Fragmented skbs are only encountered when receiving ERTM or streaming
mode L2CAP data. BNEP, CMTP, HIDP, and RFCOMM generally use basic
mode, but they need to handle fragments without crashing.
Signed-off-by: Mat Martineau <mathewm@codeaurora.org>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
During setup the host initializes all HID reports. Some devices do not
support this. If this quirk is set, we skip the initialization.
See also usbhid_init_reports() for this quirk.
Signed-off-by: David Herrmann <dh.herrmann@googlemail.com>
When an hidp connection is added for a boot protocol input
device, don't release a device reference that was never
acquired. The device reference is acquired when the session
is linked to the session list (which hasn't happened yet when
hidp_setup_input is called).
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
device, only free the allocated device if device registration fails.
Subsequent failures should only unregister the device (the input
device api documents that unregister will also free the allocated
device).
Free the cached HID report descriptor on thread terminate.
Once the session thread is running, cleanup must be
handled by the session thread only.
Partial revert of commit aabf6f89. When the hidp session thread
was converted from kernel_thread to kthread, the atomic/wakeups
were replaced with kthread_stop. kthread_stop has blocking semantics
which are inappropriate for the hidp session kthread. In addition,
the kthread signals itself to terminate in hidp_process_hid_control()
- it cannot do this with kthread_stop().
Lastly, a wakeup can be lost if the wakeup happens between checking
for the loop exit condition and setting the current state to
TASK_INTERRUPTIBLE. (Without appropriate synchronization mechanisms,
the task state should not be changed between the condition test and
the yield - via schedule() - as this creates a race between the
wakeup and resetting the state back to interruptible.)
In this commit, omtu, imtu, flush_to, mode and sport. It also remove the
pi var from l2cap_sock_sendmsg().
kernel_thread() is a low-level implementation detail and
EXPORT_SYMBOL(kernel_thread) is scheduled for removal.
Use the <linux/kthread.h> API instead.
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (48 commits)
HID: add support for Logitech Driving Force Pro wheel
HID: hid-ortek: remove spurious reference
HID: add support for Ortek PKB-1700
HID: roccat-koneplus: vorrect mode of sysfs attr 'sensor'
HID: hid-ntrig: init settle and mode check
HID: merge hid-egalax into hid-multitouch
HID: hid-multitouch: Send events per slot if CONTACTCOUNT is missing
HID: ntrig remove if and drop an indent
HID: ACRUX - activate the device immediately after binding
HID: ntrig: apply NO_INIT_REPORTS quirk
HID: hid-magicmouse: Correct touch orientation direction
HID: ntrig don't dereference unclaimed hidinput
HID: Do not create input devices for feature reports
HID: bt hidp: send Output reports using SET_REPORT on the Control channel
HID: hid-sony.c: Fix sending Output reports to the Sixaxis
HID: add support for Keytouch IEC 60945
HID: Add HID Report Descriptor to sysfs
HID: add IRTOUCH infrared USB to hid_have_special_driver
HID: kernel oops in out_cleanup in function hidinput_connect
HID: Add teletext/color keys - gyration remote - EU version (GYAR3101CKDE)
'roccat', 'upstream' and 'upstream-fixes' into for-linus
The current implementation of hidp_output_raw_report() relies only on
the Control channel even for Output reports, and the BT HID
specification [1] does not mention using the DATA message for Output
reports on the Control channel (see section 7.9.1 and also Figure 11:
SET_ Flow Chart), so let us just use SET_REPORT.
This also fixes sending Output reports to some devices (like Sony
Sixaxis) which are not able to handle DATA messages on the Control
channel.
Ideally hidp_output_raw_report() could be improved to use this scheme:
Feature Report -- SET_REPORT on the Control channel
Output Report -- DATA on the Interrupt channel
for more efficiency, but as said above, right now only the Control
channel is used.
[1] http://www.bluetooth.com/Specification%20Documents/HID_SPEC_V10.pdf
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi>
l2cap_load() was added to trigger l2cap.ko module loading from the RFCOMM
and BNEP modules. Now that L2CAP module is gone, we don't need it anymore.
This patch adds support or getting and setting feature reports for bluetooth
HID devices from HIDRAW.
Signed-off-by: Alan Ott <alan@signal11.us>
Wait for an ACK from the device before returning from
hidp_output_raw_report(). This way, failures can be returned to the user
application. Also, it prevents ACK/NAK packets from an output packet from
being confused with ACK/NAK packets from an input request packet.
Move the call to hid_add_device() (which calls a device's probe() function)
to after the kernel_thread() call which starts the hidp_session() thread.
This ensures the Bluetooth receive socket is fully running by the time a
device's probe() function is called. This way, a device can communicate
(send and receive) with the Bluetooth device from its probe() function.
Fix checkpatch warnings concerning assignments in if conditions.
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com>
Structure hidp_conninfo is copied to userland with version, product,
vendor and name fields unitialized if both session->input and session->hid
are NULL. It leads to leaking of contents of kernel stack memory.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
The Bluetooth core uses the the BD_ADDR in the opposite order from the
human readable order. So we are changing batostr() to print in the
correct order and then removing some baswap(), as they are not needed
anymore.
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (41 commits)
HID: usbhid: initialize interface pointers early enough
HID: extend mask for BUTTON usage page
HID: hid-ntrig: Single touch mode tap
HID: hid-ntrig: multitouch cleanup and fix
HID: n-trig: remove unnecessary tool switching
HID: hid-ntrig add multi input quirk and clean up
HID: usbhid: introduce timeout for stuck ctrl/out URBs
HID: magicmouse: coding style and probe failure fixes
HID: remove MODULE_VERSION from new drivers
HID: fix up Kconfig entry for MagicMouse
HID: add a device driver for the Apple Magic Mouse.
HID: Export hid_register_report
HID: Support for MosArt multitouch panel
HID: add pressure support for the Stantum multitouch panel
HID: fixed bug in single-touch emulation on the stantum panel
HID: fix typo in error message
HID: add mapping for "AL Network Chat" usage
HID: use multi input quirk for TouchPack touchscreen
HID: make full-fledged hid-bus drivers properly selectable
HID: make Wacom modesetting failures non-fatal
The report descriptor is read by user space (via the Service
Discovery Protocol), so it is only available during the ioctl
to connect. However, the HID probe function that needs the
descriptor might not be called until a specific module is
loaded. Keep a copy of the descriptor so it is available for
later use.
Signed-off-by: Michael Poole <mdpoole@troilus.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
In commit 2da31939a42 ("Bluetooth: Implement raw output support for HIDP
layer"), support for Bluetooth hid_output_raw_report was added, but it
pushes the data to the intr socket instead of the ctrl one. This has been
fixed by 6bf8268f9a91f1 ("Bluetooth: Use the control channel for raw HID reports")
Still, it is necessary to distinguish whether the report in question should be
either FEATURE or OUTPUT. For this, we have to extend the generic HID API,
so that hid_output_raw_report() callback provides means to specify this
value so that it can be passed down to lower level hardware drivers (currently
Bluetooth and USB).
Based on original patch by Bastien Nocera <hadess@hadess.net>
In commit 2da31939a42f7a676a0bc5155d6a0a39ed8451f2, support
for Bluetooth hid_output_raw_report was added, but it pushes
the data to the interrupt channel instead of the contol one.
This patch makes hid_output_raw_report use the control channel
instead. Using the interrupt channel was a mistake.
Signed-off-by: Bastien Nocera <hadess@hadess.net>
Return the PTR_ERR of the correct pointer.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Implement raw output callback which is used by hidraw to send raw data to
the underlying device.
Without this patch, the userspace hidraw-based applications can't send
output reports to HID Bluetooth devices.
Reported-and-tested-by: Brian Gunn <bgunn@solekai.com>
HID core registers input, hidraw and hiddev devices, but leaves
unregistering it up to the individual driver, which is not really nice.
Let's move all the logic to the core.
Reported-by: Marcel Holtmann <marcel@holtmann.org>
Reported-by: Brian Rogers <brian@xyzw.org>
The core exports the hci_conn_hold_device() and hci_conn_put_device()
functions for device reference of connections. Use this to ensure that
the uevents from the parent are send after the child ones.
Based on a report by Brian Rogers <brian@xyzw.org>
Currently the HID subsystem will create HIDRAW devices for the transport
driver, but it will not disconnect them. Until the HID subsytem gets
fixed, ensure that HIDRAW and HIDDEV devices are disconnected when the
Bluetooth HID device gets removed.
Based on a patch from Brian Rogers <brian@xyzw.org>
There is a test case in PTS tool; PTS will send the VIRTUAL_CABLE_UNPLUG
command to IUT. Then IUT should disconnect the channel and kill the HID
session when it receives the command. The VIRTUAL_CABLE_UNPLUG command
is parsed by HID transport, but it is not scheduled to do so. Add a
call to hidp_schedule() to kill the session.
Signed-off-by: Jothikumar Mothilal <jothikumar.mothilal@atheros.com>
With the introduction of CONFIG_DYNAMIC_PRINTK_DEBUG it is possible to
allow debugging without having to recompile the kernel. This patch turns
all BT_DBG() calls into pr_debug() to support dynamic debug messages.
As a side effect all CONFIG_BT_*_DEBUG statements are now removed and
some broken debug entries have been fixed.
Move connecting from usbhid to the hid layer and fix also hidp in
that manner.
This removes all the ignore/force hidinput/hiddev connecting quirks.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Move them from the core code to a separate driver.
Move ignore quirks from usbhid-quirks into hid-core code. Also don't output
warning when ENODEV is error code in usbhid and try ordinal input in hidp
when that error is returned.
Next step for complete hid bus, this patch includes:
- call parser either from probe or from hid-core if there is no probe.
- add ll_driver structure and centralize some stuff there (open, close...)
- split and merge usb_hid_configure and hid_probe into several functions
to allow hooks/fixes between them
Make a bus from hid core. This is the first step for converting all the
quirks and separate almost-drivers into real drivers attached to this bus.
It's implemented to change behaviour in very tiny manner, so that no driver
needs to be changed this time.
Also add generic drivers for both usb and bt into usbhid or hidp
respectively which will bind all non-blacklisted device. Those blacklisted
will be either grabbed by special drivers or by nobody if they are broken at
the very rude base.
When using the HIDP or BNEP kernel support, the user-space needs to
know if the connection has been terminated for some reasons. Wake up
the application if that happens. Otherwise kernel and user-space are
no longer on the same page and weird behaviors can happen.
Remove all those inlines which were either a) unneeded or b) increased code
size.
before: 6997 74 8 7079 1ba7 net/bluetooth/hidp/core.o
after: 6492 74 8 6574 19ae net/bluetooth/hidp/core.o
According to the bluetooth HID spec v1.0 chapter 7.4.2
"This code requests a major state change in a BT-HID device. A HID_CONTROL
request does not generate a HANDSHAKE response."
"A HID_CONTROL packet with a parameter of VIRTUAL_CABLE_UNPLUG is the only
HID_CONTROL packet a device can send to a host. A host will ignore all other
packets."
So in the hidp_precess_hid_control function, we just need to deal with the
UNLUG packet.
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Many-many code in the kernel initialized the timer->function
and timer->data together with calling init_timer(timer). There
is already a helper for this. Use it for networking code.
The patch is HUGE, but makes the code 130 lines shorter
(98 insertions(+), 228 deletions(-)).
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
In the debug code of the hidp_queue_report function, the device
variable does not exist, replace it with session->hid.
get rid of input BIT* duplicate defines
use newly global defined macros for input layer. Also remove includes of
input.h from non-input sources only for BIT macro definiton. Define the
macro temporarily in local manner, all those local definitons will be
removed further in this patchset (to not break bisecting).
BIT macro will be globally defined (1<<x)
Cc: <dtor@mail.ru>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Cc: <lenb@kernel.org>
Cc: <perex@suse.cz>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: <vernux@us.ibm.com>
Cc: <malattia@linux.it>
This patch:
- makes hidp_setup_input() return int to indicate errors;
- checks its return value to handle errors.
And this time it is against -rc7-mm1 tree.
Thanks to roel and Marcel Holtmann for comments.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Currently, the freezer treats all tasks as freezable, except for the kernel
threads that explicitly set the PF_NOFREEZE flag for themselves. This
approach is problematic, since it requires every kernel thread to either
set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't
care for the freezing of tasks at all.
It seems better to only require the kernel threads that want to or need to
be frozen to use some freezer-related code and to remove any
freezer-related code from the other (nonfreezable) kernel threads, which is
done in this patch.
The patch causes all kernel threads to be nonfreezable by default (ie. to
have PF_NOFREEZE set by default) and introduces the set_freezable()
function that should be called by the freezable kernel threads in order to
unset PF_NOFREEZE. It also makes all of the currently freezable kernel
threads call set_freezable(), so it shouldn't cause any (intentional)
change of behaviour to appear. Additionally, it updates documentation to
describe the freezing of tasks more accurately.
[akpm@linux-foundation.org: build fixes]
Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Gautham R Shenoy <ego@in.ibm.com>
When cleaning up HIDP sessions, we currently close the ACL connection
before deregistering the input device. Closing the ACL connection
schedules a workqueue to remove the associated objects from sysfs, but
the input device still refers to them -- and if the workqueue happens to
run before the input device removal, the kernel will oops when trying to
look up PHYSDEVPATH for the removed input device.
Fix this by deregistering the input device before closing the
connections.
master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid
* 'upstream-fixes' of master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid:
USB HID: hiddev - fix race between hiddev_send_event() and hiddev_release()
HID: add hooks for getkeycode() and setkeycode() methods
HID: switch to using input_dev->dev.parent
USB HID: Logitech wheel 0x046d/0xc294 needs HID_QUIRK_NOGET quirk
USB HID: usb_buffer_free() cleanup
USB HID: report descriptor of Cypress USB barcode readers needs fixup
Bluetooth HID: HIDP - don't initialize force feedback
USB HID: update CONFIG_USB_HIDINPUT_POWERBOOK description
HID: add input mappings for non-working keys on Logitech S510 remote
In preparation for struct class_device -> struct device input core
conversion, switch to using input_dev->dev.parent when specifying
device position in sysfs tree.
Also, do not access input_dev->private directly, use helpers and
do not use kfree() on input device, use input_free_device() instead.
The current implementation of force feedback for HID devices is
USB-transport only and therefore calling hid_ff_init() from hidp code is
not going to work (plus it creates unwanted dependency of hidp on usbhid).
Remove the hid_ff_init() until either the hid-ff is made
transport-independent, or at least support for bluetooth transport is
added.
I have a bugreport that scrollwheel of bluetooth version of apple
mightymouse doesn't work. The USB version of mightymouse works, as there
is a quirk for handling scrollwheel in hid/usbhid for it.
Now that bluetooth git tree is hooked to generic hid layer, it could easily
use the quirks which are already present in generic hid parser, hid-input,
etc.
Below is a simple patch against bluetooth git tree, which adds quirk
handling to current bluetooth hidp code, and sets quirk flags for device
0x05ac/0x030c, which is the bluetooth version of the apple mightymouse.
