path: root/net/atm
2014-01-21net: Fix some fallout from the etner_addr_copy() changes.David S. Miller
net/appletalk/aarp.c: In function ‘__aarp_send_query’: net/appletalk/aarp.c:137:2: error: implicit declaration of function ‘ether_addr_copy’ [-Werror=implicit-function-declaration] ... net/atm/lec.c: In function ‘send_to_lecd’: net/atm/lec.c:524:3: warning: passing argument 1 of ‘ether_addr_copy’ from incompatible pointer type [enabled by default] In file included from net/atm/lec.c:17:0: include/linux/etherdevice.h:227:20: note: expected ‘u8 *’ but argument is of type ‘unsigned char (*)[6]’ ... net/caif/caif_usb.c: In function ‘cfusbl_create’: net/caif/caif_usb.c:108:2: error: implicit declaration of function ‘ether_addr_copy’ [-Werror=implicit-function-declaration] Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-21atm: Use ether_addr_copyJoe Perches
Use ether_addr_copy instead of memcpy(a, b, ETH_ALEN) to save some cycles on arm and powerpc. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: always pass struct netdev_notifier_info to netdevice notifiersCong Wang
commit 351638e7deeed2ec8ce451b53d3 (net: pass info struct via netdevice notifier) breaks booting of my KVM guest, this is due to we still forget to pass struct netdev_notifier_info in several places. This patch completes it. Cc: Jiri Pirko <jiri@resnulli.us> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/nfc/microread/mei.c net/netfilter/nfnetlink_queue_core.c Pull in 'net' to get Eric Biederman's AF_UNIX fix, upon which some cleanups are going to go on-top. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07atm: update msg_namelen in vcc_recvmsg()Mathias Krause
The current code does not fill the msg_name member in case it is set. It also does not set the msg_namelen member to 0 and therefore makes net/socket.c leak the local, uninitialized sockaddr_storage variable to userland -- 128 bytes of kernel stack memory. Fix that by simply setting msg_namelen to 0 as obviously nobody cared about vcc_recvmsg() not filling the msg_name in case it was set. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-28net: add ETH_P_802_3_MINSimon Horman
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for an 802.3 frame. Frames with a lower value in the ethernet type field are Ethernet II. Also update all the users of this value that David Miller and I could find to use the new constant. Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN should be >= not >. As suggested by Jesse Gross. Compile tested only. Cc: David Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: John W. Linville <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Bart De Schuymer <bart.de.schuymer@pandora.be> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: linux-bluetooth@vger.kernel.org Cc: netfilter-devel@vger.kernel.org Cc: bridge@lists.linux-foundation.org Cc: linux-wireless@vger.kernel.org Cc: linux1394-devel@lists.sourceforge.net Cc: linux-media@vger.kernel.org Cc: netdev@vger.kernel.org Cc: dev@openvswitch.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-17atm: use scnprintf() instead of sprintf()chas williams - CONTRACTOR
As reported by Chen Gang <gang.chen@asianux.com>, we should ensure there is enough space when formatting the sysfs buffers. Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-02pppoatm: optimise PPP channel wakeups after sock_owned_by_user()David Woodhouse
We don't need to schedule the wakeup tasklet on *every* unlock; only if we actually blocked the channel in the first place. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Krzysztof Mazur <krzysiek@podlesie.net>
2012-12-02br2684: allow assign only on a connected socketKrzysztof Mazur
The br2684 does not check if used vcc is in connected state, causing potential Oops in pppoatm_send() when vcc->send() is called on not fully connected socket. Now br2684 can be assigned only on connected sockets; otherwise -EINVAL error is returned. Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-12-02br2684: fix module_put() raceDavid Woodhouse
The br2684 code used module_put() during unassignment from vcc with hope that we have BKL. This assumption is no longer true. Now owner field in atmvcc is used to move this module_put() to vcc_destroy_socket(). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Krzysztof Mazur <krzysiek@podlesie.net>
2012-12-02pppoatm: fix missing wakeup in pppoatm_send()David Woodhouse
Now that we can return zero from pppoatm_send() for reasons *other* than the queue being full, that means we can't depend on a subsequent call to pppoatm_pop() waking the queue, and we might leave it stalled indefinitely. Use the ->release_cb() callback to wake the queue after the sock is unlocked. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Krzysztof Mazur <krzysiek@podlesie.net>
2012-12-02br2684: don't send frames on not-ready vccDavid Woodhouse
Avoid submitting packets to a vcc which is being closed. Things go badly wrong when the ->pop method gets later called after everything's been torn down. Use the ATM socket lock for synchronisation with vcc_destroy_socket(), which clears the ATM_VF_READY bit under the same lock. Otherwise, we could end up submitting a packet to the device driver even after its ->ops->close method has been called. And it could call the vcc's ->pop method after the protocol has been shut down. Which leads to a panic. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Krzysztof Mazur <krzysiek@podlesie.net>
2012-12-02atm: add release_cb() callback to vccDavid Woodhouse
The immediate use case for this is that it will allow us to ensure that a pppoatm queue is woken after it has to drop a packet due to the sock being locked. Note that 'release_cb' is called when the socket is *unlocked*. This is not to be confused with vcc_release() — which probably ought to be called vcc_close(). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Krzysztof Mazur <krzysiek@podlesie.net>
2012-11-30pppoatm: do not inline pppoatm_may_send()Krzysztof Mazur
The pppoatm_may_send() is quite heavy and it's called three times in pppoatm_send() and inlining costs more than 200 bytes of code (more than 10% of total pppoatm driver code size). add/remove: 1/0 grow/shrink: 0/1 up/down: 132/-367 (-235) function old new delta pppoatm_may_send - 132 +132 pppoatm_send 900 533 -367 Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-11-30pppoatm: drop frames to not-ready vccKrzysztof Mazur
The vcc_destroy_socket() closes vcc before the protocol is detached from vcc by calling vcc->push() with NULL skb. This leaves some time window, where the protocol may call vcc->send() on closed vcc and crash. Now pppoatm_send(), like vcc_sendmsg(), checks for vcc flags that indicate that vcc is not ready. If the vcc is not ready we just drop frame. Queueing frames is much more complicated because we don't have callbacks that inform us about vcc flags changes. Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-11-28pppoatm: take ATM socket lock in pppoatm_send()Krzysztof Mazur
The pppoatm_send() does not take any lock that will prevent concurrent vcc_sendmsg(). This causes two problems: - there is no locking between checking the send queue size with atm_may_send() and incrementing sk_wmem_alloc, and the real queue size can be a little higher than sk_sndbuf - the vcc->sendmsg() can be called concurrently. I'm not sure if it's allowed. Some drivers (eni, nicstar, ...) seem to assume it will never happen. Now pppoatm_send() takes ATM socket lock, the same that is used in vcc_sendmsg() and other ATM socket functions. The pppoatm_send() is called with BH disabled, so bh_lock_sock() is used instead of lock_sock(). Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net> Cc: Chas Williams - CONTRACTOR <chas@cmf.nrl.navy.mil> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-11-28pppoatm: fix module_put() raceKrzysztof Mazur
The pppoatm used module_put() during unassignment from vcc with hope that we have BKL. This assumption is no longer true. Now owner field in atmvcc is used to move this module_put() to vcc_destroy_socket(). Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-11-28pppoatm: allow assign only on a connected socketKrzysztof Mazur
The pppoatm does not check if used vcc is in connected state, causing an Oops in pppoatm_send() when vcc->send() is called on not fully connected socket. Now pppoatm can be assigned only on connected sockets; otherwise -EINVAL error is returned. Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net> Cc: Chas Williams - CONTRACTOR <chas@cmf.nrl.navy.mil> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-11-28atm: add owner of push() callback to atmvccKrzysztof Mazur
The atm is using atmvcc->push(vcc, NULL) callback to notify protocol that vcc will be closed and protocol must detach from it. This callback is usually used by protocol to decrement module usage count by module_put(), but it leaves small window then module is still used after module_put(). Now the owner of push() callback is kept in atmvcc and module_put(atmvcc->owner) is called after the protocol is detached from vcc. Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Chas Williams <chas@cmf.nrl.navy.mil>
2012-11-26atm: br2684: Fix excessive queue bloatDavid Woodhouse
There's really no excuse for an additional wmem_default of buffering between the netdev queue and the ATM device. Two packets (one in-flight, and one ready to send) ought to be fine. It's not as if it should take long to get another from the netdev queue when we need it. If necessary we can make the queue space configurable later, but I don't think it's likely to be necessary. cf. commit 9d02daf754238adac48fa075ee79e7edd3d79ed3 (pppoatm: Fix excessive queue bloat) which did something very similar for PPPoATM. Note that there is a tremendously unlikely race condition which may result in qspace temporarily going negative. If a CPU running the br2684_pop() function goes off into the weeds for a long period of time after incrementing qspace to 1, but before calling netdev_wake_queue()... and another CPU ends up calling br2684_start_xmit() and *stopping* the queue again before the first CPU comes back, the netdev queue could end up being woken when qspace has already reached zero. An alternative approach to coping with this race would be to check in br2684_start_xmit() for qspace==0 and return NETDEV_TX_BUSY, but just using '> 0' and '< 1' for comparison instead of '== 0' and '!= 0' is simpler. It just warranted a mention of *why* we do it that way... Move the call to atmvcc->send() to happen *after* the accounting and potentially stopping the netdev queue, in br2684_xmit_vcc(). This matters if the ->send() call suffers an immediate failure, because it'll call br2684_pop() with the offending skb before returning. We want that to happen *after* we've done the initial accounting for the packet in question. Also make it return an appropriate success/failure indication while we're at it. Tested by running 'ping -l 1000 bottomless.aaisp.net.uk' from within my network, with only a single PPPoE-over-BR2684 link running. And after setting txqueuelen on the nas0 interface to something low (5, in fact). Before the patch, we'd see about 15 packets being queued and a resulting latency of ~56ms being reached. After the patch, we see only about 8, which is fairly much what we expect. And a max latency of ~36ms. On this OpenWRT box, wmem_default is 163840. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Reviewed-by: Krzysztof Mazur <krzysiek@podlesie.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31net:atm:fix up ENOIOCTLCMD error handlingWanlong Gao
At commit 07d106d0, Linus pointed out that ENOIOCTLCMD should be translated as ENOTTY to user mode. Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-15atm: fix info leak via getsockname()Mathias Krause
The ATM code fails to initialize the two padding bytes of struct sockaddr_atmpvc inserted for alignment. Add an explicit memset(0) before filling the structure to avoid the info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-15atm: fix info leak in getsockopt(SO_ATMPVC)Mathias Krause
2012-06-04net: Remove casts to same typeJoe Perches
Adding casts of objects to the same type is unnecessary and confusing for a human reader. For example, this cast: int y; int *p = (int *)&y; I used the coccinelle script below to find and remove these unnecessary casts. I manually removed the conversions this script produces of casts with __force and __user. @@ type T; T *p; @@ - (T *)p + p Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-04net: use consume_skb() in place of kfree_skb()Eric Dumazet
Remove some dropwatch/drop_monitor false positives. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-15atm: remove the coupling to token ring supportPaul Gortmaker
The token ring support is going away, so decouple the atm support from it in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-09atm: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13pppoatm: Fix excessive queue bloatDavid Woodhouse
We discovered that PPPoATM has an excessively deep transmit queue. A queue the size of the default socket send buffer (wmem_default) is maintained between the PPP generic core and the ATM device. Fix it to queue a maximum of *two* packets. The one the ATM device is currently working on, and one more for the ATM driver to process immediately in its TX done interrupt handler. The PPP core is designed to feed packets to the channel with minimal latency, so that really ought to be enough to keep the ATM device busy. While we're at it, fix the fact that we were triggering the wakeup tasklet on *every* pppoatm_pop() call. The comment saying "this is inefficient, but doing it right is too hard" turns out to be overly pessimistic... I think :) On machines like the Traverse Geos, with a slow Geode CPU and two high-speed ADSL2+ interfaces, there were reports of extremely high CPU usage which could partly be attributed to the extra wakeups. (The wakeup handling could actually be made a whole lot easier if we stop checking sk->sk_sndbuf altogether. Given that we now only queue *two* packets ever, one wonders what the point is. As it is, you could already deadlock the thing by setting the sk_sndbuf to a value lower than the MTU of the device, and it'd just block for ever.) Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-08Merge branch 'master' into for-nextJiri Kosina
Merge with latest Linus' tree, as I have incoming patches that fix code that is newer than current HEAD of for-next. Conflicts: drivers/net/ethernet/realtek/r8169.c
2012-04-05atm: fix commentsAlexandra Vintila
Signed-off-by: Alexandra Vintila <andavintila@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-04ppp: Replace uses of <linux/if_ppp.h> with <linux/ppp-ioctl.h>Paul Mackerras
Since all that include/linux/if_ppp.h does is #include <linux/ppp-ioctl.h>, this replaces the occurrences of #include <linux/if_ppp.h> with #include <linux/ppp-ioctl.h>. It also corrects an error in Documentation/networking/l2tp.txt, where it referenced include/linux/if_ppp.h as the source of some definitions that are actually now defined in include/linux/if_pppol2tp.h. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/sfc/rx.c Overlapping changes in drivers/net/ethernet/sfc/rx.c, one to change the rx_buf->is_page boolean into a set of u16 flags, and another to adjust how ->ip_summed is initialized. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-22atm: clip: remove clip_tblEric Dumazet
Commit 32092ecf0644 (atm: clip: Use device neigh support on top of "arp_tbl".) introduced a bug since clip_tbl is zeroed : Crash occurs in __neigh_for_each_release() idle_timer_check() must use instead arp_tbl and neigh_check_cb() should ignore non clip neighbours. Idea from David Miller. Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-01atm: clip: Convert over to dst_neigh_lookup().David S. Miller
CLIP only support ipv4, and this is evidenced by the fact that it is a device specific extension of arp_tbl, so this conversion is pretty straightforward. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-05net: Rename dst_get_neighbour{, _raw} to dst_get_neighbour_noref{, _raw}.David Miller
To reflect the fact that a refrence is not obtained to the resulting neighbour entry. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Roland Dreier <roland@purestorage.com>
2011-12-02atm: clip: Remove code commented out since eternity.David S. Miller
2011-11-30atm: clip: Use device neigh support on top of "arp_tbl".David Miller
Instead of instantiating an entire new neigh_table instance just for ATM handling, use the neigh device private facility. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-30atm: clip: Convert over to neighbour_priv()David Miller
