After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Lots of places just needs the states, not even linux/tcp.h, where this
enum was, needs it.
This speeds up development of the refactorings as less sources are
rebuilt when things get moved from net/tcp.h.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Remove the "list" member of struct sk_buff, as it is entirely
redundant. All SKB list removal callers know which list the
SKB is on, so storing this in sk_buff does nothing other than
taking up some space.
Two tricky bits were SCTP, which I took care of, and two ATM
drivers which Francois Romieu <romieu@fr.zoreil.com> fixed
up.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
I.e. not using skb->dev as a way to pass the parameter used to fill...
skb->dev :-)
Also to get the _type_trans open coded sequence grouped, next changesets
will introduce ax25_type_trans.
infrastructure for it.
Let it rip!
