[ Upstream commit ea47781c26510e5d97f80f9aceafe9065bd5e3aa ]
As variable length protocol, AX25 fails link layer header validation
tests based on a minimum length. header_ops.validate allows protocols
to validate headers that are shorter than hard_header_len. Implement
this callback for AX25.
See also http://comments.gmane.org/gmane.linux.network/401064
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 79462ad02e861803b3840cc782248c7359451cd9 ]
郭永刚 reported that one could simply crash the kernel as root by
using a simple program:
int socket_fd;
struct sockaddr_in addr;
addr.sin_port = 0;
addr.sin_addr.s_addr = INADDR_ANY;
addr.sin_family = 10;
socket_fd = socket(10,3,0x40000000);
connect(socket_fd , &addr,16);
AF_INET, AF_INET6 sockets actually only support 8-bit protocol
identifiers. inet_sock's skc_protocol field thus is sized accordingly,
thus larger protocol identifiers simply cut off the higher bits and
store a zero in the protocol fields.
This could lead to e.g. NULL function pointer because as a result of
the cut off inet_num is zero and we call down to inet_autobind, which
is NULL for raw sockets.
kernel: Call Trace:
kernel: [<ffffffff816db90e>] ? inet_autobind+0x2e/0x70
kernel: [<ffffffff816db9a4>] inet_dgram_connect+0x54/0x80
kernel: [<ffffffff81645069>] SYSC_connect+0xd9/0x110
kernel: [<ffffffff810ac51b>] ? ptrace_notify+0x5b/0x80
kernel: [<ffffffff810236d8>] ? syscall_trace_enter_phase2+0x108/0x200
kernel: [<ffffffff81645e0e>] SyS_connect+0xe/0x10
kernel: [<ffffffff81779515>] tracesys_phase2+0x84/0x89
I found no particular commit which introduced this problem.
CVE: CVE-2015-8543
Cc: Cong Wang <cwang@twopensource.com>
Reported-by: 郭永刚 <guoyonggang@360.cn>
> >> net/ax25/ax25_ip.c:225:26: error: unknown type name 'sturct'
> netdev_tx_t ax25_ip_xmit(sturct sk_buff *skb)
> vim +/sturct +225 net/ax25/ax25_ip.c
> 219 unsigned short type, const void *daddr,
> 220 const void *saddr, unsigned int len)
> 221 {
> 222 return -AX25_HEADER_LEN;
> 223 }
> 224
> > 225 netdev_tx_t ax25_ip_xmit(sturct sk_buff *skb)
> 226 {
> 227 kfree_skb(skb);
> 228 return NETDEV_TX_OK;
Ooops I misspelled struct...
Before the ax25 stack calls dev_queue_xmit it always calls
ax25_type_trans which sets skb->protocol to ETH_P_AX25.
Which means that by looking at the protocol type it is possible to
detect IP packets that have not been munged by the ax25 stack in
ndo_start_xmit and call a function to munge them.
Rename ax25_neigh_xmit to ax25_ip_xmit and tweak the return type and
value to be appropriate for an ndo_start_xmit function.
Update all of the ax25 devices to test the protocol type for ETH_P_IP
and return ax25_ip_xmit as the first thing they do. This preserves
the existing semantics of IP packet processing, but the timing will be
a little different as the IP packets now pass through the qdisc layer
before reaching the ax25 ip packet processing.
Remove the now unnecessary ax25 neighbour table operations.
Have ax25_neigh_output perform ordinary arp resolution before calling
ax25_neigh_xmit.
Call dev_hard_header in ax25_neigh_output with a destination address so
it will not fail, and the destination mac address will not need to be
set in ax25_neigh_xmit.
Remove arp_find from ax25_neigh_xmit (the ordinary arp resolution added
to ax25_neigh_output removes the need for calling arp_find).
Document how close ax25_neigh_output is to neigh_resolve_output.
Cc: linux-hams@vger.kernel.org
- Rename ax25_rebuild_header to ax25_neigh_xmit and call it from
ax25_neigh_output directly. The rename is to make it clear
that this is not a rebuild_header operation.
- Remove ax25_rebuild_header from ax25_header_ops.
The only caller is now is ax25_neigh_construct so move
neigh_compat_output into ax25_ip.c make it static and rename it
ax25_neigh_output.
AX25 already has it's own private arp cache operations to isolate
it's abuse of dev_rebuild_header to transmit packets. Add a function
ax25_neigh_construct that will allow all of the ax25 devices to
force using these operations, so that the generic arp code does
not need to.
The only user is in ax25_ip.c so stop exporting these functions.
In the unlikely (impossible?) event that we attempt to transmit
an ax25 packet over a non-ax25 device free the skb so we don't
leak it.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
The current test works fine in practice. The "amount" variable is
actually used as a boolean so negative values or any non-zero values
count as "true". However since we don't allow numbers greater than one,
let's not allow negative numbers either.
Reduce the uses of this unnecessary typedef.
Done via perl script:
$ git grep --name-only -w ctl_table net | \
xargs perl -p -i -e '\
sub trim { my ($local) = @_; $local =~ s/(^\s+|\s+$)//g; return $local; } \
s/\b(?<!struct\s)ctl_table\b(\s*\*\s*|\s+\w+)/"struct ctl_table " . trim($1)/ge'
Reflow the modified lines that now exceed 80 columns.
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
When msg_namelen is non-zero the sockaddr info gets filled out, as
requested, but the code fails to initialize the padding bytes of struct
sockaddr_ax25 inserted by the compiler for alignment. Additionally the
msg_namelen value is updated to sizeof(struct full_sockaddr_ax25) but is
not always filled up to this size.
Both issues lead to the fact that the code will leak uninitialized
kernel stack bytes in net/socket.c.
Fix both issues by initializing the memory with memset(0).
Signed-off-by: Mathias Krause <minipli@googlemail.com>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Right now, some modules such as bonding use proc_create
to create proc entries under /proc/net/, and other modules
such as ipv4 use proc_net_fops_create.
It looks a little chaos.this patch changes all of
proc_net_fops_create to proc_create. we can remove
proc_net_fops_create after this patch.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
drivers/net/ethernet/intel/ixgbevf/ixgbevf_main.c
At least there seems to be no reason to disallow ROSE sockets when
NETROM is loaded.
Signed-off-by: Alan Cox <alan@linux.intel.com>
The comments were wrong here because "AX25_MAX_DIGIS" is 8 but the
comments say 6. Also I've changed the "7" to "AX25_ADDR_LEN".
Remove some dropwatch/drop_monitor false positives.
Fix merge between commit 3adadc08cc1e ("net ax25: Reorder ax25_exit to
remove races") and commit 0ca7a4c87d27 ("net ax25: Simplify and
cleanup the ax25 sysctl handling")
The former moved around the sysctl register/unregister calls, the
later simply removed them.
With help from Stephen Rothwell.
Don't register/unregister every ax25 table in a batch. Instead register
and unregister per device ax25 sysctls as ax25 devices come and go.
This moves ax25 to be a completely modern sysctl user. Registering the
sysctls in just the initial network namespace, removing the use of
.child entries that are no longer natively supported by the sysctl core
and taking advantage of the fact that there are no longer any ordering
constraints between registering and unregistering different sysctl
tables.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
This makes it clearer which sysctls are relative to your current network
namespace.
This makes it a little less error prone by not exposing sysctls for the
initial network namespace in other namespaces.
This is the same way we handle all of our other network interfaces to
userspace and I can't honestly remember why we didn't do this for
sysctls right from the start.
While reviewing the sysctl code in ax25 I spotted races in ax25_exit
where it is possible to receive notifications and packets after already
freeing up some of the data structures needed to process those
notifications and updates.
Call unregister_netdevice_notifier early so that the rest of the cleanup
code does not need to deal with network devices. This takes advantage
of my recent enhancement to unregister_netdevice_notifier to send
unregister notifications of all network devices that are current
registered.
Move the unregistration for packet types, socket types and protocol
types before we cleanup any of the ax25 data structures to remove the
possibilities of other races.
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Commit be639ac6 ("NET: AX.25: Check ioctl arguments to avoid overflows
further down the road") rejects very large arguments, but doesn't
completely fix overflows on 64-bit systems. Consider the AX25_T2 case.
int opt;
if (opt < 1 || opt > ULONG_MAX / HZ) {
res = -EINVAL;
break;
ax25->t2 = opt * HZ;
The 32-bit multiplication opt * HZ would overflow before being assigned
to 64-bit ax25->t2. This patch changes "opt" to unsigned long.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Very large, nonsenical arguments or use in very extreme conditions could
result in integer overflows. Check ioctls arguments to avoid such
overflows and return -EINVAL for too large arguments.
To allow the use of AX.25 for even the most extreme setup (think packet
radio to the Phase 5E mars probe) we make no further attempt to clamp the
argument range.
Originally reported by Fan Long <longfancn@gmail.com> and a first patch
was sent by Xi Wang <xi.wang@gmail.com>.
Cc: Xi Wang <xi.wang@gmail.com>
Cc: Joerg Reuter <jreuter@yaina.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Thomas Osterried <thomas@osterried.de>
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
The variable 's' is set but unused in ax25_protocol_release().
Just kill it off.
Nobody alive seems to recall when they last were useful.
Commit fe10ae53384e48c51996941b7720ee16995cbcb7 adds a memset() to clear
the structure being sent back to userspace, but accidentally used the
wrong size.
Reported-by: Brad Spengler <spender@grsecurity.net>
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Cc: stable@kernel.org
Sometimes ax25_getname() doesn't initialize all members of fsa_digipeater
field of fsa struct, also the struct has padding bytes between
sax25_call and sax25_ndigis fields. This structure is then copied to
userland. It leads to leaking of contents of kernel stack memory.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
net/mac80211/main.c
This patch moves a missplaced sock_put(sk) after
bh_unlock_sock(sk)
like in other parts of AX25 driver.
Signed-off-by: Bernard Pidoux <f6bvp@free.fr>
Error codes are stored in err, but the return value is always 0. Return
err instead.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
local idexpression x;
constant C;
if (...) { ...
x = -C
... when != x
return <+...x...+>;
return NULL;
return;
* return ...;
// </smpl>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
err instead.
// <smpl>
@r@
constant C;
if (...) { ...
x = -C
... when != x
return <+...x...+>;
return NULL;
return;
* return ...;
// </smpl>
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Simplify seq_file code.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
