely that
value instead of the then-current value of skb->truesize.
Fixes: 158f323b9868 ("net: adjust skb->truesize in pskb_expand_head()")
Tested-by: Kevin Darbyshire-Bryant <ldir@darbyshire-bryant.me.uk>
commit acf784bd0ce257fe43da7ca266f7a10b837479d2 upstream.
ioc_data.dev_num can be controlled by user-space, hence leading to
a potential exploitation of the Spectre variant 1 vulnerability.
net/atm/lec.c:702 lec_vcc_attach() warn: potential spectre issue
'dev_lec'
Fix this by sanitizing ioc_data.dev_num before using it to index
dev_lec. Also, notice that there is another instance in which array
dev_lec is being indexed using ioc_data.dev_num at line 705:
lec_vcc_added(netdev_priv(dev_lec[ioc_data.dev_num]),
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Cc: stable@vger.kernel.org
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Make these const as they are only stored in the ops field of a atm_dev
structure, which is const.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
situations.
situations.
situations.
situations.
This patch uses refcount_inc_not_zero() instead of
atomic_inc_not_zero_hint() due to absense of a _hint()
version of refcount API. If the hint() version must
be used, we might need to revisit API.
situations.
situations.
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
There were many places that my previous spatch didn't find,
as pointed out by yuan linyu in various patches.
The following spatch found many more and also removes the
now unnecessary casts:
identifier p, p2;
expression len;
expression skb;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_zero(skb, len);
-p = (t)skb_put(skb, len);
... when != p
p2 = (t2)p;
-memset(p2, 0, len);
-memset(p, 0, len);
type t, t2;
identifier p, p2;
expression skb;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_zero(skb, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
... when != p
p2 = (t2)p;
-memset(p2, 0, sizeof(*p));
-memset(p, 0, sizeof(*p));
expression skb, len;
-memset(skb_put(skb, len), 0, len);
+skb_put_zero(skb, len);
Apply it to the tree (with one manual fixup to keep the
comment in vxlan.c, which spatch removed.)
neigh notifications today carry pid 0 for nlmsg_pid
in all cases. This patch fixes it to carry calling process
pid when available. Applications (eg. quagga) rely on
nlmsg_pid to ignore notifications generated by their own
netlink operations. This patch follows the routing subsystem
which already sets this correctly.
Reported-by: Vivek Venkatraman <vivek@cumulusnetworks.com>
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
drivers/net/ethernet/broadcom/genet/bcmgenet.c
net/core/sock.c
Conflicts were overlapping changes in bcmgenet and the
lockdep handling of sockets.
Andrey reported this kernel warning:
WARNING: CPU: 0 PID: 4114 at kernel/sched/core.c:7737 __might_sleep+0x149/0x1a0
do not call blocking ops when !TASK_RUNNING; state=1 set at
[<ffffffff813fcb22>] prepare_to_wait+0x182/0x530
The deeply nested alloc_skb is a problem.
Diagnosis: nesting is wrong. It makes zero sense. Fix it and the
implicit task state change problem automagically goes away.
alloc_skb() does not need to be in the "while" loop.
alloc_skb() does not need to be in the {prepare_to_wait/add_wait_queue ...
finish_wait/remove_wait_queue} block.
I claim that:
- alloc_tx() should only perform the "wait_for_decent_tx_drain" part
- alloc_skb() ought to be done directly in vcc_sendmsg
- alloc_skb() failure can be handled gracefully in vcc_sendmsg
- alloc_skb() may use a (m->msg_flags & MSG_DONTWAIT) dependent
GFP_{KERNEL / ATOMIC} flag
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Reviewed-and-Tested-by: Chas Williams <3chas3@gmail.com>
Signed-off-by: Chas Williams <3chas3@gmail.com>
Lockdep issues a circular dependency warning when AFS issues an operation
through AF_RXRPC from a context in which the VFS/VM holds the mmap_sem.
The theory lockdep comes up with is as follows:
(1) If the pagefault handler decides it needs to read pages from AFS, it
calls AFS with mmap_sem held and AFS begins an AF_RXRPC call, but
creating a call requires the socket lock:
mmap_sem must be taken before sk_lock-AF_RXRPC
(2) afs_open_socket() opens an AF_RXRPC socket and binds it. rxrpc_bind()
binds the underlying UDP socket whilst holding its socket lock.
inet_bind() takes its own socket lock:
sk_lock-AF_RXRPC must be taken before sk_lock-AF_INET
(3) Reading from a TCP socket into a userspace buffer might cause a fault
and thus cause the kernel to take the mmap_sem, but the TCP socket is
locked whilst doing this:
sk_lock-AF_INET must be taken before mmap_sem
However, lockdep's theory is wrong in this instance because it deals only
with lock classes and not individual locks. The AF_INET lock in (2) isn't
really equivalent to the AF_INET lock in (3) as the former deals with a
socket entirely internal to the kernel that never sees userspace. This is
a limitation in the design of lockdep.
Fix the general case by:
(1) Double up all the locking keys used in sockets so that one set are
used if the socket is created by userspace and the other set is used
if the socket is created by the kernel.
(2) Store the kern parameter passed to sk_alloc() in a variable in the
sock struct (sk_kern_sock). This informs sock_lock_init(),
sock_init_data() and sk_clone_lock() as to the lock keys to be used.
Note that the child created by sk_clone_lock() inherits the parent's
kern setting.
(3) Add a 'kern' parameter to ->accept() that is analogous to the one
passed in to ->create() that distinguishes whether kernel_accept() or
sys_accept4() was the caller and can be passed to sk_alloc().
Note that a lot of accept functions merely dequeue an already
allocated socket. I haven't touched these as the new socket already
exists before we get the parameter.
Note also that there are a couple of places where I've made the accepted
socket unconditionally kernel-based:
irda_accept()
rds_rcp_accept_one()
tcp_accept_from_sock()
because they follow a sock_create_kern() and accept off of that.
Whilst creating this, I noticed that lustre and ocfs don't create sockets
through sock_create_kern() and thus they aren't marked as for-kernel,
though they appear to be internal. I wonder if these should do that so
that they use the new set of lock keys.
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/signal.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Now that %z is standartised in C99 there is no reason to support %Z.
Unlike %L it doesn't even make format strings smaller.
Use BUILD_BUG_ON in a couple ATM drivers.
In case anyone didn't notice lib/vsprintf.o is about half of SLUB which
is in my opinion is quite an achievement. Hopefully this patch inspires
someone else to trim vsprintf.c more.
Link: http://lkml.kernel.org/r/20170103230126.GA30170@avx2
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
This patch fixes the following warnings when CONFIG_PROC_FS is not set:
linux/net/atm/lec.c: In function ‘lane_module_cleanup’:
linux/net/atm/lec.c:1062:27: error: ‘atm_proc_root’ undeclared (first
use in this function)
remove_proc_entry("lec", atm_proc_root);
linux/net/atm/lec.c:1062:27: note: each undeclared identifier is
reported only once for each function it appears in
Signed-off-by: Augusto Mecking Caringi <augustocaringi@gmail.com>
Pull networking fixes and cleanups from David Miller:
1) Revert bogus nla_ok() change, from Alexey Dobriyan.
2) Various bpf validator fixes from Daniel Borkmann.
3) Add some necessary SET_NETDEV_DEV() calls to hsis_femac and hip04
drivers, from Dongpo Li.
4) Several ethtool ksettings conversions from Philippe Reynes.
5) Fix bugs in inet port management wrt. soreuseport, from Tom Herbert.
6) XDP support for virtio_net, from John Fastabend.
7) Fix NAT handling within a vrf, from David Ahern.
8) Endianness fixes in dpaa_eth driver, from Claudiu Manoil
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (63 commits)
net: mv643xx_eth: fix build failure
isdn: Constify some function parameters
mlxsw: spectrum: Mark split ports as such
cgroup: Fix CGROUP_BPF config
qed: fix old-style function definition
net: ipv6: check route protocol when deleting routes
r6040: move spinlock in r6040_close as SOFTIRQ-unsafe lock order detected
irda: w83977af_ir: cleanup an indent issue
net: sfc: use new api ethtool_{get|set}_link_ksettings
net: davicom: dm9000: use new api ethtool_{get|set}_link_ksettings
net: cirrus: ep93xx: use new api ethtool_{get|set}_link_ksettings
net: chelsio: cxgb3: use new api ethtool_{get|set}_link_ksettings
net: chelsio: cxgb2: use new api ethtool_{get|set}_link_ksettings
bpf: fix mark_reg_unknown_value for spilled regs on map value marking
bpf: fix overflow in prog accounting
bpf: dynamically allocate digest scratch buffer
gtp: Fix initialization of Flags octet in GTPv1 header
gtp: gtp_check_src_ms_ipv4() always return success
net/x25: use designated initializers
isdn: use designated initializers
Prepare to mark sensitive kernel structures for randomization by making
sure they're using designated initializers. These were identified during
allyesconfig builds of x86, arm, and arm64, with most initializer fixes
extracted from grsecurity.
Pull vfs updates from Al Viro:
- more ->d_init() stuff (work.dcache)
- pathname resolution cleanups (work.namei)
- a few missing iov_iter primitives - copy_from_iter_full() and
friends. Either copy the full requested amount, advance the iterator
and return true, or fail, return false and do _not_ advance the
iterator. Quite a few open-coded callers converted (and became more
readable and harder to fuck up that way) (work.iov_iter)
- several assorted patches, the big one being logfs removal
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
logfs: remove from tree
vfs: fix put_compat_statfs64() does not handle errors
namei: fold should_follow_link() with the step into not-followed link
namei: pass both WALK_GET and WALK_MORE to should_follow_link()
namei: invert WALK_PUT logics
namei: shift interpretation of LOOKUP_FOLLOW inside should_follow_link()
namei: saner calling conventions for mountpoint_last()
namei.c: get rid of user_path_parent()
switch getfrag callbacks to ..._full() primitives
make skb_add_data,{_nocache}() and skb_copy_to_page_nocache() advance only on success
[iov_iter] new primitives - copy_from_iter_full() and friends
don't open-code file_inode()
ceph: switch to use of ->d_init()
ceph: unify dentry_operations instances
lustre: switch to use of ->d_init()
copy_from_iter_full(), copy_from_iter_full_nocache() and
csum_and_copy_from_iter_full() - counterparts of copy_from_iter()
et.al., advancing iterator only in case of successful full copy
and returning whether it had been successful or not.
Convert some obvious users. *NOTE* - do not blindly assume that
something is a good candidate for those unless you are sure that
not advancing iov_iter in failure case is the right thing in
this case. Anything that does short read/short write kind of
stuff (or is in a loop, etc.) is unlikely to be a good one.
These few drivers call ether_setup(), but have no ndo_change_mtu, and thus
were overlooked for changes to MTU range checking behavior. They
previously had no range checks, so for feature-parity, set their min_mtu
to 0 and max_mtu to ETH_MAX_MTU (65535), instead of the 68 and 1500
inherited from the ether_setup() changes. Fine-tuning can come after we get
back to full feature-parity here.
CC: netdev@vger.kernel.org
Reported-by: Asbjoern Sloth Toennesen <asbjorn@asbjorn.st>
CC: Asbjoern Sloth Toennesen <asbjorn@asbjorn.st>
CC: R Parameswaran <parameswaran.r7@gmail.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
- set min/max_mtu in all hdlc drivers, remove hdlc_change_mtu
- sent max_mtu in lec driver, remove lec_change_mtu
- set min/max_mtu in x25_asy driver
CC: Krzysztof Halasa <khc@pm.waw.pl>
CC: Krzysztof Halasa <khalasa@piap.pl>
CC: Jan "Yenya" Kasprzak <kas@fi.muni.cz>
CC: Francois Romieu <romieu@fr.zoreil.com>
CC: Kevin Curtis <kevin.curtis@farsite.co.uk>
CC: Zhao Qiang <qiang.zhao@nxp.com>
With centralized MTU checking, there's nothing productive done by
eth_change_mtu that isn't already done in dev_set_mtu, so mark it as
deprecated and remove all usage of it in the kernel. All callers have been
audited for calls to alloc_etherdev* or ether_setup directly, which means
they all have a valid dev->min_mtu and dev->max_mtu. Now eth_change_mtu
prints out a netdev_warn about being deprecated, for the benefit of
out-of-tree drivers that might be utilizing it.
Of note, dvb_net.c actually had dev->mtu = 4096, while using
eth_change_mtu, meaning that if you ever tried changing it's mtu, you
couldn't set it above 1500 anymore. It's now getting dev->max_mtu also set
to 4096 to remedy that.
v2: fix up lantiq_etop, missed breakage due to drive not compiling on x86
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled either
built-in or as a module, use that macro instead of open coding the same.
Using the macro makes the code more readable by helping abstract away some
of the Kconfig built-in and module enable details.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
dev->name is a char array of IFNAMSIZ elements, hence can never be
null, so the null pointer check is redundant. Remove it.
As the following patch will allow upper devices to follow the call down
lower devices, we need to add dev here and not rely on n->dev.
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
The sk_err and sk_err_soft fields are positive errno values and
userspace applications rely on this when using getsockopt(SO_ERROR).
ATM code places an -errno into sk_err_soft in sigd_send() and returns it
from svc_addparty()/svc_dropparty().
Although I am not familiar with ATM code I came to this conclusion
because:
1. sigd_send() msg->type cases as_okay and as_error both have:
sk->sk_err = -msg->reply;
while the as_addparty and as_dropparty cases have:
sk->sk_err_soft = msg->reply;
This is the source of the inconsistency.
2. svc_addparty() returns an -errno and assumes sk_err_soft is also an
-errno:
if (flags & O_NONBLOCK) {
error = -EINPROGRESS;
goto out;
error = xchg(&sk->sk_err_soft, 0);
out:
release_sock(sk);
return error;
This shows that sk_err_soft is indeed being treated as an -errno.
This patch ensures that sk_err_soft is always a positive errno.
Signed-off-by: Stefan Hajnoczi <stefanha@redhat.com>
Replace all trans_start updates with netif_trans_update helper.
change was done via spatch:
struct net_device *d;
- d->trans_start = jiffies
+ netif_trans_update(d)
Compile tested only.
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-rdma@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: MPT-FusionLinux.pdl@broadcom.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-can@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: b.a.t.m.a.n@lists.open-mesh.org
Cc: linux-bluetooth@vger.kernel.org
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Antonio Quartulli <a@unstable.cc>
The memory barrier in the helper wq_has_sleeper is needed by just
about every user of waitqueue_active. This patch generalises it
by making it take a wait_queue_head_t directly. The existing
helper is renamed to skwq_has_sleeper.
The in_cache_ops and eg_cache_ops structures are never modified, so declare
them as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
If we didn't call ATMARP_MKIP before ATMARP_ENCAP the VCC descriptor is
non-existant and we'll end up dereferencing a NULL ptr:
[1033173.491930] kasan: GPF could be caused by NULL-ptr deref or user memory accessirq event stamp: 123386
[1033173.493678] general protection fault: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN
[1033173.493689] Modules linked in:
[1033173.493697] CPU: 9 PID: 23815 Comm: trinity-c64 Not tainted 4.2.0-next-20150911-sasha-00043-g353d875-dirty #2545
[1033173.493706] task: ffff8800630c4000 ti: ffff880063110000 task.ti: ffff880063110000
[1033173.493823] RIP: clip_ioctl (net/atm/clip.c:320 net/atm/clip.c:689)
[1033173.493826] RSP: 0018:ffff880063117a88 EFLAGS: 00010203
[1033173.493828] RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 000000000000000c
[1033173.493830] RDX: 0000000000000002 RSI: ffffffffb3f10720 RDI: 0000000000000014
[1033173.493832] RBP: ffff880063117b80 R08: ffff88047574d9a4 R09: 0000000000000000
[1033173.493834] R10: 0000000000000000 R11: 0000000000000000 R12: 1ffff1000c622f53
[1033173.493836] R13: ffff8800cb905500 R14: ffff8808d6da2000 R15: 00000000fffffdfd
[1033173.493840] FS: 00007fa56b92d700(0000) GS:ffff880478000000(0000) knlGS:0000000000000000
[1033173.493843] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[1033173.493845] CR2: 0000000000000000 CR3: 00000000630e8000 CR4: 00000000000006a0
[1033173.493855] Stack:
[1033173.493862] ffffffffb0b60444 000000000000eaea 0000000041b58ab3 ffffffffb3c3ce32
[1033173.493867] ffffffffb0b6f3e0 ffffffffb0b60444 ffffffffb5ea2e50 1ffff1000c622f5e
[1033173.493873] ffff8800630c4cd8 00000000000ee09a ffffffffb3ec4888 ffffffffb5ea2de8
[1033173.493874] Call Trace:
[1033173.494108] do_vcc_ioctl (net/atm/ioctl.c:170)
[1033173.494113] vcc_ioctl (net/atm/ioctl.c:189)
[1033173.494116] svc_ioctl (net/atm/svc.c:605)
[1033173.494200] sock_do_ioctl (net/socket.c:874)
[1033173.494204] sock_ioctl (net/socket.c:958)
[1033173.494244] do_vfs_ioctl (fs/ioctl.c:43 fs/ioctl.c:607)
[1033173.494290] SyS_ioctl (fs/ioctl.c:622 fs/ioctl.c:613)
[1033173.494295] entry_SYSCALL_64_fastpath (arch/x86/entry/entry_64.S:186)
[1033173.494362] Code: fa 48 c1 ea 03 80 3c 02 00 0f 85 50 09 00 00 49 8b 9e 60 06 00 00 48 b8 00 00 00 00 00 fc ff df 48 8d 7b 14 48 89 fa 48 c1 ea 03 <0f> b6 04 02 48 89 fa 83 e2 07 38 d0 7f 08 84 c0 0f 85 14 09 00
All code
0: fa cli
1: 48 c1 ea 03 shr $0x3,%rdx
5: 80 3c 02 00 cmpb $0x0,(%rdx,%rax,1)
9: 0f 85 50 09 00 00 jne 0x95f
f: 49 8b 9e 60 06 00 00 mov 0x660(%r14),%rbx
16: 48 b8 00 00 00 00 00 movabs $0xdffffc0000000000,%rax
1d: fc ff df
20: 48 8d 7b 14 lea 0x14(%rbx),%rdi
24: 48 89 fa mov %rdi,%rdx
27: 48 c1 ea 03 shr $0x3,%rdx
2b:* 0f b6 04 02 movzbl (%rdx,%rax,1),%eax <-- trapping instruction
2f: 48 89 fa mov %rdi,%rdx
32: 83 e2 07 and $0x7,%edx
35: 38 d0 cmp %dl,%al
37: 7f 08 jg 0x41
39: 84 c0 test %al,%al
3b: 0f 85 14 09 00 00 jne 0x955
Code starting with the faulting instruction
0: 0f b6 04 02 movzbl (%rdx,%rax,1),%eax
7: 83 e2 07 and $0x7,%edx
a: 38 d0 cmp %dl,%al
c: 7f 08 jg 0x16
e: 84 c0 test %al,%al
10: 0f 85 14 09 00 00 jne 0x92a
[1033173.494366] RIP clip_ioctl (net/atm/clip.c:320 net/atm/clip.c:689)
[1033173.494368] RSP <ffff880063117a88>
Use vsprintf extension %pI4 instead.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
Pull networking updates from David Miller:
1) Add BQL support to via-rhine, from Tino Reichardt.
2) Integrate SWITCHDEV layer support into the DSA layer, so DSA drivers
can support hw switch offloading. From Floria Fainelli.
3) Allow 'ip address' commands to initiate multicast group join/leave,
from Madhu Challa.
4) Many ipv4 FIB lookup optimizations from Alexander Duyck.
5) Support EBPF in cls_bpf classifier and act_bpf action, from Daniel
Borkmann.
6) Remove the ugly compat support in ARP for ugly layers like ax25,
rose, etc. And use this to clean up the neigh layer, then use it to
implement MPLS support. All from Eric Biederman.
7) Support L3 forwarding offloading in switches, from Scott Feldman.
8) Collapse the LOCAL and MAIN ipv4 FIB tables when possible, to speed
up route lookups even further. From Alexander Duyck.
9) Many improvements and bug fixes to the rhashtable implementation,
from Herbert Xu and Thomas Graf. In particular, in the case where
an rhashtable user bulk adds a large number of items into an empty
table, we expand the table much more sanely.
10) Don't make the tcp_metrics hash table per-namespace, from Eric
Biederman.
11) Extend EBPF to access SKB fields, from Alexei Starovoitov.
12) Split out new connection request sockets so that they can be
established in the main hash table. Much less false sharing since
hash lookups go direct to the request sockets instead of having to
go first to the listener then to the request socks hashed
underneath. From Eric Dumazet.
13) Add async I/O support for crytpo AF_ALG sockets, from Tadeusz Struk.
14) Support stable privacy address generation for RFC7217 in IPV6. From
Hannes Frederic Sowa.
15) Hash network namespace into IP frag IDs, also from Hannes Frederic
Sowa.
16) Convert PTP get/set methods to use 64-bit time, from Richard
Cochran.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1816 commits)
fm10k: Bump driver version to 0.15.2
fm10k: corrected VF multicast update
fm10k: mbx_update_max_size does not drop all oversized messages
fm10k: reset head instead of calling update_max_size
fm10k: renamed mbx_tx_dropped to mbx_tx_oversized
fm10k: update xcast mode before synchronizing multicast addresses
fm10k: start service timer on probe
fm10k: fix function header comment
fm10k: comment next_vf_mbx flow
fm10k: don't handle mailbox events in iov_event path and always process mailbox
fm10k: use separate workqueue for fm10k driver
fm10k: Set PF queues to unlimited bandwidth during virtualization
fm10k: expose tx_timeout_count as an ethtool stat
fm10k: only increment tx_timeout_count in Tx hang path
fm10k: remove extraneous "Reset interface" message
fm10k: separate PF only stats so that VF does not display them
fm10k: use hw->mac.max_queues for stats
fm10k: only show actual queues, not the maximum in hardware
fm10k: allow creation of VLAN on default vid
fm10k: fix unused warnings
Pull trivial tree from Jiri Kosina:
"Usual trivial tree updates. Nothing outstanding -- mostly printk()
and comment fixes and unused identifier removals"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
goldfish: goldfish_tty_probe() is not using 'i' any more
powerpc: Fix comment in smu.h
qla2xxx: Fix printks in ql_log message
lib: correct link to the original source for div64_u64
si2168, tda10071, m88ds3103: Fix firmware wording
usb: storage: Fix printk in isd200_log_config()
qla2xxx: Fix printk in qla25xx_setup_mode
init/main: fix reset_device comment
ipwireless: missing assignment
goldfish: remove unreachable line of code
coredump: Fix do_coredump() comment
stacktrace.h: remove duplicate declaration task_struct
smpboot.h: Remove unused function prototype
treewide: Fix typo in printk messages
mod_devicetable: fix comment for match_flags
This patch fix spelling typo in printk messages.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Use the built-in function instead of memset.
WAIT_FOR_DEMON code is directly undefined at the beginning
of signaling.c since initial git version and thus never compiled.
This also removes buggy current->state direct access.
Suggested-by: Chas Williams <chas@cmf.nrl.navy.mil>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
... and make it handle multi-segment iovecs - deals with that
"fix this later" issue for free. A bit of shame, really - it
had been there since 2.3.15pre3 when the whole thing went into the
tree, practically a historical artefact by now...
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Testing xmit_more support with netperf and connected UDP sockets,
I found strange dst refcount false sharing.
Current handling of IFF_XMIT_DST_RELEASE is not optimal.
Dropping dst in validate_xmit_skb() is certainly too late in case
packet was queued by cpu X but dequeued by cpu Y
The logical point to take care of drop/force is in __dev_queue_xmit()
before even taking qdisc lock.
As Julian Anastasov pointed out, need for skb_dst() might come from some
packet schedulers or classifiers.
This patch adds new helper to cleanly express needs of various drivers
or qdiscs/classifiers.
Drivers that need skb_dst() in their ndo_start_xmit() should call
following helper in their setup instead of the prior :
dev->priv_flags &= ~IFF_XMIT_DST_RELEASE;
netif_keep_dst(dev);
Instead of using a single bit, we use two bits, one being
eventually rebuilt in bonding/team drivers.
The other one, is permanent and blocks IFF_XMIT_DST_RELEASE being
rebuilt in bonding/team. Eventually, we could add something
smarter later.
Cc: Julian Anastasov <ja@ssi.bg>
