path: root/net/ax25/ax25_subr.c
2017-02-04ax25: Fix segfault after sock connection timeoutBasil Gunn
[ Upstream commit 8a367e74c0120ef68c8c70d5a025648c96626dff ] The ax.25 socket connection timed out & the sock struct has been previously taken down ie. sock struct is now a NULL pointer. Checking the sock_flag causes the segfault. Check if the socket struct pointer is NULL before checking sock_flag. This segfault is seen in timed out netrom connections. Please submit to -stable. Signed-off-by: Basil Gunn <basil@pacabunga.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-18AX.25: Close socket connection on session completionBasil Gunn
A socket connection made in ax.25 is not closed when session is completed. The heartbeat timer is stopped prematurely and this is where the socket gets closed. Allow heatbeat timer to run to close socket. Symptom occurs in kernels >= 4.2.0 Originally sent 6/15/2016. Resend with distribution list matching scripts/maintainer.pl output. Signed-off-by: Basil Gunn <basil@pacabunga.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-15NET: AX.25: Stop heartbeat timer on disconnect.Richard Stearn
This may result in a kernel panic. The bug has always existed but somehow we've run out of luck now and it bites. Signed-off-by: Richard Stearn <richard@rns-stearn.demon.co.uk> Cc: stable@vger.kernel.org # all branches Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-06-03ax25: Fix NULL pointer dereference and lockup.Jarek Poplawski
From: Jarek Poplawski <jarkao2@gmail.com> There is only one function in AX25 calling skb_append(), and it really looks suspicious: appends skb after previously enqueued one, but in the meantime this previous skb could be removed from the queue. This patch Fixes it the simple way, so this is not fully compatible with the current method, but testing hasn't shown any problems. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-16[AX25]: Locking dependencies fix in ax25_disconnect().Jarek Poplawski
Bernard Pidoux reported these lockdep warnings: [ INFO: possible irq lock inversion dependency detected ] 2.6.23.1 #1 --------------------------------------------------------- fpac/4933 just changed the state of lock: (slock-AF_AX25){--..}, at: [<d8be3312>] ax25_disconnect+0x46/0xaf [ax25] but this lock was taken by another, soft-irq-safe lock in the past: (ax25_list_lock){-+..} and interrupts could create inverse lock ordering between them. [...] [ INFO: inconsistent lock state ] 2.6.23.1 #1 --------------------------------- inconsistent {in-softirq-W} -> {softirq-on-W} usage. ax25_call/4005 [HC0[0]:SC0[0]:HE1:SE1] takes: (slock-AF_AX25){-+..}, at: [<d8b79312>] ax25_disconnect+0x46/0xaf [ax25] [...] This means slock-AF_AX25 could be taken both from softirq and process context with softirqs enabled, so it's endangered itself, but also makes ax25_list_lock vulnerable. It was not 100% verified if the real lockup can happen, but this fix isn't very costly and looks safe anyway. (It was tested by Bernard with 2.6.23.9 and 2.6.24-rc5 kernels.) Reported_by: Bernard Pidoux <pidoux@ccr.jussieu.fr> Tested_by: Bernard Pidoux <pidoux@ccr.jussieu.fr> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] AX25: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-04-21[AX25]: make ax25_queue_xmit a net_device parameterArnaldo Carvalho de Melo
I.e. not using skb->dev as a way to pass the parameter used to fill... skb->dev :-) Also to get the _type_trans open coded sequence grouped, next changesets will introduce ax25_type_trans. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
