path: root/net/batman-adv/send.c
2017-07-29batman-adv: fix various spelling mistakesColin Ian King
Trivial fix to spelling mistakes in batadv_dbg debug messages and also in a comment and ensure comment line is not wider than 80 characters "ourselve" -> "ourselves" "surpressed" -> "suppressed" "troughput" -> "throughput" Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2017-05-23batman-adv: Print correct function names in dbg messagesSven Eckelmann
The function names in batman-adv changed slightly in the past. But some of the debug messages were not updated correctly and therefore some messages were incorrect. To avoid this in the future, these kind of messages should use __func__ to automatically print the correct function name. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2017-03-26batman-adv: restructure rebroadcast counter into forw_packet APILinus Lüssing
This patch refactors the num_packets counter of a forw_packet in the following three ways: 1) Removed dual-use of forw_packet::num_packets: -> now for aggregation purposes only 2) Using forw_packet::skb::cb::num_bcasts instead: -> for easier access in aggregation code later 3) make access to num_bcasts private to batadv_forw_packet_*() Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> [sven@narfation.org: Change num_bcasts to unsigned] Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2017-03-26batman-adv: privatize forw_packet skb assignmentLinus Lüssing
An skb is assigned to a forw_packet only once, shortly after the forw_packet allocation. With this patch the assignment is moved into the this allocation function. Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2017-01-28batman-adv: Fix double call of dev_queue_xmitSven Eckelmann
The net_xmit_eval has side effects because it is not making sure that e isn't evaluated twice. #define net_xmit_eval(e) ((e) == NET_XMIT_CN ? 0 : (e)) The code requested by David Miller [1] return net_xmit_eval(dev_queue_xmit(skb)); will get transformed into return ((dev_queue_xmit(skb)) == NET_XMIT_CN ? 0 : (dev_queue_xmit(skb))) dev_queue_xmit will therefore be tried again (with an already consumed skb) whenever the return code is not NET_XMIT_CN. [1] https://lkml.kernel.org/r/20170125.225624.965229145391320056.davem@davemloft.net Fixes: c33705188c49 ("batman-adv: Treat NET_XMIT_CN as transmit successfully") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2017-01-26batman-adv: Treat NET_XMIT_CN as transmit successfullyGao Feng
The tc could return NET_XMIT_CN as one congestion notification, but it does not mean the packet is lost. Other modules like ipvlan, macvlan, and others treat NET_XMIT_CN as success too. So batman-adv should handle NET_XMIT_CN also as NET_XMIT_SUCCESS. Signed-off-by: Gao Feng <gfree.wind@gmail.com> [sven@narfation.org: Moved NET_XMIT_CN handling to batadv_send_skb_packet] Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2017-01-26batman-adv: update copyright years for 2017Sven Eckelmann
2016-11-08batman-adv: fix rare race conditions on interface removalLinus Lüssing
In rare cases during shutdown the following general protection fault can happen: general protection fault: 0000 [#1] SMP Modules linked in: batman_adv(O-) [...] CPU: 3 PID: 1714 Comm: rmmod Tainted: G O 4.6.0-rc6+ #1 [...] Call Trace: [<ffffffffa0363294>] batadv_hardif_disable_interface+0x29a/0x3a6 [batman_adv] [<ffffffffa0373db4>] batadv_softif_destroy_netlink+0x4b/0xa4 [batman_adv] [<ffffffff813b52f3>] __rtnl_link_unregister+0x48/0x92 [<ffffffff813b9240>] rtnl_link_unregister+0xc1/0xdb [<ffffffff8108547c>] ? bit_waitqueue+0x87/0x87 [<ffffffffa03850d2>] batadv_exit+0x1a/0xf48 [batman_adv] [<ffffffff810c26f9>] SyS_delete_module+0x136/0x1b0 [<ffffffff8144dc65>] entry_SYSCALL_64_fastpath+0x18/0xa8 [<ffffffff8108aaca>] ? trace_hardirqs_off_caller+0x37/0xa6 Code: 89 f7 e8 21 bd 0d e1 4d 85 e4 75 0e 31 f6 48 c7 c7 50 d7 3b a0 e8 50 16 f2 e0 49 8b 9c 24 28 01 00 00 48 85 db 0f 84 b2 00 00 00 <48> 8b 03 4d 85 ed 48 89 45 c8 74 09 4c 39 ab f8 00 00 00 75 1c RIP [<ffffffffa0371852>] batadv_purge_outstanding_packets+0x1c8/0x291 [batman_adv] RSP <ffff88001da5fd78> ---[ end trace 803b9bdc6a4a952b ]--- Kernel panic - not syncing: Fatal exception in interrupt Kernel Offset: disabled ---[ end Kernel panic - not syncing: Fatal exception in interrupt It does not happen often, but may potentially happen when frequently shutting down and reinitializing an interface. With some carefully placed msleep()s/mdelay()s it can be reproduced easily. The issue is, that on interface removal, any still running worker thread of a forwarding packet will race with the interface purging routine to free a forwarding packet. Temporarily giving up a spin-lock to be able to sleep in the purging routine is not safe. Furthermore, there is a potential general protection fault not just for the purging side shown above, but also on the worker side: Temporarily removing a forw_packet from the according forw_{bcast,bat}_list will make it impossible for the purging routine to catch and cancel it. # How this patch tries to fix it: With this patch we split the queue purging into three steps: Step 1), removing forward packets from the queue of an interface and by that claim it as our responsibility to free. Step 2), we are either lucky to cancel a pending worker before it starts to run. Or if it is already running, we wait and let it do its thing, except two things: Through the claiming in step 1) we prevent workers from a) re-arming themselves. And b) prevent workers from freeing packets which we still hold in the interface purging routine. Finally, step 3, we are sure that no forwarding packets are pending or even running anymore on the interface to remove. We can then safely free the claimed forwarding packets. Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-11-08batman-adv: Remove dev_queue_xmit return code exceptionSven Eckelmann
No caller of batadv_send_skb_to_orig is expecting the results to be -1 (-EPERM) anymore when the skbuff was not consumed. They will instead expect that the skbuff is always consumed. Having such return code filter is therefore not needed anymore. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-10-30batman-adv: Consume skb in batadv_send_skb_to_origSven Eckelmann
Sending functions in Linux consume the supplied skbuff. Doing the same in batadv_send_skb_to_orig avoids the hack of returning -1 (-EPERM) to signal the caller that he is responsible for cleaning up the skb. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-10-30batman-adv: use consume_skb for non-dropped packetsSven Eckelmann
kfree_skb assumes that an skb is dropped after an failure and notes that. consume_skb should be used in non-failure situations. Such information is important for dropmonitor netlink which tells how many packets were dropped and where this drop happened. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-10-30batman-adv: Simple (re)broadcast avoidanceLinus Lüssing
With this patch, (re)broadcasting on a specific interfaces is avoided: * No neighbor: There is no need to broadcast on an interface if there is no node behind it. * Single neighbor is source: If there is just one neighbor on an interface and if this neighbor is the one we actually got this broadcast packet from, then we do not need to echo it back. * Single neighbor is originator: If there is just one neighbor on an interface and if this neighbor is the originator of this broadcast packet, then we do not need to echo it back. Goodies for BATMAN V: ("Upgrade your BATMAN IV network to V now to get these for free!") Thanks to the split of OGMv1 into two packet types, OGMv2 and ELP that is, we can now apply the same optimizations stated above to OGMv2 packets, too. Furthermore, with BATMAN V, rebroadcasts can be reduced in certain multi interface cases, too, where BATMAN IV cannot. This is thanks to the removal of the "secondary interface originator" concept in BATMAN V. Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-10-30batman-adv: Remove unused skb_reset_mac_header()Linus Lüssing
During broadcast queueing, the skb_reset_mac_header() sets the skb to a place invalid for a MAC header, pointing right into the batman-adv broadcast packet. Luckily, no one seems to actually use eth_hdr(skb) afterwards until batadv_send_skb_packet() resets the header to a valid position again. Therefore removing this unnecessary, weird skb_reset_mac_header() call. Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-10-19batman-adv: Remove needless init of variables on stackSven Eckelmann
Some variables are overwritten immediatelly in a functions. These don't have to be initialized to a specific value on the stack because the value will be overwritten before they will be used anywhere. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-08-09batman-adv: Remove orig_node reference handling from send_skb_unicastSven Eckelmann
The function batadv_send_skb_unicast is not acquiring a reference for an orig_node nor removing it from any datastructure. It still reduces the reference counter for an object which is still in the hands of the caller. This is confusing and can lead in the future to problems in the reference handling of the caller function. Signed-off-by: Sven Eckelmann <sven@narfation.org> Acked-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-08-09batman-adv: Introduce forward packet creation helperLinus Lüssing
This patch abstracts the forward packet creation into the new function batadv_forw_packet_alloc(). The queue counting and interface reference counters are now handled internally within batadv_forw_packet_alloc() and its batadv_forw_packet_free() counterpart. This should reduce the risk of having reference/queue counting bugs again and should increase code readibility. Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Just several instances of overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-06batman-adv: Fix speedy join in gateway client modeSven Eckelmann
Speedy join only works when the received packet is either broadcast or an 4addr unicast packet. Thus packets converted from broadcast to unicast via the gateway handling code have to be converted to 4addr packets to allow the receiving gateway server to add the sender address as temporary entry to the translation table. Not doing it will make the batman-adv gateway server drop the DHCP response in many situations because it doesn't yet have the TT entry for the destination of the DHCP response. Fixes: 371351731e9c ("batman-adv: change interface_rx to get orig node") Signed-off-by: Sven Eckelmann <sven@narfation.org> Acked-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-07-04batman-adv: return netdev status in the TX pathAntonio Quartulli
Return the proper netdev TX status along the TX path so that the tp_meter can understand when the queue is full and should stop sending packets. Signed-off-by: Antonio Quartulli <antonio.quartulli@open-mesh.com> Signed-off-by: Sven Eckelmann <sven.eckelmann@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-06-30batman-adv: Consolidate logging related functionsSven Eckelmann
There are several places in batman-adv which provide logging related functions. These should be grouped together in the log.* files to make them easier to find. Reported-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-06-30batman-adv: Keep includes ordered by filenameSven Eckelmann
It is easier to detect if a include is already there for a used functionality when the includes are ordered. Using an alphabetic order together with the grouping in commit 1e2c2a4fe4a5 ("batman-adv: Add required includes to all files") makes includes better manageable. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-06-30batman-adv: remove ogm_emit and ogm_schedule API callsAntonio Quartulli
The ogm_emit and ogm_schedule API calls were rather tight to the B.A.T.M.A.N. IV logic and therefore rather difficult to use with other algorithm implementations. Remove such calls and move the surrounding logic into the B.A.T.M.A.N. IV specific code. Signed-off-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
2016-06-12sched: remove NET_XMIT_POLICEDFlorian Westphal
sch_atm returns this when TC_ACT_SHOT classification occurs. But all other schedulers that use tc_classify (htb, hfsc, drr, fq_codel ...) return NET_XMIT_SUCCESS | __BYPASS in this case so just do that in atm. BATMAN uses it as an intermediate return value to signal forwarding vs. buffering, but it did not return POLICED to callers outside of BATMAN. Reviewed-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-10batman-adv: Check hard_iface refcnt before calling functionSven Eckelmann
The batadv_hardif_list list is checked in many situations and the items in this list are given to specialized functions to modify the routing behavior. At the moment each of these called functions has to check itself whether the received batadv_hard_iface has a refcount > 0 before it can increase the reference counter and use it in other objects. This can easily lead to problems because it is not easily visible where all callers of a function got the batadv_hard_iface object from and whether they already hold a valid reference. Checking the reference counter directly before calling a subfunction with a pointer from the batadv_hardif_list avoids this problem. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc>
2016-05-04Merge tag 'batman-adv-for-davem' of git://git.open-mesh.org/linux-mergeDavid S. Miller
Antonio Quartulli says: ==================== pull request: batman-adv 20160504 In this pull request you have: - two changes to the MAINTAINERS file where one marks our mailing list as moderated and the other adds a missing documentation file - kernel-doc fixes - code refactoring and various cleanups ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-04batman-adv: use to_delayed_workGeliang Tang
Use to_delayed_work() instead of open-coding it. Signed-off-by: Geliang Tang <geliangtang@163.com> Reviewed-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc>
2016-04-24batman-adv: Fix broadcast/ogm queue limit on a removed interfaceLinus Lüssing
When removing a single interface while a broadcast or ogm packet is still pending then we will free the forward packet without releasing the queue slots again. This patch is supposed to fix this issue. Fixes: 6d5808d4ae1b ("batman-adv: Add missing hardif_free_ref in forw_packet_free") Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> [sven@narfation.org: fix conflicts with current version] Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc>
2016-02-29batman-adv: keep track of when unicast packets are sentAntonio Quartulli
To enable ELP to send probing packets over wireless links only if needed, batman-adv must keep track of the last time it sent a unicast packet towards every neighbour. For this purpose a 2 main changes are introduced: 1) a new member of the elp_neigh_node structure stores the last time a unicast packet was sent towards this neighbour; 2) a wrapper function for sending unicast packets is implemented. This function will simply update the member describe din point 1) and then forward the packet to the real sending routine. Point 2) implies that any code-path leading to a unicast sending now has to use the new wrapper. Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2016-02-23batman-adv: Rename batadv_neigh_node *_free_ref function to *_putSven Eckelmann
The batman-adv source code is the only place in the kernel which uses the *_free_ref naming scheme for the *_put functions. Changing it to *_put makes it more consistent and makes it easier to understand the connection to the *_get functions. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc>
2016-02-23batman-adv: Rename batadv_hardif *_free_ref function to *_putSven Eckelmann
2016-02-23batman-adv: Rename batadv_orig_node *_free_ref function to *_putSven Eckelmann
2016-02-02batman-adv: update copyright years for 2016Sven Eckelmann
2016-02-02batman-adv: Fix kerneldoc of main functionsSven Eckelmann
2016-02-02batman-adv: Fix kerneldoc parsing of return descriptionSven Eckelmann
2016-02-02batman-adv: Fix names in kerneldoc of functionsSven Eckelmann
2016-01-09batman-adv: Delete unnecessary checks before the function call "kfree_skb"Markus Elfring
The kfree_skb() function tests whether its argument is NULL and then returns immediately. Thus the test around the calls is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc>
2015-08-25batman-adv: Replace C99 int types with kernel typeSven Eckelmann
(s|u)(8|16|32|64) are the preferred types in the kernel. The use of the standard C99 types u?int(8|16|32|64)_t are objected by some people and even checkpatch now warns about using them. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2015-08-14batman-adv: remove broadcast packets scheduled for purged outgoing ifSimon Wunderlich
When an interface is purged, the broadcast packets scheduled for this interface should get purged as well. Signed-off-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2015-06-07batman-adv: Add required includes to all filesSven Eckelmann
The header files could not be build indepdent from each other. This is happened because headers didn't include the files for things they've used. This was problematic because the success of a build depended on the knowledge about the right order of local includes. Also source files were not including everything they've used explicitly. Instead they required that transitive includes are always stable. This is problematic because some transitive includes are not obvious, depend on config settings and may not be stable in the future. The order for include blocks are: * primary headers (main.h and the *.h file of a *.c file) * global linux headers * required local headers * extra forward declarations for pointers in function/struct declarations The only exceptions are linux/bitops.h and linux/if_ether.h in packet.h. This header file is shared with userspace applications like batctl and must therefore build together with userspace applications. The header linux/bitops.h is not part of the uapi headers and linux/if_ether.h conflicts with the musl implementation of netinet/if_ether.h. The maintainers rejected the use of __KERNEL__ preprocessor checks and thus these two headers are only in main.h. All files using packet.h first have to include main.h to work correctly. Reported-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2015-05-29batman-adv: Use common declaration order in *_send_skb_(packet|unicast)Antonio Quartulli
2015-05-29batman-adv: update copyright years for 2015Sven Eckelmann
2014-03-22batman-adv: Send multicast packets to nodes with a WANT_ALL flagLinus Lüssing
With this patch a node sends IPv4 multicast packets to nodes which have a BATADV_MCAST_WANT_ALL_IPV4 flag set and IPv6 multicast packets to nodes which have a BATADV_MCAST_WANT_ALL_IPV6 flag set, too. Why is this needed? There are scenarios involving bridges where multicast report snooping and multicast TT announcements are not sufficient, which would lead to packet loss for some nodes otherwise: MLDv1 and IGMPv1/IGMPv2 have a suppression mechanism for multicast listener reports. When we have an MLDv1/IGMPv1/IGMPv2 querier behind a bridge then our snooping bridge is potentially not going to see any reports even though listeners exist because according to RFC4541 such reports are only forwarded to multicast routers: ----------------------------------------------------------- --------------- {Querier}---|Snoop. Switch|----{Listener} --------------- \ ^ ------- | br0 | < ??? ------- \ _-~---~_ _-~/ ~-_ ~ batman-adv \-----{Sender} \~_ cloud ~/ -~~__-__-~_/ I) MLDv1 Query: {Querier} -> flooded II) MLDv1 Report: {Listener} -> {Querier} -> br0 cannot detect the {Listener} => Packets from {Sender} need to be forwarded to all detected listeners and MLDv1/IGMPv1/IGMPv2 queriers. ----------------------------------------------------------- Note that we do not need to explicitly forward to MLDv2/IGMPv3 queriers, because these protocols have no report suppression: A bridge has no trouble detecting MLDv2/IGMPv3 listeners. Even though we do not support bridges yet we need to provide the according infrastructure already to not break compatibility later. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: Modified forwarding behaviour for multicast packetsLinus Lüssing
With this patch a multicast packet is not always simply flooded anymore, the behaviour for the following cases is changed to reduce unnecessary overhead: If all nodes within the horizon of a certain node have signalized multicast listener announcement capability then an IPv6 multicast packet with a destination of IPv6 link-local scope (excluding ff02::1) coming from the upstream of this node... * ...is dropped if there is no according multicast listener in the translation table, * ...is forwarded via unicast if there is a single node with interested multicast listeners * ...and otherwise still gets flooded. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: add kerneldoc for dst_hint argumentAntonio Quartulli
Some helper functions used along the TX path have now a new "dst_hint" argument but the kerneldoc was missing. Signed-off-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-03-22batman-adv: prefer ether_addr_copy to memcpyAntonio Quartulli
On some architectures ether_addr_copy() is slightly faster than memcpy() therefore use the former when possible. Signed-off-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-03-22batman-adv: use vlan_/eth_hdr() instead of skb->data in interface_tx pathLinus Lüssing
Our .ndo_start_xmit handler (batadv_interface_tx()) can rely on having the skb mac header pointer set correctly since the following commit present in kernels >= 3.9: "net: reset mac header in dev_start_xmit()" (6d1ccff627) Therefore we can safely use eth_hdr() and vlan_eth_hdr() instead of skb->data now, which spares us some ugly type casts. At the same time set the mac_header in batadv_dat_snoop_incoming_arp_request() before sending the skb along the TX path. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-02-17batman-adv: fix potential kernel paging error for unicast transmissionsAntonio Quartulli
batadv_send_skb_prepare_unicast(_4addr) might reallocate the skb's data. If it does then our ethhdr pointer is not valid anymore in batadv_send_skb_unicast(), resulting in a kernel paging error. Fixing this by refetching the ethhdr pointer after the potential reallocation. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-01-12batman-adv: update copyright years for 2014Simon Wunderlich
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-01-12batman-adv: consider outgoing interface in OGM sendingSimon Wunderlich
The current OGM sending an aggregation functionality decides on which interfaces a packet should be sent when it parses the forward packet struct. However, with the network wide multi interface optimization the outgoing interface is decided by the OGM processing function. This is reflected by moving the decision in the OGM processing function and add the outgoing interface in the forwarding packet struct. This practically implies that an OGM may be added multiple times (once per outgoing interface), and this also affects aggregation which needs to consider the outgoing interface as well. Signed-off-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-01-08batman-adv: send every DHCP packet as bat-unicastAntonio Quartulli
In different situations it is possible that the DHCP server or client uses broadcast Ethernet frames to send messages to each other. The GW component in batman-adv takes care of using bat-unicast packets to bring broadcast DHCP Discover/Requests to the "best" server. On the way back the DHCP server usually sends unicasts, but upon client request it may decide to use broadcasts as well. This patch improves the GW component so that it now snoops and sends as unicast all the DHCP packets, no matter if they were generated by a DHCP server or client. Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
