This is long overdue, and is part of cleaning up how we allocate kernel
sockets that don't reference count struct net.
The RFCOMM_PSM constant is actually a duplicate. So remove it and
use the L2CAP_PSM_RFCOMM constant instead.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Pull networking updates from David Miller:
1) New offloading infrastructure and example 'rocker' driver for
offloading of switching and routing to hardware.
This work was done by a large group of dedicated individuals, not
limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend,
Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu
2) Start making the networking operate on IOV iterators instead of
modifying iov objects in-situ during transfers. Thanks to Al Viro
and Herbert Xu.
3) A set of new netlink interfaces for the TIPC stack, from Richard
Alpe.
4) Remove unnecessary looping during ipv6 routing lookups, from Martin
KaFai Lau.
5) Add PAUSE frame generation support to gianfar driver, from Matei
Pavaluca.
6) Allow for larger reordering levels in TCP, which are easily
achievable in the real world right now, from Eric Dumazet.
7) Add a variable of napi_schedule that doesn't need to disable cpu
interrupts, from Eric Dumazet.
8) Use a doubly linked list to optimize neigh_parms_release(), from
Nicolas Dichtel.
9) Various enhancements to the kernel BPF verifier, and allow eBPF
programs to actually be attached to sockets. From Alexei
Starovoitov.
10) Support TSO/LSO in sunvnet driver, from David L Stevens.
11) Allow controlling ECN usage via routing metrics, from Florian
Westphal.
12) Remote checksum offload, from Tom Herbert.
13) Add split-header receive, BQL, and xmit_more support to amd-xgbe
driver, from Thomas Lendacky.
14) Add MPLS support to openvswitch, from Simon Horman.
15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen
Klassert.
16) Do gro flushes on a per-device basis using a timer, from Eric
Dumazet. This tries to resolve the conflicting goals between the
desired handling of bulk vs. RPC-like traffic.
17) Allow userspace to ask for the CPU upon what a packet was
received/steered, via SO_INCOMING_CPU. From Eric Dumazet.
18) Limit GSO packets to half the current congestion window, from Eric
Dumazet.
19) Add a generic helper so that all drivers set their RSS keys in a
consistent way, from Eric Dumazet.
20) Add xmit_more support to enic driver, from Govindarajulu
Varadarajan.
21) Add VLAN packet scheduler action, from Jiri Pirko.
22) Support configurable RSS hash functions via ethtool, from Eyal
Perry.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits)
Fix race condition between vxlan_sock_add and vxlan_sock_release
net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header
net/mlx4: Add support for A0 steering
net/mlx4: Refactor QUERY_PORT
net/mlx4_core: Add explicit error message when rule doesn't meet configuration
net/mlx4: Add A0 hybrid steering
net/mlx4: Add mlx4_bitmap zone allocator
net/mlx4: Add a check if there are too many reserved QPs
net/mlx4: Change QP allocation scheme
net/mlx4_core: Use tasklet for user-space CQ completion events
net/mlx4_core: Mask out host side virtualization features for guests
net/mlx4_en: Set csum level for encapsulated packets
be2net: Export tunnel offloads only when a VxLAN tunnel is created
gianfar: Fix dma check map error when DMA_API_DEBUG is enabled
cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call
net: fec: only enable mdio interrupt before phy device link up
net: fec: clear all interrupt events to support i.MX6SX
net: fec: reset fep link status in suspend function
net: sock: fix access via invalid file descriptor
net: introduce helper macro for_each_cmsghdr
This patch fixes the following sparse warnings in rfcomm/core.c:
net/bluetooth/rfcomm/core.c:391:16: warning: dubious: x | !y
net/bluetooth/rfcomm/core.c:546:24: warning: dubious: x | !y
rfcomm_run() is a tad broken in that is has a nested wait loop. One
cannot rely on p->state for the outer wait because the inner wait will
overwrite it.
Fix this using the new wait_woken() facility.
Cc: Peter Hurley <peter@hurleysoftware.com>
Cc: Alexander Holler <holler@ahsoftware.de>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Joe Perches <joe@perches.com>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: Libor Pechacek <lpechacek@suse.cz>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Seung-Woo Kim <sw0312.kim@samsung.com>
Cc: Vignesh Raman <Vignesh_Raman@mentor.com>
Cc: linux-bluetooth@vger.kernel.org
Cc: netdev@vger.kernel.org
Value returned by this macro might be used as bit value so it should
return either 0 or 1 to avoid possible bugs (similar to NSC bug)
when shifting it.
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
rfcomm_send_nsc expects CR to be either 0 or 1 since it is later
passed to __mcc_type macro and shitfed. Unfortunatelly CR extracted
from received frame type was not sanitized and shifted value was passed
resulting in bogus response.
Note: shifted value was also passed to other functions but was used
only in if satements so this bug appears only for NSC case.
The CR bit in the value octet shall be set to the same value
as the CR bit in the type field octet of the not supported command
frame but the CR bit for NCS response should be set to 0 since it is
always a response.
This was affecting TC_RFC_BV_25_C PTS qualification test.
The commits 08c30aca9e698faddebd34f81e1196295f9dc063 "Bluetooth: Remove
RFCOMM session refcnt" and 8ff52f7d04d9cc31f1e81dcf9a2ba6335ed34905
"Bluetooth: Return RFCOMM session ptrs to avoid freed session"
allow rfcomm_recv_ua and rfcomm_session_close to delete the session
(and free the corresponding socket) and propagate NULL session pointer
to the upper callers.
Additional fix is required to terminate the loop in rfcomm_process_rx
function to avoid use of freed 'sk' memory.
The issue is only reproducible with kernel option CONFIG_PAGE_POISONING
enabled making freed memory being changed and filled up with fixed char
value used to unmask use-after-free issues.
Signed-off-by: Vignesh Raman <Vignesh_Raman@mentor.com>
Signed-off-by: Vitaly Kuzmichev <Vitaly_Kuzmichev@mentor.com>
Acked-by: Dean Jenkins <Dean_Jenkins@mentor.com>
Cc: stable@vger.kernel.org
We're interested in whether an authentication request is because of a
remote or local action. So far hci_conn_security() has been used both
for incoming and outgoing actions (e.g. RFCOMM or L2CAP connect
requests) so without some modifications it cannot know which peer is
responsible for requesting authentication.
This patch adds a new "bool initiator" parameter to hci_conn_security()
to indicate which side is responsible for the request and updates the
current users to pass this information correspondingly.
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
drivers/bluetooth/btusb.c
Enabling CONFIG_DEBUG_ATOMIC_SLEEP has shown that some rfcomm functions
acquiring spinlocks call sleeping locks further in the chain. Converting
the offending spinlocks into mutexes makes sleeping safe.
Signed-off-by: Libor Pechacek <lpechacek@suse.cz>
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
The use of __constant_<foo> has been unnecessary for quite awhile now.
Make these uses consistent with the rest of the kernel.
The tty driver api design prefers no-fail writes if the driver
write_room() method has previously indicated space is available
to accept writes. Since this is trivially possible for the
RFCOMM tty driver, do so.
Introduce rfcomm_dlc_send_noerror(), which queues but does not
schedule the krfcomm thread if the dlc is not yet connected
(and thus does not error based on the connection state).
The mtu size test is also unnecessary since the caller already
chunks the written data into mtu size.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Tested-By: Alexander Holler <holler@ahsoftware.de>
If the RFCOMM session has not yet been started (ie., session is
still in BT_BOUND state) when a dlc is closed, directly close and
unlink the dlc rather than sending a DISC frame that is never
sent.
This allows the dlci to be immediately reused rather than waiting
for a 20 second timeout.
Prepare for directly closing dlc if the RFCOMM session has not
yet been started; refactor the dlc disconnect logic into a separate
local function, __rfcomm_dlc_disconn(). Retains functional
equivalence.
yet been started; refactor the deferred setup test for only those
dlc states to which the test applies. Retains functional
equivalence.
Merge conditional test for BT_LISTEN session state into following
switch statement (which is functionally equivalent).
Only one session/channel combination may be in use at any one
time. However, the failure does not occur until the tty is
opened (in rfcomm_dlc_open()).
Because these settings are actually bound at rfcomm device
creation (via RFCOMMCREATEDEV ioctl), validate and fail before
creating the rfcomm tty device.
With the introduction of security level 4, the RFCOMM sockets need to
be made aware of this new level. This change ensures that the pairing
requirements are set correctly for these connections.
L2CAP socket validates proper bdaddr_type for connect, so this
patch fixes to set explictly bdaddr_type for RFCOMM connect.
Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
L2CAP socket bind checks its bdaddr type but RFCOMM kernel thread
does not assign proper bdaddr type for L2CAP sock. This can cause
that RFCOMM failure.
Make sure to use IS_ERR_OR_NULL for checking the existing of the root
debugfs dentry bt_debugfs.
The L2CAP socket structure does not contain the address information
anymore. They need to be accessed through the L2CAP channel.
Fix to return a negative error code from the error handling
case instead of 0, as returned elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
rfcomm_session_close() sets the RFCOMM session state to BT_CLOSED.
However, in multiple places immediately before the function is
called, the RFCOMM session is set to BT_CLOSED. Therefore,
remove these unnecessary state settings.
Signed-off-by: Dean Jenkins <Dean_Jenkins@mentor.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
In rfcomm_session_del() remove the redundant call to
rfcomm_send_disc() because it is not possible for the
session to be in BT_CONNECTED state during deletion
of the session.
Previous commits have improved the handling of the RFCOMM session
timer and the RFCOMM session pointers such that freed RFCOMM
session structures should no longer be erroneously accessed. The
RFCOMM session refcnt now has no purpose and will be deleted by
this commit.
Note that the RFCOMM session is now deleted as soon as the
RFCOMM control channel link is no longer required. This makes the
lifetime of the RFCOMM session deterministic and absolute.
Previously with the refcnt, there was uncertainty about when
the session structure would be deleted because the relative
refcnt prevented the session structure from being deleted at will.
It was noted that the refcnt could malfunction under very heavy
real-time processor loading in embedded SMP environments. This
could cause premature RFCOMM session deletion or double session
deletion that could result in kernel crashes. Removal of the
refcnt prevents this issue.
There are 4 connection / disconnection RFCOMM session scenarios:
host initiated control link ---> host disconnected control link
host initiated ctrl link ---> remote device disconnected ctrl link
remote device initiated ctrl link ---> host disconnected ctrl link
remote device initiated ctrl link ---> remote device disc'ed ctrl link
The control channel connection procedures are independent of the
disconnection procedures. Strangely, the RFCOMM session refcnt was
applying special treatment so erroneously combining connection and
disconnection events. This commit fixes this issue by removing
some session code that used the "initiator" member of the session
structure that was intended for use with the data channels.
Unfortunately, the design retains local copies of the s RFCOMM
session pointer in various code blocks and this invites the erroneous
access to a freed RFCOMM session structure.
Therefore, return the RFCOMM session pointer back up the call stack
to avoid accessing a freed RFCOMM session structure. When the RFCOMM
session is deleted, NULL is passed up the call stack.
If active DLCs exist when the rfcomm session is terminating,
avoid a memory leak of rfcomm_dlc structures by ensuring that
rfcomm_session_close() is used instead of rfcomm_session_del().
A race condition exists between near simultaneous asynchronous
DLC data channel disconnection requests from the host and remote device.
This causes the socket layer to request a socket shutdown at the same
time the rfcomm core is processing the disconnect request from the remote
device.
The socket layer retains a copy of a struct rfcomm_dlc d pointer.
The d pointer refers to a copy of a struct rfcomm_session.
When the socket layer thread performs a socket shutdown, the thread
may wait on a rfcomm lock in rfcomm_dlc_close(). This means that
whilst the thread waits, the rfcomm_session and/or rfcomm_dlc structures
pointed to by d maybe freed due to rfcomm core handling. Consequently,
when the rfcomm lock becomes available and the thread runs, a
malfunction could occur as a freed rfcomm_session structure and/or a
freed rfcomm_dlc structure will be erroneously accessed.
Therefore, after the rfcomm lock is acquired, check that the struct
rfcomm_session is still valid by searching the rfcomm session list.
If the session is valid then validate the d pointer by searching the
rfcomm session list of active DLCs for the rfcomm_dlc structure
pointed by d.
Use del_timer_sync() instead of del_timer() as this ensures
that rfcomm_session_timeout() is not running on a different
CPU when rfcomm_session_put() is called. This avoids a race
condition on SMP systems because potentially
rfcomm_session_timeout() could reuse the freed RFCOMM session
structure caused by the execution of rfcomm_session_put().
Note that this modification makes the reason for the RFCOMM
session refcnt mechanism redundant.
As in del_timer() there has already placed a timer_pending() function
to check whether the timer to be deleted is pending or not, it's
unnecessary to check timer pending state again before del_timer() is
called.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Cc: Eric Dumazet <edumazet@google.com>
Since the RFCOMM_PSM is constant, __constant_cpu_to_le16() is
the right go here.
Signed-off-by: Syam Sidhardhan <s.syam@samsung.com>
Instead of old unsafe batostr function use %pMR print specifier
for printing Bluetooth addresses in sprintf and seq_printf
statements.
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com>
for printing Bluetooth addresses in debug and error statements.
Most of the include were unnecessary or already included by some other
header.
Replace module.h by export.h where possible.
Only obvious cases were left as inline, mostly oneline functions.
There is an imbalance in the rfcomm_session_hold / rfcomm_session_put
operations which causes the following crash:
[ 685.010159] BUG: unable to handle kernel paging request at 6b6b6b6b
[ 685.010169] IP: [<c149d76d>] rfcomm_process_dlcs+0x1b/0x15e
[ 685.010181] *pdpt = 000000002d665001 *pde = 0000000000000000
[ 685.010191] Oops: 0000 [#1] PREEMPT SMP
[ 685.010247]
[ 685.010255] Pid: 947, comm: krfcommd Tainted: G C 3.0.16-mid8-dirty #44
[ 685.010266] EIP: 0060:[<c149d76d>] EFLAGS: 00010246 CPU: 1
[ 685.010274] EIP is at rfcomm_process_dlcs+0x1b/0x15e
[ 685.010281] EAX: e79f551c EBX: 6b6b6b6b ECX: 00000007 EDX: e79f40b4
[ 685.010288] ESI: e79f4060 EDI: ed4e1f70 EBP: ed4e1f68 ESP: ed4e1f50
[ 685.010295] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 685.010303] Process krfcommd (pid: 947, ti=ed4e0000 task=ed43e5e0 task.ti=ed4e0000)
[ 685.010308] Stack:
[ 685.010312] ed4e1f68 c149eb53 e5925150 e79f4060 ed500000 ed4e1f70 ed4e1f80 c149ec10
[ 685.010331] 00000000 ed43e5e0 00000000 ed4e1f90 ed4e1f9c c149ec87 0000bf54 00000000
[ 685.010348] 00000000 ee03bf54 c149ec37 ed4e1fe4 c104fe01 00000000 00000000 00000000
[ 685.010367] Call Trace:
[ 685.010376] [<c149eb53>] ? rfcomm_process_rx+0x6e/0x74
[ 685.010387] [<c149ec10>] rfcomm_process_sessions+0xb7/0xde
[ 685.010398] [<c149ec87>] rfcomm_run+0x50/0x6d
[ 685.010409] [<c149ec37>] ? rfcomm_process_sessions+0xde/0xde
[ 685.010419] [<c104fe01>] kthread+0x63/0x68
[ 685.010431] [<c104fd9e>] ? __init_kthread_worker+0x42/0x42
[ 685.010442] [<c14dae82>] kernel_thread_helper+0x6/0xd
This issue has been brought up earlier here:
https://lkml.org/lkml/2011/5/21/127
The issue appears to be the rfcomm_session_put in rfcomm_recv_ua. This
operation doesn't seem be to required as for the non-initiator case we
have the rfcomm_process_rx doing an explicit put and in the initiator
case the last dlc_unlink will drive the reference counter to 0.
There have been several attempts to fix these issue:
6c2718d Bluetooth: Do not call rfcomm_session_put() for RFCOMM UA on closed socket
683d949 Bluetooth: Never deallocate a session when some DLC points to it
but AFAICS they do not fix the issue just make it harder to reproduce.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
Signed-off-by: Gopala Krishna Murala <gopala.krishna.murala@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
drivers/net/wireless/b43/dma.c
drivers/net/wireless/brcm80211/brcmfmac/dhd_linux.c
sock and sk were leftover from another change.
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
net/bluetooth/l2cap_core.c
Just two overlapping changes, one added an initialization of
a local variable, and another change added a new local variable.
RFCOMM needs a proper priority mechanism inside itself and not try to use
l2cap priority to fix its own problem.
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
(Thanks to Joe Perches for suggesting coccinelle for 0/1 -> true/false).
When the last RFCOMM data channel is closed, a timer is normally set
up to disconnect the control channel at a later time. If the control
channel disconnect command is sent with the timer pending, the timer
needs to be cancelled.
If the timer is not cancelled in this situation, the reference
counting logic for the RFCOMM session does not work correctly when the
remote device closes the L2CAP connection. The session is freed at
the wrong time, leading to a kernel panic.
Signed-off-by: Mat Martineau <mathewm@codeaurora.org>
This was triggered by turning off encryption on ACL link when rfcomm
was using high security. rfcomm_security_cfm (which is called from rx
task) was closing DLC and this involves sending disconnect message
(and locking socket).
Move closing DLC to rfcomm_process_dlcs and only flag DLC for closure
in rfcomm_security_cfm.
BUG: sleeping function called from invalid context at net/core/sock.c:2032
in_atomic(): 1, irqs_disabled(): 0, pid: 1788, name: kworker/0:3
[<c0068a08>] (unwind_backtrace+0x0/0x108) from [<c05e25dc>] (dump_stack+0x20/0x24)
[<c05e25dc>] (dump_stack+0x20/0x24) from [<c0087ba8>] (__might_sleep+0x110/0x12c)
[<c0087ba8>] (__might_sleep+0x110/0x12c) from [<c04801d8>] (lock_sock_nested+0x2c/0x64)
[<c04801d8>] (lock_sock_nested+0x2c/0x64) from [<c05670c8>] (l2cap_sock_sendmsg+0x58/0xcc)
[<c05670c8>] (l2cap_sock_sendmsg+0x58/0xcc) from [<c047cf6c>] (sock_sendmsg+0xb0/0xd0)
[<c047cf6c>] (sock_sendmsg+0xb0/0xd0) from [<c047cfc8>] (kernel_sendmsg+0x3c/0x44)
[<c047cfc8>] (kernel_sendmsg+0x3c/0x44) from [<c056b0e8>] (rfcomm_send_frame+0x50/0x58)
[<c056b0e8>] (rfcomm_send_frame+0x50/0x58) from [<c056b168>] (rfcomm_send_disc+0x78/0x80)
[<c056b168>] (rfcomm_send_disc+0x78/0x80) from [<c056b9f4>] (__rfcomm_dlc_close+0x2d0/0x2fc)
[<c056b9f4>] (__rfcomm_dlc_close+0x2d0/0x2fc) from [<c056bbac>] (rfcomm_security_cfm+0x140/0x1e0)
[<c056bbac>] (rfcomm_security_cfm+0x140/0x1e0) from [<c0555ec0>] (hci_event_packet+0x1ce8/0x4d84)
[<c0555ec0>] (hci_event_packet+0x1ce8/0x4d84) from [<c0550380>] (hci_rx_task+0x1d0/0x2d0)
[<c0550380>] (hci_rx_task+0x1d0/0x2d0) from [<c009ee04>] (tasklet_action+0x138/0x1e4)
[<c009ee04>] (tasklet_action+0x138/0x1e4) from [<c009f21c>] (__do_softirq+0xcc/0x274)
[<c009f21c>] (__do_softirq+0xcc/0x274) from [<c009f6c0>] (do_softirq+0x60/0x6c)
[<c009f6c0>] (do_softirq+0x60/0x6c) from [<c009f794>] (local_bh_enable_ip+0xc8/0xd4)
[<c009f794>] (local_bh_enable_ip+0xc8/0xd4) from [<c05e5804>] (_raw_spin_unlock_bh+0x48/0x4c)
[<c05e5804>] (_raw_spin_unlock_bh+0x48/0x4c) from [<c040d470>] (data_from_chip+0xf4/0xaec)
[<c040d470>] (data_from_chip+0xf4/0xaec) from [<c04136c0>] (send_skb_to_core+0x40/0x178)
[<c04136c0>] (send_skb_to_core+0x40/0x178) from [<c04139f4>] (cg2900_hu_receive+0x15c/0x2d0)
[<c04139f4>] (cg2900_hu_receive+0x15c/0x2d0) from [<c0414cb8>] (hci_uart_tty_receive+0x74/0xa0)
[<c0414cb8>] (hci_uart_tty_receive+0x74/0xa0) from [<c02cbd9c>] (flush_to_ldisc+0x188/0x198)
[<c02cbd9c>] (flush_to_ldisc+0x188/0x198) from [<c00b2774>] (process_one_work+0x144/0x4b8)
[<c00b2774>] (process_one_work+0x144/0x4b8) from [<c00b2e8c>] (worker_thread+0x198/0x468)
[<c00b2e8c>] (worker_thread+0x198/0x468) from [<c00b9bc8>] (kthread+0x98/0xa0)
[<c00b9bc8>] (kthread+0x98/0xa0) from [<c0061744>] (kernel_thread_exit+0x0/0x8)
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
When all items in the list have the same type there is no much of a point
to use list_for_each except if you want to use the list pointer itself.
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth
