path: root/net/batman-adv/bat_v_ogm.h
2018-07-07batman-adv: Unify include guards styleSven Eckelmann
All other include guards in batman-adv use the style: * _NET_BATMAN_ADV_$(FILENAME)_ * uppercase only * "." & "-" replaced with "_" Use this also in the B.A.T.M.A.N. IV/V OGM implementation headers. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2018-02-26batman-adv: Update copyright years for 2018Sven Eckelmann
2017-12-15batman-adv: Add SPDX license identifier above copyright headerSven Eckelmann
The "Linux kernel licensing rules" require that each file has a SPDX license identifier as first line (and sometimes as second line). The FSFE REUSE practices [1] would also require the same tags but have no restrictions on the placement in the source file. Using the "Linux kernel licensing rules" is therefore also fulfilling the FSFE REUSE practices requirements at the same time. [1] https://reuse.software/practices/ Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2017-01-26batman-adv: update copyright years for 2017Sven Eckelmann
2016-06-30batman-adv: Include main.h in bat_v_ogm.hSven Eckelmann
main.h includes statements which (re)define preprocessor variables which influence the compiled code. This makes it necessary to include it in all files. For example, it redefines pr_fmt used to the module as prefix for each pr_* message. Reported-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-02-29batman-adv: OGMv2 - implement originators logicAntonio Quartulli
Add the support for recognising new originators in the network and rebroadcast their OGMs. Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2016-02-29batman-adv: OGMv2 - add basic infrastructureAntonio Quartulli
This is the initial implementation of the new OGM protocol (version 2). It has been designed to work on top of the newly added ELP. In the previous version the OGM protocol was used to both measure link qualities and flood the network with the metric information. In this version the protocol is in charge of the latter task only, leaving the former to ELP. This means being able to decouple the interval used by the neighbor discovery from the OGM broadcasting, which revealed to be costly in dense networks and needed to be relaxed so leading to a less responsive routing protocol. Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
