[ Upstream commit 92fe24a7db751b80925214ede43f8d2be792ea7b ]
Syzbot reported a corrupted list in kobject_add_internal [1]. This
happens when multiple HCI_EV_SYNC_CONN_COMPLETE event packets with
status 0 are sent for the same HCI connection. This causes us to
register the device more than once which corrupts the kset list.
As this is forbidden behavior, we add a check for whether we're
trying to process the same HCI_EV_SYNC_CONN_COMPLETE event multiple
times for one connection. If that's the case, the event is invalid, so
we report an error that the device is misbehaving, and ignore the
packet.
Link: https://syzkaller.appspot.com/bug?extid=66264bf2fd0476be7e6c [1]
Reported-by: syzbot+66264bf2fd0476be7e6c@syzkaller.appspotmail.com
Tested-by: syzbot+66264bf2fd0476be7e6c@syzkaller.appspotmail.com
Signed-off-by: Desmond Cheong Zhi Xi <desmondcheongzx@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 5c4c8c9544099bb9043a10a5318130a943e32fc3 upstream.
hci_chan can be created in 2 places: hci_loglink_complete_evt() if
it is an AMP hci_chan, or l2cap_conn_add() otherwise. In theory,
Only AMP hci_chan should be removed by a call to
hci_disconn_loglink_complete_evt(). However, the controller might mess
up, call that function, and destroy an hci_chan which is not initiated
by hci_loglink_complete_evt().
This patch adds a verification that the destroyed hci_chan must have
been init'd by hci_loglink_complete_evt().
Example crash call trace:
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xe3/0x144 lib/dump_stack.c:118
print_address_description+0x67/0x22a mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report mm/kasan/report.c:412 [inline]
kasan_report+0x251/0x28f mm/kasan/report.c:396
hci_send_acl+0x3b/0x56e net/bluetooth/hci_core.c:4072
l2cap_send_cmd+0x5af/0x5c2 net/bluetooth/l2cap_core.c:877
l2cap_send_move_chan_cfm_icid+0x8e/0xb1 net/bluetooth/l2cap_core.c:4661
l2cap_move_fail net/bluetooth/l2cap_core.c:5146 [inline]
l2cap_move_channel_rsp net/bluetooth/l2cap_core.c:5185 [inline]
l2cap_bredr_sig_cmd net/bluetooth/l2cap_core.c:5464 [inline]
l2cap_sig_channel net/bluetooth/l2cap_core.c:5799 [inline]
l2cap_recv_frame+0x1d12/0x51aa net/bluetooth/l2cap_core.c:7023
l2cap_recv_acldata+0x2ea/0x693 net/bluetooth/l2cap_core.c:7596
hci_acldata_packet net/bluetooth/hci_core.c:4606 [inline]
hci_rx_work+0x2bd/0x45e net/bluetooth/hci_core.c:4796
process_one_work+0x6f8/0xb50 kernel/workqueue.c:2175
worker_thread+0x4fc/0x670 kernel/workqueue.c:2321
kthread+0x2f0/0x304 kernel/kthread.c:253
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:415
Allocated by task 38:
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0x8d/0x9a mm/kasan/kasan.c:553
kmem_cache_alloc_trace+0x102/0x129 mm/slub.c:2787
kmalloc include/linux/slab.h:515 [inline]
kzalloc include/linux/slab.h:709 [inline]
hci_chan_create+0x86/0x26d net/bluetooth/hci_conn.c:1674
l2cap_conn_add.part.0+0x1c/0x814 net/bluetooth/l2cap_core.c:7062
l2cap_conn_add net/bluetooth/l2cap_core.c:7059 [inline]
l2cap_connect_cfm+0x134/0x852 net/bluetooth/l2cap_core.c:7381
hci_connect_cfm+0x9d/0x122 include/net/bluetooth/hci_core.h:1404
hci_remote_ext_features_evt net/bluetooth/hci_event.c:4161 [inline]
hci_event_packet+0x463f/0x72fa net/bluetooth/hci_event.c:5981
hci_rx_work+0x197/0x45e net/bluetooth/hci_core.c:4791
Freed by task 1732:
__kasan_slab_free mm/kasan/kasan.c:521 [inline]
__kasan_slab_free+0x106/0x128 mm/kasan/kasan.c:493
slab_free_hook mm/slub.c:1409 [inline]
slab_free_freelist_hook+0xaa/0xf6 mm/slub.c:1436
slab_free mm/slub.c:3009 [inline]
kfree+0x182/0x21e mm/slub.c:3972
hci_disconn_loglink_complete_evt net/bluetooth/hci_event.c:4891 [inline]
hci_event_packet+0x6a1c/0x72fa net/bluetooth/hci_event.c:6050
The buggy address belongs to the object at ffff8881d7af9180
which belongs to the cache kmalloc-128 of size 128
The buggy address is located 24 bytes inside of
128-byte region [ffff8881d7af9180, ffff8881d7af9200)
The buggy address belongs to the page:
page:ffffea00075ebe40 count:1 mapcount:0 mapping:ffff8881da403200 index:0x0
flags: 0x8000000000000200(slab)
raw: 8000000000000200 dead000000000100 dead000000000200 ffff8881da403200
raw: 0000000000000000 0000000080150015 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8881d7af9080: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8881d7af9100: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
>ffff8881d7af9180: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881d7af9200: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8881d7af9280: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Signed-off-by: Archie Pusaka <apusaka@chromium.org>
Reported-by: syzbot+98228e7407314d2d4ba2@syzkaller.appspotmail.com
Reviewed-by: Alain Michaud <alainm@chromium.org>
Reviewed-by: Abhishek Pandit-Subedi <abhishekpandit@chromium.org>
Cc: George Kennedy <george.kennedy@oracle.com>
[ Upstream commit 6dfccd13db2ff2b709ef60a50163925d477549aa ]
AMP_MGR is getting derefernced in hci_phy_link_complete_evt(), when called
from hci_event_packet() and there is a possibility, that hcon->amp_mgr may
not be found when accessing after initialization of hcon.
- net/bluetooth/hci_event.c:4945
The bug seems to get triggered in this line:
bredr_hcon = hcon->amp_mgr->l2cap_conn->hcon;
Fix it by adding a NULL check for the hcon->amp_mgr before checking the ev-status.
Fixes: d5e911928bd8 ("Bluetooth: AMP: Process Physical Link Complete evt")
Reported-and-tested-by: syzbot+0bef568258653cff272f@syzkaller.appspotmail.com
Link: https://syzkaller.appspot.com/bug?extid=0bef568258653cff272f
Signed-off-by: Anmol Karn <anmol.karan123@gmail.com>
commit f7e0e8b2f1b0a09b527885babda3e912ba820798 upstream.
`num_reports` is not being properly checked. A malformed event packet with
a large `num_reports` number makes hci_le_direct_adv_report_evt() read out
of bounds. Fix it.
Cc: stable@vger.kernel.org
Fixes: 2f010b55884e ("Bluetooth: Add support for handling LE Direct Advertising Report events")
Reported-and-tested-by: syzbot+24ebd650e20bd263ca01@syzkaller.appspotmail.com
Link: https://syzkaller.appspot.com/bug?extid=24ebd650e20bd263ca01
Signed-off-by: Peilin Ye <yepeilin.cs@gmail.com>
commit 8746f135bb01872ff412d408ea1aa9ebd328c1f5 upstream.
E0 is not allowed with Level 4:
BLUETOOTH CORE SPECIFICATION Version 5.2 | Vol 3, Part C page 1319:
'128-bit equivalent strength for link and encryption keys
required using FIPS approved algorithms (E0 not allowed,
SAFER+ not allowed, and P-192 not allowed; encryption key
not shortened'
SC enabled:
> HCI Event: Read Remote Extended Features (0x23) plen 13
Status: Success (0x00)
Handle: 256
Page: 1/2
Features: 0x0b 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Secure Simple Pairing (Host Support)
LE Supported (Host)
Secure Connections (Host Support)
> HCI Event: Encryption Change (0x08) plen 4
Handle: 256
Encryption: Enabled with AES-CCM (0x02)
SC disabled:
Handle: 256
Page: 1/2
Features: 0x03 0x00 0x00 0x00 0x00 0x00 0x00 0x00
LE Supported (Host)
Handle: 256
Encryption: Enabled with E0 (0x01)
[May 8 20:23] Bluetooth: hci0: Invalid security: expect AES but E0 was used
< HCI Command: Disconnect (0x01|0x0006) plen 3
Handle: 256
Reason: Authentication Failure (0x05)
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
Cc: Hans-Christian Noren Egtvedt <hegtvedt@cisco.com>
commit 3ca44c16b0dcc764b641ee4ac226909f5c421aa3 upstream.
This makes hci_encrypt_cfm calls hci_connect_cfm in case the connection
state is BT_CONFIG so callers don't have to check the state.
commit a2ec905d1e160a33b2e210e45ad30445ef26ce0e upstream.
Fix kernel oops observed when an ext adv data is larger than 31 bytes.
This can be reproduced by setting up an advertiser with advertisement
larger than 31 bytes. The issue is not sensitive to the advertisement
content. In particular, this was reproduced with an advertisement of
229 bytes filled with 'A'. See stack trace below.
This is fixed by not catching ext_adv as legacy adv are only cached to
be able to concatenate a scanable adv with its scan response before
sending it up through mgmt.
With ext_adv, this is no longer necessary.
general protection fault: 0000 [#1] SMP PTI
CPU: 6 PID: 205 Comm: kworker/u17:0 Not tainted 5.4.0-37-generic #41-Ubuntu
Hardware name: Dell Inc. XPS 15 7590/0CF6RR, BIOS 1.7.0 05/11/2020
Workqueue: hci0 hci_rx_work [bluetooth]
RIP: 0010:hci_bdaddr_list_lookup+0x1e/0x40 [bluetooth]
Code: ff ff e9 26 ff ff ff 0f 1f 44 00 00 0f 1f 44 00 00 55 48 8b 07 48 89 e5 48 39 c7 75 0a eb 24 48 8b 00 48 39 f8 74 1c 44 8b 06 <44> 39 40 10 75 ef 44 0f b7 4e 04 66 44 39 48 14 75 e3 38 50 16 75
RSP: 0018:ffffbc6a40493c70 EFLAGS: 00010286
RAX: 4141414141414141 RBX: 000000000000001b RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffff9903e76c100f RDI: ffff9904289d4b28
RBP: ffffbc6a40493c70 R08: 0000000093570362 R09: 0000000000000000
R10: 0000000000000000 R11: ffff9904344eae38 R12: ffff9904289d4000
R13: 0000000000000000 R14: 00000000ffffffa3 R15: ffff9903e76c100f
FS: 0000000000000000(0000) GS:ffff990434580000(0000) knlGS:0000000000000000
CR2: 00007feed125a000 CR3: 00000001b860a003 CR4: 00000000003606e0
Call Trace:
process_adv_report+0x12e/0x560 [bluetooth]
hci_le_meta_evt+0x7b2/0xba0 [bluetooth]
hci_event_packet+0x1c29/0x2a90 [bluetooth]
hci_rx_work+0x19b/0x360 [bluetooth]
process_one_work+0x1eb/0x3b0
worker_thread+0x4d/0x400
kthread+0x104/0x140
Fixes: c215e9397b00 ("Bluetooth: Process extended ADV report event")
Reported-by: Andy Nguyen <theflow@google.com>
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Reported-by: Balakrishna Godavarthi <bgodavar@codeaurora.org>
Signed-off-by: Alain Michaud <alainm@chromium.org>
Tested-by: Sonny Sasaka <sonnysasaka@chromium.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
[ Upstream commit adf1d6926444029396861413aba8a0f2a805742a ]
After sending Inquiry Cancel command to the controller, it is possible
that Inquiry Complete event comes before Inquiry Cancel command complete
event. In this case the Inquiry Cancel command will have status of
Command Disallowed since there is no Inquiry session to be cancelled.
This case should not be treated as error, otherwise we can reach an
inconsistent state.
Example of a btmon trace when this happened:
< HCI Command: Inquiry Cancel (0x01|0x0002) plen 0
> HCI Event: Inquiry Complete (0x01) plen 1
> HCI Event: Command Complete (0x0e) plen 4
Inquiry Cancel (0x01|0x0002) ncmd 1
Status: Command Disallowed (0x0c)
Signed-off-by: Sonny Sasaka <sonnysasaka@chromium.org>
[ Upstream commit 08bb4da90150e2a225f35e0f642cdc463958d696 ]
Some controllers have been observed to send zero'd events under some
conditions. This change guards against this condition as well as adding
a trace to facilitate diagnosability of this condition.
commit 629b49c848ee71244203934347bd7730b0ddee8d upstream.
Check `num_rsp` before using it as for-loop counter. Add `unlock` label.
commit 75bbd2ea50ba1c5d9da878a17e92eac02fe0fd3a upstream.
commit 51c19bf3d5cfaa66571e4b88ba2a6f6295311101 upstream.
Check upon `num_rsp` is insufficient. A malformed event packet with a
large `num_rsp` number makes hci_extended_inquiry_result_evt() go out
of bounds. Fix it.
This patch fixes the following syzbot bug:
https://syzkaller.appspot.com/bug?id=4bf11aa05c4ca51ce0df86e500fce486552dc8d2
Reported-by: syzbot+d8489a79b781849b9c46@syzkaller.appspotmail.com
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
[ Upstream commit 56b5453a86203a44726f523b4133c1feca49ce7c ]
Bluetooth PTS test case HFP/AG/ACC/BI-12-I accepts SCO connection
with invalid parameter at the first SCO request expecting AG to
attempt another SCO request with the use of "safe settings" for
given codec, base on section 5.7.1.2 of HFP 1.7 specification.
This patch addresses it by adding "Invalid LMP Parameters" (0x1e)
to the SCO fallback case. Verified with below log:
< HCI Command: Setup Synchronous Connection (0x01|0x0028) plen 17
Handle: 256
Transmit bandwidth: 8000
Receive bandwidth: 8000
Max latency: 13
Setting: 0x0003
Input Coding: Linear
Input Data Format: 1's complement
Input Sample Size: 8-bit
# of bits padding at MSB: 0
Air Coding Format: Transparent Data
Retransmission effort: Optimize for link quality (0x02)
Packet type: 0x0380
3-EV3 may not be used
2-EV5 may not be used
3-EV5 may not be used
> HCI Event: Command Status (0x0f) plen 4
Setup Synchronous Connection (0x01|0x0028) ncmd 1
> HCI Event: Number of Completed Packets (0x13) plen 5
Num handles: 1
Handle: 256
Count: 1
> HCI Event: Max Slots Change (0x1b) plen 3
Handle: 256
Max slots: 1
> HCI Event: Synchronous Connect Complete (0x2c) plen 17
Status: Invalid LMP Parameters / Invalid LL Parameters (0x1e)
Handle: 0
Address: 00:1B:DC:F2:21:59 (OUI 00-1B-DC)
Link type: eSCO (0x02)
Transmission interval: 0x00
Retransmission window: 0x02
RX packet length: 0
TX packet length: 0
Air mode: Transparent (0x03)
Handle: 256
Max latency: 8
Setting: 0x0003
Packet type: 0x03c8
EV3 may be used
2-EV3 may not be used
Handle: 256
Max slots: 5
Handle: 256
Max slots: 1
Handle: 257
Transmission interval: 0x06
Retransmission window: 0x04
RX packet length: 30
TX packet length: 30
Signed-off-by: Hsin-Yu Chao <hychao@chromium.org>
[ Upstream commit 68d19d7d995759b96169da5aac313363f92a9075 ]
This reverts commit c49a8682fc5d298d44e8d911f4fa14690ea9485e.
There are devices which require low connection intervals for usable operation
including keyboards and mice. Forcing a static connection interval for
these types of devices has an impact in latency and causes a regression.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
[ Upstream commit c49a8682fc5d298d44e8d911f4fa14690ea9485e ]
Problem: The Linux Bluetooth stack yields complete control over the BLE
connection interval to the remote device.
The Linux Bluetooth stack provides access to the BLE connection interval
min and max values through /sys/kernel/debug/bluetooth/hci0/
conn_min_interval and /sys/kernel/debug/bluetooth/hci0/conn_max_interval.
These values are used for initial BLE connections, but the remote device
has the ability to request a connection parameter update. In the event
that the remote side requests to change the connection interval, the Linux
kernel currently only validates that the desired value is within the
acceptable range in the Bluetooth specification (6 - 3200, corresponding to
7.5ms - 4000ms). There is currently no validation that the desired value
requested by the remote device is within the min/max limits specified in
the conn_min_interval/conn_max_interval configurations. This essentially
leads to Linux yielding complete control over the connection interval to
the remote device.
The proposed patch adds a verification step to the connection parameter
update mechanism, ensuring that the desired value is within the min/max
bounds of the current connection. If the desired value is outside of the
current connection min/max values, then the connection parameter update
request is rejected and the negative response is returned to the remote
device. Recall that the initial connection is established using the local
conn_min_interval/conn_max_interval values, so this allows the Linux
administrator to retain control over the BLE connection interval.
The one downside that I see is that the current default Linux values for
conn_min_interval and conn_max_interval typically correspond to 30ms and
50ms respectively. If this change were accepted, then it is feasible that
some devices would no longer be able to negotiate to their desired
connection interval values. This might be remedied by setting the default
Linux conn_min_interval and conn_max_interval values to the widest
supported range (6 - 3200 / 7.5ms - 4000ms). This could lead to the same
behavior as the current implementation, where the remote device could
request to change the connection interval value to any value that is
permitted by the Bluetooth specification, and Linux would accept the
desired value.
Signed-off-by: Carey Sonsino <csonsino@gmail.com>
[ Upstream commit 1629db9c75342325868243d6bca5853017d91cf8 ]
In case a command which completes in Command Status was sent using the
hci_cmd_send-family of APIs there would be a misleading error in the
hci_get_cmd_complete function, since the code would be trying to fetch
the Command Complete parameters when there are none.
Avoid the misleading error and silently bail out from the function in
case the received event is a command status.
Acked-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
commit 082f2300cfa1a3d9d5221c38c5eba85d4ab98bd8 upstream.
Local random address needs to be updated before creating connection if
RPA from LE Direct Advertising Report was resolved in host. Otherwise
remote device might ignore connection request due to address mismatch.
This was affecting following qualification test cases:
GAP/CONN/SCEP/BV-03-C, GAP/CONN/GCEP/BV-05-C, GAP/CONN/DCEP/BV-05-C
Before patch:
< HCI Command: LE Set Random Address (0x08|0x0005) plen 6 #11350 [hci0] 84680.231216
Address: 56:BC:E8:24:11:68 (Resolvable)
Identity type: Random (0x01)
Identity: F2:F1:06:3D:9C:42 (Static)
> HCI Event: Command Complete (0x0e) plen 4 #11351 [hci0] 84680.246022
LE Set Random Address (0x08|0x0005) ncmd 1
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #11352 [hci0] 84680.246417
Type: Passive (0x00)
Interval: 60.000 msec (0x0060)
Window: 30.000 msec (0x0030)
Own address type: Random (0x01)
Filter policy: Accept all advertisement, inc. directed unresolved RPA (0x02)
> HCI Event: Command Complete (0x0e) plen 4 #11353 [hci0] 84680.248854
LE Set Scan Parameters (0x08|0x000b) ncmd 1
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #11354 [hci0] 84680.249466
Scanning: Enabled (0x01)
Filter duplicates: Enabled (0x01)
> HCI Event: Command Complete (0x0e) plen 4 #11355 [hci0] 84680.253222
LE Set Scan Enable (0x08|0x000c) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 18 #11356 [hci0] 84680.458387
LE Direct Advertising Report (0x0b)
Num reports: 1
Event type: Connectable directed - ADV_DIRECT_IND (0x01)
Address type: Random (0x01)
Address: 53:38:DA:46:8C:45 (Resolvable)
Identity type: Public (0x00)
Identity: 11:22:33:44:55:66 (OUI 11-22-33)
Direct address type: Random (0x01)
Direct address: 7C:D6:76:8C:DF:82 (Resolvable)
RSSI: -74 dBm (0xb6)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #11357 [hci0] 84680.458737
Scanning: Disabled (0x00)
Filter duplicates: Disabled (0x00)
> HCI Event: Command Complete (0x0e) plen 4 #11358 [hci0] 84680.469982
< HCI Command: LE Create Connection (0x08|0x000d) plen 25 #11359 [hci0] 84680.470444
Scan interval: 60.000 msec (0x0060)
Scan window: 60.000 msec (0x0060)
Filter policy: White list is not used (0x00)
Peer address type: Random (0x01)
Peer address: 53:38:DA:46:8C:45 (Resolvable)
Min connection interval: 30.00 msec (0x0018)
Max connection interval: 50.00 msec (0x0028)
Connection latency: 0 (0x0000)
Supervision timeout: 420 msec (0x002a)
Min connection length: 0.000 msec (0x0000)
Max connection length: 0.000 msec (0x0000)
> HCI Event: Command Status (0x0f) plen 4 #11360 [hci0] 84680.474971
LE Create Connection (0x08|0x000d) ncmd 1
< HCI Command: LE Create Connection Cancel (0x08|0x000e) plen 0 #11361 [hci0] 84682.545385
> HCI Event: Command Complete (0x0e) plen 4 #11362 [hci0] 84682.551014
LE Create Connection Cancel (0x08|0x000e) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 19 #11363 [hci0] 84682.551074
LE Connection Complete (0x01)
Status: Unknown Connection Identifier (0x02)
Handle: 0
Role: Master (0x00)
Peer address type: Public (0x00)
Peer address: 00:00:00:00:00:00 (OUI 00-00-00)
Connection interval: 0.00 msec (0x0000)
Supervision timeout: 0 msec (0x0000)
Master clock accuracy: 0x00
After patch:
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #210 [hci0] 667.152459
> HCI Event: Command Complete (0x0e) plen 4 #211 [hci0] 667.153613
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #212 [hci0] 667.153704
> HCI Event: Command Complete (0x0e) plen 4 #213 [hci0] 667.154584
> HCI Event: LE Meta Event (0x3e) plen 18 #214 [hci0] 667.182619
Num reports: 1
Address: 50:52:D9:A6:48:A0 (Resolvable)
Direct address: 7C:C1:57:A5:B7:A8 (Resolvable)
Identity: F4:28:73:5D:38:B0 (Static)
RSSI: -70 dBm (0xba)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #215 [hci0] 667.182704
> HCI Event: Command Complete (0x0e) plen 4 #216 [hci0] 667.183599
< HCI Command: LE Set Random Address (0x08|0x0005) plen 6 #217 [hci0] 667.183645
Address: 7C:C1:57:A5:B7:A8 (Resolvable)
> HCI Event: Command Complete (0x0e) plen 4 #218 [hci0] 667.184590
< HCI Command: LE Create Connection (0x08|0x000d) plen 25 #219 [hci0] 667.184613
Peer address: 50:52:D9:A6:48:A0 (Resolvable)
> HCI Event: Command Status (0x0f) plen 4 #220 [hci0] 667.186558
> HCI Event: LE Meta Event (0x3e) plen 19 #221 [hci0] 667.485824
Handle: 0
Role: Master (0x00)
Connection interval: 50.00 msec (0x0028)
Master clock accuracy: 0x07
@ MGMT Event: Device Connected (0x000b) plen 13 {0x0002} [hci0] 667.485996
LE Address: 11:22:33:44:55:66 (OUI 11-22-33)
Flags: 0x00000000
Data length: 0
Signed-off-by: Szymon Janc <szymon.janc@codecoup.pl>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
The SKB context buffer for HCI request is really not just for requests,
information in their are preserved for the whole HCI layer. So it makes
more sense to actually rename it into bt_cb()->hci and also call it then
struct hci_ctrl.
In addition that allows moving the decoded opcode for outgoing packets
into that struct. So far it was just consuming valuable space from the
main shared items. And opcode are not valid for L2CAP packets.
Use the new hci_conn_hash_lookup_le() API to look up LE connections.
This way we're guaranteed exact matches that also take into account
the address type.
drivers/net/usb/asix_common.c
net/ipv4/inet_connection_sock.c
net/switchdev/switchdev.c
In the inet_connection_sock.c case the request socket hashing scheme
is completely different in net-next.
The other two conflicts were overlapping changes.
We can't use hci_explicit_connect_lookup() since that would only cover
explicit connections, leaving normal reconnections completely
untouched. Not using it in turn means leaving out entries in
pend_le_reports.
To fix this and simplify the logic move conn params from the reports
list to the pend_le_conns list for the duration of an explicit
connect. Once the connect is complete move the params back to the
pend_le_reports list. This also means that the explicit connect lookup
function only needs to look into the pend_le_conns list.
When disable/enable scan command is issued twice, some controllers
will return an error for the second request, i.e. requests with this
command will fail on some controllers, and succeed on others.
This patch makes sure that unnecessary scan disable/enable commands
are not issued.
When adding device to the auto connect whitelist when there is pending
connect attempt, there is no need to update scan.
hci_connect_le_scan_cleanup is conditionally executing
hci_conn_params_del, that is calling hci_update_background_scan. Make
the other case also update scan, and remove reduntand call from
hci_connect_le_scan_remove.
When stopping interleaved discovery the state should be set to stopped
only when both LE scanning and discovery has stopped.
Signed-off-by: Jakub Pawlowski <jpawlowski@google.com>
Acked-by: Johan Hedberg <johan.hedberg@intel.com>
Some remote devices (ie Gigaset G-Tag) misbehave with ADV data length.
This can lead to incorrect EIR format in device found event when
ADV_DATA and SCAN_RSP are merged (terminator field before SCAN_RSP
part).
Fix this by inspecting ADV_DATA and correct its length if terminator
is found.
> HCI Event: LE Meta Event (0x3e) plen 42 [hci0] 32.172182
LE Advertising Report (0x02)
Num reports: 1
Event type: Connectable undirected - ADV_IND (0x00)
Address type: Public (0x00)
Address: 7C:2F:80:94:97:5A (Gigaset Communications GmbH)
Data length: 30
Flags: 0x06
LE General Discoverable Mode
BR/EDR Not Supported
Company: Gigaset Communications GmbH (384)
Data: 021512348094975abbc5
16-bit Service UUIDs (partial): 1 entry
Battery Service (0x180f)
RSSI: -65 dBm (0xbf)
> HCI Event: LE Meta Event (0x3e) plen 27 [hci0] 32.172191
Num reports: 1
Event type: Scan response - SCAN_RSP (0x04)
Data length: 15
Name (complete): Gigaset G-tag
RSSI: -59 dBm (0xc5)
Note "Data length: 30" in ADV_DATA which results in 9 extra zero bytes
after Battery Service UUID. Terminator field present in the middle of
EIR in Device Found event resulted in userspace stop parsing EIR and
skipping device name.
@ Device Found: 7C:2F:80:94:97:5A (1) rssi -59 flags 0x0000
02 01 06 0d ff 80 01 02 15 12 34 80 94 97 5a bb ..........4...Z.
c5 03 02 0f 18 00 00 00 00 00 00 00 00 00 0e 09 ................
47 69 67 61 73 65 74 20 47 2d 74 61 67 Gigaset G-tag
With this fix EIR with merged ADV_DATA and SCAN_RSP in device found
event is properly formatted:
c5 03 02 0f 18 0e 09 47 69 67 61 73 65 74 20 47 .......Gigaset G
2d 74 61 67 -tag
Signed-off-by: Szymon Janc <ext.szymon.janc@tieto.com>
Synchronous connections are initially created with type eSCO.
Link manager may reject proposed link parameters, which triggers
connection setup retry with a different set. Link type embedded
in responses should be disregarded until Synchronous Connect Complete
returns Success (0x00). Current code updates link type every time
which creates an issue when link type changes to SCO and back to eSCO
on further attepts.
Issue happens with BlackBerry 9100 and 9700 with Intel WilkinsPeak
on third connection setup attept
2015-05-18 01:27:57.332242 < HCI Command: Setup Synchronous Connection (0x01|0x0028) plen 17
handle 256 voice setting 0x0060 ptype 0x0380
2015-05-18 01:27:57.333604 > HCI Event: Command Status (0x0f) plen 4
Setup Synchronous Connection (0x01|0x0028) status 0x00 ncmd 1
2015-05-18 01:27:57.334614 > HCI Event: Synchronous Connect Complete (0x2c) plen 17
status 0x1a handle 0 bdaddr 30:7C:30:B3:A8:86 type SCO
Error: Unsupported Remote Feature / Unsupported LMP Feature
2015-05-18 01:27:57.334895 < HCI Command: Setup Synchronous Connection (0x01|0x0028) plen 17
2015-05-18 01:27:57.335601 > HCI Event: Command Status (0x0f) plen 4
2015-05-18 01:27:57.336610 > HCI Event: Synchronous Connect Complete (0x2c) plen 17
2015-05-18 01:27:57.336685 < HCI Command: Setup Synchronous Connection (0x01|0x0028) plen 17
handle 256 voice setting 0x0060 ptype 0x03c8
2015-05-18 01:27:57.337603 > HCI Event: Command Status (0x0f) plen 4
2015-05-18 01:27:57.342608 > HCI Event: Max Slots Change (0x1b) plen 3
handle 256 slots 1
2015-05-18 01:27:57.377631 > HCI Event: Synchronous Connect Complete (0x2c) plen 17
status 0x00 handle 257 bdaddr 30:7C:30:B3:A8:86 type eSCO
Air mode: CVSD
Signed-off-by: Kuba Pawlak <kubax.t.pawlak@intel.com>
Currently, when trying to connect to already paired device that just
rotated its RPA MAC address, old address would be used and connection
would fail. In order to fix that, kernel must scan and receive
advertisement with fresh RPA before connecting.
This path makes sure that after advertisement is received from device that
we try to connect to, it is properly handled in check_pending_le_conn and
trigger connect attempt.
It also modifies hci_le_connect to make sure that connect attempt will be
properly continued.
This patch adds hci_lookup_le_connect method, that will be used to check
wether outgoing le connection attempt is in progress.
To avoid amp module hooks from hci_event.c
Signed-off-by: Arron Wang <arron.wang@intel.com>
To avoid a2mp module hooks from hci_event.c and send
getinfo response operation only required by a2mp module,
we can move this callback to a2mp.c
The encryption key size is read only for BR/EDR (ACL_LINK) connections
so there's no need to check for it in the read_enc_key_size_complete()
callback.
Since Bluetooth 3.0 there's a HCI command available for reading the
encryption key size of an BR/EDR connection. This information is
essential e.g. for generating an LTK using SMP over BR/EDR, so store
it as part of struct hci_conn.
Checking for SC-only mode requirements when we get an encrypt change
event shouldn't be limited to the BT_CONFIG state but done any time
encryption changes.
The encryption key size for LTKs is supposed to be applied only at the
moment of encryption. When generating a Link Key (using LE SC) from
the LTK the full non-shortened value should be used. This patch
modifies the code to always keep the full value around and only apply
the key size when passing the value to HCI.
When establishing a Bluetooth LE connection, read the remote used
features mask to determine which features are supported. This was
not really needed with Bluetooth 4.0, but since Bluetooth 4.1 and
also 4.2 have introduced new optional features, this becomes more
important.
This works the same as with BR/EDR where the connection enters the
BT_CONFIG stage and hci_connect_cfm call is delayed until the remote
features have been retrieved. Only after successfully receiving the
remote features, the connection enters the BT_CONNECTED state.
Now that there's a HCI request API available where the callback receives
the resulting skb, we can convert the local OOB data reading to use this
new API. This patch does the necessary update in mgmt.c (which also
requires moving the callback higher up since it's now a static function)
and removes the custom calls from hci_event.c that are no-longer
necessary.
To make the hci_req_run_skb() API consistent with hci_cmd_sync_ev()
the callback should receive the cmd_complete parameters in the 'normal'
case and the full HCI event if a special event was expected. This patch
moves the hci_get_cmd_complete() function from hci_core.c to hci_event.c
where it's used to strip the skb from the needed headers before passing
it on to the callback.
Now that the synchronous HCI requests use the new API and a new private
variable the recv_evt member of hci_dev is no-longer needed. This patch
removes it.
This patch adds a second possible callback for HCI requests where the
callback will receive the full skb of the last successfully completed
HCI command. This API is useful for cases where we want to use a request
to read some data and the existing hci_event.c handlers do not store it
e.g. in the hci_dev struct.
The reason the patch is a bit bigger than just adding the new API is
because the hci_req_cmd_complete() functions required some refactoring
to enable it: now hci_req_cmd_complete() is simply used to request the
callback pointers if any, and the actual calling of them happens from a
single place at the end of hci_event_packet(). The reason for this is
that we need to pass the original skb (without any skb_pull, etc
modifications done to it) and it's simplest to keep track of it within
the hci_event_packet() function.
When dealing with HCI command status events, the reasoning for trying to
mark a request as complete if no specific event is being waited for and
status was success is not self-evident. This patch adds a clarifying
comment above the if-statement.
In order to shrink the size of bt_skb_cb, this patch moves the HCI
request related variables into their own req_ctrl struct. Additionall
the L2CAP and HCI request structs are placed inside the same union since
they will never be used at the same time for the same skb.
During the HCI init phase a completed request might be the last part of
the setup procedure after which the actual init procedure starts. The
init procedure begins with a call to hci_reset_req() which sets the
HCI_RESET flag. The purpose of this flag is to make us ignore any
updates to ncmd/cmd_cnt as long as we haven't received the command
complete event for the HCI_Reset. There's a potential race with this
however:
hci_req_cmd_complete(hdev, opcode, status);
if (ev->ncmd && !test_bit(HCI_RESET, &hdev->flags)) {
atomic_set(&hdev->cmd_cnt, 1);
if (!skb_queue_empty(&hdev->cmd_q))
queue_work(hdev->workqueue, &hdev->cmd_work);
Since the hci_req_cmd_complete() will trigger the completion of the
setup stage, it's possible that hci_reset_req() gets called before we
try to read ev->ncmd and the HCI_RESET flag. Because of this the cmd_cnt
would never be updated and the hci_reset_req() in practice ends up
blocking itself.
This patch fixes the issue by updating cmd_cnt before notifying the
request completion, and then reading it again to determine whether the
cmd_work should be queued or not.
When doing scan through mgmt api, some controllers can do both le and
classic scan at same time. They can be distinguished by
HCI_QUIRK_SIMULTANEOUS_DISCOVERY set.
This patch enables them to use this feature when doing dual mode scan.
Instead of doing le, then classic scan, both scans are run at once.
The HCI_CONN_REMOTE_OOB connection flag is used to indicate if the
pairing initiator has provided out-of-band data. However since that
value is no longer used in any decision making, just remove it.
It is actually unclear what purpose the OOB data present field from
the HCI IO Capability Response event serves in the first place. If
either side provided out-of-band data, then that data will be used
for pairing.
When only the pairing initiator is providing out-of-band data, then
the receiver side was ignoring the data. For some reason the code was
checking if the initiator has received out-of-band data and only then
also provide the required inidication that the acceptor actually has
the needed data available.
For BR/EDR out-of-band pairing it is enough if one side has received
out-of-band data. There are no extra checks needed here to make this
work smoothly. The only thing that is needed is to tell the controller
if data is present (and if it is P-192 or P-256 or both) and then let
the controller actually figure out the rest.
This means the check for outgoing connection or if the initiator has
indicated data are completely pointless and are in fact actually
causing harm. The check in question is this one:
if (conn->out || test_bit(HCI_CONN_REMOTE_OOB, &conn->flags)) {
After just taking the conditional check out and always executing the
code for determining the type of out-of-band data, the pairing works
flawlessly and prodcudes authenticated link keys.
The patch itself looks more complicated due to the reformatting of the
indentation, but it essentially just a two-line change.
The hdev->dev_flags field has outgrown itself on 32-bit systems. So
instead of hacking around it, switch to using DECLARE_BITMAP.
Instead of manually coding test_and_clear_bit on hdev->dev_flags all the
time, use hci_dev_test_and_clear_flag helper macro.
Instead of manually coding clear_bit on hdev->dev_flags all the time,
use hci_dev_clear_flag helper macro.
Instead of manually coding set_bit on hdev->dev_flags all the time,
use hci_dev_set_flag helper macro.
