[ Upstream commit d7d8bbb40a5b1f682ee6589e212934f4c6b8ad60 ]
The complete size ("total_size") of the fragmented packet is stored in the
fragment header and in the size of the fragment chain. When the fragments
are ready for merge, the skbuff's tail of the first fragment is expanded to
have enough room after the data pointer for at least total_size. This means
that it gets expanded by total_size - first_skb->len.
But this is ignoring the fact that after expanding the buffer, the fragment
header is pulled by from this buffer. Assuming that the tailroom of the
buffer was already 0, the buffer after the data pointer of the skbuff is
now only total_size - len(fragment_header) large. When the merge function
is then processing the remaining fragments, the code to copy the data over
to the merged skbuff will cause an skb_over_panic when it tries to actually
put enough data to fill the total_size bytes of the packet.
The size of the skb_pull must therefore also be taken into account when the
buffer's tailroom is expanded.
Fixes: 610bfc6bc99b ("batman-adv: Receive fragmented packets and merge")
Reported-by: Martin Weinelt <martin@darmstadt.freifunk.net>
Co-authored-by: Linus Lüssing <linus.luessing@c0d3.blue>
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
[ Upstream commit f4156f9656feac21f4de712fac94fae964c5d402 ]
The announcement messages of batman-adv COMPAT_VERSION 15 have the
possibility to announce additional information via a dynamic TVLV part.
This part is optional for the ELP packets and currently not parsed by the
Linux implementation. Still out-of-tree versions are using it to transport
things like neighbor hashes to optimize the rebroadcast behavior.
Since the ELP broadcast packets are smaller than the minimal ethernet
packet, it often has to be padded. This is often done (as specified in
RFC894) with octets of zero and thus work perfectly fine with the TVLV
part (making it a zero length and thus empty). But not all ethernet
compatible hardware seems to follow this advice. To avoid ambiguous
situations when parsing the TVLV header, just force the 4 bytes (TVLV
length + padding) after the required ELP header to zero.
Fixes: d6f94d91f766 ("batman-adv: ELP - adding basic infrastructure")
Reported-by: Linus Lüssing <linus.luessing@c0d3.blue>
[ Upstream commit 4c4af6900844ab04c9434c972021d7b48610e06a ]
The hardif_neigh refcounter is to be decreased by the queued work and
currently is never decreased if the queue_work() call fails.
Fix by checking the queue_work() return value and decrease refcount
if necessary.
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
[ Upstream commit 5af96b9c59c72fb2af2d19c5cc2f3cdcee391dff ]
The backbone_gw refcounter is to be decreased by the queued work and
if necessary.
[ Upstream commit ae3cdc97dc10c7a3b31f297dab429bfb774c9ccb ]
The function batadv_tvlv_handler_register is responsible for adding new
tvlv_handler to the handler_list. It first checks whether the entry
already is in the list or not. If it is, then the creation of a new entry
is aborted.
But the lock for the list is only held when the list is really modified.
This could lead to duplicated entries because another context could create
an entry with the same key between the check and the list manipulation.
The check and the manipulation of the list must therefore be in the same
locked code section.
Fixes: ef26157747d4 ("batman-adv: tvlv - basic infrastructure")
[ Upstream commit e7136e48ffdfb9f37b0820f619380485eb407361 ]
The function batadv_tt_global_orig_entry_add is responsible for adding new
tt_orig_list_entry to the orig_list. It first checks whether the entry
is aborted.
Fixes: d657e621a0f5 ("batman-adv: add reference counting for type batadv_tt_orig_list_entry")
[ Upstream commit 94cb82f594ed86be303398d6dfc7640a6f1d45d4 ]
The function batadv_softif_vlan_get is responsible for adding new
softif_vlan to the softif_vlan_list. It first checks whether the entry
is aborted.
Fixes: 5d2c05b21337 ("batman-adv: add per VLAN interface attribute framework")
[ Upstream commit fa122fec8640eb7186ce5a41b83a4c1744ceef8f ]
The function batadv_nc_get_nc_node is responsible for adding new nc_nodes
to the in_coding_list and out_coding_list. It first checks whether the
entry already is in the list or not. If it is, then the creation of a new
entry is aborted.
Fixes: d56b1705e28c ("batman-adv: network coding - detect coding nodes and remove these after timeout")
Acked-by: Marek Lindner <mareklindner@neomailbox.ch>
[ Upstream commit dff9bc42ab0b2d38c5e90ddd79b238fed5b4c7ad ]
The function batadv_gw_node_add is responsible for adding new gw_node to
the gateway_list. It is expecting that the caller already checked that
there is not already an entry with the same key or not.
Fixes: c6c8fea29769 ("net: Add batman-adv meshing protocol")
[ Upstream commit a25bab9d723a08bd0bdafb1529faf9094c690b70 ]
The per hardif sysfs file "batman_adv/elp_interval" is using the generic
functions to store/show uint values. The helper __batadv_store_uint_attr
requires the softif net_device as parameter to print the resulting change
as info text when the users writes to this file. It uses the helper
function batadv_info to add it at the same time to the kernel ring buffer
and to the batman-adv debug log (when CONFIG_BATMAN_ADV_DEBUG is enabled).
The function batadv_info requires as first parameter the batman-adv softif
net_device. This parameter is then used to find the private buffer which
contains the debug log for this batman-adv interface. But
batadv_store_throughput_override used as first argument the slave
net_device. This slave device doesn't have the batadv_priv private data
which is access by batadv_info.
Writing to this file with CONFIG_BATMAN_ADV_DEBUG enabled can either lead
to a segfault or to memory corruption.
Fixes: 0744ff8fa8fa ("batman-adv: Add hard_iface specific sysfs wrapper macros for UINT")
[ Upstream commit b9fd14c20871e6189f635e49b32d7789e430b3c8 ]
The per hardif sysfs file "batman_adv/throughput_override" prints the
resulting change as info text when the users writes to this file. It uses
the helper function batadv_info to add it at the same time to the kernel
ring buffer and to the batman-adv debug log (when CONFIG_BATMAN_ADV_DEBUG
is enabled).
Fixes: 0b5ecc6811bd ("batman-adv: add throughput override attribute to hard_ifaces")
[ Upstream commit 88d0895d0ea9d4431507d576c963f2ff9918144d ]
The probe ELPs for WiFi interfaces are expanded to contain at least
BATADV_ELP_MIN_PROBE_SIZE bytes. This is usually a lot more than the
number of bytes which the template ELP packet requires.
These extra padding bytes were not initialized and thus could contain data
which were previously stored at the same location. It is therefore required
to set it to some predefined or random values to avoid leaking private
information from the system transmitting these kind of packets.
Fixes: e4623c913508 ("batman-adv: Avoid probe ELP information leak")
Acked-by: Antonio Quartulli <a@unstable.cc>
[ Upstream commit a44ebeff6bbd6ef50db41b4195fca87b21aefd20 ]
When a (broken) node wrongly sends multicast TT entries with a ROAM
flag then this causes any receiving node to drop all entries for the
same multicast MAC address announced by other nodes, leading to
packet loss.
Fix this DoS vector by only storing TT sync flags. For multicast TT
non-sync'ing flag bits like ROAM are unused so far anyway.
Fixes: 1d8ab8d3c176 ("batman-adv: Modified forwarding behaviour for multicast packets")
Reported-by: Leonardo Mörlein <me@irrelefant.net>
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
[ Upstream commit 4a519b83da16927fb98fd32b0f598e639d1f1859 ]
Since commit 54e22f265e87 ("batman-adv: fix TT sync flag inconsistencies")
TT sync flags and TT non-sync'd flags are supposed to be stored
separately.
The previous patch missed to apply this separation on a TT entry with
only a single TT orig entry.
This is a minor fix because with only a single TT orig entry the DDoS
issue the former patch solves does not apply.
Fixes: 54e22f265e87 ("batman-adv: fix TT sync flag inconsistencies")
[ Upstream commit 9713cb0cf19f1cec6c007e3b37be0697042b6720 ]
A reference for the best gateway is taken when the list of gateways in the
mesh is sent via netlink. This is necessary to check whether the currently
dumped entry is the currently selected gateway or not. This information is
then transferred as flag BATADV_ATTR_FLAG_BEST.
After the comparison of the current entry is done,
batadv_v_gw_dump_entry() has to decrease the reference counter again.
Otherwise the reference will be held and thus prevents a proper shutdown of
the batman-adv interfaces (and some of the interfaces enslaved in it).
Fixes: b71bb6f924fe ("batman-adv: add B.A.T.M.A.N. V bat_gw_dump implementations")
[ Upstream commit b5685d2687d6612adf5eac519eb7008f74dfd1ec ]
batadv_iv_gw_dump_entry() has to decrease the reference counter again.
Fixes: efb766af06e3 ("batman-adv: add B.A.T.M.A.N. IV bat_gw_dump implementations")
Reported-by: Andreas Ziegler <dev@andreas-ziegler.de>
Tested-by: Andreas Ziegler <dev@andreas-ziegler.de>
[ Upstream commit a752c0a4524889cdc0765925258fd1fd72344100 ]
DHCP connectivity issues can currently occur if the following conditions
are met:
1) A DHCP packet from a client to a server
2) This packet has a multicast destination
3) This destination has a matching entry in the translation table
(FF:FF:FF:FF:FF:FF for IPv4, 33:33:00:01:00:02/33:33:00:01:00:03
for IPv6)
4) The orig-node determined by TT for the multicast destination
does not match the orig-node determined by best-gateway-selection
In this case the DHCP packet will be dropped.
The "gateway-out-of-range" check is supposed to only be applied to
unicasted DHCP packets to a specific DHCP server.
In that case dropping the the unicasted frame forces the client to
retry via a broadcasted one, but now directed to the new best
gateway.
A DHCP packet with broadcast/multicast destination is already ensured to
always be delivered to the best gateway. Dropping a multicasted
DHCP packet here will only prevent completing DHCP as there is no
other fallback.
So far, it seems the unicast check was implicitly performed by
expecting the batadv_transtable_search() to return NULL for multicast
destinations. However, a multicast address could have always ended up in
the translation table and in fact is now common.
To fix this potential loss of a DHCP client-to-server packet to a
multicast address this patch adds an explicit multicast destination
check to reliably bail out of the gateway-out-of-range check for such
destinations.
The issue and fix were tested in the following three node setup:
- Line topology, A-B-C
- A: gateway client, DHCP client
- B: gateway server, hop-penalty increased: 30->60, DHCP server
- C: gateway server, code modifications to announce FF:FF:FF:FF:FF:FF
Without this patch, A would never transmit its DHCP Discover packet
due to an always "out-of-range" condition. With this patch,
a full DHCP handshake between A and B was possible again.
Fixes: be7af5cf9cae ("batman-adv: refactoring gateway handling code")
[ Upstream commit f8fb3419ead44f9a3136995acd24e35da4525177 ]
For multicast frames AP isolation is only supposed to be checked on
the receiving nodes and never on the originating one.
Furthermore, the isolation or wifi flag bits should only be intepreted
as such for unicast and never multicast TT entries.
By injecting flags to the multicast TT entry claimed by a single
target node it was verified in tests that this multicast address
becomes unreachable, leading to packet loss.
Omitting the "src" parameter to the batadv_transtable_search() call
successfully skipped the AP isolation check and made the target
reachable again.
[ Upstream commit fc04fdb2c8a894283259f5621d31d75610701091 ]
batadv_check_unicast_ttvn may redirect a packet to itself or another
originator. This involves rewriting the ttvn and the destination address in
the batadv unicast header. These field were not yet pulled (with skb rcsum
update) and thus any change to them also requires a change in the receive
checksum.
Reported-by: Matthias Schiffer <mschiffer@universe-factory.net>
Fixes: a73105b8d4c7 ("batman-adv: improved client announcement mechanism")
[ Upstream commit 6f27d2c2a8c236d296201c19abb8533ec20d212b ]
Checking for 0 is insufficient: when an SKB without a batadv header, but
with a VLAN header is received, hdr_size will be 4, making the following
code interpret the Ethernet header as a batadv header.
Fixes: be1db4f6615b ("batman-adv: make the Distributed ARP Table vlan aware")
Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net>
[ Upstream commit 74c12c630fe310eb7fcae1b292257d47781fff0a ]
As the kernel doc describes too the code is supposed to skip adding
multicast TT entries if both the WANT_ALL_IPV4 and WANT_ALL_IPV6 flags
are present.
Unfortunately, the current code even skips adding multicast TT entries
if only either the WANT_ALL_IPV4 or WANT_ALL_IPV6 is present.
This could lead to IPv6 multicast packet loss if only an IGMP but not an
MLD querier is present for instance or vice versa.
Fixes: 687937ab3489 ("batman-adv: Add multicast optimization support for bridged setups")
[ Upstream commit fce672db548ff19e76a08a32a829544617229bc2 ]
The function batadv_bla_backbone_dump_bucket must be able to handle
non-complete dumps of a single bucket. It tries to do that by saving the
latest dumped index in *idx_skip to inform the caller about the current
state.
But the caller only assumes that buckets were not completely dumped when
the return code is non-zero. This function must therefore also return a
non-zero index when the dumping of an entry failed. Otherwise the caller
will just skip all remaining buckets.
And the function must also reset *idx_skip back to zero when it finished a
bucket. Otherwise it will skip the same number of entries in the next
bucket as the previous one had.
Fixes: ea4152e11716 ("batman-adv: add backbone table netlink support")
[ Upstream commit b0264ecdfeab5f889b02ec54af7ca8cc1c245e2f ]
The function batadv_bla_claim_dump_bucket must be able to handle
state.
Fixes: 04f3f5bf1883 ("batman-adv: add B.A.T.M.A.N. Dump BLA claims via netlink")
[ Upstream commit 011c935fceae5252619ef730baa610c655281dda ]
The function batadv_v_gw_dump stops the processing loop when
batadv_v_gw_dump_entry returns a non-0 return code. This should only
happen when the buffer is full. Otherwise, an empty message may be
returned by batadv_gw_dump. This empty message will then stop the netlink
dumping of gateway entries. At worst, not a single entry is returned to
userspace even when plenty of possible gateways exist.
Signed-off-by: Sven Eckelmann <sven.eckelmann@openmesh.com>
[ Upstream commit 10d570284258a30dc104c50787c5289ec49f3d23 ]
The function batadv_iv_gw_dump stops the processing loop when
batadv_iv_gw_dump_entry returns a non-0 return code. This should only
[ Upstream commit 3bf2a09da956b43ecfaa630a2ef9a477f991a46a ]
A more sophisticated implementation could try to combine fragment checksums
when all fragments have CHECKSUM_COMPLETE and are split at even offsets.
For now, we just set ip_summed to CHECKSUM_NONE to avoid "hw csum failure"
warnings in the kernel log when fragmented frames are received. In
consequence, skb_pull_rcsum() can be replaced with skb_pull().
Note that in usual setups, packets don't reach batman-adv with
CHECKSUM_COMPLETE (I assume NICs bail out of checksumming when they see
batadv's ethtype?), which is why the log messages do not occur on every
system using batman-adv. I could reproduce this issue by stacking
batman-adv on top of a VXLAN interface.
Tested-by: Maximilian Wilhelm <max@sdn.clinic>
[ Upstream commit abd6360591d3f8259f41c34e31ac4826dfe621b8 ]
eth_type_trans() internally calls skb_pull(), which does not adjust the
skb checksum; skb_postpull_rcsum() is necessary to avoid log spam of the
form "bat0: hw csum failure" when packets with CHECKSUM_COMPLETE are
received.
The UDP offload conflict is dealt with by simply taking what is
in net-next where we have removed all of the UFO handling code
entirely.
The TCP conflict was a case of local variables in a function
being removed from both net and net-next.
In netvsc we had an assignment right next to where a missing
set of u64 stats sync object inits were added.
This patch fixes an issue in the translation table code potentially
leading to a TT Request + Response storm. The issue may occur for nodes
involving BLA and an inconsistent configuration of the batman-adv AP
isolation feature. However, since the new multicast optimizations, a
single, malformed packet may lead to a mesh-wide, persistent
Denial-of-Service, too.
The issue occurs because nodes are currently OR-ing the TT sync flags of
all originators announcing a specific MAC address via the
translation table. When an intermediate node now receives a TT Request
and wants to answer this on behalf of the destination node, then this
intermediate node now responds with an altered flag field and broken
CRC. The next OGM of the real destination will lead to a CRC mismatch
and triggering a TT Request and Response again.
Furthermore, the OR-ing is currently never undone as long as at least
one originator announcing the according MAC address remains, leading to
the potential persistency of this issue.
This patch fixes this issue by storing the flags used in the CRC
calculation on a a per TT orig entry basis to be able to respond with
the correct, original flags in an intermediate TT Response for one
thing. And to be able to correctly unset sync flags once all nodes
announcing a sync flag vanish for another.
Fixes: e9c00136a475 ("batman-adv: fix tt_global_entries flags update")
[sw: typo in commit message]
Trivial fix to spelling mistakes in batadv_dbg debug messages and
also in a comment and ensure comment line is not wider than 80
characters
"ourselve" -> "ourselves"
"surpressed" -> "suppressed"
"troughput" -> "throughput"
skb_put_data makes it unnecessary to store the skb_put return value to copy
some data to the packet. The returned pointer of skb_put_data should
therefore not stored by functions which previously only used it to copy
some data.
The string representation for a mac address produced by %pM is 17
characters long. Left-aligning the output in a 15 character wide field
width %-15pM is therefore misleading and unnecessary.
It's misleading and unnecessary.
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
There were many places that my previous spatch didn't find,
as pointed out by yuan linyu in various patches.
The following spatch found many more and also removes the
now unnecessary casts:
identifier p, p2;
expression len;
expression skb;
type t, t2;
+p = skb_put_zero(skb, len);
... when != p
p2 = (t2)p;
-memset(p2, 0, len);
-memset(p, 0, len);
type t, t2;
identifier p, p2;
expression skb;
t *p;
+p = skb_put_zero(skb, sizeof(t));
... when != p
p2 = (t2)p;
-memset(p2, 0, sizeof(*p));
-memset(p, 0, sizeof(*p));
expression skb, len;
-memset(skb_put(skb, len), 0, len);
+skb_put_zero(skb, len);
Apply it to the tree (with one manual fixup to keep the
comment in vxlan.c, which spatch removed.)
The conflicts were two cases of overlapping changes in
batman-adv and the qed driver.
Simon Wunderlich says:
Here are two batman-adv bugfixes:
- fix rx packet counters for local ARP replies, by Sven Eckelmann
- fix memory leaks for unicast packetes received from another gateway
in bridge loop avoidance, by Andreas Pape
The wifi driver can decide to not provide parts of the station info. For
example, the expected throughput of the station can be omitted when the
used rate control doesn't provide this kind of information.
The B.A.T.M.A.N. V implementation must therefore check the filled bitfield
before it tries to access the expected_throughput of the returned
station_info.
Reported-by: Alvaro Antelo <alvaro.antelo@gmail.com>
Fixes: c833484e5f38 ("batman-adv: ELP - compute the metric based on the estimated throughput")
Reviewed-by: Marek Lindner <mareklindner@neomailbox.ch>
A wifi interface should never be handled like an ethernet devices. The
parser of the cfg80211 output must therefore skip the ethtool code when
cfg80211_get_station returned an error.
Fixes: f44a3ae9a281 ("batman-adv: refactor wifi interface detection")
This change has been made for local TT already, add another one for
global TT - but only for temporary entries (aka speedy join), to prevent
inconsistencies between local and global tables in case an older
batman-adv version is still announcing those entries from its local
table.
batadv_tp_meter_init() is invoked in batadv_init() only
which is marked with __init.
For this reason batadv_tp_meter_init() can be marked with
__init as well and dropped after module load.
Signed-off-by: Antonio Quartulli <a@unstable.cc>
Network devices can allocate reasources and private memory using
netdev_ops->ndo_init(). However, the release of these resources
can occur in one of two different places.
Either netdev_ops->ndo_uninit() or netdev->destructor().
The decision of which operation frees the resources depends upon
whether it is necessary for all netdev refs to be released before it
is safe to perform the freeing.
netdev_ops->ndo_uninit() presumably can occur right after the
NETDEV_UNREGISTER notifier completes and the unicast and multicast
address lists are flushed.
netdev->destructor(), on the other hand, does not run until the
netdev references all go away.
Further complicating the situation is that netdev->destructor()
almost universally does also a free_netdev().
This creates a problem for the logic in register_netdevice().
Because all callers of register_netdevice() manage the freeing
of the netdev, and invoke free_netdev(dev) if register_netdevice()
fails.
If netdev_ops->ndo_init() succeeds, but something else fails inside
of register_netdevice(), it does call ndo_ops->ndo_uninit(). But
it is not able to invoke netdev->destructor().
This is because netdev->destructor() will do a free_netdev() and
then the caller of register_netdevice() will do the same.
However, this means that the resources that would normally be released
by netdev->destructor() will not be.
Over the years drivers have added local hacks to deal with this, by
invoking their destructor parts by hand when register_netdevice()
fails.
Many drivers do not try to deal with this, and instead we have leaks.
Let's close this hole by formalizing the distinction between what
private things need to be freed up by netdev->destructor() and whether
the driver needs unregister_netdevice() to perform the free_netdev().
netdev->priv_destructor() performs all actions to free up the private
resources that used to be freed by netdev->destructor(), except for
free_netdev().
netdev->needs_free_netdev is a boolean that indicates whether
free_netdev() should be done at the end of unregister_netdevice().
Now, register_netdevice() can sanely release all resources after
ndo_ops->ndo_init() succeeds, by invoking both ndo_ops->ndo_uninit()
and netdev->priv_destructor().
And at the end of unregister_netdevice(), we invoke
netdev->priv_destructor() and optionally call free_netdev().
The function names in batman-adv changed slightly in the past. But some of
the debug messages were not updated correctly and therefore some messages
were incorrect. To avoid this in the future, these kind of messages should
use __func__ to automatically print the correct function name.
batadv_nc_nodes_seq_print_text()
A bit of text was put into a sequence by two separate function calls.
Print the same data by a single function call instead.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Two single characters (line breaks) should be put into a sequence.
Thus use the corresponding function "seq_putc".
With this patch the maximum fragment size is reduced from 1400 to 1280
bytes.
Fragmentation v2 correctly uses the smaller of 1400 and the interface
MTU, thus generally supporting interfaces with an MTU < 1400 bytes, too.
However, currently "Fragmentation v2" does not support re-fragmentation.
Which means that once a packet is split into two packets of 1400 + x
bytes for instance and the next hop provides an interface with an even
smaller MTU of 1280 bytes, then the larger fragment is lost.
A maximum fragment size of 1280 bytes is a safer option as this is the
minimum MTU required by IPv6, making interfaces with an MTU < 1280
rather exotic.
Regarding performance, this should have no negative impact on unicast
traffic: Having some more bytes in the smaller and some less in the
larger does not change the sum of both fragments.
Concerning TT, choosing 1280 bytes fragments might result in more TT
messages than necessary when a large network is bridged into batman-adv.
However, the TT overhead in general is marginal due to its reactive
nature, therefore such a performance impact on TT should not be
noticeable for a user.
Cc: Matthias Schiffer <mschiffer@universe-factory.net>
[linus.luessing@c0d3.blue: Added commit message]
