path: root/net/ax25/ax25_route.c
2012-06-04net: use consume_skb() in place of kfree_skb()Eric Dumazet
Remove some dropwatch/drop_monitor false positives. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-08-18net/ax25: Use available error codesJulia Lawall
Error codes are stored in err, but the return value is always 0. Return err instead. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ local idexpression x; constant C; @@ if (...) { ... x = -C ... when != x ( return <+...x...+>; | return NULL; | return; | * return ...; ) } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-11-14CRED: Wrap task credential accesses in the AX25 protocolDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-02-12[AX25] ax25_route: make ax25_route_lock BH safeJarek Poplawski
> ================================= > [ INFO: inconsistent lock state ] > 2.6.24-dg8ngn-p02 #1 > --------------------------------- > inconsistent {softirq-on-W} -> {in-softirq-R} usage. > linuxnet/3046 [HC0[0]:SC1[2]:HE1:SE0] takes: > (ax25_route_lock){--.+}, at: [<f8a0cfb7>] ax25_get_route+0x18/0xb7 [ax25] > {softirq-on-W} state was registered at: ... This lockdep report shows that ax25_route_lock is taken for reading in softirq context, and for writing in process context with BHs enabled. So, to make this safe, all write_locks in ax25_route.c are changed to _bh versions. Reported-by: Jann Traschewski <jann@gmx.de>, Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[AX25]: sparse cleanupsEric Dumazet
net/ax25/ax25_route.c:251:13: warning: context imbalance in 'ax25_rt_seq_start' - wrong count at exit net/ax25/ax25_route.c:276:13: warning: context imbalance in 'ax25_rt_seq_stop' - unexpected unlock net/ax25/ax25_std_timer.c:65:25: warning: expensive signed divide net/ax25/ax25_uid.c:46:1: warning: symbol 'ax25_uid_list' was not declared. Should it be static? net/ax25/ax25_uid.c:146:13: warning: context imbalance in 'ax25_uid_seq_start' - wrong count at exit net/ax25/ax25_uid.c:169:13: warning: context imbalance in 'ax25_uid_seq_stop' - unexpected unlock net/ax25/af_ax25.c:573:28: warning: expensive signed divide net/ax25/af_ax25.c:1865:13: warning: context imbalance in 'ax25_info_start' - wrong count at exit net/ax25/af_ax25.c:1888:13: warning: context imbalance in 'ax25_info_stop' - unexpected unlock net/ax25/ax25_ds_timer.c:133:25: warning: expensive signed divide Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] AX25: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-17[AX.25]: Mark all kmalloc users __must_checkRalf Baechle
The recent fix 0506d4068bad834aab1141b5dc5e748eb175c6b3 made obvious that error values were not being propagated through the AX.25 stack. To help with that this patch marks all kmalloc users in the AX.25, NETROM and ROSE stacks as __must_check. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[AX25]: Use kmemdupArnaldo Carvalho de Melo
Code diff stats: [acme@newtoy net-2.6.20]$ codiff /tmp/ax25.ko.before /tmp/ax25.ko.after /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ax25/ax25_out.c: ax25_send_frame | -8 1 function changed, 8 bytes removed /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ax25/ax25_route.c: ax25_rt_autobind | -15 1 function changed, 15 bytes removed /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ax25/af_ax25.c: ax25_make_new | -33 1 function changed, 33 bytes removed /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ax25/sysctl_net_ax25.c: ax25_register_sysctl | -21 1 function changed, 21 bytes removed /tmp/ax25.ko.after: 4 functions changed, 77 bytes removed [acme@newtoy net-2.6.20]$ Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-07-03[AX.25]: Reference counting for AX.25 routes.Ralf Baechle DL5RB
In the past routes could be freed even though the were possibly in use ... Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[AX.25]: Spelling fixRalf Baechle
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[NET]: kfree cleanupJesper Juhl
From: Jesper Juhl <jesper.juhl@gmail.com> This is the net/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in net/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-09-06[AX25]: Make ax2asc thread-proofRalf Baechle
Ax2asc was still using a static buffer for all invocations which isn't exactly SMP-safe. Change ax2asc to take an additional result buffer as the argument. Change all callers to provide such a buffer. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-23[AX25]: UID fixesRalf Baechle
o Brown paperbag bug - ax25_findbyuid() was always returning a NULL pointer as the result. Breaks ROSE completly and AX.25 if UID policy set to deny. o While the list structure of AX.25's UID to callsign mapping table was properly protected by a spinlock, it's elements were not refcounted resulting in a race between removal and usage of an element. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
