path: root/net/bluetooth/rfcomm/tty.c
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-02-17tty: now phase out the ioctl file pointer for goodAlan Cox
Only oddities here are a couple of drivers that bogusly called the ldisc helpers instead of returning -ENOIOCTLCMD. Fix the bug and the rest goes away. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmset: kill the file pointer argumentAlan Cox
Doing tiocmget was such fun we should do tiocmset as well for the same reasons Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmget: kill off the passing of the struct fileAlan Cox
We don't actually need this and it causes problems for internal use of this functionality. Currently there is a single use of the FILE * pointer. That is the serial core which uses it to check tty_hung_up_p. However if that is true then IO_ERROR is also already set so the check may be removed. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-16Bluetooth: Release BTM while sleeping to avoid deadlockVladislav P
Signed-off-by: Vladislav P <vladisslav@inbox.ru> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2010-12-01Bluetooth: clean up rfcomm codeAndrei Emeltchenko
Remove extra spaces, assignments in if statement, zeroing static variables, extra braces. Fix includes. Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-22tty: icount changeover for other main devicesAlan Cox
Again basically cut and paste Convert the main driver set to use the hooks for GICOUNT Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-12Bluetooth: make batostr() print in the right orderGustavo F. Padovan
The Bluetooth core uses the the BD_ADDR in the opposite order from the human readable order. So we are changing batostr() to print in the correct order and then removing some baswap(), as they are not needed anymore. Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2010-07-31Bluetooth: Remove __exit from rfcomm_cleanup_ttys()Gustavo F. Padovan
rfcomm_cleanup_ttys() is also called from rfcomm_init(), so it can't have __exit. Reported-by: Mat Martineau <mathewm@codeaurora.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-07-27Bluetooth: Add __init and __exit marks to RFCOMMGustavo F. Padovan
Those annotation save memory and space on the binary. __init code is discarded just after execute and __exit code is discarded if the module is built into the kernel image or unload of modules is not allowed. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-01proc tty: remove struct tty_operations::read_procAlexey Dobriyan
struct tty_operations::proc_fops took it's place and there is one less create_proc_read_entry() user now! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24Driver core: Fix device_move() vs. dpm list ordering, v2Cornelia Huck
dpm_list currently relies on the fact that child devices will be registered after their parents to get a correct suspend order. Using device_move() however destroys this assumption, as an already registered device may be moved under a newly registered one. This patch adds a new argument to device_move(), allowing callers to specify how dpm_list should be adapted. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-14bt/rfcomm/tty: join error pathsIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-30Bluetooth: Fix RFCOMM release oops when device is still in useMarcel Holtmann
It turns out that the following sequence of actions will reproduce the oops: 1. Create a new RFCOMM device (using RFCOMMCREATEDEV ioctl) 2. (Try to) open the device 3. Release the RFCOMM device (using RFCOMMRELEASEDEV ioctl) At this point, the "/dev/rfcomm*" device is still in use, but it is gone from the internal list, so the device id can be reused. 4. Create a new RFCOMM device with the same device id as before And now kobject will complain that the TTY already exists. (See http://lkml.org/lkml/2008/7/13/89 for a reproducible test-case.) This patch attempts to correct this by only removing the device from the internal list of devices at the final unregister stage, so that the id won't get reused until the device has been completely destructed. This should be safe as the RFCOMM_TTY_RELEASED bit will be set for the device and prevent the device from being reopened after it has been released. Based on a report from Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-11-30Bluetooth: Enable per-module dynamic debug messagesMarcel Holtmann
With the introduction of CONFIG_DYNAMIC_PRINTK_DEBUG it is possible to allow debugging without having to recompile the kernel. This patch turns all BT_DBG() calls into pr_debug() to support dynamic debug messages. As a side effect all CONFIG_BT_*_DEBUG statements are now removed and some broken debug entries have been fixed. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-07-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (1232 commits) iucv: Fix bad merging. net_sched: Add size table for qdiscs net_sched: Add accessor function for packet length for qdiscs net_sched: Add qdisc_enqueue wrapper highmem: Export totalhigh_pages. ipv6 mcast: Omit redundant address family checks in ip6_mc_source(). net: Use standard structures for generic socket address structures. ipv6 netns: Make several "global" sysctl variables namespace aware. netns: Use net_eq() to compare net-namespaces for optimization. ipv6: remove unused macros from net/ipv6.h ipv6: remove unused parameter from ip6_ra_control tcp: fix kernel panic with listening_get_next tcp: Remove redundant checks when setting eff_sacks tcp: options clean up tcp: Fix MD5 signatures for non-linear skbs sctp: Update sctp global memory limit allocations. sctp: remove unnecessary byteshifting, calculate directly in big-endian sctp: Allow only 1 listening socket with SO_REUSEADDR sctp: Do not leak memory on multiple listen() calls sctp: Support ipv6only AF_INET6 sockets. ...
2008-07-20tty: Ldisc revampAlan Cox
Move the line disciplines towards a conventional ->ops arrangement. For the moment the actual 'tty_ldisc' struct in the tty is kept as part of the tty struct but this can then be changed if it turns out that when it all settles down we want to refcount ldiscs separately to the tty. Pull the ldisc code out of /proc and put it with our ldisc code. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6
2008-07-14[Bluetooth] Move pending packets from RFCOMM socket to TTYMarcel Holtmann
When an incoming RFCOMM socket connection gets converted into a TTY, it can happen that packets are lost. This mainly happens with the Handsfree profile where the remote side starts sending data right away. The problem is that these packets are in the socket receive queue. So when creating the TTY make sure to copy all pending packets from the socket receive queue to a private queue inside the TTY. To make this actually work, the flow control on the newly created TTY will be disabled and only enabled again when the TTY is opened by an application. And right before that, the pending packets will be put into the TTY flip buffer. Signed-off-by: Denis Kenzior <denis.kenzior@trolltech.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-07-14[Bluetooth] Store remote modem status for RFCOMM TTYMarcel Holtmann
When switching a RFCOMM socket to a TTY, the remote modem status might be needed later. Currently it is lost since the original configuration is done via the socket interface. So store the modem status and reply it when the socket has been converted to a TTY. Signed-off-by: Denis Kenzior <denis.kenzior@trolltech.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-07-14[Bluetooth] Use non-canonical TTY by default for RFCOMMMarcel Holtmann
While the RFCOMM TTY emulation can act like a real serial port, in reality it is not used like this. So to not mess up stupid applications, use the non-canonical mode by default. Signed-off-by: Denis Kenzior <denis.kenzior@trolltech.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03bluetooth: rfcomm_dev_state_change deadlock fixDave Young
There's logic in __rfcomm_dlc_close: rfcomm_dlc_lock(d); d->state = BT_CLOSED; d->state_changed(d, err); rfcomm_dlc_unlock(d); In rfcomm_dev_state_change, it's possible that rfcomm_dev_put try to take the dlc lock, then we will deadlock. Here fixed it by unlock dlc before rfcomm_dev_get in rfcomm_dev_state_change. why not unlock just before rfcomm_dev_put? it's because there's another problem. rfcomm_dev_get/rfcomm_dev_del will take rfcomm_dev_lock, but in rfcomm_dev_add the lock order is : rfcomm_dev_lock --> dlc lock so I unlock dlc before the taken of rfcomm_dev_lock. Actually it's a regression caused by commit 1905f6c736cb618e07eca0c96e60e3c024023428 ("bluetooth : __rfcomm_dlc_close lock fix"), the dlc state_change could be two callbacks : rfcomm_sk_state_change and rfcomm_dev_state_change. I missed the rfcomm_sk_state_change that time. Thanks Arjan van de Ven <arjan@linux.intel.com> for the effort in commit 4c8411f8c115def968820a4df6658ccfd55d7f1a ("bluetooth: fix locking bug in the rfcomm socket cleanup handling") but he missed the rfcomm_dev_state_change lock issue. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-01bluetooth : __rfcomm_dlc_close lock fixDave Young
Lockdep warning will be trigged while rfcomm connection closing. The locks taken in rfcomm_dev_add: rfcomm_dev_lock --> d->lock In __rfcomm_dlc_close: d->lock --> rfcomm_dev_lock (in rfcomm_dev_state_change) There's two way to fix it, one is in rfcomm_dev_add we first locking d->lock then the rfcomm_dev_lock The other (in this patch), remove the locking of d->lock for rfcomm_dev_state_change because just locking "d->state = BT_CLOSED;" is enough. [ 295.002046] ======================================================= [ 295.002046] [ INFO: possible circular locking dependency detected ] [ 295.002046] 2.6.25-rc7 #1 [ 295.002046] ------------------------------------------------------- [ 295.002046] krfcommd/2705 is trying to acquire lock: [ 295.002046] (rfcomm_dev_lock){-.--}, at: [<f89a090a>] rfcomm_dev_state_change+0x6a/0xd0 [rfcomm] [ 295.002046] [ 295.002046] but task is already holding lock: [ 295.002046] (&d->lock){--..}, at: [<f899c533>] __rfcomm_dlc_close+0x43/0xd0 [rfcomm] [ 295.002046] [ 295.002046] which lock already depends on the new lock. [ 295.002046] [ 295.002046] [ 295.002046] the existing dependency chain (in reverse order) is: [ 295.002046] [ 295.002046] -> #1 (&d->lock){--..}: [ 295.002046] [<c0149b23>] check_prev_add+0xd3/0x200 [ 295.002046] [<c0149ce5>] check_prevs_add+0x95/0xe0 [ 295.002046] [<c0149f6f>] validate_chain+0x23f/0x320 [ 295.002046] [<c014b7b1>] __lock_acquire+0x1c1/0x760 [ 295.002046] [<c014c349>] lock_acquire+0x79/0xb0 [ 295.002046] [<c03d6b99>] _spin_lock+0x39/0x80 [ 295.002046] [<f89a01c0>] rfcomm_dev_add+0x240/0x360 [rfcomm] [ 295.002046] [<f89a047e>] rfcomm_create_dev+0x6e/0xe0 [rfcomm] [ 295.002046] [<f89a0823>] rfcomm_dev_ioctl+0x33/0x60 [rfcomm] [ 295.002046] [<f899facc>] rfcomm_sock_ioctl+0x2c/0x50 [rfcomm] [ 295.002046] [<c0363d38>] sock_ioctl+0x118/0x240 [ 295.002046] [<c0194196>] vfs_ioctl+0x76/0x90 [ 295.002046] [<c0194446>] do_vfs_ioctl+0x56/0x140 [ 295.002046] [<c0194569>] sys_ioctl+0x39/0x60 [ 295.002046] [<c0104faa>] syscall_call+0x7/0xb [ 295.002046] [<ffffffff>] 0xffffffff [ 295.002046] [ 295.002046] -> #0 (rfcomm_dev_lock){-.--}: [ 295.002046] [<c0149a84>] check_prev_add+0x34/0x200 [ 295.002046] [<c0149ce5>] check_prevs_add+0x95/0xe0 [ 295.002046] [<c0149f6f>] validate_chain+0x23f/0x320 [ 295.002046] [<c014b7b1>] __lock_acquire+0x1c1/0x760 [ 295.002046] [<c014c349>] lock_acquire+0x79/0xb0 [ 295.002046] [<c03d6639>] _read_lock+0x39/0x80 [ 295.002046] [<f89a090a>] rfcomm_dev_state_change+0x6a/0xd0 [rfcomm] [ 295.002046] [<f899c548>] __rfcomm_dlc_close+0x58/0xd0 [rfcomm] [ 295.002046] [<f899d44f>] rfcomm_recv_ua+0x6f/0x120 [rfcomm] [ 295.002046] [<f899e061>] rfcomm_recv_frame+0x171/0x1e0 [rfcomm] [ 295.002046] [<f899e357>] rfcomm_run+0xe7/0x550 [rfcomm] [ 295.002046] [<c013c18c>] kthread+0x5c/0xa0 [ 295.002046] [<c0105c07>] kernel_thread_helper+0x7/0x10 [ 295.002046] [<ffffffff>] 0xffffffff [ 295.002046] [ 295.002046] other info that might help us debug this: [ 295.002046] [ 295.002046] 2 locks held by krfcommd/2705: [ 295.002046] #0: (rfcomm_mutex){--..}, at: [<f899e2eb>] rfcomm_run+0x7b/0x550 [rfcomm] [ 295.002046] #1: (&d->lock){--..}, at: [<f899c533>] __rfcomm_dlc_close+0x43/0xd0 [rfcomm] [ 295.002046] [ 295.002046] stack backtrace: [ 295.002046] Pid: 2705, comm: krfcommd Not tainted 2.6.25-rc7 #1 [ 295.002046] [<c0128a38>] ? printk+0x18/0x20 [ 295.002046] [<c014927f>] print_circular_bug_tail+0x6f/0x80 [ 295.002046] [<c0149a84>] check_prev_add+0x34/0x200 [ 295.002046] [<c0149ce5>] check_prevs_add+0x95/0xe0 [ 295.002046] [<c0149f6f>] validate_chain+0x23f/0x320 [ 295.002046] [<c014b7b1>] __lock_acquire+0x1c1/0x760 [ 295.002046] [<c014c349>] lock_acquire+0x79/0xb0 [ 295.002046] [<f89a090a>] ? rfcomm_dev_state_change+0x6a/0xd0 [rfcomm] [ 295.002046] [<c03d6639>] _read_lock+0x39/0x80 [ 295.002046] [<f89a090a>] ? rfcomm_dev_state_change+0x6a/0xd0 [rfcomm] [ 295.002046] [<f89a090a>] rfcomm_dev_state_change+0x6a/0xd0 [rfcomm] [ 295.002046] [<f899c548>] __rfcomm_dlc_close+0x58/0xd0 [rfcomm] [ 295.002046] [<f899d44f>] rfcomm_recv_ua+0x6f/0x120 [rfcomm] [ 295.002046] [<f899e061>] rfcomm_recv_frame+0x171/0x1e0 [rfcomm] [ 295.002046] [<c014abd9>] ? trace_hardirqs_on+0xb9/0x130 [ 295.002046] [<c03d6e89>] ? _spin_unlock_irqrestore+0x39/0x70 [ 295.002046] [<f899e357>] rfcomm_run+0xe7/0x550 [rfcomm] [ 295.002046] [<c03d4559>] ? __sched_text_start+0x229/0x4c0 [ 295.002046] [<c0120000>] ? cpu_avg_load_per_task+0x20/0x30 [ 295.002046] [<f899e270>] ? rfcomm_run+0x0/0x550 [rfcomm] [ 295.002046] [<c013c18c>] kthread+0x5c/0xa0 [ 295.002046] [<c013c130>] ? kthread+0x0/0xa0 [ 295.002046] [<c0105c07>] kernel_thread_helper+0x7/0x10 [ 295.002046] ======================= Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05bluetooth rfcomm tty: destroy before tty_close()Dave Young
rfcomm dev could be deleted in tty_hangup, so we must not call rfcomm_dev_del again to prevent from destroying rfcomm dev before tty close. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-23[BLUETOOTH]: Move children of connection device to NULL before connection down.Dave Young
The rfcomm tty device will possibly retain even when conn is down, and sysfs doesn't support zombie device moving, so this patch move the tty device before conn device is destroyed. For the bug refered please see : http://lkml.org/lkml/2007/12/28/87 Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-10[BLUETOOTH]: rfcomm tty BUG_ON() code fixDave Young
1) In tty.c the BUG_ON at line 115 will never be called, because the the before list_del_init in this same function. 115 BUG_ON(!list_empty(&dev->list)); So move the list_del_init to rfcomm_dev_del 2) The rfcomm_dev_del could be called from diffrent path (rfcomm_tty_hangup/rfcomm_dev_state_change/rfcomm_release_dev), So add another BUG_ON when the rfcomm_dev_del is called more than one time. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[Bluetooth] Add address and channel attribute to RFCOMM TTY deviceMarcel Holtmann
Export the remote device address and channel of RFCOMM TTY device via sysfs attributes. This allows udev to create better naming rules for configured RFCOMM devices. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-07-31[IRDA]: Fix rfcomm use-after-freeMarcel Holtmann
Adrian Bunk wrote: > Commit 8de0a15483b357d0f0b821330ec84d1660cadc4e added the following > use-after-free in net/bluetooth/rfcomm/tty.c: > > <-- snip --> > > ... > static int rfcomm_dev_add(struct rfcomm_dev_req *req, struct rfcomm_dlc *dlc) > { > ... > if (IS_ERR(dev->tty_dev)) { > list_del(&dev->list); > kfree(dev); > return PTR_ERR(dev->tty_dev); > } > ... > > <-- snip --> > > Spotted by the Coverity checker. really good catch. I fully overlooked that one. The attached patch should fix it. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11[Bluetooth] Keep rfcomm_dev on the list until it is freedVille Tervo
This patch changes the RFCOMM TTY release process so that the TTY is kept on the list until it is really freed. A new device flag is used to keep track of released TTYs. Signed-off-by: Ville Tervo <ville.tervo@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-07-11[Bluetooth] Hangup TTY before releasing rfcomm_devMikko Rapeli
The core problem is that RFCOMM socket layer ioctl can release rfcomm_dev struct while RFCOMM TTY layer is still actively using it. Calling tty_vhangup() is needed for a synchronous hangup before rfcomm_dev is freed. Addresses the oops at http://bugzilla.kernel.org/show_bug.cgi?id=7509 Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-05[Bluetooth] Check that device is in rfcomm_dev_list before deletingMarcel Holtmann
If RFCOMM_RELEASE_ONHUP flag is on and rfcomm_release_dev is called before connection is closed, rfcomm_dev is deleted twice from the rfcomm_dev_list and refcount is messed up. This patch adds a check before deleting device that the device actually is listed. Signed-off-by: Ville Tervo <ville.tervo@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-02-26[Bluetooth] Make use of device_move() for RFCOMM TTY devicesMarcel Holtmann
In the case of bound RFCOMM TTY devices the parent is not available before its usage. So when opening a RFCOMM TTY device, move it to the corresponding ACL device as a child. When closing the device, move it back to the virtual device tree. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-02-10[NET] BLUETOOTH: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-09[Bluetooth] More checks if DLC is still attached to the TTYMarcel Holtmann
If the DLC device is no longer attached to the TTY device, then return errors or default values for various callbacks of the TTY layer. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-21[Bluetooth] Check if RFCOMM session is still attached to the TTYMarcel Holtmann
If the RFCOMM session is no longer attached to the TTY device, then it makes no sense to go through with changing the termios settings. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-10-15[Bluetooth] Check if DLC is still attached to the TTYMarcel Holtmann
If the DLC device is no longer attached to the TTY device, then it makes no sense to go through with changing the termios settings. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-10-15[Bluetooth] Fix reference count when connection lookup failsMarcel Holtmann
When the connection lookup for the device structure fails, the reference count for the HCI device needs to be decremented. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-28[Bluetooth] Integrate services into the driver modelMarcel Holtmann
This patch integrates the services of the Bluetooth protocols RFCOMM, BNEP and HIDP into the driver model. This makes it possible to assign the virtual TTY, network and input devices to a specific Bluetooth connection. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-12[Bluetooth] Remaining transitions to use kzalloc()Marcel Holtmann
This patch makes the remaining transitions to use kzalloc(). Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-28[PATCH] remove TTY_DONT_FLIPPaul Fulghum
Remove TTY_DONT_FLIP tty flag. This flag was introduced in 2.1.X kernels to prevent the N_TTY line discipline functions read_chan() and n_tty_receive_buf() from running at the same time. 2.2.15 introduced tty->read_lock to protect access to the N_TTY read buffer, which is the only state requiring protection between these two functions. The current TTY_DONT_FLIP implementation is broken for SMP, and is not universally honored by drivers that send data directly to the line discipline receive_buf function. Because TTY_DONT_FLIP is not necessary, is broken in implementation, and is not universally honored, it is removed. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEVGreg Kroah-Hartman
I've always found this flag confusing. Now that devfs is no longer around, it has been renamed, and the documentation for when this flag should be used has been updated. Also fixes all drivers that use this flag. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
