path: root/net/bluetooth/hidp
2008-02-05bluetooth: uninliningAndrew Morton
Remove all those inlines which were either a) unneeded or b) increased code size. text data bss dec hex filename before: 6997 74 8 7079 1ba7 net/bluetooth/hidp/core.o after: 6492 74 8 6574 19ae net/bluetooth/hidp/core.o Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05bluetooth: hidp_process_hid_control remove unnecessary parameter dealingDave Young
According to the bluetooth HID spec v1.0 chapter 7.4.2 "This code requests a major state change in a BT-HID device. A HID_CONTROL request does not generate a HANDSHAKE response." "A HID_CONTROL packet with a parameter of VIRTUAL_CABLE_UNPLUG is the only HID_CONTROL packet a device can send to a host. A host will ignore all other packets." So in the hidp_precess_hid_control function, we just need to deal with the UNLUG packet. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BLUETOOTH]: Use sockfd_put()Julia Lawall
The function sockfd_lookup uses fget on the value that is stored in the file field of the returned structure, so fput should ultimately be applied to this value. This can be done directly, but it seems better to use the specific macro sockfd_put, which does the same thing. The problem was fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression s; @@ s = sockfd_lookup(...) ... + sockfd_put(s); ?- fput(s->file); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[Bluetooth] Fix wrong argument in debug code of HIDPDave Young
In the debug code of the hidp_queue_report function, the device variable does not exist, replace it with session->hid. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[BLUETOOTH]: Make hidp_setup_input() return intWANG Cong
This patch: - makes hidp_setup_input() return int to indicate errors; - checks its return value to handle errors. And this time it is against -rc7-mm1 tree. Thanks to roel and Marcel Holtmann for comments. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-07Fix use-after-free oops in Bluetooth HID.David Woodhouse
When cleaning up HIDP sessions, we currently close the ACL connection before deregistering the input device. Closing the ACL connection schedules a workqueue to remove the associated objects from sysfs, but the input device still refers to them -- and if the workqueue happens to run before the input device removal, the kernel will oops when trying to look up PHYSDEVPATH for the removed input device. Fix this by deregistering the input device before closing the connections. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Merge branch 'upstream-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid * 'upstream-fixes' of master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid: USB HID: hiddev - fix race between hiddev_send_event() and hiddev_release() HID: add hooks for getkeycode() and setkeycode() methods HID: switch to using input_dev->dev.parent USB HID: Logitech wheel 0x046d/0xc294 needs HID_QUIRK_NOGET quirk USB HID: usb_buffer_free() cleanup USB HID: report descriptor of Cypress USB barcode readers needs fixup Bluetooth HID: HIDP - don't initialize force feedback USB HID: update CONFIG_USB_HIDINPUT_POWERBOOK description HID: add input mappings for non-working keys on Logitech S510 remote
2007-05-10[Bluetooth] Switch to using input_dev->dev.parentMarcel Holtmann
In preparation for struct class_device -> struct device input core conversion, switch to using input_dev->dev.parent when specifying device position in sysfs tree. Also, do not access input_dev->private directly, use helpers and do not use kfree() on input device, use input_free_device() instead. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-09Bluetooth HID: HIDP - don't initialize force feedbackJiri Kosina
The current implementation of force feedback for HID devices is USB-transport only and therefore calling hid_ff_init() from hidp code is not going to work (plus it creates unwanted dependency of hidp on usbhid). Remove the hid_ff_init() until either the hid-ff is made transport-independent, or at least support for bluetooth transport is added. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-03-29[PATCH] bluetooth hid quirks: mightymouse quirkJiri Kosina
I have a bugreport that scrollwheel of bluetooth version of apple mightymouse doesn't work. The USB version of mightymouse works, as there is a quirk for handling scrollwheel in hid/usbhid for it. Now that bluetooth git tree is hooked to generic hid layer, it could easily use the quirks which are already present in generic hid parser, hid-input, etc. Below is a simple patch against bluetooth git tree, which adds quirk handling to current bluetooth hidp code, and sets quirk flags for device 0x05ac/0x030c, which is the bluetooth version of the apple mightymouse. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-22[NET]: fix up misplaced inlines.Dave Jones
Turning up the warnings on gcc makes it emit warnings about the placement of 'inline' in function declarations. Here's everything that was under net/ Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-26[Bluetooth] Add open and close callbacks for HID deviceMarcel Holtmann
The open and close callbacks for the HID device are not optional, but for the Bluetooth HID report mode support it is enough to add empty dummy callbacks. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-02-26[Bluetooth] Add support for using the HID subsystemMarcel Holtmann
This patch extends the current Bluetooth HID support to use the new HID subsystem and adds full report mode support. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-02-26[Bluetooth] Fix wrong put_user() from HIDP compat ioctl patchMarcel Holtmann
The compat ioctl patch copied the parser version field into the report descriptor size field by mistake. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-02-10[NET] BLUETOOTH: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-09[PATCH] hidp __user annotationsAl Viro
2006-10-20[Bluetooth] Fix HID disconnect NULL pointer dereferenceMarcel Holtmann
The latest HID disconnect sequence change introduced a NULL pointer dereference. For the quirk to handle buggy remote HID implementations, it is enough to wait for a potential control channel disconnect from the remote side and it is also enough to wait only 500 msecs. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-10-15[Bluetooth] Add locking for bt_proto array manipulationMarcel Holtmann
The bt_proto array needs to be protected by some kind of locking to prevent a race condition between bt_sock_create and bt_sock_register. And in addition all calls to sk_alloc need to be made GFP_ATOMIC now. Signed-off-by: Masatake YAMATO <jet@gyve.org> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-10-15[Bluetooth] Fix reference count when connection lookup failsMarcel Holtmann
When the connection lookup for the device structure fails, the reference count for the HCI device needs to be decremented. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-10-15[Bluetooth] Disconnect HID interrupt channel firstMarcel Holtmann
The Bluetooth HID specification demands that the interrupt channel shall be disconnected first. This is needed to pass the qualification tests. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-10-15[Bluetooth] Fix compat ioctl for BNEP, CMTP and HIDPMarcel Holtmann
There exists no attempt do deal with the fact that a structure with a uint32_t followed by a pointer is going to be different for 32-bit and 64-bit userspace. Any 32-bit process trying to use it will be failing with -EFAULT if it's lucky; suffering from having data dumped at a random address if it's not. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-09-28[Bluetooth] Integrate services into the driver modelMarcel Holtmann
This patch integrates the services of the Bluetooth protocols RFCOMM, BNEP and HIDP into the driver model. This makes it possible to assign the virtual TTY, network and input devices to a specific Bluetooth connection. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-12[Bluetooth] Let BT_HIDP depend on INPUTMarcel Holtmann
This patch lets BT_HIDP depend on instead of select INPUT. This fixes the following warning during an s390 build: net/bluetooth/hidp/Kconfig:4:warning: 'select' used by config symbol 'BT_HIDP' refer to undefined symbol 'INPUT' A dependency on INPUT also implies !S390 (and therefore makes the explicit dependency obsolete) since INPUT is not available on s390. The practical difference should be nearly zero, since INPUT is always set to y unless EMBEDDED=y (or S390=y). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-12[Bluetooth] Remaining transitions to use kzalloc()Marcel Holtmann
This patch makes the remaining transitions to use kzalloc(). Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[NET]: kfree cleanupJesper Juhl
From: Jesper Juhl <jesper.juhl@gmail.com> This is the net/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in net/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-29[PATCH] bluetooth hidp is broken on s390Al Viro
Bluetooth HIDP selects INPUT and it really needs it to be there - module depends on input core. And input core is never built on s390... Marked as broken on s390, for now; if somebody has better ideas, feel free to fix it and remove dependency... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] Input: convert net/bluetooth to dynamic input_dev allocationDmitry Torokhov
Input: convert net/bluetooth to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-08[NET]: Transform skb_queue_len() binary tests into skb_queue_empty()David S. Miller
This is part of the grand scheme to eliminate the qlen member of skb_queue_head, and subsequently remove the 'list' member of sk_buff. Most users of skb_queue_len() want to know if the queue is empty or not, and that's trivially done with skb_queue_empty() which doesn't use the skb_queue_head->qlen member and instead uses the queue list emptyness as the test. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-25[PATCH] kill gratitious includes of major.h under net/*Al Viro
A lot of places in there are including major.h for no reason whatsoever. Removed. And yes, it still builds. The history of that stuff is often amusing. E.g. for net/core/sock.c the story looks so, as far as I've been able to reconstruct it: we used to need major.h in net/socket.c circa 1.1.early. In 1.1.13 that need had disappeared, along with register_chrdev(SOCKET_MAJOR, "socket", &net_fops) in sock_init(). Include had not. When 1.2 -> 1.3 reorg of net/* had moved a lot of stuff from net/socket.c to net/core/sock.c, this crap had followed... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
