path: root/net/ax25
2017-02-04ax25: Fix segfault after sock connection timeoutBasil Gunn
[ Upstream commit 8a367e74c0120ef68c8c70d5a025648c96626dff ] The ax.25 socket connection timed out & the sock struct has been previously taken down ie. sock struct is now a NULL pointer. Checking the sock_flag causes the segfault. Check if the socket struct pointer is NULL before checking sock_flag. This segfault is seen in timed out netrom connections. Please submit to -stable. Signed-off-by: Basil Gunn <basil@pacabunga.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-11AX.25: Close socket connection on session completionBasil Gunn
[ Upstream commit 4a7d99ea1b27734558feb6833f180cd38a159940 ] A socket connection made in ax.25 is not closed when session is completed. The heartbeat timer is stopped prematurely and this is where the socket gets closed. Allow heatbeat timer to run to close socket. Symptom occurs in kernels >= 4.2.0 Originally sent 6/15/2016. Resend with distribution list matching scripts/maintainer.pl output. Signed-off-by: Basil Gunn <basil@pacabunga.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20ax25: add link layer header validation functionWillem de Bruijn
[ Upstream commit ea47781c26510e5d97f80f9aceafe9065bd5e3aa ] As variable length protocol, AX25 fails link layer header validation tests based on a minimum length. header_ops.validate allows protocols to validate headers that are shorter than hard_header_len. Implement this callback for AX25. See also http://comments.gmane.org/gmane.linux.network/401064 Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-12-14net: add validation for the socket syscall protocol argumentHannes Frederic Sowa
郭永刚 reported that one could simply crash the kernel as root by using a simple program: int socket_fd; struct sockaddr_in addr; addr.sin_port = 0; addr.sin_addr.s_addr = INADDR_ANY; addr.sin_family = 10; socket_fd = socket(10,3,0x40000000); connect(socket_fd , &addr,16); AF_INET, AF_INET6 sockets actually only support 8-bit protocol identifiers. inet_sock's skc_protocol field thus is sized accordingly, thus larger protocol identifiers simply cut off the higher bits and store a zero in the protocol fields. This could lead to e.g. NULL function pointer because as a result of the cut off inet_num is zero and we call down to inet_autobind, which is NULL for raw sockets. kernel: Call Trace: kernel: [<ffffffff816db90e>] ? inet_autobind+0x2e/0x70 kernel: [<ffffffff816db9a4>] inet_dgram_connect+0x54/0x80 kernel: [<ffffffff81645069>] SYSC_connect+0xd9/0x110 kernel: [<ffffffff810ac51b>] ? ptrace_notify+0x5b/0x80 kernel: [<ffffffff810236d8>] ? syscall_trace_enter_phase2+0x108/0x200 kernel: [<ffffffff81645e0e>] SyS_connect+0xe/0x10 kernel: [<ffffffff81779515>] tracesys_phase2+0x84/0x89 I found no particular commit which introduced this problem. CVE: CVE-2015-8543 Cc: Cong Wang <cwang@twopensource.com> Reported-by: 郭永刚 <guoyonggang@360.cn> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-15NET: AX.25: Stop heartbeat timer on disconnect.Richard Stearn
This may result in a kernel panic. The bug has always existed but somehow we've run out of luck now and it bites. Signed-off-by: Richard Stearn <richard@rns-stearn.demon.co.uk> Cc: stable@vger.kernel.org # all branches Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-28ax25: Stop using sock->sk_protinfo.David Miller
Just make a ax25_sock structure that provides the ax25_cb pointer. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-18netfilter: Remove spurios included of netfilter.hEric W Biederman
While testing my netfilter changes I noticed several files where recompiling unncessarily because they unncessarily included netfilter.h. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-05-11net: Pass kern from net_proto_family.create to sk_allocEric W. Biederman
In preparation for changing how struct net is refcounted on kernel sockets pass the knowledge that we are creating a kernel socket from sock_create_kern through to sk_alloc. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-05ax25: Fix the build when CONFIG_INET is disabledkbuild test robot
> > >> net/ax25/ax25_ip.c:225:26: error: unknown type name 'sturct' > netdev_tx_t ax25_ip_xmit(sturct sk_buff *skb) > ^ > > vim +/sturct +225 net/ax25/ax25_ip.c > > 219 unsigned short type, const void *daddr, > 220 const void *saddr, unsigned int len) > 221 { > 222 return -AX25_HEADER_LEN; > 223 } > 224 > > 225 netdev_tx_t ax25_ip_xmit(sturct sk_buff *skb) > 226 { > 227 kfree_skb(skb); > 228 return NETDEV_TX_OK; Ooops I misspelled struct... Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-03ax25: Stop using magic neighbour cache operations.Eric W. Biederman
Before the ax25 stack calls dev_queue_xmit it always calls ax25_type_trans which sets skb->protocol to ETH_P_AX25. Which means that by looking at the protocol type it is possible to detect IP packets that have not been munged by the ax25 stack in ndo_start_xmit and call a function to munge them. Rename ax25_neigh_xmit to ax25_ip_xmit and tweak the return type and value to be appropriate for an ndo_start_xmit function. Update all of the ax25 devices to test the protocol type for ETH_P_IP and return ax25_ip_xmit as the first thing they do. This preserves the existing semantics of IP packet processing, but the timing will be a little different as the IP packets now pass through the qdisc layer before reaching the ax25 ip packet processing. Remove the now unnecessary ax25 neighbour table operations. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02ax25: Stop depending on arp_findEric W. Biederman
Have ax25_neigh_output perform ordinary arp resolution before calling ax25_neigh_xmit. Call dev_hard_header in ax25_neigh_output with a destination address so it will not fail, and the destination mac address will not need to be set in ax25_neigh_xmit. Remove arp_find from ax25_neigh_xmit (the ordinary arp resolution added to ax25_neigh_output removes the need for calling arp_find). Document how close ax25_neigh_output is to neigh_resolve_output. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02ax25: Stop calling/abusing dev_rebuild_headerEric W. Biederman
- Rename ax25_rebuild_header to ax25_neigh_xmit and call it from ax25_neigh_output directly. The rename is to make it clear that this is not a rebuild_header operation. - Remove ax25_rebuild_header from ax25_header_ops. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02neigh: Move neigh_compat_output into ax25_ip.cEric W. Biederman
The only caller is now is ax25_neigh_construct so move neigh_compat_output into ax25_ip.c make it static and rename it ax25_neigh_output. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02ax25: Refactor to use private neighbour operations.Eric W. Biederman
AX25 already has it's own private arp cache operations to isolate it's abuse of dev_rebuild_header to transmit packets. Add a function ax25_neigh_construct that will allow all of the ax25 devices to force using these operations, so that the generic arp code does not need to. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02ax25: Make ax25_header and ax25_rebuild_header staticEric W. Biederman
The only user is in ax25_ip.c so stop exporting these functions. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02ax25: In ax25_rebuild_header add missing kfree_skbEric W. Biederman
In the unlikely (impossible?) event that we attempt to transmit an ax25 packet over a non-ax25 device free the skb so we don't leak it. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: Remove iocb argument from sendmsg and recvmsgYing Xue
After TIPC doesn't depend on iocb argument in its internal implementations of sendmsg() and recvmsg() hooks defined in proto structure, no any user is using iocb argument in them at all now. Then we can drop the redundant iocb argument completely from kinds of implementations of both sendmsg() and recvmsg() in the entire networking stack. Cc: Christoph Hellwig <hch@lst.de> Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-24new helper: memcpy_from_msg()Al Viro
2014-11-05net: Add and use skb_copy_datagram_msg() helper.David S. Miller
This encapsulates all of the skb_copy_datagram_iovec() callers with call argument signature "skb, offset, msghdr->msg_iov, length". When we move to iov_iters in the networking, the iov_iter object will sit in the msghdr. Having a helper like this means there will be less places to touch during that transformation. Based upon descriptions and patch from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-11net: Fix use after free by removing length arg from sk_data_ready callbacks.David S. Miller
Several spots in the kernel perform a sequence like: skb_queue_tail(&sk->s_receive_queue, skb); sk->sk_data_ready(sk, skb->len); But at the moment we place the SKB onto the socket receive queue it can be consumed and freed up. So this skb->len access is potentially to freed up memory. Furthermore, the skb->len can be modified by the consumer so it is possible that the value isn't accurate. And finally, no actual implementation of this callback actually uses the length argument. And since nobody actually cared about it's value, lots of call sites pass arbitrary values in such as '0' and even '1'. So just remove the length argument from the callback, that way there is no confusion whatsoever and all of these use-after-free cases get fixed as a side effect. Based upon a patch by Eric Dumazet and his suggestion to audit this issue tree-wide. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-18ax25: cleanup a range testDan Carpenter
The current test works fine in practice. The "amount" variable is actually used as a boolean so negative values or any non-zero values count as "true". However since we don't allow numbers greater than one, let's not allow negative numbers either. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13net: Convert uses of typedef ctl_table to struct ctl_tableJoe Perches
Reduce the uses of this unnecessary typedef. Done via perl script: $ git grep --name-only -w ctl_table net | \ xargs perl -p -i -e '\ sub trim { my ($local) = @_; $local =~ s/(^\s+|\s+$)//g; return $local; } \ s/\b(?<!struct\s)ctl_table\b(\s*\*\s*|\s+\w+)/"struct ctl_table " . trim($1)/ge' Reflow the modified lines that now exceed 80 columns. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07ax25: fix info leak via msg_name in ax25_recvmsg()Mathias Krause
When msg_namelen is non-zero the sockaddr info gets filled out, as requested, but the code fails to initialize the padding bytes of struct sockaddr_ax25 inserted by the compiler for alignment. Additionally the msg_namelen value is updated to sizeof(struct full_sockaddr_ax25) but is not always filled up to this size. Both issues lead to the fact that the code will leak uninitialized kernel stack bytes in net/socket.c. Fix both issues by initializing the memory with memset(0). Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_fops_create to proc_createGao feng
Right now, some modules such as bonding use proc_create to create proc entries under /proc/net/, and other modules such as ipv4 use proc_net_fops_create. It looks a little chaos.this patch changes all of proc_net_fops_create to proc_create. we can remove proc_net_fops_create after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14userns: Convert net/ax25 to use kuid_t where appropriateEric W. Biederman
Cc: Ralf Baechle <ralf@linux-mips.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/ixgbevf/ixgbevf_main.c
2012-07-16ax25: Fix missing breakAlan Cox
At least there seems to be no reason to disallow ROSE sockets when NETROM is loaded. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-09small cleanup in ax25_addr_parse()Dan Carpenter
The comments were wrong here because "AX25_MAX_DIGIS" is 8 but the comments say 6. Also I've changed the "7" to "AX25_ADDR_LEN". Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-04net: use consume_skb() in place of kfree_skb()Eric Dumazet
Remove some dropwatch/drop_monitor false positives. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Fix merge between commit 3adadc08cc1e ("net ax25: Reorder ax25_exit to remove races") and commit 0ca7a4c87d27 ("net ax25: Simplify and cleanup the ax25 sysctl handling") The former moved around the sysctl register/unregister calls, the later simply removed them. With help from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net ax25: Simplify and cleanup the ax25 sysctl handling.Eric W. Biederman
Don't register/unregister every ax25 table in a batch. Instead register and unregister per device ax25 sysctls as ax25 devices come and go. This moves ax25 to be a completely modern sysctl user. Registering the sysctls in just the initial network namespace, removing the use of .child entries that are no longer natively supported by the sysctl core and taking advantage of the fact that there are no longer any ordering constraints between registering and unregistering different sysctl tables. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-19net ax25: Reorder ax25_exit to remove races.Eric W. Biederman
While reviewing the sysctl code in ax25 I spotted races in ax25_exit where it is possible to receive notifications and packets after already freeing up some of the data structures needed to process those notifications and updates. Call unregister_netdevice_notifier early so that the rest of the cleanup code does not need to deal with network devices. This takes advantage of my recent enhancement to unregister_netdevice_notifier to send unregister notifications of all network devices that are current registered. Move the unregistration for packet types, socket types and protocol types before we cleanup any of the ax25 data structures to remove the possibilities of other races. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2011-12-28ax25: avoid overflows in ax25_setsockopt()Xi Wang
Commit be639ac6 ("NET: AX.25: Check ioctl arguments to avoid overflows further down the road") rejects very large arguments, but doesn't completely fix overflows on 64-bit systems. Consider the AX25_T2 case. int opt; ... if (opt < 1 || opt > ULONG_MAX / HZ) { res = -EINVAL; break; } ax25->t2 = opt * HZ; The 32-bit multiplication opt * HZ would overflow before being assigned to 64-bit ax25->t2. This patch changes "opt" to unsigned long. Signed-off-by: Xi Wang <xi.wang@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-29NET: AX.25: Check ioctl arguments to avoid overflows further down the road.Ralf Baechle
Very large, nonsenical arguments or use in very extreme conditions could result in integer overflows. Check ioctls arguments to avoid such overflows and return -EINVAL for too large arguments. To allow the use of AX.25 for even the most extreme setup (think packet radio to the Phase 5E mars probe) we make no further attempt to clamp the argument range. Originally reported by Fan Long <longfancn@gmail.com> and a first patch was sent by Xi Wang <xi.wang@gmail.com>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Xi Wang <xi.wang@gmail.com> Cc: Joerg Reuter <jreuter@yaina.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Thomas Osterried <thomas@osterried.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17ax25: Fix set-but-unused variable.David S. Miller
The variable 's' is set but unused in ax25_protocol_release(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14NET: AX.25, NETROM, ROSE: Remove SOCK_DEBUG callsRalf Baechle
Nobody alive seems to recall when they last were useful. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-12net: ax25: fix information leak to userland harderKees Cook
Commit fe10ae53384e48c51996941b7720ee16995cbcb7 adds a memset() to clear the structure being sent back to userspace, but accidentally used the wrong size. Reported-by: Brad Spengler <spender@grsecurity.net> Signed-off-by: Kees Cook <kees.cook@canonical.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-10net: ax25: fix information leak to userlandVasiliy Kulikov
Sometimes ax25_getname() doesn't initialize all members of fsa_digipeater field of fsa struct, also the struct has padding bytes between sax25_call and sax25_ndigis fields. This structure is then copied to userland. It leads to leaking of contents of kernel stack memory. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
