A new driver is implemented to actively manage the bluetooth module
power. bluesleep also tries to manage the power of the transport used.
Two signals (GPIOs) are used to manage the power events.
BT_WAKE : signal from HOST to BT chip to intimate BT chip can sleep.
HOST_WAKE: signal from BT chip to HOST to intimate HOST should wakeup/
activate the transport modules required for BT communication.
Bug 791669, 773186
(cherry picked from commit 111f4ccd3c4cfde2fa52ae4c0c56a2288c3af3a8)
Original-Change-Id: Iff1e81bb22d9bd43113f7cdd01329da3ae852a15
Reviewed-on: http://git-master/r/19858
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R1eca7f2f51475daf6104e71e90ad5db1213fa6ea
No command should be send before Command Complete event for HCI
reset is received. This fix regression introduced by commit
6bd32326cda(Bluetooth: Use proper timer for hci command timout)
for chips whose reset command takes longer to complete (e.g. CSR)
resulting in next command being send before HCI reset completed.
Signed-off-by: Szymon Janc <szymon@janc.net.pl>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
There was a small typo here so we never actually hit the goto which
would call hci_dev_unlock_bh().
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
net/bluetooth/l2cap_core.c
In some cases it will be useful having the key size used for
encrypting the link. For example, some profiles may restrict
some operations depending on the key length.
The key size is stored in the key that is passed to userspace
using the pin_length field in the key structure.
For now this field is only valid for LE controllers. 3.0+HS
controllers define the Read Encryption Key Size command, this
field is intended for storing the value returned by that
command.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
As the LTK (the new type of key being handled now) has more data
associated with it, we need to store this extra data and retrieve
the keys based on that data.
Methods for searching for a key and for adding a new LTK are
introduced here.
Since hdev->lock may be acquired by threads runnning in interrupt
context, all threads running in process context should disable
local bottom halve before locking hdev->lock. This can be done by
using hci_dev_lock_bh macro.
This way, we avoid potencial deadlocks like this one reported by
CONFIG_PROVE_LOCKING=y.
[ 304.788780] =================================
[ 304.789686] [ INFO: inconsistent lock state ]
[ 304.789686] 2.6.39+ #1
[ 304.789686] ---------------------------------
[ 304.789686] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
[ 304.789686] ksoftirqd/0/3 [HC0[0]:SC1[1]:HE1:SE0] takes:
[ 304.789686] (&(&hdev->lock)->rlock){+.?...}, at: [<ffffffffa000bbfe>] hci_conn_check_pending+0x38/0x76 [bluetooth]
[ 304.789686] {SOFTIRQ-ON-W} state was registered at:
[ 304.789686] [<ffffffff8105188b>] __lock_acquire+0x347/0xd52
[ 304.789686] [<ffffffff810526ac>] lock_acquire+0x8a/0xa7
[ 304.789686] [<ffffffff812b3758>] _raw_spin_lock+0x2c/0x3b
[ 304.789686] [<ffffffffa0009cf0>] hci_blacklist_del+0x1f/0x8a [bluetooth]
[ 304.789686] [<ffffffffa00139fd>] hci_sock_ioctl+0x2d9/0x314 [bluetooth]
[ 304.789686] [<ffffffff812197d8>] sock_ioctl+0x1f2/0x214
[ 304.789686] [<ffffffff810b0fd6>] do_vfs_ioctl+0x46c/0x4ad
[ 304.789686] [<ffffffff810b1059>] sys_ioctl+0x42/0x65
[ 304.789686] [<ffffffff812b4892>] system_call_fastpath+0x16/0x1b
[ 304.789686] irq event stamp: 9768
[ 304.789686] hardirqs last enabled at (9768): [<ffffffff812b40d4>] restore_args+0x0/0x30
[ 304.789686] hardirqs last disabled at (9767): [<ffffffff812b3f6a>] save_args+0x6a/0x70
[ 304.789686] softirqs last enabled at (9726): [<ffffffff8102fa9b>] __do_softirq+0x129/0x13f
[ 304.789686] softirqs last disabled at (9739): [<ffffffff8102fb33>] run_ksoftirqd+0x82/0x133
[ 304.789686]
[ 304.789686] other info that might help us debug this:
[ 304.789686] Possible unsafe locking scenario:
[ 304.789686]
[ 304.789686] CPU0
[ 304.789686] ----
[ 304.789686] lock(&(&hdev->lock)->rlock);
[ 304.789686] <Interrupt>
[ 304.789686]
[ 304.789686] *** DEADLOCK ***
[ 304.789686]
[ 304.789686] 1 lock held by ksoftirqd/0/3:
[ 304.789686] #0: (hci_task_lock){++.-..}, at: [<ffffffffa0008353>] hci_rx_task+0x49/0x2f3 [bluetooth]
[ 304.789686]
[ 304.789686] stack backtrace:
[ 304.789686] Pid: 3, comm: ksoftirqd/0 Not tainted 2.6.39+ #1
[ 304.789686] Call Trace:
[ 304.789686] [<ffffffff812ae901>] print_usage_bug+0x1e7/0x1f8
[ 304.789686] [<ffffffff8100a796>] ? save_stack_trace+0x27/0x44
[ 304.789686] [<ffffffff8104fc3f>] ? print_irq_inversion_bug.part.26+0x19a/0x19a
[ 304.789686] [<ffffffff810504bb>] mark_lock+0x106/0x258
[ 304.789686] [<ffffffff812b40d4>] ? retint_restore_args+0x13/0x13
[ 304.789686] [<ffffffff81051817>] __lock_acquire+0x2d3/0xd52
[ 304.789686] [<ffffffff8102be73>] ? vprintk+0x3ab/0x3d7
[ 304.789686] [<ffffffff812ae126>] ? printk+0x3c/0x3e
[ 304.789686] [<ffffffffa000bbfe>] ? hci_conn_check_pending+0x38/0x76 [bluetooth]
[ 304.789686] [<ffffffff811601c6>] ? __dynamic_pr_debug+0x10c/0x11a
[ 304.789686] [<ffffffffa000bbfe>] hci_conn_check_pending+0x38/0x76 [bluetooth]
[ 304.789686] [<ffffffffa000c561>] hci_event_packet+0x38e/0x3e12 [bluetooth]
[ 304.789686] [<ffffffff81052615>] ? lock_release+0x16c/0x179
[ 304.789686] [<ffffffff812b3b41>] ? _raw_read_unlock+0x23/0x27
[ 304.789686] [<ffffffffa0013e7f>] ? hci_send_to_sock+0x179/0x188 [bluetooth]
[ 304.789686] [<ffffffffa00083d2>] hci_rx_task+0xc8/0x2f3 [bluetooth]
[ 304.789686] [<ffffffff8102f5a9>] tasklet_action+0x87/0xe6
[ 304.789686] [<ffffffff8102fa11>] __do_softirq+0x9f/0x13f
[ 304.789686] [<ffffffff8102fb33>] run_ksoftirqd+0x82/0x133
[ 304.789686] [<ffffffff8102fab1>] ? __do_softirq+0x13f/0x13f
[ 304.789686] [<ffffffff81040f0a>] kthread+0x7f/0x87
[ 304.789686] [<ffffffff812b55c4>] kernel_thread_helper+0x4/0x10
[ 304.789686] [<ffffffff81040e8b>] ? __init_kthread_worker+0x53/0x53
[ 304.789686] [<ffffffff812b55c0>] ? gs_change+0x13/0x13
Signed-off-by: Andre Guedes <andre.guedes@openbossa.org>
The enable_smp parameter is no longer needed. It can be replaced by
checking lmp_host_le_capable.
Since we have the extended LMP features properly implemented, we
should check the LMP_HOST_LE bit to know if the host supports LE.
Make it easier to use more normal logging styles later.
drivers/net/wireless/rtlwifi/pci.c
include/linux/netlink.h
There was no unlock call on the errors path
Move blacklisting functions to hci_core.c, so that they can
be used by both management interface and hci socket interface.
Signed-off-by: Antti Julku <antti.julku@nokia.com>
This will allow using the crypto subsystem for encrypting data. As SMP
(Security Manager Protocol) is implemented almost entirely on the host
side and the crypto module already implements the needed methods
(AES-128), it makes sense to use it.
There's now a new module option to enable/disable SMP support.
Signed-off-by: Anderson Briglia <anderson.briglia@openbossa.org>
Add BT_POWER socket option used to control the power
characteristics of the underlying ACL link. When the remote end
has put the link in sniff mode and the host stack wants to send
data we need need to explicitly exit sniff mode to work well with
certain devices (For example, A2DP on Plantronics Voyager 855).
However, this causes problems with HID devices.
Hence, moving into active mode when sending data, irrespective
of who set the sniff mode has been made as a socket option. By
default, we will move into active mode. HID devices can set the
L2CAP socket option to prevent this from happening.
Currently, this has been implemented for L2CAP sockets. This has been
tested with incoming and outgoing L2CAP sockets for HID and A2DP.
Based on discussions on linux-bluetooth and patches submitted by
Andrei Emeltchenko.
Signed-off-by: Jaikumar Ganesh <jaikumar@google.com>
This patch adds a timer to clear 'adv_entries' after three minutes.
After some amount of time, the advertising entries cached during
the last LE scan should be considered expired and they should be
removed from the advertising cache.
It was chosen a three minutes timeout as an initial attempt. This
value might change in future.
This patch implements the LE advertising cache. It stores sensitive
information (bdaddr and bdaddr_type so far) gathered from LE
advertising report events.
Only advertising entries from connectables devices are added to the
cache.
Semicolons are not necessary after switch/while/for/if braces
so remove them.
drivers/net/wireless/libertas/if_cs.c
net/bluetooth/l2cap_sock.c
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-next-2.6
Even for keys that shouldn't be stored some use cases require the
knowledge of a new key having been created so that the conclusion of a
successful pairing can be made. Therefore, always send the mgmt_new_key
event but add a store_hint parameter to it to indicate to user space
whether the key should be stored or not.
Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com>
User space shouldn't have any need for the old key type so remove it
from the corresponding Management interface event.
If a controller generates a changed combination key as its first key the
connection key type will not be correctly set. In these situations make
sure the update the connection key type when such a buggy controller is
detected.
Even if there's no previous key stored the connection might still be
secured with a non-persistent key and in that case the key type in the
hci_conn struct should be checked.
Link keys should only be stored if very specific criteria of the
authentication process are fulfilled. This patch essentially copies the
criteria that user space has so far been using to the kernel side so
that the management interface works properly.
Introduce the link key types defs and use them instead of magic numbers.
Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com>
Resolved logic conflicts causing a build failure due to
drivers/net/r8169.c changes using a patch from Stephen Rothwell.
net/bluetooth/mgmt.c
In the teardown path the reset command is sent to the controller,
this event causes the command timer to be reactivated.
So the timer is removed in two situations, when the adapter isn't
marked as UP and when we know that some command has been sent.
Reported-by: Keith Packard <keithp@keithp.com>
drivers/net/wireless/ath/ar9170/main.c
drivers/net/wireless/ath/ar9170/phy.c
drivers/net/wireless/zd1211rw/zd_rf_rf2959.c
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
It is unnecessary, once we are always in interrupt context.
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-2.6
After we made debugobjects working again, we got the following:
WARNING: at lib/debugobjects.c:262 debug_print_object+0x8e/0xb0()
Hardware name: System Product Name
ODEBUG: free active (active state 0) object type: timer_list hint: hci_cmd_timer+0x0/0x60
Pid: 2125, comm: dmsetup Tainted: G W 2.6.38-06707-gc62b389 #110375
Call Trace:
[<ffffffff8104700a>] warn_slowpath_common+0x7a/0xb0
[<ffffffff810470b6>] warn_slowpath_fmt+0x46/0x50
[<ffffffff812d3a5e>] debug_print_object+0x8e/0xb0
[<ffffffff81bd8810>] ? hci_cmd_timer+0x0/0x60
[<ffffffff812d4685>] debug_check_no_obj_freed+0x125/0x230
[<ffffffff810f1063>] ? check_object+0xb3/0x2b0
[<ffffffff810f3630>] kfree+0x150/0x190
[<ffffffff81be4d06>] ? bt_host_release+0x16/0x20
[<ffffffff81be4d06>] bt_host_release+0x16/0x20
[<ffffffff813a1907>] device_release+0x27/0xa0
[<ffffffff812c519c>] kobject_release+0x4c/0xa0
[<ffffffff812c5150>] ? kobject_release+0x0/0xa0
[<ffffffff812c61f6>] kref_put+0x36/0x70
[<ffffffff812c4d37>] kobject_put+0x27/0x60
[<ffffffff813a21f7>] put_device+0x17/0x20
[<ffffffff81bda4f9>] hci_free_dev+0x29/0x30
[<ffffffff81928be6>] vhci_release+0x36/0x70
[<ffffffff810fb366>] fput+0xd6/0x1f0
[<ffffffff810f8fe6>] filp_close+0x66/0x90
[<ffffffff810f90a9>] sys_close+0x99/0xf0
[<ffffffff81d4c96b>] system_call_fastpath+0x16/0x1b
That timer was introduced with commit 6bd32326cda(Bluetooth: Use
Timer seems to be running when the thing is closed. Removing the timer
unconditionally fixes the problem. And yes, it needs to be fixed
before the HCI_UP check.
Tested-by: Ingo Molnar <mingo@elte.hu>
We can't send new commands before a cmd_complete for the HCI_RESET command
shows up.
Reported-by: Mikko Vinni <mmvinni@yahoo.com>
Reported-by: Justin P. Mattock <justinmattock@gmail.com>
Reported-by: Ed Tomlinson <edt@aei.ca>
Tested-by: Justin P. Mattock <justinmattock@gmail.com>
Tested-by: Mikko Vinni <mmvinni@yahoo.com>
Tested-by: Ed Tomlinson <edt@aei.ca>
This patch adds commands to add and remove remote OOB data to the managment
interface. Remote data is stored in kernel and can be used by corresponding
HCI commands and events when needed.
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
hci_notify() doesn't need declaration first.
Call Trace:
shows up.
Use proper timer instead of hci command flow control to timeout
failed hci commands. Otherwise stack ends up sending commands
when flow control is used to block new commands.
2010-09-01 18:29:41.592132 < HCI Command: Remote Name Request (0x01|0x0019) plen 10
bdaddr 00:16:CF:E1:C7:D7 mode 2 clkoffset 0x0000
2010-09-01 18:29:41.592681 > HCI Event: Command Status (0x0f) plen 4
Remote Name Request (0x01|0x0019) status 0x00 ncmd 0
2010-09-01 18:29:51.022033 < HCI Command: Remote Name Request Cancel (0x01|0x001a) plen 6
Signed-off-by: Ville Tervo <ville.tervo@nokia.com>
If the fail happens the HCI del_timer may timeout after the the hci dev
unregister. This lead to a kernel crash.
Reported-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Separate LE and ACL timeouts. Othervise ACL connections
on non LE hw will time out after 45 secs.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Bluetooth chips may have separate buffers for LE traffic.
This patch add support to use LE buffers provided by the chip.
Fix checkpatch warnings concerning assignments in if conditions.
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com>
This patch adds a new set_io_capability management command which is used
to set the IO capability for Secure Simple Pairing (SSP) as well as the
Security Manager Protocol (SMP). The value is per hci_dev and each
hci_conn object inherits it upon creation.
This patch adds a management commands to feed the kernel with all stored
link keys as well as remove specific ones or all of them. Once the
load_keys command has been called the kernel takes over link key
replies. A new_key event is also added to inform userspace of newly
created link keys that should be stored permanently.
